    4. vis 1 läuft nicht mehr
      Thomas Braun Most Active @Max 0 last edited by
      @max-0 sagte in vis 1 läuft nicht mehr:
      Funktioniert aber immer noch nicht
      Und
      iob diag
      sagt nun?
      Max 0 1 Reply Last reply Reply Quote 0
      • Max 0
        Max 0 @Thomas Braun last edited by Homoran
        Skript v.2023-10-10
        *** BASE SYSTEM ***
         Static hostname: raspberrypi5
               Icon name: computer
                  Kernel: Linux 6.1.0-rpi7-rpi-2712
            Architecture: arm64
        Model           : Raspberry Pi 5 Model B Rev 1.0
        Docker          : false
        Virtualization  : none
        Kernel          : aarch64
        Userland        : arm64
        Systemuptime and Load:
         23:07:00 up  3:28,  2 users,  load average: 0.12, 0.11, 0.11
        CPU threads: 4
        *** RASPBERRY THROTTLING ***
        Current issues:
        Previously detected issues:
        *** Time and Time Zones ***
                       Local time: Fri 2023-12-29 23:07:00 CET
                   Universal time: Fri 2023-12-29 22:07:00 UTC
                         RTC time: Fri 2023-12-29 22:07:00
                      NTP service: active
                  RTC in local TZ: no
        *** User and Groups ***
        pi
        /home/pi
        pi adm dialout cdrom sudo audio video plugdev games users input render netdev gp        io i2c spi
        *** X-Server-Setup ***
        X-Server:       false
        Desktop:
        Terminal:       tty
        Boot Target:    multi-user.target
        *** MEMORY ***
        Mem:            8.4G        681M        5.3G        5.3M        2.6G        7.8G
        Swap:           104M          0B        104M
        Total:          8.5G        681M        5.4G
                 8053 M total memory
                  650 M used memory
                  607 M active memory
                 2104 M inactive memory
                 5031 M free memory
                  168 M buffer memory
                 2304 M swap cache
                   99 M total swap
                    0 M used swap
                   99 M free swap
        Raspberry only:
        vc_gencmd_read_response returned -1
        error=1 error_msg="Command not registered"
        *** FAILED SERVICES ***
        0 loaded units listed.
        *** FILESYSTEM ***
        udev           devtmpfs  3.8G     0  3.8G   0% /dev
        tmpfs          tmpfs     806M  5.0M  801M   1% /run
        /dev/mmcblk0p2 ext4       15G  2.9G   11G  22% /
        tmpfs          tmpfs     4.0G     0  4.0G   0% /dev/shm
        tmpfs          tmpfs     5.0M   48K  5.0M   1% /run/lock
        /dev/mmcblk0p1 vfat      510M   61M  450M  12% /boot/firmware
        tmpfs          tmpfs     806M     0  806M   0% /run/user/1000
        [Fri Dec 29 19:38:43 2023] Kernel command line: coherent_pool=1M 8250.nr_uarts=1        pci=pcie_bus_safe snd_bcm2835.enable_compat_alsa=0 snd_bcm2835.enable_hdmi=1  s        msc95xx.macaddr=D8:3A:DD:BB:FC:13 vc_mem.mem_base=0x3fc00000 vc_mem.mem_size=0x4        0000000  console=ttyAMA10,115200 console=tty1 root=PARTUUID=0fd8a7d6-02 rootfsty        pe=ext4 fsck.repair=yes rootwait
        [Fri Dec 29 19:38:46 2023] EXT4-fs (mmcblk0p2): mounted filesystem with ordered        data mode. Quota mode: none.
        [Fri Dec 29 19:38:49 2023] EXT4-fs (mmcblk0p2): re-mounted. Quota mode: none.
        [Fri Dec 29 19:38:53 2023] EXT4-fs (mmcblk0p2): resizing filesystem from 536576        to 3768320 blocks
        [Fri Dec 29 19:38:56 2023] EXT4-fs (mmcblk0p2): resized filesystem to 3768320
        TARGET           SOURCE         FSTYPE OPTIONS
        /                /dev/mmcblk0p2 ext4   rw,noatime
        `-/boot/firmware /dev/mmcblk0p1 vfat   rw,relatime,fmask=0022,dmask=0022,codepag        e=437,iocharset=ascii,shortname=mixed,errors=remount-ro
        /var:
        548M    /var/
        260M    /var/cache
        254M    /var/cache/apt
        164M    /var/lib
        142M    /var/cache/apt/archives
        Archived and active journals take up 24.0M in the file system.
