    4. vis 1 läuft nicht mehr
    • Max 0
      Max 0 @Homoran last edited by Homoran
      @homoran Skript v.2023-10-10
      *** BASE SYSTEM ***
       Static hostname: raspberrypi5
             Icon name: computer
                Kernel: Linux 6.1.0-rpi7-rpi-2712
          Architecture: arm64
      Model           : Raspberry Pi 5 Model B Rev 1.0
      Docker          : false
      Virtualization  : none
      Kernel          : aarch64
      Userland        : arm64
      Systemuptime and Load:
       20:46:18 up  1:07,  2 users,  load average: 0.72, 0.33, 0.17
      CPU threads: 4
      *** RASPBERRY THROTTLING ***
      Current issues:
      Previously detected issues:
      *** Time and Time Zones ***
                     Local time: Fri 2023-12-29 20:46:18 CET
                 Universal time: Fri 2023-12-29 19:46:18 UTC
                       RTC time: Fri 2023-12-29 19:46:18
                    NTP service: active
                RTC in local TZ: no
      *** User and Groups ***
      pi
      /home/pi
      pi adm dialout cdrom sudo audio video plugdev games users input render netdev gpio i2c spi
      *** X-Server-Setup ***
      X-Server:       false
      Desktop:
      Terminal:       tty
      Boot Target:    multi-user.target
      *** MEMORY ***
      Mem:            8.4G        730M        5.3G        5.3M        2.5G        7.7G
      Swap:           104M          0B        104M
      Total:          8.5G        730M        5.4G
               8053 M total memory
                697 M used memory
                655 M active memory
               2052 M inactive memory
               5037 M free memory
                149 M buffer memory
               2270 M swap cache
                 99 M total swap
                  0 M used swap
                 99 M free swap
      Raspberry only:
      vc_gencmd_read_response returned -1
      error=1 error_msg="Command not registered"
      *** FAILED SERVICES ***
      0 loaded units listed.
      *** FILESYSTEM ***
      udev           devtmpfs  3.8G     0  3.8G   0% /dev
      tmpfs          tmpfs     806M  5.0M  801M   1% /run
      /dev/mmcblk0p2 ext4       15G  2.8G   11G  21% /
      tmpfs          tmpfs     4.0G     0  4.0G   0% /dev/shm
      tmpfs          tmpfs     5.0M   48K  5.0M   1% /run/lock
      /dev/mmcblk0p1 vfat      510M   61M  450M  12% /boot/firmware
      tmpfs          tmpfs     806M     0  806M   0% /run/user/1000
      [Fri Dec 29 19:38:43 2023] Kernel command line: coherent_pool=1M 8250.nr_uarts=1 pci=pcie_bus_safe snd_bcm2835.enable_compat_alsa=0 snd_bcm2835.enable_hdmi=1  smsc95xx.macaddr=D8:3A:DD:BB:FC:13 vc_mem.mem_base=0x3fc00000 vc_mem.mem_size=0x40000000  console=ttyAMA10,115200 console=tty1 root=PARTUUID=0fd8a7d6-02 rootfstype=ext4 fsck.repair=yes rootwait
      [Fri Dec 29 19:38:46 2023] EXT4-fs (mmcblk0p2): mounted filesystem with ordered data mode. Quota mode: none.
      [Fri Dec 29 19:38:49 2023] EXT4-fs (mmcblk0p2): re-mounted. Quota mode: none.
      [Fri Dec 29 19:38:53 2023] EXT4-fs (mmcblk0p2): resizing filesystem from 536576 to 3768320 blocks
      [Fri Dec 29 19:38:56 2023] EXT4-fs (mmcblk0p2): resized filesystem to 3768320
      TARGET           SOURCE         FSTYPE OPTIONS
      /                /dev/mmcblk0p2 ext4   rw,noatime
      `-/boot/firmware /dev/mmcblk0p1 vfat   rw,relatime,fmask=0022,dmask=0022,codepage=437,iocharset=ascii,shortname=mixed,errors=remount-ro
      /var:
      496M    /var/
      206M    /var/cache
      200M    /var/cache/apt
      166M    /var/lib
      132M    /var/lib/apt/lists
      Archived and active journals take up 24.0M in the file system.
