    3. Off Topic
    4. Proxmox
    5. Proxmox: Fehlermeldung bei backup - vzdump ?
      GOETSCHHOFER @crunchip last edited by GOETSCHHOFER
      @crunchip
      Anfangs bei Abfrage iob dag kommt folgende Meldung:
      *** iob diag is starting up, please wait ***
      The state system.host.IOBROKER.versions.nodeNewestNext was not found!
      The state system.host.IOBROKER.versions.npmNewestNext was not found!
      The state system.host.IOBROKER.versions.nodeCurrent was not found!
      Jetzt aber Ergebnis Gesamtabfrage:
      Skript v.2023-10-10
      *** BASE SYSTEM ***
         Static hostname: IOBROKER
               Icon name: computer-vm
                 Chassis: vm
          Virtualization: kvm
        Operating System: Debian GNU/Linux 10 (buster)
                  Kernel: Linux 4.19.0-25-amd64
            Architecture: x86-64
      model name      : Common KVM processor
      Docker          : false
      Virtualization  : kvm
      Kernel          : x86_64
      Userland        : amd64
      Systemuptime and Load:
       07:27:35 up 18 min,  1 user,  load average: 0.15, 0.03, 0.01
      CPU threads: 6
      *** Time and Time Zones ***
                     Local time: Sat 2023-12-30 07:27:35 CET
                 Universal time: Sat 2023-12-30 06:27:35 UTC
                       RTC time: Sat 2023-12-30 06:27:36
                      Time zone: Europe/Vienna (CET, +0100)
                    NTP service: active
                RTC in local TZ: no
      *** User and Groups ***
      karl
      /home/karl
      karl cdrom floppy sudo audio dip video plugdev netdev iobroker
      *** X-Server-Setup ***
      X-Server:       false
      Desktop:
      Terminal:       tty
      *** MEMORY ***
      Mem:           5.5G        235M        4.8G        7.0M        467M        5.0G
      Swap:          974M          0B        974M
      Total:         6.4G        235M        5.7G
               5458 M total memory
                235 M used memory
                316 M active memory
                266 M inactive memory
               4755 M free memory
                 78 M buffer memory
                388 M swap cache
                974 M total swap
                  0 M used swap
                974 M free swap
      *** FAILED SERVICES ***
      0 loaded units listed. Pass --all to see loaded but inactive units, too.
      To show all installed unit files use 'systemctl list-unit-files'.
      *** FILESYSTEM ***
      udev           devtmpfs  2.7G     0  2.7G   0% /dev
      tmpfs          tmpfs     546M  7.3M  539M   2% /run
      /dev/sda1      ext4       19G  4.4G   14G  25% /
      tmpfs          tmpfs     2.7G     0  2.7G   0% /dev/shm
      tmpfs          tmpfs     5.0M     0  5.0M   0% /run/lock
      tmpfs          tmpfs     2.7G     0  2.7G   0% /sys/fs/cgroup
      tmpfs          tmpfs     546M     0  546M   0% /run/user/1000
      [Sat Dec 30 07:09:18 2023] EXT4-fs (sda1): mounted filesystem with ordered data mode. Opts: (null)
      [Sat Dec 30 07:09:18 2023] EXT4-fs (sda1): re-mounted. Opts: errors=remount-ro
      TARGET        SOURCE    FSTYPE OPTIONS
      /             /dev/sda1 ext4   rw,relatime,errors=remount-ro
      `-/sys/fs/bpf bpf       bpf    rw,nosuid,nodev,noexec,relatime,mode=700
      /var:
      665M    /var/
      457M    /var/cache
      451M    /var/cache/apt
      388M    /var/cache/apt/archives
      186M    /var/lib
            Users in the 'systemd-journal' group can see all messages. Pass -q to
            turn off this notice.
      No journal files were opened due to insufficient permissions.
      /opt/iobroker/backups:
      4.0K    /opt/iobroker/backups/
      /opt/iobroker/iobroker-data:
      285M    /opt/iobroker/iobroker-data/
      230M    /opt/iobroker/iobroker-data/files
      53M     /opt/iobroker/iobroker-data/backup-objects
      42M     /opt/iobroker/iobroker-data/files/modbus.admin/static/js
      11M     /opt/iobroker/iobroker-data/files/echarts/static/js/2.0a6dd638.chunk.js.map
      11M     /opt/iobroker/iobroker-data/files/echarts.admin/chart/static/js/2.0a6dd638.chunk.js.map
      9.3M    /opt/iobroker/iobroker-data/files/javascript.admin/static/js/2.b6edad9e.chunk.js.map
      6.8M    /opt/iobroker/iobroker-data/files/echarts.admin/static/js/2.0aad1268.chunk.js.map
      6.2M    /opt/iobroker/iobroker-data/files/modbus.admin/static/js/2.261c158c.chunk.js.map
      USB-Devices by-id:
      *** NodeJS-Installation ***
      /usr/bin/nodejs         v18.19.0
      /usr/bin/node           v18.19.0
      /usr/bin/npm            10.2.3
      /usr/bin/npx            10.2.3
      /usr/bin/corepack       0.22.0
      nodejs:
        Installed: 18.19.0-1nodesource1
        Candidate: 18.19.0-1nodesource1
        Version table:
       *** 18.19.0-1nodesource1 1001
              500 https://deb.nodesource.com/node_18.x nodistro/main amd64 Packages
              100 /var/lib/dpkg/status
           18.18.2-1nodesource1 1001
           18.18.1-1nodesource1 1001
           18.18.0-1nodesource1 1001
           18.17.1-1nodesource1 1001
           18.17.0-1nodesource1 1001
           18.16.1-1nodesource1 1001
           18.16.0-1nodesource1 1001
           18.15.0-1nodesource1 1001
           18.14.2-1nodesource1 1001
           18.14.1-1nodesource1 1001
           18.14.0-1nodesource1 1001
           18.13.0-1nodesource1 1001
           18.12.0-1nodesource1 1001
           18.11.0-1nodesource1 1001
           18.10.0-1nodesource1 1001
           18.9.1-1nodesource1 1001
           18.9.0-1nodesource1 1001
           18.8.0-1nodesource1 1001
           18.7.0-1nodesource1 1001
           18.6.0-1nodesource1 1001
           18.5.0-1nodesource1 1001
           18.4.0-1nodesource1 1001
           18.3.0-1nodesource1 1001
           18.2.0-1nodesource1 1001
           18.1.0-1nodesource1 1001
           18.0.0-1nodesource1 1001
           10.24.0~dfsg-1~deb10u3 500
              500 http://security.debian.org/debian-security buster/updates/main amd64 Packages
           10.24.0~dfsg-1~deb10u1 500
              500 http://deb.debian.org/debian buster/main amd64 Packages
      No problems detected
      Errors in npm tree:
      npm ERR! code ELSPROBLEMS
      npm ERR! invalid: tough-cookie@2.5.0 /opt/iobroker/node_modules/tough-cookie
      npm ERR! A complete log of this run can be found in: /home/karl/.npm/_logs/2023-12-30T06_27_37_794Z-debug-0.log
      *** ioBroker-Installation ***
      ioBroker Status
       Cannot read system.config: null (OK when migrating or restoring)
       Cannot find view "system" for search "host"
      Objects type: file
      States  type: file
      Core adapters versions
      js-controller:  3.2.16
      admin:          5.1.23
      javascript:     5.1.3
      Adapters from github:   14
      Adapter State
      + instance is alive
      ioBroker-Repositories
      Cannot get list: undefined
      Installed ioBroker-Instances
      Error: Object "system.config" not found
        crunchip Forum Testing Most Active @GOETSCHHOFER last edited by
        @goetschhofer sehr seltsam
        wie sieht es da aktuell aus?
        ls -lh /opt/iobroker/iobroker-data/backup-objects/ | grep objects
          @crunchip said in Proxmox: Fehlermeldung bei backup - vzdump ?:
          Dies habe ich soeben durchgeführt und wollte dir gleich psten: ☺
          -rw-rwxr--+ 1 iobroker iobroker 138K Dez 28 19:33 2023-12-28_19-33_states.json.g        z
          -rw-rwxr--+ 1 iobroker iobroker    0 Dez 29 07:39 2023-12-29_07-39_states.json.g
          Bei den objects ist mir nichts aufgefallen.
