IoBroker neu aufbauen *gelöst*
Skript v.2023-10-10 *** BASE SYSTEM *** Static hostname: raspberrypi Icon name: computer Operating System: Raspbian GNU/Linux 10 (buster) Kernel: Linux 5.10.103-v7l+ Architecture: arm Model : Raspberry Pi 4 Model B Rev 1.4 Docker : false Virtualization : none Kernel : armv7l Userland : armhf Systemuptime and Load: 20:24:12 up 2 days, 6:12, 1 user, load average: 0.82, 0.63, 0.57 CPU threads: 4 *** RASPBERRY THROTTLING *** Current issues: No throttling issues detected. Previously detected issues: No throttling issues detected. *** Time and Time Zones *** Local time: Sat 2023-12-30 20:24:13 CET Universal time: Sat 2023-12-30 19:24:13 UTC RTC time: n/a Time zone: Europe/Berlin (CET, +0100) System clock synchronized: yes NTP service: active RTC in local TZ: no *** User and Groups *** pi /home/pi pi adm dialout cdrom sudo audio video plugdev games users input netdev lpadmin gpio i2c spi iobroker *** X-Server-Setup *** X-Server: false Desktop: Terminal: tty Boot Target: multi-user.target *** MEMORY *** total used free shared buff/cache available Mem: 7.9G 1.9G 3.9G 139M 2.1G 5.6G Swap: 99M 0B 99M Total: 8.0G 1.9G 4.0G 7898 M total memory 1924 M used memory 410 M active memory 3398 M inactive memory 3860 M free memory 182 M buffer memory 1931 M swap cache 99 M total swap 0 M used swap 99 M free swap Raspberry only: oom events: 0 lifetime oom required: 0 Mbytes total time in oom handler: 0 ms max time spent in oom handler: 0 ms *** FAILED SERVICES *** UNIT LOAD ACTIVE SUB DESCRIPTION * lightdm.service loaded failed failed Light Display Manager LOAD = Reflects whether the unit definition was properly loaded. ACTIVE = The high-level unit activation state, i.e. generalization of SUB. SUB = The low-level unit activation state, values depend on unit type. 1 loaded units listed. Pass --all to see loaded but inactive units, too. To show all installed unit files use 'systemctl list-unit-files'. *** FILESYSTEM *** Filesystem Type Size Used Avail Use% Mounted on /dev/root ext4 29G 14G 15G 50% / devtmpfs devtmpfs 3.7G 0 3.7G 0% /dev tmpfs tmpfs 3.9G 0 3.9G 0% /dev/shm tmpfs tmpfs 3.9G 140M 3.8G 4% /run tmpfs tmpfs 5.0M 4.0K 5.0M 1% /run/lock tmpfs tmpfs 3.9G 0 3.9G 0% /sys/fs/cgroup /dev/mmcblk0p1 vfat 253M 49M 204M 20% /boot tmpfs tmpfs 790M 0 790M 0% /run/user/1000 Messages concerning ext4 filesystem in dmesg: [Thu Dec 28 14:11:43 2023] Kernel command line: coherent_pool=1M 8250.nr_uarts=0 snd_bcm2835.enable_compat_alsa=0 snd_bcm2835.enable_hdmi=1 smsc95xx.macaddr=E4:5F:01:3D:9B:6E vc_mem.mem_base=0x3ec00000 vc_mem.mem_size=0x40000000 dwc_otg.lpm_enable=0 console=ttyS0,115200 console=tty1 root=PARTUUID=a372f35c-02 rootfstype=ext4 elevator=deadline fsck.repair=yes rootwait quiet splash plymouth.ignore-serial-consoles [Thu Dec 28 14:11:44 2023] EXT4-fs (mmcblk0p2): mounted filesystem with ordered data mode. Opts: (null) [Thu Dec 28 14:11:44 2023] VFS: Mounted root (ext4 filesystem) readonly on device 179:2. [Thu Dec 28 14:11:46 2023] EXT4-fs (mmcblk0p2): re-mounted. Opts: (null) Show mounted filesystems \(real ones only\): TARGET SOURCE FSTYPE OPTIONS / /dev/mmcblk0p2 ext4 rw,noatime |-/sys/fs/bpf none bpf rw,nosuid,nodev,noexec,relatime,mode=700 `-/boot /dev/mmcblk0p1 