      /opt/iobroker/backups:
      4.0K    /opt/iobroker/backups/
      /opt/iobroker/iobroker-data:
      67M     /opt/iobroker/iobroker-data/
      59M     /opt/iobroker/iobroker-data/files
      30M     /opt/iobroker/iobroker-data/files/web.admin/static
      29M     /opt/iobroker/iobroker-data/files/web.admin/static/js
      21M     /opt/iobroker/iobroker-data/files/web.admin/static/js/main.aaea95f8.js.map
      8.3M    /opt/iobroker/iobroker-data/files/web.admin/static/js/main.aaea95f8.js
      7.9M    /opt/iobroker/iobroker-data/objects.jsonl
      6.3M    /opt/iobroker/iobroker-data/files/admin.admin/custom/static/js/vendors-node_modules_iobroker_adapter-react-v5_assets_devices_parseNames_js-node_modules_iobr-99c23e.847b8ad9.chunk.js.map
      2.8M    /opt/iobroker/iobroker-data/files/admin.admin/custom/static/js/vendors-node_modules_iobroker_adapter-react-v5_assets_devices_parseNames_js-node_modules_iobr-99c23e.847b8ad9.chunk.js
      USB-Devices by-id:
      *** NodeJS-Installation ***
      /usr/bin/nodejs         v18.19.0
      /usr/bin/node           v18.19.0
      /usr/bin/npm            9.2.0
      /usr/bin/npx            9.2.0
      /home/iobroker/.diag.sh: line 281: corepack: command not found
      *** nodejs is NOT correctly installed ***
      nodejs:
        Installed: 18.19.0+dfsg-6~deb12u1
        Candidate: 18.19.0+dfsg-6~deb12u1
        Version table:
       *** 18.19.0+dfsg-6~deb12u1 500
              100 /var/lib/dpkg/status
           18.19.0-1nodesource1 500
           18.18.2-1nodesource1 500
           18.18.1-1nodesource1 500
           18.18.0-1nodesource1 500
           18.17.1-1nodesource1 500
           18.17.0-1nodesource1 500
           18.16.1-1nodesource1 500
           18.16.0-1nodesource1 500
           18.15.0-1nodesource1 500
           18.14.2-1nodesource1 500
           18.14.1-1nodesource1 500
           18.14.0-1nodesource1 500
           18.13.0+dfsg1-1 500
           18.13.0-1nodesource1 500
           18.12.0-1nodesource1 500
           18.11.0-1nodesource1 500
           18.10.0-1nodesource1 500
           18.9.1-1nodesource1 500
           18.9.0-1nodesource1 500
           18.8.0-1nodesource1 500
           18.7.0-1nodesource1 500
           18.6.0-1nodesource1 500
           18.5.0-1nodesource1 500
           18.4.0-1nodesource1 500
           18.3.0-1nodesource1 500
           18.2.0-1nodesource1 500
           18.1.0-1nodesource1 500
           18.0.0-1nodesource1 500
      No problems detected
      Errors in npm tree:
      *** ioBroker-Installation ***
      ioBroker Status
      Objects type: jsonl
      States  type: jsonl
      Core adapters versions
      js-controller:  5.0.17
      admin:          6.12.0
      javascript:     "javascript" not found
      Adapters from github:   0
      Adapter State
      + system.adapter.admin.0                  : admin                 : raspberrypi5                             -  enabled, port: 8081, bind: 0.0.0.0, run as: admin
      + system.adapter.backitup.0               : backitup              : raspberrypi5                             -  enabled
      + system.adapter.discovery.0              : discovery             : raspberrypi5                             -  enabled
        system.adapter.vis.0                    : vis                   : raspberrypi5                             -  enabled
      + system.adapter.web.0                    : web                   : raspberrypi5                             -  enabled, port: 8082, bind: 0.0.0.0, run as: admin
      + instance is alive
      ioBroker-Repositories
      Active repo(s): stable
      Installed ioBroker-Instances
      Used repository: stable
      Adapter    "admin"        : 6.12.0   , installed 6.12.0
      Adapter    "backitup"     : 2.9.8    , installed 2.9.8
      Controller "js-controller": 5.0.17   , installed 5.0.17
      Adapter    "web"          : 6.1.10   , installed 6.1.10
      Adapter    "ws"           : 2.5.8    , installed 2.5.8
      Objects and States
      Objects:        173
      States:         131
      Hit:2 http://deb.debian.org/debian-security bookworm-security InRelease
      Hit:3 http://deb.debian.org/debian bookworm-updates InRelease
      Hit:4 http://archive.raspberrypi.com/debian bookworm InRelease
      Hit:5 https://deb.nodesource.com/node_18.x nodistro InRelease
      Reading package lists...
