    4. IoBroker neu aufbauen *gelöst*
      gluecksmann @Meister Mopper last edited by
      @meister-mopper
      Na nen Raspberry... mehr nicht...
      • Meister Mopper
        Meister Mopper @gluecksmann last edited by
        @gluecksmann sagte in IoBroker neu aufbauen:
        ... mehr nicht...
        Mit wie wenig Informationen löst man Probleme?
        Version des Raspi, Arbeitsspeicher, was lief bisher, iobroker-Version, wieviel Adapter, SD-Karte oder SSD, wo soll es hingehen?
        G wcag22 2 Replies Last reply Reply Quote 0
          @meister-mopper
          Skript v.2023-10-10
          *** BASE SYSTEM ***
             Static hostname: raspberrypi
                   Icon name: computer
            Operating System: Raspbian GNU/Linux 10 (buster)
                      Kernel: Linux 5.10.103-v7l+
                Architecture: arm
          Model           : Raspberry Pi 4 Model B Rev 1.4
          Docker          : false
          Virtualization  : none
          Kernel          : armv7l
          Userland        : armhf
          Systemuptime and Load:
           20:24:12 up 2 days,  6:12,  1 user,  load average: 0.82, 0.63, 0.57
          CPU threads: 4
          *** RASPBERRY THROTTLING ***
          Current issues:
          Previously detected issues:
          *** Time and Time Zones ***
                         Local time: Sat 2023-12-30 20:24:13 CET
                     Universal time: Sat 2023-12-30 19:24:13 UTC
                           RTC time: n/a
                        NTP service: active
                    RTC in local TZ: no
          *** User and Groups ***
          pi
          /home/pi
          pi adm dialout cdrom sudo audio video plugdev games users input netdev lpadmin gpio i2c spi iobroker
          *** X-Server-Setup ***
          X-Server:       false
          Desktop:
          Terminal:       tty
          Boot Target:    multi-user.target
          *** MEMORY ***
          Mem:           7.9G        1.9G        3.9G        139M        2.1G        5.6G
          Swap:           99M          0B         99M
          Total:         8.0G        1.9G        4.0G
                   7898 M total memory
                   1924 M used memory
                    410 M active memory
                   3398 M inactive memory
                   3860 M free memory
                    182 M buffer memory
                   1931 M swap cache
                     99 M total swap
                      0 M used swap
                     99 M free swap
          Raspberry only:
          oom events: 0
          *** FAILED SERVICES ***
            UNIT            LOAD   ACTIVE SUB    DESCRIPTION
          * lightdm.service loaded failed failed Light Display Manager
          LOAD   = Reflects whether the unit definition was properly loaded.
          ACTIVE = The high-level unit activation state, i.e. generalization of SUB.
          SUB    = The low-level unit activation state, values depend on unit type.
          1 loaded units listed. Pass --all to see loaded but inactive units, too.
          To show all installed unit files use 'systemctl list-unit-files'.
          *** FILESYSTEM ***
          /dev/root      ext4       29G   14G   15G  50% /
          devtmpfs       devtmpfs  3.7G     0  3.7G   0% /dev
          tmpfs          tmpfs     3.9G     0  3.9G   0% /dev/shm
          tmpfs          tmpfs     3.9G  140M  3.8G   4% /run
          tmpfs          tmpfs     3.9G     0  3.9G   0% /sys/fs/cgroup
          /dev/mmcblk0p1 vfat      253M   49M  204M  20% /boot
          tmpfs          tmpfs     790M     0  790M   0% /run/user/1000
          [Thu Dec 28 14:11:43 2023] Kernel command line: coherent_pool=1M 8250.nr_uarts=0 snd_bcm2835.enable_compat_alsa=0 snd_bcm2835.enable_hdmi=1  smsc95xx.macaddr=E4:5F:01:3D:9B:6E vc_mem.mem_base=0x3ec00000 vc_mem.mem_size=0x40000000  dwc_otg.lpm_enable=0 console=ttyS0,115200 console=tty1 root=PARTUUID=a372f35c-02 rootfstype=ext4 elevator=deadline fsck.repair=yes rootwait quiet splash plymouth.ignore-serial-consoles
          [Thu Dec 28 14:11:44 2023] EXT4-fs (mmcblk0p2): mounted filesystem with ordered data mode. Opts: (null)
          [Thu Dec 28 14:11:44 2023] VFS: Mounted root (ext4 filesystem) readonly on device 179:2.
