    3. Off Topic
    4. Proxmox
    5. Proxmox: Fehlermeldung bei backup - vzdump ?
      GOETSCHHOFER @crunchip last edited by Homoran
      @crunchip said in Proxmox: Fehlermeldung bei backup - vzdump ?:
      @goetschhofer wie ist dann nun der Stand der Dinge?
      iob diag zeigt was?
      Kann es sein dass dies zu lang ist, da ich rechts unten immer eine rote Sprechblase mit einem schwarzen Auge bekomme ?
      *** iob diag is starting up, please wait ***
      The state system.host.IOBROKER.versions.nodeNewestNext was not found!
      The state system.host.IOBROKER.versions.npmNewestNext was not found!
      No problems detected
      Errors in npm tree:
      npm ERR! code ELSPROBLEMS
      npm ERR! invalid: tough-cookie@2.5.0 /opt/iobroker/node_modules/tough-cookie
      npm ERR! A complete log of this run can be found in: /home/karl/.npm/_logs/2023-12-29T13_14_11_484Z-debug-0.log
      *** ioBroker-Installation ***
      Skript v.2023-10-10
      *** BASE SYSTEM ***
         Static hostname: IOBROKER
               Icon name: computer-vm
                 Chassis: vm
          Virtualization: kvm
        Operating System: Debian GNU/Linux 10 (buster)
                  Kernel: Linux 4.19.0-18-amd64
            Architecture: x86-64
      model name      : Common KVM processor
      Docker          : false
      Virtualization  : kvm
      Kernel          : x86_64
      Userland        : amd64
      Systemuptime and Load:
       13:45:03 up 4 min,  1 user,  load average: 0.86, 0.46, 0.19
      CPU threads: 6
      *** Time and Time Zones ***
                     Local time: Fri 2023-12-29 13:45:03 CET
                 Universal time: Fri 2023-12-29 12:45:03 UTC
                       RTC time: Fri 2023-12-29 12:45:04
                      Time zone: Europe/Vienna (CET, +0100)
                    NTP service: active
                RTC in local TZ: no
      *** User and Groups ***
      karl
      /home/karl
      karl cdrom floppy sudo audio dip video plugdev netdev iobroker
      *** X-Server-Setup ***
      X-Server:       false
      Desktop:
      Terminal:       tty
      *** MEMORY ***
      Mem:           5.5G        1.4G        3.5G        7.0M        588M        3.9G
      Swap:          974M          0B        974M
      Total:         6.4G        1.4G        4.5G
               5458 M total memory
               1360 M used memory
               1510 M active memory
                260 M inactive memory
               3509 M free memory
                 79 M buffer memory
                508 M swap cache
                974 M total swap
                  0 M used swap
                974 M free swap
      *** FAILED SERVICES ***
      0 loaded units listed. Pass --all to see loaded but inactive units, too.
      To show all installed unit files use 'systemctl list-unit-files'.
      *** FILESYSTEM ***
      udev           devtmpfs  2.7G     0  2.7G   0% /dev
      tmpfs          tmpfs     546M  7.3M  539M   2% /run
      /dev/sda1      ext4       19G  4.4G   14G  25% /
      tmpfs          tmpfs     2.7G     0  2.7G   0% /dev/shm
      tmpfs          tmpfs     5.0M     0  5.0M   0% /run/lock
      tmpfs          tmpfs     2.7G     0  2.7G   0% /sys/fs/cgroup
      tmpfs          tmpfs     546M     0  546M   0% /run/user/1000
      [Fri Dec 29 13:40:10 2023] EXT4-fs (sda1): mounted filesystem with ordered data        mode. Opts: (null)
      [Fri Dec 29 13:40:10 2023] EXT4-fs (sda1): re-mounted. Opts: errors=remount-ro
      TARGET        SOURCE    FSTYPE OPTIONS
      /             /dev/sda1 ext4   rw,relatime,errors=remount-ro
      `-/sys/fs/bpf bpf       bpf    rw,nosuid,nodev,noexec,relatime,mode=700
      /var:
      612M    /var/
      410M    /var/cache
      403M    /var/cache/apt
      342M    /var/cache/apt/archives
      183M    /var/lib
            Users in the 'systemd-journal' group can see all messages. Pass -q to
            turn off this notice.
      No journal files were opened due to insufficient permissions.