vfat rw,relatime,fmask=0022,dmask=0022,codepage=437,iocharset=ascii,shortname=mixed,errors=remount-ro Files in neuralgic directories: /var: 440M /var/ 118M /var/log 118M /var/lib 102M /var/cache 90M /var/cache/apt Archived and active journals take up 138.7M in the file system. /opt/iobroker/backups: 63M /opt/iobroker/backups/ /opt/iobroker/iobroker-data: 628M /opt/iobroker/iobroker-data/ 323M /opt/iobroker/iobroker-data/files 143M /opt/iobroker/iobroker-data/backup-objects 93M /opt/iobroker/iobroker-data/sonosCache 67M /opt/iobroker/iobroker-data/files/javascript.admin The five largest files in iobroker-data are: 35M /opt/iobroker/iobroker-data/files/devices.admin/static/js/main.24f2bb56.js.map 33M /opt/iobroker/iobroker-data/files/iot.admin/static/js/main.1797d034.js.map 23M /opt/iobroker/iobroker-data/objects.jsonl 21M /opt/iobroker/iobroker-data/files/web.admin/static/js/main.aaea95f8.js.map 18M /opt/iobroker/iobroker-data/states.jsonl USB-Devices by-id: USB-Sticks - Avoid direct links to /dev/* in your adapter setups, please always prefer the links 'by-id': /dev/serial/by-id/usb-Texas_Instruments_TI_CC2531_USB_CDC___0X00124B001CDD3388-if00 *** NodeJS-Installation *** /usr/bin/nodejs v18.19.0 /usr/bin/node v18.19.0 /usr/bin/npm 10.2.3 /usr/bin/npx 10.2.3 /usr/bin/corepack 0.22.0 nodejs: Installed: 18.19.0-1nodesource1 Candidate: 18.19.0-1nodesource1 Version table: *** 18.19.0-1nodesource1 1001 500 https://deb.nodesource.com/node_18.x nodistro/main armhf Packages 100 /var/lib/dpkg/status 18.18.2-1nodesource1 1001 500 https://deb.nodesource.com/node_18.x nodistro/main armhf Packages 18.18.1-1nodesource1 1001 500 https://deb.nodesource.com/node_18.x nodistro/main armhf Packages 18.18.0-1nodesource1 1001 500 https://deb.nodesource.com/node_18.x nodistro/main armhf Packages 18.17.1-1nodesource1 1001 500 https://deb.nodesource.com/node_18.x nodistro/main armhf Packages 18.17.0-1nodesource1 1001 500 https://deb.nodesource.com/node_18.x nodistro/main armhf Packages 18.16.1-1nodesource1 1001 500 https://deb.nodesource.com/node_18.x nodistro/main armhf Packages 18.16.0-1nodesource1 1001 500 https://deb.nodesource.com/node_18.x nodistro/main armhf Packages 18.15.0-1nodesource1 1001 500 https://deb.nodesource.com/node_18.x nodistro/main armhf Packages 18.14.2-1nodesource1 1001 500 https://deb.nodesource.com/node_18.x nodistro/main armhf Packages 18.14.1-1nodesource1 1001 500 https://deb.nodesource.com/node_18.x nodistro/main armhf Packages 18.14.0-1nodesource1 1001 500 https://deb.nodesource.com/node_18.x nodistro/main armhf Packages 18.13.0-1nodesource1 1001 500 https://deb.nodesource.com/node_18.x nodistro/main armhf Packages 18.12.0-1nodesource1 1001 500 https://deb.nodesource.com/node_18.x nodistro/main armhf Packages 18.11.0-1nodesource1 1001 500 https://deb.nodesource.com/node_18.x nodistro/main armhf Packages 18.10.0-1nodesource1 1001 500 https://deb.nodesource.com/node_18.x nodistro/main armhf Packages 18.9.1-1nodesource1 1001 500 https://deb.nodesource.com/node_18.x nodistro/main armhf Packages 18.9.0-1nodesource1 1001 500 https://deb.nodesource.com/node_18.x nodistro/main armhf Packages 18.8.0-1nodesource1 1001 500 https://deb.nodesource.com/node_18.x nodistro/main armhf