    3. Off Topic
    4. Proxmox
    5. Proxmox: Fehlermeldung bei backup - vzdump ?
      GOETSCHHOFER @crunchip last edited by GOETSCHHOFER
      @crunchip said in Proxmox: Fehlermeldung bei backup - vzdump ?:
      @goetschhofer sagte in Proxmox: Fehlermeldung bei backup - vzdump ?:
      Schon wieder.
      dann ist da wohl was faul
      fährt proxmox denn hoch?
      falls ja, ins syslog schauen
      var/log/syslog
      oder auch mit
      dmesg
      direkt in der Konsole
      1. TEIL:
      login as: karl
      karl@192.168.1.140's password:
      Linux NUC 5.4.143-1-pve #1 SMP PVE 5.4.143-1 (Tue, 28 Sep 2021 09:10:37 +0200) x        86_64
      The programs included with the Debian GNU/Linux system are free software;
      the exact distribution terms for each program are described in the
      individual files in /usr/share/doc/*/copyright.
      Debian GNU/Linux comes with ABSOLUTELY NO WARRANTY, to the extent
      permitted by applicable law.
      Last login: Thu Dec 14 14:06:36 2023 from 192.168.1.3
      karl@NUC:~$ var/log/syslog
      -bash: var/log/syslog: No such file or directory
      karl@NUC:~$ dmesg
      [    0.000000] Linux version 5.4.143-1-pve (build@proxmox) (gcc version 8.3.0 (D        ebian 8.3.0-6)) #1 SMP PVE 5.4.143-1 (Tue, 28 Sep 2021 09:10:37 +0200) ()
      [    0.000000] Command line: BOOT_IMAGE=/boot/vmlinuz-5.4.143-1-pve root=/dev/ma        pper/pve-root ro quiet
      [    0.000000] KERNEL supported cpus:
      [    0.000000]   Intel GenuineIntel
      [    0.000000]   AMD AuthenticAMD
      [    0.000000]   Hygon HygonGenuine
      [    0.000000]   Centaur CentaurHauls
      [    0.000000]   zhaoxin   Shanghai
      [    0.000000] x86/fpu: Supporting XSAVE feature 0x001: 'x87 floating point regi        sters'
      [    0.000000] x86/fpu: Supporting XSAVE feature 0x002: 'SSE registers'
      [    0.000000] x86/fpu: Supporting XSAVE feature 0x004: 'AVX registers'
      [    0.000000] x86/fpu: Supporting XSAVE feature 0x008: 'MPX bounds registers'
      [    0.000000] x86/fpu: Supporting XSAVE feature 0x010: 'MPX CSR'
      [    0.000000] x86/fpu: xstate_offset[2]:  576, xstate_sizes[2]:  256
      [    0.000000] x86/fpu: xstate_offset[3]:  832, xstate_sizes[3]:   64
      [    0.000000] x86/fpu: xstate_offset[4]:  896, xstate_sizes[4]:   64
      [    0.000000] x86/fpu: Enabled xstate features 0x1f, context size is 960 bytes,        using 'compacted' format.
      [    0.000000] BIOS-provided physical RAM map:
      [    0.000000] BIOS-e820: [mem 0x0000000000000000-0x000000000009efff] usable
      [    0.000000] BIOS-e820: [mem 0x000000000009f000-0x00000000000fffff] reserved
      [    0.000000] BIOS-e820: [mem 0x0000000000100000-0x0000000079e7efff] usable
      [    0.000000] BIOS-e820: [mem 0x0000000079e7f000-0x000000007a2e0fff] reserved
      [    0.000000] BIOS-e820: [mem 0x000000007a2e1000-0x000000007a35dfff] ACPI data
      [    0.000000] BIOS-e820: [mem 0x000000007a35e000-0x000000007a3e6fff] ACPI NVS
      [    0.000000] BIOS-e820: [mem 0x000000007a3e7000-0x000000007ac52fff] reserved
      [    0.000000] BIOS-e820: [mem 0x000000007ac53000-0x000000007ad0dfff] type 20
      [    0.000000] BIOS-e820: [mem 0x000000007ad0e000-0x000000007ad0efff] usable
      [    0.000000] BIOS-e820: [mem 0x000000007ad0f000-0x000000007fffffff] reserved
      [    0.000000] BIOS-e820: [mem 0x00000000e0000000-0x00000000efffffff] reserved
      [    0.000000] BIOS-e820: [mem 0x00000000fe000000-0x00000000fe010fff] reserved
      [    0.000000] BIOS-e820: [mem 0x00000000fec00000-0x00000000fec00fff] reserved
      [    0.000000] BIOS-e820: [mem 0x00000000fed00000-0x00000000fed03fff] reserved
      [    0.000000] BIOS-e820: [mem 0x00000000fee00000-0x00000000fee00fff] reserved
      [    0.000000] BIOS-e820: [mem 0x00000000ff000000-0x00000000ffffffff] reserved
      [    0.000000] BIOS-e820: [mem 0x0000000100000000-0x000000047dffffff] usable
      [    0.000000] NX (Execute Disable) protection: active
      [    0.000000] efi: EFI v2.70 by American Megatrends
      [    0.000000] efi:  ACPI 2.0=0x7a2fa000  ACPI=0x7a2fa000  TPMFinalLog=0x7a39100        0  SMBIOS=0x7aaa7000  SMBIOS 3.0=0x7aaa6000  MEMATTR=0x77fb8418  ESRT=0x7aad1918
      [    0.000000] secureboot: Secure boot could not be determined (mode 0)
      [    0.000000] SMBIOS 3.2.1 present.
      [    0.000000] DMI: Intel(R) Client Systems NUC8i3BEK/NUC8BEB, BIOS BECFL357.86A        .0081.2020.0504.1834 05/04/2020
      [    0.000000] tsc: Detected 3000.000 MHz processor
      [    0.000360] e820: update [mem 0x00000000-0x00000fff] usable ==> reserved
      [    0.000362] e820: remove [mem 0x000a0000-0x000fffff] usable
      [    0.000366] last_pfn = 0x47e000 max_arch_pfn = 0x400000000
      [    0.000371] MTRR default type: write-back
      [    0.000371] MTRR fixed ranges enabled:
      [    0.000372]   00000-9FFFF write-back
      [    0.000373]   A0000-BFFFF uncachable
      [    0.000374]   C0000-FFFFF write-protect
      [    0.000374] MTRR variable ranges enabled:
      [    0.000376]   0 base 0080000000 mask 7F80000000 uncachable
      [    0.000376]   1 base 007C000000 mask 7FFC000000 uncachable
      [    0.000377]   2 base 007B800000 mask 7FFF800000 uncachable
      [    0.000378]   3 base 2000000000 mask 6000000000 uncachable
      [    0.000378]   4 base 1000000000 mask 7000000000 uncachable
      [    0.000379]   5 base 0800000000 mask 7800000000 uncachable
      [    0.000380]   6 base 4000000000 mask 4000000000 uncachable
      [    0.000380]   7 disabled
      [    0.000381]   8 disabled
      [    0.000381]   9 disabled
      [    0.000797] x86/PAT: Configuration [0-7]: WB  WC  UC- UC  WB  WP  UC- WT
      [    0.000964] last_pfn = 0x7ad0f max_arch_pfn = 0x400000000
      [    0.008161] esrt: Reserving ESRT space from 0x000000007aad1918 to 0x000000007        aad1950.
      [    0.008168] check: Scanning 1 areas for low memory corruption
      [    0.008171] Using GB pages for direct mapping
      [    0.008370] secureboot: Secure boot could not be determined (mode 0)
      [    0.008371] RAMDISK: [mem 0x32259000-0x35123fff]
      [    0.008373] ACPI: Early table checksum verification disabled
      [    0.008376] ACPI: RSDP 0x000000007A2FA000 000024 (v02 INTEL )
      [    0.008379] ACPI: XSDT 0x000000007A2FA0A8 0000CC (v01 INTEL  NUC8i3BE 0000005        1 AMI  00010013)
      [    0.008383] ACPI: FACP 0x000000007A338BB0 000114 (v06 INTEL  NUC8i3BE 0000005        1 AMI  00010013)
      [    0.008387] ACPI: DSDT 0x000000007A2FA200 03E9AB (v02 INTEL  NUC8i3BE 0000005        1 INTL 20160527)
      [    0.008390] ACPI: FACS 0x000000007A3E6080 000040
      [    0.008392] ACPI: APIC 0x000000007A338CC8 000084 (v04 INTEL  NUC8i3BE 0000005        1 AMI  00010013)
      [    0.008394] ACPI: FPDT 0x000000007A338D50 000044 (v01 INTEL  NUC8i3BE 0000005        1 AMI  00010013)
      [    0.008396] ACPI: FIDT 0x000000007A338D98 00009C (v01 INTEL  NUC8i3BE 0000005        1 AMI  00010013)
      [    0.008398] ACPI: MCFG 0x000000007A338E38 00003C (v01 INTEL  NUC8i3BE 0000005        1 MSFT 00000097)
      [    0.008400] ACPI: SSDT 0x000000007A338E78 001B1C (v02 INTEL  NUC8i3BE 0000005        1 INTL 20160527)
      [    0.008402] ACPI: SSDT 0x000000007A33A998 0031C6 (v02 INTEL  NUC8i3BE 0000005        1 INTL 20160527)
      [    0.008404] ACPI: HPET 0x000000007A33DB60 000038 (v01 INTEL  NUC8i3BE 0000005        1      01000013)
      [    0.008406] ACPI: SSDT 0x000000007A33DB98 000FAE (v02 INTEL  NUC8i3BE 0000005        1 INTL 20160527)
      [    0.008409] ACPI: SSDT 0x000000007A33EB48 003048 (v02 INTEL  NUC8i3BE 0000005        1 INTL 20160527)
      [    0.008411] ACPI: UEFI 0x000000007A341B90 000042 (v01 INTEL  NUC8i3BE 0000005        1      01000013)
      [    0.008413] ACPI: LPIT 0x000000007A341BD8 000094 (v01 INTEL  NUC8i3BE 0000005        1      01000013)
      [    0.008415] ACPI: SSDT 0x000000007A341C70 0027DE (v02 INTEL  NUC8i3BE 0000005        1 INTL 20160527)
      [    0.008417] ACPI: SSDT 0x000000007A344450 0008B8 (v02 INTEL  NUC8i3BE 0000005        1 INTL 20160527)
      [    0.008419] ACPI: DBGP 0x000000007A344D08 000034 (v01 INTEL  NUC8i3BE 0000005        1      01000013)
      [    0.008421] ACPI: DBG2 0x000000007A344D40 000054 (v00 INTEL  NUC8i3BE 0000005        1      01000013)
      [    0.008423] ACPI: DMAR 0x000000007A344D98 0000A8 (v01 INTEL  NUC8i3BE 0000005        1      01000013)
      [    0.008426] ACPI: SSDT 0x000000007A344E40 000144 (v02 INTEL  NUC8i3BE 0000005        1 INTL 20160527)
      [    0.008428] ACPI: NHLT 0x000000007A344F88 00002D (v00 INTEL  NUC8i3BE 0000005        1      01000013)
      [    0.008430] ACPI: TPM2 0x000000007A344FB8 000034 (v04 INTEL  NUC8i3BE 0000005        1 AMI  00000000)
      [    0.008432] ACPI: WSMT 0x000000007A344FF0 000028 (v01 INTEL  NUC8i3BE 0000005        1 AMI  00010013)
      [    0.008435] ACPI: Reserving FACP table memory at [mem 0x7a338bb0-0x7a338cc3]
      [    0.008435] ACPI: Reserving DSDT table memory at [mem 0x7a2fa200-0x7a338baa]
      [    0.008436] ACPI: Reserving FACS table memory at [mem 0x7a3e6080-0x7a3e60bf]
      [    0.008436] ACPI: Reserving APIC table memory at [mem 0x7a338cc8-0x7a338d4b]
      [    0.008437] ACPI: Reserving FPDT table memory at [mem 0x7a338d50-0x7a338d93]
      [    0.008438] ACPI: Reserving FIDT table memory at [mem 0x7a338d98-0x7a338e33]
      [    0.008438] ACPI: Reserving MCFG table memory at [mem 0x7a338e38-0x7a338e73]
      [    0.008439] ACPI: Reserving SSDT table memory at [mem 0x7a338e78-0x7a33a993]
      [    0.008439] ACPI: Reserving SSDT table memory at [mem 0x7a33a998-0x7a33db5d]
      [    0.008440] ACPI: Reserving HPET table memory at [mem 0x7a33db60-0x7a33db97]
      [    0.008441] ACPI: Reserving SSDT table memory at [mem 0x7a33db98-0x7a33eb45]
      [    0.008441] ACPI: Reserving SSDT table memory at [mem 0x7a33eb48-0x7a341b8f]
      [    0.008442] ACPI: Reserving UEFI table memory at [mem 0x7a341b90-0x7a341bd1]
      [    0.008442] ACPI: Reserving LPIT table memory at [mem 0x7a341bd8-0x7a341c6b]
      [    0.008443] ACPI: Reserving SSDT table memory at [mem 0x7a341c70-0x7a34444d]
      [    0.008444] ACPI: Reserving SSDT table memory at [mem 0x7a344450-0x7a344d07]
      [    0.008444] ACPI: Reserving DBGP table memory at [mem 0x7a344d08-0x7a344d3b]
      [    0.008445] ACPI: Reserving DBG2 table memory at [mem 0x7a344d40-0x7a344d93]
      [    0.008446] ACPI: Reserving DMAR table memory at [mem 0x7a344d98-0x7a344e3f]
      [    0.008446] ACPI: Reserving SSDT table memory at [mem 0x7a344e40-0x7a344f83]
      [    0.008447] ACPI: Reserving NHLT table memory at [mem 0x7a344f88-0x7a344fb4]
      [    0.008447] ACPI: Reserving TPM2 table memory at [mem 0x7a344fb8-0x7a344feb]
      [    0.008448] ACPI: Reserving WSMT table memory at [mem 0x7a344ff0-0x7a345017]
      [    0.008462] ACPI: Local APIC address 0xfee00000
      [    0.008704] No NUMA configuration found
      [    0.008705] Faking a node at [mem 0x0000000000000000-0x000000047dffffff]
      [    0.008714] NODE_DATA(0) allocated [mem 0x47dfd5000-0x47dffffff]
      [    0.008931] Zone ranges:
      [    0.008932]   DMA      [mem 0x0000000000001000-0x0000000000ffffff]
      [    0.008933]   DMA32    [mem 0x0000000001000000-0x00000000ffffffff]
      [    0.008934]   Normal   [mem 0x0000000100000000-0x000000047dffffff]
      [    0.008934]   Device   empty
      [    0.008935] Movable zone start for each node
      [    0.008938] Early memory node ranges
      [    0.008939]   node   0: [mem 0x0000000000001000-0x000000000009efff]
      [    0.008939]   node   0: [mem 0x0000000000100000-0x0000000079e7efff]
      [    0.008940]   node   0: [mem 0x000000007ad0e000-0x000000007ad0efff]
      [    0.008941]   node   0: [mem 0x0000000100000000-0x000000047dffffff]
      [    0.009369] Zeroed struct page in unavailable ranges: 33250 pages
      [    0.009370] Initmem setup node 0 [mem 0x0000000000001000-0x000000047dffffff]
      [    0.009371] On node 0 totalpages: 4161054
      [    0.009372]   DMA zone: 64 pages used for memmap
      [    0.009373]   DMA zone: 22 pages reserved
      [    0.009373]   DMA zone: 3998 pages, LIFO batch:0
      [    0.009430]   DMA32 zone: 7738 pages used for memmap
      [    0.009431]   DMA32 zone: 495232 pages, LIFO batch:63
      [    0.017522]   Normal zone: 57216 pages used for memmap
      [    0.017523]   Normal zone: 3661824 pages, LIFO batch:63
      [    0.055329] Reserving Intel graphics memory at [mem 0x7c000000-0x7fffffff]
      [    0.055821] ACPI: PM-Timer IO Port: 0x1808
      [    0.055823] ACPI: Local APIC address 0xfee00000
      [    0.055828] ACPI: LAPIC_NMI (acpi_id[0x01] high edge lint[0x1])
      [    0.055829] ACPI: LAPIC_NMI (acpi_id[0x02] high edge lint[0x1])
      [    0.055829] ACPI: LAPIC_NMI (acpi_id[0x03] high edge lint[0x1])
      [    0.055830] ACPI: LAPIC_NMI (acpi_id[0x04] high edge lint[0x1])
      [    0.055890] IOAPIC[0]: apic_id 2, version 32, address 0xfec00000, GSI 0-119
      [    0.055891] ACPI: INT_SRC_OVR (bus 0 bus_irq 0 global_irq 2 dfl dfl)
      [    0.055893] ACPI: INT_SRC_OVR (bus 0 bus_irq 9 global_irq 9 high level)
      [    0.055894] ACPI: IRQ0 used by override.