      /opt/iobroker/backups:
      4.0K    /opt/iobroker/backups/
      /opt/iobroker/iobroker-data:
      316M    /opt/iobroker/iobroker-data/
      230M    /opt/iobroker/iobroker-data/files
      53M     /opt/iobroker/iobroker-data/backup-objects
      42M     /opt/iobroker/iobroker-data/files/modbus.admin/static/js
      16M     /opt/iobroker/iobroker-data/objects.json.bak
      11M     /opt/iobroker/iobroker-data/files/echarts/static/js/2.0a6dd638.chunk.js.        map
      11M     /opt/iobroker/iobroker-data/files/echarts.admin/chart/static/js/2.0a6dd6        38.chunk.js.map
      9.3M    /opt/iobroker/iobroker-data/files/javascript.admin/static/js/2.b6edad9e.        chunk.js.map
      USB-Devices by-id:
      USB-Sticks -  Avoid direct links to /dev/* in your adapter setups, please always        prefer the links 'by-id':
      *** NodeJS-Installation ***
      /usr/bin/nodejs         v18.19.0
      /usr/bin/node           v18.19.0
      /usr/bin/npm            10.2.3
      /usr/bin/npx            10.2.3
      /usr/bin/corepack       0.22.0
      nodejs:
        Installed: 18.19.0-1nodesource1
        Candidate: 18.19.0-1nodesource1
        Version table:
       *** 18.19.0-1nodesource1 1001
              500 https://deb.nodesource.com/node_18.x nodistro/main amd64 Packages
              100 /var/lib/dpkg/status
           18.18.2-1nodesource1 1001
           18.18.1-1nodesource1 1001
           18.18.0-1nodesource1 1001
           18.17.1-1nodesource1 1001
           18.17.0-1nodesource1 1001
           18.16.1-1nodesource1 1001
           18.16.0-1nodesource1 1001
           18.15.0-1nodesource1 1001
           18.14.2-1nodesource1 1001
           18.14.1-1nodesource1 1001
           18.14.0-1nodesource1 1001
           18.13.0-1nodesource1 1001
           18.12.0-1nodesource1 1001
           18.11.0-1nodesource1 1001
           18.10.0-1nodesource1 1001
           18.9.1-1nodesource1 1001
           18.9.0-1nodesource1 1001
           18.8.0-1nodesource1 1001
           18.7.0-1nodesource1 1001
           18.6.0-1nodesource1 1001
           18.5.0-1nodesource1 1001
           18.4.0-1nodesource1 1001
           18.3.0-1nodesource1 1001
           18.2.0-1nodesource1 1001
           18.1.0-1nodesource1 1001
           18.0.0-1nodesource1 1001
           10.24.0~dfsg-1~deb10u3 500
              500 http://security.debian.org/debian-security buster/updates/main amd64 Packages
           10.24.0~dfsg-1~deb10u1 500
              500 http://deb.debian.org/debian buster/main amd64 Packages
      Errors in npm tree:
      npm ERR! A complete log of this run can be found in: /home/karl/.npm/_logs/2023-12-29T12_45_05_793Z-debug-0.log
      ioBroker Status
      Objects type: file
      States  type: file
      Core adapters versions
      js-controller:  3.2.16
      admin:          5.1.23
      javascript:     5.1.3
      Adapters from github:   14
      Adapter State
      + system.adapter.admin.0                  : admin                 : IOBROKER                                 -  enabled, port: 8081, bind: 0.0.0.0, run as: admin
        system.adapter.awattar.0                : awattar               : IOBROKER                                 -  enabled
        system.adapter.backitup.0               : backitup              : IOBROKER                                 - disabled
        system.adapter.discovery.0              : discovery             : IOBROKER                                 - disabled
      + system.adapter.email.0                  : email                 : IOBROKER                                 -  enabled
        system.adapter.fhem.0                   : fhem                  : IOBROKER                                 - disabled, port: 7072
      + system.adapter.fronius.0                : fronius               : IOBROKER                                 -  enabled
        system.adapter.icons-icons8.0           : icons-icons8          : IOBROKER                                 - disabled
      + system.adapter.influxdb.0               : influxdb              : IOBROKER                                 -  enabled, port: 8086
      + system.adapter.info.0                   : info                  : IOBROKER                                 -  enabled
      + system.adapter.javascript.0             : javascript            : IOBROKER                                 -  enabled
      + system.adapter.javascript.1             : javascript            : IOBROKER                                 -  enabled
        system.adapter.mbus.0                   : mbus                  : IOBROKER                                 - disabled, port: 3493
      + system.adapter.modbus.0                 : modbus                : IOBROKER                                 -  enabled