          [Thu Dec 28 14:11:46 2023] EXT4-fs (mmcblk0p2): re-mounted. Opts: (null)
          TARGET        SOURCE         FSTYPE OPTIONS
          /             /dev/mmcblk0p2 ext4   rw,noatime
          |-/sys/fs/bpf none           bpf    rw,nosuid,nodev,noexec,relatime,mode=700
          `-/boot       /dev/mmcblk0p1 vfat   rw,relatime,fmask=0022,dmask=0022,codepage=437,iocharset=ascii,shortname=mixed,errors=remount-ro
          /var:
          440M    /var/
          118M    /var/log
          118M    /var/lib
          102M    /var/cache
          90M     /var/cache/apt
          Archived and active journals take up 138.7M in the file system.
          /opt/iobroker/backups:
          63M     /opt/iobroker/backups/
          /opt/iobroker/iobroker-data:
          628M    /opt/iobroker/iobroker-data/
          323M    /opt/iobroker/iobroker-data/files
          143M    /opt/iobroker/iobroker-data/backup-objects
          93M     /opt/iobroker/iobroker-data/sonosCache
          67M     /opt/iobroker/iobroker-data/files/javascript.admin
          35M     /opt/iobroker/iobroker-data/files/devices.admin/static/js/main.24f2bb56.js.map
          33M     /opt/iobroker/iobroker-data/files/iot.admin/static/js/main.1797d034.js.map
          23M     /opt/iobroker/iobroker-data/objects.jsonl
          21M     /opt/iobroker/iobroker-data/files/web.admin/static/js/main.aaea95f8.js.map
          18M     /opt/iobroker/iobroker-data/states.jsonl
          USB-Devices by-id:
          /dev/serial/by-id/usb-Texas_Instruments_TI_CC2531_USB_CDC___0X00124B001CDD3388-if00
          *** NodeJS-Installation ***
          /usr/bin/nodejs         v18.19.0
          /usr/bin/node           v18.19.0
          /usr/bin/npm            10.2.3
          /usr/bin/npx            10.2.3
          /usr/bin/corepack       0.22.0
          nodejs:
            Installed: 18.19.0-1nodesource1
            Candidate: 18.19.0-1nodesource1
            Version table:
           *** 18.19.0-1nodesource1 1001
                  500 https://deb.nodesource.com/node_18.x nodistro/main armhf Packages
                  100 /var/lib/dpkg/status
               18.18.2-1nodesource1 1001
               18.18.1-1nodesource1 1001
               18.18.0-1nodesource1 1001
               18.17.1-1nodesource1 1001
               18.17.0-1nodesource1 1001
               18.16.1-1nodesource1 1001
               18.16.0-1nodesource1 1001
               18.15.0-1nodesource1 1001
               18.14.2-1nodesource1 1001
               18.14.1-1nodesource1 1001
               18.14.0-1nodesource1 1001
               18.13.0-1nodesource1 1001
               18.12.0-1nodesource1 1001
               18.11.0-1nodesource1 1001
               18.10.0-1nodesource1 1001
               18.9.1-1nodesource1 1001
               18.9.0-1nodesource1 1001
               18.8.0-1nodesource1 1001
               18.7.0-1nodesource1 1001
               18.6.0-1nodesource1 1001
               18.5.0-1nodesource1 1001
               18.4.0-1nodesource1 1001
               18.3.0-1nodesource1 1001
               18.2.0-1nodesource1 1001
               18.1.0-1nodesource1 1001
               18.0.0-1nodesource1 1001
               10.24.0~dfsg-1~deb10u3 500
          No problems detected
          Errors in npm tree:
          npm ERR! code ELSPROBLEMS
          npm ERR! invalid: iobroker.govee@0.0.6 /opt/iobroker/node_modules/iobroker.govee
          npm ERR! A complete log of this run can be found in: /home/pi/.npm/_logs/2023-12-30T19_24_22_588Z-debug-0.log
          *** ioBroker-Installation ***
          ioBroker Status
          Objects type: jsonl
          States  type: jsonl
          Core adapters versions
          js-controller:  5.0.17
          admin:          6.12.0
          javascript:     7.1.6
          npm ERR! A complete log of this run can be found in: /home/pi/.npm/_logs/2023-12-30T19_24_44_517Z-debug-0.log
          Adapters from github:   1
          Adapter State
          + system.adapter.admin.0                  : admin                 : raspberrypi                              -  enabled, port: 8081, bind: 0.0.0.0, run as: admin
          + system.adapter.alexa2.0                 : alexa2                : raspberrypi                              -  enabled
            system.adapter.alias-manager.0          : alias-manager         : raspberrypi                              - disabled
          + system.adapter.awtrix-light.0           : awtrix-light          : raspberrypi                              -  enabled
