    3. Off Topic
    4. Proxmox
    5. Proxmox: Fehlermeldung bei backup - vzdump ?
      GOETSCHHOFER @crunchip last edited by
      @crunchip
      Sorry !
      Skript v.2023-10-10
      *** BASE SYSTEM ***
         Static hostname: IOBROKER
               Icon name: computer-vm
                 Chassis: vm
          Virtualization: kvm
        Operating System: Debian GNU/Linux 10 (buster)
                  Kernel: Linux 4.19.0-18-amd64
            Architecture: x86-64
      model name      : Common KVM processor
      Docker          : false
      Virtualization  : kvm
      Kernel          : x86_64
      Userland        : amd64
      Systemuptime and Load:
       09:46:56 up 4 min,  1 user,  load average: 0.00, 0.02, 0.00
      CPU threads: 6
      *** Time and Time Zones ***
                     Local time: Fri 2023-12-29 09:46:56 CET
                 Universal time: Fri 2023-12-29 08:46:56 UTC
                       RTC time: Fri 2023-12-29 08:46:57
                      Time zone: Europe/Vienna (CET, +0100)
                    NTP service: active
                RTC in local TZ: no
      *** User and Groups ***
      karl
      /home/karl
      karl cdrom floppy sudo audio dip video plugdev netdev iobroker
      *** X-Server-Setup ***
      X-Server:       false
      Desktop:
      Terminal:       tty
      *** MEMORY ***
      Mem:           5.5G        178M        4.8G        7.0M        521M        5.0G
      Swap:          974M          0B        974M
      Total:         6.4G        178M        5.7G
               5458 M total memory
                178 M used memory
                275 M active memory
                218 M inactive memory
               4759 M free memory
                 90 M buffer memory
                431 M swap cache
                974 M total swap
                  0 M used swap
                974 M free swap
      *** FAILED SERVICES ***
      0 loaded units listed. Pass --all to see loaded but inactive units, too.
      To show all installed unit files use 'systemctl list-unit-files'.
      *** FILESYSTEM ***
      udev           devtmpfs  2.7G     0  2.7G   0% /dev
      tmpfs          tmpfs     546M  7.3M  539M   2% /run
      /dev/sda1      ext4       19G  4.1G   14G  23% /
      tmpfs          tmpfs     2.7G     0  2.7G   0% /dev/shm
      tmpfs          tmpfs     5.0M     0  5.0M   0% /run/lock
      tmpfs          tmpfs     2.7G     0  2.7G   0% /sys/fs/cgroup
      tmpfs          tmpfs     546M     0  546M   0% /run/user/1000
      [Fri Dec 29 09:42:11 2023] EXT4-fs (sda1): mounted filesystem with ordered data mode. Opts: (null)
      [Fri Dec 29 09:42:11 2023] EXT4-fs (sda1): re-mounted. Opts: errors=remount-ro
      TARGET        SOURCE    FSTYPE OPTIONS
      /             /dev/sda1 ext4   rw,relatime,errors=remount-ro
      `-/sys/fs/bpf bpf       bpf    rw,nosuid,nodev,noexec,relatime,mode=700
      /var:
      413M    /var/
      226M    /var/cache
      220M    /var/cache/apt
      169M    /var/lib
      157M    /var/cache/apt/archives
            Users in the 'systemd-journal' group can see all messages. Pass -q to
            turn off this notice.
      No journal files were opened due to insufficient permissions.
      /opt/iobroker/backups:
      4.0K    /opt/iobroker/backups/
      /opt/iobroker/iobroker-data:
      298M    /opt/iobroker/iobroker-data/
      230M    /opt/iobroker/iobroker-data/files
      67M     /opt/iobroker/iobroker-data/backup-objects
      42M     /opt/iobroker/iobroker-data/files/modbus.admin/static/js
      11M     /opt/iobroker/iobroker-data/files/echarts/static/js/2.0a6dd638.chunk.js.map
      11M     /opt/iobroker/iobroker-data/files/echarts.admin/chart/static/js/2.0a6dd638.chunk.js.map
      9.3M    /opt/iobroker/iobroker-data/files/javascript.admin/static/js/2.b6edad9e.chunk.js.map
      6.8M    /opt/iobroker/iobroker-data/files/echarts.admin/static/js/2.0aad1268.chunk.js.map
      6.2M    /opt/iobroker/iobroker-data/files/modbus.admin/static/js/2.261c158c.chunk.js.map
      USB-Devices by-id:
      *** NodeJS-Installation ***
      /usr/bin/nodejs         v12.22.7
      /usr/bin/node           v12.22.7
      /usr/bin/npm            6.14.15
      /usr/bin/npx            6.14.15
      /home/iobroker/.diag.sh: line 281: corepack: command not found
      *** nodejs is NOT correctly installed ***
      nodejs:
        Installed: 12.22.7-deb-1nodesource1
        Candidate: 12.22.12-deb-1nodesource1
        Version table:
           12.22.12-deb-1nodesource1 500
              500 https://deb.nodesource.com/node_12.x buster/main amd64 Packages
       *** 12.22.7-deb-1nodesource1 100
              100 /var/lib/dpkg/status
           10.24.0~dfsg-1~deb10u3 500
              500 http://security.debian.org/debian-security buster/updates/main amd64 Packages
           10.24.0~dfsg-1~deb10u1 500
              500 http://deb.debian.org/debian buster/main amd64 Packages
      No problems detected
      Errors in npm tree:
      npm ERR! peer dep missing: tough-cookie@>=4.0.0, required by axios-cookiejar-support@2.0.3
      npm ERR! peer dep missing: tough-cookie@^4.0.0, required by http-cookie-agent@1.0.4
      *** ioBroker-Installation ***
      ioBroker Status
       Cannot read system.config: null (OK when migrating or restoring)
       Cannot find view "system" for search "host"
      Objects type: file
      States  type: file
      Core adapters versions
      js-controller:  3.2.16
      admin:          5.1.23
      javascript:     5.1.3
      Adapters from github:   24
      Adapter State
      + instance is alive
      ioBroker-Repositories
      Cannot get list: undefined
      Installed ioBroker-Instances
      Error: Object "system.config" not found
        Thomas Braun Most Active @GOETSCHHOFER last edited by
        @goetschhofer sagte in Proxmox: Fehlermeldung bei backup - vzdump ?:
        Alleine damit:
        bist du schon weit im Rückstand.
        Bring das auf Debian 12 und nodejs v18.
        Und den ioBroker im Zuge dessen dann auch.
          GOETSCHHOFER @Meister Mopper last edited by GOETSCHHOFER
          @meister-mopper
          Vielen Dank für den hilfreichen Tipp, aber ich versteh nur "Bahnhof". 😕
            Thomas Braun Most Active @Meister Mopper last edited by
            @meister-mopper sagte in Proxmox: Fehlermeldung bei backup - vzdump ?:
            @goetschhofer
            Vorschlag:
            Bau da eine neue vm mit einem 64-bit bookworm debian, installier den iobroker mit dem Einzeiler, installier manuell den vis-Adapter und spiel ein (hoffentlich) vorhandenes backitup-Backup ein.
            Da würde ich zuvor im Alt-System noch den ioBroker auf einen aktuellen Stand bringen und ein Backup davon im neuen System einspielen.
              GOETSCHHOFER @Thomas Braun last edited by
              Auch dir vielen lieben Dank für die hilfreichen Tipps. 👍
              Das Problem ist nur, ich brauche eine Schritt für Schritt Anleitung, einfach für "Dummys".
              Thomas Braun crunchip 3 Replies Last reply Reply Quote 0
                Die dürfte es bereits zigfach geben. Bist ja nicht der Erste mit dem 'Problem' der Aufgabe.
                  crunchip Forum Testing Most Active @GOETSCHHOFER last edited by
                  @goetschhofer
                  eine Möglichkeit wäre
                  1. deinen aktuellen js-controller aktualisieren
                  2. alle Adapter soweit möglich abzudaten
                  3. iobroker backup via backitup
                  dann geht es weiter mit Schritt 4
                    Thomas Braun Most Active @GOETSCHHOFER last edited by Thomas Braun
                    @goetschhofer
                    iob stop
                    iob fix
                    iob nodejs-update
                    sollte erstmal nodejs@18 auf das System zaubern.
                    Dann per
                    iob stop
                    iob update
                    iob upgrade
                    iob upgrade self
                    iob start
                    den ioBroker hochziehen.
                    Davon dann (wie gewohnt?) ein Backup extern ablegen.
                    Dann entweder das Debian 10 via Debian 11 auf Debian 12 hieven oder gleich eine frische Installation von Debian 12 im Container vornehmen. Vermutlich ist letzteres einfacher und schneller erledigt.
                    Dann den iobroker 'leer' installieren und den vis-Adapter schon mal installieren. In dieses Grundgerüst legst du dann das Backup wieder rein.
                    Fertig.
                      Schritt 1:
                      ioBroker nodejs fixer 2023-10-13
                      No recommendation for a nodejs version found on your system. We recommend to ins                     tall latest version from nodejs v18 tree.
                      Your current setup is:
                      We found these nodejs versions available for installation:
                      nodejs:
                        Version table:
                      Nothing to do - Your installation is using the correct paths.
                      You are running nodejs v12.22.7. Do you want to install latest version from node                     js v.18 tree?
                      Press <y> to continue or any other key to quit
                      Trying to update your installation now. Please be patient.
                      Virtualization: kvm
                      Waiting for ioBroker to shut down - Give me a minute...
                      *** These repos are active on your system:
                      Hit:1 http://security.debian.org/debian-security buster/updates InRelease
                      Hit:2 http://deb.debian.org/debian buster InRelease
                      Hit:3 http://deb.debian.org/debian buster-updates InRelease
                      Get:4 https://repos.influxdata.com/debian buster InRelease [7047 B]
                      Err:4 https://repos.influxdata.com/debian buster InRelease
                        The following signatures couldn't be verified because the public key is not av                     ailable: NO_PUBKEY D8FF8E1F7DF8B07E
                      Fetched 7047 B in 0s (16.9 kB/s)
                      Reading package lists... Done
                      W: An error occurred during the signature verification. The repository is not up                     dated and the previous index files will be used. GPG error: https://repos.influx                     data.com/debian buster InRelease: The following signatures couldn't be verified                      because the public key is not available: NO_PUBKEY D8FF8E1F7DF8B07E
                      W: Failed to fetch https://repos.influxdata.com/debian/dists/buster/InRelease  T                     he following signatures couldn't be verified because the public key is not avail                     able: NO_PUBKEY D8FF8E1F7DF8B07E
                      W: Some index files failed to download. They have been ignored, or old ones used                      instead.