          Bei den states schaut es so aus:
          Objects type: file
          States  type: file
          karl@IOBROKER:/$ ls -lh /opt/iobroker/iobroker-data/backup-objects/ | grep objec        ts
          -rw-rwxr--+ 1 iobroker iobroker 3,8M Dez 28 07:17 2023-12-28_07-17_objects.json.        gz
          -rw-rwxr--+ 1 iobroker iobroker 3,8M Dez 28 10:33 2023-12-28_10-33_objects.json.        gz
          -rw-rwxr--+ 1 iobroker iobroker 3,8M Dez 28 12:55 2023-12-28_12-55_objects.json.        gz
          -rw-rwxr--+ 1 iobroker iobroker 3,8M Dez 29 07:38 2023-12-29_07-38_objects.json.        gz
          -rw-rwxr--+ 1 iobroker iobroker 3,4K Dez 29 07:53 2023-12-29_07-53_objects.json.        gz
          -rw-rwxr--+ 1 iobroker iobroker 3,4K Dez 29 08:01 2023-12-29_08-01_objects.json.        gz
          -rw-rwxr--+ 1 iobroker iobroker 3,4K Dez 29 08:54 2023-12-29_08-54_objects.json.        gz
          -rw-rwxr--+ 1 iobroker iobroker 3,4K Dez 29 09:05 2023-12-29_09-05_objects.json.        gz
          -rw-rwxr--+ 1 iobroker iobroker 3,4K Dez 29 09:38 2023-12-29_09-38_objects.json.        gz
          -rw-rwxr--+ 1 iobroker iobroker 3,4K Dez 29 09:42 2023-12-29_09-42_objects.json.        gz
          -rw-rwxr--+ 1 iobroker iobroker 3,4K Dez 29 09:43 2023-12-29_09-43_objects.json.        gz
          -rw-rwxr--+ 1 iobroker iobroker 3,6K Dez 29 11:53 2023-12-29_11-53_objects.json.        gz
          -rw-rwxr--+ 1 iobroker iobroker 3,6K Dez 29 11:58 2023-12-29_11-58_objects.json.        gz
          -rw-rwxr--+ 1 iobroker iobroker 3,6K Dez 29 12:02 2023-12-29_12-02_objects.json.        gz
          -rw-rwxr--+ 1 iobroker iobroker 3,6K Dez 29 13:04 2023-12-29_13-04_objects.json.        gz
          -rw-rwxr--+ 1 iobroker iobroker 3,6K Dez 29 13:27 2023-12-29_13-27_objects.json.        gz
          -rw-rwxr--+ 1 iobroker iobroker 3,8M Dez 29 13:29 2023-12-29_13-29_objects.json.        gz
          -rw-rwxr--+ 1 iobroker iobroker 3,8M Dez 29 13:40 2023-12-29_13-40_objects.json.        gz
          -rw-rwxr--+ 1 iobroker iobroker 3,8M Dez 29 13:56 2023-12-29_13-56_objects.json.        gz
          -rw-rwxr--+ 1 iobroker iobroker 3,8M Dez 29 14:07 2023-12-29_14-07_objects.json.        gz
          -rw-rwxr--+ 1 iobroker iobroker 3,8M Dez 29 15:08 2023-12-29_15-08_objects.json.        gz
          -rw-rwxr--+ 1 iobroker iobroker 3,8M Dez 29 15:46 2023-12-29_15-46_objects.json.        gz
          -rw-rwxr--+ 1 iobroker iobroker 1,8M Dez 29 15:49 2023-12-29_15-49_objects.json.        gz
          -rw-rwxr--+ 1 iobroker iobroker 3,6K Dez 29 15:59 2023-12-29_15-59_objects.json.        gz
          -rw-rw-r--+ 1 iobroker iobroker 3,6K Dez 29 16:05 2023-12-29_16-05_objects.json.        gz
          -rw-rw-r--+ 1 iobroker iobroker 3,6K Dez 29 16:12 2023-12-29_16-12_objects.json.        gz
          -rw-rw-r--+ 1 iobroker iobroker 3,6K Dez 29 16:14 2023-12-29_16-14_objects.json.        gz
          -rw-rw-r--+ 1 iobroker iobroker 3,6K Dez 29 16:18 2023-12-29_16-18_objects.json.        gz
          -rw-rw-r--+ 1 iobroker iobroker 3,8M Dez 30 06:41 2023-12-30_06-41_objects.json.        gz
          -rw-rw-r--+ 1 iobroker iobroker 3,8M Dez 30 07:03 2023-12-30_07-03_objects.json.        gz
          -rw-rw-r--+ 1 iobroker iobroker 3,5K Dez 30 07:09 2023-12-30_07-09_objects.json.        gz
          karl@IOBROKER:/$ ls -lh /opt/iobroker/iobroker-data/backup-objects/ | grep state        s
          -rw-rwxr--+ 1 iobroker iobroker 138K Dez 28 07:31 2023-12-28_07-31_states.json.g        z
          -rw-rwxr--+ 1 iobroker iobroker 138K Dez 28 09:31 2023-12-28_09-31_states.json.g        z
          -rw-rwxr--+ 1 iobroker iobroker 139K Dez 28 11:31 2023-12-28_11-31_states.json.g        z
          -rw-rwxr--+ 1 iobroker iobroker 138K Dez 28 13:32 2023-12-28_13-32_states.json.g        z
          -rw-rwxr--+ 1 iobroker iobroker 139K Dez 28 15:32 2023-12-28_15-32_states.json.g        z
          -rw-rwxr--+ 1 iobroker iobroker 138K Dez 28 17:33 2023-12-28_17-33_states.json.g        z
          -rw-rwxr--+ 1 iobroker iobroker    0 Dez 29 07:39 2023-12-29_07-39_states.json.g        z
          -rw-rwxr--+ 1 iobroker iobroker 138K Dez 29 07:53 2023-12-29_07-53_states.json.g        z
          -rw-rwxr--+ 1 iobroker iobroker 138K Dez 29 08:02 2023-12-29_08-02_states.json.g        z
          -rw-rwxr--+ 1 iobroker iobroker 138K Dez 29 08:54 2023-12-29_08-54_states.json.g        z
          -rw-rwxr--+ 1 iobroker iobroker 138K Dez 29 09:05 2023-12-29_09-05_states.json.g        z
          -rw-rwxr--+ 1 iobroker iobroker 138K Dez 29 09:39 2023-12-29_09-39_states.json.g        z
          -rw-rwxr--+ 1 iobroker iobroker 138K Dez 29 09:42 2023-12-29_09-42_states.json.g        z
          -rw-rwxr--+ 1 iobroker iobroker 138K Dez 29 09:44 2023-12-29_09-44_states.json.g        z
          -rw-rwxr--+ 1 iobroker iobroker 138K Dez 29 10:22 2023-12-29_10-22_states.json.g        z
          -rw-rwxr--+ 1 iobroker iobroker 139K Dez 29 10:27 2023-12-29_10-27_states.json.g        z
          -rw-rwxr--+ 1 iobroker iobroker 139K Dez 29 10:28 2023-12-29_10-28_states.json.g        z
          -rw-rwxr--+ 1 iobroker iobroker 139K Dez 29 11:53 2023-12-29_11-53_states.json.g        z
          -rw-rwxr--+ 1 iobroker iobroker 139K Dez 29 11:54 2023-12-29_11-54_states.json.g        z
          -rw-rwxr--+ 1 iobroker iobroker 139K Dez 29 11:58 2023-12-29_11-58_states.json.g        z
          -rw-rwxr--+ 1 iobroker iobroker 139K Dez 29 12:03 2023-12-29_12-03_states.json.g        z
          -rw-rwxr--+ 1 iobroker iobroker 139K Dez 29 13:05 2023-12-29_13-05_states.json.g        z
          -rw-rwxr--+ 1 iobroker iobroker 139K Dez 29 13:27 2023-12-29_13-27_states.json.g        z
          -rw-rwxr--+ 1 iobroker iobroker 139K Dez 29 13:30 2023-12-29_13-30_states.json.g        z
          -rw-rwxr--+ 1 iobroker iobroker 138K Dez 29 13:40 2023-12-29_13-40_states.json.g        z
          -rw-rwxr--+ 1 iobroker iobroker 138K Dez 29 13:57 2023-12-29_13-57_states.json.g        z
          -rw-rwxr--+ 1 iobroker iobroker 139K Dez 29 14:08 2023-12-29_14-08_states.json.g        z
          -rw-rwxr--+ 1 iobroker iobroker 138K Dez 29 15:08 2023-12-29_15-08_states.json.g        z
          -rw-rwxr--+ 1 iobroker iobroker 139K Dez 29 15:46 2023-12-29_15-46_states.json.g        z
          -rw-rwxr--+ 1 iobroker iobroker 139K Dez 29 16:00 2023-12-29_16-00_states.json.g        z
          -rw-rw-r--+ 1 iobroker iobroker 139K Dez 29 16:06 2023-12-29_16-06_states.json.g        z
          -rw-rw-r--+ 1 iobroker iobroker 139K Dez 29 16:13 2023-12-29_16-13_states.json.g        z
          -rw-rw-r--+ 1 iobroker iobroker 139K Dez 29 16:15 2023-12-29_16-15_states.json.g        z
          -rw-rw-r--+ 1 iobroker iobroker 139K Dez 29 16:19 2023-12-29_16-19_states.json.g        z
          -rw-rw-r--+ 1 iobroker iobroker 139K Dez 29 18:19 2023-12-29_18-19_states.json.g        z
