    3. Einsteigerfragen
    4. Von BETA zurück auf STABLE
    • sissiwup
      sissiwup @Thomas Braun last edited by
      live bringt im beta keine Timeouts. Probiere jetzt mal stable. Danke für den Tipp
      sissiwup 1 Reply Last reply Reply Quote 0
      • sissiwup
        sissiwup @sissiwup last edited by
        @sissiwup
        Sieht viel besser aus:
        iobroker stop && iobroker update && iobroker upgrade self && iobroker upgrade && iobroker start
        Used repository: live-stable
        Adapter    "admin"        : 5.3.1    , installed 5.3.1
        Adapter    "backitup"     : 2.3.3    , installed 2.3.5
        Adapter    "broadlink2"   : 2.1.5    , installed 2.1.5
        Adapter    "coronavirus-statistics": 0.8.7, installed 0.8.7
        Adapter    "devices"      : 1.0.9    , installed 1.0.10
        Adapter    "dwd"          : 2.7.7    , installed 2.7.7
        Adapter    "fritzbox"     : 0.2.1    , installed 0.2.1
        Adapter    "geofency"     : 1.0.3    , installed 1.1.0
        Adapter    "habpanel"     : 0.4.3    , installed 0.5.0
        Adapter    "hm-rega"      : 3.0.35   , installed 3.0.37
        Adapter    "hm-rpc"       : 1.15.0   , installed 1.15.8
        Adapter    "ical"         : 1.11.4   , installed 1.11.6
        Adapter    "icons-material-svg": 0.1.0, installed 0.1.0
        Adapter    "icons-mfd-png": 1.0.2    , installed 1.0.2
        Adapter    "icons-mfd-svg": 1.0.2    , installed 1.0.2
        Adapter    "icons-open-icon-library-png": 0.1.2, installed 0.1.3
        Adapter    "info"         : 1.9.8    , installed 1.9.19
        Adapter    "javascript"   : 5.2.21   , installed 5.3.3
        Controller "js-controller": 4.0.19   , installed 4.0.19
        Adapter    "mqtt"         : 2.4.1    , installed 2.7.3
        Adapter    "ping"         : 1.5.0    , installed 1.5.3
        Adapter    "pushover"     : 2.0.5    , installed 2.1.0
        Adapter    "scenes"       : 2.3.8    , installed 2.3.9
        Adapter    "simple-api"   : 2.6.2    , installed 2.6.3
        Adapter    "socketio"     : 3.1.5    , installed 4.1.4
        Adapter    "sonoff"       : 2.4.7    , installed 2.4.7
        Adapter    "sql"          : 1.16.1   , installed 1.16.2
        Adapter    "tankerkoenig" : 2.1.1    , installed 2.1.1
        Adapter    "telegram"     : 1.11.1   , installed 1.11.1
        Adapter    "trashschedule": 1.4.1    , installed 1.4.3
        Adapter    "vis"          : 1.4.5    , installed 1.4.12
        Adapter    "vis-canvas-gauges": 0.1.5, installed 0.1.5
        Adapter    "vis-colorpicker": 1.2.0  , installed 1.2.0
        Adapter    "vis-hqwidgets": 1.1.9    , installed 1.1.9
        Adapter    "vis-icontwo"  : 0.87.0   , installed 0.87.0
        Adapter    "vis-inventwo" : 3.2.8    , installed 3.3.1
        Adapter    "vis-justgage" : 1.0.2    , installed 1.0.2
        Adapter    "vis-lcars"    : 1.0.4    , installed 1.0.4
        Adapter    "vis-map"      : 1.0.4    , installed 1.0.4
        Adapter    "vis-material-advanced": 1.7.2, installed 1.7.2
        Adapter    "vis-metro"    : 1.1.2    , installed 1.2.0
        Adapter    "vis-timeandweather": 1.1.7, installed 1.1.7
        Adapter    "vis-weather"  : 2.5.5    , installed 2.5.5
        Adapter    "web"          : 3.4.16   , installed 4.2.0
        Adapter    "yahka"        : 0.13.1   , installed 0.13.1
        Host    "zotac"          is up to date.
        All adapters are up to date
        Jetzt muss ich nur noch die "zu neuen" zurück drehen ...
        Geht das auch per cmdline?
          Thomas Braun Most Active @sissiwup last edited by
          @sissiwup
          iobroker upgrade ADAPTERNAME@Versionsnummer
          Wenn es stabil mit den jetzigen Versionen funktioniert würde ich da aber gar nix fummeln. Die Versionen werden irgendwann von den stabilen Versionen überschrieben, wenn die Versionsnummer entsprechend die jetzige übersteigt.