      [    0.055894] ACPI: IRQ9 used by override.
      [    0.055896] Using ACPI (MADT) for SMP configuration information
      [    0.055897] ACPI: HPET id: 0x8086a201 base: 0xfed00000
      [    0.055899] TSC deadline timer available
      [    0.055900] smpboot: Allowing 4 CPUs, 0 hotplug CPUs
      [    0.055912] PM: Registered nosave memory: [mem 0x00000000-0x00000fff]
      [    0.055914] PM: Registered nosave memory: [mem 0x0009f000-0x000fffff]
      [    0.055915] PM: Registered nosave memory: [mem 0x79e7f000-0x7a2e0fff]
      [    0.055915] PM: Registered nosave memory: [mem 0x7a2e1000-0x7a35dfff]
      [    0.055916] PM: Registered nosave memory: [mem 0x7a35e000-0x7a3e6fff]
      [    0.055916] PM: Registered nosave memory: [mem 0x7a3e7000-0x7ac52fff]
      [    0.055916] PM: Registered nosave memory: [mem 0x7ac53000-0x7ad0dfff]
      [    0.055917] PM: Registered nosave memory: [mem 0x7ad0f000-0x7fffffff]
      [    0.055918] PM: Registered nosave memory: [mem 0x80000000-0xdfffffff]
      [    0.055918] PM: Registered nosave memory: [mem 0xe0000000-0xefffffff]
      [    0.055919] PM: Registered nosave memory: [mem 0xf0000000-0xfdffffff]
      [    0.055919] PM: Registered nosave memory: [mem 0xfe000000-0xfe010fff]
      [    0.055920] PM: Registered nosave memory: [mem 0xfe011000-0xfebfffff]
      [    0.055920] PM: Registered nosave memory: [mem 0xfec00000-0xfec00fff]
      [    0.055920] PM: Registered nosave memory: [mem 0xfec01000-0xfecfffff]
      [    0.055921] PM: Registered nosave memory: [mem 0xfed00000-0xfed03fff]
      [    0.055921] PM: Registered nosave memory: [mem 0xfed04000-0xfedfffff]
      [    0.055922] PM: Registered nosave memory: [mem 0xfee00000-0xfee00fff]
      [    0.055922] PM: Registered nosave memory: [mem 0xfee01000-0xfeffffff]
      [    0.055922] PM: Registered nosave memory: [mem 0xff000000-0xffffffff]
      [    0.055924] [mem 0x80000000-0xdfffffff] available for PCI devices
      [    0.055925] Booting paravirtualized kernel on bare hardware
      [    0.055927] clocksource: refined-jiffies: mask: 0xffffffff max_cycles: 0xffff        ffff, max_idle_ns: 7645519600211568 ns
      [    0.055931] setup_percpu: NR_CPUS:8192 nr_cpumask_bits:4 nr_cpu_ids:4 nr_node        _ids:1
      [    0.056092] percpu: Embedded 55 pages/cpu s188416 r8192 d28672 u524288
      [    0.056097] pcpu-alloc: s188416 r8192 d28672 u524288 alloc=1*2097152
      [    0.056097] pcpu-alloc: [0] 0 1 2 3
      [    0.056116] Built 1 zonelists, mobility grouping on.  Total pages: 4096014
      [    0.056117] Policy zone: Normal
      [    0.056118] Kernel command line: BOOT_IMAGE=/boot/vmlinuz-5.4.143-1-pve root=        /dev/mapper/pve-root ro quiet
      [    0.057060] Dentry cache hash table entries: 2097152 (order: 12, 16777216 byt        es, linear)
      [    0.057523] Inode-cache hash table entries: 1048576 (order: 11, 8388608 bytes        , linear)
      [    0.057565] mem auto-init: stack:off, heap alloc:on, heap free:off
      [    0.061280] Calgary: detecting Calgary via BIOS EBDA area
      [    0.061282] Calgary: Unable to locate Rio Grande table in EBDA - bailing!
      [    0.101527] Memory: 16160564K/16644216K available (14339K kernel code, 2369K        rwdata, 4996K rodata, 2708K init, 5024K bss, 483652K reserved, 0K cma-reserved)
      [    0.101533] random: get_random_u64 called from __kmem_cache_create+0x42/0x530        with crng_init=0
      [    0.101631] SLUB: HWalign=64, Order=0-3, MinObjects=0, CPUs=4, Nodes=1
      [    0.101641] Kernel/User page tables isolation: enabled
      [    0.101652] ftrace: allocating 44463 entries in 174 pages
      [    0.116410] rcu: Hierarchical RCU implementation.
      [    0.116411] rcu:     RCU restricting CPUs from NR_CPUS=8192 to nr_cpu_ids=4.
      [    0.116412]  Tasks RCU enabled.
      [    0.116413] rcu: RCU calculated value of scheduler-enlistment delay is 25 jif        fies.
      [    0.116414] rcu: Adjusting geometry for rcu_fanout_leaf=16, nr_cpu_ids=4
      [    0.118808] NR_IRQS: 524544, nr_irqs: 1024, preallocated irqs: 16
      [    0.119282] random: crng done (trusting CPU's manufacturer)
      [    0.119304] Console: colour dummy device 80x25
      [    0.119308] printk: console [tty0] enabled
      [    0.119324] ACPI: Core revision 20190816
      [    0.119709] clocksource: hpet: mask: 0xffffffff max_cycles: 0xffffffff, max_i        dle_ns: 79635855245 ns
      [    0.119822] APIC: Switch to symmetric I/O mode setup
      [    0.119824] DMAR: Host address width 39
      [    0.119825] DMAR: DRHD base: 0x000000fed90000 flags: 0x0
      [    0.119829] DMAR: dmar0: reg_base_addr fed90000 ver 1:0 cap 1c0000c40660462 e        cap 19e2ff0505e
      [    0.119830] DMAR: DRHD base: 0x000000fed91000 flags: 0x1
      [    0.119833] DMAR: dmar1: reg_base_addr fed91000 ver 1:0 cap d2008c40660462 ec        ap f050da
      [    0.119834] DMAR: RMRR base: 0x0000007a294000 end: 0x0000007a2b3fff
      [    0.119835] DMAR: RMRR base: 0x0000007b800000 end: 0x0000007fffffff
      [    0.119836] DMAR-IR: IOAPIC id 2 under DRHD base  0xfed91000 IOMMU 1
      [    0.119837] DMAR-IR: HPET id 0 under DRHD base 0xfed91000
      [    0.119838] DMAR-IR: Queued invalidation will be enabled to support x2apic an        d Intr-remapping.
      [    0.122163] DMAR-IR: Enabled IRQ remapping in x2apic mode
      [    0.122165] x2apic enabled
      [    0.122191] Switched APIC routing to cluster x2apic.
      [    0.127918] ..TIMER: vector=0x30 apic1=0 pin1=2 apic2=-1 pin2=-1
      [    0.147782] clocksource: tsc-early: mask: 0xffffffffffffffff max_cycles: 0x2b        3e459bf4c, max_idle_ns: 440795289890 ns
      [    0.147786] Calibrating delay loop (skipped), value calculated using timer fr        equency.. 6000.00 BogoMIPS (lpj=12000000)
      [    0.147788] pid_max: default: 32768 minimum: 301
      [    0.149762] LSM: Security Framework initializing
      [    0.149770] Yama: becoming mindful.
      [    0.149801] AppArmor: AppArmor initialized
      [    0.149873] Mount-cache hash table entries: 32768 (order: 6, 262144 bytes, li        near)
      [    0.149921] Mountpoint-cache hash table entries: 32768 (order: 6, 262144 byte        s, linear)
      [    0.149934] *** VALIDATE tmpfs ***
      [    0.150069] *** VALIDATE proc ***
      [    0.150114] *** VALIDATE cgroup1 ***
      [    0.150115] *** VALIDATE cgroup2 ***
      [    0.150170] mce: CPU0: Thermal monitoring enabled (TM1)
      [    0.150188] process: using mwait in idle threads
      [    0.150190] Last level iTLB entries: 4KB 64, 2MB 8, 4MB 8
      [    0.150191] Last level dTLB entries: 4KB 64, 2MB 0, 4MB 0, 1GB 4
      [    0.150193] Spectre V1 : Mitigation: usercopy/swapgs barriers and __user poin        ter sanitization
      [    0.150195] Spectre V2 : Mitigation: Full generic retpoline
      [    0.150195] Spectre V2 : Spectre v2 / SpectreRSB mitigation: Filling RSB on c        ontext switch
      [    0.150195] Spectre V2 : Enabling Restricted Speculation for firmware calls
      [    0.150197] Spectre V2 : mitigation: Enabling conditional Indirect Branch Pre        diction Barrier
      [    0.150197] Spectre V2 : User space: Mitigation: STIBP via seccomp and prctl
      [    0.150198] Speculative Store Bypass: Mitigation: Speculative Store Bypass di        sabled via prctl and seccomp
      [    0.150200] SRBDS: Vulnerable: No microcode
      [    0.150201] MDS: Mitigation: Clear CPU buffers
      [    0.150430] Freeing SMP alternatives memory: 40K
      [    0.152281] smpboot: CPU0: Intel(R) Core(TM) i3-8109U CPU @ 3.00GHz (family:        0x6, model: 0x8e, stepping: 0xa)
      [    0.152365] Performance Events: PEBS fmt3+, Skylake events, 32-deep LBR, full        -width counters, Intel PMU driver.
      [    0.152370] ... version:                4
      [    0.152370] ... bit width:              48
      [    0.152371] ... generic registers:      4
      [    0.152371] ... value mask:             0000ffffffffffff
      [    0.152372] ... max period:             00007fffffffffff
      [    0.152372] ... fixed-purpose events:   3
      [    0.152372] ... event mask:             000000070000000f
      [    0.152408] rcu: Hierarchical SRCU implementation.
      [    0.153094] NMI watchdog: Enabled. Permanently consumes one hw-PMU counter.
      [    0.153138] smp: Bringing up secondary CPUs ...