Packages 18.7.0-1nodesource1 1001 500 https://deb.nodesource.com/node_18.x nodistro/main armhf Packages 18.6.0-1nodesource1 1001 500 https://deb.nodesource.com/node_18.x nodistro/main armhf Packages 18.5.0-1nodesource1 1001 500 https://deb.nodesource.com/node_18.x nodistro/main armhf Packages 18.4.0-1nodesource1 1001 500 https://deb.nodesource.com/node_18.x nodistro/main armhf Packages 18.3.0-1nodesource1 1001 500 https://deb.nodesource.com/node_18.x nodistro/main armhf Packages 18.2.0-1nodesource1 1001 500 https://deb.nodesource.com/node_18.x nodistro/main armhf Packages 18.1.0-1nodesource1 1001 500 https://deb.nodesource.com/node_18.x nodistro/main armhf Packages 18.0.0-1nodesource1 1001 500 https://deb.nodesource.com/node_18.x nodistro/main armhf Packages 10.24.0~dfsg-1~deb10u3 500 500 http://raspbian.raspberrypi.org/raspbian buster/main armhf Packages Temp directories causing npm8 problem: 0 No problems detected Errors in npm tree: npm ERR! code ELSPROBLEMS npm ERR! invalid: iobroker.govee@0.0.6 /opt/iobroker/node_modules/iobroker.govee npm ERR! A complete log of this run can be found in: /home/pi/.npm/_logs/2023-12-30T19_24_22_588Z-debug-0.log *** ioBroker-Installation *** ioBroker Status iobroker is running on this host. Objects type: jsonl States type: jsonl Core adapters versions js-controller: 5.0.17 admin: 6.12.0 javascript: 7.1.6 npm ERR! code ELSPROBLEMS npm ERR! invalid: iobroker.govee@0.0.6 /opt/iobroker/node_modules/iobroker.govee npm ERR! A complete log of this run can be found in: /home/pi/.npm/_logs/2023-12-30T19_24_44_517Z-debug-0.log Adapters from github: 1 Adapter State + system.adapter.admin.0 : admin : raspberrypi - enabled, port: 8081, bind: 0.0.0.0, run as: admin + system.adapter.alexa2.0 : alexa2 : raspberrypi - enabled system.adapter.alias-manager.0 : alias-manager : raspberrypi - disabled + system.adapter.awtrix-light.0 : awtrix-light : raspberrypi - enabled + system.adapter.backitup.0 : backitup : raspberrypi - enabled + system.adapter.ble.0 : ble : raspberrypi - enabled system.adapter.chromecast.0 : chromecast : raspberrypi - disabled system.adapter.daswetter.0 : daswetter : raspberrypi - enabled system.adapter.devices.0 : devices : raspberrypi - disabled + system.adapter.discovery.0 : discovery : raspberrypi - enabled system.adapter.dwd.0 : dwd : raspberrypi - enabled + system.adapter.fullybrowser.0 : fullybrowser : raspberrypi - enabled + system.adapter.govee.0 : govee : raspberrypi - enabled + system.adapter.gruenbeck.0 : gruenbeck : raspberrypi - enabled system.adapter.history.0 : history : raspberrypi - disabled + system.adapter.hue.0 : hue : raspberrypi - enabled, port: 443 system.adapter.ical.0 : ical : raspberrypi - enabled system.adapter.icons-mfd-png.0 : icons-mfd-png : raspberrypi - disabled system.adapter.icons-mfd-svg.0 : icons-mfd-svg : raspberrypi - disabled + system.adapter.info.0 : info : raspberrypi - enabled + system.adapter.iot.0 : iot : raspberrypi - enabled + system.adapter.javascript.0 : javascript : raspberrypi - enabled + system.adapter.meross.0 : meross : raspberrypi - enabled + system.adapter.mielecloudservice.0 : mielecloudservice : raspberrypi - enabled + system.adapter.musiccast.0 : musiccast : raspberrypi - enabled + system.adapter.net-tools.0 : net-tools : raspberrypi - enabled + system.adapter.netatmo.0 : netatmo : raspberrypi - enabled + system.adapter.philips-air.0 : philips-air : raspberrypi - enabled + system.adapter.philips-air.1 : philips-air : raspberrypi - enabled + system.adapter.ping.0 : ping : raspberrypi - enabled + system.adapter.pollenflug.0 : pollenflug : raspberrypi - enabled + system.adapter.scenes.0 : scenes : raspberrypi - enabled + system.adapter.shelly.0 : shelly : raspberrypi - enabled, port: 1882, bind: 0.0.0.0 system.adapter.shuttercontrol.0 : shuttercontrol : raspberrypi - disabled + system.adapter.smartcontrol.0 : smartcontrol : raspberrypi - enabled + system.adapter.sonoff.0 : sonoff : raspberrypi - enabled, port: 1883, bind: 0.0.0.0 + system.adapter.sonos.0 : sonos : raspberrypi - enabled + system.adapter.trashschedule.0 : trashschedule : raspberrypi - enabled + system.adapter.tuya.0 : tuya : raspberrypi - enabled system.adapter.vis-colorpicker.0 : vis-colorpicker : raspberrypi - enabled system.adapter.vis-hqwidgets.0 : vis-hqwidgets : raspberrypi - enabled system.adapter.vis-icontwo.0 : vis-icontwo : raspberrypi - enabled + system.adapter.vis-inventwo.0 : vis-inventwo : raspberrypi - enabled system.adapter.vis-material-advanced.0 : vis-material-advanced : raspberrypi - enabled system.adapter.vis-metro.0 : vis-metro : raspberrypi - enabled system.adapter.vis-players.0 : vis-players : raspberrypi - enabled system.adapter.vis-timeandweather.0 : vis-timeandweather : raspberrypi - enabled system.adapter.vis.0 : vis : raspberrypi - enabled system.adapter.weatherunderground.0 : weatherunderground : raspberrypi - enabled + system.adapter.web.0 : web : raspberrypi - enabled, port: 8082, bind: 0.0.0.0, run as: admin + system.adapter.zigbee.0 : zigbee : raspberrypi - enabled, port: /dev/serial/by-id/usb-Texas_Instruments_TI_CC2531_USB_CDC___0X00124B001CDD3388-if00 + instance is alive Enabled adapters with bindings + system.adapter.admin.0 : admin : raspberrypi - enabled, port: 8081, bind: 0.0.0.0, run as: admin + system.adapter.hue.0 : hue : raspberrypi - enabled, port: 443 + system.adapter.shelly.0 : shelly : raspberrypi - enabled, port: 1882, bind: 0.0.0.0 + system.adapter.sonoff.0 : sonoff : raspberrypi - enabled, port: 1883, bind: 0.0.0.0 + system.adapter.web.0 : web : raspberrypi - enabled, port: 8082, bind: 0.0.0.0, run as: admin + system.adapter.zigbee.0 : zigbee : raspberrypi - enabled, port: /dev/serial/by-id/usb-Texas_Instruments_TI_CC2531_USB_CDC___0X00124B001CDD3388-if00 ioBroker-Repositories stable : http://download.iobroker.net/sources-dist.json beta : http://download.iobroker.net/sources-dist-latest.json Active repo(s): stable Installed ioBroker-Instances Used repository: stable Adapter "admin" : 6.12.0 , installed 6.12.0 Adapter "alexa2" : 3.26.3 , installed 3.26.3 Adapter "alias-manager": 1.2.6 , installed 1.2.6 Adapter "awtrix-light" : 0.10.0 , installed 0.10.0 Adapter "backitup" : 2.9.8 , installed 2.9.8 Adapter "ble" : 0.13.4 , installed 0.13.4 Adapter "chromecast" : 3.0.3 , installed 3.0.3 Adapter "daswetter" : 3.1.11 , installed 3.1.11 Adapter "devices" : 1.1.5 , installed 1.1.5 Adapter "discovery" : 4.2.0 , installed 4.2.0 Adapter "dwd" : 2.8.5 , installed 2.8.5 Adapter "fullybrowser" : 3.0.6 , installed 3.0.6 Adapter "gruenbeck" : 0.0.42 , installed 0.0.42 Adapter "history" : 3.0.1 , installed 3.0.1 Adapter "hue" : 3.10.1 , installed 3.10.1 Adapter "ical" : 1.13.3 , installed 1.13.3 Adapter "icons-mfd-png": 1.2.1 , installed 1.1.0 [Updatable] Adapter "icons-mfd-svg": 1.1.0 , installed 1.1.0 Adapter "info" : 2.0.0 , installed 2.0.0 Adapter "iot" : 2.0.11 , installed 2.0.11 Adapter "javascript" : 7.1.6 , installed 7.1.6 Controller "js-controller": 5.0.17 , installed 5.0.17 Adapter "meross" : 1.16.1 , installed 1.15.1 [Updatable] Adapter "mielecloudservice": 6.5.4, installed 6.5.4 Adapter "mihome-vacuum": 4.1.0 , installed 4.1.0 Adapter "musiccast" : 1.1.3 , installed 1.1.3 Adapter "net-tools" : 0.2.0 , installed 0.2.0 Adapter "netatmo" : 3.1.0 , installed 3.1.0 Adapter "philips-air" : 1.0.3 , installed 1.0.3 Adapter "ping" : 1.6.2 , installed 1.6.2 Adapter "pollenflug" : 1.0.6 , installed 1.0.6 Adapter "scenes" : 2.3.9 , installed 2.3.9 Adapter "shelly" : 6.6.1 , installed 6.6.1 Adapter "shuttercontrol": 1.6.3 , installed 1.6.3 Adapter "simple-api" : 2.7.2 , installed 2.7.2 Adapter "smartcontrol" : 2.0.1 , installed 2.0.1 Adapter "socketio" : 6.6.0 , installed 6.6.0 Adapter "sonoff" : 3.0.3 , installed 3.0.3 Adapter "sonos" : 3.0.0 , installed 3.0.0 Adapter "trashschedule": 2.3.0 , installed 2.3.0 Adapter "tuya" : 3.15.0 , installed 3.14.2 [Updatable] Adapter "vis" : 1.5.4 , installed 1.5.4 Adapter "vis-colorpicker": 2.0.3 , installed 2.0.3 Adapter "vis-hqwidgets": 1.4.0 , installed 1.4.0 Adapter "vis-icontwo" : 1.0.0 , installed 1.0.0 Adapter "vis-inventwo" : 3.3.3 , installed 3.3.3 Adapter "vis-material-advanced": 1.7.4, installed 1.7.4 Adapter "vis-metro" : 1.2.0 , installed 1.2.0 Adapter "vis-players" : 0.1.6 , installed 0.1.6 Adapter "vis-timeandweather": 1.2.2, installed 1.2.2 Adapter "weatherunderground": 3.6.0, installed 3.6.0 Adapter "web" : 6.1.10 , installed 6.1.10 Adapter "ws" : 2.5.8 , installed 2.5.8 Adapter "zigbee" : 1.9.5 , installed 1.8.24 [Updatable] Objects and States Please stand by - This may take a while Objects: 11361 States: 9441 *** OS-Repositories and Updates *** Hit:1 http://raspbian.raspberrypi.org/raspbian buster InRelease Hit:2 http://archive.raspberrypi.org/debian buster InRelease Hit:3 https://deb.nodesource.com/node_18.x nodistro InRelease Reading package lists... Pending Updates: 0 *** Listening Ports *** Active Internet connections (only servers) Proto Recv-Q Send-Q Local Address Foreign Address State User Inode PID/Program name tcp 0 0 0.0.0.0:22 0.0.0.0:* LISTEN 0 18008 642/sshd tcp 0 0 127.0.0.1:631 0.0.0.0:* LISTEN 0 11568912 30479/cupsd tcp 0 0 0.0.0.0:1883 0.0.0.0:* LISTEN 1001 20705 999/io.sonoff.0 tcp 0 0 127.0.0.1:9000 0.0.0.0:* LISTEN 1001 18400 632/iobroker.js-con tcp 0 0 127.0.0.1:9001 0.0.0.0:* LISTEN 1001 19317 632/iobroker.js-con tcp6 0 0 :::8081 :::* LISTEN 1001 178386 15017/io.admin.0 tcp6 0 0 :::8082 :::* LISTEN 1001 363390 9027/io.web.0 tcp6 0 0 :::22 :::* LISTEN 0 18010 642/sshd tcp6 0 0 ::1:631 :::* LISTEN 0 11568911 30479/cupsd tcp6 0 0 :::3500 :::* LISTEN 1001 21820 980/io.sonos.0 udp 0 0 0.0.0.0:6666 0.0.0.0:* 1001 19741 1036/io.tuya.0 udp 0 0 0.0.0.0:6667 0.0.0.0:* 