      Pending Updates: 0
      *** Listening Ports ***
      tcp        0      0 127.0.0.1:9001          0.0.0.0:*               LISTEN      1001       50870      14564/iobroker.js-c
      tcp        0      0 127.0.0.1:9000          0.0.0.0:*               LISTEN      1001       50877      14564/iobroker.js-c
      tcp        0      0 0.0.0.0:22              0.0.0.0:*               LISTEN      0          17375      1863/sshd: /usr/sbi
      tcp6       0      0 :::22                   :::*                    LISTEN      0          17377      1863/sshd: /usr/sbi
      tcp6       0      0 :::8081                 :::*                    LISTEN      1001       50986      14607/io.admin.0
      tcp6       0      0 :::8082                 :::*                    LISTEN      1001       52618      14824/io.web.0
      udp        0      0 0.0.0.0:5353            0.0.0.0:*                           104        758        655/avahi-daemon: r
      udp        0      0 0.0.0.0:33709           0.0.0.0:*                           104        760        655/avahi-daemon: r
      udp6       0      0 :::5353                 :::*                                104        759        655/avahi-daemon: r
      udp6       0      0 fe80::aaec:1ab3:54b:546 :::*                                0          16660      775/NetworkManager
      udp6       0      0 :::54271                :::*                                104        761        655/avahi-daemon: r
      2023-12-29 20:25:11.316  - info: web.0 (14824) <== Disconnect system.user.admin from ::ffff:192.168.178.109 vis.0
      2023-12-29 20:25:11.368  - info: web.0 (14824) ==> Connected system.user.admin from ::ffff:192.168.178.109
      2023-12-29 20:25:19.295  - info: vis.0 (14869) starting. Version 1.5.4 in /opt/iobroker/node_modules/iobroker.vis, node: v18.19.0, js-controller: 5.0.17
      2023-12-29 20:25:19.897  - info: vis.0 (14869) Terminated (NO_ERROR): Without reason
      2023-12-29 20:25:20.416  - info: host.raspberrypi5 instance system.adapter.vis.0 terminated while should be started once
      2023-12-29 20:25:22.291  - info: vis.0 (14884) starting. Version 1.5.4 in /opt/iobroker/node_modules/iobroker.vis, node: v18.19.0, js-controller: 5.0.17
      2023-12-29 20:25:22.889  - info: vis.0 (14884) Terminated (NO_ERROR): Without reason
      2023-12-29 20:25:23.407  - info: host.raspberrypi5 instance system.adapter.vis.0 terminated while should be started once
      2023-12-29 20:28:33.981  - info: web.0 (14824) <== Disconnect system.user.admin from ::ffff:192.168.178.109 vis.0
      2023-12-29 20:28:59.713  - info: web.0 (14824) ==> Connected system.user.admin from ::ffff:192.168.178.109
      2023-12-29 20:29:12.782  - info: web.0 (14824) ==> Connected system.user.admin from ::ffff:192.168.178.196