        /opt/iobroker/backups:
        4.0K    /opt/iobroker/backups/
        /opt/iobroker/iobroker-data:
        69M     /opt/iobroker/iobroker-data/
        59M     /opt/iobroker/iobroker-data/files
        30M     /opt/iobroker/iobroker-data/files/web.admin/static
        29M     /opt/iobroker/iobroker-data/files/web.admin/static/js
        21M     /opt/iobroker/iobroker-data/files/web.admin/static/js/main.aaea95f8.js.m        ap
        8.3M    /opt/iobroker/iobroker-data/files/web.admin/static/js/main.aaea95f8.js
        7.9M    /opt/iobroker/iobroker-data/objects.jsonl
        6.3M    /opt/iobroker/iobroker-data/files/admin.admin/custom/static/js/vendors-n        ode_modules_iobroker_adapter-react-v5_assets_devices_parseNames_js-node_modules_        iobr-99c23e.847b8ad9.chunk.js.map
        2.8M    /opt/iobroker/iobroker-data/files/admin.admin/custom/static/js/vendors-n        ode_modules_iobroker_adapter-react-v5_assets_devices_parseNames_js-node_modules_        iobr-99c23e.847b8ad9.chunk.js
        USB-Devices by-id:
        USB-Sticks -  Avoid direct links to /dev/* in your adapter setups, please always        prefer the links 'by-id':
        *** NodeJS-Installation ***
        /usr/bin/nodejs         v18.19.0
        /usr/bin/node           v18.19.0
        /usr/bin/npm            10.2.3
        /usr/bin/npx            10.2.3
        /usr/bin/corepack       0.22.0
        nodejs:
          Installed: 18.19.0-1nodesource1
          Candidate: 18.19.0-1nodesource1
          Version table:
             18.19.0+dfsg-6~deb12u1 500
                500 http://deb.debian.org/debian-security bookworm-security/main arm64 P        ackages
         *** 18.19.0-1nodesource1 1001
                100 /var/lib/dpkg/status
             18.18.2-1nodesource1 1001
             18.18.1-1nodesource1 1001
             18.18.0-1nodesource1 1001
             18.17.1-1nodesource1 1001
             18.17.0-1nodesource1 1001
             18.16.1-1nodesource1 1001
             18.16.0-1nodesource1 1001
             18.15.0-1nodesource1 1001
             18.14.2-1nodesource1 1001
             18.14.1-1nodesource1 1001
             18.14.0-1nodesource1 1001
             18.13.0+dfsg1-1 500
             18.13.0-1nodesource1 1001
             18.12.0-1nodesource1 1001
             18.11.0-1nodesource1 1001
             18.10.0-1nodesource1 1001
             18.9.1-1nodesource1 1001
             18.9.0-1nodesource1 1001
             18.8.0-1nodesource1 1001
             18.7.0-1nodesource1 1001
             18.6.0-1nodesource1 1001
             18.5.0-1nodesource1 1001
             18.4.0-1nodesource1 1001
             18.3.0-1nodesource1 1001
             18.2.0-1nodesource1 1001
             18.1.0-1nodesource1 1001
             18.0.0-1nodesource1 1001
        No problems detected
        Errors in npm tree:
        *** ioBroker-Installation ***
        ioBroker Status
        Objects type: jsonl
        States  type: jsonl
        Core adapters versions
        js-controller:  5.0.17
        admin:          6.12.0
        javascript:     "javascript" not found
        Adapters from github:   0
        Adapter State
        + system.adapter.admin.0                  : admin                 : raspberrypi5                             -  enabled, port: 8081, bind: 0.0.0.0, run as: admin
        + system.adapter.backitup.0               : backitup              : raspberrypi5                             -  enabled
        + system.adapter.discovery.0              : discovery             : raspberrypi5                             -  enabled
          system.adapter.vis.0                    : vis                   : raspberrypi5                             -  enabled
        + system.adapter.web.0                    : web                   : raspberrypi5                             -  enabled, port: 8082, bind: 0.0.0.0, run as: admin
        + instance is alive
        ioBroker-Repositories
        Active repo(s): stable
        Installed ioBroker-Instances
        Used repository: stable
        Adapter    "admin"        : 6.12.0   , installed 6.12.0
        Adapter    "backitup"     : 2.9.8    , installed 2.9.8
        Controller "js-controller": 5.0.17   , installed 5.0.17
        Adapter    "web"          : 6.1.10   , installed 6.1.10
        Adapter    "ws"           : 2.5.8    , installed 2.5.8
        Objects and States
        Objects:        180
        States:         138
        Hit:2 http://deb.debian.org/debian-security bookworm-security InRelease
        Hit:3 http://deb.debian.org/debian bookworm-updates InRelease
        Hit:4 https://deb.nodesource.com/node_18.x nodistro InRelease
        Hit:5 http://archive.raspberrypi.com/debian bookworm InRelease
        Reading package lists...
