    4. vis 1 läuft nicht mehr
      Homoran Global Moderator Administrators @Max 0 last edited by
      @max-0 sagte in vis 1 läuft nicht mehr:
      Was meinst du mit iob diag?
      bitte diesen Befehl in der Konsole ausführen, und die Ausgabe posten
      Bin neu hier
      Na, dann hab ich hier was für dich zu lesen
      Max 0 2 Replies Last reply Reply Quote 0
      • Max 0
        Max 0 @Homoran last edited by Homoran
        @homoran Skript v.2023-10-10
        *** BASE SYSTEM ***
         Static hostname: raspberrypi5
               Icon name: computer
                  Kernel: Linux 6.1.0-rpi7-rpi-2712
            Architecture: arm64
        Model           : Raspberry Pi 5 Model B Rev 1.0
        Docker          : false
        Virtualization  : none
        Kernel          : aarch64
        Userland        : arm64
        Systemuptime and Load:
         20:46:18 up  1:07,  2 users,  load average: 0.72, 0.33, 0.17
        CPU threads: 4
        *** RASPBERRY THROTTLING ***
        Current issues:
        Previously detected issues:
        *** Time and Time Zones ***
                       Local time: Fri 2023-12-29 20:46:18 CET
                   Universal time: Fri 2023-12-29 19:46:18 UTC
                         RTC time: Fri 2023-12-29 19:46:18
                      NTP service: active
                  RTC in local TZ: no
        *** User and Groups ***
        pi
        /home/pi
        pi adm dialout cdrom sudo audio video plugdev games users input render netdev gpio i2c spi
        *** X-Server-Setup ***
        X-Server:       false
        Desktop:
        Terminal:       tty
        Boot Target:    multi-user.target
        *** MEMORY ***
        Mem:            8.4G        730M        5.3G        5.3M        2.5G        7.7G
        Swap:           104M          0B        104M
        Total:          8.5G        730M        5.4G
                 8053 M total memory
                  697 M used memory
                  655 M active memory
                 2052 M inactive memory
                 5037 M free memory
                  149 M buffer memory
                 2270 M swap cache
                   99 M total swap
                    0 M used swap
                   99 M free swap
        Raspberry only:
        vc_gencmd_read_response returned -1
        error=1 error_msg="Command not registered"
        *** FAILED SERVICES ***
        0 loaded units listed.
        *** FILESYSTEM ***
        udev           devtmpfs  3.8G     0  3.8G   0% /dev
        tmpfs          tmpfs     806M  5.0M  801M   1% /run
        /dev/mmcblk0p2 ext4       15G  2.8G   11G  21% /
        tmpfs          tmpfs     4.0G     0  4.0G   0% /dev/shm
        tmpfs          tmpfs     5.0M   48K  5.0M   1% /run/lock
        /dev/mmcblk0p1 vfat      510M   61M  450M  12% /boot/firmware
        tmpfs          tmpfs     806M     0  806M   0% /run/user/1000
        [Fri Dec 29 19:38:43 2023] Kernel command line: coherent_pool=1M 8250.nr_uarts=1 pci=pcie_bus_safe snd_bcm2835.enable_compat_alsa=0 snd_bcm2835.enable_hdmi=1  smsc95xx.macaddr=D8:3A:DD:BB:FC:13 vc_mem.mem_base=0x3fc00000 vc_mem.mem_size=0x40000000  console=ttyAMA10,115200 console=tty1 root=PARTUUID=0fd8a7d6-02 rootfstype=ext4 fsck.repair=yes rootwait
        [Fri Dec 29 19:38:46 2023] EXT4-fs (mmcblk0p2): mounted filesystem with ordered data mode. Quota mode: none.
        [Fri Dec 29 19:38:49 2023] EXT4-fs (mmcblk0p2): re-mounted. Quota mode: none.