      [    0.153208] x86: Booting SMP configuration:
      [    0.153208] .... node  #0, CPUs:      #1 #2
      [    0.153627] MDS CPU bug present and SMT on, data leak possible. See https://w        ww.kernel.org/doc/html/latest/admin-guide/hw-vuln/mds.html for more details.
      [    0.153627]  #3
      [    0.153627] smp: Brought up 1 node, 4 CPUs
      [    0.153627] smpboot: Max logical packages: 1
      [    0.153627] smpboot: Total of 4 processors activated (24000.00 BogoMIPS)
      [    0.156175] devtmpfs: initialized
      [    0.156175] x86/mm: Memory block size: 128MB
      [    0.157094] PM: Registering ACPI NVS region [mem 0x7a35e000-0x7a3e6fff] (5611        52 bytes)
      [    0.157094] clocksource: jiffies: mask: 0xffffffff max_cycles: 0xffffffff, ma        x_idle_ns: 7645041785100000 ns
      [    0.157094] futex hash table entries: 1024 (order: 4, 65536 bytes, linear)
      [    0.157094] pinctrl core: initialized pinctrl subsystem
      [    0.157094] PM: RTC time: 11:22:33, date: 2023-12-30
      [    0.157094] NET: Registered protocol family 16
      [    0.157094] audit: initializing netlink subsys (disabled)
      [    0.157094] audit: type=2000 audit(1703935353.032:1): state=initialized audit        _enabled=0 res=1
      [    0.157094] EISA bus registered
      [    0.157094] cpuidle: using governor ladder
      [    0.157094] cpuidle: using governor menu
      [    0.157094] KVM setup pv remote TLB flush
      [    0.157094] ACPI FADT declares the system doesn't support PCIe ASPM, so disab        le it
      [    0.157094] ACPI: bus type PCI registered
      [    0.157094] acpiphp: ACPI Hot Plug PCI Controller Driver version: 0.5
      [    0.157094] PCI: MMCONFIG for domain 0000 [bus 00-ff] at [mem 0xe0000000-0xef        ffffff] (base 0xe0000000)
      [    0.157094] PCI: MMCONFIG at [mem 0xe0000000-0xefffffff] reserved in E820
      [    0.157094] PCI: Using configuration type 1 for base access
      [    0.157094] ENERGY_PERF_BIAS: Set to 'normal', was 'performance'
      [    0.160228] HugeTLB registered 1.00 GiB page size, pre-allocated 0 pages
      [    0.160228] HugeTLB registered 2.00 MiB page size, pre-allocated 0 pages
      [    0.160228] ACPI: Added _OSI(Module Device)
      [    0.160228] ACPI: Added _OSI(Processor Device)
      [    0.160228] ACPI: Added _OSI(3.0 _SCP Extensions)
      [    0.160228] ACPI: Added _OSI(Processor Aggregator Device)
      [    0.160228] ACPI: Added _OSI(Linux-Dell-Video)
      [    0.160228] ACPI: Added _OSI(Linux-Lenovo-NV-HDMI-Audio)
      [    0.160228] ACPI: Added _OSI(Linux-HPI-Hybrid-Graphics)
      [    0.237640] ACPI: 8 ACPI AML tables successfully acquired and loaded
      [    0.249714] ACPI: Dynamic OEM Table Load:
      [    0.249718] ACPI: SSDT 0xFFFF9C566B23A700 0000F4 (v02 PmRef  Cpu0Psd  0000300        0 INTL 20160527)
      [    0.251233] ACPI: \_SB_.PR00: _OSC native thermal LVT Acked
      [    0.253115] ACPI: Dynamic OEM Table Load:
      [    0.253119] ACPI: SSDT 0xFFFF9C566B276000 000400 (v02 PmRef  Cpu0Cst  0000300        1 INTL 20160527)
      [    0.254784] ACPI: Dynamic OEM Table Load:
      [    0.254788] ACPI: SSDT 0xFFFF9C566B747800 000689 (v02 PmRef  Cpu0Ist  0000300        0 INTL 20160527)
      [    0.256547] ACPI: Dynamic OEM Table Load:
      [    0.256550] ACPI: SSDT 0xFFFF9C566B280400 00011B (v02 PmRef  Cpu0Hwp  0000300        0 INTL 20160527)
      [    0.258081] ACPI: Dynamic OEM Table Load:
      [    0.258085] ACPI: SSDT 0xFFFF9C566B746800 000724 (v02 PmRef  HwpLvt   0000300        0 INTL 20160527)
      [    0.259946] ACPI: Dynamic OEM Table Load:
      [    0.259950] ACPI: SSDT 0xFFFF9C566B746000 0005FC (v02 PmRef  ApIst    0000300        0 INTL 20160527)
      [    0.261668] ACPI: Dynamic OEM Table Load:
      [    0.261672] ACPI: SSDT 0xFFFF9C566B277C00 000317 (v02 PmRef  ApHwp    0000300        0 INTL 20160527)
      [    0.263430] ACPI: Dynamic OEM Table Load:
      [    0.263435] ACPI: SSDT 0xFFFF9C566B795000 000AB0 (v02 PmRef  ApPsd    0000300        0 INTL 20160527)
      [    0.265804] ACPI: Dynamic OEM Table Load:
      [    0.265808] ACPI: SSDT 0xFFFF9C566B277800 00030A (v02 PmRef  ApCst    0000300        0 INTL 20160527)
      [    0.269674] ACPI: EC: EC started
      [    0.269674] ACPI: EC: interrupt blocked
      [    0.269702] ACPI: \_SB_.PCI0.LPCB.H_EC: Used as first EC
      [    0.269704] ACPI: \_SB_.PCI0.LPCB.H_EC: GPE=0x14, IRQ=-1, EC_CMD/EC_SC=0x66,        EC_DATA=0x62
      [    0.269705] ACPI: \_SB_.PCI0.LPCB.H_EC: Boot DSDT EC used to handle transacti        ons
      [    0.269705] ACPI: Interpreter enabled
      [    0.269749] ACPI: (supports S0 S3 S4 S5)
      [    0.269749] ACPI: Using IOAPIC for interrupt routing
      [    0.269791] PCI: Using host bridge windows from ACPI; if necessary, use "pci=        nocrs" and report a bug
      [    0.271258] ACPI: Enabled 8 GPEs in block 00 to 7F
      [    0.287244] ACPI: Power Resource [USBC] (on)
      [    0.290894] ACPI: Power Resource [V0PR] (on)
      [    0.291380] ACPI: Power Resource [V1PR] (on)
      [    0.291856] ACPI: Power Resource [V2PR] (on)
      [    0.298763] ACPI: Power Resource [WRST] (on)
      [    0.304748] ACPI: Power Resource [FN00] (off)
      [    0.304847] ACPI: Power Resource [FN01] (off)
      [    0.304943] ACPI: Power Resource [FN02] (off)
      [    0.305041] ACPI: Power Resource [FN03] (off)
      [    0.305137] ACPI: Power Resource [FN04] (off)
      [    0.305918] ACPI: Power Resource [PIN] (off)
      [    0.306498] ACPI: PCI Root Bridge [PCI0] (domain 0000 [bus 00-fe])
      [    0.306504] acpi PNP0A08:00: _OSC: OS supports [ExtendedConfig ASPM ClockPM S        egments MSI HPX-Type3]
      [    0.307920] acpi PNP0A08:00: _OSC: platform does not support [AER]
      [    0.310516] acpi PNP0A08:00: _OSC: OS now controls [PCIeHotplug SHPCHotplug P        ME PCIeCapability LTR]
      [    0.310517] acpi PNP0A08:00: FADT indicates ASPM is unsupported, using BIOS c        onfiguration
      [    0.311572] PCI host bridge to bus 0000:00
      [    0.311574] pci_bus 0000:00: root bus resource [io  0x0000-0x0cf7 window]
      [    0.311575] pci_bus 0000:00: root bus resource [io  0x0d00-0xffff window]
      [    0.311576] pci_bus 0000:00: root bus resource [mem 0x000a0000-0x000bffff win        dow]
      [    0.311577] pci_bus 0000:00: root bus resource [mem 0x000e0000-0x000e3fff win        dow]
      [    0.311578] pci_bus 0000:00: root bus resource [mem 0x000e4000-0x000e7fff win        dow]
      [    0.311579] pci_bus 0000:00: root bus resource [mem 0x000e8000-0x000ebfff win        dow]
      [    0.311579] pci_bus 0000:00: root bus resource [mem 0x000ec000-0x000effff win        dow]
      [    0.311580] pci_bus 0000:00: root bus resource [mem 0x80000000-0xdfffffff win        dow]
      [    0.311581] pci_bus 0000:00: root bus resource [mem 0x4000000000-0x7fffffffff        window]
      [    0.311582] pci_bus 0000:00: root bus resource [mem 0xfc800000-0xfe7fffff win        dow]
      [    0.311583] pci_bus 0000:00: root bus resource [bus 00-fe]
      [    0.311592] pci 0000:00:00.0: [8086:3ecc] type 00 class 0x060000
      [    0.312034] pci 0000:00:02.0: [8086:3ea5] type 00 class 0x030000
      [    0.312045] pci 0000:00:02.0: reg 0x10: [mem 0xa7000000-0xa7ffffff 64bit]
      [    0.312051] pci 0000:00:02.0: reg 0x18: [mem 0x80000000-0x8fffffff 64bit pref        ]
      [    0.312055] pci 0000:00:02.0: reg 0x20: [io  0x4000-0x403f]
      [    0.312253] pci 0000:00:08.0: [8086:1911] type 00 class 0x088000
      [    0.312267] pci 0000:00:08.0: reg 0x10: [mem 0x4022c1a000-0x4022c1afff 64bit]
      [    0.312461] pci 0000:00:12.0: [8086:9df9] type 00 class 0x118000
      [    0.312484] pci 0000:00:12.0: reg 0x10: [mem 0x4022c19000-0x4022c19fff 64bit]
      [    0.312699] pci 0000:00:14.0: [8086:9ded] type 00 class 0x0c0330
      [    0.312719] pci 0000:00:14.0: reg 0x10: [mem 0x4022c00000-0x4022c0ffff 64bit]
      [    0.312779] pci 0000:00:14.0: PME# supported from D3hot D3cold
      [    0.313253] pci 0000:00:14.2: [8086:9def] type 00 class 0x050000
      [    0.313273] pci 0000:00:14.2: reg 0x10: [mem 0x4022c14000-0x4022c15fff 64bit]
      [    0.313283] pci 0000:00:14.2: reg 0x18: [mem 0x4022c18000-0x4022c18fff 64bit]
      [    0.313488] pci 0000:00:14.3: [8086:9df0] type 00 class 0x028000
      [    0.313570] pci 0000:00:14.3: reg 0x10: [mem 0x4022c10000-0x4022c13fff 64bit]
      [    0.313880] pci 0000:00:14.3: PME# supported from D0 D3hot D3cold
      [    0.314100] pci 0000:00:16.0: [8086:9de0] type 00 class 0x078000
      [    0.314127] pci 0000:00:16.0: reg 0x10: [mem 0x4022c17000-0x4022c17fff 64bit]
      [    0.314206] pci 0000:00:16.0: PME# supported from D3hot
      [    0.314463] pci 0000:00:17.0: [8086:9dd3] type 00 class 0x010601
      [    0.314483] pci 0000:00:17.0: reg 0x10: [mem 0xa8b24000-0xa8b25fff]
      [    0.314491] pci 0000:00:17.0: reg 0x14: [mem 0xa8b27000-0xa8b270ff]
      [    0.314500] pci 0000:00:17.0: reg 0x18: [io  0x4090-0x4097]
      [    0.314509] pci 0000:00:17.0: reg 0x1c: [io  0x4080-0x4083]
      [    0.314517] pci 0000:00:17.0: reg 0x20: [io  0x4060-0x407f]
      [    0.314526] pci 0000:00:17.0: reg 0x24: [mem 0xa8b26000-0xa8b267ff]
      [    0.314572] pci 0000:00:17.0: PME# supported from D3hot
      [    0.314784] pci 0000:00:1c.0: [8086:9db8] type 01 class 0x060400
      [    0.314869] pci 0000:00:1c.0: PME# supported from D0 D3hot D3cold
      [    0.315113] pci 0000:00:1c.4: [8086:9dbc] type 01 class 0x060400
      [    0.315290] pci 0000:00:1c.4: PME# supported from D0 D3hot D3cold
      [    0.315312] pci 0000:00:1c.4: PTM enabled (root), 4ns granularity
      [    0.315457] pci 0000:00:1d.0: [8086:9db0] type 01 class 0x060400
      [    0.315548] pci 0000:00:1d.0: PME# supported from D0 D3hot D3cold
      [    0.315566] pci 0000:00:1d.0: PTM enabled (root), 4ns granularity
      [    0.315813] pci 0000:00:1d.6: [8086:9db6] type 01 class 0x060400
      [    0.315984] pci 0000:00:1d.6: PME# supported from D0 D3hot D3cold
      [    0.316004] pci 0000:00:1d.6: PTM enabled (root), 4ns granularity
      [    0.316147] pci 0000:00:1f.0: [8086:9d84] type 00 class 0x060100
      [    0.316521] pci 0000:00:1f.3: [8086:9dc8] type 00 class 0x040380
      [    0.316568] pci 0000:00:1f.3: reg 0x10: [mem 0xa8b20000-0xa8b23fff 64bit]
      [    0.316614] pci 0000:00:1f.3: reg 0x20: [mem 0x4022b00000-0x4022bfffff 64bit]
      [    0.316708] pci 0000:00:1f.3: PME# supported from D3hot D3cold
      [    0.317539] pci 0000:00:1f.4: [8086:9da3] type 00 class 0x0c0500
      [    0.317567] pci 0000:00:1f.4: reg 0x10: [mem 0x4022c16000-0x4022c160ff 64bit]
      [    0.317596] pci 0000:00:1f.4: reg 0x20: [io  0xefa0-0xefbf]
      [    0.317799] pci 0000:00:1f.5: [8086:9da4] type 00 class 0x0c8000
      [    0.317815] pci 0000:00:1f.5: reg 0x10: [mem 0xfe010000-0xfe010fff]
      [    0.318000] pci 0000:00:1f.6: [8086:15be] type 00 class 0x020000
      [    0.318046] pci 0000:00:1f.6: reg 0x10: [mem 0xa8b00000-0xa8b1ffff]
      [    0.318231] pci 0000:00:1f.6: PME# supported from D0 D3hot D3cold
      [    0.318522] acpiphp: Slot [1] registered
      [    0.318531] pci 0000:00:1c.0: PCI bridge to [bus 01]