      2023-12-29 20:35:24.724  - warn: web.0 (14824) State "dev3" has no existing object, this might lead to an error in future versions
      2023-12-29 20:35:25.626  - warn: web.0 (14824) State "dev3" has no existing object, this might lead to an error in future versions
      2023-12-29 20:35:26.397  - warn: web.0 (14824) State "dev1" has no existing object, this might lead to an error in future versions
      2023-12-29 20:35:27.843  - warn: web.0 (14824) State "dev2" has no existing object, this might lead to an error in future versions
      2023-12-29 20:35:28.846  - warn: web.0 (14824) State "dev2" has no existing object, this might lead to an error in future versions
      2023-12-29 20:35:30.206  - warn: web.0 (14824) State "dev2" has no existing object, this might lead to an error in future versions
      2023-12-29 20:35:37.405  - info: web.0 (14824) <== Disconnect system.user.admin from ::ffff:192.168.178.196 vis.0
      2023-12-29 20:35:45.761  - info: web.0 (14824) ==> Connected system.user.admin from ::ffff:192.168.178.196
      2023-12-29 20:36:03.952  - info: web.0 (14824) <== Disconnect system.user.admin from ::ffff:192.168.178.196 vis.0
      2023-12-29 20:36:05.291  - info: web.0 (14824) ==> Connected system.user.admin from ::ffff:192.168.178.196
      2023-12-29 20:38:36.455  - info: web.0 (14824) <== Disconnect system.user.admin from ::ffff:192.168.178.196 vis.0
      2023-12-29 20:40:00.042  - info: web.0 (14824) <== Disconnect system.user.admin from ::ffff:192.168.178.109 vis.0
      2023-12-29 20:40:03.827  - info: web.0 (14824) ==> Connected system.user.admin from ::ffff:192.168.178.109
      2023-12-29 20:40:06.584  - info: web.0 (14824) <== Disconnect system.user.admin from ::ffff:192.168.178.109 vis.0
      iob diag has finished.
      Press any key for a summary
        Homoran Global Moderator Administrators @Max 0 last edited by
        @max-0 sagte in vis 1 läuft nicht mehr:
        hattest du das nicht gemacht?
        bitte iob nodejs-update ausführen, da ist anscheinend noch das alte repo aktiv
        das ist wahrscheinlich der Fehler
        https://forum.iobroker.net/topic/71461/dfsg-nodejs-eingehandelt-hier-die-korrektur/10
        hiernach läuft vis tatsächlich nicht
        iob start vis
        Max 0 1 Reply Last reply Reply Quote 0
        • Max 0
          @homoran resizing filesystem from 536576 to 3768320 blocks
          was bedeutet dies und was müsste ich da machen?
          Den iob nodejs-update habe ich gemacht
          und den iob start vis auch. Funktioniert aber immer noch nicht
          Und was meinst du mit *** 18.19.0+dfsg-6~deb12u1 500 ?
          habe auf dem Link geschaut aber nichts gefunden
            Thomas Braun Most Active @Max 0 last edited by
            Und
            iob diag
            sagt nun?
