    4. Zigbee Stick spinnt *gelöst*
      reutli @Frank579 last edited by reutli
      @gluecksmann
      davor auch mal reboot gemacht???
      debug modus im Adapter aktivieren...
      und dann den Adapter nochmals neustarten
      und dann
      @frank579 sagte in Zigbee Stick spinnt:
      @gluecksmann jetzt nochmal komplett iob diag
        gluecksmann @Frank579 last edited by
        @frank579
        *** BASE SYSTEM ***
          Static hostname: raspberrypi
                Icon name: computer
         Operating System: Raspbian GNU/Linux 10 (buster)
                   Kernel: Linux 5.10.103-v7l+
             Architecture: arm
        Model           : Raspberry Pi 4 Model B Rev 1.4
        Docker          : false
        Virtualization  : none
        Kernel          : armv7l
        Userland        : armhf
        Systemuptime and Load:
        17:33:54 up  3:22,  1 user,  load average: 0.68, 3.79, 4.41
        CPU threads: 4
        *** RASPBERRY THROTTLING ***
        Current issues:
        Previously detected issues:
        *** Time and Time Zones ***
                      Local time: Thu 2023-12-28 17:33:54 CET
                  Universal time: Thu 2023-12-28 16:33:54 UTC
                        RTC time: n/a
                     NTP service: active
                 RTC in local TZ: no
        *** User and Groups ***
        pi
        /home/pi
        pi adm dialout cdrom sudo audio video plugdev games users input netdev lpadmin gpio i2c spi iobroker
        *** X-Server-Setup ***
        X-Server:       false
        Desktop:
        Terminal:       tty
        Boot Target:    multi-user.target
        *** MEMORY ***
        Mem:           7.9G        1.6G        4.9G        8.0M        1.5G        6.1G
        Swap:           99M          0B         99M
        Total:         8.0G        1.6G        5.0G
                7898 M total memory
                1554 M used memory
                 300 M active memory
                2506 M inactive memory
                4885 M free memory
                 184 M buffer memory
                1273 M swap cache
                  99 M total swap
                   0 M used swap
                  99 M free swap
        Raspberry only:
        oom events: 0
        *** FAILED SERVICES ***
         UNIT            LOAD   ACTIVE SUB    DESCRIPTION
        * lightdm.service loaded failed failed Light Display Manager
        LOAD   = Reflects whether the unit definition was properly loaded.
        ACTIVE = The high-level unit activation state, i.e. generalization of SUB.
        SUB    = The low-level unit activation state, values depend on unit type.
        1 loaded units listed. Pass --all to see loaded but inactive units, too.
        To show all installed unit files use 'systemctl list-unit-files'.
        *** FILESYSTEM ***
        /dev/root      ext4       29G   14G   15G  50% /
        devtmpfs       devtmpfs  3.7G     0  3.7G   0% /dev
        tmpfs          tmpfs     3.9G     0  3.9G   0% /dev/shm
        tmpfs          tmpfs     3.9G  8.5M  3.9G   1% /run
        tmpfs          tmpfs     3.9G     0  3.9G   0% /sys/fs/cgroup
        /dev/mmcblk0p1 vfat      253M   49M  204M  20% /boot
        tmpfs          tmpfs     790M     0  790M   0% /run/user/1000
        [Thu Dec 28 14:11:43 2023] Kernel command line: coherent_pool=1M 8250.nr_uarts=0 snd_bcm2835.enable_compat_alsa=0 snd_bcm2835.enable_hdmi=1  smsc95xx.macaddr=E4:5F:01:3D:9B:6E vc_mem.mem_base=0x3ec00000 vc_mem.mem_size=0x40000000  dwc_otg.lpm_enable=0 console=ttyS0,115200 console=tty1 root=PARTUUID=a372f35c-02 rootfstype=ext4 elevator=deadline fsck.repair=yes rootwait quiet splash plymouth.ignore-serial-consoles
        [Thu Dec 28 14:11:44 2023] EXT4-fs (mmcblk0p2): mounted filesystem with ordered data mode. Opts: (null)
        [Thu Dec 28 14:11:44 2023] VFS: Mounted root (ext4 filesystem) readonly on device 179:2.