      [    0.318663] pci 0000:00:1c.4: PCI bridge to [bus 02-3a]
      [    0.318667] pci 0000:00:1c.4:   bridge window [mem 0x90000000-0xa60fffff]
      [    0.318671] pci 0000:00:1c.4:   bridge window [mem 0x4000000000-0x4021ffffff        64bit pref]
      [    0.318857] pci 0000:3b:00.0: [2646:2263] type 00 class 0x010802
      [    0.318890] pci 0000:3b:00.0: reg 0x10: [mem 0xa8a00000-0xa8a03fff 64bit]
      [    0.319184] pci 0000:00:1d.0: PCI bridge to [bus 3b]
      [    0.319188] pci 0000:00:1d.0:   bridge window [mem 0xa8a00000-0xa8afffff]
      [    0.319399] pci 0000:3c:00.0: [10ec:522a] type 00 class 0xff0000
      [    0.319427] pci 0000:3c:00.0: reg 0x10: [mem 0xa8000000-0xa8000fff]
      [    0.319563] pci 0000:3c:00.0: supports D1 D2
      [    0.319564] pci 0000:3c:00.0: PME# supported from D1 D2 D3hot D3cold
      [    0.319735] pci 0000:00:1d.6: ASPM: current common clock configuration is bro        ken, reconfiguring
      [    0.331929] pci 0000:00:1d.6: PCI bridge to [bus 3c]
      [    0.331932] pci 0000:00:1d.6:   bridge window [io  0x3000-0x3fff]
      [    0.331934] pci 0000:00:1d.6:   bridge window [mem 0xa8000000-0xa89fffff]
      [    0.331938] pci 0000:00:1d.6:   bridge window [mem 0x4022100000-0x4022afffff        64bit pref]
      [    0.333784] ACPI: PCI Interrupt Link [LNKA] (IRQs 3 4 5 6 10 11 12 14 15) *0
      [    0.333884] ACPI: PCI Interrupt Link [LNKB] (IRQs 3 4 5 6 10 11 12 14 15) *1
      [    0.333984] ACPI: PCI Interrupt Link [LNKC] (IRQs 3 4 5 6 10 11 12 14 15) *0
      [    0.334083] ACPI: PCI Interrupt Link [LNKD] (IRQs 3 4 5 6 10 11 12 14 15) *0
      [    0.334180] ACPI: PCI Interrupt Link [LNKE] (IRQs 3 4 5 6 10 11 12 14 15) *0
      [    0.334277] ACPI: PCI Interrupt Link [LNKF] (IRQs 3 4 5 6 10 11 12 14 15) *0
      [    0.334374] ACPI: PCI Interrupt Link [LNKG] (IRQs 3 4 5 6 10 11 12 14 15) *0
      [    0.334470] ACPI: PCI Interrupt Link [LNKH] (IRQs 3 4 5 6 10 11 12 14 15) *0
      [    0.335329] ACPI: EC: interrupt unblocked
      [    0.335329] ACPI: EC: event unblocked
      [    0.335347] ACPI: \_SB_.PCI0.LPCB.H_EC: GPE=0x14, IRQ=-1, EC_CMD/EC_SC=0x66,        EC_DATA=0x62
      [    0.335348] ACPI: \_SB_.PCI0.LPCB.H_EC: Boot DSDT EC used to handle transacti        ons and events
      [    0.335807] iommu: Default domain type: Translated
      [    0.335930] SCSI subsystem initialized
      [    0.335934] libata version 3.00 loaded.
      [    0.335934] pci 0000:00:02.0: vgaarb: setting as boot VGA device
      [    0.335934] pci 0000:00:02.0: vgaarb: VGA device added: decodes=io+mem,owns=i        o+mem,locks=none
      [    0.335934] pci 0000:00:02.0: vgaarb: bridge control possible
      [    0.335934] vgaarb: loaded
      [    0.335934] ACPI: bus type USB registered
      [    0.335934] usbcore: registered new interface driver usbfs
      [    0.335934] usbcore: registered new interface driver hub
      [    0.335934] usbcore: registered new device driver usb
      [    0.335934] pps_core: LinuxPPS API ver. 1 registered
      [    0.335934] pps_core: Software ver. 5.3.6 - Copyright 2005-2007 Rodolfo Giome        tti <giometti@linux.it>
      [    0.335934] PTP clock support registered
      [    0.335934] EDAC MC: Ver: 3.0.0
      [    0.335952] Registered efivars operations
      [    0.335952] PCI: Using ACPI for IRQ routing
      [    0.371170] PCI: pci_cache_line_size set to 64 bytes
      [    0.371487] e820: reserve RAM buffer [mem 0x0009f000-0x0009ffff]
      [    0.371488] e820: reserve RAM buffer [mem 0x79e7f000-0x7bffffff]
      [    0.371489] e820: reserve RAM buffer [mem 0x7ad0f000-0x7bffffff]
      [    0.371490] e820: reserve RAM buffer [mem 0x47e000000-0x47fffffff]
      [    0.371572] NetLabel: Initializing
      [    0.371573] NetLabel:  domain hash size = 128
      [    0.371573] NetLabel:  protocols = UNLABELED CIPSOv4 CALIPSO
      [    0.371584] NetLabel:  unlabeled traffic allowed by default
      [    0.371834] hpet0: at MMIO 0xfed00000, IRQs 2, 8, 0, 0, 0, 0, 0, 0
      [    0.371837] hpet0: 8 comparators, 64-bit 24.000000 MHz counter
      [    0.375800] clocksource: Switched to clocksource tsc-early
      [    0.385941] *** VALIDATE bpf ***
      [    0.385995] VFS: Disk quotas dquot_6.6.0
      [    0.386007] VFS: Dquot-cache hash table entries: 512 (order 0, 4096 bytes)
      [    0.386027] *** VALIDATE ramfs ***
      [    0.386029] *** VALIDATE hugetlbfs ***
      [    0.386095] AppArmor: AppArmor Filesystem Enabled
      [    0.386121] pnp: PnP ACPI init
      [    0.386248] system 00:00: [mem 0x40000000-0x403fffff] could not be reserved
      [    0.386252] system 00:00: Plug and Play ACPI device, IDs PNP0c02 (active)
      [    0.386682] system 00:01: [io  0x0a00-0x0a1f] has been reserved
      [    0.386683] system 00:01: [io  0x0a20-0x0a2f] has been reserved
      [    0.386684] system 00:01: [io  0x0a30-0x0a3f] has been reserved
      [    0.386685] system 00:01: [io  0x0a40-0x0a4f] has been reserved
      [    0.386686] system 00:01: [io  0x0a50-0x0a5f] has been reserved
      [    0.386687] system 00:01: [io  0x0a60-0x0a6f] has been reserved
      [    0.386690] system 00:01: Plug and Play ACPI device, IDs PNP0c02 (active)
      [    0.386945] system 00:02: [io  0x0680-0x069f] has been reserved
      [    0.386946] system 00:02: [io  0x164e-0x164f] has been reserved
      [    0.386949] system 00:02: Plug and Play ACPI device, IDs PNP0c02 (active)
      [    0.387075] system 00:03: [io  0x1854-0x1857] has been reserved
      [    0.387077] system 00:03: Plug and Play ACPI device, IDs INT3f0d PNP0c02 (act        ive)
      [    0.387317] system 00:04: [mem 0xfed10000-0xfed17fff] has been reserved
      [    0.387318] system 00:04: [mem 0xfed18000-0xfed18fff] has been reserved
      [    0.387319] system 00:04: [mem 0xfed19000-0xfed19fff] has been reserved
      [    0.387320] system 00:04: [mem 0xe0000000-0xefffffff] has been reserved
      [    0.387321] system 00:04: [mem 0xfed20000-0xfed3ffff] has been reserved
      [    0.387322] system 00:04: [mem 0xfed90000-0xfed93fff] could not be reserved
      [    0.387323] system 00:04: [mem 0xfed45000-0xfed8ffff] has been reserved
      [    0.387324] system 00:04: [mem 0xfee00000-0xfeefffff] could not be reserved
      [    0.387327] system 00:04: Plug and Play ACPI device, IDs PNP0c02 (active)
      [    0.387573] system 00:05: [io  0x1800-0x18fe] could not be reserved
      [    0.387575] system 00:05: [mem 0xfd000000-0xfd69ffff] has been reserved
      [    0.387576] system 00:05: [mem 0xfd6b0000-0xfd6cffff] has been reserved
      [    0.387577] system 00:05: [mem 0xfd6f0000-0xfdffffff] has been reserved
      [    0.387578] system 00:05: [mem 0xfe000000-0xfe01ffff] could not be reserved
      [    0.387579] system 00:05: [mem 0xfe200000-0xfe7fffff] has been reserved
      [    0.387580] system 00:05: [mem 0xff000000-0xffffffff] has been reserved
      [    0.387582] system 00:05: Plug and Play ACPI device, IDs PNP0c02 (active)
      [    0.387926] system 00:06: [io  0x2000-0x20fe] has been reserved
      [    0.387929] system 00:06: Plug and Play ACPI device, IDs PNP0c02 (active)
      [    0.389159] system 00:07: Plug and Play ACPI device, IDs PNP0c02 (active)
      [    0.390263] pnp: PnP ACPI: found 8 devices
      [    0.391233] thermal_sys: Registered thermal governor 'fair_share'
      [    0.391233] thermal_sys: Registered thermal governor 'bang_bang'
      [    0.391234] thermal_sys: Registered thermal governor 'step_wise'
      [    0.391234] thermal_sys: Registered thermal governor 'user_space'
      [    0.391235] thermal_sys: Registered thermal governor 'power_allocator'
      [    0.395728] clocksource: acpi_pm: mask: 0xffffff max_cycles: 0xffffff, max_id        le_ns: 2085701024 ns
      [    0.395757] pci 0000:00:1c.4: bridge window [io  0x1000-0x0fff] to [bus 02-3a        ] add_size 1000
      [    0.395763] pci 0000:00:1c.4: BAR 13: assigned [io  0x5000-0x5fff]
      [    0.395765] pci 0000:00:1c.0: PCI bridge to [bus 01]
      [    0.395778] pci 0000:00:1c.4: PCI bridge to [bus 02-3a]
      [    0.395781] pci 0000:00:1c.4:   bridge window [io  0x5000-0x5fff]
      [    0.395787] pci 0000:00:1c.4:   bridge window [mem 0x90000000-0xa60fffff]
      [    0.395792] pci 0000:00:1c.4:   bridge window [mem 0x4000000000-0x4021ffffff        64bit pref]
      [    0.395796] pci 0000:00:1d.0: PCI bridge to [bus 3b]
      [    0.395800] pci 0000:00:1d.0:   bridge window [mem 0xa8a00000-0xa8afffff]
      [    0.395805] pci 0000:00:1d.6: PCI bridge to [bus 3c]
      [    0.395807] pci 0000:00:1d.6:   bridge window [io  0x3000-0x3fff]
      [    0.395810] pci 0000:00:1d.6:   bridge window [mem 0xa8000000-0xa89fffff]
      [    0.395812] pci 0000:00:1d.6:   bridge window [mem 0x4022100000-0x4022afffff        64bit pref]
      [    0.395817] pci_bus 0000:00: resource 4 [io  0x0000-0x0cf7 window]
      [    0.395818] pci_bus 0000:00: resource 5 [io  0x0d00-0xffff window]
      [    0.395819] pci_bus 0000:00: resource 6 [mem 0x000a0000-0x000bffff window]
      [    0.395820] pci_bus 0000:00: resource 7 [mem 0x000e0000-0x000e3fff window]
      [    0.395820] pci_bus 0000:00: resource 8 [mem 0x000e4000-0x000e7fff window]
      [    0.395821] pci_bus 0000:00: resource 9 [mem 0x000e8000-0x000ebfff window]
      [    0.395822] pci_bus 0000:00: resource 10 [mem 0x000ec000-0x000effff window]
      [    0.395823] pci_bus 0000:00: resource 11 [mem 0x80000000-0xdfffffff window]
      [    0.395824] pci_bus 0000:00: resource 12 [mem 0x4000000000-0x7fffffffff windo        w]
      [    0.395825] pci_bus 0000:00: resource 13 [mem 0xfc800000-0xfe7fffff window]
      [    0.395826] pci_bus 0000:02: resource 0 [io  0x5000-0x5fff]
      [    0.395827] pci_bus 0000:02: resource 1 [mem 0x90000000-0xa60fffff]
      [    0.395828] pci_bus 0000:02: resource 2 [mem 0x4000000000-0x4021ffffff 64bit        pref]
      [    0.395828] pci_bus 0000:3b: resource 1 [mem 0xa8a00000-0xa8afffff]
      [    0.395829] pci_bus 0000:3c: resource 0 [io  0x3000-0x3fff]
      [    0.395830] pci_bus 0000:3c: resource 1 [mem 0xa8000000-0xa89fffff]
      [    0.395831] pci_bus 0000:3c: resource 2 [mem 0x4022100000-0x4022afffff 64bit        pref]
      [    0.396004] NET: Registered protocol family 2
      [    0.396182] IP idents hash table entries: 262144 (order: 9, 2097152 bytes, li        near)
      [    0.397760] tcp_listen_portaddr_hash hash table entries: 8192 (order: 5, 1310        72 bytes, linear)
      [    0.397853] TCP established hash table entries: 131072 (order: 8, 1048576 byt        es, linear)
      [    0.398037] TCP bind hash table entries: 65536 (order: 8, 1048576 bytes, line        ar)
      [    0.398097] TCP: Hash tables configured (established 131072 bind 65536)
      [    0.398146] UDP hash table entries: 8192 (order: 6, 262144 bytes, linear)
      [    0.398193] UDP-Lite hash table entries: 8192 (order: 6, 262144 bytes, linear        )
      [    0.398245] NET: Registered protocol family 1
      [    0.398248] NET: Registered protocol family 44
      [    0.398260] pci 0000:00:02.0: Video device with shadowed ROM at [mem 0x000c00        00-0x000dffff]
      [    0.398759] PCI: CLS 64 bytes, default 64
      [    0.398798] Trying to unpack rootfs image as initramfs...
