    4. Zigbee Stick spinnt *gelöst*
      gluecksmann @reutli last edited by
      @reutli
      So, jetzt wieder die früherer Version drauf... aber kommt immer noch die Fehlermeldung wie ganz am Anfang... Einstellungen SInd...
      d7704ac8-c27a-49af-9395-2061addfc502-grafik.png ```
      3deeb232-5f57-4a77-a09a-429d8b588aa3-grafik.png code_text
        Frank579 @gluecksmann last edited by
        @gluecksmann jetzt nochmal komplett iob diag
        R G 2 Replies Last reply Reply Quote 0
          reutli @Frank579 last edited by reutli
          @gluecksmann
          davor auch mal reboot gemacht???
          debug modus im Adapter aktivieren...
          und dann den Adapter nochmals neustarten
          und dann
          @frank579 sagte in Zigbee Stick spinnt:
            gluecksmann @Frank579 last edited by
            @frank579
            *** BASE SYSTEM ***
              Static hostname: raspberrypi
                    Icon name: computer
             Operating System: Raspbian GNU/Linux 10 (buster)
                       Kernel: Linux 5.10.103-v7l+
                 Architecture: arm
            Model           : Raspberry Pi 4 Model B Rev 1.4
            Docker          : false
            Virtualization  : none
            Kernel          : armv7l
            Userland        : armhf
            Systemuptime and Load:
            17:33:54 up  3:22,  1 user,  load average: 0.68, 3.79, 4.41
            CPU threads: 4
            *** RASPBERRY THROTTLING ***
            Current issues:
            Previously detected issues:
            *** Time and Time Zones ***
                          Local time: Thu 2023-12-28 17:33:54 CET
                      Universal time: Thu 2023-12-28 16:33:54 UTC
                            RTC time: n/a
                         NTP service: active
                     RTC in local TZ: no
            *** User and Groups ***
            pi
            /home/pi
            pi adm dialout cdrom sudo audio video plugdev games users input netdev lpadmin gpio i2c spi iobroker
            *** X-Server-Setup ***
            X-Server:       false
            Desktop:
            Terminal:       tty
            Boot Target:    multi-user.target
            *** MEMORY ***
            Mem:           7.9G        1.6G        4.9G        8.0M        1.5G        6.1G
            Swap:           99M          0B         99M
            Total:         8.0G        1.6G        5.0G
                    7898 M total memory
                    1554 M used memory
                     300 M active memory
                    2506 M inactive memory
                    4885 M free memory
                     184 M buffer memory
                    1273 M swap cache
                      99 M total swap
                       0 M used swap
                      99 M free swap
            Raspberry only:
            oom events: 0
            *** FAILED SERVICES ***
             UNIT            LOAD   ACTIVE SUB    DESCRIPTION
            * lightdm.service loaded failed failed Light Display Manager
            LOAD   = Reflects whether the unit definition was properly loaded.
            ACTIVE = The high-level unit activation state, i.e. generalization of SUB.
            SUB    = The low-level unit activation state, values depend on unit type.
            1 loaded units listed. Pass --all to see loaded but inactive units, too.
            To show all installed unit files use 'systemctl list-unit-files'.
            *** FILESYSTEM ***
            /dev/root      ext4       29G   14G   15G  50% /
            devtmpfs       devtmpfs  3.7G     0  3.7G   0% /dev
            tmpfs          tmpfs     3.9G     0  3.9G   0% /dev/shm
            tmpfs          tmpfs     3.9G  8.5M  3.9G   1% /run
            tmpfs          tmpfs     3.9G     0  3.9G   0% /sys/fs/cgroup
            /dev/mmcblk0p1 vfat      253M   49M  204M  20% /boot
            tmpfs          tmpfs     790M     0  790M   0% /run/user/1000
            [Thu Dec 28 14:11:43 2023] Kernel command line: coherent_pool=1M 8250.nr_uarts=0 snd_bcm2835.enable_compat_alsa=0 snd_bcm2835.enable_hdmi=1  smsc95xx.macaddr=E4:5F:01:3D:9B:6E vc_mem.mem_base=0x3ec00000 vc_mem.mem_size=0x40000000  dwc_otg.lpm_enable=0 console=ttyS0,115200 console=tty1 root=PARTUUID=a372f35c-02 rootfstype=ext4 elevator=deadline fsck.repair=yes rootwait quiet splash plymouth.ignore-serial-consoles
            [Thu Dec 28 14:11:44 2023] EXT4-fs (mmcblk0p2): mounted filesystem with ordered data mode. Opts: (null)
            [Thu Dec 28 14:11:44 2023] VFS: Mounted root (ext4 filesystem) readonly on device 179:2.