        [Thu Dec 28 14:11:46 2023] EXT4-fs (mmcblk0p2): re-mounted. Opts: (null)
        TARGET        SOURCE         FSTYPE OPTIONS
        /             /dev/mmcblk0p2 ext4   rw,noatime
        |-/sys/fs/bpf none           bpf    rw,nosuid,nodev,noexec,relatime,mode=700
        `-/boot       /dev/mmcblk0p1 vfat   rw,relatime,fmask=0022,dmask=0022,codepage=437,iocharset=ascii,shortname=mixed,errors=remount-ro
        /var:
        413M    /var/
        118M    /var/lib
        102M    /var/cache
        91M     /var/log
        90M     /var/cache/apt
        Archived and active journals take up 8.0M in the file system.
        /opt/iobroker/backups:
        63M     /opt/iobroker/backups/
        /opt/iobroker/iobroker-data:
        621M    /opt/iobroker/iobroker-data/
        322M    /opt/iobroker/iobroker-data/files
        143M    /opt/iobroker/iobroker-data/backup-objects
        93M     /opt/iobroker/iobroker-data/sonosCache
        67M     /opt/iobroker/iobroker-data/files/javascript.admin
        35M     /opt/iobroker/iobroker-data/files/devices.admin/static/js/main.24f2bb56.js.map
        33M     /opt/iobroker/iobroker-data/files/iot.admin/static/js/main.1797d034.js.map
        30M     /opt/iobroker/iobroker-data/objects.jsonl
        21M     /opt/iobroker/iobroker-data/files/web.admin/static/js/main.aaea95f8.js.map
        12M     /opt/iobroker/iobroker-data/objects.json.migrated
        USB-Devices by-id:
        /dev/serial/by-id/usb-Texas_Instruments_TI_CC2531_USB_CDC___0X00124B001CDD3388-if00
        *** NodeJS-Installation ***
        /usr/bin/nodejs         v18.19.0
        /usr/bin/node           v18.19.0
        /usr/bin/npm            10.2.3
        /usr/bin/npx            10.2.3
        /usr/bin/corepack       0.22.0
        nodejs:
         Installed: 18.19.0-1nodesource1
         Candidate: 18.19.0-1nodesource1
         Version table:
        *** 18.19.0-1nodesource1 1001
               500 https://deb.nodesource.com/node_18.x nodistro/main armhf Packages
               100 /var/lib/dpkg/status
            18.18.2-1nodesource1 1001
            18.18.1-1nodesource1 1001
            18.18.0-1nodesource1 1001
            18.17.1-1nodesource1 1001
            18.17.0-1nodesource1 1001
            18.16.1-1nodesource1 1001
            18.16.0-1nodesource1 1001
            18.15.0-1nodesource1 1001
            18.14.2-1nodesource1 1001
            18.14.1-1nodesource1 1001
            18.14.0-1nodesource1 1001
            18.13.0-1nodesource1 1001
            18.12.0-1nodesource1 1001
            18.11.0-1nodesource1 1001
            18.10.0-1nodesource1 1001
            18.9.1-1nodesource1 1001
            18.9.0-1nodesource1 1001
            18.8.0-1nodesource1 1001
            18.7.0-1nodesource1 1001
            18.6.0-1nodesource1 1001
            18.5.0-1nodesource1 1001
            18.4.0-1nodesource1 1001
            18.3.0-1nodesource1 1001
            18.2.0-1nodesource1 1001
            18.1.0-1nodesource1 1001
            18.0.0-1nodesource1 1001
            10.24.0~dfsg-1~deb10u3 500
        No problems detected
        Errors in npm tree:
        npm ERR! code ELSPROBLEMS
        npm ERR! invalid: iobroker.govee@0.0.5 /opt/iobroker/node_modules/iobroker.govee
        npm ERR! A complete log of this run can be found in: /home/pi/.npm/_logs/2023-12-28T16_34_03_703Z-debug-0.log
        *** ioBroker-Installation ***
        ioBroker Status
        Objects type: jsonl
        States  type: jsonl
        Core adapters versions
        js-controller:  5.0.17
        admin:          6.12.0
        javascript:     7.1.6
        npm ERR! A complete log of this run can be found in: /home/pi/.npm/_logs/2023-12-28T16_34_25_768Z-debug-0.log
        Adapters from github:   1
        Adapter State
        + system.adapter.admin.0                  : admin                 : raspberrypi                              -  enabled, port: 8081, bind: 0.0.0.0, run as: admin
        + system.adapter.alexa2.0                 : alexa2                : raspberrypi                              -  enabled
         system.adapter.alias-manager.0          : alias-manager         : raspberrypi                              - disabled
         system.adapter.awtrix-light.0           : awtrix-light          : raspberrypi                              - disabled
        + system.adapter.backitup.0               : backitup              : raspberrypi                              -  enabled
        + system.adapter.ble.0                    : ble                   : raspberrypi                              -  enabled
         system.adapter.chromecast.0             : chromecast            : raspberrypi                              - disabled
         system.adapter.daswetter.0              : daswetter             : raspberrypi                              -  enabled
         system.adapter.devices.0                : devices               : raspberrypi                              - disabled