        system.adapter.modbus.1                 : modbus                : IOBROKER                                 -  enabled
      + system.adapter.modbus.2                 : modbus                : IOBROKER                                 -  enabled
        system.adapter.modbus.3                 : modbus                : IOBROKER                                 - disabled
      + system.adapter.mqtt.0                   : mqtt                  : IOBROKER                                 -  enabled, port: 1883, bind: 0.0.0.0
        system.adapter.mqtt.1                   : mqtt                  : IOBROKER                                 - disabled, port: 1884, bind: 0.0.0.0
        system.adapter.node-red.0               : node-red              : IOBROKER                                 - disabled, port: 1880, bind: 0.0.0.0
        system.adapter.parser.0                 : parser                : IOBROKER                                 - disabled
        system.adapter.parser.1                 : parser                : IOBROKER                                 - disabled
        system.adapter.parser.2                 : parser                : IOBROKER                                 - disabled
      + system.adapter.proxmox.0                : proxmox               : IOBROKER                                 -  enabled, port: 8006
      + system.adapter.shelly.0                 : shelly                : IOBROKER                                 -  enabled, port: 1882, bind: 0.0.0.0
      + system.adapter.socketio.0               : socketio              : IOBROKER                                 -  enabled, port: 8084, bind: 0.0.0.0, run as: admin
      + system.adapter.sonoff.0                 : sonoff                : IOBROKER                                 -  enabled, port: 1885, bind: 0.0.0.0
      + system.adapter.sourceanalytix.0         : sourceanalytix        : IOBROKER                                 -  enabled
        system.adapter.vis-bars.0               : vis-bars              : IOBROKER                                 - disabled
        system.adapter.vis-materialdesign.0     : vis-materialdesign    : IOBROKER                                 - disabled
        system.adapter.vis.0                    : vis                   : IOBROKER                                 -  enabled
      + system.adapter.web.0                    : web                   : IOBROKER                                 -  enabled, port: 8082, bind: 0.0.0.0, run as: admin
      + instance is alive
      ioBroker-Repositories
      Stable (default): http://download.iobroker.net/sources-dist.json
      Beta (latest): http://download.iobroker.net/sources-dist-latest.json
      live        : http://iobroker.live/repo/sources-dist-latest.json
      Active repo: Stable (default)
      Installed ioBroker-Instances
      Used repository: Stable (default)
      hash unchanged, use cached sources
      update done
      Adapter    "admin"         : 6.12.0   , installed 5.1.23 [Updateable]
      Adapter    "awattar"       : 1.0.6    , installed 1.0.6
      Adapter    "b-control-em"  : 0.3.1    , installed 0.2.1 [Updateable]
      Adapter    "backitup"      : 2.9.8    , installed 2.1.17 [Updateable]
      Adapter    "canbus"        : 1.3.1    , installed 1.3.1
      Adapter    "chromecast"    : 3.0.3    , installed 2.3.1 [Updateable]
      Adapter    "cloud"         : 4.4.1    , installed 4.1.0 [Updateable]
      Adapter    "daswetter"     : 3.1.11   , installed 3.0.7 [Updateable]
      Adapter    "discovery"     : 4.2.0    , installed 2.6.2 [Updateable]
      Adapter    "dwd"           : 2.8.5    , installed 2.7.5 [Updateable]
      Adapter    "echarts"       : 1.5.4    , installed 0.4.13 [Updateable]
      Adapter    "email"         : 1.2.1    , installed 1.0.10 [Updateable]
      Adapter    "fhem"          : 2.0.5    , installed 1.6.0 [Updateable]
      Adapter    "flot"          : 1.12.0   , installed 1.10.6 [Updateable]
      Adapter    "followthesun"  : 0.5.0    , installed 0.3.4 [Updateable]
      Adapter    "fritzdect"     : 2.5.9    , installed 2.1.15 [Updateable]
      Adapter    "fronius"       : 2.0.2    , installed 1.1.6 [Updateable]
      Adapter    "habpanel"      : 0.5.0    , installed 0.4.3 [Updateable]
      Adapter    "homekit-controller": 0.5.8   , installed 0.3.3 [Updateable]
      Adapter    "hs100"         : 2.2.0    , installed 2.0.3 [Updateable]
      Adapter    "icons-icons8"  : 0.0.1    , installed 0.0.1
      Adapter    "influxdb"      : 3.2.0    , installed 1.9.5 [Updateable]
      Adapter    "info"          : 2.0.0    , installed 1.9.8 [Updateable]
      Adapter    "iot"           : 2.0.11   , installed 1.8.22 [Updateable]
      Adapter    "iqontrol"      : 2.3.0    , installed 1.6.4 [Updateable]