                      *** Installing ca-certificates, curl and gnupg, just in case they are missing.
                      (Reading database ... 50397 files and directories currently installed.)
                      Preparing to unpack .../00-gpg-wks-client_2.2.12-1+deb10u2_amd64.deb ...
                      Unpacking gpg-wks-client (2.2.12-1+deb10u2) over (2.2.12-1+deb10u1) ...
                      Preparing to unpack .../01-dirmngr_2.2.12-1+deb10u2_amd64.deb ...
                      Unpacking dirmngr (2.2.12-1+deb10u2) over (2.2.12-1+deb10u1) ...
                      Preparing to unpack .../02-gpg-wks-server_2.2.12-1+deb10u2_amd64.deb ...
                      Unpacking gpg-wks-server (2.2.12-1+deb10u2) over (2.2.12-1+deb10u1) ...
                      Preparing to unpack .../03-gnupg-utils_2.2.12-1+deb10u2_amd64.deb ...
                      Unpacking gnupg-utils (2.2.12-1+deb10u2) over (2.2.12-1+deb10u1) ...
                      Preparing to unpack .../04-gpg-agent_2.2.12-1+deb10u2_amd64.deb ...
                      Unpacking gpg-agent (2.2.12-1+deb10u2) over (2.2.12-1+deb10u1) ...
                      Preparing to unpack .../05-gpg_2.2.12-1+deb10u2_amd64.deb ...
                      Unpacking gpg (2.2.12-1+deb10u2) over (2.2.12-1+deb10u1) ...
                      Preparing to unpack .../06-gpgconf_2.2.12-1+deb10u2_amd64.deb ...
                      Unpacking gpgconf (2.2.12-1+deb10u2) over (2.2.12-1+deb10u1) ...
                      Preparing to unpack .../07-gnupg-l10n_2.2.12-1+deb10u2_all.deb ...
                      Unpacking gnupg-l10n (2.2.12-1+deb10u2) over (2.2.12-1+deb10u1) ...
                      Preparing to unpack .../08-gnupg_2.2.12-1+deb10u2_all.deb ...
                      Unpacking gnupg (2.2.12-1+deb10u2) over (2.2.12-1+deb10u1) ...
                      Preparing to unpack .../09-gpgsm_2.2.12-1+deb10u2_amd64.deb ...
                      Unpacking gpgsm (2.2.12-1+deb10u2) over (2.2.12-1+deb10u1) ...
                      Preparing to unpack .../10-gpgv_2.2.12-1+deb10u2_amd64.deb ...
                      Unpacking gpgv (2.2.12-1+deb10u2) over (2.2.12-1+deb10u1) ...
                      Setting up gpgv (2.2.12-1+deb10u2) ...
                      Preparing to unpack .../curl_7.64.0-4+deb10u8_amd64.deb ...
                      Unpacking curl (7.64.0-4+deb10u8) over (7.64.0-4+deb10u2) ...
                      Preparing to unpack .../libcurl4_7.64.0-4+deb10u8_amd64.deb ...
                      Unpacking libcurl4:amd64 (7.64.0-4+deb10u8) over (7.64.0-4+deb10u2) ...
                      Setting up gnupg-l10n (2.2.12-1+deb10u2) ...
                      Setting up gpgconf (2.2.12-1+deb10u2) ...
                      Setting up libcurl4:amd64 (7.64.0-4+deb10u8) ...
                      Setting up curl (7.64.0-4+deb10u8) ...
                      Setting up gpg (2.2.12-1+deb10u2) ...
                      Setting up gnupg-utils (2.2.12-1+deb10u2) ...
                      Setting up gpg-agent (2.2.12-1+deb10u2) ...
                      Setting up gpgsm (2.2.12-1+deb10u2) ...
                      Setting up dirmngr (2.2.12-1+deb10u2) ...
                      Setting up gpg-wks-server (2.2.12-1+deb10u2) ...
                      Setting up gpg-wks-client (2.2.12-1+deb10u2) ...
                      Setting up gnupg (2.2.12-1+deb10u2) ...
                      Processing triggers for man-db (2.8.5-2) ...
                      Processing triggers for libc-bin (2.28-10) ...
                      *** Creating new /etc/apt/sources.list.d/nodesource.list and pinning source
                      deb [signed-by=/etc/apt/keyrings/nodesource.gpg] https://deb.nodesource.com/node                     _18.x nodistro main
                      Package: nodejs
                      Pin: origin deb.nodesource.com
                      Pin-Priority: 1001
                      *** These repos are active after the adjustments:
                      Get:5 https://deb.nodesource.com/node_18.x nodistro InRelease [12.1 kB]
                      Get:6 https://deb.nodesource.com/node_18.x nodistro/main amd64 Packages [6634 B]
                      Fetched 25.8 kB in 0s (52.0 kB/s)
                      Installing the recommended nodejs version now!
                      Exact recommended version unknown, installing a fallback!
                      Preparing to unpack .../nodejs_18.0.0-1nodesource1_amd64.deb ...
                      Detected old npm client, removing...
                      Unpacking nodejs (18.0.0-1nodesource1) over (12.22.7-deb-1nodesource1) ...
                      Setting up nodejs (18.0.0-1nodesource1) ...
                      Updating fallback to latest nodejs v18 release
                      Extracting templates from packages: 100%
                      Preconfiguring packages ...
                      (Reading database ... 51227 files and directories currently installed.)
                      Preparing to unpack .../base-files_10.3+deb10u13_amd64.deb ...
                      Unpacking base-files (10.3+deb10u13) over (10.3+deb10u11) ...
                      Setting up base-files (10.3+deb10u13) ...
                      Installing new version of config file /etc/debian_version ...
                      Preparing to unpack .../archives/dpkg_1.19.8_amd64.deb ...
                      Unpacking dpkg (1.19.8) over (1.19.7) ...
                      Setting up dpkg (1.19.8) ...
                      Preparing to unpack .../gzip_1.9-3+deb10u1_amd64.deb ...
                      Unpacking gzip (1.9-3+deb10u1) over (1.9-3) ...
                      Setting up gzip (1.9-3+deb10u1) ...
                      Preparing to unpack .../ncurses-bin_6.1+20181013-2+deb10u5_amd64.deb ...
                      Unpacking ncurses-bin (6.1+20181013-2+deb10u5) over (6.1+20181013-2+deb10u2) ...
                      Setting up ncurses-bin (6.1+20181013-2+deb10u5) ...
                      Preparing to unpack .../libc6-dev_2.28-10+deb10u2_amd64.deb ...
                      Unpacking libc6-dev:amd64 (2.28-10+deb10u2) over (2.28-10) ...
                      Preparing to unpack .../libc-dev-bin_2.28-10+deb10u2_amd64.deb ...
                      Unpacking libc-dev-bin (2.28-10+deb10u2) over (2.28-10) ...
                      Preparing to unpack .../linux-libc-dev_4.19.289-2_amd64.deb ...
                      Unpacking linux-libc-dev:amd64 (4.19.289-2) over (4.19.208-1) ...
                      Preparing to unpack .../libc6_2.28-10+deb10u2_amd64.deb ...
                      Unpacking libc6:amd64 (2.28-10+deb10u2) over (2.28-10) ...
                      Setting up libc6:amd64 (2.28-10+deb10u2) ...
                      (Reading database ... 51225 files and directories currently installed.)
                      Preparing to unpack .../libc-bin_2.28-10+deb10u2_amd64.deb ...
                      Unpacking libc-bin (2.28-10+deb10u2) over (2.28-10) ...
                      Setting up libc-bin (2.28-10+deb10u2) ...
                      Preparing to unpack .../ncurses-base_6.1+20181013-2+deb10u5_all.deb ...
                      Unpacking ncurses-base (6.1+20181013-2+deb10u5) over (6.1+20181013-2+deb10u2) ...
                      Setting up ncurses-base (6.1+20181013-2+deb10u5) ...
                      Preparing to unpack .../libudev-dev_241-7~deb10u10_amd64.deb ...
                      Unpacking libudev-dev:amd64 (241-7~deb10u10) over (241-7~deb10u8) ...
                      Preparing to unpack .../libsystemd0_241-7~deb10u10_amd64.deb ...
                      Unpacking libsystemd0:amd64 (241-7~deb10u10) over (241-7~deb10u8) ...
                      Setting up libsystemd0:amd64 (241-7~deb10u10) ...
                      Preparing to unpack .../libpam-systemd_241-7~deb10u10_amd64.deb ...
                      Unpacking libpam-systemd:amd64 (241-7~deb10u10) over (241-7~deb10u8) ...
                      Preparing to unpack .../libnss-systemd_241-7~deb10u10_amd64.deb ...
                      Unpacking libnss-systemd:amd64 (241-7~deb10u10) over (241-7~deb10u8) ...
                      Preparing to unpack .../systemd_241-7~deb10u10_amd64.deb ...
                      Unpacking systemd (241-7~deb10u10) over (241-7~deb10u8) ...
                      Preparing to unpack .../udev_241-7~deb10u10_amd64.deb ...
                      Unpacking udev (241-7~deb10u10) over (241-7~deb10u8) ...
                      Preparing to unpack .../libudev1_241-7~deb10u10_amd64.deb ...
                      Unpacking libudev1:amd64 (241-7~deb10u10) over (241-7~deb10u8) ...
                      Setting up libudev1:amd64 (241-7~deb10u10) ...
                      Setting up systemd (241-7~deb10u10) ...
                      Preparing to unpack .../0-systemd-sysv_241-7~deb10u10_amd64.deb ...
                      Unpacking systemd-sysv (241-7~deb10u10) over (241-7~deb10u8) ...
                      Preparing to unpack .../1-libdbus-1-dev_1.12.28-0+deb10u1_amd64.deb ...
                      Unpacking libdbus-1-dev:amd64 (1.12.28-0+deb10u1) over (1.12.20-0+deb10u1) ...
                      Preparing to unpack .../2-dbus_1.12.28-0+deb10u1_amd64.deb ...