          -rw-rw-r--+ 1 iobroker iobroker 139K Dez 29 20:19 2023-12-29_20-19_states.json.g        z
          -rw-rw-r--+ 1 iobroker iobroker 139K Dez 29 22:19 2023-12-29_22-19_states.json.g        z
          -rw-rw-r--+ 1 iobroker iobroker 139K Dez 30 00:19 2023-12-30_00-19_states.json.g        z
          -rw-rw-r--+ 1 iobroker iobroker 139K Dez 30 02:19 2023-12-30_02-19_states.json.g        z
          -rw-rw-r--+ 1 iobroker iobroker 139K Dez 30 04:19 2023-12-30_04-19_states.json.g        z
          -rw-rw-r--+ 1 iobroker iobroker 139K Dez 30 06:19 2023-12-30_06-19_states.json.g        z
          -rw-rw-r--+ 1 iobroker iobroker 139K Dez 30 06:42 2023-12-30_06-42_states.json.g        z
          -rw-rw-r--+ 1 iobroker iobroker 139K Dez 30 07:04 2023-12-30_07-04_states.json.g        z
          -rw-rw-r--+ 1 iobroker iobroker 139K Dez 30 07:09 2023-12-30_07-09_states.json.g        z
          karl@IOBROKER:/$ ^C
          karl@IOBROKER:/$ ^C
          karl@IOBROKER:/$
            @goetschhofer sagte in Proxmox: Fehlermeldung bei backup - vzdump ?:
            2023-12-30_07-03_objects.json.gz
            2023-12-30_07-09_states.json.gz
            dann führst du obiges erneut aus, mit diesen ersetzen, und dann mal nichts machen
              Führe ich so aus:
              iobroker stop
              cd /opt/iobroker/iobroker-data/
              mv objects.json objects.json.old
              mv states.json states.json.old
              cd backup-objects/
              gunzip -ck 2023-12-29_07-38_objects.json.gz > /opt/iobroker/iobroker-data/objects.json
              gunzip -ck 2023-12-28_19-33_states.json.gz > /opt/iobroker/iobroker-data/states.json
              iobroker start
                GOETSCHHOFER @GOETSCHHOFER last edited by GOETSCHHOFER
                @goetschhofer said in Proxmox: Fehlermeldung bei backup - vzdump ?:
                iobroker start
                Habe ich nun so ausgeführt:
                Ich sehe gerade bei den Dateien, welche ich reinkopiert habe, zeigt er unten nicht alles an, aber ich habe es wie oben dokumentiert hineinkopiert.
                login as: karl
                karl@192.168.1.176's password:
                Linux IOBROKER 4.19.0-25-amd64 #1 SMP Debian 4.19.289-2 (2023-08-08) x86_64
                The programs included with the Debian GNU/Linux system are free software;
                the exact distribution terms for each program are described in the
                individual files in /usr/share/doc/*/copyright.
                Debian GNU/Linux comes with ABSOLUTELY NO WARRANTY, to the extent
                permitted by applicable law.
                Last login: Sat Dec 30 07:47:27 2023 from 192.168.1.3
                karl@IOBROKER:~$ iobroker stop
                karl@IOBROKER:~$ cd /opt/iobroker/iobroker-data/
                karl@IOBROKER:/opt/iobroker/iobroker-data$ mv objects.json objects.json.old
                karl@IOBROKER:/opt/iobroker/iobroker-data$ mv states.json states.json.old
                karl@IOBROKER:/opt/iobroker/iobroker-data$ cd backup-objects/
                karl@IOBROKER:/opt/iobroker/iobroker-data/backup-objects$ gunzip -ck 2023-12-29_        07-38_objects.json.gz > /opt/iobroker/iobroker-data/objects.json
                karl@IOBROKER:/opt/iobroker/iobroker-data/backup-objects$ gunzip -ck 2023-12-28_        19-33_states.json.gz > /opt/iobroker/iobroker-data/states.json
                karl@IOBROKER:/opt/iobroker/iobroker-data/backup-objects$ iobroker start
                karl@IOBROKER:/opt/iobroker/iobroker-data/backup-objects$ cd ..
                karl@IOBROKER:/opt/iobroker/iobroker-data$ cd ..
                karl@IOBROKER:/opt/iobroker$ cd ..
                karl@IOBROKER:/opt$ cd ..
                karl@IOBROKER:/$ iobroker start
                karl@IOBROKER:/$
                  crunchip Forum Testing Most Active @GOETSCHHOFER last edited by crunchip
                  aber falsch, ich habe dir doch beide genannt
                  du solltest diese nehmen
                  und
                  iobroker stop
                  cd backup-objects/
                  gunzip -ck 2023-12-30_07-03_objects.json.gz > /opt/iobroker/iobroker-data/objects.json
                  gunzip -ck 2023-12-30_07-09_states.json.gz > /opt/iobroker/iobroker-data/states.json
                  iobroker start
                    iobroker start
                    Sorry, die files kennt er nicht.
                    login as: karl
                    Last login: Sat Dec 30 10:24:46 2023 from 192.168.1.3
                    karl@IOBROKER:/opt/iobroker/iobroker-data$ gunzip -ck 2023-12-30_07-03_objects.json.gz > /opt/iobroker/iobroker-data/objects.json                       gzip: 2023-12-30_07-03_objects.json.gz: No such file or directory
                    karl@IOBROKER:/opt/iobroker/iobroker-data$ gunzip -ck 2023-12-30_07-09_states.json.gz > /opt/iobroker/iobroker-data/states.json
                    gzip: 2023-12-30_07-09_states.json.gz: No such file or directory
                    Anbei die aktuelle Abfrage zu den OBJECTS mit:
                    karl@IOBROKER:/$ ls -lh /opt/iobroker/iobroker-data/backup-objects/ | grep objects
                    -rw-rwxr--+ 1 iobroker iobroker 3,8M Dez 28 10:33 2023-12-28_10-33_objects.json.gz
                    -rw-rwxr--+ 1 iobroker iobroker 3,8M Dez 28 12:55 2023-12-28_12-55_objects.json.gz
                    -rw-rwxr--+ 1 iobroker iobroker 3,8M Dez 29 07:38 2023-12-29_07-38_objects.json.gz
                    -rw-rwxr--+ 1 iobroker iobroker 3,4K Dez 29 07:53 2023-12-29_07-53_objects.json.gz
                    -rw-rwxr--+ 1 iobroker iobroker 3,4K Dez 29 08:01 2023-12-29_08-01_objects.json.gz
                    -rw-rwxr--+ 1 iobroker iobroker 3,4K Dez 29 08:54 2023-12-29_08-54_objects.json.gz
                    -rw-rwxr--+ 1 iobroker iobroker 3,4K Dez 29 09:05 2023-12-29_09-05_objects.json.gz
                    -rw-rwxr--+ 1 iobroker iobroker 3,4K Dez 29 09:38 2023-12-29_09-38_objects.json.gz
                    -rw-rwxr--+ 1 iobroker iobroker 3,4K Dez 29 09:42 2023-12-29_09-42_objects.json.gz
                    -rw-rwxr--+ 1 iobroker iobroker 3,4K Dez 29 09:43 2023-12-29_09-43_objects.json.gz
                    -rw-rwxr--+ 1 iobroker iobroker 3,6K Dez 29 11:53 2023-12-29_11-53_objects.json.gz
                    -rw-rwxr--+ 1 iobroker iobroker 3,6K Dez 29 11:58 2023-12-29_11-58_objects.json.gz
                    -rw-rwxr--+ 1 iobroker iobroker 3,6K Dez 29 12:02 2023-12-29_12-02_objects.json.gz
                    -rw-rwxr--+ 1 iobroker iobroker 3,6K Dez 29 13:04 2023-12-29_13-04_objects.json.gz
                    -rw-rwxr--+ 1 iobroker iobroker 3,6K Dez 29 13:27 2023-12-29_13-27_objects.json.gz
                    -rw-rwxr--+ 1 iobroker iobroker 3,8M Dez 29 13:29 2023-12-29_13-29_objects.json.gz
                    -rw-rwxr--+ 1 iobroker iobroker 3,8M Dez 29 13:40 2023-12-29_13-40_objects.json.gz