      Adapter    "javascript"    : 7.1.6    , installed 5.1.3 [Updateable]
      Controller "js-controller" : 5.0.17   , installed 3.2.16 [Updateable]
      Adapter    "logparser"     : 2.2.0    , installed 1.1.0 [Updateable]
      Adapter    "mbus"          : 2.6.1    , installed 2.4.0 [Updateable]
      Adapter    "modbus"        : 6.0.1    , installed 3.4.14 [Updateable]
      Adapter    "mqtt"          : 5.1.0    , installed 2.4.0 [Updateable]
      Adapter    "mqtt-client"   : 1.7.0    , installed 1.4.0 [Updateable]
      Adapter    "node-red"      : 4.0.3    , installed 2.4.0 [Updateable]
      Adapter    "openweathermap": 0.4.5    , installed 0.1.0 [Updateable]
      Adapter    "parser"        : 2.0.7    , installed 1.0.7 [Updateable]
      Adapter    "ping"          : 1.6.2    , installed 1.4.12 [Updateable]
      Adapter    "proxmox"       : 2.2.2    , installed 1.3.3 [Updateable]
      Adapter    "shelly"        : 6.6.1    , installed 4.0.7 [Updateable]
      Adapter    "simple-api"    : 2.7.2    , installed 2.6.1 [Updateable]
      Adapter    "smart-eq"      : 0.0.4    , installed 0.0.2 [Updateable]
      Adapter    "smartmeter"    : 3.4.0    , installed 3.2.1 [Updateable]
      Adapter    "socketio"      : 6.6.0    , installed 3.1.4 [Updateable]
      Adapter    "sonoff"        : 3.0.3    , installed 2.5.1 [Updateable]
      Adapter    "virtualpowermeter": 1.4.6   , installed 1.4.2 [Updateable]
      Adapter    "vis"           : 1.5.4    , installed 1.4.3 [Updateable]
      Adapter    "vis-bars"      : 0.1.4    , installed 0.1.4
      Adapter    "vis-history"   : 1.0.0    , installed 1.0.0
      Adapter    "vis-materialdesign": 0.5.9   , installed 0.5.1-beta [Updateable]
      Adapter    "web"           : 6.1.10   , installed 3.4.7 [Updateable]
      Objects and States
      Objects:        1187
      States:         2809
      W: An error occurred during the signature verification. The repository is not updated and the previous index files will be used. GPG error: https://repos.influxdata.com/debian buster InRelease: The following signatures couldn't be verified because the public key is not available: NO_PUBKEY D8FF8E1F7DF8B07E
      W: Failed to fetch https://repos.influxdata.com/debian/dists/buster/InRelease  The following signatures couldn't be verified because the public key is not available: NO_PUBKEY D8FF8E1F7DF8B07E
      W: Some index files failed to download. They have been ignored, or old ones used instead.
      Hit:1 http://security.debian.org/debian-security buster/updates InRelease
      Hit:2 http://deb.debian.org/debian buster InRelease
      Hit:3 http://deb.debian.org/debian buster-updates InRelease
      Get:4 https://repos.influxdata.com/debian buster InRelease [7047 B]
      Hit:5 https://deb.nodesource.com/node_18.x nodistro InRelease
      Err:4 https://repos.influxdata.com/debian buster InRelease
      Fetched 7047 B in 1s (13.6 kB/s)
      Reading package lists...
      Pending Updates: 0
      *** Listening Ports ***
      tcp        0      0 0.0.0.0:111             0.0.0.0:*               LISTEN      0          626        1/init
      tcp        0      0 0.0.0.0:22              0.0.0.0:*               LISTEN      0          13262      400/sshd
      tcp        0      0 127.0.0.1:8088          0.0.0.0:*               LISTEN      998        14476      374/influxd
      tcp        0      0 0.0.0.0:1883            0.0.0.0:*               LISTEN      1001       17559      1130/io.mqtt.0
      tcp        0      0 0.0.0.0:1885            0.0.0.0:*               LISTEN      1001       17366      1300/io.sonoff.0
      tcp        0      0 127.0.0.1:9000          0.0.0.0:*               LISTEN      1001       15421      425/iobroker.js-con
      tcp        0      0 127.0.0.1:9001          0.0.0.0:*               LISTEN      1001       13983      425/iobroker.js-con
      tcp6       0      0 :::111                  :::*                    LISTEN      0          634        1/init
      tcp6       0      0 :::8081                 :::*                    LISTEN      1001       15552      537/io.admin.0
      tcp6       0      0 :::8082                 :::*                    LISTEN      1001       16377      1253/io.web.0
      tcp6       0      0 :::8084                 :::*                    LISTEN      1001       16294      1182/io.socketio.0
      tcp6       0      0 :::8086                 :::*                    LISTEN      998        14483      374/influxd
      tcp6       0      0 :::22                   :::*                    LISTEN      0          13264      400/sshd
      udp        0      0 0.0.0.0:68              0.0.0.0:*                           0          12821      309/dhclient
