    4. vis 1 läuft nicht mehr
      Homoran Global Moderator Administrators @Max 0 last edited by
      @max-0 bitte iob diag in der Langfassung!
      • Glasfaser
        Glasfaser last edited by
        @max-0 sagte in vis 1 läuft nicht mehr:
        Und was bedeutet im Iobroker bei Protokollen ?
        	cannot call visUtils: Not exists
        Dazu mal .
        iobroker upload all
        sudo reboot
        dann einen Browser nutzen , den du noch nie für ioBroker genutzt hast , was ist dann !?
        • Max 0
          Max 0 last edited by Max 0
          @Homoran
          Skript v.2023-10-10
          *** BASE SYSTEM ***
           Static hostname: raspberrypi5
                 Icon name: computer
                    Kernel: Linux 6.1.0-rpi7-rpi-2712
              Architecture: arm64
          Model           : Raspberry Pi 5 Model B Rev 1.0
          Docker          : false
          Virtualization  : none
          Kernel          : aarch64
          Userland        : arm64
          Systemuptime and Load:
           16:51:57 up  1:10,  2 users,  load average: 0.07, 0.02, 0.00
          CPU threads: 4
          *** RASPBERRY THROTTLING ***
          Current issues:
          Previously detected issues:
          *** Time and Time Zones ***
                         Local time: Sat 2023-12-30 16:51:57 GMT
                     Universal time: Sat 2023-12-30 16:51:57 UTC
                           RTC time: Sat 2023-12-30 16:51:57
                          Time zone: Europe/London (GMT, +0000)
                        NTP service: active
                    RTC in local TZ: no
          *** User and Groups ***
          pi
          /home/pi
          pi adm dialout cdrom sudo audio video plugdev games users input render netdev gp        io i2c spi iobroker
          *** X-Server-Setup ***
          X-Server:       false
          Desktop:
          Terminal:       tty
          Boot Target:    multi-user.target
          *** MEMORY ***
          Mem:            8.4G        676M        7.5G        5.3M        364M        7.8G
          Swap:           104M          0B        104M
          Total:          8.5G        676M        7.6G
                   8053 M total memory
                    646 M used memory
                    619 M active memory
                    133 M inactive memory
                   7150 M free memory
                     41 M buffer memory
                    306 M swap cache
                     99 M total swap
                      0 M used swap
                     99 M free swap
          Raspberry only:
          vc_gencmd_read_response returned -1
          error=1 error_msg="Command not registered"
          *** FAILED SERVICES ***
          0 loaded units listed.
          *** FILESYSTEM ***
          udev           devtmpfs  3.8G     0  3.8G   0% /dev
          tmpfs          tmpfs     806M  5.1M  801M   1% /run
          /dev/mmcblk0p2 ext4       15G  2.8G   11G  21% /
          tmpfs          tmpfs     4.0G     0  4.0G   0% /dev/shm
          tmpfs          tmpfs     5.0M   48K  5.0M   1% /run/lock
          /dev/mmcblk0p1 vfat      510M   61M  450M  12% /boot/firmware
          tmpfs          tmpfs     806M     0  806M   0% /run/user/1000
          [Sat Dec 30 15:41:39 2023] Kernel command line: coherent_pool=1M 8250.nr_uarts=1        pci=pcie_bus_safe snd_bcm2835.enable_compat_alsa=0 snd_bcm2835.enable_hdmi=1  s        msc95xx.macaddr=D8:3A:DD:BB:FC:13 vc_mem.mem_base=0x3fc00000 vc_mem.mem_size=0x4        0000000  console=ttyAMA10,115200 console=tty1 root=PARTUUID=df43037d-02 rootfsty        pe=ext4 fsck.repair=yes rootwait
          [Sat Dec 30 15:41:42 2023] EXT4-fs (mmcblk0p2): mounted filesystem with ordered        data mode. Quota mode: none.
          [Sat Dec 30 15:41:45 2023] EXT4-fs (mmcblk0p2): re-mounted. Quota mode: none.