                      Unpacking dbus (1.12.28-0+deb10u1) over (1.12.20-0+deb10u1) ...
                      Preparing to unpack .../3-libdbus-1-3_1.12.28-0+deb10u1_amd64.deb ...
                      Unpacking libdbus-1-3:amd64 (1.12.28-0+deb10u1) over (1.12.20-0+deb10u1) ...
                      Preparing to unpack .../4-libexpat1-dev_2.2.6-2+deb10u6_amd64.deb ...
                      Unpacking libexpat1-dev:amd64 (2.2.6-2+deb10u6) over (2.2.6-2+deb10u1) ...
                      Preparing to unpack .../5-libexpat1_2.2.6-2+deb10u6_amd64.deb ...
                      Unpacking libexpat1:amd64 (2.2.6-2+deb10u6) over (2.2.6-2+deb10u1) ...
                      Preparing to unpack .../6-libgmp10_2%3a6.1.2+dfsg-4+deb10u1_amd64.deb ...
                      Unpacking libgmp10:amd64 (2:6.1.2+dfsg-4+deb10u1) over (2:6.1.2+dfsg-4) ...
                      Setting up libgmp10:amd64 (2:6.1.2+dfsg-4+deb10u1) ...
                      Preparing to unpack .../libtasn1-6_4.13-3+deb10u1_amd64.deb ...
                      Unpacking libtasn1-6:amd64 (4.13-3+deb10u1) over (4.13-3) ...
                      Setting up libtasn1-6:amd64 (4.13-3+deb10u1) ...
                      Preparing to unpack .../libgnutls30_3.6.7-4+deb10u11_amd64.deb ...
                      Unpacking libgnutls30:amd64 (3.6.7-4+deb10u11) over (3.6.7-4+deb10u7) ...
                      Setting up libgnutls30:amd64 (3.6.7-4+deb10u11) ...
                      Preparing to unpack .../libfastjson4_0.99.8-2+deb10u1_amd64.deb ...
                      Unpacking libfastjson4:amd64 (0.99.8-2+deb10u1) over (0.99.8-2) ...
                      Preparing to unpack .../zlib1g-dev_1%3a1.2.11.dfsg-1+deb10u2_amd64.deb ...
                      Unpacking zlib1g-dev:amd64 (1:1.2.11.dfsg-1+deb10u2) over (1:1.2.11.dfsg-1) ...
                      Preparing to unpack .../zlib1g_1%3a1.2.11.dfsg-1+deb10u2_amd64.deb ...
                      Unpacking zlib1g:amd64 (1:1.2.11.dfsg-1+deb10u2) over (1:1.2.11.dfsg-1) ...
                      Setting up zlib1g:amd64 (1:1.2.11.dfsg-1+deb10u2) ...
                      Preparing to unpack .../0-rsyslog_8.1901.0-1+deb10u2_amd64.deb ...
                      Unpacking rsyslog (8.1901.0-1+deb10u2) over (8.1901.0-1) ...
                      Preparing to unpack .../1-libwbclient0_2%3a4.9.5+dfsg-5+deb10u4_amd64.deb ...
                      Unpacking libwbclient0:amd64 (2:4.9.5+dfsg-5+deb10u4) over (2:4.9.5+dfsg-5+deb10u1) ...
                      Preparing to unpack .../2-python2.7-dev_2.7.16-2+deb10u3_amd64.deb ...
                      Unpacking python2.7-dev (2.7.16-2+deb10u3) over (2.7.16-2+deb10u1) ...
                      Preparing to unpack .../3-libpython2.7-dev_2.7.16-2+deb10u3_amd64.deb ...
                      Unpacking libpython2.7-dev:amd64 (2.7.16-2+deb10u3) over (2.7.16-2+deb10u1) ...
                      Preparing to unpack .../4-libpython2.7_2.7.16-2+deb10u3_amd64.deb ...
                      Unpacking libpython2.7:amd64 (2.7.16-2+deb10u3) over (2.7.16-2+deb10u1) ...
                      Preparing to unpack .../5-python2.7_2.7.16-2+deb10u3_amd64.deb ...
                      Unpacking python2.7 (2.7.16-2+deb10u3) over (2.7.16-2+deb10u1) ...
                      Preparing to unpack .../6-libssl1.1_1.1.1n-0+deb10u6_amd64.deb ...
                      Unpacking libssl1.1:amd64 (1.1.1n-0+deb10u6) over (1.1.1d-0+deb10u7) ...
                      Preparing to unpack .../7-bzip2_1.0.6-9.2~deb10u2_amd64.deb ...
                      Unpacking bzip2 (1.0.6-9.2~deb10u2) over (1.0.6-9.2~deb10u1) ...
                      Preparing to unpack .../8-libbz2-1.0_1.0.6-9.2~deb10u2_amd64.deb ...
                      Unpacking libbz2-1.0:amd64 (1.0.6-9.2~deb10u2) over (1.0.6-9.2~deb10u1) ...
                      Setting up libbz2-1.0:amd64 (1.0.6-9.2~deb10u2) ...
                      Preparing to unpack .../libncurses6_6.1+20181013-2+deb10u5_amd64.deb ...
                      Unpacking libncurses6:amd64 (6.1+20181013-2+deb10u5) over (6.1+20181013-2+deb10u2) ...
                      Preparing to unpack .../libtinfo6_6.1+20181013-2+deb10u5_amd64.deb ...
                      Unpacking libtinfo6:amd64 (6.1+20181013-2+deb10u5) over (6.1+20181013-2+deb10u2) ...
                      Setting up libtinfo6:amd64 (6.1+20181013-2+deb10u5) ...
                      Preparing to unpack .../libncursesw6_6.1+20181013-2+deb10u5_amd64.deb ...
                      Unpacking libncursesw6:amd64 (6.1+20181013-2+deb10u5) over (6.1+20181013-2+deb10u2) ...
                      Setting up libncursesw6:amd64 (6.1+20181013-2+deb10u5) ...
                      Preparing to unpack .../0-libsqlite3-0_3.27.2-3+deb10u2_amd64.deb ...
                      Unpacking libsqlite3-0:amd64 (3.27.2-3+deb10u2) over (3.27.2-3+deb10u1) ...
                      Preparing to unpack .../1-libpython2.7-stdlib_2.7.16-2+deb10u3_amd64.deb ...
                      Unpacking libpython2.7-stdlib:amd64 (2.7.16-2+deb10u3) over (2.7.16-2+deb10u1) ...
                      Preparing to unpack .../2-python2.7-minimal_2.7.16-2+deb10u3_amd64.deb ...
                      Unpacking python2.7-minimal (2.7.16-2+deb10u3) over (2.7.16-2+deb10u1) ...
                      Preparing to unpack .../3-libpython2.7-minimal_2.7.16-2+deb10u3_amd64.deb ...
                      Unpacking libpython2.7-minimal:amd64 (2.7.16-2+deb10u3) over (2.7.16-2+deb10u1) ...
                      Preparing to unpack .../4-python3.7_3.7.3-2+deb10u6_amd64.deb ...
                      Unpacking python3.7 (3.7.3-2+deb10u6) over (3.7.3-2+deb10u3) ...
                      Preparing to unpack .../5-libpython3.7-stdlib_3.7.3-2+deb10u6_amd64.deb ...
                      Unpacking libpython3.7-stdlib:amd64 (3.7.3-2+deb10u6) over (3.7.3-2+deb10u3) ...
                      Preparing to unpack .../6-python3.7-minimal_3.7.3-2+deb10u6_amd64.deb ...
                      Unpacking python3.7-minimal (3.7.3-2+deb10u6) over (3.7.3-2+deb10u3) ...
                      Preparing to unpack .../7-libpython3.7-minimal_3.7.3-2+deb10u6_amd64.deb ...
                      Unpacking libpython3.7-minimal:amd64 (3.7.3-2+deb10u6) over (3.7.3-2+deb10u3) ...
                      Preparing to unpack .../8-liblzma5_5.2.4-1+deb10u1_amd64.deb ...
                      Unpacking liblzma5:amd64 (5.2.4-1+deb10u1) over (5.2.4-1) ...
                      Setting up liblzma5:amd64 (5.2.4-1+deb10u1) ...
                      Preparing to unpack .../debian-archive-keyring_2019.1+deb10u2_all.deb ...
                      Unpacking debian-archive-keyring (2019.1+deb10u2) over (2019.1+deb10u1) ...
                      Setting up debian-archive-keyring (2019.1+deb10u2) ...
                      (Reading database ... 51231 files and directories currently installed.)
                      Preparing to unpack .../00-tzdata_2021a-0+deb10u12_all.deb ...
                      Unpacking tzdata (2021a-0+deb10u12) over (2021a-0+deb10u3) ...
                      Preparing to unpack .../01-cpio_2.12+dfsg-9+deb10u1_amd64.deb ...
                      Unpacking cpio (2.12+dfsg-9+deb10u1) over (2.12+dfsg-9) ...
                      Preparing to unpack .../02-libisc-export1100_1%3a9.11.5.P4+dfsg-5.1+deb10u9_amd64.deb ...
                      Unpacking libisc-export1100:amd64 (1:9.11.5.P4+dfsg-5.1+deb10u9) over (1:9.11.5.P4+dfsg-5.1+deb10u6) ...
                      Preparing to unpack .../03-libdns-export1104_1%3a9.11.5.P4+dfsg-5.1+deb10u9_amd64.deb ...
                      Unpacking libdns-export1104 (1:9.11.5.P4+dfsg-5.1+deb10u9) over (1:9.11.5.P4+dfsg-5.1+deb10u6) ...
                      Preparing to unpack .../04-isc-dhcp-client_4.4.1-2+deb10u3_amd64.deb ...
                      Unpacking isc-dhcp-client (4.4.1-2+deb10u3) over (4.4.1-2+deb10u1) ...
                      Preparing to unpack .../05-isc-dhcp-common_4.4.1-2+deb10u3_amd64.deb ...
                      Unpacking isc-dhcp-common (4.4.1-2+deb10u3) over (4.4.1-2+deb10u1) ...
                      Preparing to unpack .../06-vim-tiny_2%3a8.1.0875-5+deb10u6_amd64.deb ...
                      Unpacking vim-tiny (2:8.1.0875-5+deb10u6) over (2:8.1.0875-5) ...
