    4. <gelöst> Serieller Port defekt
      searcher57 @Homoran last edited by
      @homoran said in Serieller Port defekt:
      @searcher57 iob diag in der Langfassung bitte
      v.2023-10-10
      Static hostname: raspberrypi
      Icon name: computer
      Operating System: Debian GNU/Linux 11 (bullseye)
      Kernel: Linux 6.1.21-v8+
      Architecture: arm64
      Installation: native
      Kernel: aarch64
      Userland: arm64
      Timezone: Europe/Berlin (CET, +0100)
      User-ID: 1000
      X-Server: false
      Boot Target: multi-user.target
      Pending OS-Updates: 0
      Pending iob updates: 0
      Nodejs-Installation: /usr/bin/nodejs v18.19.0
      /usr/bin/node v18.19.0
      /usr/bin/npm 10.2.3
      /usr/bin/npx 10.2.3
      /usr/bin/corepack 0.22.0
      Recommended versions are nodejs 18.19.0 and npm 10.2.3
      MEMORY:
      total used free shared buff/cache available
      Mem: 7.8G 2.0G 5.1G 1.0M 742M 5.7G
      Swap: 99M 0B 99M
      Total: 7.9G 2.0G 5.2G
      Active iob-Instances: 23
      Active repo(s): stable
      ioBroker Core: js-controller 5.0.17
      admin 6.12.0
      ioBroker Status: iobroker is running on this host.
      Objects type: jsonl
      States type: jsonl
      • system.adapter.admin.0 : admin : raspberrypi - enabled, port: 8081, bind: 0.0.0.0, run as: admin
      • system.adapter.web.0 : web : raspberrypi - enabled, port: 8082, bind: 0.0.0.0, run as: admin
      Objects: 10746
      States: 8973
      Size of iob-Database:
      38M /opt/iobroker/iobroker-data/objects.jsonl
      2.1M /opt/iobroker/iobroker-data/states.jsonl
      === Mark text until here for copying ===
      pi@raspberrypi:~ $ ```
      > Skript v.2023-10-10
      > *** BASE SYSTEM ***
      >          Icon name: computer
      >       Architecture: arm64
      > Model           : Raspberry Pi 4 Model B Rev 1.5
      > Docker          : false
      > Virtualization  : none
      > Kernel          : aarch64
      > Userland        : arm64
      > Systemuptime and Load:
      >  17:00:01 up  3:25,  1 user,  load average: 0.27, 0.21, 0.22
      > CPU threads: 4
      > *** RASPBERRY THROTTLING ***
      > Current issues:
      > No throttling issues detected.
      > Previously detected issues:
      v> *** Time and Time Zones ***
      >                Local time: Fri 2023-12-29 17:00:01 CET
      >            Universal time: Fri 2023-12-29 16:00:01 UTC
      >                  RTC time: n/a
      >                 Time zone: Europe/Berlin (CET, +0100)
      > System clock synchronized: yes
      >               NTP service: active
      >           RTC in local TZ: no
      > *** User and Groups ***
      > pi
      > /home/pi
      > pi adm dialout cdrom sudo audio video plugdev games users input render netdev gp        io i2c spi iobroker
      > *** X-Server-Setup ***
      > X-Server:       false
      > Desktop:
      > Terminal:       tty
      > *** MEMORY ***
      > Mem:            7.8G        2.0G        5.1G        1.0M        717M        5.7G
      > Swap:            99M          0B         99M
      >          7812 M total memory
      >          1989 M used memory
      >          2126 M active memory
      >           454 M inactive memory
      >          5105 M free memory
      >            63 M buffer memory
      >           653 M swap cache
      >            99 M total swap
      >             0 M used swap
      >            99 M free swap
      > Raspberry only:
      > oom events: 0
      > lifetime oom required: 0 Mbytes
      > total time in oom handler: 0 ms
      > max time spent in oom handler: 0 ms
      > *** FAILED SERVICES ***
      >   UNIT LOAD ACTIVE SUB DESCRIPTION
      > 0 loaded units listed.
      > *** FILESYSTEM ***
      > Filesystem     Type      Size  Used Avail Use% Mounted on
      > /dev/root      ext4       29G  7.5G   21G  27% /
      > devtmpfs       devtmpfs  3.6G     0  3.6G   0% /dev
      > tmpfs          tmpfs     3.9G     0  3.9G   0% /dev/shm
      > tmpfs          tmpfs     1.6G  1.2M  1.6G   1% /run
      > tmpfs          tmpfs     5.0M  4.0K  5.0M   1% /run/lock
      > /dev/mmcblk0p1 vfat      255M   31M  225M  13% /boot
      > /dev/sda1      exfat      29G  111M   29G   1% /mnt/usb0
      > tmpfs          tmpfs     782M     0  782M   0% /run/user/1000
      > Messages concerning ext4 filesystem in dmesg:
      > [Fri Dec 29 13:34:19 2023] Kernel command line: coherent_pool=1M 8250.nr_uarts=1        snd_bcm2835.enable_headphones=0 snd_bcm2835.enable_headphones=1 snd_bcm2835.ena        ble_hdmi=1 snd_bcm2835.enable_hdmi=0  smsc95xx.macaddr=D8:3A:DD:43:B6:26 vc_mem.        mem_base=0x3ec00000 vc_mem.mem_size=0x40000000  console=tty1 console=ttyS0,11520        0 root=PARTUUID=f28374b8-02 rootfstype=ext4 fsck.repair=yes rootwait
      > [Fri Dec 29 13:34:22 2023] EXT4-fs (mmcblk0p2): mounted filesystem with ordered        data mode. Quota mode: none.
      > [Fri Dec 29 13:34:22 2023] VFS: Mounted root (ext4 filesystem) readonly on devic        e 179:2.
      > [Fri Dec 29 13:34:25 2023] EXT4-fs (mmcblk0p2): re-mounted. Quota mode: none.
      > Show mounted filesystems \(real ones only\):
      > TARGET      SOURCE         FSTYPE OPTIONS
      > /           /dev/mmcblk0p2 ext4   rw,noatime
      > |-/boot     /dev/mmcblk0p1 vfat   rw,relatime,fmask=0022,dmask=0022,codepage=437        ,iocharset=ascii,shortname=mixed,errors=remount-ro
      > `-/mnt/usb0 /dev/sda1      exfat  rw,nosuid,nodev,noexec,relatime,fmask=0000,dma        sk=0000,allow_utime=0022,iocharset=utf8,errors=remount-ro
      -bash: Skript: Kommando nicht gefunden.
      -bash: dplvvänng: Kommando nicht gefunden.
      -bash: Static: Kommando nicht gefunden.
      -bash: Icon: Kommando nicht gefunden.
      -bash: command substitution: Zeile 7: Syntaxfehler beim unerwarteten Symbol »(«
      -bash: command substitution: Zeile 7: `  Operating System: Debian GNU/Linux 11 (bullseye)'
      -bash: -/mnt/usb0: Datei oder Verzeichnis nicht gefunden
      pi@raspberrypi:~ $
      pi@raspberrypi:~ $ Files in neuralgic directories:
      -bash: Files: Kommando nicht gefunden.
      pi@raspberrypi:~ $
      pi@raspberrypi:~ $ /var:
      -bash: /var:: Datei oder Verzeichnis nicht gefunden
      pi@raspberrypi:~ $ 2.7G    /var/
      -bash: 2.7G: Kommando nicht gefunden.
      pi@raspberrypi:~ $ 2.0G    /var/log
      -bash: 2.0G: Kommando nicht gefunden.
      pi@raspberrypi:~ $ 1.9G    /var/log/journal/d6ace433f2bf45719775348c9ccdd23f
      -bash: 1.9G: Kommando nicht gefunden.
      pi@raspberrypi:~ $ 321M    /var/lib
      -bash: 321M: Kommando nicht gefunden.
      pi@raspberrypi:~ $
      mpi@raspberrypi:~ $ Archived and active journals take up 1.8G in the file system.