        [Fri Dec 29 19:38:53 2023] EXT4-fs (mmcblk0p2): resizing filesystem from 536576 to 3768320 blocks
        [Fri Dec 29 19:38:56 2023] EXT4-fs (mmcblk0p2): resized filesystem to 3768320
        TARGET           SOURCE         FSTYPE OPTIONS
        /                /dev/mmcblk0p2 ext4   rw,noatime
        `-/boot/firmware /dev/mmcblk0p1 vfat   rw,relatime,fmask=0022,dmask=0022,codepage=437,iocharset=ascii,shortname=mixed,errors=remount-ro
        /var:
        496M    /var/
        206M    /var/cache
        200M    /var/cache/apt
        166M    /var/lib
        132M    /var/lib/apt/lists
        Archived and active journals take up 24.0M in the file system.
        /opt/iobroker/backups:
        4.0K    /opt/iobroker/backups/
        /opt/iobroker/iobroker-data:
        67M     /opt/iobroker/iobroker-data/
        59M     /opt/iobroker/iobroker-data/files
        30M     /opt/iobroker/iobroker-data/files/web.admin/static
        29M     /opt/iobroker/iobroker-data/files/web.admin/static/js
        21M     /opt/iobroker/iobroker-data/files/web.admin/static/js/main.aaea95f8.js.map
        8.3M    /opt/iobroker/iobroker-data/files/web.admin/static/js/main.aaea95f8.js
        7.9M    /opt/iobroker/iobroker-data/objects.jsonl
        6.3M    /opt/iobroker/iobroker-data/files/admin.admin/custom/static/js/vendors-node_modules_iobroker_adapter-react-v5_assets_devices_parseNames_js-node_modules_iobr-99c23e.847b8ad9.chunk.js.map
        2.8M    /opt/iobroker/iobroker-data/files/admin.admin/custom/static/js/vendors-node_modules_iobroker_adapter-react-v5_assets_devices_parseNames_js-node_modules_iobr-99c23e.847b8ad9.chunk.js
        USB-Devices by-id:
        *** NodeJS-Installation ***
        /usr/bin/nodejs         v18.19.0
        /usr/bin/node           v18.19.0
        /usr/bin/npm            9.2.0
        /usr/bin/npx            9.2.0
        /home/iobroker/.diag.sh: line 281: corepack: command not found
        *** nodejs is NOT correctly installed ***
        nodejs:
          Installed: 18.19.0+dfsg-6~deb12u1
          Candidate: 18.19.0+dfsg-6~deb12u1
          Version table:
         *** 18.19.0+dfsg-6~deb12u1 500
                100 /var/lib/dpkg/status
             18.19.0-1nodesource1 500
             18.18.2-1nodesource1 500
             18.18.1-1nodesource1 500
             18.18.0-1nodesource1 500
             18.17.1-1nodesource1 500
             18.17.0-1nodesource1 500
             18.16.1-1nodesource1 500
             18.16.0-1nodesource1 500
             18.15.0-1nodesource1 500
             18.14.2-1nodesource1 500
             18.14.1-1nodesource1 500
             18.14.0-1nodesource1 500
             18.13.0+dfsg1-1 500
             18.13.0-1nodesource1 500
             18.12.0-1nodesource1 500
             18.11.0-1nodesource1 500
             18.10.0-1nodesource1 500
             18.9.1-1nodesource1 500
             18.9.0-1nodesource1 500
             18.8.0-1nodesource1 500
             18.7.0-1nodesource1 500
             18.6.0-1nodesource1 500
             18.5.0-1nodesource1 500
             18.4.0-1nodesource1 500
             18.3.0-1nodesource1 500
             18.2.0-1nodesource1 500
             18.1.0-1nodesource1 500
             18.0.0-1nodesource1 500
        No problems detected
        Errors in npm tree:
        *** ioBroker-Installation ***
        ioBroker Status
        Objects type: jsonl
        States  type: jsonl
        Core adapters versions
        js-controller:  5.0.17
        admin:          6.12.0
        javascript:     "javascript" not found
        Adapters from github:   0
        Adapter State