1001 19742 1036/io.tuya.0 udp 0 0 0.0.0.0:37928 0.0.0.0:* 1001 21652 911/io.philips-air. udp 0 0 0.0.0.0:5683 0.0.0.0:* 1001 21575 856/io.shelly.0 udp 0 0 0.0.0.0:68 0.0.0.0:* 0 18449 631/dhcpcd udp 0 0 0.0.0.0:631 0.0.0.0:* 0 11569634 30482/cups-browsed udp 0 0 0.0.0.0:41100 0.0.0.0:* 1001 24005 1320/io.musiccast.0 udp 0 0 0.0.0.0:60062 0.0.0.0:* 108 17435 356/avahi-daemon: r udp 0 0 0.0.0.0:5353 0.0.0.0:* 108 17433 356/avahi-daemon: r udp 0 0 0.0.0.0:48886 0.0.0.0:* 1001 21952 1017/io.philips-air udp6 0 0 :::546 :::* 0 18466 631/dhcpcd udp6 0 0 :::5353 :::* 108 17434 356/avahi-daemon: r udp6 0 0 :::39823 :::* 108 17436 356/avahi-daemon: r *** Log File - Last 25 Lines *** 2023-12-30 20:25:54.884 - info: philips-air.0 (911) State value to set for "philips-air.0.control.lightBrightness" has to be type "number" but received type "string" 2023-12-30 20:25:59.600 - error: govee.0 (19110) AxiosError: Request failed with status code 429 2023-12-30 20:25:54.889 - info: philips-air.0 (911) State value to set for "philips-air.0.control.airQualityNotificationThreshold" has to be type "number" but received type "string" 2023-12-30 20:25:54.898 - info: philips-air.0 (911) State value to set for "philips-air.0.status.allergenIndex" has to be type "number" but received type "string" 2023-12-30 20:25:54.944 - info: philips-air.0 (911) State value to set for "philips-air.0.control.childLock" has to be type "boolean" but received type "string" 2023-12-30 20:25:54.996 - info: philips-air.0 (911) State value to set for "philips-air.0.device.uptime" has to be type "number" but received type "string" 2023-12-30 20:25:55.052 - info: philips-air.0 (911) State value to set for "philips-air.0.status.pm25" has to be type "number" but received type "string" 2023-12-30 20:25:55.072 - info: philips-air.0 (911) State value to set for "philips-air.0.control.timerHours" has to be type "number" but received type "string" 2023-12-30 20:25:55.079 - info: philips-air.0 (911) State value to set for "philips-air.0.status.timerMinutes" has to be type "number" but received type "string" 2023-12-30 20:25:55.095 - info: philips-air.0 (911) State value to set for "philips-air.0.filter.preFilterCleanInHours" has to be type "number" but received type "string" 2023-12-30 20:25:55.144 - info: philips-air.0 (911) State value to set for "philips-air.0.filter.hepaFilterReplaceInHours" has to be type "number" but received type "string" 2023-12-30 20:25:55.151 - info: philips-air.0 (911) State value to set for "philips-air.0.filter.activeCarbonFilterReplaceInHours" has to be type "number" but received type "string" 2023-12-30 20:26:05.399 - info: philips-air.0 (911) State value to set for "philips-air.0.control.lightBrightness" has to be type "number" but received type "string" 2023-12-30 20:26:09.619 - error: govee.0 (19110) AxiosError: Request failed with status code 429 2023-12-30 20:26:05.408 - info: philips-air.0 (911) State value to set for "philips-air.0.control.airQualityNotificationThreshold" has to be type "number" but received type "string" 2023-12-30 20:26:05.460 - info: philips-air.0 (911) State value to set for "philips-air.0.status.allergenIndex" has to be type "number" but received type "string" 2023-12-30 