          TARGET           SOURCE         FSTYPE OPTIONS
          /                /dev/mmcblk0p2 ext4   rw,noatime
          `-/boot/firmware /dev/mmcblk0p1 vfat   rw,relatime,fmask=0022,dmask=0022,codepag        e=437,iocharset=ascii,shortname=mixed,errors=remount-ro
          /var:
          507M    /var/
          206M    /var/cache
          200M    /var/cache/apt
          166M    /var/lib
          132M    /var/lib/apt/lists
          Archived and active journals take up 35.2M in the file system.
          /opt/iobroker/backups:
          4.0K    /opt/iobroker/backups/
          /opt/iobroker/iobroker-data:
          63M     /opt/iobroker/iobroker-data/
          59M     /opt/iobroker/iobroker-data/files
          30M     /opt/iobroker/iobroker-data/files/web.admin/static
          29M     /opt/iobroker/iobroker-data/files/web.admin/static/js
          21M     /opt/iobroker/iobroker-data/files/web.admin/static/js/main.aaea95f8.js.m        ap
          8.3M    /opt/iobroker/iobroker-data/files/web.admin/static/js/main.aaea95f8.js
          6.3M    /opt/iobroker/iobroker-data/files/admin.admin/custom/static/js/vendors-n        ode_modules_iobroker_adapter-react-v5_assets_devices_parseNames_js-node_modules_        iobr-99c23e.847b8ad9.chunk.js.map
          4.1M    /opt/iobroker/iobroker-data/objects.jsonl
          2.8M    /opt/iobroker/iobroker-data/files/admin.admin/custom/static/js/vendors-n        ode_modules_iobroker_adapter-react-v5_assets_devices_parseNames_js-node_modules_        iobr-99c23e.847b8ad9.chunk.js
          USB-Devices by-id:
          USB-Sticks -  Avoid direct links to /dev/* in your adapter setups, please always        prefer the links 'by-id':
          *** NodeJS-Installation ***
          /usr/bin/nodejs         v18.19.0
          /usr/bin/node           v18.19.0
          /usr/bin/npm            9.2.0
          /usr/bin/npx            9.2.0
          /home/iobroker/.diag.sh: line 281: corepack: command not found
          *** nodejs is NOT correctly installed ***
          nodejs:
            Installed: 18.19.0+dfsg-6~deb12u1
            Candidate: 18.19.0+dfsg-6~deb12u1
            Version table:
           *** 18.19.0+dfsg-6~deb12u1 500
                  500 http://deb.debian.org/debian-security bookworm-security/main arm64 P        ackages
                  100 /var/lib/dpkg/status
               18.19.0-1nodesource1 500
               18.18.2-1nodesource1 500
               18.18.1-1nodesource1 500
               18.18.0-1nodesource1 500
               18.17.1-1nodesource1 500
               18.17.0-1nodesource1 500
               18.16.1-1nodesource1 500
               18.16.0-1nodesource1 500
               18.15.0-1nodesource1 500
               18.14.2-1nodesource1 500
               18.14.1-1nodesource1 500
               18.14.0-1nodesource1 500
               18.13.0+dfsg1-1 500
               18.13.0-1nodesource1 500
               18.12.0-1nodesource1 500
               18.11.0-1nodesource1 500
               18.10.0-1nodesource1 500
               18.9.1-1nodesource1 500
               18.9.0-1nodesource1 500
               18.8.0-1nodesource1 500
               18.7.0-1nodesource1 500
               18.6.0-1nodesource1 500
               18.5.0-1nodesource1 500
               18.4.0-1nodesource1 500
               18.3.0-1nodesource1 500
               18.2.0-1nodesource1 500
               18.1.0-1nodesource1 500
               18.0.0-1nodesource1 500
          No problems detected
          Errors in npm tree:
          *** ioBroker-Installation ***
          ioBroker Status
          Objects type: jsonl
          States  type: jsonl
          Core adapters versions