        + system.adapter.admin.0                  : admin                 : raspberrypi5                             -  enabled, port: 8081, bind: 0.0.0.0, run as: admin
        + system.adapter.backitup.0               : backitup              : raspberrypi5                             -  enabled
        + system.adapter.discovery.0              : discovery             : raspberrypi5                             -  enabled
          system.adapter.vis.0                    : vis                   : raspberrypi5                             -  enabled
        + system.adapter.web.0                    : web                   : raspberrypi5                             -  enabled, port: 8082, bind: 0.0.0.0, run as: admin
        + instance is alive
        ioBroker-Repositories
        Active repo(s): stable
        Installed ioBroker-Instances
        Used repository: stable
        Adapter    "admin"        : 6.12.0   , installed 6.12.0
        Adapter    "backitup"     : 2.9.8    , installed 2.9.8
        Controller "js-controller": 5.0.17   , installed 5.0.17
        Adapter    "web"          : 6.1.10   , installed 6.1.10
        Adapter    "ws"           : 2.5.8    , installed 2.5.8
        Objects and States
        Objects:        173
        States:         131
        Hit:2 http://deb.debian.org/debian-security bookworm-security InRelease
        Hit:3 http://deb.debian.org/debian bookworm-updates InRelease
        Hit:4 http://archive.raspberrypi.com/debian bookworm InRelease
        Hit:5 https://deb.nodesource.com/node_18.x nodistro InRelease
        Reading package lists...
        Pending Updates: 0
        *** Listening Ports ***
        tcp        0      0 127.0.0.1:9001          0.0.0.0:*               LISTEN      1001       50870      14564/iobroker.js-c
        tcp        0      0 127.0.0.1:9000          0.0.0.0:*               LISTEN      1001       50877      14564/iobroker.js-c
        tcp        0      0 0.0.0.0:22              0.0.0.0:*               LISTEN      0          17375      1863/sshd: /usr/sbi
        tcp6       0      0 :::22                   :::*                    LISTEN      0          17377      1863/sshd: /usr/sbi
        tcp6       0      0 :::8081                 :::*                    LISTEN      1001       50986      14607/io.admin.0
        tcp6       0      0 :::8082                 :::*                    LISTEN      1001       52618      14824/io.web.0
        udp        0      0 0.0.0.0:5353            0.0.0.0:*                           104        758        655/avahi-daemon: r
        udp        0      0 0.0.0.0:33709           0.0.0.0:*                           104        760        655/avahi-daemon: r
        udp6       0      0 :::5353                 :::*                                104        759        655/avahi-daemon: r
        udp6       0      0 fe80::aaec:1ab3:54b:546 :::*                                0          16660      775/NetworkManager
        udp6       0      0 :::54271                :::*                                104        761        655/avahi-daemon: r
        2023-12-29 20:25:11.316  - info: web.0 (14824) <== Disconnect system.user.admin from ::ffff:192.168.178.109 vis.0
        2023-12-29 20:25:11.368  - info: web.0 (14824) ==> Connected system.user.admin from ::ffff:192.168.178.109
        2023-12-29 20:25:19.295  - info: vis.0 (14869) starting. Version 1.5.4 in /opt/iobroker/node_modules/iobroker.vis, node: v18.19.0, js-controller: 5.0.17
        2023-12-29 20:25:19.897  - info: vis.0 (14869) Terminated (NO_ERROR): Without reason