      -bash: Archived: Kommando nicht gefunden.
      pi@raspberrypi:~ $
      pi@raspberrypi:~ $ /opt/iobroker/backups:
      -bash: /opt/iobroker/backups:: Datei oder Verzeichnis nicht gefunden
      pi@raspberrypi:~ $ 109M    /opt/iobroker/backups/
      -bash: 109M: Kommando nicht gefunden.
      pi@raspberrypi:~ $
      xpi@raspberrypi:~ $ /opt/iobroker/iobroker-data:
      -bash: /opt/iobroker/iobroker-data:: Datei oder Verzeichnis nicht gefunden
      pi@raspberrypi:~ $ 575M    /opt/iobroker/iobroker-data/
      -bash: 575M: Kommando nicht gefunden.
      pi@raspberrypi:~ $ 430M    /opt/iobroker/iobroker-data/files
      -bash: 430M: Kommando nicht gefunden.
      pi@raspberrypi:~ $ 89M     /opt/iobroker/iobroker-data/files/echarts.admin
      -bash: 89M: Kommando nicht gefunden.
      pi@raspberrypi:~ $ 86M     /opt/iobroker/iobroker-data/backup-objects
      -bash: 86M: Kommando nicht gefunden.
      pi@raspberrypi:~ $ 67M     /opt/iobroker/iobroker-data/files/javascript.admin
      -bash: 67M: Kommando nicht gefunden.
      pi@raspberrypi:~ $
      pi@raspberrypi:~ $ The five largest files in iobroker-data are:
      -bash: The: Kommando nicht gefunden.
      pi@raspberrypi:~ $ 38M     /opt/iobroker/iobroker-data/objects.jsonl
      -bash: 38M: Kommando nicht gefunden.
      pi@raspberrypi:~ $ 35M     /opt/iobroker/iobroker-data/files/devices.admin/static/js/main.24f2bb56.        js.map
      001
              500 ht-bash: 35M: Kommando nicht gefunden.
      pi@raspberrypi:~ $ 33M     /opt/iobroker/iobroker-data/files/iot.admin/static/js/main.1797d034.js.m        ap
      -bash: 33M: Kommando nicht gefunden.
      pi@raspberrypi:~ $ 24M     /opt/iobroker/iobroker-data/files/echarts/static/js/main.6841ce54.js.map
      -bash: 24M: Kommando nicht gefunden.
      pi@raspberrypi:~ $ 24M     /opt/iobroker/iobroker-data/files/echarts.admin/chart/static/js/main.684        1ce54.js.map
      pi@raspberrypi:~ $
       pi@raspberrypi:~ $ USB-Devices by-id:
      -bash: USB-Devices: Kommando nicht gefunden.
      pi@raspberrypi:~ $ USB-Sticks -  Avoid direct links to /dev/* in your adapter setups, please always        prefer the links 'by-id':
      -bash: USB-Sticks: Kommando nicht gefunden.
      pi@raspberrypi:~ $
      pi@raspberrypi:~ $ find: '/dev/serial/by-id/': No such file or directory
      -bash: find:: Kommando nicht gefunden.
      pi@raspberrypi:~ $
      pi@raspberrypi:~ $ *** NodeJS-Installation ***
      pi@raspberrypi:~ $
      pi@raspberrypi:~ $ /usr/bin/nodejs         v18.19.0
      node:internal/modules/cjs/loader:1137
        throw err;
      Error: Cannot find module '/home/pi/v18.19.0'
          at Module._resolveFilename (node:internal/modules/cjs/loader:1134:15)
          at Module._load (node:internal/modules/cjs/loader:975:27)
          at Function.executeUserEntryPoint [as runMain] (node:internal/modules/run_main:128:12)
          at node:internal/main/run_main_module:28:49 {
        code: 'MODULE_NOT_FOUND',
        requireStack: []
      Node.js v18.19.0
      pi@raspberrypi:~ $ /usr/bin/node           v18.19.0
        throw err;
        requireStack: []
      Node.js v18.19.0
      pi@raspberrypi:~ $ /usr/bin/npm            10.2.3
      Unknown command: "10.2.3"
      To see a list of supported npm commands, run:
        npm help
      pi@raspberrypi:~ $ /usr/bin/npx            10.2.3
      npm notice
      npm notice New patch version of npm available! 10.2.3 -> 10.2.5
      npm notice Changelog: https://github.com/npm/cli/releases/tag/v10.2.5
      npm notice Run npm install -g npm@10.2.5 to update!
      npm notice
      npm ERR! code E404
      npm ERR! 404 Not Found - GET https://registry.npmjs.org/10.2.3 - Not found
      npm ERR! 404
      npm ERR! 404  '10.2.3@*' is not in this registry.
      npm ERR! 404
      npm ERR! 404 Note that you can also install from a
      npm ERR! 404 tarball, folder, http url, or git url.
      npm ERR! A complete log of this run can be found in: /home/pi/.npm/_logs/2023-12-29T16_02_42_886Z-debug-0.log
      pi@raspberrypi:~ $ /usr/bin/corepack       0.22.0
      Unknown Syntax Error: Command not found; did you mean one of:
        0. corepack -h
        1. corepack -v
        2. corepack disable [--install-directory #0] ...
        3. corepack enable [--install-directory #0] ...
        4. corepack install <-g,--global> [--all] [--cache-only] ...
        5. corepack install
        6. corepack pack [--all] [--json] [-o,--output #0] ...
        7. corepack up
        8. corepack use <pattern>
        9. corepack hydrate [--activate] <fileName>
       10. corepack prepare [--activate] [--all] [--json] [-o,--output] ...
      While running 0.22.0
      pi@raspberrypi:~ $
       pi@raspberrypi:~ $
       pi@raspberrypi:~ $ nodejs:
      -bash: nodejs:: Kommando nicht gefunden.
      pi@raspberrypi:~ $   Installed: 18.19.0-1nodesource1
      -bash: Installed:: Kommando nicht gefunden.
      pi@raspberrypi:~ $   Candidate: 18.19.0-1nodesource1
      -bash: Candidate:: Kommando nicht gefunden.
      pi@raspberrypi:~ $   Version table:
      -bash: Version: Kommando nicht gefunden.
      pi@raspberrypi:~ $  *** 18.19.0-1nodesource1 1001
      pi@raspberrypi:~ $         500 https://deb.nodesource.com/node_18.x nodistro/main arm64 Packages
      -bash: 500: Kommando nicht gefunden.
      pi@raspberrypi:~ $         100 /var/lib/dpkg/status
      -bash: 100: Kommando nicht gefunden.
      pi@raspberrypi:~ $      18.18.2-1nodesource1 1001
      -bash: 18.18.2-1nodesource1: Kommando nicht gefunden.
      pi@raspberrypi:~ $      18.18.1-1nodesource1 1001
      -bash: 18.18.1-1nodesource1: Kommando nicht gefunden.
      pi@raspberrypi:~ $      18.18.0-1nodesource1 1001
      -bash: 18.18.0-1nodesource1: Kommando nicht gefunden.
      pi@raspberrypi:~ $      18.17.1-1nodesource1 1001
      -bash: 18.17.1-1nodesource1: Kommando nicht gefunden.
      pi@raspberrypi:~ $      18.17.0-1nodesource1 1001
      -bash: 18.17.0-1nodesource1: Kommando nicht gefunden.