            [Thu Dec 28 14:11:46 2023] EXT4-fs (mmcblk0p2): re-mounted. Opts: (null)
            TARGET        SOURCE         FSTYPE OPTIONS
            /             /dev/mmcblk0p2 ext4   rw,noatime
            |-/sys/fs/bpf none           bpf    rw,nosuid,nodev,noexec,relatime,mode=700
            `-/boot       /dev/mmcblk0p1 vfat   rw,relatime,fmask=0022,dmask=0022,codepage=437,iocharset=ascii,shortname=mixed,errors=remount-ro
            /var:
            413M    /var/
            118M    /var/lib
            102M    /var/cache
            91M     /var/log
            90M     /var/cache/apt
            Archived and active journals take up 8.0M in the file system.
            /opt/iobroker/backups:
            63M     /opt/iobroker/backups/
            /opt/iobroker/iobroker-data:
            621M    /opt/iobroker/iobroker-data/
            322M    /opt/iobroker/iobroker-data/files
            143M    /opt/iobroker/iobroker-data/backup-objects
            93M     /opt/iobroker/iobroker-data/sonosCache
            67M     /opt/iobroker/iobroker-data/files/javascript.admin
            35M     /opt/iobroker/iobroker-data/files/devices.admin/static/js/main.24f2bb56.js.map
            33M     /opt/iobroker/iobroker-data/files/iot.admin/static/js/main.1797d034.js.map
            30M     /opt/iobroker/iobroker-data/objects.jsonl
            21M     /opt/iobroker/iobroker-data/files/web.admin/static/js/main.aaea95f8.js.map
            12M     /opt/iobroker/iobroker-data/objects.json.migrated
            USB-Devices by-id:
            /dev/serial/by-id/usb-Texas_Instruments_TI_CC2531_USB_CDC___0X00124B001CDD3388-if00
            *** NodeJS-Installation ***
            /usr/bin/nodejs         v18.19.0
            /usr/bin/node           v18.19.0
            /usr/bin/npm            10.2.3
            /usr/bin/npx            10.2.3
            /usr/bin/corepack       0.22.0
            nodejs:
             Installed: 18.19.0-1nodesource1
             Candidate: 18.19.0-1nodesource1
             Version table:
            *** 18.19.0-1nodesource1 1001
                   500 https://deb.nodesource.com/node_18.x nodistro/main armhf Packages
                   100 /var/lib/dpkg/status
                18.18.2-1nodesource1 1001
                18.18.1-1nodesource1 1001
                18.18.0-1nodesource1 1001
                18.17.1-1nodesource1 1001
                18.17.0-1nodesource1 1001
                18.16.1-1nodesource1 1001
                18.16.0-1nodesource1 1001
                18.15.0-1nodesource1 1001
                18.14.2-1nodesource1 1001
                18.14.1-1nodesource1 1001
                18.14.0-1nodesource1 1001
                18.13.0-1nodesource1 1001
                18.12.0-1nodesource1 1001
                18.11.0-1nodesource1 1001
                18.10.0-1nodesource1 1001
                18.9.1-1nodesource1 1001
                18.9.0-1nodesource1 1001
                18.8.0-1nodesource1 1001
                18.7.0-1nodesource1 1001
                18.6.0-1nodesource1 1001
                18.5.0-1nodesource1 1001
                18.4.0-1nodesource1 1001
                18.3.0-1nodesource1 1001
                18.2.0-1nodesource1 1001
                18.1.0-1nodesource1 1001
                18.0.0-1nodesource1 1001
                10.24.0~dfsg-1~deb10u3 500
            No problems detected
            Errors in npm tree:
            npm ERR! code ELSPROBLEMS
            npm ERR! invalid: iobroker.govee@0.0.5 /opt/iobroker/node_modules/iobroker.govee
            npm ERR! A complete log of this run can be found in: /home/pi/.npm/_logs/2023-12-28T16_34_03_703Z-debug-0.log
            *** ioBroker-Installation ***
            ioBroker Status
            Objects type: jsonl
            States  type: jsonl
            Core adapters versions
            js-controller:  5.0.17
            admin:          6.12.0
            javascript:     7.1.6
            npm ERR! A complete log of this run can be found in: /home/pi/.npm/_logs/2023-12-28T16_34_25_768Z-debug-0.log
            Adapters from github:   1
            Adapter State
            + system.adapter.admin.0                  : admin                 : raspberrypi                              -  enabled, port: 8081, bind: 0.0.0.0, run as: admin
            + system.adapter.alexa2.0                 : alexa2                : raspberrypi                              -  enabled
             system.adapter.alias-manager.0          : alias-manager         : raspberrypi                              - disabled
             system.adapter.awtrix-light.0           : awtrix-light          : raspberrypi                              - disabled
            + system.adapter.backitup.0               : backitup              : raspberrypi                              -  enabled
            + system.adapter.ble.0                    : ble                   : raspberrypi                              -  enabled
             system.adapter.chromecast.0             : chromecast            : raspberrypi                              - disabled
             system.adapter.daswetter.0              : daswetter             : raspberrypi                              -  enabled