          + system.adapter.backitup.0               : backitup              : raspberrypi                              -  enabled
          + system.adapter.ble.0                    : ble                   : raspberrypi                              -  enabled
            system.adapter.chromecast.0             : chromecast            : raspberrypi                              - disabled
            system.adapter.daswetter.0              : daswetter             : raspberrypi                              -  enabled
            system.adapter.devices.0                : devices               : raspberrypi                              - disabled
          + system.adapter.discovery.0              : discovery             : raspberrypi                              -  enabled
            system.adapter.dwd.0                    : dwd                   : raspberrypi                              -  enabled
          + system.adapter.fullybrowser.0           : fullybrowser          : raspberrypi                              -  enabled
          + system.adapter.govee.0                  : govee                 : raspberrypi                              -  enabled
          + system.adapter.gruenbeck.0              : gruenbeck             : raspberrypi                              -  enabled
            system.adapter.history.0                : history               : raspberrypi                              - disabled
          + system.adapter.hue.0                    : hue                   : raspberrypi                              -  enabled, port: 443
            system.adapter.ical.0                   : ical                  : raspberrypi                              -  enabled
            system.adapter.icons-mfd-png.0          : icons-mfd-png         : raspberrypi                              - disabled
            system.adapter.icons-mfd-svg.0          : icons-mfd-svg         : raspberrypi                              - disabled
          + system.adapter.info.0                   : info                  : raspberrypi                              -  enabled
          + system.adapter.iot.0                    : iot                   : raspberrypi                              -  enabled
          + system.adapter.javascript.0             : javascript            : raspberrypi                              -  enabled
          + system.adapter.meross.0                 : meross                : raspberrypi                              -  enabled
          + system.adapter.mielecloudservice.0      : mielecloudservice     : raspberrypi                              -  enabled
          + system.adapter.musiccast.0              : musiccast             : raspberrypi                              -  enabled
          + system.adapter.net-tools.0              : net-tools             : raspberrypi                              -  enabled
          + system.adapter.netatmo.0                : netatmo               : raspberrypi                              -  enabled
          + system.adapter.philips-air.0            : philips-air           : raspberrypi                              -  enabled
          + system.adapter.philips-air.1            : philips-air           : raspberrypi                              -  enabled
          + system.adapter.ping.0                   : ping                  : raspberrypi                              -  enabled
          + system.adapter.pollenflug.0             : pollenflug            : raspberrypi                              -  enabled
          + system.adapter.scenes.0                 : scenes                : raspberrypi                              -  enabled
          + system.adapter.shelly.0                 : shelly                : raspberrypi                              -  enabled, port: 1882, bind: 0.0.0.0
            system.adapter.shuttercontrol.0         : shuttercontrol        : raspberrypi                              - disabled
          + system.adapter.smartcontrol.0           : smartcontrol          : raspberrypi                              -  enabled
          + system.adapter.sonoff.0                 : sonoff                : raspberrypi                              -  enabled, port: 1883, bind: 0.0.0.0
          + system.adapter.sonos.0                  : sonos                 : raspberrypi                              -  enabled
          + system.adapter.trashschedule.0          : trashschedule         : raspberrypi                              -  enabled
