    4. Zigbee Tuya TS0601 Temperature & Humidity läuft nicht
      rocky753 @arteck last edited by
      @arteck da war er schon drin. hab ihn nochmal neu angelernt und unter ausschliessen rein, aber keine Veränderung...
      2023-09-30 15:28:52.140	info	Zigbee started
      2023-09-30 15:28:52.139	info	0x3425b4fffe307d63 (addr 31147): TS011F_plug_3 - TuYa Smart plug (with power monitoring by polling) (Router)
      2023-09-30 15:28:52.137	info	0x3425b4fffe170775 (addr 49041): TS011F_plug_3 - TuYa Smart plug (with power monitoring by polling) (Router)
      2023-09-30 15:28:52.135	info	0x00158d000911dbbb (addr 20444): MCCGQ11LM - Xiaomi Aqara door & window contact sensor (EndDevice)
      2023-09-30 15:28:52.133	info	0xa4c138a66e67005b (addr 36428): IH-K009 - TuYa Temperature & humidity sensor (EndDevice)
      2023-09-30 15:28:52.131	info	0xa4c1380d4d269b2b (addr 16273): IH-K009 - TuYa Temperature & humidity sensor (EndDevice)
      2023-09-30 15:28:52.129	info	0x00158d0008f3290c (addr 39180): DJT11LM - Xiaomi Aqara vibration sensor (EndDevice)
      2023-09-30 15:28:52.124	info	0xa4c138d0b860a01f (addr 10643): TS0601_temperature_humidity_sensor_1 - TuYa Temperature & humidity sensor (EndDevice)
      2023-09-30 15:28:52.073	error	Device 0xa4c138d0b860a01f "TS0601_temperature_humidity_sensor_1" not described in statesMapping.
      2023-09-30 15:28:52.055	info	Currently 7 devices are joined:
      2023-09-30 15:28:52.039	info	--> transmitPower : normal
      2023-09-30 15:28:52.019	info	Unable to disable LED, unsupported function.
      2023-09-30 15:28:52.011	info	Coordinator firmware version: {"type":"zStack3x0","meta":{"transportrev":2,"product":1,"majorrel":2,"minorrel":7,"maintrel":1,"revision":20221226}}
      2023-09-30 15:28:51.629	info	Installed Version: ioBroker/ioBroker.zigbee
      2023-09-30 15:28:50.726	info	Starting Zigbee npm ...
      2023-09-30 15:28:50.723	info	delete old Backup files. keep only last 10
      2023-09-30 15:28:50.572	info	starting. Version 1.8.24 (non-npm: ioBroker/ioBroker.zigbee) in /opt/iobroker/node_modules/iobroker.zigbee, node: v16.19.1, js-controller: 4.0.24
      2023-09-30 15:28:42.984	info	Terminated (ADAPTER_REQUESTED_TERMINATION): Without reason
      2023-09-30 15:28:42.982	info	terminating
      2023-09-30 15:28:42.581	info	Zigbee: disabling joining new devices.
      2023-09-30 15:28:42.480	info	cleaned everything up...
      2023-09-30 15:28:42.476	info	Got terminate signal TERMINATE_YOURSELF
      2023-09-30 15:28:36.100	info	Zigbee: stop joining
      2023-09-30 15:28:32.589	warn	Object of state "zigbee.0.exclude.TS0601_temperature_humidity_sensor_1" is missing the required property "common.type"
      2023-09-30 15:27:48.053	warn	TypeError: Cannot read properties of undefined (reading 'replace') at Commands.deleteDevice (/opt/iobroker/node_modules/iobroker.zigbee/lib/commands.js:449:30) at Commands.onMessage (/opt/iobroker/node_modules/iobroker.zigbee/lib/commands.js:71:30) at Zigbee.<anonymous> (/opt/iobroker/node_modules/iobroker.zigbee/lib/commands.js:14:48) at Zigbee.emit (node:events:525:35) at Zigbee.emit (node:domain:489:12) at change (/opt/iobroker/node_modules/@iobroker/js-controller-adapter/src/lib/adapter/adapter.js:5831:34) at Immediate._onImmediate (/opt/iobroker/node_modules/@iobroker/db-states-redis/lib/states/statesInRedisClient.js:322:37) at processImmediate (node:internal/timers:466:21)
      2023-09-30 15:27:47.747	warn	States system pmessage io.messagebox.system.adapter.zigbee.0 {"command":"deleteDevice","message":{"force":false},"from":"system.adapter.admin.0","callback":{"message":{"force":false},"id":281,"ack":false,"time":1696080467744},"_id":33765716} Cannot read properties of undefined (reading 'replace')
      2023-09-30 15:27:45.353	info	Device '0xa4c138d0b860a01f' is supported, identified as: TuYa Temperature & humidity sensor (TS0601_temperature_humidity_sensor_1)
      2023-09-30 15:27:45.353	info	Successfully interviewed '0xa4c138d0b860a01f', device has successfully been paired
      2023-09-30 15:27:44.122	info	Device '0xa4c138d0b860a01f' announced itself
      2023-09-30 15:27:44.066	info	Starting interview of '0xa4c138d0b860a01f'
      2023-09-30 15:27:34.565	info	Zigbee: allowing new devices to join.