        2023-12-29 20:25:20.416  - info: host.raspberrypi5 instance system.adapter.vis.0 terminated while should be started once
        2023-12-29 20:25:22.291  - info: vis.0 (14884) starting. Version 1.5.4 in /opt/iobroker/node_modules/iobroker.vis, node: v18.19.0, js-controller: 5.0.17
        2023-12-29 20:25:22.889  - info: vis.0 (14884) Terminated (NO_ERROR): Without reason
        2023-12-29 20:25:23.407  - info: host.raspberrypi5 instance system.adapter.vis.0 terminated while should be started once
        2023-12-29 20:28:33.981  - info: web.0 (14824) <== Disconnect system.user.admin from ::ffff:192.168.178.109 vis.0
        2023-12-29 20:28:59.713  - info: web.0 (14824) ==> Connected system.user.admin from ::ffff:192.168.178.109
        2023-12-29 20:29:12.782  - info: web.0 (14824) ==> Connected system.user.admin from ::ffff:192.168.178.196
        2023-12-29 20:35:24.724  - warn: web.0 (14824) State "dev3" has no existing object, this might lead to an error in future versions
        2023-12-29 20:35:25.626  - warn: web.0 (14824) State "dev3" has no existing object, this might lead to an error in future versions
        2023-12-29 20:35:26.397  - warn: web.0 (14824) State "dev1" has no existing object, this might lead to an error in future versions
        2023-12-29 20:35:27.843  - warn: web.0 (14824) State "dev2" has no existing object, this might lead to an error in future versions
        2023-12-29 20:35:28.846  - warn: web.0 (14824) State "dev2" has no existing object, this might lead to an error in future versions
        2023-12-29 20:35:30.206  - warn: web.0 (14824) State "dev2" has no existing object, this might lead to an error in future versions
        2023-12-29 20:35:37.405  - info: web.0 (14824) <== Disconnect system.user.admin from ::ffff:192.168.178.196 vis.0
        2023-12-29 20:35:45.761  - info: web.0 (14824) ==> Connected system.user.admin from ::ffff:192.168.178.196
        2023-12-29 20:36:03.952  - info: web.0 (14824) <== Disconnect system.user.admin from ::ffff:192.168.178.196 vis.0
        2023-12-29 20:36:05.291  - info: web.0 (14824) ==> Connected system.user.admin from ::ffff:192.168.178.196
        2023-12-29 20:38:36.455  - info: web.0 (14824) <== Disconnect system.user.admin from ::ffff:192.168.178.196 vis.0
        2023-12-29 20:40:00.042  - info: web.0 (14824) <== Disconnect system.user.admin from ::ffff:192.168.178.109 vis.0
        2023-12-29 20:40:03.827  - info: web.0 (14824) ==> Connected system.user.admin from ::ffff:192.168.178.109
        2023-12-29 20:40:06.584  - info: web.0 (14824) <== Disconnect system.user.admin from ::ffff:192.168.178.109 vis.0
        iob diag has finished.
        Press any key for a summary
          hattest du das nicht gemacht?
          bitte iob nodejs-update ausführen, da ist anscheinend noch das alte repo aktiv
          das ist wahrscheinlich der Fehler
          https://forum.iobroker.net/topic/71461/dfsg-nodejs-eingehandelt-hier-die-korrektur/10
          hiernach läuft vis tatsächlich nicht
          iob start vis
          Max 0 1 Reply Last reply Reply Quote 0
          • Max 0
            @homoran resizing filesystem from 536576 to 3768320 blocks
            was bedeutet dies und was müsste ich da machen?
            Den iob nodejs-update habe ich gemacht
            und den iob start vis auch. Funktioniert aber immer noch nicht
            Und was meinst du mit *** 18.19.0+dfsg-6~deb12u1 500 ?
            habe auf dem Link geschaut aber nichts gefunden
              Thomas Braun Most Active @Max 0 last edited by
              Und
              iob diag
              sagt nun?