      pi@raspberrypi:~ $      18.16.1-1nodesource1 1001
      -bash: 18.16.1-1nodesource1: Kommando nicht gefunden.
      pi@raspberrypi:~ $      18.16.0-1nodesource1 1001
      -bash: 18.16.0-1nodesource1: Kommando nicht gefunden.
      pi@raspberrypi:~ $      18.15.0-1nodesource1 1001
      -bash: 18.15.0-1nodesource1: Kommando nicht gefunden.
      pi@raspberrypi:~ $      18.14.2-1nodesource1 1001
      -bash: 18.14.2-1nodesource1: Kommando nicht gefunden.
      pi@raspberrypi:~ $      18.14.1-1nodesource1 1001
      -bash: 18.14.1-1nodesource1: Kommando nicht gefunden.
      pi@raspberrypi:~ $      18.14.0-1nodesource1 1001
      -bash: 18.14.0-1nodesource1: Kommando nicht gefunden.
      pi@raspberrypi:~ $      18.13.0-1nodesource1 1001
      -bash: 18.13.0-1nodesource1: Kommando nicht gefunden.
      pi@raspberrypi:~ $      18.12.0-1nodesource1 1001
      -bash: 18.12.0-1nodesource1: Kommando nicht gefunden.
      pi@raspberrypi:~ $      18.11.0-1nodesource1 1001
      -bash: 18.11.0-1nodesource1: Kommando nicht gefunden.
      pi@raspberrypi:~ $      18.10.0-1nodesource1 1001
      -bash: 18.10.0-1nodesource1: Kommando nicht gefunden.
      pi@raspberrypi:~ $      18.9.1-1nodesource1 1001
      -bash: 18.9.1-1nodesource1: Kommando nicht gefunden.
      pi@raspberrypi:~ $      18.9.0-1nodesource1 1001
      -bash: 18.9.0-1nodesource1: Kommando nicht gefunden.
      pi@raspberrypi:~ $      18.8.0-1nodesource1 1001
      -bash: 18.8.0-1nodesource1: Kommando nicht gefunden.
      pi@raspberrypi:~ $      18.7.0-1nodesource1 1001
      -bash: 18.7.0-1nodesource1: Kommando nicht gefunden.
      pi@raspberrypi:~ $      18.6.0-1nodesource1 1001
      -bash: 18.6.0-1nodesource1: Kommando nicht gefunden.
      pi@raspberrypi:~ $      18.5.0-1nodesource1 1001
      -bash: 18.5.0-1nodesource1: Kommando nicht gefunden.
      pi@raspberrypi:~ $      18.4.0-1nodesource1 1001
      -bash: 18.4.0-1nodesource1: Kommando nicht gefunden.
      pi@raspberrypi:~ $      18.3.0-1nodesource1 1001
      -bash: 18.3.0-1nodesource1: Kommando nicht gefunden.
      pi@raspberrypi:~ $      18.2.0-1nodesource1 1001
      -bash: 18.2.0-1nodesource1: Kommando nicht gefunden.
      pi@raspberrypi:~ $      18.1.0-1nodesource1 1001
      -bash: 18.1.0-1nodesource1: Kommando nicht gefunden.
      pi@raspberrypi:~ $      18.0.0-1nodesource1 1001
      -bash: 18.0.0-1nodesource1: Kommando nicht gefunden.
      pi@raspberrypi:~ $      12.22.12~dfsg-1~deb11u4 500
      -bash: 12.22.12~dfsg-1~deb11u4: Kommando nicht gefunden.
      pi@raspberrypi:~ $         500 http://deb.debian.org/debian bullseye/main arm64 Packages
      pi@raspberrypi:~ $         500 http://security.debian.org/debian-security bullseye-security/main ar        m64 Packages
      pi@raspberrypi:~ $
      pi@raspberrypi:~ $ Temp directories causing npm8 problem: 0
      -bash: Temp: Kommando nicht gefunden.
      pi@raspberrypi:~ $ No problems detected
      -bash: No: Kommando nicht gefunden.
      pi@raspberrypi:~ $
      pi@raspberrypi:~ $ Errors in npm tree:
      -bash: Errors: Kommando nicht gefunden.
      pi@raspberrypi:~ $
      pi@raspberrypi:~ $ *** ioBroker-Installation ***
      pi@raspberrypi:~ $
      pi@raspberrypi:~ $ ioBroker Status
      -bash: ioBroker: Kommando nicht gefunden.
      pi@raspberrypi:~ $ iobroker is running on this host.
      iobroker [command]
      Commands:
        iobroker setup                                               Setup ioBroker
        iobroker start [all|<adapter>.<instance>|<adapter>]          Starts the js-controller or a specified adapter instance or all instances of an adapter
        iobroker stop [<adapter>.<instance>|<adapter>]               stops the js-controller or a specified adapter instance or all instances of an adapter
        iobroker restart [<adapter>.<instance>|<adapter>]            Restarts js-controller or a specified adapter instance or all instances of an adapter  [aliases: r]
        iobroker debug <adapter>[.<instance>]                        Starts a Node.js debugging session for the adapter instance
        iobroker info                                                Shows the host info
        iobroker logs [<adapter>]                                    Monitor log
        iobroker add <adapter> [desiredNumber]                       Add instance of adapter  [aliases: a]
        iobroker install <adapter>                                   Installs a specified adapter  [aliases: i]
        iobroker rebuild [<module>]                                  Rebuild all native modules or path
        iobroker url <url> [<name>]                                  Install adapter from specified url, e.g. GitHub
        iobroker del <adapter>                                       Remove adapter and all instances from this host  [aliases: delete]
        iobroker del <adapter>.<instance>                            Remove adapter instance  [aliases: delete]
        iobroker update [<repositoryUrl>]                            Update repository and list adapters
        iobroker upgrade                                             Upgrade management
        iobroker upload [all|<adapter>]                              Upload management  [aliases: u]
        iobroker object                                              Object management  [aliases: o]
        iobroker state                                               State management  [aliases: s]
        iobroker message <adapter>[.instance] <command> [<message>]  Send message to adapter instance/s
        iobroker list <type> [<filter>]                              List all entries, like objects
        iobroker chmod <mode> <file>                                 Change file rights
        iobroker chown <user> <group> <file>                         Change file ownership
        iobroker touch <file>                                        Touch file
        iobroker rm <file>                                           Remove file
        iobroker file                                                File management
        iobroker user                                                User commands
        iobroker group                                               group management
        iobroker host <hostname>                                     Set host to given hostname
        iobroker set <adapter>.<instance>                            Change settings of adapter config
        iobroker license <license.file or license.text>              Update license by given file
        iobroker cert                                                Certificate management
        iobroker clean <yes>                                         Clears all objects and states
        iobroker backup                                              Create backup
        iobroker restore <backup name or path>                       Restore a specified backup
        iobroker validate <backup name or path>                      Validate a specified backup
        iobroker status [all|<adapter>.<instance>]                   Status of ioBroker or adapter instance  [aliases: isrun]
        iobroker repo [<name>]                                       Show repo information
        iobroker uuid                                                Show uuid of the installation  [aliases: id]
        iobroker unsetup                                             Reset license, installation secret and language
        iobroker fix                                                 Execute the installation fixer script, this updates your ioBroker installation
        iobroker nodejs-update [<major-version>]                     Upgrade the Node.JS installation to the current LTS
        iobroker multihost                                           Multihost management
        iobroker compact                                             compact group management
        iobroker plugin                                              Plugin management
        iobroker vendor <passphrase> [<vendor.json>]                 Update the vendor information using given passphrase
        iobroker version [<adapter>]                                 Show version of js-controller or specified adapter  [aliases: v]
      Options:
        --help  Show help  [boolean]
      pi@raspberrypi:~ $
       pi@raspberrypi:~ $
       pi@raspberrypi:~ $ Objects type: jsonl
      -bash: Objects: Kommando nicht gefunden.
