      TT-Tom @ticaki last edited by TT-Tom
      @ticaki
      ich habe ein Blockly mal erstellt und Trigger auf ACTUAL mit einem Selektor.
       <variables>
         <variable id="`3q~tn|]r(LvC{19,zEY">Status_offeneFenster</variable>
         <variable id="1#Xk,SKr8Zq2_0q?X|J9">offeneFenster</variable>
         <variable id="9/yJg%I-v6N#IQN8st6m">i</variable>
       </variables>
       <block type="on_ext" id="U::/4wmI3}Z@$SKGvvg=" x="88" y="63">
         <value name="OID0">
           <shadow type="field_oid" id="7Ap7C6jIj.Mb{_iqs{{c">
           <block type="selector" id="96E5N_xE!C=N626d0a_!">
             <field name="TEXT">alias.0.Fenster.*.ACTUAL</field>
           <block type="variables_set" id="o,82sN(nBal}d`S@FhlR">
             <field name="VAR" id="`3q~tn|]r(LvC{19,zEY">Status_offeneFenster</field>
               <block type="logic_boolean" id="];3BCyF%j]5d6+iW7SW4">
               <block type="variables_set" id="^tJ|0)6.8hOKTt~3bSY9">
                 <field name="VAR" id="1#Xk,SKr8Zq2_0q?X|J9">offeneFenster</field>
                   <block type="math_number" id=")NrEP9EVPkpU]lvaOIow">
                     <field name="NUM">0</field>
                   <block type="controls_forEach" id="zvEO{_Dt/YKLr5SA*4qm">
                     <field name="VAR" id="9/yJg%I-v6N#IQN8st6m">i</field>
                     <value name="LIST">
                       <block type="selector" id="`nXP$958BtmgM?C9iXJ,">
                     <statement name="DO">
                       <block type="controls_if" id="|Tcfi[X*+Z+I^XU`W}c!">
                           <block type="get_value_var" id="B+{iQL0J8Uf/auyLg4;o">
                             <value name="OID">
                               <shadow type="text" id="nv_xNDwj^vZd(VS@iL;U">
                                 <field name="TEXT">i</field>
                               <block type="variables_get" id="-R.oMz[v.gJ{a/*nGZsC">
                           <block type="math_change" id="%GBC0#O-FVUS`64Eg8Li">
                             <value name="DELTA">
                               <shadow type="math_number" id="O`wb$_E?4FjD*66Z.#Gz">
                                 <field name="NUM">1</field>
                               <block type="math_number" id="Z0%Qp}aXwh|l3tUTm:KU">
                               <block type="variables_set" id="-%h(cYD!_^|7$j1?7-a;">
                                   <block type="logic_boolean" id="JyKdvLU=OeWD@`O7AQVi">
                       <block type="update" id="VyzVl0%MBx@R,H+HEEGI">
                         <field name="OID">0_userdata.0.NSPanel.Allgemein.Fenster.Anzahl_offene</field>
                           <block type="convert_tostring" id="p[AN%(l=kC~8Cq!%kyQy">
                               <block type="variables_get" id="d`73i^f,-$v2QCbRQy$g">
                           <block type="update" id="v2F]Z/TZY!PunG*kfkwO">
                             <field name="OID">0_userdata.0.NSPanel.Allgemein.Fenster.Status_offene</field>
                               <block type="variables_get" id=",$^vy#7#dLe!?DtT8N|U">
                               <block type="debug" id="M({M!_ScK2[_^j=8BB,k">
                                 <value name="TEXT">
                                   <shadow type="text" id="mzN-~@]E)uw@:W_};^IK">
                                   <block type="text_join" id="fj*OT/+j;9m96a+a?y|Z">
                                     <value name="ADD0">
                                       <block type="variables_get" id="])A_QS+y+K{m/p[dOVM$">
                                     <value name="ADD1">
                                       <block type="text" id="XEdD(OQYXlXrVeP1Bw|k">
                                         <field name="TEXT"> Fenster offen </field>
                                     <value name="ADD2">
                                       <block type="on_source" id="]/!CU#MQ~Ci#!Y]o1~BA" disabled="true">
                                         <field name="ATTR">id</field>
      die Ordnerstruktur sieht bei mir so aus
        ticaki @TT-Tom last edited by ticaki
        @tt-tom
        Das Skript sucht per Selektor die Fenster und baut dann das hier, incl Stockwerk und Räumen.
        Die nimmt es aus der enum id für den raum "enum.rooms.Haus.second_floor" ist das Stockwerk. "enum.rooms.Haus.second_floor.Bad" ist der Raum.
        Den Namen nimmt es auf adapter.0.diesemDatenpunkt. Den Sensoren müssen Räumen und Funktionen zugewiesen sein:Bildschirmfoto 2023-12-30 um 18.24.32.png
          @ticaki
          für die User ist es immer gut, wenn das Script alle Arbeit abnimmt und die Config sich in Grenzen hält. Persönlich bin ich eher der Bastler und teste hier intensiv. Schön das du unsere Crew hier so gut unterstützt. Danke nochmal.