          • sissiwup
            Hallo, du hast Recht. Ich schaue mir das erstmal so an. Danke.
              @sissiwup sagte in Von BETA zurück auf STABLE:
              Mit solchen Verkettungen würde ich nicht arbeiten:
              Besser einzeln eingeben. Dann kann man besser auf Rückmeldungen reagieren.
              • sissiwup
                @thomas-braun sagte in Von BETA zurück auf STABLE:
                Ich dachte durch die && hält er an, sobald es einen Fehler gibt.
                Mache ich eigentlich schon Jahrelang so. Bisher ohne Probleme ...
                  Das stimmt. Aber nicht jede ungewollte Folgeaktion wirft einen Fehler / Return Code <>0.
                    daruse @Thomas Braun last edited by
                    Hallo, das Thema ist zwar schon länger her, aber vllt könnt ihr mir auf die Sprünge helfen.
                    Ich hatte erst die VIS-2 beta installiert dann auf VIS-2 gewechselt. Aber irgendwie nicht über die Adapter, sprich ich kann aktuell nicht einfach auf die neueste Version mit update/upgrade hochziehen.
                    iobroker repo list:
                    Active repo(s): stable
                    iobroker update:
                    Used repository: stable
                    Adapter    "admin"        : 6.12.0   , installed 6.12.2
                    Adapter    "backitup"     : 2.9.8    , installed 2.9.8
                    Adapter    "evcc"         : 0.0.10   , installed 0.0.10
                    Adapter    "influxdb"     : 3.2.0    , installed 3.2.0
                    Adapter    "javascript"   : 7.1.6    , installed 7.1.6
                    Controller "js-controller": 5.0.17   , installed 5.0.17
                    Adapter    "modbus"       : 6.0.1    , installed 6.0.1
                    Adapter    "ocpp"         : 0.12.5   , installed 0.12.5
                    Adapter    "pushover"     : 3.0.6    , installed 3.0.6
                    Adapter    "shelly"       : 6.6.1    , installed 6.6.1
                    Adapter    "smartmeter"   : 3.4.0    , installed 3.4.0
                    Adapter    "web"          : 6.1.10   , installed 6.1.10
                    Adapter    "ws"           : 2.5.8    , installed 2.5.8
                    Könnt ihr mir Bitte sagen wie ich auf die "offizielle" stabile VIS-2 Version komme?
                    Danke und viele Grüße,
                    daruse
                      Thomas Braun Most Active @daruse last edited by
                      @daruse sagte in Von BETA zurück auf STABLE:
                      Es gibt keine. Nur eine Beta-Version, die über den Reiter npm oder über das Beta-Repo zu beziehen ist.
                        Homoran Global Moderator Administrators @daruse last edited by
                        Die gibt es nicht!
                        vis2 ist beta
                          Ok Danke das war mir so nicht bewusst.
                          Ich habe aktuell die Version 2.3.5 installiert und im Änderungsprotokoll hab ich bereits die 2.9.8 gesehen. Wie wäre der saubere Weg dies manuell zu updaten?
                            Über den Reiter 'npm'
                              Danke, hat geklappt.
                              Noch eine Frage zum Schluss, wenn VIS-2 stable werden sollte, gibt es dann eine Möglichkeit von beta auf stable zu switchen?
                                Wildbill @daruse last edited by
                                @daruse Sobald die stable-Version Deine installierte Version „einholt“ wirst Du automatisch über anstehende Updates installiert.
                                Gruss, Jürgen
                                  daruse @Wildbill last edited by
                                  @wildbill
                                  alles klar
                                  Danke euch!
                                  • Segway
                                    Segway @Thomas Braun last edited by
                                    Sauber ist es wie oben von mir gepostet.
                                    Mhhh, Stolper ich auch wieder über eine solche Konfiguration. Sieht bei mir auch wieder komplett anders. Hab ich wohl wieder was verpasst oder ist das richtig ?
                                    iob repo list
                                    Stable (default): http://download.iobroker.net/sources-dist.json
                                    Beta (latest) : http://download.iobroker.net/sources-dist-latest.json
                                    Active repo(s): Stable (default)
                                      Thomas Braun Most Active last edited by
                                      @segway
                                      Wenn es bei dir funktioniert ist das so in Ordnung.
                                      beta repository
                                      1550