      pi@raspberrypi:~ $ States  type: jsonl
      -bash: States: Kommando nicht gefunden.
      pi@raspberrypi:~ $
      pi@raspberrypi:~ $ Core adapters versions
      -bash: Core: Kommando nicht gefunden.
      pi@raspberrypi:~ $ js-controller:  5.0.17
      -bash: js-controller:: Kommando nicht gefunden.
      pi@raspberrypi:~ $ admin:          6.12.0
      -bash: admin:: Kommando nicht gefunden.
      pi@raspberrypi:~ $ javascript:     7.1.6
      -bash: javascript:: Kommando nicht gefunden.
      pi@raspberrypi:~ $
       pi@raspberrypi:~ $ Adapters from github:   0
      -bash: Adapters: Kommando nicht gefunden.
      pi@raspberrypi:~ $
       pi@raspberrypi:~ $ Adapter State
      -bash: Adapter: Kommando nicht gefunden.
      pi@raspberrypi:~ $ + system.adapter.admin.0                  : admin                 : raspberrypi        -  enabled, port: 8081, bind: 0.0.0.0, run as: admi        n
      -bash: +: Kommando nicht gefunden.
      pi@raspberrypi:~ $ + system.adapter.alexa2.0                 : alexa2                : raspberrypi        -  enabled
      pi@raspberrypi:~ $   system.adapter.alias-manager.0          : alias-manager         : raspberrypi        - disabled
      -bash: system.adapter.alias-manager.0: Kommando nicht gefunden.
      pi@raspberrypi:~ $ + system.adapter.awtrix-light.0           : awtrix-light          : raspberrypi        -  enabled
      pi@raspberrypi:~ $ + system.adapter.backitup.0               : backitup              : raspberrypi        -  enabled
      pi@raspberrypi:~ $ + system.adapter.broadlink2.0             : broadlink2            : raspberrypi        -  enabled
      pi@raspberrypi:~ $   system.adapter.devices.0                : devices               : raspberrypi        - disabled
      -bash: system.adapter.devices.0: Kommando nicht gefunden.
      pi@raspberrypi:~ $ + system.adapter.discovery.0              : discovery             : raspberrypi        -  enabled
      pi@raspberrypi:~ $   system.adapter.doorbird.0               : doorbird              : raspberrypi        - disabled
      -bash: system.adapter.doorbird.0: Kommando nicht gefunden.
      pi@raspberrypi:~ $ + system.adapter.echarts.0                : echarts               : raspberrypi        -  enabled
      pi@raspberrypi:~ $ + system.adapter.hm-rega.0                : hm-rega               : raspberrypi        -  enabled
      pi@raspberrypi:~ $ + system.adapter.hm-rpc.0                 : hm-rpc                : raspberrypi        -  enabled, port: 0
      pi@raspberrypi:~ $ + system.adapter.hm-rpc.1                 : hm-rpc                : raspberrypi        -  enabled, port: 0
      pi@raspberrypi:~ $   system.adapter.hue.0                    : hue                   : raspberrypi        - disabled, port: 443
      -bash: system.adapter.hue.0: Kommando nicht gefunden.
      pi@raspberrypi:~ $ + system.adapter.influxdb.0               : influxdb              : raspberrypi        -  enabled, port: 8086
      pi@raspberrypi:~ $ + system.adapter.info.0                   : info                  : raspberrypi        -  enabled
      pi@raspberrypi:~ $ + system.adapter.iot.0                    : iot                   : raspberrypi        -  enabled
      pi@raspberrypi:~ $ + system.adapter.javascript.0             : javascript            : raspberrypi        -  enabled
      pi@raspberrypi:~ $ + system.adapter.rpi2.0                   : rpi2                  : raspberrypi        -  enabled
      pi@raspberrypi:~ $ + system.adapter.shelly.0                 : shelly                : raspberrypi        -  enabled, port: 1882, bind: 0.0.0.0
      pi@raspberrypi:~ $ + system.adapter.simple-api.0             : simple-api            : raspberrypi        -  enabled, port: 8087, bind: 0.0.0.0, run as: admi        n
      pi@raspberrypi:~ $   system.adapter.smartmeter.0             : smartmeter            : raspberrypi        - disabled
      -bash: system.adapter.smartmeter.0: Kommando nicht gefunden.
      pi@raspberrypi:~ $ + system.adapter.statistics.0             : statistics            : raspberrypi        -  enabled
      pi@raspberrypi:~ $ + system.adapter.tankerkoenig.0           : tankerkoenig          : raspberrypi        -  enabled
      pi@raspberrypi:~ $ + system.adapter.telegram.0               : telegram              : raspberrypi        -  enabled, port: 8443, bind: 0.0.0.0
      pi@raspberrypi:~ $ + system.adapter.text2command.0           : text2command          : raspberrypi        -  enabled
      pi@raspberrypi:~ $   system.adapter.vis.0                    : vis                   : raspberrypi        -  enabled
      -bash: system.adapter.vis.0: Kommando nicht gefunden.
      pi@raspberrypi:~ $ + system.adapter.web.0                    : web                   : raspberrypi        -  enabled, port: 8082, bind: 0.0.0.0, run as: admi        n
      pi@raspberrypi:~ $   system.adapter.yr.0                     : yr                    : raspberrypi        -  enabled
      -bash: system.adapter.yr.0: Kommando nicht gefunden.
      pi@raspberrypi:~ $
      pi@raspberrypi:~ $ + instance is alive
       instal-bash: +: Kommando nicht gefunden.
      pi@raspberrypi:~ $
      pi@raspberrypi:~ $ Enabled adapters with bindings
      -bash: Enabled: Kommando nicht gefunden.
      pi@raspberrypi:~ $
      pi@raspberrypi:~ $ ioBroker-Repositories
      -bash: ioBroker-Repositories: Kommando nicht gefunden.
      pi@raspberrypi:~ $ stable        : http://download.iobroker.net/sources-dist.json
      -bash: stable: Kommando nicht gefunden.
      pi@raspberrypi:~ $ beta          : http://download.iobroker.net/sources-dist-latest.json
      -bash: beta: Kommando nicht gefunden.
      pi@raspberrypi:~ $
      pi@raspberrypi:~ $ Active repo(s): stable
      -bash: Syntaxfehler beim unerwarteten Symbol »(«
      pi@raspberrypi:~ $
      pi@raspberrypi:~ $ Installed ioBroker-Instances
      -bash: Installed: Kommando nicht gefunden.
      pi@raspberrypi:~ $ Used repository: stable
      -bash: Used: Kommando nicht gefunden.