          Armilar 1 Reply Last reply Reply Quote 1
          • Armilar
            Armilar Most Active Forum Testing @TT-Tom last edited by
            Update - v4.3.3.28
            • Durch Änderung des Payload, sollte das Problem mit zu langen Alias Verzeichnissen und daraus resultierenden langen Zeichenketten behoben sein. Es ist trotzdem sinnvoll die Verzeichnisse kurz zuhalten, statt Erdgeschoss -> EG oder Schlafzimmer -> SZ nutzen.
            • Fix: Die Icons des Fenster-Alias sind von der Logik gedreht
            • Es wird beim Port-Check berücksichtigt, wenn ein MQTT-Client installiert ist
            • Fix: Der Fallback, wenn ein Name nicht im Alias vorhanden ist, wurde erweitert
            Wie kann ich das Update durchführen?
            Wenn aktuelle Version ab v4.3.3.10, dann unteren Teil des NSPanelTs.ts ab:
            // ________________ DE: Ab hier keine Konfiguration mehr _______________
            austauschen
            https://github.com/joBr99/nspanel-lovelace-ui/blob/main/ioBroker/NsPanelTs.ts
            Wenn aktuelle Version bis v4.3.3.9, dann Updateaneitung befolgen:
            https://github.com/joBr99/nspanel-lovelace-ui/wiki/NSPanel-Starthilfe-FAQ#hilfe-bei-update--upgrade
            🎆 🍾 Wir wünschen euch allen einen guten Rutsch ins neue Jahr 2024 🍾 🎆
            VG
            @Armilar, @TT-Tom & @Kuckuckmann 😊
            D 1 Reply Last reply Reply Quote 4
            • O
              OlliGut last edited by OlliGut
              ich würde gerne meine Bose Soundtouch mit dem NSPanel steuern. Ich habe auf dem IOBroker den Soundtouch Adapter installiert und eine Instanz angelegt. Da es die vorkonfigurierten MediaCards nur für Sonos, Alexa etc gibt. wollte ich einfach eine Standard-MediaCard nutzen.
              let Bose = <PageMedia>
                  "type": "cardMedia",
                  "heading": "Bose",
                  "useColor": true,
                  "items": [<PageItem>{
                              id: AliasPath + 'Media.Bose',
                              adapterPlayerInstance: "bosesoundtouch.0.",
                              mediaDevice: "192.168.178.32",
                              speakerList: ["Wohnzimmer"],
                              colorMediaIcon: colorSpotify,
                              colorMediaArtist: Yellow,
                              colorMediaTitle: Yellow,
                              autoCreateALias : true
              Aber schon ein erster Versuch schlägt fehl: "Cannot read properties of undefined (reading 'id')"
              Was eigentlich logisch ist, weil es den Pfad unter Alias auch nicht gibt; allerdings wird er auch nicht angelegt, obwohl ich das Autoanlegen aktiviert habe.
              Hat vielleicht jemand so einen Adapter bereits gebaut und könnte mir etwas helfen, oder wie sollte ich vorgehen, wenn ich das selber machen müsste?
              Für einen Tipp bedanke ich mich im Voraus und wünsche allen schonmal einen guten Rutsch.
              Gruß Olli
                DerT Forum Testing @Armilar last edited by
                Hallo Zusammen,
                ich hab das ganze mal Testweise bei mir aufgebaut und eine Frage zu den Hardware Buttons.
                Irgendwie steig ich beim Beispiel nicht ganz durch..
                //-------EN: Start Settings for Hardware Button, if used in software (Rule2) --------------------------------------
                    // DE: Konfiguration des linken Schalters des NSPanels
                    // EN: Configuration of the left switch of the NSPanel
                    button1: {
                        // DE: Mögliche Werte wenn Rule2 definiert: 'page', 'toggle', 'set' - Wenn nicht definiert --> mode: null
                        // EN: Possible values if Rule2 defined: 'page', 'toggle', 'set' - If not defined --> mode: null
                        mode: 'page',
                        // DE: Zielpage - Verwendet wenn mode = page
                        // EN: Target page - Used if mode = page
                        page: null,
                        // DE: Zielentity - Verwendet wenn mode = set oder toggle
                        // EN: Target entity - Used if mode = set or toggle
                        entity: null,
                        // DE: Zielwert - Verwendet wenn mode = set
                        // EN: Target value - Used if mode = set
                        setValue: null
                    // DE: Konfiguration des rechten Schalters des NSPanels
                    // EN: Configuration of the right switch of the NSPanel
                    button2: {
                        mode: null,
                        page: null,
                        entity: null,
                        setValue: null
                //--------- DE: Ende - Einstellungen für Hardware Button, wenn Sie softwareseitig genutzt werden (Rule2) -------------
                Gibt es dazu noch irgendwo was im Wiki das ich nicht gefunden habe? Die Regel habe ich eingestellt.