        + system.adapter.discovery.0              : discovery             : raspberrypi                              -  enabled
         system.adapter.dwd.0                    : dwd                   : raspberrypi                              -  enabled
        + system.adapter.fullybrowser.0           : fullybrowser          : raspberrypi                              -  enabled
        + system.adapter.govee.0                  : govee                 : raspberrypi                              -  enabled
        + system.adapter.gruenbeck.0              : gruenbeck             : raspberrypi                              -  enabled
         system.adapter.history.0                : history               : raspberrypi                              - disabled
        + system.adapter.hue.0                    : hue                   : raspberrypi                              -  enabled, port: 443
         system.adapter.ical.0                   : ical                  : raspberrypi                              -  enabled
         system.adapter.icons-mfd-png.0          : icons-mfd-png         : raspberrypi                              - disabled
         system.adapter.icons-mfd-svg.0          : icons-mfd-svg         : raspberrypi                              - disabled
        + system.adapter.info.0                   : info                  : raspberrypi                              -  enabled
        + system.adapter.iot.0                    : iot                   : raspberrypi                              -  enabled
        + system.adapter.javascript.0             : javascript            : raspberrypi                              -  enabled
        + system.adapter.meross.0                 : meross                : raspberrypi                              -  enabled
        + system.adapter.mielecloudservice.0      : mielecloudservice     : raspberrypi                              -  enabled
        + system.adapter.musiccast.0              : musiccast             : raspberrypi                              -  enabled
        + system.adapter.net-tools.0              : net-tools             : raspberrypi                              -  enabled
        + system.adapter.netatmo.0                : netatmo               : raspberrypi                              -  enabled
        + system.adapter.philips-air.0            : philips-air           : raspberrypi                              -  enabled
        + system.adapter.philips-air.1            : philips-air           : raspberrypi                              -  enabled
        + system.adapter.ping.0                   : ping                  : raspberrypi                              -  enabled
        + system.adapter.pollenflug.0             : pollenflug            : raspberrypi                              -  enabled
        + system.adapter.scenes.0                 : scenes                : raspberrypi                              -  enabled
        + system.adapter.shelly.0                 : shelly                : raspberrypi                              -  enabled, port: 1882, bind: 0.0.0.0
         system.adapter.shuttercontrol.0         : shuttercontrol        : raspberrypi                              - disabled
        + system.adapter.smartcontrol.0           : smartcontrol          : raspberrypi                              -  enabled
        + system.adapter.sonoff.0                 : sonoff                : raspberrypi                              -  enabled, port: 1883, bind: 0.0.0.0
        + system.adapter.sonos.0                  : sonos                 : raspberrypi                              -  enabled
        + system.adapter.trashschedule.0          : trashschedule         : raspberrypi                              -  enabled
        + system.adapter.tuya.0                   : tuya                  : raspberrypi                              -  enabled
         system.adapter.vis-colorpicker.0        : vis-colorpicker       : raspberrypi                              -  enabled
         system.adapter.vis-hqwidgets.0          : vis-hqwidgets         : raspberrypi                              -  enabled
         system.adapter.vis-icontwo.0            : vis-icontwo           : raspberrypi                              -  enabled
        + system.adapter.vis-inventwo.0           : vis-inventwo          : raspberrypi                              -  enabled
         system.adapter.vis-material-advanced.0  : vis-material-advanced : raspberrypi                              -  enabled
         system.adapter.vis-metro.0              : vis-metro             : raspberrypi                              -  enabled
         system.adapter.vis-players.0            : vis-players           : raspberrypi                              -  enabled
         system.adapter.vis-timeandweather.0     : vis-timeandweather    : raspberrypi                              -  enabled
