Admin Interface nicht mehr erreichbar
@thomas-braun Host System ist Windows 10.
@hilei bitte komplett mit Eingabe und allen Ausgaben als Text in code-tags
sorry ich steig grad aus was ich machen soll
@crunchip sagte in Admin Interface nicht mehr erreichbar:
Ist doch wurscht. Die VM beherbergt doch offensichtlich was Linuxisches.
@thomas-braun said in Admin Interface nicht mehr erreichbar:
iob diag
homematic@linuxserver:/opt/iobroker$ iob diag No command 'iob' found, did you mean: Command 'iok' from package 'iok' (universe) Command 'irb' from package 'ruby' (main) Command 'iog' from package 'iog' (universe) Command 'bob' from package 'python-sponge' (universe) iob: command not found homematic@linuxserver:/opt/iobroker$
iobroker stop iobroker fix iobroker start
Last login: Sun Dec 31 14:16:18 2023 homematic@linuxserver:~$ iobroker stop iobroker controller daemon is not running homematic@linuxserver:~$ iobroker fix iobroker fix Execute the installation fixer script, this updates your ioBroker installation Options: --help Show help [boolean] homematic@linuxserver:~$ iobroker start Starting iobroker controller daemon... iobroker controller daemon started. PID: 9299 homematic@linuxserver:~$ iobroker diag iobroker [command] Commands: iobroker setup Setup ioBroker iobroker start [all|<adapter>.<instance>] Starts the js-controller or a specified adapter instance iobroker stop [<adapter>.<instance>] stops the js-controller or a specified adapter instance iobroker restart [<adapter>.<instance>] Restarts js-controller or a specified adapter instance [aliases: r] iobroker debug <adapter>[.<instance>] Starts a Node.js debugging session for the adapter instance iobroker info Shows the host info iobroker logs [<adapter>] Monitor log iobroker add <adapter> [desiredNumber] Add instance of adapter [aliases: a] iobroker install <adapter> Installs a specified adapter [aliases: i] iobroker rebuild [<module>] Rebuild all native modules or path iobroker url <url> [<name>] Install adapter from specified url, e.g. GitHub iobroker del <adapter> Remove adapter and all instances from this host [aliases: delete] iobroker del <adapter>.<instance> Remove adapter instance [aliases: delete] iobroker update [<repositoryUrl>] Update repository and list adapters iobroker upgrade Upgrade management iobroker upload [all|<adapter>] Upload management [aliases: u] iobroker object Object management [aliases: o] iobroker state State management [aliases: s] iobroker message <adapter>[.instance] <command> [<message>] Send message to adapter instance/s iobroker list <type> [<filter>] List all entries, like objects iobroker chmod <mode> <file> Change file rights iobroker chown <user> <group> <file> Change file ownership iobroker touch <file> Touch file iobroker rm <file> Remove file iobroker file File management iobroker user User commands iobroker group group management iobroker host <hostname> Set host to given hostname iobroker set <adapter>.<instance> Change settings of adapter config iobroker license <license.file or license.text> Update license by given file iobroker cert Certificate management iobroker clean <yes> Clears all objects and states iobroker backup Create backup iobroker restore <backup name or path> Restore a specified backup iobroker validate <backup name or path> Validate a specified backup iobroker status [all|<adapter>.<instance>] Status of ioBroker or adapter instance [aliases: isrun] iobroker repo [<name>] Show repo information iobroker uuid Show uuid of the installation [aliases: id] iobroker unsetup Reset license, installation secret and language iobroker fix Execute the installation fixer script, this updates your ioBroker installation iobroker multihost Multihost management iobroker compact compact group management iobroker plugin Plugin management iobroker version [<adapter>] Show version of js-controller or specified adapter [aliases: v] Options: --help Show help [boolean] homematic@linuxserver:~$
Was ist das für ein komisches System da bei dir?
rennt schon eine weile ohne dass ich mich viel darum gekümmert habe - never change a running system
jetzt rennt scheinbar nimmer
@hilei sagte in Admin Interface nicht mehr erreichbar:
Das ist eigentlich das Zeichen mich dann auch nicht mehr weiter um dein System zu kümmern. Wenn du es schon selber nicht tust, warum sollten sich andere um den versumpften Krampf scheren?
@thomas-braun sagte in Admin Interface nicht mehr erreichbar:
habe ioBroker in einer VM mit VMWareplayer laufen. Habe den VMWareplayer gestern von Version 15 auf Version 17 upgegraded. Host System ist Windows 10.
kommt vom nävva tatschen.
danke für deine hilfe aber kein grund so zu reagieren. hat bis dato super funktioniert und wenn ich updates für irgendwas gebraucht habe, habe das auch gemacht. aber ich habe einfach nicht die zeit mich laufend mit diesen dingen zu beschäftigen und updates zu machen wenns nicht unbedingt nötig ist die dann vielleicht zu problemen führen können und ich wieder stunden damit verbringe das wieder hinzubekommen - wäre nicht das erste mal.
und ausser runterfahren vmwareplayer update habe ich nichts gemacht - da rechne ich nicht unbedingt damit dass nacher zwar der iobroker noch rennt aber nicht mehr aufs admin interface komme.
ich werde das backup dass ich vor der umstellung gemacht habe einfach auf einem anderen windows pc mit vmwareplayer 15 nochmal probieren...
curl -sLf -o diag.sh https://iobroker.net/diag.sh && bash diag.sh
homematic@linuxserver:~$ curl -sLf -o diag.sh https://iobroker.net/diag.sh && bash diag.sh homematic@linuxserver:~$ curl -sLf -o diag.sh https://iobroker.net/diag.sh && bash diag.sh homematic@linuxserver:~$
Dann mach es halt neu.
Und halt das Zeuch auf einem aktuellen Stand.
'Never tatsch irgendwas' ist ganz schlecht. Die Entwicklung geht dafür zu schnell weiter. -
@hilei
was ich komisch finde ist dass er die MeldungERR_CONNECTION_REFUSED
bringt. sprich erreichbar dürfte sie ja sein? vielleicht irgendein windows security setting. na mal schauen...
ohne admin kann ich ja nicht mal ein backup ziehen und einspielen oder? -
In einem gesunden System über die Kommandozeile.
danke vorerst - dass muss jetzt mal auf nächstes Jahr warten
bildschirmzeit für heute ausgeschöpft laut chefin und kindern
werde berichten...