      [    1.073314] Freeing initrd memory: 47916K
      [    1.091860] PCI-DMA: Using software bounce buffering for IO (SWIOTLB)
      [    1.091862] software IO TLB: mapped [mem 0x73fb8000-0x77fb8000] (64MB)
      [    1.092045] platform rtc_cmos: registered platform RTC device (no PNP device        found)
      [    1.092088] check: Scanning for low memory corruption every 60 seconds
      [    1.092445] Initialise system trusted keyrings
      [    1.092454] Key type blacklist registered
      [    1.092479] workingset: timestamp_bits=36 max_order=22 bucket_order=0
      [    1.093487] zbud: loaded
      [    1.093766] squashfs: version 4.0 (2009/01/31) Phillip Lougher
      [    1.093882] fuse: init (API version 7.31)
      [    1.093894] *** VALIDATE fuse ***
      [    1.093895] *** VALIDATE fuse ***
      [    1.093971] Platform Keyring initialized
      [    1.096802] Key type asymmetric registered
      [    1.096803] Asymmetric key parser 'x509' registered
      [    1.096809] Block layer SCSI generic (bsg) driver version 0.4 loaded (major 2        44)
      [    1.096835] io scheduler mq-deadline registered
      [    1.097029] pcieport 0000:00:1c.0: PME: Signaling with IRQ 122
      [    1.097334] pcieport 0000:00:1c.4: PME: Signaling with IRQ 123
      [    1.097361] pcieport 0000:00:1c.4: pciehp: Slot #8 AttnBtn- PwrCtrl- MRL- Att        nInd- PwrInd- HotPlug+ Surprise+ Interlock- NoCompl+ LLActRep+
      [    1.097677] pcieport 0000:00:1d.0: PME: Signaling with IRQ 124
      [    1.097900] pcieport 0000:00:1d.6: PME: Signaling with IRQ 125
      [    1.097923] pcieport 0000:00:1d.6: pciehp: Slot #18 AttnBtn- PwrCtrl- MRL- At        tnInd- PwrInd- HotPlug+ Surprise+ Interlock- NoCompl+ LLActRep+
      [    1.098022] shpchp: Standard Hot Plug PCI Controller Driver version: 0.4
      [    1.098066] intel_idle: MWAIT substates: 0x11142120
      [    1.098067] intel_idle: v0.4.1 model 0x8E
      [    1.098242] intel_idle: lapic_timer_reliable_states 0xffffffff
      [    1.098403] input: Sleep Button as /devices/LNXSYSTM:00/LNXSYBUS:00/PNP0C0E:0        0/input/input0
      [    1.098419] ACPI: Sleep Button [SLPB]
      [    1.098443] input: Power Button as /devices/LNXSYSTM:00/LNXSYBUS:00/PNP0C0C:0        0/input/input1
      [    1.098454] ACPI: Power Button [PWRB]
      [    1.098476] input: Power Button as /devices/LNXSYSTM:00/LNXPWRBN:00/input/inp        ut2
      [    1.098500] ACPI: Power Button [PWRF]
      [    1.099498] thermal LNXTHERM:00: registered as thermal_zone0
      [    1.099499] ACPI: Thermal Zone [TZ0] (-263 C)
      [    1.100012] thermal LNXTHERM:01: registered as thermal_zone1
      [    1.100013] ACPI: Thermal Zone [TZ00] (28 C)
      [    1.100173] Serial: 8250/16550 driver, 32 ports, IRQ sharing enabled
      [    1.101854] Linux agpgart interface v0.103
      [    1.308051] loop: module loaded
      [    1.308650] nvme nvme0: pci function 0000:3b:00.0
      [    1.308740] libphy: Fixed MDIO Bus: probed
      [    1.308741] tun: Universal TUN/TAP device driver, 1.6
      [    1.308774] PPP generic driver version 2.4.2
      [    1.308832] i8042: PNP: No PS/2 controller found.
      [    1.308833] i8042: Probing ports directly.
      [    1.310130] i8042: No controller found
      [    1.310182] mousedev: PS/2 mouse device common for all mice
      [    1.310305] rtc_cmos rtc_cmos: RTC can wake from S4
      [    1.311100] rtc_cmos rtc_cmos: registered as rtc0
      [    1.311109] rtc_cmos rtc_cmos: alarms up to one month, y3k, 114 bytes nvram,
        GOETSCHHOFER @GOETSCHHOFER last edited by GOETSCHHOFER
        @crunchip
        1. TEIL:
        hpet irqs
        [    1.311113] i2c /dev entries driver
        [    1.311151] device-mapper: uevent: version 1.0.3
        [    1.311193] device-mapper: ioctl: 4.41.0-ioctl (2019-09-16) initialised: dm-d        evel@redhat.com
        [    1.311209] platform eisa.0: Probing EISA bus 0
        [    1.311210] platform eisa.0: EISA: Cannot allocate resource for mainboard
        [    1.311211] platform eisa.0: Cannot allocate resource for EISA slot 1
        [    1.311212] platform eisa.0: Cannot allocate resource for EISA slot 2
        [    1.311213] platform eisa.0: Cannot allocate resource for EISA slot 3
        [    1.311214] platform eisa.0: Cannot allocate resource for EISA slot 4
        [    1.311214] platform eisa.0: Cannot allocate resource for EISA slot 5
        [    1.311215] platform eisa.0: Cannot allocate resource for EISA slot 6
        [    1.311216] platform eisa.0: Cannot allocate resource for EISA slot 7
        [    1.311216] platform eisa.0: Cannot allocate resource for EISA slot 8
        [    1.311217] platform eisa.0: EISA: Detected 0 cards
        [    1.311219] intel_pstate: Intel P-state driver initializing
        [    1.311519] intel_pstate: HWP enabled
        [    1.311540] ledtrig-cpu: registered to indicate activity on CPUs
        [    1.311543] EFI Variables Facility v0.08 2004-May-17
        [    1.330147] intel_pmc_core INT33A1:00:  initialized
        [    1.330211] drop_monitor: Initializing network drop monitor service
        [    1.330319] NET: Registered protocol family 10
        [    1.334709] Segment Routing with IPv6
        [    1.334728] NET: Registered protocol family 17
        [    1.334745] Bridge firewalling registered
        [    1.334764] Key type dns_resolver registered
        [    1.334936] RAS: Correctable Errors collector initialized.
        [    1.334962] microcode: sig=0x806ea, pf=0x40, revision=0xca
        [    1.335039] microcode: Microcode Update Driver: v2.2.
        [    1.335043] IPI shorthand broadcast: enabled
        [    1.335048] sched_clock: Marking stable (1330485294, 4549088)->(1336074378, -        1039996)
        [    1.335095] registered taskstats version 1
        [    1.335102] Loading compiled-in X.509 certificates
        [    1.335120] zswap: loaded using pool lzo/zbud
        [    1.335169] Key type ._fscrypt registered
        [    1.335170] Key type .fscrypt registered
        [    1.339321] Key type big_key registered
        [    1.339325] Key type trusted registered
        [    1.341363] Key type encrypted registered
        [    1.341367] AppArmor: AppArmor sha1 policy hashing enabled
        [    1.342131] integrity: Loading X.509 certificate: UEFI:db
        [    1.342155] integrity: Loaded X.509 cert 'Microsoft Corporation UEFI CA 2011:        13adbf4309bd82709c8cd54f316ed522988a1bd4'
        [    1.342156] integrity: Loading X.509 certificate: UEFI:db
        [    1.342169] integrity: Loaded X.509 cert 'Microsoft Windows Production PCA 20        11: a92902398e16c49778cd90f99e4f9ae17c55af53'
        [    1.342169] integrity: Loading X.509 certificate: UEFI:db
        [    1.342440] integrity: Loaded X.509 cert 'CISD FW Update - Certificate: 06826        8b4a41c93854262d49b4f788f13'
        [    1.343219] ima: Allocated hash algorithm: sha1
        [    1.357568] ima: No architecture policies found
        [    1.357575] evm: Initialising EVM extended attributes:
        [    1.357575] evm: security.selinux
        [    1.357575] evm: security.SMACK64
        [    1.357576] evm: security.SMACK64EXEC
        [    1.357576] evm: security.SMACK64TRANSMUTE
        [    1.357576] evm: security.SMACK64MMAP
        [    1.357577] evm: security.apparmor
        [    1.357577] evm: security.ima
        [    1.357577] evm: security.capability
        [    1.357578] evm: HMAC attrs: 0x1
        [    1.359381] PM:   Magic number: 3:282:379
        [    1.359666] rtc_cmos rtc_cmos: setting system clock to 2023-12-30T11:22:34 UT        C (1703935354)
        [    1.524900] nvme nvme0: missing or invalid SUBNQN field.
        [    1.527514] nvme nvme0: 4/0/0 default/read/poll queues
        [    1.528665]  nvme0n1: p1 p2 p3
        [    1.548801] Freeing unused decrypted memory: 2040K
        [    1.549235] Freeing unused kernel image memory: 2708K
        [    1.549291] Write protecting the kernel read-only data: 22528k
        [    1.549707] Freeing unused kernel image memory: 2008K
        [    1.549962] Freeing unused kernel image memory: 1148K
        [    1.556435] x86/mm: Checked W+X mappings: passed, no W+X pages found.
        [    1.556436] x86/mm: Checking user space page tables
        [    1.562783] x86/mm: Checked W+X mappings: passed, no W+X pages found.
        [    1.562786] Run /init as init process
        [    1.679113] acpi PNP0C14:02: duplicate WMI GUID 05901221-D566-11D1-B2F0-00A0C        9062910 (first instance was on PNP0C14:01)
        [    1.679178] acpi PNP0C14:03: duplicate WMI GUID 05901221-D566-11D1-B2F0-00A0C        9062910 (first instance was on PNP0C14:01)
        [    1.681971] xhci_hcd 0000:00:14.0: xHCI Host Controller
        [    1.681979] xhci_hcd 0000:00:14.0: new USB bus registered, assigned bus numbe        r 1
        [    1.682064] i801_smbus 0000:00:1f.4: SPD Write Disable is set
        [    1.682121] i801_smbus 0000:00:1f.4: SMBus using PCI interrupt
        [    1.682776] e1000e: Intel(R) PRO/1000 Network Driver - 3.2.6-k
        [    1.682777] e1000e: Copyright(c) 1999 - 2015 Intel Corporation.