20:26:05.465 - info: philips-air.0 (911) State value to set for "philips-air.0.control.childLock" has to be type "boolean" but received type "string" 2023-12-30 20:26:05.513 - info: philips-air.0 (911) State value to set for "philips-air.0.device.uptime" has to be type "number" but received type "string" 2023-12-30 20:26:05.574 - info: philips-air.0 (911) State value to set for "philips-air.0.status.pm25" has to be type "number" but received type "string" 2023-12-30 20:26:05.600 - info: philips-air.0 (911) State value to set for "philips-air.0.control.timerHours" has to be type "number" but received type "string" 2023-12-30 20:26:05.656 - info: philips-air.0 (911) State value to set for "philips-air.0.status.timerMinutes" has to be type "number" but received type "string" 2023-12-30 20:26:05.681 - info: philips-air.0 (911) State value to set for "philips-air.0.filter.preFilterCleanInHours" has to be type "number" but received type "string" 2023-12-30 20:26:05.744 - info: philips-air.0 (911) State value to set for "philips-air.0.filter.hepaFilterReplaceInHours" has to be type "number" but received type "string" 2023-12-30 20:26:05.752 - info: philips-air.0 (911) State value to set for "philips-air.0.filter.activeCarbonFilterReplaceInHours" has to be type "number" but received type "string" 2023-12-30 20:26:19.613 - error: govee.0 (19110) AxiosError: Request failed with status code 429 -
da mir von allen Seitern gesagt wird das mein System veraltet ist,
richtig ... aber du kannst auch gerne bei Threaderstellung mehr Input geben ,
denn nicht jeder verfolgt deine Threads bzw. ist auch dort enthaltenhttps://forum.iobroker.net/topic/71348/zigbee-stick-spinnt-gelöst
Operating System: Raspbian GNU/Linux 10 (buster) Model : Raspberry Pi 4 Model B Rev 1.4kann ich im Notfall einfach die Karte wieder zurücktauschen,
ja geht
@meister-mopper sagte in IoBroker neu aufbauen:
@gluecksmann sagte in IoBroker neu aufbauen:
... mehr nicht...
Mit wie wenig Informationen löst man Probleme?
Version des Raspi, Arbeitsspeicher, was lief bisher, iobroker-Version, wieviel Adapter, SD-Karte oder SSD, wo soll es hingehen?
So wie ich die Ausgangsfrage verstanden habe, sind die von Dir geforderten Informationen nicht notwendig.
Weil:
Ohne SD-Karte ist der Raspi "doof" und kann gar nichts. Er macht mit bzw. nach dem booten nur das, was ihm über die SD-Karte "befohlen" wird.Um die Frage von @gluecksmann zu beantworten: ja.
Du kannst beliebig viele SD-Karten vorbereiten und diese nach einander verwenden. Nach dem herunterfahren des Raspi und entfernen der SD-Karte ist der Raspi wieder "doof" und kann weder booten noch irgendetwas tun.Heißt: Nur über die verwendete SD-Karte teilst Du dem Raspi mit, was auf ihm passiert.
Heißt: Nach entfernen der SD-Karte bleiben auf dem Raspi keinerlei Informationen zurück.
Heißt: Du fängst mit jeder SD-Karte neu und von vorn an, egal, was Du machst.Ich hoffe, das war das, was Du wissen wolltest...
Nur mal am Rande ...
das sehe ich bei jeder Ausgabe von dir ... ist das gewollt das dein Log damit zugemüllt wird , wenn nicht stelle bei der Adapter Instanz philips-air die Logstufe auf Warn oder Error . -
Hallo, Ihr habt meine Frage richtig verstanden... Karte wechseln...neu versuchen...