                    -rw-rwxr--+ 1 iobroker iobroker 3,8M Dez 29 13:56 2023-12-29_13-56_objects.json.gz
                    -rw-rwxr--+ 1 iobroker iobroker 3,8M Dez 29 14:07 2023-12-29_14-07_objects.json.gz
                    -rw-rwxr--+ 1 iobroker iobroker 3,8M Dez 29 15:08 2023-12-29_15-08_objects.json.gz
                    -rw-rwxr--+ 1 iobroker iobroker 3,8M Dez 29 15:46 2023-12-29_15-46_objects.json.gz
                    -rw-rwxr--+ 1 iobroker iobroker 1,8M Dez 29 15:49 2023-12-29_15-49_objects.json.gz
                    -rw-rwxr--+ 1 iobroker iobroker 3,6K Dez 29 15:59 2023-12-29_15-59_objects.json.gz
                    -rw-rw-r--+ 1 iobroker iobroker 3,6K Dez 29 16:05 2023-12-29_16-05_objects.json.gz
                    -rw-rw-r--+ 1 iobroker iobroker 3,6K Dez 29 16:12 2023-12-29_16-12_objects.json.gz
                    -rw-rw-r--+ 1 iobroker iobroker 3,6K Dez 29 16:14 2023-12-29_16-14_objects.json.gz
                    -rw-rw-r--+ 1 iobroker iobroker 3,6K Dez 29 16:18 2023-12-29_16-18_objects.json.gz
                    -rw-rw-r--+ 1 iobroker iobroker 3,8M Dez 30 06:41 2023-12-30_06-41_objects.json.gz
                    -rw-rw-r--+ 1 iobroker iobroker 3,8M Dez 30 07:03 2023-12-30_07-03_objects.json.gz
                    -rw-rw-r--+ 1 iobroker iobroker 3,5K Dez 30 07:09 2023-12-30_07-09_objects.json.gz
                    -rw-rw-r--+ 1 iobroker iobroker 3,8M Dez 30 10:10 2023-12-30_10-10_objects.json.gz
                    karl@IOBROKER:/$
                    Anbei die aktuelle Abfrage zu den STATES mit:
                    ls -lh /opt/iobroker/iobroker-data/backup-objects/ | grep states
                    karl@IOBROKER:/$ ls -lh /opt/iobroker/iobroker-data/backup-objects/ | grep states
                    -rw-rwxr--+ 1 iobroker iobroker 139K Dez 28 11:31 2023-12-28_11-31_states.json.gz
                    -rw-rwxr--+ 1 iobroker iobroker 138K Dez 28 13:32 2023-12-28_13-32_states.json.gz
                    -rw-rwxr--+ 1 iobroker iobroker 139K Dez 28 15:32 2023-12-28_15-32_states.json.gz
                    -rw-rwxr--+ 1 iobroker iobroker 138K Dez 28 17:33 2023-12-28_17-33_states.json.gz
                    -rw-rwxr--+ 1 iobroker iobroker 138K Dez 28 19:33 2023-12-28_19-33_states.json.gz
                    -rw-rwxr--+ 1 iobroker iobroker    0 Dez 29 07:39 2023-12-29_07-39_states.json.gz
                    -rw-rwxr--+ 1 iobroker iobroker 138K Dez 29 07:53 2023-12-29_07-53_states.json.gz
                    -rw-rwxr--+ 1 iobroker iobroker 138K Dez 29 08:02 2023-12-29_08-02_states.json.gz
                    -rw-rwxr--+ 1 iobroker iobroker 138K Dez 29 08:54 2023-12-29_08-54_states.json.gz
                    -rw-rwxr--+ 1 iobroker iobroker 138K Dez 29 09:05 2023-12-29_09-05_states.json.gz
                    -rw-rwxr--+ 1 iobroker iobroker 138K Dez 29 09:39 2023-12-29_09-39_states.json.gz
                    -rw-rwxr--+ 1 iobroker iobroker 138K Dez 29 09:42 2023-12-29_09-42_states.json.gz
                    -rw-rwxr--+ 1 iobroker iobroker 138K Dez 29 09:44 2023-12-29_09-44_states.json.gz
                    -rw-rwxr--+ 1 iobroker iobroker 138K Dez 29 10:22 2023-12-29_10-22_states.json.gz
                    -rw-rwxr--+ 1 iobroker iobroker 139K Dez 29 10:27 2023-12-29_10-27_states.json.gz
                    -rw-rwxr--+ 1 iobroker iobroker 139K Dez 29 10:28 2023-12-29_10-28_states.json.gz
                    -rw-rwxr--+ 1 iobroker iobroker 139K Dez 29 11:53 2023-12-29_11-53_states.json.gz
                    -rw-rwxr--+ 1 iobroker iobroker 139K Dez 29 11:54 2023-12-29_11-54_states.json.gz
                    -rw-rwxr--+ 1 iobroker iobroker 139K Dez 29 11:58 2023-12-29_11-58_states.json.gz
                    -rw-rwxr--+ 1 iobroker iobroker 139K Dez 29 12:03 2023-12-29_12-03_states.json.gz
                    -rw-rwxr--+ 1 iobroker iobroker 139K Dez 29 13:05 2023-12-29_13-05_states.json.gz
                    -rw-rwxr--+ 1 iobroker iobroker 139K Dez 29 13:27 2023-12-29_13-27_states.json.gz
                    -rw-rwxr--+ 1 iobroker iobroker 139K Dez 29 13:30 2023-12-29_13-30_states.json.gz
                    -rw-rwxr--+ 1 iobroker iobroker 138K Dez 29 13:40 2023-12-29_13-40_states.json.gz
                    -rw-rwxr--+ 1 iobroker iobroker 138K Dez 29 13:57 2023-12-29_13-57_states.json.gz
                    -rw-rwxr--+ 1 iobroker iobroker 139K Dez 29 14:08 2023-12-29_14-08_states.json.gz
                    -rw-rwxr--+ 1 iobroker iobroker 138K Dez 29 15:08 2023-12-29_15-08_states.json.gz
                    -rw-rwxr--+ 1 iobroker iobroker 139K Dez 29 15:46 2023-12-29_15-46_states.json.gz
                    -rw-rwxr--+ 1 iobroker iobroker 139K Dez 29 16:00 2023-12-29_16-00_states.json.gz
                    -rw-rw-r--+ 1 iobroker iobroker 139K Dez 29 16:06 2023-12-29_16-06_states.json.gz
                    -rw-rw-r--+ 1 iobroker iobroker 139K Dez 29 16:13 2023-12-29_16-13_states.json.gz
                    -rw-rw-r--+ 1 iobroker iobroker 139K Dez 29 16:15 2023-12-29_16-15_states.json.gz
                    -rw-rw-r--+ 1 iobroker iobroker 139K Dez 29 16:19 2023-12-29_16-19_states.json.gz
                    -rw-rw-r--+ 1 iobroker iobroker 139K Dez 29 18:19 2023-12-29_18-19_states.json.gz
                    -rw-rw-r--+ 1 iobroker iobroker 139K Dez 29 20:19 2023-12-29_20-19_states.json.gz
                    -rw-rw-r--+ 1 iobroker iobroker 139K Dez 29 22:19 2023-12-29_22-19_states.json.gz
                    -rw-rw-r--+ 1 iobroker iobroker 139K Dez 30 00:19 2023-12-30_00-19_states.json.gz
                    -rw-rw-r--+ 1 iobroker iobroker 139K Dez 30 02:19 2023-12-30_02-19_states.json.gz
                    -rw-rw-r--+ 1 iobroker iobroker 139K Dez 30 04:19 2023-12-30_04-19_states.json.gz
                    -rw-rw-r--+ 1 iobroker iobroker 139K Dez 30 06:19 2023-12-30_06-19_states.json.gz
                    -rw-rw-r--+ 1 iobroker iobroker 139K Dez 30 06:42 2023-12-30_06-42_states.json.gz
                    -rw-rw-r--+ 1 iobroker iobroker 139K Dez 30 07:04 2023-12-30_07-04_states.json.gz
                    -rw-rw-r--+ 1 iobroker iobroker 139K Dez 30 07:09 2023-12-30_07-09_states.json.gz
                    -rw-rw-r--+ 1 iobroker iobroker 139K Dez 30 09:10 2023-12-30_09-10_states.json.gz
                    -rw-rw-r--+ 1 iobroker iobroker 139K Dez 30 10:11 2023-12-30_10-11_states.json.gz
                    karl@IOBROKER:/$
                      komisch, ist doch eigentlich da, aber egal
                      dann wäre der nächste Schritt deine Adapter auf Stand zu bringen, damit du anschließend den controller updaten kannst und anschließend hoffen, das die Datenbank bestehen bleibt😁
                      du hast noch einige Adapter aus Git installiert
                      Ausgabe von
                      iob update
                        iob update
                        Wie soll ich die adapter auf Stand bringen, ich kann ja über die WEBUI nicht auf den iobroker ?