         system.adapter.vis.0                    : vis                   : raspberrypi                              -  enabled
         system.adapter.weatherunderground.0     : weatherunderground    : raspberrypi                              -  enabled
        + system.adapter.web.0                    : web                   : raspberrypi                              -  enabled, port: 8082, bind: 0.0.0.0, run as: admin
        + system.adapter.zigbee.0                 : zigbee                : raspberrypi                              -  enabled, port: /dev/serial/by-id/usb-Texas_Instruments_TI_CC2531_USB_CDC___0X00124B001CDD3388-if00
        + instance is alive
        ioBroker-Repositories
        Active repo(s): stable
        Installed ioBroker-Instances
        Used repository: stable
        Adapter    "admin"        : 6.12.0   , installed 6.12.0
        Adapter    "alexa2"       : 3.26.3   , installed 3.26.3
        Adapter    "awtrix-light" : 0.10.0   , installed 0.10.0
        Adapter    "backitup"     : 2.9.8    , installed 2.9.8
        Adapter    "ble"          : 0.13.4   , installed 0.13.4
        Adapter    "chromecast"   : 3.0.3    , installed 3.0.3
        Adapter    "daswetter"    : 3.1.11   , installed 3.1.11
        Adapter    "fullybrowser" : 3.0.6    , installed 3.0.6
        Adapter    "gruenbeck"    : 0.0.42   , installed 0.0.42
        Adapter    "hue"          : 3.10.1   , installed 3.10.1
        Adapter    "icons-mfd-png": 1.1.0    , installed 1.1.0
        Adapter    "iot"          : 2.0.11   , installed 2.0.11
        Adapter    "javascript"   : 7.1.6    , installed 7.1.6
        Controller "js-controller": 5.0.17   , installed 5.0.17
        Adapter    "meross"       : 1.15.1   , installed 1.15.1
        Adapter    "mielecloudservice": 6.5.4, installed 6.5.4
        Adapter    "mihome-vacuum": 4.1.0    , installed 4.1.0
        Adapter    "musiccast"    : 1.1.3    , installed 1.1.3
        Adapter    "netatmo"      : 3.1.0    , installed 3.1.0
        Adapter    "philips-air"  : 1.0.3    , installed 1.0.3
        Adapter    "pollenflug"   : 1.0.6    , installed 1.0.6
        Adapter    "shelly"       : 6.6.1    , installed 6.6.1
        Adapter    "shuttercontrol": 1.6.3   , installed 1.6.3
        Adapter    "smartcontrol" : 2.0.1    , installed 2.0.1
        Adapter    "sonoff"       : 3.0.3    , installed 3.0.3
        Adapter    "sonos"        : 3.0.0    , installed 3.0.0
        Adapter    "trashschedule": 2.3.0    , installed 2.3.0
        Adapter    "tuya"         : 3.14.2   , installed 3.14.2
        Adapter    "vis-icontwo"  : 1.0.0    , installed 1.0.0
        Adapter    "weatherunderground": 3.6.0, installed 3.6.0
        Adapter    "web"          : 6.1.10   , installed 6.1.10
        Adapter    "ws"           : 2.5.8    , installed 2.5.8
        Adapter    "zigbee"       : 1.8.25   , installed 1.8.24 [Updatable]
        Objects and States
        Objects:        11296
        States:         9373
        Hit:1 http://archive.raspberrypi.org/debian buster InRelease
        Hit:2 http://raspbian.raspberrypi.org/raspbian buster InRelease
        Hit:3 https://deb.nodesource.com/node_18.x nodistro InRelease
        Reading package lists...
        Pending Updates: 0
        *** Listening Ports ***
        tcp        0      0 0.0.0.0:22              0.0.0.0:*               LISTEN      0          18008      642/sshd
        tcp        0      0 127.0.0.1:631           0.0.0.0:*               LISTEN      0          14831      363/cupsd
        tcp        0      0 0.0.0.0:1883            0.0.0.0:*               LISTEN      1001       20705      999/io.sonoff.0
        tcp        0      0 127.0.0.1:9000          0.0.0.0:*               LISTEN      1001       18400      632/iobroker.js-con
        tcp        0      0 127.0.0.1:9001          0.0.0.0:*               LISTEN      1001       19317      632/iobroker.js-con
        tcp6       0      0 :::8081                 :::*                    LISTEN      1001       178386     15017/io.admin.0
        tcp6       0      0 :::8082                 :::*                    LISTEN      1001       363390     9027/io.web.0
        tcp6       0      0 :::22                   :::*                    LISTEN      0          18010      642/sshd
        tcp6       0      0 ::1:631                 :::*                    LISTEN      0          14830      363/cupsd
        tcp6       0      0 :::3500                 :::*                    LISTEN      1001       21820      980/io.sonos.0
        udp        0      0 0.0.0.0:6666            0.0.0.0:*                           1001       19741      1036/io.tuya.0
        udp        0      0 0.0.0.0:6667            0.0.0.0:*                           1001       19742      1036/io.tuya.0
        udp        0      0 0.0.0.0:37928           0.0.0.0:*                           1001       21652      911/io.philips-air.