            • Max 0
              Max 0 @Thomas Braun last edited by Homoran
              Skript v.2023-10-10
              *** BASE SYSTEM ***
                     Icon name: computer
                  Architecture: arm64
              Docker          : false
              Kernel          : aarch64
              Userland        : arm64
               23:07:00 up  3:28,  2 users,  load average: 0.12, 0.11, 0.11
              CPU threads: 4
              Current issues:
                             Local time: Fri 2023-12-29 23:07:00 CET
                         Universal time: Fri 2023-12-29 22:07:00 UTC
                               RTC time: Fri 2023-12-29 22:07:00
                            NTP service: active
                        RTC in local TZ: no
              pi
              /home/pi
              pi adm dialout cdrom sudo audio video plugdev games users input render netdev gp        io i2c spi
              X-Server:       false
              Desktop:
              Terminal:       tty
              *** MEMORY ***
              Mem:            8.4G        681M        5.3G        5.3M        2.6G        7.8G
              Swap:           104M          0B        104M
              Total:          8.5G        681M        5.4G
                       8053 M total memory
                        650 M used memory
                        607 M active memory
                       2104 M inactive memory
                       5031 M free memory
                        168 M buffer memory
                       2304 M swap cache
                         99 M total swap
                          0 M used swap
                         99 M free swap
              Raspberry only:
              *** FILESYSTEM ***
              /dev/mmcblk0p2 ext4       15G  2.9G   11G  22% /
              [Fri Dec 29 19:38:43 2023] Kernel command line: coherent_pool=1M 8250.nr_uarts=1        pci=pcie_bus_safe snd_bcm2835.enable_compat_alsa=0 snd_bcm2835.enable_hdmi=1  s        msc95xx.macaddr=D8:3A:DD:BB:FC:13 vc_mem.mem_base=0x3fc00000 vc_mem.mem_size=0x4        0000000  console=ttyAMA10,115200 console=tty1 root=PARTUUID=0fd8a7d6-02 rootfsty        pe=ext4 fsck.repair=yes rootwait
              `-/boot/firmware /dev/mmcblk0p1 vfat   rw,relatime,fmask=0022,dmask=0022,codepag        e=437,iocharset=ascii,shortname=mixed,errors=remount-ro
              /var:
              548M    /var/
              260M    /var/cache
              254M    /var/cache/apt
              164M    /var/lib
              142M    /var/cache/apt/archives
              69M     /opt/iobroker/iobroker-data/
              21M     /opt/iobroker/iobroker-data/files/web.admin/static/js/main.aaea95f8.js.m        ap
              6.3M    /opt/iobroker/iobroker-data/files/admin.admin/custom/static/js/vendors-n        ode_modules_iobroker_adapter-react-v5_assets_devices_parseNames_js-node_modules_        iobr-99c23e.847b8ad9.chunk.js.map
              2.8M    /opt/iobroker/iobroker-data/files/admin.admin/custom/static/js/vendors-n        ode_modules_iobroker_adapter-react-v5_assets_devices_parseNames_js-node_modules_        iobr-99c23e.847b8ad9.chunk.js
              USB-Devices by-id:
              USB-Sticks -  Avoid direct links to /dev/* in your adapter setups, please always        prefer the links 'by-id':
              /usr/bin/npm            10.2.3
              /usr/bin/npx            10.2.3
              /usr/bin/corepack       0.22.0
              nodejs:
                Installed: 18.19.0-1nodesource1
                Candidate: 18.19.0-1nodesource1
                Version table:
                      500 http://deb.debian.org/debian-security bookworm-security/main arm64 P        ackages
               *** 18.19.0-1nodesource1 1001
                   18.18.2-1nodesource1 1001
                   18.18.1-1nodesource1 1001
                   18.18.0-1nodesource1 1001
                   18.17.1-1nodesource1 1001
                   18.17.0-1nodesource1 1001
                   18.16.1-1nodesource1 1001
                   18.16.0-1nodesource1 1001
                   18.15.0-1nodesource1 1001
                   18.14.2-1nodesource1 1001
                   18.14.1-1nodesource1 1001
                   18.14.0-1nodesource1 1001
                   18.13.0+dfsg1-1 500
                   18.13.0-1nodesource1 1001
                   18.12.0-1nodesource1 1001
                   18.11.0-1nodesource1 1001
                   18.10.0-1nodesource1 1001
                   18.9.1-1nodesource1 1001
                   18.9.0-1nodesource1 1001
                   18.8.0-1nodesource1 1001
                   18.7.0-1nodesource1 1001