             system.adapter.devices.0                : devices               : raspberrypi                              - disabled
            + system.adapter.discovery.0              : discovery             : raspberrypi                              -  enabled
             system.adapter.dwd.0                    : dwd                   : raspberrypi                              -  enabled
            + system.adapter.fullybrowser.0           : fullybrowser          : raspberrypi                              -  enabled
            + system.adapter.govee.0                  : govee                 : raspberrypi                              -  enabled
            + system.adapter.gruenbeck.0              : gruenbeck             : raspberrypi                              -  enabled
             system.adapter.history.0                : history               : raspberrypi                              - disabled
            + system.adapter.hue.0                    : hue                   : raspberrypi                              -  enabled, port: 443
             system.adapter.ical.0                   : ical                  : raspberrypi                              -  enabled
             system.adapter.icons-mfd-png.0          : icons-mfd-png         : raspberrypi                              - disabled
             system.adapter.icons-mfd-svg.0          : icons-mfd-svg         : raspberrypi                              - disabled
            + system.adapter.info.0                   : info                  : raspberrypi                              -  enabled
            + system.adapter.iot.0                    : iot                   : raspberrypi                              -  enabled
            + system.adapter.javascript.0             : javascript            : raspberrypi                              -  enabled
            + system.adapter.meross.0                 : meross                : raspberrypi                              -  enabled
            + system.adapter.mielecloudservice.0      : mielecloudservice     : raspberrypi                              -  enabled
            + system.adapter.musiccast.0              : musiccast             : raspberrypi                              -  enabled
            + system.adapter.net-tools.0              : net-tools             : raspberrypi                              -  enabled
            + system.adapter.netatmo.0                : netatmo               : raspberrypi                              -  enabled
            + system.adapter.philips-air.0            : philips-air           : raspberrypi                              -  enabled
            + system.adapter.philips-air.1            : philips-air           : raspberrypi                              -  enabled
            + system.adapter.ping.0                   : ping                  : raspberrypi                              -  enabled
            + system.adapter.pollenflug.0             : pollenflug            : raspberrypi                              -  enabled
            + system.adapter.scenes.0                 : scenes                : raspberrypi                              -  enabled
            + system.adapter.shelly.0                 : shelly                : raspberrypi                              -  enabled, port: 1882, bind: 0.0.0.0
             system.adapter.shuttercontrol.0         : shuttercontrol        : raspberrypi                              - disabled
            + system.adapter.smartcontrol.0           : smartcontrol          : raspberrypi                              -  enabled
            + system.adapter.sonoff.0                 : sonoff                : raspberrypi                              -  enabled, port: 1883, bind: 0.0.0.0
            + system.adapter.sonos.0                  : sonos                 : raspberrypi                              -  enabled
            + system.adapter.trashschedule.0          : trashschedule         : raspberrypi                              -  enabled
            + system.adapter.tuya.0                   : tuya                  : raspberrypi                              -  enabled
             system.adapter.vis-colorpicker.0        : vis-colorpicker       : raspberrypi                              -  enabled
             system.adapter.vis-hqwidgets.0          : vis-hqwidgets         : raspberrypi                              -  enabled
             system.adapter.vis-icontwo.0            : vis-icontwo           : raspberrypi                              -  enabled
            + system.adapter.vis-inventwo.0           : vis-inventwo          : raspberrypi                              -  enabled
             system.adapter.vis-material-advanced.0  : vis-material-advanced : raspberrypi                              -  enabled
             system.adapter.vis-metro.0              : vis-metro             : raspberrypi                              -  enabled
             system.adapter.vis-players.0            : vis-players           : raspberrypi                              -  enabled
             system.adapter.vis-timeandweather.0     : vis-timeandweather    : raspberrypi                              -  enabled
