    4. Raspbian light Stretch für Raspberry Pi 2/3 All-In-One mit piVCCU
      christianbl88 last edited by
      Das Ergebniss:
      pi@raspberrypi:~ $ uname -a
      Linux raspberrypi 4.9.59+ #1047 Sun Oct 29 11:47:10 GMT 2017 armv6l GNU/Linux
      pi@raspberrypi:~ $ ls -la /lib/modules/
      total 16
      drwxr-xr-x  4 root root 4096 Nov  1 15:39 .
      drwxr-xr-x 16 root root 4096 Nov  1 16:15 ..
      drwxr-xr-x  3 root root 4096 Nov  1 15:39 4.9.59+
      drwxr-xr-x  3 root root 4096 Nov 30 19:04 4.9.59-v7+
      pi@raspberrypi:~ $ ls -la /lib/modules/*/kernel/drivers/pivccu/*
      -rw-r--r-- 1 root root 10732 Nov 19 12:53 /lib/modules/4.9.59-v7+/kernel/drivers/pivccu/dw_apb_raw_uart.ko
      -rw-r--r-- 1 root root 16680 Nov 19 12:53 /lib/modules/4.9.59-v7+/kernel/drivers/pivccu/eq3_char_loop.ko
      -rw-r--r-- 1 root root 17796 Nov 19 12:53 /lib/modules/4.9.59-v7+/kernel/drivers/pivccu/generic_raw_uart.ko
      -rw-r--r-- 1 root root  9912 Nov 19 12:53 /lib/modules/4.9.59-v7+/kernel/drivers/pivccu/pl011_raw_uart.ko
      -rw-r--r-- 1 root root  5332 Nov 19 12:53 /lib/modules/4.9.59-v7+/kernel/drivers/pivccu/plat_eq3ccu2.ko
      pi@raspberrypi:~ $ lsmod
      Module                  Size  Used by
      iptable_filter          2220  0
      bridge                112535  0
      stp                     2218  1 bridge
      llc                     5790  2 bridge,stp
      fuse                   94600  3
      snd_bcm2835            23131  0
      snd_pcm                97825  1 snd_bcm2835
      snd_timer              22706  1 snd_pcm
      snd                    68784  3 snd_timer,snd_bcm2835,snd_pcm
      bcm2835_gpiomem         3791  0
      uio_pdrv_genirq         3718  0
      uio                    10166  1 uio_pdrv_genirq
      fixed                   3029  0
      ip_tables              12512  1 iptable_filter
      x_tables               20921  2 ip_tables,iptable_filter
      ipv6                  384613  13 bridge
      pi@raspberrypi:~ $ ls -la /boot/overlays/pivccu*
      -rwxr-xr-x 1 root root 296 Nov 30 19:04 /boot/overlays/pivccu-bcm2835.dtbo
      pi@raspberrypi:~ $ cat /proc/device-tree/compatible
      brcm,bcm2835pi@raspberrypi:~ $ ls -la /proc/device-tree/soc/serial*/compatible
      -r--r--r-- 1 root root 13 Nov 30 21:28 /proc/device-tree/soc/serial@7e201000/compatible
      -r--r--r-- 1 root root 22 Nov 30 21:28 /proc/device-tree/soc/serial@7e215040/compatible
      pi@raspberrypi:~ $ cat /proc/device-tree/soc/serial*/compatible
      pivccu,pl011brcm,bcm2835-aux-uartpi@raspberrypi:~ $
        deimos last edited by
        @Homoran:
        @Homoran:
        Danke, dann sehe ich da heute abend mal nach. `
        Ergebnis 1 ( /etc/apt/sources.list)
        deb http://mirrordirector.raspbian.org/raspbian/ stretch main contrib non-free $
        # Uncomment line below then 'apt-get update' to enable 'apt-get source'
        #deb-src http://archive.raspbian.org/raspbian/ stretch main contrib non-free rpi
        deb http://alexreinert.github.io/piVCCU stable main
        deb http://alexreinert.github.io/piVCCU testing main
        Ergebnis 1 ( Ergebnis 1 ( /etc/apt/sources.list.d/pivccu.list)
        =leer
        muss ich dann wohl nochmal mit deinem Image neu machen :shock: `
        Die drei Einträge in der sources.list sind nicht gut, aber das produziert erstmal nur Warnungen und man kann sich nicht sicher sein, ob jetzt testing oder stable verwendet wird.
        Das die zweite Datei nicht exisitiert ist nicht schlimm. Es muss ein Eintrag entweder in der ersten oder in der zweiten sein. In meinem Image habe ich das immer in der zweiten eigenen, aber das muss nicht zwingend so sein. In meiner ersten Anleitung war es auch noch direkt in der sources.list.
        Viele Grüße
        Alex
          ok, das sieht erstmal gut aus. Dann jetzt bitte mal
          sudo modprobe pl011_raw_uart
          sudo lsmod
          sudo dmesg | grep uart
          sudo pivccu-info
            pi@raspberrypi:~ $ sudo modprobe pl011_raw_uart
            modprobe: FATAL: Module pl011_raw_uart not found in directory /lib/modules/4.9.59+
            pi@raspberrypi:~ $ sudo lsmod
            Module                  Size  Used by
            bridge                112535  0
            stp                     2218  1 bridge
            fuse                   94600  3
            snd_bcm2835            23131  0
            fixed                   3029  0
            pi@raspberrypi:~ $ sudo dmesg | grep uart
            pi@raspberrypi:~ $ sudo pivccu-info
            piVCCU version: 2.29.23-16
            Kernel modules: Not available
            Raw UART dev:   Not available
            Board serial:   Unknown
            State:          STOPPED
              Ok, ich habe einen neuen Verdacht. Machst du bitte mal ein Detail-Foto von deinem Pi?
                Foto pi~~![](</s><URL url=)<link_text text="https://uploads.tapatalk-cdn.com/201711 ... 530fb9.jpg">https://uploads.tapatalk-cdn.com/20171130/bb328ae59fa6dd90d33b8c277c530fb9.jpg</link_text>" />
                Gesendet von meinem ONEPLUS A3003 mit Tapatalk~~
                  Verdacht bestätigt: Das ist kein Pi 2 B.
                    Huch… Wie was... [emoji28]
                      Den Bilder nach dürfte es ein Pi 1 B sein. Der wird von piVCCU nicht unterstützt. (macht auch wenig Sinn, der hat kaum CPU Power und je nach Produktionsdatum nur 256MB RAM).
                        @christianbl88:
                        Gesendet von meinem ONEPLUS A3003 mit Tapatalk ` Vielen Dank für die Hilfestellung.. tut mir leid das mit das nicht selbst bewusst geworden ist… War der vollen überzeugen daß das einer ist..
                        6361
