    4. hm-rpc Probleme
    hm-rpc Probleme
    • Glasfaser
      Glasfaser @Homoran last edited by Glasfaser
      oder
      @Mephisto090
      2023-12-28 12:06:54: (../src/gw_backend.c.274) establishing connection failed: socket: tcp:127.0.0.1:8183: Connection refused
      Mappe den Port 8183:8183 auch mal weiter . ( Firewall )
      https://groups.google.com/g/homekey-app/c/Lhrq3oqnXJA/m/ZjaDggHbvQYJ?pli=1
      EDIT :
      Issues :##https://github.com/jens-maus/RaspberryMatic/issues/2415
      ghost created this issue in jens-maus/RaspberryMatic
      closed HMIP nach Update defekt #2415
        Mephisto090 @Glasfaser last edited by
        @glasfaser said in hm-rpc Probleme:
        Habe ich. Jetzt steht es Plain da
        2023-12-29 15:40:03: (../src/server.c.2078) server stopped by UID = 0 PID = 27178
        2023-12-29 15:40:03: (../src/server.c.1704) server started (lighttpd/1.4.69)
        2023-12-29 15:40:33: (../src/mod_auth.c.850) password doesn't match for /rega.exe username: ioBroker IP: 192.168.178.61
        2023-12-29 15:41:03: (../src/mod_auth.c.850) password doesn't match for /rega.exe username: ioBroker IP: 192.168.178.61
        2023-12-29 15:41:33: (../src/mod_auth.c.850) password doesn't match for /rega.exe username: ioBroker IP: 192.168.178.61
        2023-12-29 15:42:03: (../src/mod_auth.c.850) password doesn't match for /rega.exe username: ioBroker IP: 192.168.178.61
        2023-12-29 15:42:33: (../src/mod_auth.c.850) password doesn't match for /rega.exe username: ioBroker IP: 192.168.178.61
        2023-12-29 15:43:03: (../src/mod_auth.c.850) password doesn't match for /rega.exe username: ioBroker IP: 192.168.178.61
        2023-12-29 15:43:33: (../src/mod_auth.c.850) password doesn't match for /rega.exe username: ioBroker IP: 192.168.178.61
        2023-12-29 15:44:04: (../src/mod_auth.c.850) password doesn't match for /rega.exe username: ioBroker IP: 192.168.178.61
        2023-12-29 15:44:33: (../src/mod_auth.c.850) password doesn't match for /rega.exe username: ioBroker IP: 192.168.178.61
        2023-12-29 15:45:04: (../src/mod_auth.c.850) password doesn't match for /rega.exe username: ioBroker IP: 192.168.178.61
        2023-12-29 15:45:34: (../src/mod_auth.c.850) password doesn't match for /rega.exe username: ioBroker IP: 192.168.178.61
        2023-12-29 15:46:04: (../src/mod_auth.c.850) password doesn't match for /rega.exe username: ioBroker IP: 192.168.178.61
        Das einloggen mit Nutzerdaten geht trotzdem nicht
        Glasfaser Homoran 2 Replies Last reply Reply Quote 0
        • Glasfaser
          Glasfaser @Mephisto090 last edited by
          @mephisto090 sagte in hm-rpc Probleme:
          username: ioBroker
          jetzt taucht auch der Benutzer auf.
          Ich selber habe es ohne https , Benutzer und Passwort laufen . ( Ist ja alles im Haus )
            Homoran Global Moderator Administrators @Mephisto090 last edited by
            ioBroker != iobroker
            • Glasfaser
                  labels:
                    - "autoheal=true"
                    - "com.centurylinklabs.watchtower.enable=true"
                  healthcheck:
                    test: ["CMD", "curl", "-f", "http://localhost:8081"]
                    interval: 30s
                    timeout: 2s
                    retries: 2
                    start_period: 3m30s
              Ist OT ..
              Watchtower ist mir klar ...
              Aber healthcheck hat das Image doch selber !?
              bzw. wo hast du die Compose her !?
                Mephisto090 @Homoran last edited by
                @homoran said in hm-rpc Probleme:
                habe beides probiert. Er zeigt komischerweise immer ioBroker an. Habe sogar kleingeschrieben den Nutzer neu angelegt.
                Ist OT ..
                Habe ich mir irgendwann mal selbst zusammengebaut
                  hast du noch andere hm-rpc Instanzen?
                    Nein, da ich nur HmIP Geräte habe.
                      @mephisto090 boote mal beides neu!
                      ccu und iob
                        ccu und iob
                        Hatte ich bei beiden um die Portweiterleitung eingeben zu können
                        6072