      udp        0      0 0.0.0.0:111             0.0.0.0:*                           0          629        1/init
      udp        0      0 0.0.0.0:5683            0.0.0.0:*                           1001       17586      1156/io.shelly.0
      udp6       0      0 :::111                  :::*                                0          639        1/init
      2023-12-29 13:45:38.484  - silly: modbus.2 (1238) States user redis pmessage modbus.2.*/modbus.2.holdingRegisters.1.40085_AC-Phase_Voltage-L1-V:{"val":233.51,"ack":true,"ts":1703853938467,"q":0,"from":"system.adapter.modbus.2","user":"system.user.admin","lc":1703853938467}
      2023-12-29 13:45:38.484  - silly: modbus.2 (1238) States user redis pmessage modbus.2.*/modbus.2.holdingRegisters.1.40087_AC-Phase_Voltage-L2-V:{"val":231.14,"ack":true,"ts":1703853938467,"q":0,"from":"system.adapter.modbus.2","user":"system.user.admin","lc":1703853938467}
      2023-12-29 13:45:38.484  - silly: modbus.2 (1238) States user redis pmessage modbus.2.*/modbus.2.holdingRegisters.1.40089_AC-Phase_Voltage-L3-V:{"val":230.23,"ack":true,"ts":1703853938467,"q":0,"from":"system.adapter.modbus.2","user":"system.user.admin","lc":1703853938467}
      2023-12-29 13:45:38.484  - silly: modbus.2 (1238) States user redis pmessage modbus.2.*/modbus.2.holdingRegisters.1.40091_AC-Power-W:{"val":247.93,"ack":true,"ts":1703853938467,"q":0,"from":"system.adapter.modbus.2","user":"system.user.admin","lc":1703853938467}
      2023-12-29 13:45:38.484  - silly: modbus.2 (1238) States user redis pmessage modbus.2.*/modbus.2.holdingRegisters.1.40095_AC-Apparent_Power-VA:{"val":248.05,"ack":true,"ts":1703853938467,"q":0,"from":"system.adapter.modbus.2","user":"system.user.admin","lc":1703853938467}
      2023-12-29 13:45:38.484  - silly: modbus.2 (1238) States user redis pmessage modbus.2.*/modbus.2.holdingRegisters.1.40097_AC-Reactive_Power-VAr:{"val":-0.46,"ack":true,"ts":1703853938467,"q":0,"from":"system.adapter.modbus.2","user":"system.user.admin","lc":1703853938467}
      2023-12-29 13:45:38.484  - silly: modbus.2 (1238) States user redis pmessage modbus.2.*/modbus.2.holdingRegisters.1.40099_AC-Power_Faktor:{"val":99.95,"ack":true,"ts":1703853938467,"q":0,"from":"system.adapter.modbus.2","user":"system.user.admin","lc":1703853938467}
      2023-12-29 13:45:38.485  - silly: modbus.2 (1238) States user redis pmessage modbus.2.*/modbus.2.holdingRegisters.1.40107_DC-Power-W:{"val":267.72,"ack":true,"ts":1703853938467,"q":0,"from":"system.adapter.modbus.2","user":"system.user.admin","lc":1703853938467}
      2023-12-29 13:45:38.485  - debug: modbus.2 (1238) [DevID_1/holdingRegs] Poll address 40265 DONE
      2023-12-29 13:45:38.485  - debug: modbus.2 (1238) [DevID_1/holdingRegs/40265] Scale factor value stored from this address = -5
      2023-12-29 13:45:38.485  - debug: modbus.2 (1238) [DevID_1/holdingRegs/40266] Scale factor value stored from this address = -2
      2023-12-29 13:45:38.485  - debug: modbus.2 (1238) [DevID_1/holdingRegs/40267] Scale factor value stored from this address = -2
      2023-12-29 13:45:38.485  - debug: modbus.2 (1238) [DevID_1/holdingRegs/40268] Scale factor value stored from this address = -2
      2023-12-29 13:45:38.489  - debug: modbus.2 (1238) [DevID_1/holdingRegs] Poll address 40282 - 5 registers
      2023-12-29 13:45:38.493  - debug: modbus.2 (1238) [DevID_1/holdingRegs] Poll address 40282 DONE
      2023-12-29 13:45:38.494  - debug: modbus.2 (1238) [DevID_1/holdingRegs/40282] Input Value = 40866
      2023-12-29 13:45:38.494  - debug: modbus.2 (1238) [DevID_1/holdingRegs/40282] Formula = x * Math.pow(10, sf['40265'])
      2023-12-29 13:45:38.494  - debug: modbus.2 (1238) [DevID_1/holdingRegs/40282] Calculation result = 0.40865999999999997, type = number
      2023-12-29 13:45:38.494  - debug: modbus.2 (1238) [DevID_1/holdingRegs/40283] Input Value = 65513
      2023-12-29 13:45:38.494  - debug: modbus.2 (1238) [DevID_1/holdingRegs/40283] Formula = x * Math.pow(10, sf['40266'])
      2023-12-29 13:45:38.494  - debug: modbus.2 (1238) [DevID_1/holdingRegs/40283] Calculation result = 655.13, type = number
      2023-12-29 13:45:38.494  - debug: modbus.2 (1238) [DevID_1/holdingRegs/40285] Input Value = 983880858
      2023-12-29 13:45:38.494  - debug: modbus.2 (1238) [DevID_1/holdingRegs/40285] Formula = x * Math.pow(10, sf['40268'])
      2023-12-29 13:45:38.494  - debug: modbus.2 (1238) [DevID_1/holdingRegs/40285] Calculation result = 9838808.58, type = number
      2023-12-29 13:45:38.539  - silly: modbus.2 (1238) States user redis pmessage modbus.2.*/modbus.2.holdingRegisters.1.40283_DC-Voltage-V:{"val":655.13,"ack":true,"ts":1703853938539,"q":0,"from":"system.adapter.modbus.2","user":"system.user.admin","lc":1703853938539}
      iob diag has finished.