                        Soll ich in proxmox ein backup machen ?
                        karl@IOBROKER:/$ iob update
                        Server Cannot load /opt/iobroker/iobroker-data/objects.json: /opt/iobroker/iobroker-data/objects.json: Unexpected end of JSON input. Try last Backup!
                        Server Cannot load /opt/iobroker/iobroker-data/states.json: /opt/iobroker/iobroker-data/states.json: Unexpected end of JSON input. Try last Backup!
                        Used repository: Stable (default)
                        hash changed or no sources cached => force download of new sources
                        Cannot get any information of "_repoInfo". Ignored.
                        update done
                        Adapter    "accuweather"   : 1.3.2
                        Adapter    "acme"          : 0.1.2
                        Adapter    "adb"           : 0.0.7
                        Adapter    "adguard"       : 0.0.8
                        Adapter    "admin"         : 6.12.0   , installed 5.1.23 [Updateable]
                        Adapter    "aio"           : 0.1.1
                        Adapter    "airconwithme"  : 0.0.4
                        Adapter    "airzone"       : 2.0.3
                        Adapter    "alarm"         : 3.4.3
                        Adapter    "alexa-shoppinglist": 0.1.5
                        Adapter    "alexa-timer-vis": 0.2.0
                        Adapter    "alexa2"        : 3.26.3
                        Adapter    "alias-manager" : 1.2.6
                        Adapter    "alpha-ess"     : 2.0.0
                        Adapter    "alpha2"        : 1.0.0
                        Adapter    "amazon-dash"   : 1.2.0
                        Adapter    "anelhut"       : 1.0.15
                        Adapter    "apcups"        : 1.0.15
                        Adapter    "apg-info"      : 0.1.0
                        Adapter    "artnet"        : 1.2.2
                        Adapter    "asterisk"      : 1.0.6
                        Adapter    "asuswrt"       : 1.0.1
                        Adapter    "atlas-scientific-ezo-i2c": 2.3.0
                        Adapter    "awattar"       : 1.0.6    , installed 1.0.6
                        Adapter    "awtrix-light"  : 0.10.0
                        Adapter    "b-control-em"  : 0.3.1    , installed 0.2.1 [Updateable]
                        Adapter    "backitup"      : 2.9.8    , installed 2.1.17 [Updateable]
                        Adapter    "beckhoff"      : 1.5.3
                        Adapter    "benchmark"     : 1.1.4
                        Adapter    "benq"          : 0.2.5
                        Adapter    "bestway"       : 0.0.4
                        Adapter    "bidirectional-counter": 2.1.3
                        Adapter    "birthdays"     : 2.4.1
                        Adapter    "ble"           : 0.13.4
                        Adapter    "blebox"        : 2.1.0
                        Adapter    "bluelink"      : 2.3.6
                        Adapter    "bmw"           : 2.5.7
                        Adapter    "bosch-ebike"   : 0.0.3
                        Adapter    "bosesoundtouch": 0.10.3
                        Adapter    "botslab360"    : 0.0.2
                        Adapter    "botvac"        : 2.0.1
                        Adapter    "bring"         : 1.8.4
                        Adapter    "broadlink2"    : 2.1.5
                        Adapter    "bsblan"        : 0.3.1
                        Adapter    "bshb"          : 0.2.6
                        Adapter    "bwt"           : 0.0.5
                        Adapter    "bydbatt"       : 1.1.0
                        Adapter    "bydhvs"        : 1.5.0
                        Adapter    "canbus"        : 1.3.1    , installed 1.3.1
                        Adapter    "cec2"          : 0.1.1
                        Adapter    "chromecast"    : 3.0.3    , installed 2.3.1 [Updateable]
                        Adapter    "cleveron"      : 0.0.6
                        Adapter    "cloud"         : 4.4.1    , installed 4.1.0 [Updateable]
                        Adapter    "cloudflare"    : 1.1.1
                        Adapter    "comfoair"      : 1.1.8
                        Adapter    "contactid"     : 1.0.2
                        Adapter    "coronavirus-statistics": 0.9.0
                        Adapter    "countdown"     : 2.2.0
                        Adapter    "cul"           : 2.2.0
                        Adapter    "daikin"        : 1.4.2
                        Adapter    "daikin-cloud"  : 0.3.0
                        Adapter    "daswetter"     : 3.1.11   , installed 3.0.7 [Updateable]
                        Adapter    "deconz"        : 1.3.23
                        Adapter    "denon"         : 1.15.4
                        Adapter    "device-reminder": 3.0.0
                        Adapter    "device-watcher": 2.9.6
                        Adapter    "devices"       : 1.1.5
                        Adapter    "deyeidc"       : 0.0.14
                        Adapter    "digitalstrom"  : 2.3.0
                        Adapter    "discord"       : 2.2.0
                        Adapter    "discovergy"    : 0.5.13
                        Adapter    "discovery"     : 4.2.0    , installed 2.6.2 [Updateable]
                        Adapter    "divera247"     : 0.2.0
                        Adapter    "doorbird"      : 1.3.0
                        Adapter    "doorio"        : 2.1.4
                        Adapter    "drag-indicator": 2.1.4
                        Adapter    "ds18b20"       : 2.0.5
                        Adapter    "dwd"           : 2.8.5    , installed 2.7.5 [Updateable]
                        Adapter    "dysonairpurifier": 2.5.9
                        Adapter    "e3dc-rscp"     : 1.2.5
                        Adapter    "easee"         : 1.0.10
                        Adapter    "ebus"          : 3.2.4
                        Adapter    "echarts"       : 1.5.4    , installed 0.4.13 [Updateable]
                        Adapter    "ecovacs-deebot": 1.4.13
                        Adapter    "egigeozone"    : 0.1.2
                        Adapter    "ekey"          : 1.2.3
                        Adapter    "elero-usb-transmitter": 0.5.2
                        Adapter    "email"         : 1.2.1    , installed 1.0.10 [Updateable]
                        Adapter    "emby"          : 1.1.1
                        Adapter    "emporia"       : 0.0.12
                        Adapter    "ems-esp"       : 2.6.2
                        Adapter    "energymanager" : 1.4.2
                        Adapter    "enet"          : 1.0.1
                        Adapter    "enigma2"       : 2.0.5
                        Adapter    "envertech-pv"  : 1.1.0
                        Adapter    "epson_ecotank_et_2750": 0.0.12
                        Adapter    "epson_stylus_px830": 0.2.1
                        Adapter    "epson_xp540"   : 1.0.6
                        Adapter    "eusec"         : 1.2.1
                        Adapter    "evcc"          : 0.0.10
                        Adapter    "eventlist"     : 2.0.0
                        Adapter    "exchangerates" : 0.0.14
                        Adapter    "fahrplan"      : 1.2.3
                        Adapter    "fakeroku"      : 0.2.2
                        Adapter    "fb-checkpresence": 1.2.2
                        Adapter    "feiertage"     : 1.1.4
                        Adapter    "fhem"          : 2.0.5    , installed 1.6.0 [Updateable]
                        Adapter    "fiat"          : 0.0.8
                        Adapter    "firetv"        : 2.0.2
                        Adapter    "fitbit-fitness": 0.5.0
                        Adapter    "flot"          : 1.12.0   , installed 1.10.6 [Updateable]
                        Adapter    "followthesun"  : 0.5.0    , installed 0.3.4 [Updateable]
                        Adapter    "foobar2000"    : 2.1.0
                        Adapter    "ford"          : 0.0.14
                        Adapter    "frigate"       : 0.2.7
                        Adapter    "fritzbox"      : 0.5.0
                        Adapter    "fritzdect"     : 2.5.9    , installed 2.1.15 [Updateable]
                        Adapter    "froeling"      : 0.0.8
                        Adapter    "fronius"       : 2.0.2    , installed 1.1.6 [Updateable]
                        Adapter    "fronius-solarweb": 0.0.3
                        Adapter    "fronius-wattpilot": 4.6.2
                        Adapter    "frontier_silicon": 0.1.1
                        Adapter    "fuelpricemonitor": 0.4.0
                        Adapter    "fullcalendar"  : 2.2.6
                        Adapter    "fullybrowser"  : 3.0.6
                        Adapter    "g-homa"        : 0.5.3
                        Adapter    "garmin"        : 0.0.3
                        Adapter    "geofency"      : 1.2.4
                        Adapter    "gigaset-elements": 0.4.3
                        Adapter    "gira-iot"      : 0.4.0
                        Adapter    "go-e"          : 1.0.29
                        Adapter    "govee-local"   : 0.1.2
                        Adapter    "growatt"       : 3.2.1