      pi@raspberrypi:~ $ Adapter    "admin"        : 6.12.0   , installed 6.12.0
      pi@raspberrypi:~ $ Adapter    "alexa2"       : 3.26.3   , installed 3.26.3
      pi@raspberrypi:~ $ Adapter    "alias-manager": 1.2.6    , installed 1.2.6
      pi@raspberrypi:~ $ Adapter    "awtrix-light" : 0.10.0   , installed 0.10.0
      pi@raspberrypi:~ $ Adapter    "backitup"     : 2.9.8    , installed 2.9.8
      pi@raspberrypi:~ $ Adapter    "broadlink2"   : 2.1.5    , installed 2.1.5
      pi@raspberrypi:~ $ Adapter    "devices"      : 1.1.5    , installed 1.1.5
      pi@raspberrypi:~ $ Adapter    "discovery"    : 4.2.0    , installed 4.2.0
      pi@raspberrypi:~ $ Adapter    "doorbird"     : 1.3.0    , installed 1.3.0
      pi@raspberrypi:~ $ Adapter    "echarts"      : 1.5.4    , installed 1.7.1
      pi@raspberrypi:~ $ Adapter    "hm-rega"      : 4.0.0    , installed 4.0.0
      pi@raspberrypi:~ $ Adapter    "hm-rpc"       : 1.15.19  , installed 1.15.19
      pi@raspberrypi:~ $ Adapter    "hue"          : 3.10.1   , installed 3.10.1
      pi@raspberrypi:~ $ Adapter    "influxdb"     : 3.2.0    , installed 3.2.0
      pi@raspberrypi:~ $ Adapter    "info"         : 2.0.0    , installed 2.0.0
      pi@raspberrypi:~ $ Adapter    "iot"          : 2.0.11   , installed 2.0.11
      pi@raspberrypi:~ $ Adapter    "iqontrol"     : 2.3.0    , installed 2.3.0
      pi@raspberrypi:~ $ Adapter    "javascript"   : 7.1.6    , installed 7.1.6
      pi@raspberrypi:~ $ Controller "js-controller": 5.0.17   , installed 5.0.17
      -bash: Controller: Kommando nicht gefunden.
      pi@raspberrypi:~ $ Adapter    "rpi2"         : 1.3.2    , installed 1.3.2
      pi@raspberrypi:~ $ Adapter    "shelly"       : 6.6.1    , installed 6.6.1
      pi@raspberrypi:~ $ Adapter    "simple-api"   : 2.7.2    , installed 2.7.2
      pi@raspberrypi:~ $ Adapter    "smartmeter"   : 3.4.0    , installed 3.4.0
      pi@raspberrypi:~ $ Adapter    "socketio"     : 6.6.0    , installed 6.6.0
      pi@raspberrypi:~ $ Adapter    "statistics"   : 2.4.0    , installed 2.4.0
      pi@raspberrypi:~ $ Adapter    "tankerkoenig" : 3.3.7    , installed 3.3.7
      pi@raspberrypi:~ $ Adapter    "telegram"     : 3.0.1    , installed 3.0.1
      pi@raspberrypi:~ $ Adapter    "text2command" : 3.0.2    , installed 3.0.2
      pi@raspberrypi:~ $ Adapter    "viessmann"    : 1.4.6    , installed 1.4.6
      pi@raspberrypi:~ $ Adapter    "viessmannapi" : 2.3.0    , installed 2.3.0
      pi@raspberrypi:~ $ Adapter    "vis"          : 1.5.4    , installed 1.5.4
      pi@raspberrypi:~ $ Adapter    "web"          : 6.1.10   , installed 6.1.10
      pi@raspberrypi:~ $ Adapter    "ws"           : 2.5.8    , installed 2.5.8
      pi@raspberrypi:~ $ Adapter    "yr"           : 5.3.0    , installed 5.3.0
      pi@raspberrypi:~ $
      pi@raspberrypi:~ $ Objects and States
      pi@raspberrypi:~ $ Please stand by - This may take a while
      -bash: Please: Kommando nicht gefunden.
      pi@raspberrypi:~ $ Objects:        10746
      -bash: Objects:: Kommando nicht gefunden.
      pi@raspberrypi:~ $ States:         8973
      -bash: States:: Kommando nicht gefunden.
      pi@raspberrypi:~ $
      pi@raspberrypi:~ $ *** OS-Repositories and Updates ***
      pi@raspberrypi:~ $ Hit:1 http://archive.raspberrypi.org/debian bullseye InRelease
      -bash: Hit:1: Kommando nicht gefunden.
      pi@raspberrypi:~ $ Hit:2 http://deb.debian.org/debian bullseye InRelease
      -bash: Hit:2: Kommando nicht gefunden.
      pi@raspberrypi:~ $ Hit:3 http://deb.debian.org/debian bullseye-updates InRelease
      -bash: Hit:3: Kommando nicht gefunden.
      pi@raspberrypi:~ $ Hit:4 http://security.debian.org/debian-security bullseye-security InRelease
      -bash: Hit:4: Kommando nicht gefunden.
      pi@raspberrypi:~ $ Hit:5 https://repos.influxdata.com/debian bullseye InRelease
      -bash: Hit:5: Kommando nicht gefunden.
      pi@raspberrypi:~ $ Hit:6 https://deb.nodesource.com/node_18.x nodistro InRelease
      -bash: Hit:6: Kommando nicht gefunden.
      pi@raspberrypi:~ $ Reading package lists...
      -bash: Reading: Kommando nicht gefunden.
      pi@raspberrypi:~ $ Pending Updates: 0
      -bash: Pending: Kommando nicht gefunden.
      pi@raspberrypi:~ $
      pi@raspberrypi:~ $ *** Listening Ports ***
      pi@raspberrypi:~ $ Active Internet connections (only servers)
      pi@raspberrypi:~ $ Proto Recv-Q Send-Q Local Address           Foreign Address         State       User       Inode      PID/Program name
      -bash: Proto: Kommando nicht gefunden.
      pi@raspberrypi:~ $ tcp        0      0 127.0.0.1:9001          0.0.0.0:*               LISTEN      1001       12196      615/iobroker.js-con
      -bash: tcp: Kommando nicht gefunden.
      pi@raspberrypi:~ $ tcp        0      0 127.0.0.1:9000          0.0.0.0:*               LISTEN      1001       3635       615/iobroker.js-con
      pi@raspberrypi:~ $ tcp        0      0 192.168.178.74:2001     0.0.0.0:*               LISTEN      1001       3803       845/io.hm-rpc.1
      pi@raspberrypi:~ $ tcp        0      0 192.168.178.74:2010     0.0.0.0:*               LISTEN      1001       3784       828/io.hm-rpc.0
      pi@raspberrypi:~ $ tcp        0      0 0.0.0.0:22              0.0.0.0:*               LISTEN      0          12067      569/sshd: /usr/sbin
      pi@raspberrypi:~ $ tcp        0      0 0.0.0.0:1883            0.0.0.0:*               LISTEN      110        14773      540/mosquitto
      pi@raspberrypi:~ $ tcp        0      0 0.0.0.0:1882            0.0.0.0:*               LISTEN      1001       15197      897/io.shelly.0
      pi@raspberrypi:~ $ tcp6       0      0 :::8081                 :::*                    LISTEN      1001       14923      725/io.admin.0
      -bash: tcp6: Kommando nicht gefunden.
      pi@raspberrypi:~ $ tcp6       0      0 :::8082                 :::*                    LISTEN      1001       19733      1693/io.web.0
      pi@raspberrypi:~ $ tcp6       0      0 :::8087                 :::*                    LISTEN      1001       17540      1190/io.simple-api.
      pi@raspberrypi:~ $ tcp6       0      0 :::8086                 :::*                    LISTEN      999        14801      453/influxd
      pi@raspberrypi:~ $ tcp6       0      0 :::22                   :::*                    LISTEN      0          12069      569/sshd: /usr/sbin
      pi@raspberrypi:~ $ tcp6       0      0 :::1883                 :::*                    LISTEN      110        14774      540/mosquitto
      pi@raspberrypi:~ $ udp        0      0 0.0.0.0:15001           0.0.0.0:*                           1001       16701      995/io.broadlink2.0
      -bash: udp: Kommando nicht gefunden.