        [    1.682809] ahci 0000:00:17.0: version 3.0
        [    1.683054] xhci_hcd 0000:00:14.0: hcc params 0x200077c1 hci version 0x110 qu        irks 0x0000000000009810
        [    1.683064] xhci_hcd 0000:00:14.0: cache line size of 64 is not supported
        [    1.683134] ahci 0000:00:17.0: AHCI 0001.0301 32 slots 1 ports 6 Gbps 0x4 imp        l SATA mode
        [    1.683136] ahci 0000:00:17.0: flags: 64bit ncq sntf pm clo only pio slum par        t deso sadm sds apst
        [    1.683191] e1000e 0000:00:1f.6: Interrupt Throttling Rate (ints/sec) set to        dynamic conservative mode
        [    1.683343] usb usb1: New USB device found, idVendor=1d6b, idProduct=0002, bc        dDevice= 5.04
        [    1.683344] usb usb1: New USB device strings: Mfr=3, Product=2, SerialNumber=        1
        [    1.683345] usb usb1: Product: xHCI Host Controller
        [    1.683346] usb usb1: Manufacturer: Linux 5.4.143-1-pve xhci-hcd
        [    1.683346] usb usb1: SerialNumber: 0000:00:14.0
        [    1.684065] hub 1-0:1.0: USB hub found
        [    1.684194] hub 1-0:1.0: 12 ports detected
        [    1.690985] xhci_hcd 0000:00:14.0: xHCI Host Controller
        [    1.690988] xhci_hcd 0000:00:14.0: new USB bus registered, assigned bus numbe        r 2
        [    1.690992] xhci_hcd 0000:00:14.0: Host supports USB 3.1 Enhanced SuperSpeed
        [    1.691027] usb usb2: New USB device found, idVendor=1d6b, idProduct=0003, bc        dDevice= 5.04
        [    1.691028] usb usb2: New USB device strings: Mfr=3, Product=2, SerialNumber=        1
        [    1.691030] usb usb2: Product: xHCI Host Controller
        [    1.691031] usb usb2: Manufacturer: Linux 5.4.143-1-pve xhci-hcd
        [    1.691032] usb usb2: SerialNumber: 0000:00:14.0
        [    1.691249] hub 2-0:1.0: USB hub found
        [    1.691262] hub 2-0:1.0: 6 ports detected
        [    1.692288] usb: port power management may be unreliable
        [    1.697037] scsi host0: ahci
        [    1.707131] scsi host1: ahci
        [    1.707297] scsi host2: ahci
        [    1.707331] ata1: DUMMY
        [    1.707332] ata2: DUMMY
        [    1.707338] ata3: SATA max UDMA/133 abar m2048@0xa8b26000 port 0xa8b26200 irq        132
        [    1.897964] e1000e 0000:00:1f.6 0000:00:1f.6 (uninitialized): registered PHC        clock
        [    1.968176] e1000e 0000:00:1f.6 eth0: (PCI Express:2.5GT/s:Width x1) 1c:69:7a        :a1:24:1b
        [    1.968178] e1000e 0000:00:1f.6 eth0: Intel(R) PRO/1000 Network Connection
        [    1.968301] e1000e 0000:00:1f.6 eth0: MAC: 13, PHY: 12, PBA No: FFFFFF-0FF
        [    1.984909] e1000e 0000:00:1f.6 eno1: renamed from eth0
        [    2.024007] usb 1-10: new full-speed USB device number 2 using xhci_hcd
        [    2.024804] ata3: SATA link down (SStatus 4 SControl 300)
        [    2.079244] fbcon: Taking over console
        [    2.108012] tsc: Refined TSC clocksource calibration: 2999.998 MHz
        [    2.108017] clocksource: tsc: mask: 0xffffffffffffffff max_cycles: 0x2b3e43c8        763, max_idle_ns: 440795360101 ns
        [    2.108028] clocksource: Switched to clocksource tsc
        [    2.172763] usb 1-10: New USB device found, idVendor=8087, idProduct=0aaa, bc        dDevice= 0.02
        [    2.172764] usb 1-10: New USB device strings: Mfr=0, Product=0, SerialNumber=        0
        [    2.299909] usb 2-1: new SuperSpeed Gen 1 USB device number 2 using xhci_hcd
        [    2.320660] usb 2-1: New USB device found, idVendor=0781, idProduct=5581, bcd        Device= 1.00
        [    2.320661] usb 2-1: New USB device strings: Mfr=1, Product=2, SerialNumber=3
        [    2.320662] usb 2-1: Product:  SanDisk 3.2Gen1
        [    2.320663] usb 2-1: Manufacturer:  USB
        [    2.320663] usb 2-1: SerialNumber: 09012f2628e4c2ae279e230673d5c0e627351182b2        2493c32e6e4d1e7fe6d0701a770000000000000000000090dea40000905a2081558107b0a88e10
        [    2.322469] usb-storage 2-1:1.0: USB Mass Storage device detected
        [    2.322535] scsi host3: usb-storage 2-1:1.0
        [    2.322600] usbcore: registered new interface driver usb-storage
        [    2.322860] usbcore: registered new interface driver uas
        [    2.448098] usb 2-3: new SuperSpeed Gen 1 USB device number 3 using xhci_hcd
        [    2.472695] usb 2-3: New USB device found, idVendor=0781, idProduct=5588, bcd        Device= 1.00
        [    2.472696] usb 2-3: New USB device strings: Mfr=2, Product=3, SerialNumber=1
        [    2.472697] usb 2-3: Product: USB Extreme Pro
        [    2.472698] usb 2-3: Manufacturer: SanDisk
        [    2.472699] usb 2-3: SerialNumber: 00000000000000000000
        [    2.473660] usb-storage 2-3:1.0: USB Mass Storage device detected
        [    2.473710] scsi host4: usb-storage 2-3:1.0
        [    2.779826] raid6: avx2x4   gen() 35854 MB/s
        [    2.827818] raid6: avx2x4   xor() 22567 MB/s
        [    2.875825] raid6: avx2x2   gen() 31198 MB/s
        [    2.923825] raid6: avx2x2   xor() 19857 MB/s
        [    2.971825] raid6: avx2x1   gen() 23565 MB/s
        [    3.019827] raid6: avx2x1   xor() 17962 MB/s
        [    3.067825] raid6: sse2x4   gen() 14839 MB/s
        [    3.115824] raid6: sse2x4   xor()  9338 MB/s
        [    3.163826] raid6: sse2x2   gen() 12829 MB/s
        [    3.211825] raid6: sse2x2   xor()  8574 MB/s
        [    3.259825] raid6: sse2x1   gen()  9977 MB/s
        [    3.307826] raid6: sse2x1   xor()  6595 MB/s
        [    3.307827] raid6: using algorithm avx2x4 gen() 35854 MB/s
        [    3.307827] raid6: .... xor() 22567 MB/s, rmw enabled
        [    3.307828] raid6: using avx2x2 recovery algorithm
        [    3.308348] xor: automatically using best checksumming function   avx
        [    3.314026] Btrfs loaded, crc32c=crc32c-intel
        [    3.324374] scsi 3:0:0:0: Direct-Access      USB      SanDisk 3.2Gen1 1.00 PQ        : 0 ANSI: 6
        [    3.324537] sd 3:0:0:0: Attached scsi generic sg0 type 0
        [    3.324720] sd 3:0:0:0: [sda] 30629376 512-byte logical blocks: (15.7 GB/14.6        GiB)
        [    3.325752] sd 3:0:0:0: [sda] Write Protect is off
        [    3.325754] sd 3:0:0:0: [sda] Mode Sense: 43 00 00 00
        [    3.326020] sd 3:0:0:0: [sda] Write cache: disabled, read cache: enabled, doe        sn't support DPO or FUA
        [    3.380461] sd 3:0:0:0: [sda] tag#0 FAILED Result: hostbyte=DID_OK driverbyte        =DRIVER_SENSE
        [    3.380463] sd 3:0:0:0: [sda] tag#0 Sense Key : Medium Error [current]
        [    3.380464] sd 3:0:0:0: [sda] tag#0 Add. Sense: Unrecovered read error
        [    3.380466] sd 3:0:0:0: [sda] tag#0 CDB: Read(10) 28 00 00 00 00 00 00 00 08        00
        [    3.380467] blk_update_request: critical medium error, dev sda, sector 0 op 0        x0:(READ) flags 0x0 phys_seg 1 prio class 0
        [    3.380473] Buffer I/O error on dev sda, logical block 0, async page read
        [    3.453332] sd 3:0:0:0: [sda] tag#0 FAILED Result: hostbyte=DID_OK driverbyte        =DRIVER_SENSE
        [    3.453334] sd 3:0:0:0: [sda] tag#0 Sense Key : Medium Error [current]
        [    3.453335] sd 3:0:0:0: [sda] tag#0 Add. Sense: Unrecovered read error
        [    3.453336] sd 3:0:0:0: [sda] tag#0 CDB: Read(10) 28 00 00 00 00 08 00 00 08        00
        [    3.453338] blk_update_request: critical medium error, dev sda, sector 8 op 0        x0:(READ) flags 0x0 phys_seg 1 prio class 0
        [    3.453343] Buffer I/O error on dev sda, logical block 1, async page read
        [    3.453388] Dev sda: unable to read RDB block 8
        [    3.484464] scsi 4:0:0:0: Direct-Access     SanDisk  Extreme Pro      0    PQ        : 0 ANSI: 6
        [    3.484720] sd 4:0:0:0: Attached scsi generic sg1 type 0
        [    3.484971] sd 4:0:0:0: [sdb] 250085376 512-byte logical blocks: (128 GB/119        GiB)
        [    3.485364] sd 4:0:0:0: [sdb] Write Protect is off
        [    3.485366] sd 4:0:0:0: [sdb] Mode Sense: 43 00 00 00
        [    3.485574] sd 4:0:0:0: [sdb] Write cache: enabled, read cache: enabled, does        n't support DPO or FUA
        [    3.488033] sd 3:0:0:0: [sda] tag#0 FAILED Result: hostbyte=DID_OK driverbyte        =DRIVER_SENSE
        [    3.488035] sd 3:0:0:0: [sda] tag#0 Sense Key : Medium Error [current]
        [    3.488036] sd 3:0:0:0: [sda] tag#0 Add. Sense: Unrecovered read error
        [    3.488037] sd 3:0:0:0: [sda] tag#0 CDB: Read(10) 28 00 00 00 00 18 00 00 08        00
        [    3.488039] blk_update_request: critical medium error, dev sda, sector 24 op        0x0:(READ) flags 0x0 phys_seg 1 prio class 0
        [    3.488043] Buffer I/O error on dev sda, logical block 3, async page read
        [    3.488053]  sda: unable to read partition table
        [    3.521078]  sdb: sdb1
        [    3.549146] sd 4:0:0:0: [sdb] Attached SCSI removable disk
        [    3.555318] sd 3:0:0:0: [sda] tag#0 FAILED Result: hostbyte=DID_OK driverbyte        =DRIVER_SENSE
        [    3.555320] sd 3:0:0:0: [sda] tag#0 Sense Key : Medium Error [current]
        [    3.555321] sd 3:0:0:0: [sda] tag#0 Add. Sense: Unrecovered read error
        [    3.555323] sd 3:0:0:0: [sda] tag#0 CDB: Read(10) 28 00 01 d3 5d 80 00 00 08        00
        [    3.555324] blk_update_request: critical medium error, dev sda, sector 306292        48 op 0x0:(READ) flags 0x80700 phys_seg 1 prio class 0
        [    3.556690] sd 3:0:0:0: [sda] Attached SCSI removable disk
        [    3.629328] sd 3:0:0:0: [sda] tag#0 FAILED Result: hostbyte=DID_OK driverbyte        =DRIVER_SENSE
        [    3.629330] sd 3:0:0:0: [sda] tag#0 Sense Key : Medium Error [current]
        [    3.629331] sd 3:0:0:0: [sda] tag#0 Add. Sense: Unrecovered read error
        [    3.629332] sd 3:0:0:0: [sda] tag#0 CDB: Read(10) 28 00 01 d3 5d f0 00 00 08        00
        [    3.629335] blk_update_request: critical medium error, dev sda, sector 306293        60 op 0x0:(READ) flags 0x80700 phys_seg 1 prio class 0
        [    3.698838] sd 3:0:0:0: [sda] tag#0 FAILED Result: hostbyte=DID_OK driverbyte        =DRIVER_SENSE
        [    3.698840] sd 3:0:0:0: [sda] tag#0 Sense Key : Medium Error [current]
        [    3.698841] sd 3:0:0:0: [sda] tag#0 Add. Sense: Unrecovered read error
        [    3.698843] sd 3:0:0:0: [sda] tag#0 CDB: Read(10) 28 00 00 00 00 00 00 00 08        00
        [    3.698844] blk_update_request: critical medium error, dev sda, sector 0 op 0        x0:(READ) flags 0x80700 phys_seg 1 prio class 0
        [    3.771582] sd 3:0:0:0: [sda] tag#0 FAILED Result: hostbyte=DID_OK driverbyte        =DRIVER_SENSE
        [    3.771584] sd 3:0:0:0: [sda] tag#0 Sense Key : Medium Error [current]
        [    3.771585] sd 3:0:0:0: [sda] tag#0 Add. Sense: Unrecovered read error
        [    3.771587] sd 3:0:0:0: [sda] tag#0 CDB: Read(10) 28 00 00 00 00 08 00 00 08        00
        [    3.771589] blk_update_request: critical medium error, dev sda, sector 8 op 0        x0:(READ) flags 0x80700 phys_seg 1 prio class 0
        [    3.832093] sd 3:0:0:0: [sda] tag#0 FAILED Result: hostbyte=DID_OK driverbyte        =DRIVER_SENSE
        [    3.832095] sd 3:0:0:0: [sda] tag#0 Sense Key : Medium Error [current]
        [    3.832096] sd 3:0:0:0: [sda] tag#0 Add. Sense: Unrecovered read error
        [    3.832098] sd 3:0:0:0: [sda] tag#0 CDB: Read(10) 28 00 01 d3 5d f8 00 00 01        00
        [    3.832099] blk_update_request: critical medium error, dev sda, sector 306293        68 op 0x0:(READ) flags 0x80700 phys_seg 1 prio class 0
        [    3.875486] sd 3:0:0:0: [sda] tag#0 FAILED Result: hostbyte=DID_OK driverbyte        =DRIVER_SENSE
        [    3.875488] sd 3:0:0:0: [sda] tag#0 Sense Key : Medium Error [current]
        [    3.875489] sd 3:0:0:0: [sda] tag#0 Add. Sense: Unrecovered read error
        [    3.875490] sd 3:0:0:0: [sda] tag#0 CDB: Read(10) 28 00 01 d3 5d f9 00 00 01        00
        [    3.875492] blk_update_request: critical medium error, dev sda, sector 306293        69 op 0x0:(READ) flags 0x0 phys_seg 1 prio class 0
        [    3.875498] Buffer I/O error on dev sda, logical block 3828671, async page re        ad
        [    3.897949] sd 3:0:0:0: [sda] tag#0 FAILED Result: hostbyte=DID_OK driverbyte        =DRIVER_SENSE
        [    3.897951] sd 3:0:0:0: [sda] tag#0 Sense Key : Medium Error [current]
        [    3.897952] sd 3:0:0:0: [sda] tag#0 Add. Sense: Unrecovered read error
        [    3.897954] sd 3:0:0:0: [sda] tag#0 CDB: Read(10) 28 00 01 d3 5d f8 00 00 01        00
        [    3.897956] blk_update_request: critical medium error, dev sda, sector 306293        68 op 0x0:(READ) flags 0x0 phys_seg 1 prio class 0
        [    3.897962] Buffer I/O error on dev sda, logical block 3828671, async page re        ad
        [    3.928361] EXT4-fs (dm-1): mounted filesystem with ordered data mode. Opts:        (null)
        [    4.013255] systemd[1]: Inserted module 'autofs4'
        [    4.057461] systemd[1]: systemd 241 running in system mode. (+PAM +AUDIT +SEL        INUX +IMA +APPARMOR +SMACK +SYSVINIT +UTMP +LIBCRYPTSETUP +GCRYPT +GNUTLS +ACL +        XZ +LZ4 +SECCOMP +BLKID +ELFUTILS +KMOD -IDN2 +IDN -PCRE2 default-hierarchy=hybr        id)
        [    4.076134] systemd[1]: Detected architecture x86-64.