          + system.adapter.tuya.0                   : tuya                  : raspberrypi                              -  enabled
            system.adapter.vis-colorpicker.0        : vis-colorpicker       : raspberrypi                              -  enabled
            system.adapter.vis-hqwidgets.0          : vis-hqwidgets         : raspberrypi                              -  enabled
            system.adapter.vis-icontwo.0            : vis-icontwo           : raspberrypi                              -  enabled
          + system.adapter.vis-inventwo.0           : vis-inventwo          : raspberrypi                              -  enabled
            system.adapter.vis-material-advanced.0  : vis-material-advanced : raspberrypi                              -  enabled
            system.adapter.vis-metro.0              : vis-metro             : raspberrypi                              -  enabled
            system.adapter.vis-players.0            : vis-players           : raspberrypi                              -  enabled
            system.adapter.vis-timeandweather.0     : vis-timeandweather    : raspberrypi                              -  enabled
            system.adapter.vis.0                    : vis                   : raspberrypi                              -  enabled
            system.adapter.weatherunderground.0     : weatherunderground    : raspberrypi                              -  enabled
          + system.adapter.web.0                    : web                   : raspberrypi                              -  enabled, port: 8082, bind: 0.0.0.0, run as: admin
          + system.adapter.zigbee.0                 : zigbee                : raspberrypi                              -  enabled, port: /dev/serial/by-id/usb-Texas_Instruments_TI_CC2531_USB_CDC___0X00124B001CDD3388-if00
          + instance is alive
          ioBroker-Repositories
          Active repo(s): stable
          Installed ioBroker-Instances
          Used repository: stable
          Adapter    "admin"        : 6.12.0   , installed 6.12.0
          Adapter    "alexa2"       : 3.26.3   , installed 3.26.3
          Adapter    "awtrix-light" : 0.10.0   , installed 0.10.0
          Adapter    "backitup"     : 2.9.8    , installed 2.9.8
          Adapter    "ble"          : 0.13.4   , installed 0.13.4
          Adapter    "chromecast"   : 3.0.3    , installed 3.0.3
          Adapter    "daswetter"    : 3.1.11   , installed 3.1.11
          Adapter    "fullybrowser" : 3.0.6    , installed 3.0.6
          Adapter    "gruenbeck"    : 0.0.42   , installed 0.0.42
          Adapter    "hue"          : 3.10.1   , installed 3.10.1
          Adapter    "icons-mfd-png": 1.2.1    , installed 1.1.0  [Updatable]
          Adapter    "iot"          : 2.0.11   , installed 2.0.11
          Adapter    "javascript"   : 7.1.6    , installed 7.1.6
          Controller "js-controller": 5.0.17   , installed 5.0.17
          Adapter    "meross"       : 1.16.1   , installed 1.15.1 [Updatable]
          Adapter    "mielecloudservice": 6.5.4, installed 6.5.4
          Adapter    "mihome-vacuum": 4.1.0    , installed 4.1.0
          Adapter    "musiccast"    : 1.1.3    , installed 1.1.3
          Adapter    "netatmo"      : 3.1.0    , installed 3.1.0
          Adapter    "philips-air"  : 1.0.3    , installed 1.0.3
          Adapter    "pollenflug"   : 1.0.6    , installed 1.0.6
          Adapter    "shelly"       : 6.6.1    , installed 6.6.1
          Adapter    "shuttercontrol": 1.6.3   , installed 1.6.3
          Adapter    "smartcontrol" : 2.0.1    , installed 2.0.1
          Adapter    "sonoff"       : 3.0.3    , installed 3.0.3
          Adapter    "sonos"        : 3.0.0    , installed 3.0.0
          Adapter    "trashschedule": 2.3.0    , installed 2.3.0
          Adapter    "tuya"         : 3.15.0   , installed 3.14.2 [Updatable]
          Adapter    "vis-icontwo"  : 1.0.0    , installed 1.0.0
          Adapter    "weatherunderground": 3.6.0, installed 3.6.0
          Adapter    "web"          : 6.1.10   , installed 6.1.10
          Adapter    "ws"           : 2.5.8    , installed 2.5.8
          Adapter    "zigbee"       : 1.9.5    , installed 1.8.24 [Updatable]
          Objects and States
          Objects:        11361
          States:         9441
          Hit:1 http://raspbian.raspberrypi.org/raspbian buster InRelease
          Hit:2 http://archive.raspberrypi.org/debian buster InRelease
          Hit:3 https://deb.nodesource.com/node_18.x nodistro InRelease
          Reading package lists...
