    4. vis 1 läuft nicht mehr
    • Max 0
      Max 0 @sigi234 last edited by
      • Max 0
        Max 0 @OliverIO last edited by
        @oliverio
        Ich benutze den Opera browser
        Opera Version 105.0.4970.63
        Und hier die browserkonsole:
        2023-12-30T10:48:23.961Z Connected => authenticate
        data:application/json;charset=8{"name":"ioBroker vis","short_name":"vis","start_url":".#main/%22,%22display%22:%22standalone%22,%22background_color%22:%22#ffffff%22,%22description%22:%22WEB%20visualisation%20for%20ioBroker%20platform%22,%22icons%22:[{%22src%22:%22img/vis.png%22,%22sizes%22:%22192x192%22,%22type%22:%22image/png%22}]}:1
               Failed to load resource: net::ERR_INVALID_URL
        conn.js:331 2023-12-30T10:48:24.070Z Authenticated: true
        vis.js:3595 Create inner vis object demoTemperature
        vis.js:3595 Create inner vis object demoHumidity
        translate.js:20 "Use background": {"en": "Use background", "de": "Use background", "ru": "Use background"},
        edit.html:1 Uncaught SyntaxError: Unexpected non-whitespace character after JSON at position 2 (line 1 column 3)
            at JSON.parse (<anonymous>)
            at Object.unserialize (loStorage.js:2:567)
            at r.get (loStorage.js:2:1871)
            at Function.get (loStorage.js:2:2346)
            at Object.bindInstance (vis.js:576:54)
            at Object.initNext (vis.js:705:14)
            at Object.<anonymous> (vis.js:603:18)
            at Object.loadWidgetSets (vis.js:568:34)
            at Object.init (vis.js:602:14)
            at vis.js:3661:29
        • Max 0
          Max 0 @Homoran last edited by
          Hat das Auswirkungen das ich nur ein Bruchteil meiner SD Karte nutze?
          Was kann ich dagegen tun?
          DJMarc75 Homoran 2 Replies Last reply Reply Quote 0
            sigi234 Forum Testing Most Active @Max 0 last edited by
            @max-0 sagte in vis 1 läuft nicht mehr:
            Haken setzen bei reine Websockes ....
            • DJMarc75
              DJMarc75 @Max 0 last edited by
              Im Terminal
              sudo raspi-config
              eingeben.
              Dann
              Zuletzt den Raspberry rebooten.
              Max 0 1 Reply Last reply Reply Quote 0
                Homoran Global Moderator Administrators @Max 0 last edited by
                ist doch jetzt passiert
                • Max 0
                  Max 0 @DJMarc75 last edited by Max 0
                  @djmarc75
                  Habe ich gemacht
                  Und jetzt?
                  • Max 0
                    Vlt hilft das
                      Vlt hilft das
                      als Text in code-tags wäre es besser.
                      was willst du damit zeigen?
                      • OliverIO
                        die beiden fehlermeldungen sagen, das was mit vis nicht stimmt.
                        ich würde vis mal deinstallieren und dann wieder installieren.
                        wenn das nicht hilft, dann den web adapter deinstallieren und wieder installieren (ich glaube das zweitere muss man mit den consolenbefehlen für den iobroker machen.)
                        den hinweis mit den websockets ebenfalls probieren und natürlich der partition den kompletten platz der sd karte geben. homoran hat gezeigt wie man das macht
                        • Max 0
                          @homoran said in vis 1 läuft nicht mehr:
                          Was meinst du mit iob diag?
                          bitte diesen Befehl in der Konsole ausführen, und die Ausgabe posten
                          Bin neu hier
                          Na, dann hab ich hier was für dich zu lesen
                            @max-0 was willst du mir jetzt sagen?
                            • Max 0
                              Sorry das war falsch das wollte ich nicht.
                              Ein Frage habe ich was genau soll ich jetzt machen bin mit dem oberen Beitrag jetzt ein bisschen verwirrt
                                @max-0 Was genau ist denn jetzt Status?
                                • Max 0
                                  Und was bedeutet im Iobroker bei Protokollen ?
                                  	cannot call visUtils: Not exists
                                  • Max 0
                                    Das ich das was man mir jetzt gesagt habe gemacht habe.
                                    Aber es funktioniert leider immer noch nicht
                                      gelöscht und neu installiert?
                                      welche Version?
                                      • Max 0
                                        Habe beide Neuinstalliert
                                        Opera Momentaufnahme_2023-12-30_165659_192.168.178.76.png Opera Momentaufnahme_2023-12-30_165709_192.168.178.76.png
                                          @max-0 bitte iob diag in der Langfassung!
                                          • Glasfaser
                                            Glasfaser last edited by
                                            Dazu mal .
                                            iobroker upload all
                                            sudo reboot
                                            dann einen Browser nutzen , den du noch nie für ioBroker genutzt hast , was ist dann !?
                                            3399