      pi@raspberrypi:~ $ udp        0      0 0.0.0.0:68              0.0.0.0:*                           0          12155      717/dhcpcd
      pi@raspberrypi:~ $ udp        0      0 0.0.0.0:5353            0.0.0.0:*                           108        14683      399/avahi-daemon: r
      pi@raspberrypi:~ $ udp        0      0 0.0.0.0:46709           0.0.0.0:*                           108        14685      399/avahi-daemon: r
      pi@raspberrypi:~ $ udp        0      0 0.0.0.0:54904           0.0.0.0:*                           1001       15853      995/io.broadlink2.0
      pi@raspberrypi:~ $ udp6       0      0 :::49235                :::*                                108        14686      399/avahi-daemon: r
      -bash: udp6: Kommando nicht gefunden.
      pi@raspberrypi:~ $ udp6       0      0 :::5353                 :::*                                108        14684      399/avahi-daemon: r
      pi@raspberrypi:~ $
      pi@raspberrypi:~ $ *** Log File - Last 25 Lines ***
      pi@raspberrypi:~ $
      pi@raspberrypi:~ $ 2023-12-29 16:50:30.228  - info: host.raspberrypi Updating repository "stable" under "http://download.iobroker.net/sources-dist.json"
      -bash: 2023-12-29: Kommando nicht gefunden.
      pi@raspberrypi:~ $ 2023-12-29 16:54:40.802  - info: admin.0 (725) <== Disconnect system.user.admin from ::ffff:192.168.178.24
      pi@raspberrypi:~ $ 2023-12-29 16:55:00.042  - info: host.raspberrypi instance system.adapter.yr.0 started with pid 7607
      pi@raspberrypi:~ $ 2023-12-29 16:55:33.485  - info: host.raspberrypi instance system.adapter.yr.0 terminated with code 11 (ADAPTER_REQUESTED_TERMINATION)
      pi@raspberrypi:~ $ 2023-12-29 17:00:00.047  - info: host.raspberrypi instance system.adapter.yr.0 started with pid 7817
      pi@raspberrypi:~ $ 2023-12-29 17:00:00.066  - info: javascript.0 (764) script.js.downloads.Shelly-Verbrauch: Shelly Verbrauch: Verbrauchswerte aktualisiert: 1 | Reboots korrigiert: 0 | Unveränderte Werte: 12
      pi@raspberrypi:~ $ 2023-12-29 17:00:00.154  - warn: javascript.0 (764) getState "smartmeter.0.1-0:1_8_0__255.value" not found (3)
      pi@raspberrypi:~ $ 2023-12-29 17:00:00.157  - warn: javascript.0 (764)     at haupt (script.js.Strom.Strombezug:32:20)
      pi@raspberrypi:~ $ 2023-12-29 17:00:00.157  - warn: javascript.0 (764)     at Object.<anonymous> (script.js.Strom.Strombezug:44:5)
      pi@raspberrypi:~ $ 2023-12-29 17:00:00.158  - warn: javascript.0 (764)     at Job.job (/opt/iobroker/node_modules/iobroker.javascript/lib/sandbox.js:1617:34)
      pi@raspberrypi:~ $ 2023-12-29 17:00:00.158  - warn: javascript.0 (764)     at Job.invoke (/opt/iobroker/node_modules/node-schedule/lib/Job.js:171:15)
      pi@raspberrypi:~ $ 2023-12-29 17:00:00.158  - warn: javascript.0 (764)     at /opt/iobroker/node_modules/node-schedule/lib/Invocation.js:268:28
      pi@raspberrypi:~ $ 2023-12-29 17:00:00.158  - warn: javascript.0 (764)     at Timeout._onTimeout (/opt/iobroker/node_modules/node-schedule/lib/Invocation.js:228:7)
      pi@raspberrypi:~ $ 2023-12-29 17:00:00.159  - warn: javascript.0 (764)     at listOnTimeout (node:internal/timers:569:17)
      pi@raspberrypi:~ $ 2023-12-29 17:00:00.159  - warn: javascript.0 (764)     at processTimers (node:internal/timers:512:7)
      pi@raspberrypi:~ $ 2023-12-29 17:00:00.222  - warn: javascript.0 (764) getState "smartmeter.0.1-0:2_8_0__255.value" not found (3)
      pi@raspberrypi:~ $ 2023-12-29 17:00:00.224  - warn: javascript.0 (764)     at haupt (script.js.Strom.Stromeinspeisung:32:20)
      pi@raspberrypi:~ $ 2023-12-29 17:00:00.224  - warn: javascript.0 (764)     at Object.<anonymous> (script.js.Strom.Stromeinspeisung:44:5)
      pi@raspberrypi:~ $ 2023-12-29 17:00:00.224  - warn: javascript.0 (764)     at Job.job (/opt/iobroker/node_modules/iobroker.javascript/lib/sandbox.js:1617:34)
      pi@raspberrypi:~ $ 2023-12-29 17:00:00.225  - warn: javascript.0 (764)     at Job.invoke (/opt/iobroker/node_modules/node-schedule/lib/Job.js:171:15)
      pi@raspberrypi:~ $ 2023-12-29 17:00:00.225  - warn: javascript.0 (764)     at /opt/iobroker/node_modules/node-schedule/lib/Invocation.js:268:28
      pi@raspberrypi:~ $ 2023-12-29 17:00:00.226  - warn: javascript.0 (764)     at Timeout._onTimeout (/opt/iobroker/node_modules/node-schedule/lib/Invocation.js:228:7)
      pi@raspberrypi:~ $ 2023-12-29 17:00:00.226  - warn: javascript.0 (764)     at listOnTimeout (node:internal/timers:569:17)
      pi@raspberrypi:~ $ 2023-12-29 17:00:00.226  - warn: javascript.0 (764)     at processTimers (node:internal/timers:512:7)
      pi@raspberrypi:~ $ 2023-12-29 17:00:29.701  - info: host.raspberrypi instance system.adapter.yr.0 terminated with code 11 (ADAPTER_REQUESTED_TERMINATION)
      pi@raspberrypi:~ $
      > ============ Mark until here for C&P =============
      @searcher57 sagte in Serieller Port defekt:
      möglich dass du da den udev bug hast
      Was ist das denn für ein Zähler?
      es gibt welche, bei denen die Dioden sterben.
      hattest du ggf. einen kurzen Stromausfall und der Zähler ist zurückgesetzt.
      oder, od
      oder, oder, oder....
      Ich habe einen elektronischen 2 Richtungszähler von ISKRA und den optischen Lesekopf mit Magnet aufgesetzt. Da ich aber seit langer Zeit mit der Erfasssung des Gasverbrauchs (über Reed Kontakt) experimentiere weil die Werte nicht übereinstimmen, kann es sein dass ich da am GPIO einen Kurzschluss fabriziert habe!😞 😕
        Homoran Global Moderator Administrators @searcher57 last edited by
        hast du mal mit einem Handy ohne IR Sperrfilter auf die Schnittstelle geschaut?
          Ja, das funktioniert!
            mh, wenn das Signal nicht zu schwach ist (ich glaube Iskra kam da auch mal vor) könntest du mit deinem Bratversuch recht haben
            S 3 Replies Last reply Reply Quote 0
              Bratversuch??
              Die Frage, nützt es was wenn ich mir den USB Adapter kaufe?
                Ich habe mir nämlich erst vor einem halben Jahr einen neuen Raspi 8GB gekauft, weil der 2GB an seine Grenze gekommen war.
                  searcher57 @searcher57 last edited by
                  @searcher57 said in Serieller Port defekt:
                  Da ich aber beide nutze, könnte ich evtl. den kleinen dafür nutzen!
                    zumindest zum testen
                      Ok, ist zwar mit einigem Aufwand verbunden, aber ein Rentner hat ja sonst nichts zu tun!😁 😁 !
                      Ich melde mich später.