             system.adapter.vis.0                    : vis                   : raspberrypi                              -  enabled
             system.adapter.weatherunderground.0     : weatherunderground    : raspberrypi                              -  enabled
            + system.adapter.web.0                    : web                   : raspberrypi                              -  enabled, port: 8082, bind: 0.0.0.0, run as: admin
            + system.adapter.zigbee.0                 : zigbee                : raspberrypi                              -  enabled, port: /dev/serial/by-id/usb-Texas_Instruments_TI_CC2531_USB_CDC___0X00124B001CDD3388-if00
            + instance is alive
            ioBroker-Repositories
            Active repo(s): stable
            Installed ioBroker-Instances
            Used repository: stable
            Adapter    "admin"        : 6.12.0   , installed 6.12.0
            Adapter    "alexa2"       : 3.26.3   , installed 3.26.3
            Adapter    "awtrix-light" : 0.10.0   , installed 0.10.0
            Adapter    "backitup"     : 2.9.8    , installed 2.9.8
            Adapter    "ble"          : 0.13.4   , installed 0.13.4
            Adapter    "chromecast"   : 3.0.3    , installed 3.0.3
            Adapter    "daswetter"    : 3.1.11   , installed 3.1.11
            Adapter    "fullybrowser" : 3.0.6    , installed 3.0.6
            Adapter    "gruenbeck"    : 0.0.42   , installed 0.0.42
            Adapter    "hue"          : 3.10.1   , installed 3.10.1
            Adapter    "icons-mfd-png": 1.1.0    , installed 1.1.0
            Adapter    "iot"          : 2.0.11   , installed 2.0.11
            Adapter    "javascript"   : 7.1.6    , installed 7.1.6
            Controller "js-controller": 5.0.17   , installed 5.0.17
            Adapter    "meross"       : 1.15.1   , installed 1.15.1
            Adapter    "mielecloudservice": 6.5.4, installed 6.5.4
            Adapter    "mihome-vacuum": 4.1.0    , installed 4.1.0
            Adapter    "musiccast"    : 1.1.3    , installed 1.1.3
            Adapter    "netatmo"      : 3.1.0    , installed 3.1.0
            Adapter    "philips-air"  : 1.0.3    , installed 1.0.3
            Adapter    "pollenflug"   : 1.0.6    , installed 1.0.6
            Adapter    "shelly"       : 6.6.1    , installed 6.6.1
            Adapter    "shuttercontrol": 1.6.3   , installed 1.6.3
            Adapter    "smartcontrol" : 2.0.1    , installed 2.0.1
            Adapter    "sonoff"       : 3.0.3    , installed 3.0.3
            Adapter    "sonos"        : 3.0.0    , installed 3.0.0
            Adapter    "trashschedule": 2.3.0    , installed 2.3.0
            Adapter    "tuya"         : 3.14.2   , installed 3.14.2
            Adapter    "vis-icontwo"  : 1.0.0    , installed 1.0.0
            Adapter    "weatherunderground": 3.6.0, installed 3.6.0
            Adapter    "web"          : 6.1.10   , installed 6.1.10
            Adapter    "ws"           : 2.5.8    , installed 2.5.8
            Adapter    "zigbee"       : 1.8.25   , installed 1.8.24 [Updatable]
            Objects and States
            Objects:        11296
            States:         9373
            Hit:1 http://archive.raspberrypi.org/debian buster InRelease
            Hit:2 http://raspbian.raspberrypi.org/raspbian buster InRelease
            Hit:3 https://deb.nodesource.com/node_18.x nodistro InRelease
            Reading package lists...
            Pending Updates: 0
            *** Listening Ports ***
            tcp        0      0 0.0.0.0:22              0.0.0.0:*               LISTEN      0          18008      642/sshd
            tcp        0      0 127.0.0.1:631           0.0.0.0:*               LISTEN      0          14831      363/cupsd
            tcp        0      0 0.0.0.0:1883            0.0.0.0:*               LISTEN      1001       20705      999/io.sonoff.0
            tcp        0      0 127.0.0.1:9000          0.0.0.0:*               LISTEN      1001       18400      632/iobroker.js-con
            tcp        0      0 127.0.0.1:9001          0.0.0.0:*               LISTEN      1001       19317      632/iobroker.js-con
            tcp6       0      0 :::8081                 :::*                    LISTEN      1001       178386     15017/io.admin.0
            tcp6       0      0 :::8082                 :::*                    LISTEN      1001       363390     9027/io.web.0
            tcp6       0      0 :::22                   :::*                    LISTEN      0          18010      642/sshd
            tcp6       0      0 ::1:631                 :::*                    LISTEN      0          14830      363/cupsd
            tcp6       0      0 :::3500                 :::*                    LISTEN      1001       21820      980/io.sonos.0
            udp        0      0 0.0.0.0:6666            0.0.0.0:*                           1001       19741      1036/io.tuya.0
            udp        0      0 0.0.0.0:6667            0.0.0.0:*                           1001       19742      1036/io.tuya.0
            udp        0      0 0.0.0.0:37928           0.0.0.0:*                           1001       21652      911/io.philips-air.