                   18.6.0-1nodesource1 1001
                   18.5.0-1nodesource1 1001
                   18.4.0-1nodesource1 1001
                   18.3.0-1nodesource1 1001
                   18.2.0-1nodesource1 1001
                   18.1.0-1nodesource1 1001
                   18.0.0-1nodesource1 1001
              Errors in npm tree:
              ioBroker Status
              Objects type: jsonl
              States  type: jsonl
              admin:          6.12.0
              Adapter State
              + instance is alive
              Objects and States
              Objects:        180
              States:         138
              Hit:4 https://deb.nodesource.com/node_18.x nodistro InRelease
              Hit:5 http://archive.raspberrypi.com/debian bookworm InRelease
              Pending Updates: 0
              tcp        0      0 127.0.0.1:9001          0.0.0.0:*               LISTEN      1001       73444      20322/iobroker.js-c
              tcp        0      0 127.0.0.1:9000          0.0.0.0:*               LISTEN      1001       73451      20322/iobroker.js-c
              tcp6       0      0 :::8081                 :::*                    LISTEN      1001       72340      20340/io.admin.0
              tcp6       0      0 :::8082                 :::*                    LISTEN      1001       71622      20397/io.web.0
              2023-12-29 22:54:09.429  - info: host.raspberrypi5 instance system.adapter.discovery.0 started with pid 20367
              2023-12-29 22:54:10.104  - info: discovery.0 (20367) starting. Version 4.2.0 in /opt/iobroker/node_modules/iobroker.discovery, node: v18.19.0, js-controller: 5.0.17
              2023-12-29 22:54:13.424  - info: host.raspberrypi5 instance system.adapter.backitup.0 started with pid 20382
              2023-12-29 22:54:14.130  - info: backitup.0 (20382) starting. Version 2.9.8 in /opt/iobroker/node_modules/iobroker.backitup, node: v18.19.0, js-controller: 5.0.17
              2023-12-29 22:54:14.155  - info: backitup.0 (20382) [iobroker] backup will be activated at 02:48 every 1 day(s)
              2023-12-29 22:54:14.294  - info: admin.0 (20340) ==> Connected system.user.admin from ::ffff:192.168.178.109
              2023-12-29 22:54:17.427  - info: host.raspberrypi5 instance system.adapter.web.0 started with pid 20397
              2023-12-29 22:54:18.144  - info: web.0 (20397) starting. Version 6.1.10 in /opt/iobroker/node_modules/iobroker.web, node: v18.19.0, js-controller: 5.0.17
              2023-12-29 22:54:18.209  - info: web.0 (20397) socket.io server listening on port 8082
              2023-12-29 22:54:18.211  - info: web.0 (20397) http server listening on port 8082
              2023-12-29 22:54:18.937  - info: admin.0 (20340) <== Disconnect system.user.admin from ::ffff:192.168.178.109 admin
              2023-12-29 22:54:19.521  - info: admin.0 (20340) ==> Connected system.user.admin from ::ffff:192.168.178.109
              2023-12-29 22:54:22.126  - info: vis.0 (20412) starting. Version 1.5.4 in /opt/iobroker/node_modules/iobroker.vis, node: v18.19.0, js-controller: 5.0.17
              2023-12-29 22:54:22.725  - info: vis.0 (20412) Terminated (NO_ERROR): Without reason
              2023-12-29 22:54:23.277  - info: host.raspberrypi5 instance system.adapter.vis.0 terminated while should be started once
              2023-12-29 22:54:34.893  - info: web.0 (20397) ==> Connected system.user.admin from ::ffff:192.168.178.109
              2023-12-29 22:54:37.305  - info: web.0 (20397) <== Disconnect system.user.admin from ::ffff:192.168.178.109 vis.0
              2023-12-29 22:55:06.666  - info: admin.0 (20340) <== Disconnect system.user.admin from ::ffff:192.168.178.109 admin
              2023-12-29 22:55:07.139  - info: admin.0 (20340) ==> Connected system.user.admin from ::ffff:192.168.178.109
              2023-12-29 22:58:25.891  - info: admin.0 (20340) <== Disconnect system.user.admin from ::ffff:192.168.178.109 admin
              2023-12-29 22:58:26.369  - info: admin.0 (20340) ==> Connected system.user.admin from ::ffff:192.168.178.109
              2023-12-29 23:06:22.986  - info: admin.0 (20340) <== Disconnect system.user.admin from ::ffff:192.168.178.109 admin
              2023-12-29 23:06:23.461  - info: admin.0 (20340) ==> Connected system.user.admin from ::ffff:192.168.178.109
              2023-12-29 23:06:27.503  - info: web.0 (20397) ==> Connected system.user.admin from ::ffff:192.168.178.109
              2023-12-29 23:06:29.257  - info: web.0 (20397) <== Disconnect system.user.admin from ::ffff:192.168.178.109 vis.0
                @max-0
                nodejs passt.