      Press any key for a summary
      karl@IOBROKER:~$
        Thomas Braun Most Active @GOETSCHHOFER last edited by
        @goetschhofer
        Die Baustelle 'influx':
        sudo rm /etc/apt/sources.list.d/infl*
        wget -q https://repos.influxdata.com/influxdata-archive_compat.key
        echo '393e8779c89ac8d958f81f942f9ad7fb82a25e133faddaf92e15b16e6ac9ce4c influxdata-archive_compat.key' | sha256sum -c && cat influxdata-archive_compat.key | gpg --dearmor | sudo tee /usr/share/keyrings/influxdata-archive_compat.gpg > /dev/null
        echo 'deb [signed-by=/usr/share/keyrings/influxdata-archive_compat.gpg] https://repos.influxdata.com/debian stable main' | sudo tee /etc/apt/sources.list.d/influxdata.list
        rm influxdata-archive_compat.key
        sudo apt update
          GOETSCHHOFER @Thomas Braun last edited by
          @thomas-braun said in Proxmox: Fehlermeldung bei backup - vzdump ?:
          @goetschhofer
          sudo apt update
          iobroker läuft jetzt wieder.
          Kann ich dies so einfach reinkopieren ?
            @goetschhofer
            Ja.
              @goetschhofer
              Ja.
              Habe dies durchgeführt, muss ich hier noch etwas machen ?
              Es gibt 2 zusätzliche Versionen. Bitte verwenden Sie die Option »-a«, um sie anzuzeigen.
              login as: karl
              karl@192.168.1.176's password:
              Linux IOBROKER 4.19.0-18-amd64 #1 SMP Debian 4.19.208-1 (2021-09-29) x86_64
              The programs included with the Debian GNU/Linux system are free software;
              the exact distribution terms for each program are described in the
              individual files in /usr/share/doc/*/copyright.
              Debian GNU/Linux comes with ABSOLUTELY NO WARRANTY, to the extent
              permitted by applicable law.
              Last login: Fri Dec 29 14:51:17 2023 from 192.168.1.3
              karl@IOBROKER:~$ sudo rm /etc/apt/sources.list.d/infl*
              [sudo] Passwort für karl:
              karl@IOBROKER:~$ wget -q https://repos.influxdata.com/influxdata-archive_compat.        key
              karl@IOBROKER:~$ echo '393e8779c89ac8d958f81f942f9ad7fb82a25e133faddaf92e15b16e6        ac9ce4c influxdata-archive_compat.key' | sha256sum -c && cat influxdata-archive_        compat.key | gpg --dearmor | sudo tee /usr/share/keyrings/influxdata-archive_com        pat.gpg > /dev/null
              influxdata-archive_compat.key: OK
              karl@IOBROKER:~$ echo 'deb [signed-by=/usr/share/keyrings/influxdata-archive_com        pat.gpg] https://repos.influxdata.com/debian stable main' | sudo tee /etc/apt/so        urces.list.d/influxdata.list
              deb [signed-by=/usr/share/keyrings/influxdata-archive_compat.gpg] https://repos.        influxdata.com/debian stable main
              karl@IOBROKER:~$ rm influxdata-archive_compat.key
              karl@IOBROKER:~$ sudo apt update
              OK:1 http://security.debian.org/debian-security buster/updates InRelease
              OK:2 http://deb.debian.org/debian buster InRelease
              OK:3 http://deb.debian.org/debian buster-updates InRelease
              OK:4 https://deb.nodesource.com/node_18.x nodistro InRelease
              Holen:5 https://repos.influxdata.com/debian stable InRelease [6.901 B]
              Holen:6 https://repos.influxdata.com/debian stable/main amd64 Packages [8.164 B]
              Es wurden 15,1 kB in 1 s geholt (12,3 kB/s).
              Aktualisierung für 1 Paket verfügbar. Führen Sie »apt list --upgradable« aus, um        es anzuzeigen.
              karl@IOBROKER:~$ ^C
              karl@IOBROKER:~$ apt list --upgradable
              Auflistung... Fertig
              linux-image-amd64/oldoldstable 4.19+105+deb10u20 amd64 [aktualisierbar von: 4.19+105+deb10u13]
              N: Es gibt 2 zusätzliche Versionen. Bitte verwenden Sie die Option »-a«, um sie anzuzeigen.
              karl@IOBROKER:~$
                @goetschhofer sagte in Proxmox: Fehlermeldung bei backup - vzdump ?:
                Bei einer VM:
                sudo apt update
                sudo apt full-upgrade
                sudo reboot
                Bei einem LXC sollte das eigentlich nicht gemeldet werden.
                G Karl Götschhofer 2 Replies Last reply Reply Quote 1
                  Iobroker ist bei mir eine VM.