              • Max 0
                Max 0 @Thomas Braun last edited by Homoran
                Skript v.2023-10-10
                *** BASE SYSTEM ***
                       Icon name: computer
                    Architecture: arm64
                Docker          : false
                Kernel          : aarch64
                Userland        : arm64
                 23:07:00 up  3:28,  2 users,  load average: 0.12, 0.11, 0.11
                CPU threads: 4
                Current issues:
                               Local time: Fri 2023-12-29 23:07:00 CET
                           Universal time: Fri 2023-12-29 22:07:00 UTC
                                 RTC time: Fri 2023-12-29 22:07:00
                              NTP service: active
                          RTC in local TZ: no
                pi
                /home/pi
                pi adm dialout cdrom sudo audio video plugdev games users input render netdev gp        io i2c spi
                X-Server:       false
                Desktop:
                Terminal:       tty
                *** MEMORY ***
                Mem:            8.4G        681M        5.3G        5.3M        2.6G        7.8G
                Swap:           104M          0B        104M
                Total:          8.5G        681M        5.4G
                         8053 M total memory
                          650 M used memory
                          607 M active memory
                         2104 M inactive memory
                         5031 M free memory
                          168 M buffer memory
                         2304 M swap cache
                           99 M total swap
                            0 M used swap
                           99 M free swap
                Raspberry only:
                *** FILESYSTEM ***
                /dev/mmcblk0p2 ext4       15G  2.9G   11G  22% /
                [Fri Dec 29 19:38:43 2023] Kernel command line: coherent_pool=1M 8250.nr_uarts=1        pci=pcie_bus_safe snd_bcm2835.enable_compat_alsa=0 snd_bcm2835.enable_hdmi=1  s        msc95xx.macaddr=D8:3A:DD:BB:FC:13 vc_mem.mem_base=0x3fc00000 vc_mem.mem_size=0x4        0000000  console=ttyAMA10,115200 console=tty1 root=PARTUUID=0fd8a7d6-02 rootfsty        pe=ext4 fsck.repair=yes rootwait
                `-/boot/firmware /dev/mmcblk0p1 vfat   rw,relatime,fmask=0022,dmask=0022,codepag        e=437,iocharset=ascii,shortname=mixed,errors=remount-ro
                /var:
                548M    /var/
                260M    /var/cache
                254M    /var/cache/apt
                164M    /var/lib
                142M    /var/cache/apt/archives
                69M     /opt/iobroker/iobroker-data/
                21M     /opt/iobroker/iobroker-data/files/web.admin/static/js/main.aaea95f8.js.m        ap
                6.3M    /opt/iobroker/iobroker-data/files/admin.admin/custom/static/js/vendors-n        ode_modules_iobroker_adapter-react-v5_assets_devices_parseNames_js-node_modules_        iobr-99c23e.847b8ad9.chunk.js.map
                2.8M    /opt/iobroker/iobroker-data/files/admin.admin/custom/static/js/vendors-n        ode_modules_iobroker_adapter-react-v5_assets_devices_parseNames_js-node_modules_        iobr-99c23e.847b8ad9.chunk.js
                USB-Devices by-id:
                USB-Sticks -  Avoid direct links to /dev/* in your adapter setups, please always        prefer the links 'by-id':
                /usr/bin/npm            10.2.3
                /usr/bin/npx            10.2.3
                /usr/bin/corepack       0.22.0
                nodejs:
                  Installed: 18.19.0-1nodesource1
                  Candidate: 18.19.0-1nodesource1
                  Version table:
                        500 http://deb.debian.org/debian-security bookworm-security/main arm64 P        ackages
                 *** 18.19.0-1nodesource1 1001
                     18.18.2-1nodesource1 1001
                     18.18.1-1nodesource1 1001
                     18.18.0-1nodesource1 1001
                     18.17.1-1nodesource1 1001
                     18.17.0-1nodesource1 1001
                     18.16.1-1nodesource1 1001
                     18.16.0-1nodesource1 1001
                     18.15.0-1nodesource1 1001
                     18.14.2-1nodesource1 1001
                     18.14.1-1nodesource1 1001
                     18.14.0-1nodesource1 1001
                     18.13.0+dfsg1-1 500
                     18.13.0-1nodesource1 1001
                     18.12.0-1nodesource1 1001
                     18.11.0-1nodesource1 1001
                     18.10.0-1nodesource1 1001
                     18.9.1-1nodesource1 1001
                     18.9.0-1nodesource1 1001
                     18.8.0-1nodesource1 1001