            udp        0      0 0.0.0.0:5683            0.0.0.0:*                           1001       21575      856/io.shelly.0
            udp        0      0 0.0.0.0:68              0.0.0.0:*                           0          18449      631/dhcpcd
            udp        0      0 0.0.0.0:631             0.0.0.0:*                           0          16300      460/cups-browsed
            udp        0      0 0.0.0.0:41100           0.0.0.0:*                           1001       24005      1320/io.musiccast.0
            udp        0      0 0.0.0.0:60062           0.0.0.0:*                           108        17435      356/avahi-daemon: r
            udp        0      0 0.0.0.0:5353            0.0.0.0:*                           108        17433      356/avahi-daemon: r
            udp        0      0 0.0.0.0:48886           0.0.0.0:*                           1001       21952      1017/io.philips-air
            udp6       0      0 :::546                  :::*                                0          18466      631/dhcpcd
            udp6       0      0 :::5353                 :::*                                108        17434      356/avahi-daemon: r
            udp6       0      0 :::39823                :::*                                108        17436      356/avahi-daemon: r
            2023-12-28 17:33:48.594  - info: philips-air.0 (911) State value to set for "philips-air.0.filter.hepaFilterReplaceInHours" has to be type "number" but received type "string"
            2023-12-28 17:33:48.644  - info: philips-air.0 (911) State value to set for "philips-air.0.filter.activeCarbonFilterReplaceInHours" has to be type "number" but received type "string"
            2023-12-28 17:33:52.420  - info: philips-air.0 (911) State value to set for "philips-air.0.control.lightBrightness" has to be type "number" but received type "string"
            2023-12-28 17:33:52.429  - info: philips-air.0 (911) State value to set for "philips-air.0.control.airQualityNotificationThreshold" has to be type "number" but received type "string"
            2023-12-28 17:33:52.481  - info: philips-air.0 (911) State value to set for "philips-air.0.status.allergenIndex" has to be type "number" but received type "string"
            2023-12-28 17:33:52.493  - info: philips-air.0 (911) State value to set for "philips-air.0.control.childLock" has to be type "boolean" but received type "string"
            2023-12-28 17:33:52.542  - info: philips-air.0 (911) State value to set for "philips-air.0.device.uptime" has to be type "number" but received type "string"
            2023-12-28 17:33:52.600  - info: philips-air.0 (911) State value to set for "philips-air.0.status.pm25" has to be type "number" but received type "string"
            2023-12-28 17:33:52.618  - info: philips-air.0 (911) State value to set for "philips-air.0.control.timerHours" has to be type "number" but received type "string"
            2023-12-28 17:33:52.625  - info: philips-air.0 (911) State value to set for "philips-air.0.status.timerMinutes" has to be type "number" but received type "string"
            2023-12-28 17:33:52.640  - info: philips-air.0 (911) State value to set for "philips-air.0.filter.preFilterCleanInHours" has to be type "number" but received type "string"
            2023-12-28 17:33:52.695  - info: philips-air.0 (911) State value to set for "philips-air.0.filter.hepaFilterReplaceInHours" has to be type "number" but received type "string"
            2023-12-28 17:33:52.701  - info: philips-air.0 (911) State value to set for "philips-air.0.filter.activeCarbonFilterReplaceInHours" has to be type "number" but received type "string"
            2023-12-28 17:34:18.240  - error: philips-air.1 (1017) Error by sending: Error: No reply in 247 seconds.