                  • Karl Götschhofer
                    Karl Götschhofer @Thomas Braun last edited by Karl Götschhofer
                    Bei einer VM:
                    sudo apt update
                    sudo reboot
                    Habe vorhin bei supt apt full-upgrade beim 1. Versuch offenbar zu früh abgebrochen, jetzt bekomme ich beim 2. Versuch eine Fehlermeldung, dass die händisch zum Ausführen ist ?
                    Der dpkg-Prozess wurde unterbrochen; Sie müssen manuell »sudo dpkg --configur                                  e -a« ausführen, um das Problem zu beheben
                    login as: karl
                    Last login: Fri Dec 29 15:00:48 2023 from 192.168.1.3
                    OK:4 https://repos.influxdata.com/debian stable InRelease
                    OK:5 https://deb.nodesource.com/node_18.x nodistro InRelease
                    Alle Pakete sind aktuell.
                    karl@IOBROKER:~$ sudo apt full-upgrade
                    E: Der dpkg-Prozess wurde unterbrochen; Sie müssen manuell »sudo dpkg --configur                                  e -a« ausführen, um das Problem zu beheben.
                    karl@IOBROKER:~$ ^C
                    karl@IOBROKER:~$
                      Thomas Braun Most Active @Karl Götschhofer last edited by
                      @karl-götschhofer
                      Warum macht man sowas? Du greifst auch nicht in eine rotierende Maschine, oder?
                      Versuch es mit dem genannten Befehl...
                        GOETSCHHOFER @Thomas Braun last edited by GOETSCHHOFER
                        @karl-götschhofer
                        Sorry, blöd gelaufen, ich könnte mir in den A... beißen.
                        Ich konnte schon wunderbar auf die WebUI vom iobroker zugreifen, nun ist dies leider auch nicht mehr möglich.
                        Habe wieder gefixt, hat aber auch nichts geholfen.🤕
                        Über Putty kann ich zugreifen u. in proxmox läuft auch der iobroker.
                        Du meinst sicherlich ?
                        sudo dpkg --configure -a
                          GOETSCHHOFER @GOETSCHHOFER last edited by
                          @Thomas-Braun
                          Das sudo apt update u. sudo full-upgrade läuft meines Erachtens durch.
                          Beim sudo reboot bekomme ich eine Meldung.
                          login as: karl
                          Linux IOBROKER 4.19.0-25-amd64 #1 SMP Debian 4.19.289-2 (2023-08-08) x86_64
                          Last login: Fri Dec 29 16:13:01 2023 from 192.168.1.3
                          Paketaktualisierung (Upgrade) wird berechnet... Fertig
                          Das folgende Paket wurde automatisch installiert und wird nicht mehr benötigt:
                            linux-image-4.19.0-17-amd64
                          Verwenden Sie »sudo apt autoremove«, um es zu entfernen.
                          0 aktualisiert, 0 neu installiert, 0 zu entfernen und 0 nicht aktualisiert.
                          karl@IOBROKER:~$
                            @goetschhofer
                            sudo apt autoremove
                              sudo apt autoremove
                              Habe ich jetzt durchgeführt, aber Zugriff über WEBUI leider nicht möglich.
                              Please stretch the window of your terminal programm (puTTY) as wide as possible        or switch to full screen
                              The following checks may give hints to potential malconfigurations or errors, pl        ease post them in our forum:
                              https://forum.iobroker.net
                              Just copy and paste the Summary Page, including the ``` characters at start and        end.
                              It helps us to help you!
                              Press any key to continue
                              karl@IOBROKER:~$ sudo apt autoremove
                              Die folgenden Pakete werden ENTFERNT:
                              0 aktualisiert, 0 neu installiert, 1 zu entfernen und 0 nicht aktualisiert.
                              Nach dieser Operation werden 270 MB Plattenplatz freigegeben.
                              Möchten Sie fortfahren? [J/n] J
                              (Lese Datenbank ... 55383 Dateien und Verzeichnisse sind derzeit installiert.)
                              Entfernen von linux-image-4.19.0-17-amd64 (4.19.194-3) ...
                              /etc/kernel/postrm.d/initramfs-tools:
                              update-initramfs: Deleting /boot/initrd.img-4.19.0-17-amd64
                              /etc/kernel/postrm.d/zz-update-grub:
                              Generating grub configuration file ...
                              Found linux image: /boot/vmlinuz-4.19.0-25-amd64
                              Found initrd image: /boot/initrd.img-4.19.0-25-amd64
                              Found linux image: /boot/vmlinuz-4.19.0-18-amd64
                              Found initrd image: /boot/initrd.img-4.19.0-18-amd64
                              Warning: os-prober will be executed to detect other bootable partitions.
                              Its output will be used to detect bootable binaries on them and create new boot        entries.
                              done
                              karl@IOBROKER:~$
                              Soll ich dies jetzt neu durchführen ?