                      Preparing to unpack .../07-xxd_2%3a8.1.0875-5+deb10u6_amd64.deb ...
                      Unpacking xxd (2:8.1.0875-5+deb10u6) over (2:8.1.0875-5) ...
                      Preparing to unpack .../08-vim-common_2%3a8.1.0875-5+deb10u6_all.deb ...
                      Unpacking vim-common (2:8.1.0875-5+deb10u6) over (2:8.1.0875-5) ...
                      Preparing to unpack .../09-libicu-dev_63.1-6+deb10u3_amd64.deb ...
                      Unpacking libicu-dev:amd64 (63.1-6+deb10u3) over (63.1-6+deb10u1) ...
                      Preparing to unpack .../10-icu-devtools_63.1-6+deb10u3_amd64.deb ...
                      Unpacking icu-devtools (63.1-6+deb10u3) over (63.1-6+deb10u1) ...
                      Preparing to unpack .../11-libicu63_63.1-6+deb10u3_amd64.deb ...
                      Unpacking libicu63:amd64 (63.1-6+deb10u3) over (63.1-6+deb10u1) ...
                      Preparing to unpack .../12-libxml2_2.9.4+dfsg1-7+deb10u6_amd64.deb ...
                      Unpacking libxml2:amd64 (2.9.4+dfsg1-7+deb10u6) over (2.9.4+dfsg1-7+deb10u2) ...
                      Preparing to unpack .../13-bind9-host_1%3a9.11.5.P4+dfsg-5.1+deb10u9_amd64.deb ...
                      Unpacking bind9-host (1:9.11.5.P4+dfsg-5.1+deb10u9) over (1:9.11.5.P4+dfsg-5.1+deb10u6) ...
                      Preparing to unpack .../14-libbind9-161_1%3a9.11.5.P4+dfsg-5.1+deb10u9_amd64.deb ...
                      Unpacking libbind9-161:amd64 (1:9.11.5.P4+dfsg-5.1+deb10u9) over (1:9.11.5.P4+dfsg-5.1+deb10u6) ...
                      Preparing to unpack .../15-libisccfg163_1%3a9.11.5.P4+dfsg-5.1+deb10u9_amd64.deb ...
                      Unpacking libisccfg163:amd64 (1:9.11.5.P4+dfsg-5.1+deb10u9) over (1:9.11.5.P4+dfsg-5.1+deb10u6) ...
                      Preparing to unpack .../16-libisccc161_1%3a9.11.5.P4+dfsg-5.1+deb10u9_amd64.deb ...
                      Unpacking libisccc161:amd64 (1:9.11.5.P4+dfsg-5.1+deb10u9) over (1:9.11.5.P4+dfsg-5.1+deb10u6) ...
                      Preparing to unpack .../17-libdns1104_1%3a9.11.5.P4+dfsg-5.1+deb10u9_amd64.deb ...
                      Unpacking libdns1104:amd64 (1:9.11.5.P4+dfsg-5.1+deb10u9) over (1:9.11.5.P4+dfsg-5.1+deb10u6) ...
                      Preparing to unpack .../18-libisc1100_1%3a9.11.5.P4+dfsg-5.1+deb10u9_amd64.deb ...
                      Unpacking libisc1100:amd64 (1:9.11.5.P4+dfsg-5.1+deb10u9) over (1:9.11.5.P4+dfsg-5.1+deb10u6) ...
                      Preparing to unpack .../19-libgssapi-krb5-2_1.17-3+deb10u6_amd64.deb ...
                      Unpacking libgssapi-krb5-2:amd64 (1.17-3+deb10u6) over (1.17-3+deb10u3) ...
                      Preparing to unpack .../20-libkrb5-3_1.17-3+deb10u6_amd64.deb ...
                      Unpacking libkrb5-3:amd64 (1.17-3+deb10u6) over (1.17-3+deb10u3) ...
                      Preparing to unpack .../21-libkrb5support0_1.17-3+deb10u6_amd64.deb ...
                      Unpacking libkrb5support0:amd64 (1.17-3+deb10u6) over (1.17-3+deb10u3) ...
                      Preparing to unpack .../22-libk5crypto3_1.17-3+deb10u6_amd64.deb ...
                      Unpacking libk5crypto3:amd64 (1.17-3+deb10u6) over (1.17-3+deb10u3) ...
                      Preparing to unpack .../23-liblwres161_1%3a9.11.5.P4+dfsg-5.1+deb10u9_amd64.deb ...
                      Unpacking liblwres161:amd64 (1:9.11.5.P4+dfsg-5.1+deb10u9) over (1:9.11.5.P4+dfsg-5.1+deb10u6) ...
                      Preparing to unpack .../24-krb5-locales_1.17-3+deb10u6_all.deb ...
                      Unpacking krb5-locales (1.17-3+deb10u6) over (1.17-3+deb10u3) ...
                      Preparing to unpack .../25-libc-l10n_2.28-10+deb10u2_all.deb ...
                      Unpacking libc-l10n (2.28-10+deb10u2) over (2.28-10) ...
                      Preparing to unpack .../26-locales_2.28-10+deb10u2_all.deb ...
                      Unpacking locales (2.28-10+deb10u2) over (2.28-10) ...
                      Preparing to unpack .../27-ncurses-term_6.1+20181013-2+deb10u5_all.deb ...
                      Unpacking ncurses-term (6.1+20181013-2+deb10u5) over (6.1+20181013-2+deb10u2) ...
                      Preparing to unpack .../28-openssh-sftp-server_1%3a7.9p1-10+deb10u4_amd64.deb ...
                      Unpacking openssh-sftp-server (1:7.9p1-10+deb10u4) over (1:7.9p1-10+deb10u2) ...
                      Preparing to unpack .../29-openssh-server_1%3a7.9p1-10+deb10u4_amd64.deb ...
                      Unpacking openssh-server (1:7.9p1-10+deb10u4) over (1:7.9p1-10+deb10u2) ...
                      Preparing to unpack .../30-git-man_1%3a2.20.1-2+deb10u8_all.deb ...
                      Unpacking git-man (1:2.20.1-2+deb10u8) over (1:2.20.1-2+deb10u3) ...
                      Preparing to unpack .../31-libsasl2-modules-db_2.1.27+dfsg-1+deb10u2_amd64.deb ...
                      Unpacking libsasl2-modules-db:amd64 (2.1.27+dfsg-1+deb10u2) over (2.1.27+dfsg-1+deb10u1) ...
                      Preparing to unpack .../32-libsasl2-2_2.1.27+dfsg-1+deb10u2_amd64.deb ...
                      Unpacking libsasl2-2:amd64 (2.1.27+dfsg-1+deb10u2) over (2.1.27+dfsg-1+deb10u1) ...
                      Preparing to unpack .../33-libldap-common_2.4.47+dfsg-3+deb10u7_all.deb ...
                      Unpacking libldap-common (2.4.47+dfsg-3+deb10u7) over (2.4.47+dfsg-3+deb10u6) ...
                      Preparing to unpack .../34-libldap-2.4-2_2.4.47+dfsg-3+deb10u7_amd64.deb ...
                      Unpacking libldap-2.4-2:amd64 (2.4.47+dfsg-3+deb10u7) over (2.4.47+dfsg-3+deb10u6) ...
                      Preparing to unpack .../35-libnghttp2-14_1.36.0-2+deb10u2_amd64.deb ...
                      Unpacking libnghttp2-14:amd64 (1.36.0-2+deb10u2) over (1.36.0-2+deb10u1) ...
                      Preparing to unpack .../36-libssh2-1_1.8.0-2.1+deb10u1_amd64.deb ...
                      Unpacking libssh2-1:amd64 (1.8.0-2.1+deb10u1) over (1.8.0-2.1) ...
                      Preparing to unpack .../37-libcurl3-gnutls_7.64.0-4+deb10u8_amd64.deb ...
                      Unpacking libcurl3-gnutls:amd64 (7.64.0-4+deb10u8) over (7.64.0-4+deb10u2) ...
                      Preparing to unpack .../38-libpcre2-8-0_10.32-5+deb10u1_amd64.deb ...
                      Unpacking libpcre2-8-0:amd64 (10.32-5+deb10u1) over (10.32-5) ...
                      Preparing to unpack .../39-git_1%3a2.20.1-2+deb10u8_amd64.deb ...
                      Unpacking git (1:2.20.1-2+deb10u8) over (1:2.20.1-2+deb10u3) ...
                      Preparing to unpack .../40-openssh-client_1%3a7.9p1-10+deb10u4_amd64.deb ...
                      Unpacking openssh-client (1:7.9p1-10+deb10u4) over (1:7.9p1-10+deb10u2) ...
                      Preparing to unpack .../41-reportbug_7.5.3~deb10u2_all.deb ...
                      Unpacking reportbug (7.5.3~deb10u2) over (7.5.3~deb10u1) ...
                      Preparing to unpack .../42-python3-urllib3_1.24.1-1+deb10u2_all.deb ...
                      Unpacking python3-urllib3 (1.24.1-1+deb10u2) over (1.24.1-1) ...
                      Preparing to unpack .../43-python3-requests_2.21.0-1+deb10u1_all.deb ...
                      Unpacking python3-requests (2.21.0-1+deb10u1) over (2.21.0-1) ...
                      Preparing to unpack .../44-python3-reportbug_7.5.3~deb10u2_all.deb ...
                      Unpacking python3-reportbug (7.5.3~deb10u2) over (7.5.3~deb10u1) ...
                      Preparing to unpack .../45-xz-utils_5.2.4-1+deb10u1_amd64.deb ...
                      Unpacking xz-utils (5.2.4-1+deb10u1) over (5.2.4-1) ...
                      Preparing to unpack .../46-cifs-utils_2%3a6.8-2+deb10u1_amd64.deb ...
                      Unpacking cifs-utils (2:6.8-2+deb10u1) over (2:6.8-2) ...
                      Preparing to unpack .../47-distro-info-data_0.41+deb10u8_all.deb ...
                      Unpacking distro-info-data (0.41+deb10u8) over (0.41+deb10u4) ...
                      Preparing to unpack .../48-dpkg-dev_1.19.8_all.deb ...
                      Unpacking dpkg-dev (1.19.8) over (1.19.7) ...