Zu dem philips air... der ist aktuell aus... sollte ich die Instanz einfach mal pausieren...
DAnke für eure Infos...nun kann ich "spielen"
Du kannst doch die Instanz an lassen .
Nur meine Frage war ... ist es Absicht das du alles sehen willst was der Adapter philips-air macht , deshalb mein Vorschlag@glasfaser sagte in IoBroker neu aufbauen:
, wenn nicht stelle bei der Adapter Instanz philips-air die Logstufe auf Warn oder Error .Das reicht dann ...
Nö, eigendlich nicht... Kann man scheinbar umstellen...
@gluecksmann Ich würde eine neue SD-Karte hernehmen und das aktuelle Raspian ohne Desktop raufspielen. Mit backitup ein Backup vom ioBroker auf einen USB-Stick oder ein Netzlaufwerk sichern. Auf die neue SD-Karte ioBroker installieren. Falls du VIS verwendest dieses installieren und dann das Backup wiederherstellen. Fertig.
Und wenn es nicht so klappt wie du dir das wünscht, einfach die alte Karte wieder in den Raspi und alles ist wie es bis jetzt war.
@dr-bakterius sagte in IoBroker neu aufbauen *gelöst*:
Unter backitup kann man das Backup herunterladen und auf der neuen Installation wieder hochladen. Da ist weder USB Stick oder NAS nötig.
Mit VIS 1.5.4 ist der Fehler behoben das man VIS zuerst installieren muss bei der Neuinstallation. Selber getestet und funktioniert.
@shadowhunter23 Danke für die Hinweise. Da ich meine Backups auf einem Netzlaufwerk speichere, war mir das nicht bekannt. Und VIS einmalig zu installieren macht nicht viel Mühe. Aber gut, dass man nicht mehr daran denken muss.
wie oft gab ich schon den Hinweis mit dem "Vis bug" hier im Forum und trotzdem, als ich kürzlich 3mal ne Testinstallation auf nem anderen Rechner installierte, hab ichs selbst jedesmal vergessen, vis vor dem backup zu installieren
@crunchip jetzt nicht mehr!
mit vis 1.5.4 hat das endlich ein Ende
Deswegen ist die Version auch ziemlich schnell ins stable "geprügelt worden" -
@homoran hab ich schon mitbekommen, zu dem Zeitpunkt gabs die allerdings noch nicht
@homoran sagte in IoBroker neu aufbauen *gelöst*:
dein Wort in Gottes Ohren
Bevor ich gleich am Start was falsch mache... Ich finde ein angeblich veraltetes IOS Image, und eine 2er Beta. Welche nehmen? Hat jemand eine schöne ANleitung? Finde den Link nicht mher..hatte mir schon mal jemand gepostet...
wie zu erwarten war bei mir... klappt nicht...als ich gestartet habe das System auf die SD Karte zu spielen, hat er mit den Schribrechten gemeckert, um dann trotzdem den Prozess zu starten... Hat es auch laut Abschlußmeldung erfolgreich gemacht... aber wenn ich die Karte in den Raspberry stecke, komme ich per Putty nicht drauf.... die IP Adresse sollte ja die gleiche sein, habe ich in Router so eingestellt.. Passwort und Username ist nicht gespeichert, also müsste ich ja mit den vorherigen Putty Einstellunge draufkommen...
@gluecksmann sagte in IoBroker neu aufbauen *gelöst*:
klappt nicht.
heisst genau was??
...keine Logausgaben, ein und Ausgaben in der Konsole......
exakter Wortlaut?
ohne Meldung??
aber der Schlüssel hat sich geändert.
auch dort nachgesehen und verifiziert?
klappt nicht...
Ist keine verwertbare Beschreibung. So kann ich dir nur sagen:
Bei mir klappt's. -
klicke ich drauf, habe ich voher eine Abfrage nach Benutzernamen und PAsswort bekommen,,,
Jetzt kommt das....
Jetzt kommt das....
wie hast du installiert?
SSH ist wohl nicht aktiviert.