      2023-09-30 15:24:52.284	info	List of port: [{"path":"/dev/ttyUSB0","manufacturer":"Silicon Labs","serialNumber":"0001","pnpId":"usb-Silicon_Labs_Sonoff_Zigbee_3.0_USB_Dongle_Plus_0001-if00-port0","vendorId":"10c4","productId":"ea60"},{"path":"/dev/ttyAMA0"},{"path":"/dev/ttyS0"}]
      2023-09-30 15:21:02.927	info	debug devices set to []
      2023-09-30 15:21:02.883	info	Zigbee started
        Huligan @rocky753 last edited by Huligan
        @rocky753 Hi Rocky, suche mal bitte bei dir nach "_TZE200_zl1kmjqx" in deiner
        /opt/iobroker/node_modules/zigbee-herdsman-converters/devices/tuya.js
        Die wird bei dem Model 'TS0601_temperature_humidity_sensor_1' zu finden sein.
        Mir hats geholfen die Model ID sprich die Zeile mit "TZE200_zl1kmjqx" zu löschen und dann die ID
        bei dem 'TS0601_temperature_humidity_sensor
        _2' einzufügen:
        Bin ein begnadeter Zeichner 😉 f190ade5-b91c-46d1-a502-1f77a4703f71-grafik.png
        Beachte auch die Datapoints, hier ggf. den Humidity .raw Wert durch divideBy10 ersetzen. Sieht man auch im Screenshot.
        Ich hatte eine andere Modelversion wird aber sicher allgemein klappen.
        Dann Speichern, Adapter neustarten und bei dem bereits regestriertem Sensor reconfigure durchführen:
        Außer den Batterystatus kam alles nach einigen Sekunden durch. Bin aber guter Dinge das dieser wie öfters zu lesen auch noch nachgeliefert wird.
        Ich hab meinen Adapter über den Broker direkt installiert also ohne GIT oder Ähnlichem. Vielleicht hilf es ja den einen oder anderen.
        Seht mir nach das ich mich auch nicht tiefer mit dem eigentlichen Problem rumgeärgert hab und nur einen schnellen Workaround gesucht habe.
          arteck Developer Most Active @Huligan last edited by arteck
          @huligan sagte in Zigbee Tuya TS0601 Temperature & Humidity läuft nicht:
          TZE200_zl1kmjqx
          das würde bedeuten dass der
          TZE200_zl1kmjqx nicht TS0601_temperature_humidity_sensor_1 sondern TS0601_temperature_humidity_sensor_2 ist
          hmm
          ichhab mal ein issue angelegt https://github.com/Koenkk/zigbee2mqtt/issues/19092 aber ohne den Sensor ist es schwer
            Huligan @arteck last edited by Huligan
            @arteck Kann ich leider nicht beurteilen. War eher ein ein One-Hit bei einer Trial Error Analyse.
            Die Anpassung beim valueConverter spricht eher dagegen ebenso der noch fehlender Batterie Wert.
            Allerdings vom Bild was der Adapter dann läd passt es aber auch wieder.7c3266f0-3ceb-478f-887f-b82a1d40e7d3-grafik.png
            Zumindest Rund und nicht eckig 😉
            Meine Model-ID war die "_TZE200_bjawzodf"
            Bin kein Entwickler und mir wars eher wichtig die beiden Werte irgendwie zu bekommen als gar nichts.
              rocky753 @Huligan last edited by
              @huligan hat direkt geklappt, DANKE!!!
              Wenn es als "TS0601_temperature_humidity_sensor_2" erkannt wird, passt es. Nur humidity divideby10 noch rein, dann passen auch die Werte. Nur Batterie wird bei auch nicht angezeigt.
                vielleicht hängt ihr ech an das issue dran was ich gepostet habe .. und klärt das.. nicht dass Tuya da wieder murks baut.. und ballert 2 Geräte mit der gleicher id raus..
                  Smo @arteck last edited by
                  Ich hab mich an das Issue rangehängt, weil Huligans Lösung funktionierte, jetzt kam ein Zigbee Update, und die Änderungen sind wieder rückgängig gemacht 😕 Gibts sowas wie eine user.conf, die nicht überschrieben wird?
                    arteck Developer Most Active @Smo last edited by
                    @smo installier die 1.9.2 da ist es korrigiert
                      @arteck Ah, danke dir. Wie find ich die? Das neueste Release was ich finde ist die über npm installierbere 1.9.1. In den Commits steht immer mal was von 1.9.2, also einfach den aktuellen Stand des Repos übernehmen?
                        @smo 1.9.4 ist draussen
                          @arteck Danke. Hab schon 🙂
                          2898