        Pending Updates: 0
        *** Listening Ports ***
        tcp        0      0 127.0.0.1:9001          0.0.0.0:*               LISTEN      1001       73444      20322/iobroker.js-c
        tcp        0      0 127.0.0.1:9000          0.0.0.0:*               LISTEN      1001       73451      20322/iobroker.js-c
        tcp        0      0 0.0.0.0:22              0.0.0.0:*               LISTEN      0          17375      1863/sshd: /usr/sbi
        tcp6       0      0 :::22                   :::*                    LISTEN      0          17377      1863/sshd: /usr/sbi
        tcp6       0      0 :::8081                 :::*                    LISTEN      1001       72340      20340/io.admin.0
        tcp6       0      0 :::8082                 :::*                    LISTEN      1001       71622      20397/io.web.0
        udp        0      0 0.0.0.0:5353            0.0.0.0:*                           104        758        655/avahi-daemon: r
        udp        0      0 0.0.0.0:33709           0.0.0.0:*                           104        760        655/avahi-daemon: r
        udp6       0      0 :::5353                 :::*                                104        759        655/avahi-daemon: r
        udp6       0      0 fe80::aaec:1ab3:54b:546 :::*                                0          16660      775/NetworkManager
        udp6       0      0 :::54271                :::*                                104        761        655/avahi-daemon: r
        2023-12-29 22:54:09.429  - info: host.raspberrypi5 instance system.adapter.discovery.0 started with pid 20367
        2023-12-29 22:54:10.104  - info: discovery.0 (20367) starting. Version 4.2.0 in /opt/iobroker/node_modules/iobroker.discovery, node: v18.19.0, js-controller: 5.0.17
        2023-12-29 22:54:13.424  - info: host.raspberrypi5 instance system.adapter.backitup.0 started with pid 20382
        2023-12-29 22:54:14.130  - info: backitup.0 (20382) starting. Version 2.9.8 in /opt/iobroker/node_modules/iobroker.backitup, node: v18.19.0, js-controller: 5.0.17
        2023-12-29 22:54:14.155  - info: backitup.0 (20382) [iobroker] backup will be activated at 02:48 every 1 day(s)
        2023-12-29 22:54:14.294  - info: admin.0 (20340) ==> Connected system.user.admin from ::ffff:192.168.178.109
        2023-12-29 22:54:17.427  - info: host.raspberrypi5 instance system.adapter.web.0 started with pid 20397
        2023-12-29 22:54:18.144  - info: web.0 (20397) starting. Version 6.1.10 in /opt/iobroker/node_modules/iobroker.web, node: v18.19.0, js-controller: 5.0.17
        2023-12-29 22:54:18.209  - info: web.0 (20397) socket.io server listening on port 8082
        2023-12-29 22:54:18.211  - info: web.0 (20397) http server listening on port 8082
        2023-12-29 22:54:18.937  - info: admin.0 (20340) <== Disconnect system.user.admin from ::ffff:192.168.178.109 admin
        2023-12-29 22:54:19.521  - info: admin.0 (20340) ==> Connected system.user.admin from ::ffff:192.168.178.109
        2023-12-29 22:54:22.126  - info: vis.0 (20412) starting. Version 1.5.4 in /opt/iobroker/node_modules/iobroker.vis, node: v18.19.0, js-controller: 5.0.17
        2023-12-29 22:54:22.725  - info: vis.0 (20412) Terminated (NO_ERROR): Without reason
        2023-12-29 22:54:23.277  - info: host.raspberrypi5 instance system.adapter.vis.0 terminated while should be started once
        2023-12-29 22:54:34.893  - info: web.0 (20397) ==> Connected system.user.admin from ::ffff:192.168.178.109
        2023-12-29 22:54:37.305  - info: web.0 (20397) <== Disconnect system.user.admin from ::ffff:192.168.178.109 vis.0
        2023-12-29 22:55:06.666  - info: admin.0 (20340) <== Disconnect system.user.admin from ::ffff:192.168.178.109 admin
        2023-12-29 22:55:07.139  - info: admin.0 (20340) ==> Connected system.user.admin from ::ffff:192.168.178.109
        2023-12-29 22:58:25.891  - info: admin.0 (20340) <== Disconnect system.user.admin from ::ffff:192.168.178.109 admin
        2023-12-29 22:58:26.369  - info: admin.0 (20340) ==> Connected system.user.admin from ::ffff:192.168.178.109
        2023-12-29 23:06:22.986  - info: admin.0 (20340) <== Disconnect system.user.admin from ::ffff:192.168.178.109 admin
        2023-12-29 23:06:23.461  - info: admin.0 (20340) ==> Connected system.user.admin from ::ffff:192.168.178.109
        2023-12-29 23:06:27.503  - info: web.0 (20397) ==> Connected system.user.admin from ::ffff:192.168.178.109
        2023-12-29 23:06:29.257  - info: web.0 (20397) <== Disconnect system.user.admin from ::ffff:192.168.178.109 vis.0
          @max-0
          nodejs passt.