          Pending Updates: 0
          *** Listening Ports ***
          tcp        0      0 0.0.0.0:22              0.0.0.0:*               LISTEN      0          18008      642/sshd
          tcp        0      0 127.0.0.1:631           0.0.0.0:*               LISTEN      0          11568912   30479/cupsd
          tcp        0      0 0.0.0.0:1883            0.0.0.0:*               LISTEN      1001       20705      999/io.sonoff.0
          tcp        0      0 127.0.0.1:9000          0.0.0.0:*               LISTEN      1001       18400      632/iobroker.js-con
          tcp        0      0 127.0.0.1:9001          0.0.0.0:*               LISTEN      1001       19317      632/iobroker.js-con
          tcp6       0      0 :::8081                 :::*                    LISTEN      1001       178386     15017/io.admin.0
          tcp6       0      0 :::8082                 :::*                    LISTEN      1001       363390     9027/io.web.0
          tcp6       0      0 :::22                   :::*                    LISTEN      0          18010      642/sshd
          tcp6       0      0 ::1:631                 :::*                    LISTEN      0          11568911   30479/cupsd
          tcp6       0      0 :::3500                 :::*                    LISTEN      1001       21820      980/io.sonos.0
          udp        0      0 0.0.0.0:6666            0.0.0.0:*                           1001       19741      1036/io.tuya.0
          udp        0      0 0.0.0.0:6667            0.0.0.0:*                           1001       19742      1036/io.tuya.0
          udp        0      0 0.0.0.0:37928           0.0.0.0:*                           1001       21652      911/io.philips-air.
          udp        0      0 0.0.0.0:5683            0.0.0.0:*                           1001       21575      856/io.shelly.0
          udp        0      0 0.0.0.0:68              0.0.0.0:*                           0          18449      631/dhcpcd
          udp        0      0 0.0.0.0:631             0.0.0.0:*                           0          11569634   30482/cups-browsed
          udp        0      0 0.0.0.0:41100           0.0.0.0:*                           1001       24005      1320/io.musiccast.0
          udp        0      0 0.0.0.0:60062           0.0.0.0:*                           108        17435      356/avahi-daemon: r
          udp        0      0 0.0.0.0:5353            0.0.0.0:*                           108        17433      356/avahi-daemon: r
          udp        0      0 0.0.0.0:48886           0.0.0.0:*                           1001       21952      1017/io.philips-air
          udp6       0      0 :::546                  :::*                                0          18466      631/dhcpcd
          udp6       0      0 :::5353                 :::*                                108        17434      356/avahi-daemon: r
          udp6       0      0 :::39823                :::*                                108        17436      356/avahi-daemon: r
          2023-12-30 20:25:54.884  - info: philips-air.0 (911) State value to set for "philips-air.0.control.lightBrightness" has to be type "number" but received type "string"
          2023-12-30 20:25:59.600  - error: govee.0 (19110) AxiosError: Request failed with status code 429
          2023-12-30 20:25:54.889  - info: philips-air.0 (911) State value to set for "philips-air.0.control.airQualityNotificationThreshold" has to be type "number" but received type "string"
          2023-12-30 20:25:54.898  - info: philips-air.0 (911) State value to set for "philips-air.0.status.allergenIndex" has to be type "number" but received type "string"
          2023-12-30 20:25:54.944  - info: philips-air.0 (911) State value to set for "philips-air.0.control.childLock" has to be type "boolean" but received type "string"
          2023-12-30 20:25:54.996  - info: philips-air.0 (911) State value to set for "philips-air.0.device.uptime" has to be type "number" but received type "string"
          2023-12-30 20:25:55.052  - info: philips-air.0 (911) State value to set for "philips-air.0.status.pm25" has to be type "number" but received type "string"
          2023-12-30 20:25:55.072  - info: philips-air.0 (911) State value to set for "philips-air.0.control.timerHours" has to be type "number" but received type "string"
          2023-12-30 20:25:55.079  - info: philips-air.0 (911) State value to set for "philips-air.0.status.timerMinutes" has to be type "number" but received type "string"
          2023-12-30 20:25:55.095  - info: philips-air.0 (911) State value to set for "philips-air.0.filter.preFilterCleanInHours" has to be type "number" but received type "string"
          2023-12-30 20:25:55.144  - info: philips-air.0 (911) State value to set for "philips-air.0.filter.hepaFilterReplaceInHours" has to be type "number" but received type "string"
          2023-12-30 20:25:55.151  - info: philips-air.0 (911) State value to set for "philips-air.0.filter.activeCarbonFilterReplaceInHours" has to be type "number" but received type "string"