                      Preparing to unpack .../49-libdpkg-perl_1.19.8_all.deb ...
                      Unpacking libdpkg-perl (1.19.8) over (1.19.7) ...
                      Preparing to unpack .../50-libglib2.0-data_2.58.3-2+deb10u5_all.deb ...
                      Unpacking libglib2.0-data (2.58.3-2+deb10u5) over (2.58.3-2+deb10u3) ...
                      Preparing to unpack .../51-libelf1_0.176-1.1+deb10u1_amd64.deb ...
                      Unpacking libelf1:amd64 (0.176-1.1+deb10u1) over (0.176-1.1) ...
                      Preparing to unpack .../52-libglib2.0-dev_2.58.3-2+deb10u5_amd64.deb ...
                      Unpacking libglib2.0-dev:amd64 (2.58.3-2+deb10u5) over (2.58.3-2+deb10u3) ...
                      Preparing to unpack .../53-libglib2.0-dev-bin_2.58.3-2+deb10u5_amd64.deb ...
                      Unpacking libglib2.0-dev-bin (2.58.3-2+deb10u5) over (2.58.3-2+deb10u3) ...
                      Preparing to unpack .../54-libglib2.0-bin_2.58.3-2+deb10u5_amd64.deb ...
                      Unpacking libglib2.0-bin (2.58.3-2+deb10u5) over (2.58.3-2+deb10u3) ...
                      Preparing to unpack .../55-libglib2.0-0_2.58.3-2+deb10u5_amd64.deb ...
                      Unpacking libglib2.0-0:amd64 (2.58.3-2+deb10u5) over (2.58.3-2+deb10u3) ...
                      Preparing to unpack .../56-librsvg2-dev_2.44.10-2.1+deb10u3_amd64.deb ...
                      Unpacking librsvg2-dev:amd64 (2.44.10-2.1+deb10u3) over (2.44.10-2.1) ...
                      Preparing to unpack .../57-librsvg2-common_2.44.10-2.1+deb10u3_amd64.deb ...
                      Unpacking librsvg2-common:amd64 (2.44.10-2.1+deb10u3) over (2.44.10-2.1) ...
                      Preparing to unpack .../58-librsvg2-2_2.44.10-2.1+deb10u3_amd64.deb ...
                      Unpacking librsvg2-2:amd64 (2.44.10-2.1+deb10u3) over (2.44.10-2.1) ...
                      Preparing to unpack .../59-gir1.2-rsvg-2.0_2.44.10-2.1+deb10u3_amd64.deb ...
                      Unpacking gir1.2-rsvg-2.0:amd64 (2.44.10-2.1+deb10u3) over (2.44.10-2.1) ...
                      Preparing to unpack .../60-grub2-common_2.06-3~deb10u4_amd64.deb ...
                      Unpacking grub2-common (2.06-3~deb10u4) over (2.02+dfsg1-20+deb10u4) ...
                      Preparing to unpack .../61-grub-pc_2.06-3~deb10u4_amd64.deb ...
                      Unpacking grub-pc (2.06-3~deb10u4) over (2.02+dfsg1-20+deb10u4) ...
                      Preparing to unpack .../62-grub-pc-bin_2.06-3~deb10u4_amd64.deb ...
                      Unpacking grub-pc-bin (2.06-3~deb10u4) over (2.02+dfsg1-20+deb10u4) ...
                      Preparing to unpack .../63-libfreetype6-dev_2.9.1-3+deb10u3_amd64.deb ...
                      Unpacking libfreetype6-dev:amd64 (2.9.1-3+deb10u3) over (2.9.1-3+deb10u2) ...
                      Preparing to unpack .../64-libfreetype6_2.9.1-3+deb10u3_amd64.deb ...
                      Unpacking libfreetype6:amd64 (2.9.1-3+deb10u3) over (2.9.1-3+deb10u2) ...
                      Preparing to unpack .../65-grub-common_2.06-3~deb10u4_amd64.deb ...
                      Unpacking grub-common (2.06-3~deb10u4) over (2.02+dfsg1-20+deb10u4) ...
                      Preparing to unpack .../66-libavahi-common-dev_0.7-4+deb10u3_amd64.deb ...
                      Unpacking libavahi-common-dev:amd64 (0.7-4+deb10u3) over (0.7-4+deb10u1) ...
                      Preparing to unpack .../67-libavahi-common-data_0.7-4+deb10u3_amd64.deb ...
                      Unpacking libavahi-common-data:amd64 (0.7-4+deb10u3) over (0.7-4+deb10u1) ...
                      Preparing to unpack .../68-libavahi-common3_0.7-4+deb10u3_amd64.deb ...
                      Unpacking libavahi-common3:amd64 (0.7-4+deb10u3) over (0.7-4+deb10u1) ...
                      Preparing to unpack .../69-libavahi-client-dev_0.7-4+deb10u3_amd64.deb ...
                      Unpacking libavahi-client-dev:amd64 (0.7-4+deb10u3) over (0.7-4+deb10u1) ...
                      Preparing to unpack .../70-libavahi-client3_0.7-4+deb10u3_amd64.deb ...
                      Unpacking libavahi-client3:amd64 (0.7-4+deb10u3) over (0.7-4+deb10u1) ...
                      Preparing to unpack .../71-libavahi-compat-libdnssd-dev_0.7-4+deb10u3_amd64.deb ...
                      Unpacking libavahi-compat-libdnssd-dev:amd64 (0.7-4+deb10u3) over (0.7-4+deb10u1) ...
                      Preparing to unpack .../72-libavahi-compat-libdnssd1_0.7-4+deb10u3_amd64.deb ...
                      Unpacking libavahi-compat-libdnssd1:amd64 (0.7-4+deb10u3) over (0.7-4+deb10u1) ...
                      Preparing to unpack .../73-libfribidi-dev_1.0.5-3.1+deb10u2_amd64.deb ...
                      Unpacking libfribidi-dev:amd64 (1.0.5-3.1+deb10u2) over (1.0.5-3.1+deb10u1) ...
                      Preparing to unpack .../74-libfribidi0_1.0.5-3.1+deb10u2_amd64.deb ...
                      Unpacking libfribidi0:amd64 (1.0.5-3.1+deb10u2) over (1.0.5-3.1+deb10u1) ...
                      Preparing to unpack .../75-libgif-dev_5.1.4-3+deb10u1_amd64.deb ...
                      Unpacking libgif-dev (5.1.4-3+deb10u1) over (5.1.4-3) ...
                      Preparing to unpack .../76-libgif7_5.1.4-3+deb10u1_amd64.deb ...
                      Unpacking libgif7:amd64 (5.1.4-3+deb10u1) over (5.1.4-3) ...
                      Preparing to unpack .../77-libksba8_1.3.5-2+deb10u2_amd64.deb ...
                      Unpacking libksba8:amd64 (1.3.5-2+deb10u2) over (1.3.5-2) ...
                      Preparing to unpack .../78-libpixman-1-dev_0.36.0-1+deb10u1_amd64.deb ...
                      Unpacking libpixman-1-dev:amd64 (0.36.0-1+deb10u1) over (0.36.0-1) ...
                      Preparing to unpack .../79-libpixman-1-0_0.36.0-1+deb10u1_amd64.deb ...
                      Unpacking libpixman-1-0:amd64 (0.36.0-1+deb10u1) over (0.36.0-1) ...
                      Preparing to unpack .../80-libsasl2-modules_2.1.27+dfsg-1+deb10u2_amd64.deb ...
                      Unpacking libsasl2-modules:amd64 (2.1.27+dfsg-1+deb10u2) over (2.1.27+dfsg-1+deb10u1) ...
                      Preparing to unpack .../81-libwebp6_0.6.1-2+deb10u3_amd64.deb ...
                      Unpacking libwebp6:amd64 (0.6.1-2+deb10u3) over (0.6.1-2+deb10u1) ...
                      Preparing to unpack .../82-libtiff5_4.1.0+git191117-2~deb10u8_amd64.deb ...
                      Unpacking libtiff5:amd64 (4.1.0+git191117-2~deb10u8) over (4.1.0+git191117-2~deb10u3) ...
                      Preparing to unpack .../83-libtirpc-common_1.1.4-0.4+deb10u1_all.deb ...
                      Unpacking libtirpc-common (1.1.4-0.4+deb10u1) over (1.1.4-0.4) ...
                      Preparing to unpack .../84-libtirpc3_1.1.4-0.4+deb10u1_amd64.deb ...
                      Unpacking libtirpc3:amd64 (1.1.4-0.4+deb10u1) over (1.1.4-0.4) ...
                      Preparing to unpack .../85-libx11-data_2%3a1.6.7-1+deb10u4_all.deb ...
                      Unpacking libx11-data (2:1.6.7-1+deb10u4) over (2:1.6.7-1+deb10u2) ...
                      Preparing to unpack .../86-libx11-dev_2%3a1.6.7-1+deb10u4_amd64.deb ...
                      Unpacking libx11-dev:amd64 (2:1.6.7-1+deb10u4) over (2:1.6.7-1+deb10u2) ...
                      Preparing to unpack .../87-libx11-6_2%3a1.6.7-1+deb10u4_amd64.deb ...
                      Unpacking libx11-6:amd64 (2:1.6.7-1+deb10u4) over (2:1.6.7-1+deb10u2) ...
                      Preparing to unpack .../88-nodejs_18.19.0-1nodesource1_amd64.deb ...
                      Unpacking nodejs (18.19.0-1nodesource1) over (18.0.0-1nodesource1) ...
                      Preparing to unpack .../89-openssl_1.1.1n-0+deb10u6_amd64.deb ...
                      Unpacking openssl (1.1.1n-0+deb10u6) over (1.1.1d-0+deb10u7) ...
                      Preparing to unpack .../90-publicsuffix_20220811.1734-0+deb10u1_all.deb ...
                      Unpacking publicsuffix (20220811.1734-0+deb10u1) over (20190415.1030-1) ...
                      Preparing to unpack .../91-python-ipaddress_1.0.17-1+deb10u1_all.deb ...
                      Unpacking python-ipaddress (1.0.17-1+deb10u1) over (1.0.17-1) ...
                      Preparing to unpack .../92-python-cryptography_2.6.1-3+deb10u4_amd64.deb ...
                      Unpacking python-cryptography (2.6.1-3+deb10u4) over (2.6.1-3+deb10u2) ...