                              sudo apt update
                              sudo reboot
                                Das hat mit dem Kernel aber nix zu tun.
                                iob diag
                                sagt?
                                  GOETSCHHOFER @Thomas Braun last edited by Homoran
                                  iob diag
                                  sagt?
                                  Anfangs kann ich folgendes lesen, welches aber wieder in der Anzeige verschwindet.
                                  The state system.host.IOBROKER.versions.nodeCurrent was not found!
                                  iob diag:
                                  Skript v.2023-10-10
                                  *** BASE SYSTEM ***
                                             Chassis: vm
                                      Virtualization: kvm
                                              Kernel: Linux 4.19.0-25-amd64
                                  Docker          : false
                                  Kernel          : x86_64
                                  Userland        : amd64
                                   17:13:49 up 55 min,  1 user,  load average: 0.07, 0.02, 0.00
                                  CPU threads: 6
                                                 Local time: Fri 2023-12-29 17:13:49 CET
                                             Universal time: Fri 2023-12-29 16:13:49 UTC
                                                   RTC time: Fri 2023-12-29 16:13:50
                                                NTP service: active
                                            RTC in local TZ: no
                                  karl
                                  /home/karl
                                  X-Server:       false
                                  Desktop:
                                  Terminal:       tty
                                  *** MEMORY ***
                                  Mem:           5.5G        269M        4.9G         14M        307M        5.0G
                                  Swap:          974M          0B        974M
                                  Total:         6.4G        269M        5.9G
                                           5458 M total memory
                                            269 M used memory
                                            287 M active memory
                                            184 M inactive memory
                                           4882 M free memory
                                              6 M buffer memory
                                            300 M swap cache
                                            974 M total swap
                                              0 M used swap
                                            974 M free swap
                                  *** FILESYSTEM ***
                                  tmpfs          tmpfs     546M   15M  532M   3% /run
                                  [Fri Dec 29 16:18:25 2023] EXT4-fs (sda1): mounted filesystem with ordered data        mode. Opts: (null)
                                  [Fri Dec 29 16:18:25 2023] EXT4-fs (sda1): re-mounted. Opts: errors=remount-ro
                                  /var:
                                  673M    /var/
                                  457M    /var/cache
                                  451M    /var/cache/apt
                                  388M    /var/cache/apt/archives
                                  194M    /var/lib
                                  280M    /opt/iobroker/iobroker-data/
                                  49M     /opt/iobroker/iobroker-data/backup-objects
                                  6.8M    /opt/iobroker/iobroker-data/files/echarts.admin/static/js/2.0aad1268.chu        nk.js.map
                                  6.2M    /opt/iobroker/iobroker-data/files/modbus.admin/static/js/2.261c158c.chun        k.js.map
                                  USB-Devices by-id:
                                  /usr/bin/npm            10.2.3
                                  /usr/bin/npx            10.2.3
                                  nodejs:
                                    Version table:
                                  **Errors in npm tree:**
                                  npm ERR! A complete log of this run can be found in: /home/karl/.npm/_logs/2023-12-29T16_13_52_837Z-debug-0.log
                                  ioBroker Status
                                   Cannot read system.config: null (OK when migrating or restoring)
                                   Cannot find view "system" for search "host"
                                  Objects type: file
                                  States  type: file
                                  admin:          5.1.23
                                  javascript:     5.1.3
                                  Adapter State
                                  + instance is alive
                                  Cannot get list: undefined
                                  Error: Object "system.config" not found
                                  • Meister Mopper
                                    Meister Mopper @GOETSCHHOFER last edited by
                                    @goetschhofer
                                    Wieso packst du die logs nicht einfach mal in die code tags .
                                    Das ist doch kein Hexenwerk, und alle können die Informationen super gut lesen.
                                      GOETSCHHOFER @Meister Mopper last edited by GOETSCHHOFER
                                      @meister-mopper said in Proxmox: Fehlermeldung bei backup - vzdump ?:
                                      @goetschhofer
                                      Habe ich sicher gemacht, aber offenbar dürfte der Umfang zu groß sein ?
                                      Bei den anderen beiden im Beitrag hat es auch funktioniert, ich habe mich selbst gewundert, dass dies nicht möglich ist.
                                      Habe dies mindestens 5 x probiert, kannst mir glauben, habe es jetzt nochmals probiert.
                                      • Meister Mopper
                                        Meister Mopper @GOETSCHHOFER last edited by Meister Mopper
                                        5 x probiert, kannst mir glauben.
                                        In dem Fall könntest du mal versuchen, öfter den cache deines Browsers zu löschen. Welcher ist es?
                                          @meister-mopper
                                          Ja, vielen Dank für den Hinweis👍
                                          Strg+Shift+Entf Tastenkombination war die Lösung, jetzt funktioniert es.
                                            crunchip Forum Testing Most Active @GOETSCHHOFER last edited by
                                            nö
                                            81.1k
                                            34089