          2023-12-30 20:26:05.399  - info: philips-air.0 (911) State value to set for "philips-air.0.control.lightBrightness" has to be type "number" but received type "string"
          2023-12-30 20:26:09.619  - error: govee.0 (19110) AxiosError: Request failed with status code 429
          2023-12-30 20:26:05.408  - info: philips-air.0 (911) State value to set for "philips-air.0.control.airQualityNotificationThreshold" has to be type "number" but received type "string"
          2023-12-30 20:26:05.460  - info: philips-air.0 (911) State value to set for "philips-air.0.status.allergenIndex" has to be type "number" but received type "string"
          2023-12-30 20:26:05.465  - info: philips-air.0 (911) State value to set for "philips-air.0.control.childLock" has to be type "boolean" but received type "string"
          2023-12-30 20:26:05.513  - info: philips-air.0 (911) State value to set for "philips-air.0.device.uptime" has to be type "number" but received type "string"
          2023-12-30 20:26:05.574  - info: philips-air.0 (911) State value to set for "philips-air.0.status.pm25" has to be type "number" but received type "string"
          2023-12-30 20:26:05.600  - info: philips-air.0 (911) State value to set for "philips-air.0.control.timerHours" has to be type "number" but received type "string"
          2023-12-30 20:26:05.656  - info: philips-air.0 (911) State value to set for "philips-air.0.status.timerMinutes" has to be type "number" but received type "string"
          2023-12-30 20:26:05.681  - info: philips-air.0 (911) State value to set for "philips-air.0.filter.preFilterCleanInHours" has to be type "number" but received type "string"
          2023-12-30 20:26:05.744  - info: philips-air.0 (911) State value to set for "philips-air.0.filter.hepaFilterReplaceInHours" has to be type "number" but received type "string"
          2023-12-30 20:26:05.752  - info: philips-air.0 (911) State value to set for "philips-air.0.filter.activeCarbonFilterReplaceInHours" has to be type "number" but received type "string"
          2023-12-30 20:26:19.613  - error: govee.0 (19110) AxiosError: Request failed with status code 429
          • Glasfaser
            Glasfaser @gluecksmann last edited by Glasfaser
            @gluecksmann
            da mir von allen Seitern gesagt wird das mein System veraltet ist,
            richtig ... aber du kannst auch gerne bei Threaderstellung mehr Input geben ,
            denn nicht jeder verfolgt deine Threads bzw. ist auch dort enthalten
            https://forum.iobroker.net/topic/71348/zigbee-stick-spinnt-gelöst
            kann ich im Notfall einfach die Karte wieder zurücktauschen,
            ja geht
            • wcag22
              wcag22 @Meister Mopper last edited by wcag22
              @meister-mopper sagte in IoBroker neu aufbauen:
              ... mehr nicht...
              So wie ich die Ausgangsfrage verstanden habe, sind die von Dir geforderten Informationen nicht notwendig.
              Weil:
              Ohne SD-Karte ist der Raspi "doof" und kann gar nichts. Er macht mit bzw. nach dem booten nur das, was ihm über die SD-Karte "befohlen" wird.
              Um die Frage von @gluecksmann zu beantworten: ja.
              Du kannst beliebig viele SD-Karten vorbereiten und diese nach einander verwenden. Nach dem herunterfahren des Raspi und entfernen der SD-Karte ist der Raspi wieder "doof" und kann weder booten noch irgendetwas tun.
              Heißt: Nur über die verwendete SD-Karte teilst Du dem Raspi mit, was auf ihm passiert.
              Heißt: Nach entfernen der SD-Karte bleiben auf dem Raspi keinerlei Informationen zurück.
              Heißt: Du fängst mit jeder SD-Karte neu und von vorn an, egal, was Du machst.
              Ich hoffe, das war das, was Du wissen wolltest...
              • Glasfaser
                Nur mal am Rande ...
                das sehe ich bei jeder Ausgabe von dir ... ist das gewollt das dein Log damit zugemüllt wird , wenn nicht stelle bei der Adapter Instanz philips-air die Logstufe auf Warn oder Error .
                  gluecksmann @Glasfaser last edited by
                  @glasfaser
                  Hallo, Ihr habt meine Frage richtig verstanden... Karte wechseln...neu versuchen...
                  Zu dem philips air... der ist aktuell aus... sollte ich die Instanz einfach mal pausieren...
                  DAnke für eure Infos...nun kann ich "spielen"
                  • Glasfaser
                    Du kannst doch die Instanz an lassen .
                    Nur meine Frage war ... ist es Absicht das du alles sehen willst was der Adapter philips-air macht , deshalb mein Vorschlag
                    @glasfaser sagte in IoBroker neu aufbauen:
                    Das reicht dann ...
                      @glasfaser
                      Nö, eigendlich nicht... Kann man scheinbar umstellen...