        [    4.092531] systemd[1]: Set hostname to <NUC>.
        [    4.174658] systemd[1]: Listening on Device-mapper event daemon FIFOs.
        [    4.175175] systemd[1]: Created slice User and Session Slice.
        [    4.175183] systemd[1]: Reached target Slices.
        [    4.175252] systemd[1]: Listening on Journal Socket (/dev/log).
        [    4.175300] systemd[1]: Listening on Syslog Socket.
        [    4.175352] systemd[1]: Listening on fsck to fsckd communication Socket.
        [    4.175389] systemd[1]: Started Dispatch Password Requests to Console Directo        ry Watch.
        [    4.186292] Loading iSCSI transport class v2.0-870.
        [    4.189528] iscsi: registered transport (tcp)
        [    4.197303] RPC: Registered named UNIX socket transport module.
        [    4.197304] RPC: Registered udp transport module.
        [    4.197305] RPC: Registered tcp transport module.
        [    4.197306] RPC: Registered tcp NFSv4.1 backchannel transport module.
        [    4.197879] EXT4-fs (dm-1): re-mounted. Opts: errors=remount-ro
        [    4.217143] iscsi: registered transport (iser)
        [    4.221762] spl: loading out-of-tree module taints kernel.
        [    4.230448] znvpair: module license 'CDDL' taints kernel.
        [    4.230449] Disabling lock debugging due to kernel taint
        [    4.281678] systemd-journald[385]: Received request to flush runtime journal        from PID 1
        [    4.366262] ZFS: Loaded module v2.0.6-pve1~bpo10+1, ZFS pool version 5000, ZF        S filesystem version 5
        [    4.410176] mei_me 0000:00:16.0: enabling device (0000 -> 0002)
        [    4.423377] cfg80211: Loading compiled-in X.509 certificates for regulatory d        atabase
        [    4.423622] cfg80211: Loaded X.509 cert 'sforshee: 00b28ddf47aef9cea7'
        [    4.424137] platform regulatory.0: Direct firmware load for regulatory.db fai        led with error -2
        [    4.424140] cfg80211: failed to load regulatory.db
        [    4.425601] RAPL PMU: API unit is 2^-32 Joules, 5 fixed counters, 655360 ms o        vfl timer
        [    4.425602] RAPL PMU: hw unit of domain pp0-core 2^-14 Joules
        [    4.425603] RAPL PMU: hw unit of domain package 2^-14 Joules
        [    4.425603] RAPL PMU: hw unit of domain dram 2^-14 Joules
        [    4.425604] RAPL PMU: hw unit of domain pp1-gpu 2^-14 Joules
        [    4.425604] RAPL PMU: hw unit of domain psys 2^-14 Joules
        [    4.425741] input: PC Speaker as /devices/platform/pcspkr/input/input3
        [    4.436121] cryptd: max_cpu_qlen set to 1000
        [    4.438279] Bluetooth: Core ver 2.22
        [    4.438294] NET: Registered protocol family 31
        [    4.438295] Bluetooth: HCI device and connection manager initialized
        [    4.438298] Bluetooth: HCI socket layer initialized
        [    4.438299] Bluetooth: L2CAP socket layer initialized
        [    4.438302] Bluetooth: SCO socket layer initialized
        [    4.469530] AVX2 version of gcm_enc/dec engaged.
        [    4.469532] AES CTR mode by8 optimization enabled
        [    4.475950] usbcore: registered new interface driver btusb
        [    4.476590] Intel(R) Wireless WiFi driver for Linux
        [    4.476590] Copyright(c) 2003- 2015 Intel Corporation
        [    4.476644] iwlwifi 0000:00:14.3: enabling device (0000 -> 0002)
        [    4.486381] Bluetooth: hci0: Bootloader revision 0.1 build 42 week 52 2015
        [    4.487381] Bluetooth: hci0: Device revision is 2
        [    4.487382] Bluetooth: hci0: Secure boot is enabled
        [    4.487383] Bluetooth: hci0: OTP lock is enabled
        [    4.487384] Bluetooth: hci0: API lock is enabled
        [    4.487384] Bluetooth: hci0: Debug lock is disabled
        [    4.487385] Bluetooth: hci0: Minimum firmware build 1 week 10 2014
        [    4.488064] bluetooth hci0: Direct firmware load for intel/ibt-17-16-1.sfi fa        iled with error -2
        [    4.488067] Bluetooth: hci0: Failed to load Intel firmware file (-2)
        [    4.501687] snd_hda_intel 0000:00:1f.3: DSP detected with PCI class/subclass/        prog-if info 0x040380
        [    4.506354] iwlwifi 0000:00:14.3: loaded firmware version 46.6b541b68.0 op_mo        de iwlmvm
        [    4.507126] snd_hda_intel 0000:00:1f.3: enabling device (0000 -> 0002)
        [    4.534778] iwlwifi 0000:00:14.3: Detected Intel(R) Dual Band Wireless AC 956        0, REV=0x318
        [    4.589227] iwlwifi 0000:00:14.3: base HW address: 54:8d:5a:64:5f:c8
        [    4.593958] i915 0000:00:02.0: Found 128MB of eDRAM
        [    4.593978] i915 0000:00:02.0: vgaarb: deactivate vga console
        [    4.604189] [drm] Supports vblank timestamp caching Rev 2 (21.10.2013).
        [    4.604190] [drm] Driver supports precise vblank timestamp query.
        [    4.611839] i915 0000:00:02.0: vgaarb: changed VGA decodes: olddecodes=io+mem        ,decodes=io+mem:owns=io+mem
        [    4.613681] [drm] Finished loading DMC firmware i915/kbl_dmc_ver1_04.bin (v1.        4)
        [    4.646980] intel_rapl_common: Found RAPL domain package
        [    4.646982] intel_rapl_common: Found RAPL domain core
        [    4.646983] intel_rapl_common: Found RAPL domain uncore
        [    4.646984] intel_rapl_common: Found RAPL domain dram
        [    4.655971] ieee80211 phy0: Selected rate control algorithm 'iwl-mvm-rs'
        [    4.656295] thermal thermal_zone4: failed to read out thermal zone (-61)
        [    4.669261] iwlwifi 0000:00:14.3 wlp0s20f3: renamed from wlan0
        [    4.670332] i915 0000:00:02.0: Failed to program MOCS registers; expect perfo        rmance issues.
        [    4.671039] [drm] Initialized i915 1.6.0 20190822 for 0000:00:02.0 on minor 0
        [    4.671874] Adding 8388604k swap on /dev/mapper/pve-swap.  Priority:-2 extent        s:1 across:8388604k SSFS
        [    4.673263] ACPI: Video Device [GFX0] (multi-head: yes  rom: no  post: no)
        [    4.674004] acpi device:0f: registered as cooling_device10
        [    4.674074] input: Video Bus as /devices/LNXSYSTM:00/LNXSYBUS:00/PNP0A08:00/L        NXVIDEO:00/input/input4
        [    4.674279] snd_hda_intel 0000:00:1f.3: bound 0000:00:02.0 (ops i915_audio_co        mponent_bind_ops [i915])
        [    4.704046] [drm] Cannot find any crtc or sizes
        [    4.716304] EXT4-fs (sdb1): recovery complete
        [    4.716306] EXT4-fs (sdb1): mounted filesystem with ordered data mode. Opts:        (null)
        [    4.725527] snd_hda_codec_realtek hdaudioC0D0: autoconfig for ALC233: line_ou        ts=1 (0x21/0x0/0x0/0x0/0x0) type:hp
        [    4.725529] snd_hda_codec_realtek hdaudioC0D0:    speaker_outs=0 (0x0/0x0/0x0        /0x0/0x0)
        [    4.725530] snd_hda_codec_realtek hdaudioC0D0:    hp_outs=0 (0x0/0x0/0x0/0x0/        0x0)
        [    4.725531] snd_hda_codec_realtek hdaudioC0D0:    mono: mono_out=0x0
        [    4.725532] snd_hda_codec_realtek hdaudioC0D0:    inputs:
        [    4.725534] snd_hda_codec_realtek hdaudioC0D0:      Mic=0x19
        [    4.725535] snd_hda_codec_realtek hdaudioC0D0:      Internal Mic=0x12
        [    4.732874] [drm] Cannot find any crtc or sizes
        [    4.762446] [drm] Cannot find any crtc or sizes
        [    4.783807] input: HDA Intel PCH Mic as /devices/pci0000:00/0000:00:1f.3/soun        d/card0/input5
        [    4.783874] input: HDA Intel PCH Front Headphone as /devices/pci0000:00/0000:        00:1f.3/sound/card0/input6
        [    4.783918] input: HDA Intel PCH HDMI/DP,pcm=3 as /devices/pci0000:00/0000:00        :1f.3/sound/card0/input7
        [    4.783960] input: HDA Intel PCH HDMI/DP,pcm=7 as /devices/pci0000:00/0000:00        :1f.3/sound/card0/input8
        [    4.783997] input: HDA Intel PCH HDMI/DP,pcm=8 as /devices/pci0000:00/0000:00        :1f.3/sound/card0/input9
        [    4.784037] input: HDA Intel PCH HDMI/DP,pcm=9 as /devices/pci0000:00/0000:00        :1f.3/sound/card0/input10
        [    4.784085] input: HDA Intel PCH HDMI/DP,pcm=10 as /devices/pci0000:00/0000:0        0:1f.3/sound/card0/input11
        [    4.811748] Buffer I/O error on dev sda, logical block 3828671, async page re        ad
        [    4.892958] audit: type=1400 audit(1703935358.028:2): apparmor="STATUS" opera        tion="profile_load" profile="unconfined" name="/usr/bin/lxc-start" pid=621 comm=        "apparmor_parser"
        [    4.893992] audit: type=1400 audit(1703935358.028:3): apparmor="STATUS" opera        tion="profile_load" profile="unconfined" name="nvidia_modprobe" pid=624 comm="ap        parmor_parser"
        [    4.893995] audit: type=1400 audit(1703935358.028:4): apparmor="STATUS" opera        tion="profile_load" profile="unconfined" name="nvidia_modprobe//kmod" pid=624 co        mm="apparmor_parser"
        [    4.897116] audit: type=1400 audit(1703935358.032:5): apparmor="STATUS" opera        tion="profile_load" profile="unconfined" name="/usr/sbin/tcpdump" pid=622 comm="        apparmor_parser"
        [    4.898253] audit: type=1400 audit(1703935358.032:6): apparmor="STATUS" opera        tion="profile_load" profile="unconfined" name="/usr/bin/man" pid=623 comm="appar        mor_parser"
        [    4.898258] audit: type=1400 audit(1703935358.032:7): apparmor="STATUS" opera        tion="profile_load" profile="unconfined" name="man_filter" pid=623 comm="apparmo        r_parser"
        [    4.898260] audit: type=1400 audit(1703935358.032:8): apparmor="STATUS" opera        tion="profile_load" profile="unconfined" name="man_groff" pid=623 comm="apparmor        _parser"
        [    4.901270] audit: type=1400 audit(1703935358.036:9): apparmor="STATUS" opera        tion="profile_load" profile="unconfined" name="lxc-container-default" pid=625 co        mm="apparmor_parser"
        [    4.901273] audit: type=1400 audit(1703935358.036:10): apparmor="STATUS" oper        ation="profile_load" profile="unconfined" name="lxc-container-default-cgns" pid=        625 comm="apparmor_parser"
        [    4.945828] new mount options do not match the existing superblock, will be i        gnored
        [    4.955576] softdog: initialized. soft_noboot=0 soft_margin=60 sec soft_panic        =0 (nowayout=0)
        [    4.958548] vmbr0: port 1(eno1) entered blocking state
        [    4.958550] vmbr0: port 1(eno1) entered disabled state
        [    4.960983] device eno1 entered promiscuous mode
        [    5.302916] bpfilter: Loaded bpfilter_umh pid 753
        [    5.303165] Started bpfilter
        [    5.339629] kauditd_printk_skb: 2 callbacks suppressed
        [    5.339631] audit: type=1400 audit(1703935358.472:13): apparmor="STATUS" oper        ation="profile_replace" info="same as current profile, skipping" profile="unconf        ined" name="/usr/bin/lxc-start" pid=778 comm="apparmor_parser"
        [    5.350501] audit: type=1400 audit(1703935358.484:14): apparmor="STATUS" oper        ation="profile_replace" info="same as current profile, skipping" profile="unconf        ined" name="lxc-container-default" pid=786 comm="apparmor_parser"
        [    5.350505] audit: type=1400 audit(1703935358.484:15): apparmor="STATUS" oper        ation="profile_replace" info="same as current profile, skipping" profile="unconf        ined" name="lxc-container-default-cgns" pid=786 comm="apparmor_parser"
        [    5.350508] audit: type=1400 audit(1703935358.484:16): apparmor="STATUS" oper        ation="profile_replace" info="same as current profile, skipping" profile="unconf        ined" name="lxc-container-default-with-mounting" pid=786 comm="apparmor_parser"
        [    5.350511] audit: type=1400 audit(1703935358.484:17): apparmor="STATUS" oper        ation="profile_replace" info="same as current profile, skipping" profile="unconf        ined" name="lxc-container-default-with-nesting" pid=786 comm="apparmor_parser"
        [    8.174341] e1000e: eno1 NIC Link is Up 1000 Mbps Full Duplex, Flow Control:        Rx/Tx
        [    8.174393] vmbr0: port 1(eno1) entered blocking state
        [    8.174394] vmbr0: port 1(eno1) entered forwarding state
        [    8.174456] IPv6: ADDRCONF(NETDEV_CHANGE): vmbr0: link becomes ready
        [   10.828385] EXT4-fs warning (device dm-7): ext4_multi_mount_protect:322: MMP        interval 42 higher than expected, please wait.