                      Preparing to unpack .../93-sudo_1.8.27-1+deb10u5_amd64.deb ...
                      Unpacking sudo (1.8.27-1+deb10u5) over (1.8.27-1+deb10u3) ...
                      Preparing to unpack .../94-unzip_6.0-23+deb10u3_amd64.deb ...
                      Unpacking unzip (6.0-23+deb10u3) over (6.0-23+deb10u2) ...
                      Setting up libksba8:amd64 (1.3.5-2+deb10u2) ...
                      Setting up libexpat1:amd64 (2.2.6-2+deb10u6) ...
                      Setting up cpio (2.12+dfsg-9+deb10u1) ...
                      Setting up libpixman-1-0:amd64 (0.36.0-1+deb10u1) ...
                      Setting up systemd-sysv (241-7~deb10u10) ...
                      Setting up libc-l10n (2.28-10+deb10u2) ...
                      Setting up libpixman-1-dev:amd64 (0.36.0-1+deb10u1) ...
                      Setting up libglib2.0-0:amd64 (2.58.3-2+deb10u5) ...
                      No schema files found: doing nothing.
                      Setting up distro-info-data (0.41+deb10u8) ...
                      Setting up libfastjson4:amd64 (0.99.8-2+deb10u1) ...
                      Setting up libssl1.1:amd64 (1.1.1n-0+deb10u6) ...
                      Setting up libtirpc-common (1.1.4-0.4+deb10u1) ...
                      Setting up unzip (6.0-23+deb10u3) ...
                      Setting up libsqlite3-0:amd64 (3.27.2-3+deb10u2) ...
                      Setting up libsasl2-modules:amd64 (2.1.27+dfsg-1+deb10u2) ...
                      Setting up rsyslog (8.1901.0-1+deb10u2) ...
                      Setting up libnghttp2-14:amd64 (1.36.0-2+deb10u2) ...
                      Setting up linux-libc-dev:amd64 (4.19.289-2) ...
                      Setting up libnss-systemd:amd64 (241-7~deb10u10) ...
                      Setting up krb5-locales (1.17-3+deb10u6) ...
                      Setting up bzip2 (1.0.6-9.2~deb10u2) ...
                      Setting up locales (2.28-10+deb10u2) ...
                      Generating locales (this might take a while)...
                        de_AT.UTF-8... done
                      Generation complete.
                      Setting up nodejs (18.19.0-1nodesource1) ...
                      Setting up libldap-common (2.4.47+dfsg-3+deb10u7) ...
                      Setting up libpython3.7-minimal:amd64 (3.7.3-2+deb10u6) ...
                      Setting up libwbclient0:amd64 (2:4.9.5+dfsg-5+deb10u4) ...
                      Setting up libicu63:amd64 (63.1-6+deb10u3) ...
                      Setting up xxd (2:8.1.0875-5+deb10u6) ...
                      Setting up libkrb5support0:amd64 (1.17-3+deb10u6) ...
                      Setting up libsasl2-modules-db:amd64 (2.1.27+dfsg-1+deb10u2) ...
                      Setting up tzdata (2021a-0+deb10u12) ...
                      Current default time zone: 'Europe/Vienna'
                      Local time is now:      Fri Dec 29 10:24:54 CET 2023.
                      Universal Time is now:  Fri Dec 29 09:24:54 UTC 2023.
                      Run 'dpkg-reconfigure tzdata' if you wish to change it.
                      Setting up libglib2.0-data (2.58.3-2+deb10u5) ...
                      Setting up libpython2.7-minimal:amd64 (2.7.16-2+deb10u3) ...
                      Setting up vim-common (2:8.1.0875-5+deb10u6) ...
                      Setting up libfreetype6:amd64 (2.9.1-3+deb10u3) ...
                      Setting up libx11-data (2:1.6.7-1+deb10u4) ...
                      Setting up python2.7-minimal (2.7.16-2+deb10u3) ...
                      Setting up libavahi-common-data:amd64 (0.7-4+deb10u3) ...
                      Setting up libncurses6:amd64 (6.1+20181013-2+deb10u5) ...
                      Setting up libdbus-1-3:amd64 (1.12.28-0+deb10u1) ...
                      Setting up dbus (1.12.28-0+deb10u1) ...
                      A reboot is required to replace the running dbus-daemon.
                      Please reboot the system when convenient.
                      Setting up xz-utils (5.2.4-1+deb10u1) ...
                      Setting up libfribidi0:amd64 (1.0.5-3.1+deb10u2) ...
                      Setting up udev (241-7~deb10u10) ...
                      update-initramfs: deferring update (trigger activated)
                      Setting up libwebp6:amd64 (0.6.1-2+deb10u3) ...
                      Setting up icu-devtools (63.1-6+deb10u3) ...
                      Setting up sudo (1.8.27-1+deb10u5) ...
                      Setting up libudev-dev:amd64 (241-7~deb10u10) ...
                      Setting up libpcre2-8-0:amd64 (10.32-5+deb10u1) ...
                      Setting up libk5crypto3:amd64 (1.17-3+deb10u6) ...
                      Setting up python3.7-minimal (3.7.3-2+deb10u6) ...
                      Setting up libdpkg-perl (1.19.8) ...
                      Setting up libsasl2-2:amd64 (2.1.27+dfsg-1+deb10u2) ...
                      Setting up python3-urllib3 (1.24.1-1+deb10u2) ...
                      Setting up libisc-export1100:amd64 (1:9.11.5.P4+dfsg-5.1+deb10u9) ...
                      Setting up libgif7:amd64 (5.1.4-3+deb10u1) ...
                      Setting up libgif-dev (5.1.4-3+deb10u1) ...
                      Setting up libpam-systemd:amd64 (241-7~deb10u10) ...
                      Setting up git-man (1:2.20.1-2+deb10u8) ...
                      Setting up libx11-6:amd64 (2:1.6.7-1+deb10u4) ...
                      Setting up libssh2-1:amd64 (1.8.0-2.1+deb10u1) ...
                      Setting up isc-dhcp-common (4.4.1-2+deb10u3) ...
                      Setting up libkrb5-3:amd64 (1.17-3+deb10u6) ...
                      Setting up libtiff5:amd64 (4.1.0+git191117-2~deb10u8) ...
                      Setting up libc-dev-bin (2.28-10+deb10u2) ...
                      Setting up openssl (1.1.1n-0+deb10u6) ...
                      Setting up libelf1:amd64 (0.176-1.1+deb10u1) ...
                      Setting up libdns-export1104 (1:9.11.5.P4+dfsg-5.1+deb10u9) ...
                      Setting up publicsuffix (20220811.1734-0+deb10u1) ...
                      Setting up libxml2:amd64 (2.9.4+dfsg1-7+deb10u6) ...
                      Setting up python-ipaddress (1.0.17-1+deb10u1) ...
                      Setting up ncurses-term (6.1+20181013-2+deb10u5) ...
                      Setting up libglib2.0-dev-bin (2.58.3-2+deb10u5) ...
                      Setting up libpython3.7-stdlib:amd64 (3.7.3-2+deb10u6) ...
                      Setting up libfribidi-dev:amd64 (1.0.5-3.1+deb10u2) ...
                      Setting up cifs-utils (2:6.8-2+deb10u1) ...
                      Setting up python-cryptography (2.6.1-3+deb10u4) ...
                      Setting up libavahi-common3:amd64 (0.7-4+deb10u3) ...
                      Setting up libx11-dev:amd64 (2:1.6.7-1+deb10u4) ...
                      Setting up libglib2.0-bin (2.58.3-2+deb10u5) ...
                      Setting up isc-dhcp-client (4.4.1-2+deb10u3) ...
                      Setting up libldap-2.4-2:amd64 (2.4.47+dfsg-3+deb10u7) ...
                      Setting up libisc1100:amd64 (1:9.11.5.P4+dfsg-5.1+deb10u9) ...
                      Setting up vim-tiny (2:8.1.0875-5+deb10u6) ...
                      Setting up dpkg-dev (1.19.8) ...
                      Setting up libpython2.7-stdlib:amd64 (2.7.16-2+deb10u3) ...
                      Setting up librsvg2-2:amd64 (2.44.10-2.1+deb10u3) ...
                      Setting up grub-common (2.06-3~deb10u4) ...
                      Installing new version of config file /etc/grub.d/00_header ...
                      Installing new version of config file /etc/grub.d/05_debian_theme ...
                      Installing new version of config file /etc/grub.d/10_linux ...
                      Installing new version of config file /etc/grub.d/20_linux_xen ...
                      Installing new version of config file /etc/grub.d/30_os-prober ...
                      Installing new version of config file /etc/grub.d/30_uefi-firmware ...
                      Installing new version of config file /etc/grub.d/41_custom ...
                      Setting up libdbus-1-dev:amd64 (1.12.28-0+deb10u1) ...
                      Setting up liblwres161:amd64 (1:9.11.5.P4+dfsg-5.1+deb10u9) ...
                      Setting up python3-requests (2.21.0-1+deb10u1) ...
                      Setting up libgssapi-krb5-2:amd64 (1.17-3+deb10u6) ...
                      Setting up librsvg2-common:amd64 (2.44.10-2.1+deb10u3) ...
                      Setting up libavahi-common-dev:amd64 (0.7-4+deb10u3) ...
                      Setting up libisccc161:amd64 (1:9.11.5.P4+dfsg-5.1+deb10u9) ...
                      Setting up libc6-dev:amd64 (2.28-10+deb10u2) ...
                      Setting up python3-reportbug (7.5.3~deb10u2) ...
                      Setting up gir1.2-rsvg-2.0:amd64 (2.44.10-2.1+deb10u3) ...
                      Setting up libicu-dev:amd64 (63.1-6+deb10u3) ...
                      Setting up libavahi-client3:amd64 (0.7-4+deb10u3) ...
                      Setting up libdns1104:amd64 (1:9.11.5.P4+dfsg-5.1+deb10u9) ...
                      Setting up libtirpc3:amd64 (1.1.4-0.4+deb10u1) ...
                      Setting up python3.7 (3.7.3-2+deb10u6) ...
                      Setting up libpython2.7:amd64 (2.7.16-2+deb10u3) ...
                      Setting up python2.7 (2.7.16-2+deb10u3) ...