                        Adapter    "gruenbeck"     : 0.0.42
                        Adapter    "gsmsms"        : 0.0.6
                        Adapter    "haassohn"      : 1.0.9
                        Adapter    "habpanel"      : 0.5.0    , installed 0.4.3 [Updateable]
                        Adapter    "haier"         : 1.0.4
                        Adapter    "ham"           : 5.3.1
                        Adapter    "ham-wemo"      : 3.0.2
                        Adapter    "harmony"       : 1.3.0
                        Adapter    "hass"          : 1.4.0
                        Adapter    "hausbus_de"    : 1.2.12
                        Adapter    "heatingcontrol": 2.11.1
                        Adapter    "heizoel"       : 1.0.3
                        Adapter    "heizungssteuerung": 1.7.0
                        Adapter    "hekr"          : 0.0.6
                        Adapter    "helios"        : 0.0.3
                        Adapter    "heos"          : 2.1.0
                        Adapter    "heytech"       : 1.0.6
                        Adapter    "hid-community" : 0.3.0
                        Adapter    "hikvision-alarmserver": 0.1.0
                        Adapter    "history"       : 3.0.1
                        Adapter    "hm-rega"       : 4.0.0
                        Adapter    "hm-rpc"        : 1.15.19
                        Adapter    "hmip"          : 1.20.0
                        Adapter    "homeconnect"   : 1.1.1
                        Adapter    "homee"         : 1.2.0
                        Adapter    "homekit-controller": 0.5.8   , installed 0.3.3 [Updateable]
                        Adapter    "homenet"       : 0.0.2
                        Adapter    "homepilot"     : 1.1.6
                        Adapter    "hoover"        : 0.0.7
                        Adapter    "hp-ilo"        : 1.0.6
                        Adapter    "hs100"         : 2.2.0    , installed 2.0.3 [Updateable]
                        Adapter    "hue"           : 3.10.1
                        Adapter    "huum-sauna"    : 0.4.5
                        Adapter    "i2c"           : 1.2.1
                        Adapter    "ical"          : 1.13.3
                        Adapter    "iceroad"       : 1.2.1
                        Adapter    "ico-cloud"     : 1.1.0
                        Adapter    "icons-addictive-flavour-png": 0.1.0
                        Adapter    "icons-eclipse-smarthome-classic": 1.0.0
                        Adapter    "icons-fatcow-hosting": 0.1.0
                        Adapter    "icons-freepic" : 1.0.0
                        Adapter    "icons-icons8"  : 0.0.1    , installed 0.0.1
                        Adapter    "icons-material-png": 0.1.0
                        Adapter    "icons-material-svg": 0.1.0
                        Adapter    "icons-mfd-png" : 1.2.1
                        Adapter    "icons-mfd-svg" : 1.1.0
                        Adapter    "icons-open-icon-library-png": 0.1.2
                        Adapter    "icons-smarthome": 1.0.0
                        Adapter    "icons-ultimate-png": 1.0.1
                        Adapter    "ikettle2"      : 1.0.1
                        Adapter    "imap"          : 0.1.1
                        Adapter    "imow"          : 0.0.2
                        Adapter    "influxdb"      : 3.2.0    , installed 1.9.5 [Updateable]
                        Adapter    "info"          : 2.0.0    , installed 1.9.8 [Updateable]
                        Adapter    "innogy-smarthome": 1.2.6
                        Adapter    "innoxel"       : 0.3.1
                        Adapter    "intex"         : 0.1.5
                        Adapter    "iot"           : 2.0.11   , installed 1.8.22 [Updateable]
                        Adapter    "iqontrol"      : 2.3.0    , installed 1.6.4 [Updateable]
                        Adapter    "iwg-vpn"       : 2.0.5
                        Adapter    "janitza-gridvis": 3.1.8
                        Adapter    "jarvis"        : 3.1.8
                        Adapter    "javascript"    : 7.1.6    , installed 5.1.3 [Updateable]
                        Adapter    "jeelink"       : 1.2.3
                        Controller "js-controller" : 5.0.17   , installed 3.2.16 [Updateable]
                        Adapter    "judoisoft"     : 1.1.0
                        Adapter    "kecontact"     : 2.0.2
                        Adapter    "klf200"        : 1.1.2
                        Adapter    "km200"         : 2.0.3
                        Adapter    "knmi-weather"  : 1.0.2
                        Adapter    "knx"           : 2.0.24
                        Adapter    "kodi"          : 3.0.0
                        Adapter    "kostal-piko-ba": 3.0.9
                        Adapter    "lametric"      : 3.1.1
                        Adapter    "landroid"      : 1.0.3
                        Adapter    "lcn"           : 1.1.1
                        Adapter    "legrand-ecocompteur": 1.0.0
                        Adapter    "letrika_comgw" : 0.0.6
                        Adapter    "lg-ess-home"   : 0.2.3
                        Adapter    "lg-thinq"      : 0.1.4
                        Adapter    "lgtv"          : 2.1.2
                        Adapter    "lgtv-rs"       : 0.1.1
                        Adapter    "lgtv11"        : 1.0.5
                        Adapter    "libre"         : 0.0.4
                        Adapter    "lifx"          : 1.0.4
                        Adapter    "lightcontrol"  : 0.4.0
                        Adapter    "lightify"      : 0.2.16
                        Adapter    "link"          : 0.5.12
                        Adapter    "link2home"     : 0.0.1
                        Adapter    "linkeddevices" : 1.5.5
                        Adapter    "linktap"       : 0.3.0
                        Adapter    "linux-control" : 1.1.5
                        Adapter    "logparser"     : 2.2.0    , installed 1.1.0 [Updateable]
                        Adapter    "loqed"         : 0.3.1
                        Adapter    "lovelace"      : 3.0.1
                        Adapter    "lowpass-filter": 2.2.3
                        Adapter    "loxone"        : 3.0.1
                        Adapter    "luftdaten"     : 3.1.0
                        Adapter    "lupusec"       : 1.3.6
                        Adapter    "luxtronik1"    : 0.3.5
                        Adapter    "material"      : 1.3.1
                        Adapter    "matrix-org"    : 1.0.0
                        Adapter    "maveo"         : 0.0.5
                        Adapter    "maxcube"       : 1.0.4
                        Adapter    "maxcul"        : 1.3.1
                        Adapter    "mbus"          : 2.6.1    , installed 2.4.0 [Updateable]
                        Adapter    "mclighting"    : 0.1.2
                        Adapter    "meater"        : 1.0.2
                        Adapter    "mediola-gateway": 1.0.1
                        Adapter    "megad"         : 1.2.1
                        Adapter    "megadd"        : 0.2.0
                        Adapter    "megaesp"       : 0.1.0
                        Adapter    "melcloud"      : 1.3.6
                        Adapter    "mercedesme"    : 0.1.1
                        Adapter    "mercury"       : 0.1.6
                        Adapter    "meross"        : 1.16.1
                        Adapter    "meteoalarm"    : 2.3.7
                        Adapter    "micronova"     : 0.0.2
                        Adapter    "midea"         : 0.0.7
                        Adapter    "miele"         : 0.1.5
                        Adapter    "mielecloudservice": 6.5.4
                        Adapter    "mihome"        : 1.4.0
                        Adapter    "mihome-cloud"  : 0.1.0
                        Adapter    "mihome-lamp"   : 1.1.0
                        Adapter    "mihome-plug"   : 0.2.1
                        Adapter    "mihome-vacuum" : 4.1.0
                        Adapter    "mikrotik"      : 1.1.1
                        Adapter    "milight"       : 0.4.0
                        Adapter    "milight-smart-light": 1.2.2
                        Adapter    "minuvis"       : 2.3.3
                        Adapter    "mobile"        : 1.0.1
                        Adapter    "modbus"        : 6.0.1    , installed 3.4.14 [Updateable]
                        Adapter    "moma"          : 1.2.9
                        Adapter    "mpd"           : 1.1.1
                        Adapter    "mqtt"          : 5.1.0    , installed 2.4.0 [Updateable]
                        Adapter    "mqtt-client"   : 1.7.0    , installed 1.4.0 [Updateable]
                        Adapter    "musiccast"     : 1.1.3
                        Adapter    "mydlink"       : 1.3.5
                        Adapter    "myenergi"      : 0.0.3
                        Adapter    "mysensors"     : 3.0.0
                        Adapter    "mystrom"       : 0.0.14
                        Adapter    "myvbus"        : 0.2.5
                        Adapter    "nanoleaf-lightpanels": 1.4.0
                        Adapter    "net-tools"     : 0.2.0
                        Adapter    "netatmo"       : 3.1.0