                      • Dr. Bakterius
                        Dr. Bakterius Most Active @gluecksmann last edited by
                        @gluecksmann Ich würde eine neue SD-Karte hernehmen und das aktuelle Raspian ohne Desktop raufspielen. Mit backitup ein Backup vom ioBroker auf einen USB-Stick oder ein Netzlaufwerk sichern. Auf die neue SD-Karte ioBroker installieren. Falls du VIS verwendest dieses installieren und dann das Backup wiederherstellen. Fertig.
                        Und wenn es nicht so klappt wie du dir das wünscht, einfach die alte Karte wieder in den Raspi und alles ist wie es bis jetzt war.
                          Shadowhunter23 @Dr. Bakterius last edited by Shadowhunter23
                          @dr-bakterius sagte in IoBroker neu aufbauen *gelöst*:
                          Unter backitup kann man das Backup herunterladen und auf der neuen Installation wieder hochladen. Da ist weder USB Stick oder NAS nötig.
                          Mit VIS 1.5.4 ist der Fehler behoben das man VIS zuerst installieren muss bei der Neuinstallation. Selber getestet und funktioniert.
                          Dr. Bakterius 1 Reply Last reply Reply Quote 1
                          • Dr. Bakterius
                            Dr. Bakterius Most Active @Shadowhunter23 last edited by
                            @shadowhunter23 Danke für die Hinweise. Da ich meine Backups auf einem Netzlaufwerk speichere, war mir das nicht bekannt. Und VIS einmalig zu installieren macht nicht viel Mühe. Aber gut, dass man nicht mehr daran denken muss.
                            crunchip G 2 Replies Last reply Reply Quote 0
                              crunchip Forum Testing Most Active @Dr. Bakterius last edited by
                              wie oft gab ich schon den Hinweis mit dem "Vis bug" hier im Forum und trotzdem, als ich kürzlich 3mal ne Testinstallation auf nem anderen Rechner installierte, hab ichs selbst jedesmal vergessen, vis vor dem backup zu installieren😂
                                Homoran Global Moderator Administrators @crunchip last edited by Homoran
                                @crunchip jetzt nicht mehr!
                                mit vis 1.5.4 hat das endlich ein Ende
                                Deswegen ist die Version auch ziemlich schnell ins stable "geprügelt worden"
                                  crunchip Forum Testing Most Active @Homoran last edited by
                                  @homoran hab ich schon mitbekommen, zu dem Zeitpunkt gabs die allerdings noch nicht
                                  @homoran sagte in IoBroker neu aufbauen *gelöst*:
                                  dein Wort in Gottes Ohren😁
                                    gluecksmann @Dr. Bakterius last edited by
                                    @dr-bakterius
                                    Bevor ich gleich am Start was falsch mache... Ich finde ein angeblich veraltetes IOS Image, und eine 2er Beta. Welche nehmen? Hat jemand eine schöne ANleitung? Finde den Link nicht mher..hatte mir schon mal jemand gepostet...
                                      Thomas Braun Most Active @gluecksmann last edited by
                                      @gluecksmann
                                      Mach es danach:
                                      https://forum.iobroker.net/topic/51869/installation-auf-raspi-einfacher-geht-s-nicht
                                        gluecksmann @Thomas Braun last edited by
                                        wie zu erwarten war bei mir... klappt nicht...als ich gestartet habe das System auf die SD Karte zu spielen, hat er mit den Schribrechten gemeckert, um dann trotzdem den Prozess zu starten... Hat es auch laut Abschlußmeldung erfolgreich gemacht... aber wenn ich die Karte in den Raspberry stecke, komme ich per Putty nicht drauf.... die IP Adresse sollte ja die gleiche sein, habe ich in Router so eingestellt.. Passwort und Username ist nicht gespeichert, also müsste ich ja mit den vorherigen Putty Einstellunge draufkommen...
                                          Homoran Global Moderator Administrators @gluecksmann last edited by
                                          @gluecksmann sagte in IoBroker neu aufbauen *gelöst*:
                                          klappt nicht.
                                          heisst genau was??
                                          ...keine Logausgaben, ein und Ausgaben in der Konsole......
                                          exakter Wortlaut?
                                          ohne Meldung??
                                          aber der Schlüssel hat sich geändert.
                                          auch dort nachgesehen und verifiziert?
                                            klappt nicht...
                                            Ist keine verwertbare Beschreibung. So kann ich dir nur sagen:
                                            Bei mir klappt's.
                                            G Meister Mopper 2 Replies Last reply Reply Quote 0
                                            1543