        udp        0      0 0.0.0.0:5683            0.0.0.0:*                           1001       21575      856/io.shelly.0
        udp        0      0 0.0.0.0:68              0.0.0.0:*                           0          18449      631/dhcpcd
        udp        0      0 0.0.0.0:631             0.0.0.0:*                           0          16300      460/cups-browsed
        udp        0      0 0.0.0.0:41100           0.0.0.0:*                           1001       24005      1320/io.musiccast.0
        udp        0      0 0.0.0.0:60062           0.0.0.0:*                           108        17435      356/avahi-daemon: r
        udp        0      0 0.0.0.0:5353            0.0.0.0:*                           108        17433      356/avahi-daemon: r
        udp        0      0 0.0.0.0:48886           0.0.0.0:*                           1001       21952      1017/io.philips-air
        udp6       0      0 :::546                  :::*                                0          18466      631/dhcpcd
        udp6       0      0 :::5353                 :::*                                108        17434      356/avahi-daemon: r
        udp6       0      0 :::39823                :::*                                108        17436      356/avahi-daemon: r
        2023-12-28 17:33:48.594  - info: philips-air.0 (911) State value to set for "philips-air.0.filter.hepaFilterReplaceInHours" has to be type "number" but received type "string"
        2023-12-28 17:33:48.644  - info: philips-air.0 (911) State value to set for "philips-air.0.filter.activeCarbonFilterReplaceInHours" has to be type "number" but received type "string"
        2023-12-28 17:33:52.420  - info: philips-air.0 (911) State value to set for "philips-air.0.control.lightBrightness" has to be type "number" but received type "string"
        2023-12-28 17:33:52.429  - info: philips-air.0 (911) State value to set for "philips-air.0.control.airQualityNotificationThreshold" has to be type "number" but received type "string"
        2023-12-28 17:33:52.481  - info: philips-air.0 (911) State value to set for "philips-air.0.status.allergenIndex" has to be type "number" but received type "string"
        2023-12-28 17:33:52.493  - info: philips-air.0 (911) State value to set for "philips-air.0.control.childLock" has to be type "boolean" but received type "string"
        2023-12-28 17:33:52.542  - info: philips-air.0 (911) State value to set for "philips-air.0.device.uptime" has to be type "number" but received type "string"
        2023-12-28 17:33:52.600  - info: philips-air.0 (911) State value to set for "philips-air.0.status.pm25" has to be type "number" but received type "string"
        2023-12-28 17:33:52.618  - info: philips-air.0 (911) State value to set for "philips-air.0.control.timerHours" has to be type "number" but received type "string"
        2023-12-28 17:33:52.625  - info: philips-air.0 (911) State value to set for "philips-air.0.status.timerMinutes" has to be type "number" but received type "string"
        2023-12-28 17:33:52.640  - info: philips-air.0 (911) State value to set for "philips-air.0.filter.preFilterCleanInHours" has to be type "number" but received type "string"
        2023-12-28 17:33:52.695  - info: philips-air.0 (911) State value to set for "philips-air.0.filter.hepaFilterReplaceInHours" has to be type "number" but received type "string"
        2023-12-28 17:33:52.701  - info: philips-air.0 (911) State value to set for "philips-air.0.filter.activeCarbonFilterReplaceInHours" has to be type "number" but received type "string"
        2023-12-28 17:34:18.240  - error: philips-air.1 (1017) Error by sending: Error: No reply in 247 seconds.
        2023-12-28 17:34:24.323  - warn: sonoff.0 (999) Client [tasmota2] has invalid password or username
        2023-12-28 17:34:38.463  - warn: sonos.0 (980) State "sonos.0.root.192_168_2_145.queue_html" has no existing object, this might lead to an error in future versions
        2023-12-28 17:34:38.598  - warn: sonos.0 (980) State "sonos.0.root.192_168_2_145.queue_html" has no existing object, this might lead to an error in future versions
        2023-12-28 17:34:48.242  - error: philips-air.1 (1017) Error by sending: Error: No reply in 247 seconds.