                      • MartinP
                        MartinP @searcher57 last edited by
                        @searcher57 Okay, also ein Raspberry Pi und die serielle Schnittstelle über die GPIO-Leiste ...
                        Gibt es denn Aktionen, an die Du Dich erinnerst, die zum Schrotten der GPIO-Pins geführt haben könnten? Der berühmte abgerutschte Schraubendreher?
                        Bei einer durch einer Anwendung blockierten seriellen Schnittstelle sollte minicom eigentlich "das Gerät >>dev/....<< ist gesperrt" zurückmelden ... das fällt also als Ursache aus.
                        Hast Du für den Test Rx mit Tx gebrückt?
                          searcher57 @MartinP last edited by
                          @martinp said in Serieller Port defekt:
                          Frage 1 : Nein
                          Frage 2: Ja über einen 4,7k Ohm Widerstand
                          • MartinP
                            @searcher57 Hmm, es gibt widersprüchliche Informationen zum internen Pullups im Raspberry Pi SOC, die sich beim Booten plötzlich wieder aktivieren, trotzdem eigentlich wegkonfiguriert z. B. hier hat es da schon einmal Probleme gegeben...
                            https://stackoverflow.com/questions/45061820/what-enables-the-raspberry-pi-gpio15rxd0-pull-up-resistor-during-boot
                            eine 4,7 kOhm "Verbindung" zwischen Rx und Tx wird relativ leicht überstimmt ....
                            Ich würde das Experiment mit einer direkten Brücke, oder zumindest einem Widerstand von um die 220 Ohm wiederholen...
                              Entschuldigung, ich war essen. Also, Du hast recht mit einem 150 Ohm Widerstand funzt der kleine!👍 👍 Ich melde mich, wenn ich mit dem 8 GB Erfolg habe.
                                Also, ich verzweifle im Moment. Auf dem 2GB hat der Test bestanden. Aber ich kann den Test weder auf dem 8GB noch auf dem 2GB wiederholen.
                                  So, nachdem ich bei beiden den Test wenigstens einmal erfolgreich durchführen konnte, werde ich mir für nächstes Jahr einen neuen IR Lesekopf bestellen. Ich melde mich wieder, wenn ich Erfolg habe.
                                  Danke für Eure Mühe und guten Rutsch und weiterhin gute Ratschläge!! 🍷 🍷
                                  • MartinP
                                    @searcher57 die Beschriftung der Leitungen des lesekopfs können irritieren. Der Lesekopfs sendet auf dem mit RX beschrifteten Pin
                                      Frohes neues Jahr!
                                      So ich habe mittlerweile 2 neue IR Leseköpfe getestet und komme nicht weiter. Auch ein Tausch von RX und TX hat nicht geholfen. Die Instanz bekommt einfach keine Verbindung zu Gerät oder Dienst. Kannst Du mir mal die Einstellungen des Smartmeter Adapter geben? Hier nochmal das aktuelle iob diag.
                                      Skript v.2023-10-10
                                      *** BASE SYSTEM ***
                                               Icon name: computer
                                            Architecture: arm64
                                      Docker          : false
                                      Kernel          : aarch64
                                      Userland        : arm64
                                       14:52:55 up 2 days,  1:10,  1 user,  load average: 0.59, 0.90, 0.65
                                      CPU threads: 4
                                      Current issues:
                                                     Local time: Fri 2024-01-05 14:52:55 CET
                                                 Universal time: Fri 2024-01-05 13:52:55 UTC
                                                       RTC time: n/a
                                                    NTP service: active
                                                RTC in local TZ: no
                                      pi
                                      /home/pi
                                      X-Server:       false
                                      Desktop:
                                      Terminal:       tty
                                      *** MEMORY ***
                                      Mem:            7.8G        2.3G        4.5G        1.0M        1.0G        5.3G
                                      Swap:            99M          0B         99M
                                      Total:          7.9G        2.3G        4.6G
                                               7812 M total memory
                                               2342 M used memory
                                               2514 M active memory
                                                629 M inactive memory
                                               4450 M free memory
                                                125 M buffer memory
                                                893 M swap cache
                                                 99 M total swap
                                                  0 M used swap
                                                 99 M free swap
                                      Raspberry only:
                                      oom events: 0
                                      *** FILESYSTEM ***
                                      /dev/root      ext4       29G  7.7G   21G  28% /
                                      /dev/sda1      exfat      29G  112M   29G   1% /mnt/usb0
                                      [Wed Jan  3 13:42:01 2024] Kernel command line: coherent_pool=1M 8250.nr_uarts=1        snd_bcm2835.enable_headphones=0 snd_bcm2835.enable_headphones=1 snd_bcm2835.ena        ble_hdmi=1 snd_bcm2835.enable_hdmi=0  smsc95xx.macaddr=D8:3A:DD:43:B6:26 vc_mem.        mem_base=0x3ec00000 vc_mem.mem_size=0x40000000  console=tty1 console=ttyS0,11520        0 root=PARTUUID=f28374b8-02 rootfstype=ext4 fsck.repair=yes rootwait
                                      [Wed Jan  3 13:42:04 2024] EXT4-fs (mmcblk0p2): INFO: recovery required on reado        nly filesystem
                                      [Wed Jan  3 13:42:04 2024] EXT4-fs (mmcblk0p2): write access will be enabled dur        ing recovery
                                      [Wed Jan  3 13:42:05 2024] EXT4-fs (mmcblk0p2): orphan cleanup on readonly fs
                                      [Wed Jan  3 13:42:05 2024] EXT4-fs (mmcblk0p2): 5 orphan inodes deleted
                                      [Wed Jan  3 13:42:05 2024] EXT4-fs (mmcblk0p2): recovery complete
                                      [Wed Jan  3 13:42:05 2024] EXT4-fs (mmcblk0p2): mounted filesystem with ordered        data mode. Quota mode: none.
                                      [Wed Jan  3 13:42:05 2024] VFS: Mounted root (ext4 filesystem) readonly on devic        e 179:2.
                                      [Wed Jan  3 13:42:08 2024] EXT4-fs (mmcblk0p2): re-mounted. Quota mode: none.
                                      /var:
                                      2.8G    /var/
                                      2.2G    /var/log
                                      2.1G    /var/log/journal/d6ace433f2bf45719775348c9ccdd23f
                                      327M    /var/lib
                                      Archived and active journals take up 2.0G in the file system.
                                      553M    /opt/iobroker/iobroker-data/
                                      28M     /opt/iobroker/iobroker-data/objects.jsonl
                                      USB-Devices by-id:
                                      /usr/bin/npm            10.2.3
                                      /usr/bin/npx            10.2.3
                                      nodejs:
                                        Version table:
                                      Errors in npm tree:
                                      ioBroker Status
                                      Objects type: jsonl
                                      States  type: jsonl
                                      admin:          6.12.0
                                      javascript:     7.1.6
                                      Adapter State
                                      + system.adapter.smartmeter.0             : smartmeter            : raspberrypi        -  enabled
                                      + instance is alive
                                      Objects and States
                                      Objects:        10773
                                      States:         9009
                                      Hit:4 https://repos.influxdata.com/debian bullseye InRelease
                                      Hit:5 http://security.debian.org/debian-security bullseye-security InRelease
                                      Pending Updates: 2
                                      tcp        0      0 127.0.0.1:9000          0.0.0.0:*               LISTEN      1001       20010      1888/iobroker.js-co
                                      tcp        0      0 127.0.0.1:9001          0.0.0.0:*               LISTEN      1001       20003      1888/iobroker.js-co
                                      tcp        0      0 192.168.178.74:2010     0.0.0.0:*               LISTEN      1001       113614     10651/io.hm-rpc.0
                                      tcp        0      0 192.168.178.74:2001     0.0.0.0:*               LISTEN      1001       115460     10598/io.hm-rpc.1
                                      tcp        0      0 0.0.0.0:22              0.0.0.0:*               LISTEN      0          15491      569/sshd: /usr/sbin
                                      tcp        0      0 0.0.0.0:1882            0.0.0.0:*               LISTEN      1001       20423      2076/io.shelly.0
                                      tcp        0      0 0.0.0.0:1883            0.0.0.0:*               LISTEN      110        12758      544/mosquitto
                                      tcp6       0      0 :::22                   :::*                    LISTEN      0          15493      569/sshd: /usr/sbin
                                      tcp6       0      0 :::1883                 :::*                    LISTEN      110        12759      544/mosquitto
                                      tcp6       0      0 :::8082                 :::*                    LISTEN      1001       23889      2821/io.web.0
                                      tcp6       0      0 :::8081                 :::*                    LISTEN      1001       19294      1906/io.admin.0
                                      tcp6       0      0 :::8086                 :::*                    LISTEN      999        15510      446/influxd
                                      tcp6       0      0 :::8087                 :::*                    LISTEN      1001       21761      2279/io.simple-api.