                        Adapter    "netatmo-crawler": 0.8.1
                        Adapter    "netatmo-energy": 2.7.0
                        Adapter    "nibeuplink"    : 1.3.0
                        Adapter    "nina"          : 0.0.25
                        Adapter    "nissan"        : 0.0.12
                        Adapter    "niu"           : 0.0.3
                        Adapter    "node-red"      : 4.0.3    , installed 2.4.0 [Updateable]
                        Adapter    "notification-manager": 1.0.0
                        Adapter    "nsclient"      : 0.2.2
                        Adapter    "nuki"          : 1.6.0
                        Adapter    "nuki-extended" : 2.6.5
                        Adapter    "nut"           : 1.6.0
                        Adapter    "ocpp"          : 0.12.5
                        Adapter    "octoprint"     : 5.1.0
                        Adapter    "odl"           : 3.0.1
                        Adapter    "oekofen-json"  : 1.0.5
                        Adapter    "oilfox"        : 4.2.0
                        Adapter    "omnicomm-lls"  : 0.0.7
                        Adapter    "onkyo"         : 2.1.2
                        Adapter    "onvif"         : 1.1.1
                        Adapter    "opendtu"       : 1.0.1
                        Adapter    "openhab"       : 1.1.0
                        Adapter    "openknx"       : 0.6.3
                        Adapter    "openligadb"    : 1.2.4
                        Adapter    "openweathermap": 0.4.5    , installed 0.1.0 [Updateable]
                        Adapter    "operating-hours": 1.0.6
                        Adapter    "opi"           : 0.1.2
                        Adapter    "oppoplayer"    : 0.2.4
                        Adapter    "owfs"          : 0.7.0
                        Adapter    "owntracks"     : 1.0.5
                        Adapter    "panasonic-comfort-cloud": 2.2.4
                        Adapter    "panasonic-viera": 2.0.0
                        Adapter    "parcel"        : 0.0.27
                        Adapter    "parser"        : 2.0.7    , installed 1.0.7 [Updateable]
                        Adapter    "paw"           : 0.3.2
                        Adapter    "pegelalarm"    : 1.3.2
                        Adapter    "ph803w"        : 1.1.1
                        Adapter    "phantomjs"     : 1.1.3
                        Adapter    "philips-air"   : 1.0.3
                        Adapter    "philips-tv"    : 0.5.3
                        Adapter    "pi-hole"       : 1.3.6
                        Adapter    "piface"        : 1.0.0
                        Adapter    "pimatic"       : 0.3.2
                        Adapter    "ping"          : 1.6.2    , installed 1.4.12 [Updateable]
                        Adapter    "pixelit"       : 1.1.3
                        Adapter    "places"        : 1.1.2
                        Adapter    "plenticore"    : 2.2.0
                        Adapter    "plex"          : 1.1.4
                        Adapter    "plexconnect"   : 0.0.7
                        Adapter    "pollenflug"    : 1.0.6
                        Adapter    "porsche"       : 0.0.3
                        Adapter    "powerfox2"     : 0.0.14
                        Adapter    "procon-ip"     : 1.5.1
                        Adapter    "proxmox"       : 2.2.2    , installed 1.3.3 [Updateable]
                        Adapter    "proxy"         : 1.3.2
                        Adapter    "psa"           : 0.0.11
                        Adapter    "puppeteer"     : 0.2.7
                        Adapter    "pushbullet"    : 2.0.1
                        Adapter    "pushover"      : 3.0.6
                        Adapter    "pushsafer"     : 1.0.3
                        Adapter    "pvforecast"    : 2.9.0
                        Adapter    "pvoutputorg"   : 1.8.10
                        Adapter    "pylontech"     : 0.0.7
                        Adapter    "radar2"        : 2.1.0
                        Adapter    "radiohead"     : 1.3.0
                        Adapter    "rct"           : 1.2.2
                        Adapter    "renacidc"      : 0.0.6
                        Adapter    "renault"       : 0.0.15
                        Adapter    "reolink"       : 1.0.2
                        Adapter    "residents"     : 0.1.1
                        Adapter    "resol"         : 1.3.0
                        Adapter    "rest-api"      : 1.1.0
                        Adapter    "rflink"        : 2.1.6
                        Adapter    "rickshaw"      : 1.0.0
                        Adapter    "ring"          : 5.0.10
                        Adapter    "robonect"      : 1.3.4
                        Adapter    "roborock"      : 0.4.4
                        Adapter    "roomba"        : 1.2.2
                        Adapter    "rpi2"          : 1.3.2
                        Adapter    "rssfeed"       : 2.6.1
                        Adapter    "s7"            : 1.3.15
                        Adapter    "sainlogic"     : 0.10.5
                        Adapter    "samsung"       : 0.5.11
                        Adapter    "samsung_tizen" : 1.0.0
                        Adapter    "sanext"        : 0.0.5
                        Adapter    "sayit"         : 3.0.5
                        Adapter    "sbfspot"       : 4.1.7
                        Adapter    "scenes"        : 2.3.9
                        Adapter    "scheduler"     : 1.1.9
                        Adapter    "schoolfree"    : 1.1.3
                        Adapter    "schwoerer-ventcube": 1.4.2
                        Adapter    "seko"          : 0.0.1
                        Adapter    "selverf"       : 0.6.3
                        Adapter    "semp"          : 1.3.13
                        Adapter    "seq"           : 0.3.0
                        Adapter    "shelly"        : 6.6.1    , installed 4.0.7 [Updateable]
                        Adapter    "shuttercontrol": 1.6.3
                        Adapter    "sia"           : 1.0.4
                        Adapter    "siegenia"      : 1.1.1
                        Adapter    "signal-cmb"    : 0.3.0
                        Adapter    "signifylights" : 0.3.1
                        Adapter    "simple-api"    : 2.7.2    , installed 2.6.1 [Updateable]
                        Adapter    "sma-em"        : 1.0.0
                        Adapter    "smappee"       : 0.2.6
                        Adapter    "smart-eq"      : 0.0.4    , installed 0.0.2 [Updateable]
                        Adapter    "smartcontrol"  : 2.0.1
                        Adapter    "smartgarden"   : 2.0.0
                        Adapter    "smartmeter"    : 3.4.0    , installed 3.2.1 [Updateable]
                        Adapter    "smartthings"   : 0.0.4
                        Adapter    "snips"         : 1.5.1
                        Adapter    "snmp"          : 3.1.0
                        Adapter    "socketio"      : 6.6.0    , installed 3.1.4 [Updateable]
                        Adapter    "solarlog"      : 2.2.8
                        Adapter    "solarmanpv"    : 0.5.1
                        Adapter    "solarviewdatareader": 1.0.7
                        Adapter    "solarwetter"   : 1.1.5
                        Adapter    "solax"         : 0.8.0
                        Adapter    "sonnen"        : 1.16.0
                        Adapter    "sonoff"        : 3.0.3    , installed 2.5.1 [Updateable]
                        Adapter    "sonos"         : 3.0.0
                        Adapter    "sony-bravia"   : 1.0.9
                        Adapter    "spotify-premium": 1.3.1
                        Adapter    "sprinklecontrol": 0.2.13
                        Adapter    "sql"           : 2.2.0
                        Adapter    "squeezeboxrpc" : 1.3.9
                        Adapter    "starline"      : 1.1.3
                        Adapter    "statistics"    : 2.4.0
                        Adapter    "stiebel-isg"   : 1.7.7
                        Adapter    "sureflap"      : 1.2.1
                        Adapter    "swiss-weather-api": 2.0.3
                        Adapter    "synochat"      : 1.3.1
                        Adapter    "synology"      : 3.0.1
                        Adapter    "systeminfo"    : 1.1.0
                        Adapter    "tado"          : 0.4.12
                        Adapter    "tahoma"        : 0.10.2
                        Adapter    "tankerkoenig"  : 3.3.7
                        Adapter    "tapo"          : 0.0.8
                        Adapter    "telegram"      : 3.0.1
                        Adapter    "telegram-menu" : 1.5.1
                        Adapter    "terminal"      : 1.0.0
                        Adapter    "tesla-motors"  : 1.3.2
                        Adapter    "text2command"  : 3.0.2
                        Adapter    "tibberlink"    : 2.0.0
                        Adapter    "tinker"        : 1.2.1
                        Adapter    "tinymqttbroker": 0.1.0
                        Adapter    "toyota"        : 0.0.3
                        Adapter    "tr-064"        : 4.2.18
                        Adapter    "traccar"       : 1.1.4
                        Adapter    "tractive-gps"  : 1.1.0