        2023-12-28 17:35:00.048  - info: host.raspberrypi instance system.adapter.dwd.0 started with pid 303
        2023-12-28 17:35:04.662  - info: dwd.0 (303) starting. Version 2.8.5 in /opt/iobroker/node_modules/iobroker.dwd, node: v18.19.0, js-controller: 5.0.17
        2023-12-28 17:35:05.205  - info: web.0 (9027) ==> Connected system.user.admin from ::ffff:192.168.2.148
        2023-12-28 17:35:07.075  - info: dwd.0 (303) Terminated (ADAPTER_REQUESTED_TERMINATION): Without reason
        2023-12-28 17:35:07.617  - info: host.raspberrypi instance system.adapter.dwd.0 terminated with code 11 (ADAPTER_REQUESTED_TERMINATION)
        2023-12-28 17:35:15.042  - info: web.0 (9027) ==> Connected system.user.admin from ::ffff:192.168.2.148
        2023-12-28 17:35:18.242  - error: philips-air.1 (1017) Error by sending: Error: No reply in 247 seconds.
          Thomas Braun Most Active @gluecksmann last edited by
          @gluecksmann
          iobroker.govee
          nochmal installieren.
          R G 3 Replies Last reply Reply Quote 0
            reutli @Thomas Braun last edited by
            @gluecksmann
            reboot gemacht?
            debug modus im Adapter aktiviert?
            Adapter neu gestartet?
            Wenn ja: zeigen
            Wenn nein: machen und dann zeigen
            Sonst kann hier wahrscheinlich keiner mehr weiter helfen...
              gluecksmann @Thomas Braun last edited by
              der ist aktuell nicht das Problem...glaub den werfe ich erst mal raus...
                gluecksmann @reutli last edited by
                @reutli
                Reboot und Adapter neu starten kann ich... Debug Modus ist wo?
                  Frank579 @gluecksmann last edited by
                  @gluecksmann
                  @gluecksmann sagte in Zigbee Stick spinnt:
                  Debug Modus ist wo?
                  Auf dem IOBroker im Expertenmodus auf Instanzen Zigbee aufklappen
                  mit Bleistift umstellen
                  Dann mal den ganzen Start aus dem log
                    @frank579
                    Hallo, habe den Adapter neu gestartet...jetzt läuft es wieder... komisch...
                    F R 2 Replies Last reply Reply Quote 0
                      Da wir gerade so plaudern... welchen Zigbee Stick könnt Ihr empfehlen? Gibt da ja den Sonoff ZBDongle ...aber den wohl mit zwei verschiedenen Chipsätzen..
                        @gluecksmann Okay dann bleib trotzdem erst mal auf der Version, bis es was neues gibt 🙂
                        @thomas-braun sagte in Zigbee Stick spinnt:
                        @gluecksmann
                        iobroker.govee
                        Hast du das gemacht einfach nochmal drüber, das alles sauber ist, dann sollte bei iob diag auch nichts auffällige mehr sein ...
                          @frank579
                          Traue mich das kaum... jetzt wo es so schön läuft..
                            @gluecksmann
                            Ich hab Hier den von @dimaiv aber als LAN Version. und super Zufrieden, klarer Vorteil ist der LAN Anschluss, muss also nicht im Netzwerkschrank liegen, Liegt bei mir im Büro (zentral) auf dem Schrank
                              doch mach das, nicht das dich das irgendwann einholt ...
                                @frank579
                                Den Adapter gibt es scheinbar nicht mehr... macht erst mal auch nix... bin zufrieden das alles wieder läuft...muss aber mal echt über eine Neuinstallation nachdenken
                                  @gluecksmann sagte in Zigbee Stick spinnt *gelöst*:
                                  Doch, aus dem github.
                                  Das ist auch der Grund, warum der als invalid angezeigt wird.
                                  Also nochmal in aktueller Version aus dem github fischen.
                                    Da finde ich nur govee Local... da erschließt sich mir aber die Funktion, bzw. Inbetriebnahme nicht...aber wie gesagt...nicht schlimm
                                      @gluecksmann
                                      https://github.com/nbuenger/ioBroker.govee
                                        reutli @gluecksmann last edited by reutli
                                        Edit:
                                        war quatsch.
                                        5808