          js-controller:  5.0.17
          admin:          6.12.0
          javascript:     "javascript" not found
          Adapters from github:   0
          Adapter State
          + system.adapter.admin.0                  : admin                 : raspberrypi5                             -  enabled, port: 8081, bind: 0.0.0.0, run as: admin
          + system.adapter.backitup.0               : backitup              : raspberrypi5                             -  enabled
          + system.adapter.discovery.0              : discovery             : raspberrypi5                             -  enabled
            system.adapter.vis.0                    : vis                   : raspberrypi5                             -  enabled
          + system.adapter.web.0                    : web                   : raspberrypi5                             -  enabled, port: 8082, bind: 0.0.0.0, run as: admin
          + instance is alive
          ioBroker-Repositories
          Active repo(s): stable
          Installed ioBroker-Instances
          Used repository: stable
          Adapter    "admin"        : 6.12.0   , installed 6.12.0
          Adapter    "backitup"     : 2.9.8    , installed 2.9.8
          Controller "js-controller": 5.0.17   , installed 5.0.17
          Adapter    "web"          : 6.1.10   , installed 6.1.10
          Adapter    "ws"           : 2.5.8    , installed 2.5.8
          Objects and States
          Objects:        180
          States:         132
          Hit:2 http://deb.debian.org/debian-security bookworm-security InRelease
          Hit:3 http://deb.debian.org/debian bookworm-updates InRelease
          Hit:4 http://archive.raspberrypi.com/debian bookworm InRelease
          Hit:5 https://deb.nodesource.com/node_18.x nodistro InRelease
          Reading package lists...
          Pending Updates: 0
          *** Listening Ports ***
          tcp        0      0 127.0.0.1:9000          0.0.0.0:*               LISTEN      1001       14108      820/iobroker.js-con
          tcp        0      0 127.0.0.1:9001          0.0.0.0:*               LISTEN      1001       15042      820/iobroker.js-con
          tcp        0      0 0.0.0.0:22              0.0.0.0:*               LISTEN      0          14028      828/sshd: /usr/sbin
          tcp6       0      0 :::8082                 :::*                    LISTEN      1001       16177      973/io.web.0
          tcp6       0      0 :::8081                 :::*                    LISTEN      1001       14159      915/io.admin.0
          tcp6       0      0 :::22                   :::*                    LISTEN      0          14039      828/sshd: /usr/sbin
          udp        0      0 0.0.0.0:41688           0.0.0.0:*                           104        13951      678/avahi-daemon: r
          udp        0      0 0.0.0.0:5353            0.0.0.0:*                           104        13949      678/avahi-daemon: r
          udp6       0      0 fe80::4618:f457:9d0:546 :::*                                0          15032      785/NetworkManager
          udp6       0      0 :::5353                 :::*                                104        13950      678/avahi-daemon: r
          udp6       0      0 :::35918                :::*                                104        13952      678/avahi-daemon: r
          2023-12-30 15:42:03.837  - info: admin.0 (915) received all objects
          2023-12-30 15:42:04.857  - info: admin.0 (915) socket.io server listening on port 8081
          2023-12-30 15:42:04.860  - info: admin.0 (915) http server listening on port 8081
          2023-12-30 15:42:04.861  - info: admin.0 (915) Use link "http://127.0.0.1:8081" to configure.