                     18.7.0-1nodesource1 1001
                     18.6.0-1nodesource1 1001
                     18.5.0-1nodesource1 1001
                     18.4.0-1nodesource1 1001
                     18.3.0-1nodesource1 1001
                     18.2.0-1nodesource1 1001
                     18.1.0-1nodesource1 1001
                     18.0.0-1nodesource1 1001
                Errors in npm tree:
                ioBroker Status
                Objects type: jsonl
                States  type: jsonl
                admin:          6.12.0
                Adapter State
                + instance is alive
                Objects and States
                Objects:        180
                States:         138
                Hit:4 https://deb.nodesource.com/node_18.x nodistro InRelease
                Hit:5 http://archive.raspberrypi.com/debian bookworm InRelease
                Pending Updates: 0
                tcp        0      0 127.0.0.1:9001          0.0.0.0:*               LISTEN      1001       73444      20322/iobroker.js-c
                tcp        0      0 127.0.0.1:9000          0.0.0.0:*               LISTEN      1001       73451      20322/iobroker.js-c
                tcp6       0      0 :::8081                 :::*                    LISTEN      1001       72340      20340/io.admin.0
                tcp6       0      0 :::8082                 :::*                    LISTEN      1001       71622      20397/io.web.0
                2023-12-29 22:54:09.429  - info: host.raspberrypi5 instance system.adapter.discovery.0 started with pid 20367
                2023-12-29 22:54:10.104  - info: discovery.0 (20367) starting. Version 4.2.0 in /opt/iobroker/node_modules/iobroker.discovery, node: v18.19.0, js-controller: 5.0.17
                2023-12-29 22:54:13.424  - info: host.raspberrypi5 instance system.adapter.backitup.0 started with pid 20382
                2023-12-29 22:54:14.130  - info: backitup.0 (20382) starting. Version 2.9.8 in /opt/iobroker/node_modules/iobroker.backitup, node: v18.19.0, js-controller: 5.0.17
                2023-12-29 22:54:14.155  - info: backitup.0 (20382) [iobroker] backup will be activated at 02:48 every 1 day(s)
                2023-12-29 22:54:14.294  - info: admin.0 (20340) ==> Connected system.user.admin from ::ffff:192.168.178.109
                2023-12-29 22:54:17.427  - info: host.raspberrypi5 instance system.adapter.web.0 started with pid 20397
                2023-12-29 22:54:18.144  - info: web.0 (20397) starting. Version 6.1.10 in /opt/iobroker/node_modules/iobroker.web, node: v18.19.0, js-controller: 5.0.17
                2023-12-29 22:54:18.209  - info: web.0 (20397) socket.io server listening on port 8082
                2023-12-29 22:54:18.211  - info: web.0 (20397) http server listening on port 8082
                2023-12-29 22:54:18.937  - info: admin.0 (20340) <== Disconnect system.user.admin from ::ffff:192.168.178.109 admin
                2023-12-29 22:54:19.521  - info: admin.0 (20340) ==> Connected system.user.admin from ::ffff:192.168.178.109
                2023-12-29 22:54:22.126  - info: vis.0 (20412) starting. Version 1.5.4 in /opt/iobroker/node_modules/iobroker.vis, node: v18.19.0, js-controller: 5.0.17
                2023-12-29 22:54:22.725  - info: vis.0 (20412) Terminated (NO_ERROR): Without reason
                2023-12-29 22:54:23.277  - info: host.raspberrypi5 instance system.adapter.vis.0 terminated while should be started once
                2023-12-29 22:54:34.893  - info: web.0 (20397) ==> Connected system.user.admin from ::ffff:192.168.178.109
                2023-12-29 22:54:37.305  - info: web.0 (20397) <== Disconnect system.user.admin from ::ffff:192.168.178.109 vis.0
                2023-12-29 22:55:06.666  - info: admin.0 (20340) <== Disconnect system.user.admin from ::ffff:192.168.178.109 admin
                2023-12-29 22:55:07.139  - info: admin.0 (20340) ==> Connected system.user.admin from ::ffff:192.168.178.109
                2023-12-29 22:58:25.891  - info: admin.0 (20340) <== Disconnect system.user.admin from ::ffff:192.168.178.109 admin
                2023-12-29 22:58:26.369  - info: admin.0 (20340) ==> Connected system.user.admin from ::ffff:192.168.178.109
                2023-12-29 23:06:22.986  - info: admin.0 (20340) <== Disconnect system.user.admin from ::ffff:192.168.178.109 admin
                2023-12-29 23:06:23.461  - info: admin.0 (20340) ==> Connected system.user.admin from ::ffff:192.168.178.109
                2023-12-29 23:06:27.503  - info: web.0 (20397) ==> Connected system.user.admin from ::ffff:192.168.178.109
                2023-12-29 23:06:29.257  - info: web.0 (20397) <== Disconnect system.user.admin from ::ffff:192.168.178.109 vis.0
                  @max-0
                  nodejs passt.