                                      udp        0      0 0.0.0.0:36659           0.0.0.0:*                           108        12639      401/avahi-daemon: r
                                      udp        0      0 0.0.0.0:68              0.0.0.0:*                           0          15535      722/dhcpcd
                                      udp        0      0 0.0.0.0:41116           0.0.0.0:*                           1001       22628      2144/io.broadlink2.
                                      udp        0      0 0.0.0.0:5353            0.0.0.0:*                           108        12637      401/avahi-daemon: r
                                      udp        0      0 0.0.0.0:15001           0.0.0.0:*                           1001       21657      2144/io.broadlink2.
                                      udp6       0      0 :::49513                :::*                                108        12640      401/avahi-daemon: r
                                      udp6       0      0 :::5353                 :::*                                108        12638      401/avahi-daemon: r
                                      2024-01-05 14:31:24.808  - info: admin.0 (1906) <== Disconnect system.user.admin from ::ffff:192.168.178.24 admin
                                      2024-01-05 14:33:02.013  - info: smartmeter.0 (84304) Error: No or too long answer from Serial Device after last request.
                                      2024-01-05 14:33:02.015  - warn: smartmeter.0 (84304) No or too long answer from Serial Device after last request.
                                      2024-01-05 14:35:00.038  - info: host.raspberrypi instance system.adapter.yr.0 started with pid 84412
                                      2024-01-05 14:35:40.961  - info: host.raspberrypi instance system.adapter.yr.0 terminated with code 11 (ADAPTER_REQUESTED_TERMINATION)
                                      2024-01-05 14:36:02.020  - info: smartmeter.0 (84304) Error: No or too long answer from Serial Device after last request.
                                      2024-01-05 14:36:02.021  - warn: smartmeter.0 (84304) No or too long answer from Serial Device after last request.
                                      2024-01-05 14:38:37.448  - info: admin.0 (1906) ==> Connected system.user.admin from ::ffff:192.168.178.30
                                      2024-01-05 14:39:02.023  - info: smartmeter.0 (84304) Error: No or too long answer from Serial Device after last request.
                                      2024-01-05 14:39:02.024  - warn: smartmeter.0 (84304) No or too long answer from Serial Device after last request.
                                      2024-01-05 14:40:00.085  - info: host.raspberrypi instance system.adapter.yr.0 started with pid 84544
                                      2024-01-05 14:40:44.445  - info: host.raspberrypi instance system.adapter.yr.0 terminated with code 11 (ADAPTER_REQUESTED_TERMINATION)
                                      2024-01-05 14:42:02.029  - info: smartmeter.0 (84304) Error: No or too long answer from Serial Device after last request.
                                      2024-01-05 14:42:02.030  - warn: smartmeter.0 (84304) No or too long answer from Serial Device after last request.
                                      2024-01-05 14:45:00.044  - info: host.raspberrypi instance system.adapter.yr.0 started with pid 85986
                                      2024-01-05 14:45:00.053  - info: javascript.0 (1944) script.js.downloads.Shelly-Verbrauch: Shelly Verbrauch: Verbrauchswerte aktualisiert: 1 | Reboots korrigiert: 0 | Unveränderte Werte: 12
                                      2024-01-05 14:45:02.046  - info: smartmeter.0 (84304) Error: No or too long answer from Serial Device after last request.
                                      2024-01-05 14:45:02.047  - warn: smartmeter.0 (84304) No or too long answer from Serial Device after last request.
                                      2024-01-05 14:45:26.487  - info: host.raspberrypi instance system.adapter.yr.0 terminated with code 11 (ADAPTER_REQUESTED_TERMINATION)
                                      2024-01-05 14:48:02.050  - info: smartmeter.0 (84304) Error: No or too long answer from Serial Device after last request.
                                      2024-01-05 14:48:02.052  - warn: smartmeter.0 (84304) No or too long answer from Serial Device after last request.
                                      2024-01-05 14:50:00.054  - info: host.raspberrypi instance system.adapter.yr.0 started with pid 88585
                                      2024-01-05 14:50:38.191  - info: host.raspberrypi instance system.adapter.yr.0 terminated with code 11 (ADAPTER_REQUESTED_TERMINATION)
                                      2024-01-05 14:51:02.054  - info: smartmeter.0 (84304) Error: No or too long answer from Serial Device after last request.
                                      2024-01-05 14:51:02.057  - warn: smartmeter.0 (84304) No or too long answer from Serial Device after last request.
                                      MartinP Meister Mopper 2 Replies Last reply Reply Quote 0
                                      • MartinP
                                        MartinP @searcher57 last edited by MartinP
                                        @searcher57 Ich habe meinen seriellen TTL Lesekopf über tasmota auf einem NodeMCU augewertet.
                                        Hat auch etwas gedauert, den Kopf richtig zu justieren. Ich habe ein Taschen-Oszilloskop, was mir die Arbeit sehr erleichtert hat.
                                        Als ich da auf dem Draht am "Rx" Pad des Lesekopfes ein Signal "gesehen" habe, habe ich den Lesekopf sofort fixiert ...
                                        In irgendeinem Thread hier hatte ein User auch von einem Zählertyp berichtet, der bei Dunkelheit die Sendeleistung der IR-Sendediode reduzierte, was ihn fast zur Verzeweiflung brachte.
                                        ggfs. ganz einfach anfangen, und eine kleine LED mit Vorwiderstand an den Rx-Ausgang des Lesekopfes, wenn Du kein Taschen-Oszilloskop hast ...
                                        Die sollte dann ja bei richtiger Beschaltung flackern, wenn sie Telegramme empfängt ...
                                        Ich habe den Lesekopf in einem allerersten Schritt nicht im zugigen Keller am Zähler getestet, sondern vorher die IR-Fernbedienung vom Fernseher missbraucht .... das ließ sich besser am Basteltisch im Sitzen erledigen ...
                                          Ich habe den Lesekopf auf dieser Ebene nicht im zugigen Keller getestet, sondern vorher die IR-Fernbedienung vom Fernseher missbraucht .... das ließ sich besser am Basteltisch im Sitzen erledigen ...
                                          Ich habe jetzt einen Lesekopf, der besser aufgebaut ist. Er hat ein Gehäuse mit 2 Schrauben und sitzt passgenau. Wie gesagt der Test der seriellen Schnittstelle hat ja funktioniert. Die Diode am Zähler sendet auch.
                                            Sorry ich habe jetzt noch einen Termin. Den Test mit der LED mache ich heute Abend.
                                            362
                                            44459