          2023-12-30 15:42:04.929  - info: host.raspberrypi5 instance system.adapter.discovery.0 started with pid 938
          2023-12-30 15:42:06.016  - info: discovery.0 (938) starting. Version 4.2.0 in /opt/iobroker/node_modules/iobroker.discovery, node: v18.19.0, js-controller: 5.0.17
          2023-12-30 15:42:08.930  - info: host.raspberrypi5 instance system.adapter.backitup.0 started with pid 958
          2023-12-30 15:42:09.916  - info: backitup.0 (958) starting. Version 2.9.8 in /opt/iobroker/node_modules/iobroker.backitup, node: v18.19.0, js-controller: 5.0.17
          2023-12-30 15:42:09.977  - info: backitup.0 (958) [iobroker] backup will be activated at 02:48 every 1 day(s)
          2023-12-30 15:42:12.929  - info: host.raspberrypi5 instance system.adapter.web.0 started with pid 973
          2023-12-30 15:42:13.948  - info: web.0 (973) starting. Version 6.1.10 in /opt/iobroker/node_modules/iobroker.web, node: v18.19.0, js-controller: 5.0.17
          2023-12-30 15:42:14.040  - info: web.0 (973) socket.io server listening on port 8082
          2023-12-30 15:42:14.043  - info: web.0 (973) http server listening on port 8082
          2023-12-30 15:42:17.694  - info: vis.0 (988) starting. Version 1.5.4 in /opt/iobroker/node_modules/iobroker.vis, node: v18.19.0, js-controller: 5.0.17
          2023-12-30 15:42:18.455  - info: vis.0 (988) Terminated (NO_ERROR): Without reason
          2023-12-30 15:42:19.004  - info: host.raspberrypi5 instance system.adapter.vis.0 terminated while should be started once
          2023-12-30 15:42:31.020  - info: admin.0 (915) ==> Connected system.user.admin from ::ffff:192.168.178.109
          2023-12-30 15:42:31.118  - error: host.raspberrypi5 cannot call visUtils: Not exists
          2023-12-30 15:42:36.962  - error: host.raspberrypi5 cannot call visUtils: Not exists
          2023-12-30 15:42:42.183  - info: web.0 (973) ==> Connected system.user.admin from ::ffff:192.168.178.109
          2023-12-30 15:42:45.358  - info: web.0 (973) <== Disconnect system.user.admin from ::ffff:192.168.178.109 vis.0
          2023-12-30 15:42:45.630  - info: web.0 (973) ==> Connected system.user.admin from ::ffff:192.168.178.109
          2023-12-30 15:42:50.459  - info: web.0 (973) <== Disconnect system.user.admin from ::ffff:192.168.178.109 vis.0
          2023-12-30 15:54:29.081  - info: admin.0 (915) ==> Connected system.user.admin from ::ffff:192.168.178.109
          2023-12-30 15:54:31.491  - info: admin.0 (915) <== Disconnect system.user.admin from ::ffff:192.168.178.109 web
            Thomas Braun Most Active @Max 0 last edited by Thomas Braun
            @max-0
            Zeitzone ist wohl falsch.
            Und nodejs ist auch nicht die richtige Version.
            https://forum.iobroker.net/topic/71478/plötzliche-probleme-durch-nodejs-dfsg-version
            • Max 0
              An alle danke für die schnelle Hilfe aber wenn ich einen anderen Browser benutze funktioniert alles wie gewohnt
              Glasfaser OliverIO Homoran 3 Replies Last reply Reply Quote 0
              • Glasfaser
                Glasfaser @Max 0 last edited by
                OK .. wie ich auch geschrieben habe ... :
                @glasfaser sagte in vis 1 läuft nicht mehr:
                Was war mit den Befehlen, hast du sie zuvor noch genutzt !?
                und beachte auch was @Thomas-Braun noch Dir vorgibt !
                • OliverIO
                  OliverIO @Max 0 last edited by OliverIO
                  dann den browser cache löschen und neu im browser laden
                  https://www.ionos.de/digitalguide/server/konfiguration/so-leeren-sie-ihren-cache/
                    ist jetzt nicht wahr?!?
                    wel hen nutzst du und wie sieht es da im incognito modus aus?
                    Max 0 1 Reply Last reply Reply Quote 0
                    • Max 0
                      Max 0 @Homoran last edited by
                      Ich nutze den Opera GX Browser
                      Und es geht auch nicht im incognit modus
                        Homoran Global Moderator Administrators @Max 0 last edited by Homoran
                        Opera hat so seine Zicken.
                        Der ist grundsätzlich nicht empfohlen
                        und auf was für einem OS?
                        wäre jetzt aver interessant was in dessen Browserkonsole für ein Problem angezeigt wird
                        3399