        [   18.206034] L1TF CPU bug present and SMT on, data leak possible. See CVE-2018        -3646 and https://www.kernel.org/doc/html/latest/admin-guide/hw-vuln/l1tf.html f        or details.
        [   54.135957] EXT4-fs (dm-7): recovery complete
        [   54.136320] EXT4-fs (dm-7): mounted filesystem with ordered data mode. Opts:        (null)
        [   54.202377] audit: type=1400 audit(1703935407.578:18): apparmor="STATUS" oper        ation="profile_load" profile="/usr/bin/lxc-start" name="lxc-200_</var/lib/lxc>"        pid=1128 comm="apparmor_parser"
        [   54.248970] cgroup: cgroup: disabling cgroup2 socket matching due to net_prio        or net_cls activation
        [   54.650945] fwbr200i0: port 1(fwln200i0) entered blocking state
        [   54.650947] fwbr200i0: port 1(fwln200i0) entered disabled state
        [   54.650997] device fwln200i0 entered promiscuous mode
        [   54.651030] fwbr200i0: port 1(fwln200i0) entered blocking state
        [   54.651031] fwbr200i0: port 1(fwln200i0) entered forwarding state
        [   54.654926] vmbr0: port 2(fwpr200p0) entered blocking state
        [   54.654928] vmbr0: port 2(fwpr200p0) entered disabled state
        [   54.654995] device fwpr200p0 entered promiscuous mode
        [   54.655025] vmbr0: port 2(fwpr200p0) entered blocking state
        [   54.655026] vmbr0: port 2(fwpr200p0) entered forwarding state
        [   54.658705] fwbr200i0: port 2(veth200i0) entered blocking state
        [   54.658706] fwbr200i0: port 2(veth200i0) entered disabled state
        [   54.658756] device veth200i0 entered promiscuous mode
        [   54.689186] eth0: renamed from vethzJwP9l
        [   55.022554] IPv6: ADDRCONF(NETDEV_CHANGE): eth0: link becomes ready
        [   55.022580] fwbr200i0: port 2(veth200i0) entered blocking state
        [   55.022580] fwbr200i0: port 2(veth200i0) entered forwarding state
        [   66.712713] device tap100i0 entered promiscuous mode
        [   66.740245] fwbr100i0: port 1(fwln100i0) entered blocking state
        [   66.740247] fwbr100i0: port 1(fwln100i0) entered disabled state
        [   66.740315] device fwln100i0 entered promiscuous mode
        [   66.740354] fwbr100i0: port 1(fwln100i0) entered blocking state
        [   66.740355] fwbr100i0: port 1(fwln100i0) entered forwarding state
        [   66.743609] vmbr0: port 3(fwpr100p0) entered blocking state
        [   66.743610] vmbr0: port 3(fwpr100p0) entered disabled state
        [   66.743659] device fwpr100p0 entered promiscuous mode
        [   66.743677] vmbr0: port 3(fwpr100p0) entered blocking state
        [   66.743678] vmbr0: port 3(fwpr100p0) entered forwarding state
        [   66.747387] fwbr100i0: port 2(tap100i0) entered blocking state
        [   66.747389] fwbr100i0: port 2(tap100i0) entered disabled state
        [   66.747484] fwbr100i0: port 2(tap100i0) entered blocking state
        [   66.747485] fwbr100i0: port 2(tap100i0) entered forwarding state
        [   79.461410] EXT4-fs warning (device dm-6): ext4_multi_mount_protect:322: MMP        interval 42 higher than expected, please wait.
        [  123.743732] EXT4-fs (dm-6): recovery complete
        [  123.744244] EXT4-fs (dm-6): mounted filesystem with ordered data mode. Opts:        (null)
        [  123.806852] audit: type=1400 audit(1703935477.215:19): apparmor="STATUS" oper        ation="profile_load" profile="/usr/bin/lxc-start" name="lxc-210_</var/lib/lxc>"        pid=1786 comm="apparmor_parser"
        [  124.236297] fwbr210i0: port 1(fwln210i0) entered blocking state
        [  124.236299] fwbr210i0: port 1(fwln210i0) entered disabled state
        [  124.236365] device fwln210i0 entered promiscuous mode
        [  124.236396] fwbr210i0: port 1(fwln210i0) entered blocking state
        [  124.236397] fwbr210i0: port 1(fwln210i0) entered forwarding state
        [  124.240518] vmbr0: port 4(fwpr210p0) entered blocking state
        [  124.240520] vmbr0: port 4(fwpr210p0) entered disabled state
        [  124.240595] device fwpr210p0 entered promiscuous mode
        [  124.240615] vmbr0: port 4(fwpr210p0) entered blocking state
        [  124.240616] vmbr0: port 4(fwpr210p0) entered forwarding state
        [  124.244524] fwbr210i0: port 2(veth210i0) entered blocking state
        [  124.244526] fwbr210i0: port 2(veth210i0) entered disabled state
        [  124.244590] device veth210i0 entered promiscuous mode
        [  124.287390] eth0: renamed from vethcqPbhO
        [  124.713871] IPv6: ADDRCONF(NETDEV_CHANGE): eth0: link becomes ready
        [  124.713901] fwbr210i0: port 2(veth210i0) entered blocking state
        [  124.713904] fwbr210i0: port 2(veth210i0) entered forwarding state
        karl@NUC:~$
          Thomas Braun Most Active @GOETSCHHOFER last edited by Thomas Braun
          @goetschhofer sagte in Proxmox: Fehlermeldung bei backup - vzdump ?:
          Der Datenträger hat ein Problem.
          Dein puTTY bitte größer machen oder besser gleich ein gescheites Terminal verwenden...
            GOETSCHHOFER @Thomas Braun last edited by GOETSCHHOFER
            @thomas-braun said in Proxmox: Fehlermeldung bei backup - vzdump ?:
            Was meinst du mit putty größer machen oder gleich ein gescheites Terminal verwenden ?
            crunchip G Thomas Braun 3 Replies Last reply Reply Quote 0
              crunchip Forum Testing Most Active @GOETSCHHOFER last edited by
              @goetschhofer das Fenster auf ganze Bildschirmbreite ziehen, deine Texte sind immer abgeschnitten
              da würd ich mir mal Gedanken über eine neue Platte machen und bei Gelegenheit auch gleich mal den Lüfter reinigen, sofern dieser noch intakt ist
                @goetschhofer
                Nachdem ich ihm eine 10 minütige cool-down-Phase gegönnt habe, läuft er wieder normal und ich kann wieder auf proxmox und Putty zugreifen, aber ohne iobroker-WEBUI.
                crunchip 2 Replies Last reply Reply Quote 0
                  @goetschhofer
                  Das Fenster von puTTY vergrößern, damit da nicht diese dämlichen Zeilenumbrüche auftauchen. Oder gleich die PowerShell verwenden und per SSH auf den Server gehen.
                    wieder normal
                    aber auch nur kurzfristig
                      im proxmox syslog müsste eigentlich die Temperatur, Plattenprobleme, etc ebenfalls angezeigt werden
                        GOETSCHHOFER @crunchip last edited by GOETSCHHOFER
                        @crunchip
                        Bis gestern hat er ja noch erheblich Krach gemacht der Lüfter, vor allem auch vorgestern bei der Datensicherung, seit gestern ist der NUC mäusestill u. ich vermute, dass er sich da dann abschaltet bei Überhitzung.
                        Wie kann ich in proxmox über syslog die Temperatur und eventuelle Plattenprobleme abrufen ?
                        karl@NUC:~$ syslog
                        -bash: syslog: command not found
                        karl@NUC:~$ ^C
                          crunchip Forum Testing Most Active @GOETSCHHOFER last edited by crunchip
                          dein syslog findest du wie oben genannt, in
                          var/log/syslog
                          kannst du aufrufen mit z.b.
                          tail -f /var/log/syslog
                          dies wird dir auch direkt in der Proxmox-oberfläche angezeigt
                            @crunchip
                            Ich konnte ihn wie heute schon abermals zum Leben erwecken.😬
                            Soll ich ihn bis morgen mal Laufen lassen und schauen was er macht oder sollte ich nochmals die weiteren Schritte versuchen ?
                            login as: karl
                            karl@192.168.1.176's password:
                            Linux IOBROKER 4.19.0-25-amd64 #1 SMP Debian 4.19.289-2 (2023-08-08) x86_64
                            The programs included with the Debian GNU/Linux system are free software;
                            the exact distribution terms for each program are described in the
                            individual files in /usr/share/doc/*/copyright.
                            Debian GNU/Linux comes with ABSOLUTELY NO WARRANTY, to the extent
                            permitted by applicable law.
                            Last login: Sat Dec 30 16:22:31 2023 from 192.168.1.3
                            karl@IOBROKER:~$ iobroker stop
                            karl@IOBROKER:~$ cd /opt/iobroker/iobroker-data/
                            karl@IOBROKER:/opt/iobroker/iobroker-data$
                            karl@IOBROKER:/opt/iobroker/iobroker-data$ mv states.json states.json.old
                            karl@IOBROKER:/opt/iobroker/iobroker-data$ cd backup-objects/
                            karl@IOBROKER:/opt/iobroker/iobroker-data/backup-objects$ gunzip -ck 2023-12-30_11-40_objects.json.gz > /opt/iobroker/iobroker-data/objects.json
                            karl@IOBROKER:/opt/iobroker/iobroker-data/backup-objects$ gunzip -ck 2023-12-30_15-16_states.json.gz > /opt/iobroker/iobroker-data/states.json
                            karl@IOBROKER:/opt/iobroker/iobroker-data/backup-objects$ iobroker start
                            karl@IOBROKER:/opt/iobroker/iobroker-data/backup-objects$ cd ..
                            karl@IOBROKER:/opt/iobroker/iobroker-data$ cd ..
                            karl@IOBROKER:/opt/iobroker$ cd ..
                            karl@IOBROKER:/opt$ cd ..
                            karl@IOBROKER:/$ iobroker start
                            karl@IOBROKER:/$
                            Habe jetzt nur iob diag abgefragt u. markiert, anschließend strg+c und flugs war er wieder weg. 😖
                            Putty fatal error !
                              @goetschhofer
                              Mit Strg-C schießt du den Prozess ab.
                              Welches Terminal verwendest du denn da nun?
                                @goetschhofer
                                Leider immer noch mit Putty, werde mir gleich Powershell installieren.
                                Aber mit Str+C hat es bis dato immer funktioniert. Warum jetzt nicht mehr ?
                                Markieren mit der Maus u. Strg+c kopiere ich mir laufend Dateien heraus.
                                Thomas Braun crunchip 2 Replies Last reply Reply Quote 0
                                  @goetschhofer
                                  Weil in einem 'richtigen' Terminal die Tastenkombination 'Strg-C' nicht für copy sondern für 'cancel' steht und somit der laufende Prozess abgeschossen werden kann.
                                  Einige Terminalprogramme fangen sowas dann Kontextabhängig ab. Mal besser, mal schlechter.
                                    @goetschhofer
                                    Wie markiere ich dies dann richtig zum Kopieren ?
                                      @goetschhofer
                                      Keine Ahnung. Ich verwende puTTY nicht. Ist mir einfach zu schlecht.
                                        @goetschhofer
                                        Könntest du mir einen link für das richtige Windows Powershell zum Downloaden posten ?
                                        Hier gibt es einige Möglichkeiten.
                                          @goetschhofer
                                          https://learn.microsoft.com/en-us/powershell/scripting/install/installing-powershell-on-windows?view=powershell-7.4
                                            in putty markierst du nur mit der Maus, mehr musst du nicht machen, das liegt dann automatisch in der Zwischenablage und kann mit rechtsklick eingefügt werden
                                            1.2k
                                            81.1k
                                            34052