                  • Max 0
                    @thomas-brau
                    Und jetzt?
                    Thomas Braun sigi234 2 Replies Last reply Reply Quote 0
                      @max-0
                      Von vis hab ich keine Ahnung.
                        sigi234 Forum Testing Most Active @Max 0 last edited by
                        @thomas-brau
                        Und jetzt?
                        Screenshot vom WEB Adapter bitte.
                          was bedeutet dies u
                          dass du von deiner SD Karte nur einen Bruchteil genutzt hattest
                          die Anleitung mit wenigen Befehlen stand direkt im ersten Post.
                          Hat sich aber wohl inzwischen erledigt.
                          • OliverIO
                            OliverIO last edited by
                            @max-0
                            Welcher browser?
                            Welsch Version?
                            Was sagen die Fehlermeldungen in der browserkonsole? Öffnen mit F12
                            • Max 0
                              Max 0 @sigi234 last edited by
                              • Max 0
                                Max 0 @OliverIO last edited by
                                @oliverio
                                Ich benutze den Opera browser
                                Opera Version 105.0.4970.63
                                Und hier die browserkonsole:
                                2023-12-30T10:48:23.961Z Connected => authenticate
                                data:application/json;charset=8{"name":"ioBroker vis","short_name":"vis","start_url":".#main/%22,%22display%22:%22standalone%22,%22background_color%22:%22#ffffff%22,%22description%22:%22WEB%20visualisation%20for%20ioBroker%20platform%22,%22icons%22:[{%22src%22:%22img/vis.png%22,%22sizes%22:%22192x192%22,%22type%22:%22image/png%22}]}:1
                                       Failed to load resource: net::ERR_INVALID_URL
                                conn.js:331 2023-12-30T10:48:24.070Z Authenticated: true
                                vis.js:3595 Create inner vis object demoTemperature
                                vis.js:3595 Create inner vis object demoHumidity
                                translate.js:20 "Use background": {"en": "Use background", "de": "Use background", "ru": "Use background"},
                                edit.html:1 Uncaught SyntaxError: Unexpected non-whitespace character after JSON at position 2 (line 1 column 3)
                                    at JSON.parse (<anonymous>)
                                    at Object.unserialize (loStorage.js:2:567)
                                    at r.get (loStorage.js:2:1871)
                                    at Function.get (loStorage.js:2:2346)
                                    at Object.bindInstance (vis.js:576:54)
                                    at Object.initNext (vis.js:705:14)
                                    at Object.<anonymous> (vis.js:603:18)
                                    at Object.loadWidgetSets (vis.js:568:34)
                                    at Object.init (vis.js:602:14)
                                    at vis.js:3661:29
                                • Max 0
                                  Hat das Auswirkungen das ich nur ein Bruchteil meiner SD Karte nutze?
                                  Was kann ich dagegen tun?
                                  DJMarc75 Homoran 2 Replies Last reply Reply Quote 0
                                    Haken setzen bei reine Websockes ....
                                    • DJMarc75
                                      DJMarc75 @Max 0 last edited by
                                      Im Terminal
                                      sudo raspi-config
                                      eingeben.
                                      Dann
                                      Zuletzt den Raspberry rebooten.
                                        ist doch jetzt passiert
                                        • Max 0
                                          Max 0 @DJMarc75 last edited by Max 0
                                          @djmarc75
                                          Habe ich gemacht
                                          Und jetzt?
                                          • Max 0
                                            Vlt hilft das
                                            3399