            2023-12-28 17:34:24.323  - warn: sonoff.0 (999) Client [tasmota2] has invalid password or username
            2023-12-28 17:34:38.463  - warn: sonos.0 (980) State "sonos.0.root.192_168_2_145.queue_html" has no existing object, this might lead to an error in future versions
            2023-12-28 17:34:38.598  - warn: sonos.0 (980) State "sonos.0.root.192_168_2_145.queue_html" has no existing object, this might lead to an error in future versions
            2023-12-28 17:34:48.242  - error: philips-air.1 (1017) Error by sending: Error: No reply in 247 seconds.
            2023-12-28 17:35:00.048  - info: host.raspberrypi instance system.adapter.dwd.0 started with pid 303
            2023-12-28 17:35:04.662  - info: dwd.0 (303) starting. Version 2.8.5 in /opt/iobroker/node_modules/iobroker.dwd, node: v18.19.0, js-controller: 5.0.17
            2023-12-28 17:35:05.205  - info: web.0 (9027) ==> Connected system.user.admin from ::ffff:192.168.2.148
            2023-12-28 17:35:07.075  - info: dwd.0 (303) Terminated (ADAPTER_REQUESTED_TERMINATION): Without reason
            2023-12-28 17:35:07.617  - info: host.raspberrypi instance system.adapter.dwd.0 terminated with code 11 (ADAPTER_REQUESTED_TERMINATION)
            2023-12-28 17:35:15.042  - info: web.0 (9027) ==> Connected system.user.admin from ::ffff:192.168.2.148
            2023-12-28 17:35:18.242  - error: philips-air.1 (1017) Error by sending: Error: No reply in 247 seconds.
              Thomas Braun Most Active @gluecksmann last edited by
              @gluecksmann
              iobroker.govee
              nochmal installieren.
              R G 3 Replies Last reply Reply Quote 0
                reutli @Thomas Braun last edited by
                @gluecksmann
                reboot gemacht?
                debug modus im Adapter aktiviert?
                Adapter neu gestartet?
                Wenn ja: zeigen
                Wenn nein: machen und dann zeigen
                Sonst kann hier wahrscheinlich keiner mehr weiter helfen...
                  gluecksmann @Thomas Braun last edited by
                  der ist aktuell nicht das Problem...glaub den werfe ich erst mal raus...
                    @reutli
                    Reboot und Adapter neu starten kann ich... Debug Modus ist wo?
                      @gluecksmann
                      @gluecksmann sagte in Zigbee Stick spinnt:
                      Debug Modus ist wo?
                      Auf dem IOBroker im Expertenmodus auf Instanzen Zigbee aufklappen
                      mit Bleistift umstellen
                      Dann mal den ganzen Start aus dem log
                        @frank579
                        Hallo, habe den Adapter neu gestartet...jetzt läuft es wieder... komisch...
                        F R 2 Replies Last reply Reply Quote 0
                          Da wir gerade so plaudern... welchen Zigbee Stick könnt Ihr empfehlen? Gibt da ja den Sonoff ZBDongle ...aber den wohl mit zwei verschiedenen Chipsätzen..
                            @gluecksmann Okay dann bleib trotzdem erst mal auf der Version, bis es was neues gibt 🙂
                            @thomas-braun sagte in Zigbee Stick spinnt:
                            @gluecksmann
                            iobroker.govee
                            Hast du das gemacht einfach nochmal drüber, das alles sauber ist, dann sollte bei iob diag auch nichts auffällige mehr sein ...
                              @frank579
                              Traue mich das kaum... jetzt wo es so schön läuft..
                                @gluecksmann
                                Ich hab Hier den von @dimaiv aber als LAN Version. und super Zufrieden, klarer Vorteil ist der LAN Anschluss, muss also nicht im Netzwerkschrank liegen, Liegt bei mir im Büro (zentral) auf dem Schrank
                                  doch mach das, nicht das dich das irgendwann einholt ...
                                    @frank579
                                    Den Adapter gibt es scheinbar nicht mehr... macht erst mal auch nix... bin zufrieden das alles wieder läuft...muss aber mal echt über eine Neuinstallation nachdenken
                                      @gluecksmann sagte in Zigbee Stick spinnt *gelöst*:
                                      Doch, aus dem github.
                                      Das ist auch der Grund, warum der als invalid angezeigt wird.
                                      Also nochmal in aktueller Version aus dem github fischen.
                                        Da finde ich nur govee Local... da erschließt sich mir aber die Funktion, bzw. Inbetriebnahme nicht...aber wie gesagt...nicht schlimm
                                          @gluecksmann
                                          https://github.com/nbuenger/ioBroker.govee
                                            reutli @gluecksmann last edited by reutli
                                            Edit:
                                            war quatsch.
                                            5807