                      Setting up grub2-common (2.06-3~deb10u4) ...
                      Installing new version of config file /etc/kernel/postinst.d/zz-update-grub ...
                      Installing new version of config file /etc/kernel/postrm.d/zz-update-grub ...
                      Setting up openssh-client (1:7.9p1-10+deb10u4) ...
                      Setting up libcurl3-gnutls:amd64 (7.64.0-4+deb10u8) ...
                      Setting up libavahi-client-dev:amd64 (0.7-4+deb10u3) ...
                      Setting up reportbug (7.5.3~deb10u2) ...
                      Setting up libavahi-compat-libdnssd1:amd64 (0.7-4+deb10u3) ...
                      Setting up grub-pc-bin (2.06-3~deb10u4) ...
                      Setting up grub-pc (2.06-3~deb10u4) ...
                      Installing for i386-pc platform.
                      Installation finished. No error reported.
                      Generating grub configuration file ...
                      Found linux image: /boot/vmlinuz-4.19.0-18-amd64
                      Found initrd image: /boot/initrd.img-4.19.0-18-amd64
                      Found linux image: /boot/vmlinuz-4.19.0-17-amd64
                      Found initrd image: /boot/initrd.img-4.19.0-17-amd64
                      Warning: os-prober will be executed to detect other bootable partitions.
                      Its output will be used to detect bootable binaries on them and create new boot entries.
                      done
                      Setting up libexpat1-dev:amd64 (2.2.6-2+deb10u6) ...
                      Setting up git (1:2.20.1-2+deb10u8) ...
                      Setting up zlib1g-dev:amd64 (1:1.2.11.dfsg-1+deb10u2) ...
                      Setting up libisccfg163:amd64 (1:9.11.5.P4+dfsg-5.1+deb10u9) ...
                      Setting up openssh-sftp-server (1:7.9p1-10+deb10u4) ...
                      Setting up libpython2.7-dev:amd64 (2.7.16-2+deb10u3) ...
                      Setting up openssh-server (1:7.9p1-10+deb10u4) ...
                      rescue-ssh.target is a disabled or a static unit, not starting it.
                      Setting up libavahi-compat-libdnssd-dev:amd64 (0.7-4+deb10u3) ...
                      Setting up libbind9-161:amd64 (1:9.11.5.P4+dfsg-5.1+deb10u9) ...
                      Setting up libfreetype6-dev:amd64 (2.9.1-3+deb10u3) ...
                      Setting up libglib2.0-dev:amd64 (2.58.3-2+deb10u5) ...
                      Setting up librsvg2-dev:amd64 (2.44.10-2.1+deb10u3) ...
                      Setting up bind9-host (1:9.11.5.P4+dfsg-5.1+deb10u9) ...
                      Setting up python2.7-dev (2.7.16-2+deb10u3) ...
                      Processing triggers for libc-bin (2.28-10+deb10u2) ...
                      Processing triggers for systemd (241-7~deb10u10) ...
                      Processing triggers for libgdk-pixbuf2.0-0:amd64 (2.38.1+dfsg-1) ...
                      Processing triggers for mime-support (3.62) ...
                      Processing triggers for initramfs-tools (0.133+deb10u1) ...
                      update-initramfs: Generating /boot/initrd.img-4.19.0-18-amd64
                      v18.19.0 has been installed! You are using the latest version now!
                      W: An error occurred during the signature verification. The repository is not updated and the previous index files will be used. GPG error: https://repos.influxdata.com/debian buster InRelease: The following signatures couldn't be verified because the public key is not available: NO_PUBKEY D8FF8E1F7DF8B07E
                      W: Failed to fetch https://repos.influxdata.com/debian/dists/buster/InRelease  The following signatures couldn't be verified because the public key is not available: NO_PUBKEY D8FF8E1F7DF8B07E
                      Installing the recommended nodejs version!
                      *** You need to manually restart your container/virtual machine now! ***
                      We tried our best to fix your nodejs. Please run 'iob diag' again to verify.
                      karl@IOBROKER:~$
                      Skript v.2023-10-10
                      *** BASE SYSTEM ***
                                 Chassis: vm
                          Virtualization: kvm
                      Docker          : false
                      Kernel          : x86_64
                      Userland        : amd64
                       10:27:51 up 45 min,  1 user,  load average: 0.09, 0.21, 0.09
                      CPU threads: 6
                      This system needs to be REBOOTED!
                                     Local time: Fri 2023-12-29 10:27:51 CET
                                 Universal time: Fri 2023-12-29 09:27:51 UTC
                                       RTC time: Fri 2023-12-29 09:27:52
                                    NTP service: active
                                RTC in local TZ: no
                      karl
                      /home/karl
                      X-Server:       false
                      Desktop:
                      Terminal:       tty
                      *** MEMORY ***
                      Mem:           5.5G        163M        3.8G        7.0M        1.5G        5.0G
                      Swap:          974M          0B        974M
                      Total:         6.4G        163M        4.8G
                               5458 M total memory
                                163 M used memory
                                380 M active memory
                                972 M inactive memory
                               3795 M free memory
                                 17 M buffer memory
                               1481 M swap cache
                                974 M total swap
                                  0 M used swap
                                974 M free swap
                        UNIT             LOAD   ACTIVE SUB    DESCRIPTION
                      * iobroker.service loaded failed failed ioBroker Server
                      LOAD   = Reflects whether the unit definition was properly loaded.
                      ACTIVE = The high-level unit activation state, i.e. generalization of SUB.
                      SUB    = The low-level unit activation state, values depend on unit type.
                      1 loaded units listed. Pass --all to see loaded but inactive units, too.
                      *** FILESYSTEM ***
                      /dev/sda1      ext4       19G  4.4G   14G  25% /
                      /var:
                      600M    /var/
                      410M    /var/cache
                      403M    /var/cache/apt
                      342M    /var/cache/apt/archives
                      172M    /var/lib
                      USB-Devices by-id:
                      /usr/bin/nodejs         v18.19.0
                      /usr/bin/node           v18.19.0
                      /usr/bin/npm            10.2.3
                      /usr/bin/npx            10.2.3
                      /usr/bin/corepack       0.22.0
                      nodejs:
                        Installed: 18.19.0-1nodesource1
                        Candidate: 18.19.0-1nodesource1
                        Version table:
                       *** 18.19.0-1nodesource1 1001
                              500 https://deb.nodesource.com/node_18.x nodistro/main amd64 Packages
                           18.18.2-1nodesource1 1001
                           18.18.1-1nodesource1 1001
                           18.18.0-1nodesource1 1001
                           18.17.1-1nodesource1 1001
                           18.17.0-1nodesource1 1001
                           18.16.1-1nodesource1 1001
                           18.16.0-1nodesource1 1001
                           18.15.0-1nodesource1 1001
                           18.14.2-1nodesource1 1001
                           18.14.1-1nodesource1 1001
                           18.14.0-1nodesource1 1001
                           18.13.0-1nodesource1 1001
                           18.12.0-1nodesource1 1001
                           18.11.0-1nodesource1 1001
                           18.10.0-1nodesource1 1001
                           18.9.1-1nodesource1 1001
                           18.9.0-1nodesource1 1001
                           18.8.0-1nodesource1 1001
                           18.7.0-1nodesource1 1001
                           18.6.0-1nodesource1 1001
                           18.5.0-1nodesource1 1001
                           18.4.0-1nodesource1 1001
                           18.3.0-1nodesource1 1001
                           18.2.0-1nodesource1 1001
                           18.1.0-1nodesource1 1001
                           18.0.0-1nodesource1 1001
                      Errors in npm tree:
                      npm ERR! code ELSPROBLEMS
                      npm ERR! invalid: tough-cookie@2.5.0 /opt/iobroker/node_modules/tough-cookie
                      npm ERR! A complete log of this run can be found in: /home/karl/.npm/_logs/2023-12-29T09_27_54_481Z-debug-0.log
                      ioBroker Status
                      iobroker is not running on this host.
                      Objects type: file
                      States  type: file
                      admin:          5.1.23
                      javascript:     5.1.3
                      Adapters from github:   14
                      Adapter State
                      + instance is alive
                        Hast du das gemacht?
                          @thomas-braun said in Proxmox: Fehlermeldung bei backup - vzdump ?:
                          Ja, habe ich soeben gemacht ! 👍
                            GOETSCHHOFER @GOETSCHHOFER last edited by
                            @Thomas-Braun
                            iob habe ich in proxmox rebootet.
                            Beim Hochziehen des iob bekomme ich jetzt aber eine Fehlermeldung ?
                            login as: karl
                            karl@192.168.1.176's password:
                            Linux IOBROKER 4.19.0-18-amd64 #1 SMP Debian 4.19.208-1 (2021-09-29) x86_64
                            The programs included with the Debian GNU/Linux system are free software;
                            the exact distribution terms for each program are described in the
                            individual files in /usr/share/doc/*/copyright.
                            Debian GNU/Linux comes with ABSOLUTELY NO WARRANTY, to the extent
                            permitted by applicable law.
                            Last login: Fri Dec 29 10:21:17 2023 from 192.168.1.3
                            karl@IOBROKER:~$ iob stop
                            karl@IOBROKER:~$ iob update
                              crunchip Forum Testing Most Active @GOETSCHHOFER last edited by crunchip
                              das ist ja dein ursprüngliche Problem
                              https://forum.iobroker.net/topic/43325/mini-howto-cannot-find-view-system-for-search-host?_=1616096619995
                              G 2 Replies Last reply Reply Quote 1
                                @crunchip
                                Vorhin nach Eingabe iob diag kam gleich am Anfang auch so eine ähnliche Fehlermeldung mit cannot read system.config: null.
                                The state system.host.IOBROKER.versions.nodeNewestNext was not found!
                                The state system.host.IOBROKER.versions.npmNewestNext was not found!