                        Adapter    "tradfri"       : 3.1.3
                        Adapter    "trashschedule" : 2.3.0
                        Adapter    "trivum"        : 0.0.5
                        Adapter    "tronity"       : 1.1.1
                        Adapter    "tunnelbroker-endpoint-updater": 0.0.1
                        Adapter    "tuya"          : 3.15.0
                        Adapter    "tvprogram"     : 1.1.2
                        Adapter    "tvspielfilm"   : 2.0.5
                        Adapter    "twinkly"       : 1.0.14
                        Adapter    "unifi"         : 0.6.7
                        Adapter    "upnp"          : 1.0.21
                        Adapter    "uv-protect"    : 0.5.1
                        Adapter    "vaillant"      : 0.1.2
                        Adapter    "valloxmv"      : 1.2.0
                        Adapter    "valuetrackerovertime": 1.0.1
                        Adapter    "vcard"         : 0.0.9
                        Adapter    "vds2465-server": 0.1.10
                        Adapter    "velux"         : 0.0.7
                        Adapter    "vesync"        : 0.0.3
                        Adapter    "viessmann"     : 1.4.6
                        Adapter    "viessmannapi"  : 2.3.0
                        Adapter    "virtualpowermeter": 1.4.6   , installed 1.4.2 [Updateable]
                        Adapter    "vis"           : 1.5.4    , installed 1.4.3 [Updateable]
                        Adapter    "vis-bars"      : 0.1.4    , installed 0.1.4
                        Adapter    "vis-canvas-gauges": 1.0.1
                        Adapter    "vis-colorpicker": 2.0.3
                        Adapter    "vis-fancyswitch": 1.1.0
                        Adapter    "vis-google-fonts": 1.0.4
                        Adapter    "vis-history"   : 1.0.0    , installed 1.0.0
                        Adapter    "vis-hqwidgets" : 1.4.0
                        Adapter    "vis-icontwo"   : 1.0.0
                        Adapter    "vis-inventwo"  : 3.3.3
                        Adapter    "vis-jqui-mfd"  : 1.0.12
                        Adapter    "vis-justgage"  : 2.1.0
                        Adapter    "vis-keyboard"  : 0.0.2
                        Adapter    "vis-lcars"     : 1.1.1
                        Adapter    "vis-map"       : 1.0.4
                        Adapter    "vis-material"  : 0.1.3
                        Adapter    "vis-material-advanced": 1.7.4
                        Adapter    "vis-materialdesign": 0.5.9   , installed 0.5.1-beta [Updateable]
                        Adapter    "vis-metro"     : 1.2.0
                        Adapter    "vis-players"   : 0.1.6
                        Adapter    "vis-plumb"     : 1.0.2
                        Adapter    "vis-rgraph"    : 0.0.2
                        Adapter    "vis-timeandweather": 1.2.2
                        Adapter    "vis-weather"   : 2.5.6
                        Adapter    "voltoplus"     : 0.1.3
                        Adapter    "volumio"       : 0.1.2
                        Adapter    "volvo"         : 0.1.0
                        Adapter    "vr200"         : 1.0.0
                        Adapter    "vw-connect"    : 0.0.67
                        Adapter    "wallpanel"     : 0.3.11
                        Adapter    "warp"          : 1.2.2
                        Adapter    "weather-warnings": 0.6.4
                        Adapter    "weatherflow_udp": 0.1.3
                        Adapter    "weatherunderground": 3.6.0
                        Adapter    "web"           : 6.1.10   , installed 3.4.7 [Updateable]
                        Adapter    "webcal"        : 1.3.0
                        Adapter    "webui"         : 0.20.7
                        Adapter    "webuntis"      : 0.3.4
                        Adapter    "weishaupt-wem" : 0.0.15
                        Adapter    "welcome"       : 0.1.0
                        Adapter    "whatsapp-cmb"  : 0.2.3
                        Adapter    "wiegand-tcpip" : 0.4.6
                        Adapter    "wiffi-wz"      : 2.2.1
                        Adapter    "wifilight"     : 1.1.4
                        Adapter    "windows-control": 0.1.5
                        Adapter    "wiobrowser"    : 2.0.2
                        Adapter    "wireguard"     : 1.6.1
                        Adapter    "wireless-mbus" : 0.9.1
                        Adapter    "withings"      : 0.0.13
                        Adapter    "wlanthermo-nano": 0.2.1
                        Adapter    "wled"          : 0.7.2
                        Adapter    "wmswebcontrol" : 0.0.5
                        Adapter    "wolf"          : 1.7.0
                        Adapter    "wolf-smartset" : 1.1.1
                        Adapter    "worx"          : 2.3.4
                        Adapter    "ws"            : 2.5.8
                        Adapter    "xbox"          : 1.1.0
                        Adapter    "xs1"           : 1.0.2
                        Adapter    "xterm"         : 2.0.1
                        Adapter    "yahka"         : 1.0.3
                        Adapter    "yahoo-stock-market": 0.0.5
                        Adapter    "yamaha"        : 0.5.3
                        Adapter    "yeelight-2"    : 1.2.1
                        Adapter    "youtube"       : 4.4.0
                        Adapter    "yr"            : 5.3.0
                        Adapter    "zehnder-cloud" : 0.0.7
                        Adapter    "zigbee"        : 1.9.5
                        Adapter    "zigbee2mqtt"   : 2.13.3
                        Adapter    "zont"          : 0.5.4
                        Adapter    "zwave2"        : 3.1.0
                        karl@IOBROKER:/$
                          @goetschhofer deine Datenbank stimmt nicht
                            Wie darf ich dies verstehen ?
                            G crunchip 2 Replies Last reply Reply Quote 0
                              @crunchip
                              Sollten wir vorher das Problem mit den Dateien versuchen zu lösen ?
                              Bei den states sehe ich eine 0 u. bei den objects sehe ich auch eine große Veränderung ?
                              -rw-rw-r--+ 1 iobroker iobroker 3,8M Dez 30 10:54 2023-12-30_10-54_objects.json.gz
                              -rw-rw-r--+ 1 iobroker iobroker 138K Dez 30 10:54 2023-12-30_10-54_states.json.gz
                              karl@IOBROKER:/$
                                @goetschhofer dein Fehler von oben
                                dir fehlt wohl jetzt die DB für states
                                führe das nochmal aus
                                iobroker stop
                                cd backup-objects/
                                gunzip -ck 2023-12-30_10-11_states.json.gz > /opt/iobroker/iobroker-data/states.json
                                iobroker start
                                und dann noch mal
                                iob update
                                  iobroker start
                                  Ich glaube jetzt schaut es gut aus, super danke ! 👍
                                  Jetzt kann ich auch wieder auf den iobroker.
                                  Ist hier etwas zu aktualisieren ?
                                  Soll ich sicherheitshalber mal gleich eine Datensicherung in proxmox machen ?
                                  login as: karl
                                  Last login: Sat Dec 30 10:27:16 2023 from 192.168.1.3
                                  karl@IOBROKER:/opt/iobroker/iobroker-data/backup-objects$ gunzip -ck 2023-12-30_07-03_objects.json.gz > /opt/iobroker/iobroker-data/objects.json
                                  karl@IOBROKER:/opt/iobroker/iobroker-data/backup-objects$ gunzip -ck 2023-12-30_10-11_states.json.gz > /opt/iobroker/iobroker-data/states.json
                                  karl@IOBROKER:/$
                                  update done
                                  karl@IOBROKER:/$
                                    kannst du mal, dann ist zumindest dieser Stand vorerst gesichert
                                    anschließend deine Adapter updaten
                                    iobroker upgrade
                                      zeig mal die Ausgabe von
                                      iob repo list
                                        iob repo list
                                        karl@IOBROKER:~$ iob repo list
                                        Stable (default): http://download.iobroker.net/sources-dist.json
                                        Beta (latest): http://download.iobroker.net/sources-dist-latest.json
                                        live        : http://iobroker.live/repo/sources-dist-latest.json
                                        Active repo: Stable (default)
                                        karl@IOBROKER:~$
                                          @goetschhofer ok das passt
                                            Super !!!👍
                                            81.1k
                                            34079