          • Max 0
            @thomas-brau
            Und jetzt?
            Thomas Braun sigi234 2 Replies Last reply Reply Quote 0
              @max-0
              Von vis hab ich keine Ahnung.
                sigi234 Forum Testing Most Active @Max 0 last edited by
                @thomas-brau
                Und jetzt?
                Screenshot vom WEB Adapter bitte.
                  Homoran Global Moderator Administrators @Max 0 last edited by
                  was bedeutet dies u
                  dass du von deiner SD Karte nur einen Bruchteil genutzt hattest
                  Und was meinst du mit *** 18.19.0+dfsg-6~deb12u1 500 ?
                  habe auf dem Link geschaut aber nichts gefunden
                  die Anleitung mit wenigen Befehlen stand direkt im ersten Post.
                  Hat sich aber wohl inzwischen erledigt.
                  • OliverIO
                    OliverIO last edited by
                    @max-0
                    Welcher browser?
                    Welsch Version?
                    Was sagen die Fehlermeldungen in der browserkonsole? Öffnen mit F12
                    • Max 0
                      Max 0 @sigi234 last edited by
                      • Max 0
                        Max 0 @OliverIO last edited by
                        @oliverio
                        Ich benutze den Opera browser
                        Opera Version 105.0.4970.63
                        Und hier die browserkonsole:
                        2023-12-30T10:48:23.961Z Connected => authenticate
                        data:application/json;charset=8{"name":"ioBroker vis","short_name":"vis","start_url":".#main/%22,%22display%22:%22standalone%22,%22background_color%22:%22#ffffff%22,%22description%22:%22WEB%20visualisation%20for%20ioBroker%20platform%22,%22icons%22:[{%22src%22:%22img/vis.png%22,%22sizes%22:%22192x192%22,%22type%22:%22image/png%22}]}:1
                               Failed to load resource: net::ERR_INVALID_URL
                        conn.js:331 2023-12-30T10:48:24.070Z Authenticated: true
                        vis.js:3595 Create inner vis object demoTemperature
                        vis.js:3595 Create inner vis object demoHumidity
                        translate.js:20 "Use background": {"en": "Use background", "de": "Use background", "ru": "Use background"},
                        edit.html:1 Uncaught SyntaxError: Unexpected non-whitespace character after JSON at position 2 (line 1 column 3)
                            at JSON.parse (<anonymous>)
                            at Object.unserialize (loStorage.js:2:567)
                            at r.get (loStorage.js:2:1871)
                            at Function.get (loStorage.js:2:2346)
                            at Object.bindInstance (vis.js:576:54)
                            at Object.initNext (vis.js:705:14)
                            at Object.<anonymous> (vis.js:603:18)
                            at Object.loadWidgetSets (vis.js:568:34)
                            at Object.init (vis.js:602:14)
                            at vis.js:3661:29
                        • Max 0
                          Max 0 @Homoran last edited by
                          Hat das Auswirkungen das ich nur ein Bruchteil meiner SD Karte nutze?
                          Was kann ich dagegen tun?
                          DJMarc75 Homoran 2 Replies Last reply Reply Quote 0
                            Haken setzen bei reine Websockes ....
                            • DJMarc75
                              DJMarc75 @Max 0 last edited by
                              Im Terminal
                              sudo raspi-config
                              eingeben.
                              Dann
                              Zuletzt den Raspberry rebooten.
                                ist doch jetzt passiert
                                • Max 0
                                  Max 0 @DJMarc75 last edited by Max 0
                                  @djmarc75
                                  Habe ich gemacht
                                  Und jetzt?
                                  • Max 0
                                    Vlt hilft das
                                      Vlt hilft das
                                      als Text in code-tags wäre es besser.
                                      was willst du damit zeigen?
                                      • OliverIO
                                        die beiden fehlermeldungen sagen, das was mit vis nicht stimmt.
                                        ich würde vis mal deinstallieren und dann wieder installieren.
                                        wenn das nicht hilft, dann den web adapter deinstallieren und wieder installieren (ich glaube das zweitere muss man mit den consolenbefehlen für den iobroker machen.)
                                        den hinweis mit den websockets ebenfalls probieren und natürlich der partition den kompletten platz der sd karte geben. homoran hat gezeigt wie man das macht
                                        • Max 0
                                          @homoran said in vis 1 läuft nicht mehr:
                                          Was meinst du mit iob diag?
                                          bitte diesen Befehl in der Konsole ausführen, und die Ausgabe posten
                                          Bin neu hier
                                          Na, dann hab ich hier was für dich zu lesen
                                            @max-0 was willst du mir jetzt sagen?
                                            3399