                • Max 0
                  @thomas-brau
                  Und jetzt?
                  Thomas Braun sigi234 2 Replies Last reply Reply Quote 0
                    @max-0
                    Von vis hab ich keine Ahnung.
                      sigi234 Forum Testing Most Active @Max 0 last edited by
                      @thomas-brau
                      Und jetzt?
                      Screenshot vom WEB Adapter bitte.
                        was bedeutet dies u
                        dass du von deiner SD Karte nur einen Bruchteil genutzt hattest
                        die Anleitung mit wenigen Befehlen stand direkt im ersten Post.
                        Hat sich aber wohl inzwischen erledigt.
                        • OliverIO
                          OliverIO last edited by
                          @max-0
                          Welcher browser?
                          Welsch Version?
                          Was sagen die Fehlermeldungen in der browserkonsole? Öffnen mit F12
                          • Max 0
                            Max 0 @sigi234 last edited by
                            • Max 0
                              Max 0 @OliverIO last edited by
                              @oliverio
                              Ich benutze den Opera browser
                              Opera Version 105.0.4970.63
                              Und hier die browserkonsole:
                              2023-12-30T10:48:23.961Z Connected => authenticate
                              data:application/json;charset=8{"name":"ioBroker vis","short_name":"vis","start_url":".#main/%22,%22display%22:%22standalone%22,%22background_color%22:%22#ffffff%22,%22description%22:%22WEB%20visualisation%20for%20ioBroker%20platform%22,%22icons%22:[{%22src%22:%22img/vis.png%22,%22sizes%22:%22192x192%22,%22type%22:%22image/png%22}]}:1
                                     Failed to load resource: net::ERR_INVALID_URL
                              conn.js:331 2023-12-30T10:48:24.070Z Authenticated: true
                              vis.js:3595 Create inner vis object demoTemperature
                              vis.js:3595 Create inner vis object demoHumidity
                              translate.js:20 "Use background": {"en": "Use background", "de": "Use background", "ru": "Use background"},
                              edit.html:1 Uncaught SyntaxError: Unexpected non-whitespace character after JSON at position 2 (line 1 column 3)
                                  at JSON.parse (<anonymous>)
                                  at Object.unserialize (loStorage.js:2:567)
                                  at r.get (loStorage.js:2:1871)
                                  at Function.get (loStorage.js:2:2346)
                                  at Object.bindInstance (vis.js:576:54)
                                  at Object.initNext (vis.js:705:14)
                                  at Object.<anonymous> (vis.js:603:18)
                                  at Object.loadWidgetSets (vis.js:568:34)
                                  at Object.init (vis.js:602:14)
                                  at vis.js:3661:29
                              • Max 0
                                Hat das Auswirkungen das ich nur ein Bruchteil meiner SD Karte nutze?
                                Was kann ich dagegen tun?
                                DJMarc75 Homoran 2 Replies Last reply Reply Quote 0
                                  Haken setzen bei reine Websockes ....
                                  • DJMarc75
                                    DJMarc75 @Max 0 last edited by
                                    Im Terminal
                                    sudo raspi-config
                                    eingeben.
                                    Dann
                                    Zuletzt den Raspberry rebooten.
                                      ist doch jetzt passiert
                                      • Max 0
                                        Max 0 @DJMarc75 last edited by Max 0
                                        @djmarc75
                                        Habe ich gemacht
                                        Und jetzt?
                                        • Max 0
                                          Vlt hilft das
                                            Vlt hilft das
                                            als Text in code-tags wäre es besser.
                                            was willst du damit zeigen?
                                            3399