                                  GOETSCHHOFER @crunchip last edited by GOETSCHHOFER
                                  @crunchip said in Proxmox: Fehlermeldung bei backup - vzdump ?:
                                  karl@IOBROKER:~$ iobroker status
                                  Objects type: file
                                  States  type: file
                                  karl@IOBROKER:~$
                                  Objects type: file
                                  States  type: file
                                  karl@IOBROKER:~$ ^C
                                  karl@IOBROKER:~$ ls -lh /opt/iobroker/iobroker-data/backup-objects/ | grep objec        ts
                                  -rw-rwxr--+ 1 iobroker iobroker 3,8M Dez 24 00:00 2023-12-24_00-00_objects.json.        gz
                                  -rw-rwxr--+ 1 iobroker iobroker 3,8M Dez 24 09:25 2023-12-24_09-25_objects.json.        gz
                                  -rw-rwxr--+ 1 iobroker iobroker 3,8M Dez 24 12:55 2023-12-24_12-55_objects.json.        gz
                                  -rw-rwxr--+ 1 iobroker iobroker 3,8M Dez 25 00:00 2023-12-25_00-00_objects.json.        gz
                                  -rw-rwxr--+ 1 iobroker iobroker 3,8M Dez 25 12:55 2023-12-25_12-55_objects.json.        gz
                                  -rw-rwxr--+ 1 iobroker iobroker 3,8M Dez 26 00:00 2023-12-26_00-00_objects.json.        gz
                                  -rw-rwxr--+ 1 iobroker iobroker 3,8M Dez 26 12:55 2023-12-26_12-55_objects.json.        gz
                                  -rw-rwxr--+ 1 iobroker iobroker 3,8M Dez 27 00:00 2023-12-27_00-00_objects.json.        gz
                                  -rw-rwxr--+ 1 iobroker iobroker 3,8M Dez 27 07:56 2023-12-27_07-56_objects.json.        gz
                                  -rw-rwxr--+ 1 iobroker iobroker 3,8M Dez 27 12:55 2023-12-27_12-55_objects.json.        gz
                                  -rw-rwxr--+ 1 iobroker iobroker 3,8M Dez 28 00:00 2023-12-28_00-00_objects.json.        gz
                                  -rw-rwxr--+ 1 iobroker iobroker 3,8M Dez 28 07:17 2023-12-28_07-17_objects.json.        gz
                                  -rw-rwxr--+ 1 iobroker iobroker 3,8M Dez 28 10:33 2023-12-28_10-33_objects.json.        gz
                                  -rw-rwxr--+ 1 iobroker iobroker 3,8M Dez 28 12:55 2023-12-28_12-55_objects.json.        gz
                                  -rw-rwxr--+ 1 iobroker iobroker 3,8M Dez 29 07:38 2023-12-29_07-38_objects.json.        gz
                                  -rw-rwxr--+ 1 iobroker iobroker 3,4K Dez 29 07:53 2023-12-29_07-53_objects.json.        gz
                                  -rw-rwxr--+ 1 iobroker iobroker 3,4K Dez 29 08:01 2023-12-29_08-01_objects.json.        gz
                                  -rw-rwxr--+ 1 iobroker iobroker 3,4K Dez 29 08:54 2023-12-29_08-54_objects.json.        gz
                                  -rw-rwxr--+ 1 iobroker iobroker 3,4K Dez 29 09:05 2023-12-29_09-05_objects.json.        gz
                                  -rw-rwxr--+ 1 iobroker iobroker 3,4K Dez 29 09:38 2023-12-29_09-38_objects.json.        gz
                                  -rw-rwxr--+ 1 iobroker iobroker 3,4K Dez 29 09:42 2023-12-29_09-42_objects.json.        gz
                                  -rw-rwxr--+ 1 iobroker iobroker 3,4K Dez 29 09:43 2023-12-29_09-43_objects.json.        gz
                                  -rw-rw-r--+ 1 iobroker iobroker 3,6K Dez 29 11:53 2023-12-29_11-53_objects.json.        gz
                                  -rw-rw-r--+ 1 iobroker iobroker 3,6K Dez 29 11:58 2023-12-29_11-58_objects.json.        gz
                                  -rw-rw-r--+ 1 iobroker iobroker 3,6K Dez 29 12:02 2023-12-29_12-02_objects.json.        gz
                                  karl@IOBROKER:~$
                                    hier hast du deinen Sprung
                                      Wäre die Vorgehensweise wie unten angeführt richtig ?
                                      iobroker stop
                                      cd /opt/iobroker/iobroker-data/
                                      mv objects.json objects.json.old
                                      mv states.json states.json.old
                                      cd backup-objects/
                                      Bei den states habe ich offenbar das gleich Problem mit einer 0 Datei.
                                      rw-rwxr--+ 1 iobroker iobroker 138K Dez 28 19:33 2023-12-28_19-33_states.json.g        z
                                      -rw-rwxr--+ 1 iobroker iobroker    0 Dez 29 07:39 2023-12-29_07-39_states.json.g
                                      login as: karl
                                      Last login: Fri Dec 29 12:06:43 2023 from 192.168.1.3
                                      karl@IOBROKER:~$ ls -lh /opt/iobroker/iobroker-data/backup-objects/ | grep state        s
                                      -rw-rwxr--+ 1 iobroker iobroker 138K Dez 27 13:27 2023-12-27_13-27_states.json.g        z
                                      -rw-rwxr--+ 1 iobroker iobroker 138K Dez 27 15:27 2023-12-27_15-27_states.json.g        z
                                      -rw-rwxr--+ 1 iobroker iobroker 138K Dez 27 17:28 2023-12-27_17-28_states.json.g        z
                                      -rw-rwxr--+ 1 iobroker iobroker 138K Dez 27 19:28 2023-12-27_19-28_states.json.g        z
                                      -rw-rwxr--+ 1 iobroker iobroker 138K Dez 27 21:29 2023-12-27_21-29_states.json.g        z
                                      -rw-rwxr--+ 1 iobroker iobroker 138K Dez 27 23:29 2023-12-27_23-29_states.json.g        z
                                      -rw-rwxr--+ 1 iobroker iobroker 138K Dez 28 01:29 2023-12-28_01-29_states.json.g        z
                                      -rw-rwxr--+ 1 iobroker iobroker 138K Dez 28 03:30 2023-12-28_03-30_states.json.g        z
                                      -rw-rwxr--+ 1 iobroker iobroker 138K Dez 28 05:30 2023-12-28_05-30_states.json.g        z
                                      -rw-rwxr--+ 1 iobroker iobroker 138K Dez 28 07:31 2023-12-28_07-31_states.json.g        z
                                      -rw-rwxr--+ 1 iobroker iobroker 138K Dez 28 09:31 2023-12-28_09-31_states.json.g        z
                                      -rw-rwxr--+ 1 iobroker iobroker 139K Dez 28 11:31 2023-12-28_11-31_states.json.g        z
                                      -rw-rwxr--+ 1 iobroker iobroker 138K Dez 28 13:32 2023-12-28_13-32_states.json.g        z
                                      -rw-rwxr--+ 1 iobroker iobroker 139K Dez 28 15:32 2023-12-28_15-32_states.json.g        z
                                      -rw-rwxr--+ 1 iobroker iobroker 138K Dez 28 17:33 2023-12-28_17-33_states.json.g        z
                                      -rw-rwxr--+ 1 iobroker iobroker 138K Dez 28 19:33 2023-12-28_19-33_states.json.g        z
                                      -rw-rwxr--+ 1 iobroker iobroker    0 Dez 29 07:39 2023-12-29_07-39_states.json.g        z
                                      -rw-rwxr--+ 1 iobroker iobroker 138K Dez 29 07:53 2023-12-29_07-53_states.json.g        z
                                      -rw-rwxr--+ 1 iobroker iobroker 138K Dez 29 08:02 2023-12-29_08-02_states.json.g        z
                                      -rw-rwxr--+ 1 iobroker iobroker 138K Dez 29 08:54 2023-12-29_08-54_states.json.g        z
                                      -rw-rwxr--+ 1 iobroker iobroker 138K Dez 29 09:05 2023-12-29_09-05_states.json.g        z
                                      -rw-rwxr--+ 1 iobroker iobroker 138K Dez 29 09:39 2023-12-29_09-39_states.json.g        z
                                      -rw-rwxr--+ 1 iobroker iobroker 138K Dez 29 09:42 2023-12-29_09-42_states.json.g        z
                                      -rw-rwxr--+ 1 iobroker iobroker 138K Dez 29 09:44 2023-12-29_09-44_states.json.g        z
                                      -rw-rw-r--+ 1 iobroker iobroker 138K Dez 29 10:22 2023-12-29_10-22_states.json.g        z
                                      -rw-rw-r--+ 1 iobroker iobroker 139K Dez 29 10:27 2023-12-29_10-27_states.json.g        z
                                      -rw-rw-r--+ 1 iobroker iobroker 139K Dez 29 10:28 2023-12-29_10-28_states.json.g        z
                                      -rw-rw-r--+ 1 iobroker iobroker 139K Dez 29 11:53 2023-12-29_11-53_states.json.g        z
                                      -rw-rw-r--+ 1 iobroker iobroker 139K Dez 29 11:54 2023-12-29_11-54_states.json.g        z
                                      -rw-rw-r--+ 1 iobroker iobroker 139K Dez 29 11:58 2023-12-29_11-58_states.json.g        z
                                      -rw-rw-r--+ 1 iobroker iobroker 139K Dez 29 12:03 2023-12-29_12-03_states.json.g        z
                                      karl@IOBROKER:~$
                                        das ist nur die Hälfte, anschliessend ja noch die intakten json.gz reinpacken
                                        gunzip -ck 2023-12-29_07-38_objects.json.gz > /opt/iobroker/iobroker-data/objects.json
                                        gunzip -ck 2023-12-28_19-33_states.json.gz > /opt/iobroker/iobroker-data/states.json
                                        iobroker start
                                          GOETSCHHOFER last edited by GOETSCHHOFER
                                          @crunchip
                                          Ich hätte noch eine Verständnisfrage:
                                          Habe ja aus meiner täglichen Datensicherung um 12 h (14 Tage zurück) backups meiner VM, u. LXC`s,
                                          letztes backup gestern um 12 h.
                                          Wäre es vielleicht vorteilhafter hier ein restore der VM iobroker zu machen u. anschließend von diesem gesicherten Stand das Ganze nachzuziehen ?
                                            @goetschhofer mag sein das dann dein iobroker zwar wieder läuft, ändert aber an der Tatsache nichts, da du die oben erwähnten Hinweise zum veraltete System nach wie vor ausführen musst.
                                            hat das denn nicht funktioniert mit den json.gz wie oben geschrieben?
                                            81.1k
                                            34079