                Konkret habe ich zwei Szenarien die ich gerne mal testen würde.
                1. Mit den Buttons durch die Menüs navigieren
                2. Temperatur an einem Thermostat reduzieren bzw. erhöhen.
                  TT-Tom @DerT last edited by TT-Tom
                  @dert sagte in SONOFF NSPanel mit Lovelace UI:
                  du kannst mit der Rule1 den Tasten ein Befehl zuweisen. Zum Beispiel Home, das hat die selbe Funktion, wenn im Display auf das Haus drückst.
                  Siehe Beispiel im Wiki.
                  Du kannst nur auf einen festen Wert setzen.
                      button1: {
                          mode: 'set',
                          page: null,
                          entity: 'alias.0.NSPanel.Thermostat.SET',
                          setValue: 25
                  Kannst aber auch gerne ein Issues aufmachen. Thema: Button1 mode: Set -> setValue up/down. Dann schauen wir uns das im neuen Jahr mal an.
                  Schönen Rutsch in neue Jahr
                  • Armilar
                    Armilar Most Active Forum Testing @TT-Tom last edited by Armilar
                    @DerT
                    Kann auch ein true liefern (links down/rechts up)... ist bloß eine Frage, wie man den Wert später auswertet...
                    Selbst wenn der Wert nur 1 wäre, könnte ein Blockly den Setpoint-Datenpunkt inkrementieren oder dekrementieren.
                    Das Navigationsbeispiel ist hier:
                    https://github.com/joBr99/nspanel-lovelace-ui/wiki/ioBroker-Navigation#navigation-mit-den-hardware-buttons
                    bzw.:
                    https://github.com/joBr99/nspanel-lovelace-ui/wiki/ioBroker---FAQ-&-Anleitungen#13d-mit-den-hardwarebuttons-vor-und-zurück-navigieren
                    Ich bin dann mal feiern 😉
                    • jayjojayson
                      jayjojayson last edited by
                      Hallo, erstmal ein gesundes und glückliches neues Jahr für alle.
                      Ich nutze das neue Script nun auch schon ein bisschen und funktioniert auch alles soweit super, aber ich bekomme einen Fehler einfach nicht weg und weiß nicht woran das liegen kann. Hat einer von euch vielleicht eine Idee?
                      	javascript.0 (5055) script.js.NSPanels.Panel2: error at function HandleScreensaverUpdate: parseFormat is not a function
                      Eigentlich habe ich nichts geändert, bis auf den ScreensaverEntity 4, hier will ich meinen aktuellen Solarertrag anzeigen.
                      Etwas weiter unten in den Einstellungen kann man die beiden virtuellen button im Screen konfigurieren
                      mrIcon1ScreensaverEntity und mrIcon2ScreensaverEntity. Wenn ich dort Datenpunkte hinterlege, zeigt er mir auch gleich Fehler an. Muss man irgendwo Relay.1 und Relay.2 extra setzen?
                      //---- Anfang     Screensaver Einstellungen / Screensaver settings ---------------------
                          leftScreensaverEntity:
                                   // Examples for Advanced-Screensaver: https://github.com/joBr99/nspanel-lovelace-ui/wiki/ioBroker-Config-Screensaver#entity-status-icons-ab-v400
                          bottomScreensaverEntity :
                                  // bottomScreensaverEntity 1
                                      ScreensaverEntity: 'accuweather.0.Daily.Day1.Sunrise',
                                      ScreensaverEntityFactor: 1,
                                      ScreensaverEntityDecimalPlaces: 0,
                                      ScreensaverEntityDateFormat: { hour: '2-digit', minute: '2-digit' }, // Description at Wiki-Pages
                                      ScreensaverEntityIconOn: 'weather-sunset-up',
                                      ScreensaverEntityIconOff: null,
                                      ScreensaverEntityText: 'Sonne',
                                      ScreensaverEntityUnitText: '%',
                                      ScreensaverEntityIconColor: MSYellow //{'val_min': 0, 'val_max': 100}
                                  // bottomScreensaverEntity 2
                                      ScreensaverEntity: 'accuweather.0.Current.WindSpeed',
                                      ScreensaverEntityFactor: (1000/3600),
                                      ScreensaverEntityDecimalPlaces: 1,
                                      ScreensaverEntityIconOn: 'weather-windy',
                                      ScreensaverEntityText: "Wind",
                                      ScreensaverEntityUnitText: 'm/s',
                                      ScreensaverEntityIconColor: { 'val_min': 0, 'val_max': 120 }
                                  // bottomScreensaverEntity 3
                                      ScreensaverEntity: 'accuweather.0.Current.WindGust',
                                      ScreensaverEntityIconOn: 'weather-tornado',
                                      ScreensaverEntityText: 'Böen',
                                  // bottomScreensaverEntity 4
                                      ScreensaverEntity: 'growatt.0.782463.devices.ACJ0B1802L.deviceData.eToday',
                                      ScreensaverEntityIconOn: 'solar-power',
                                      ScreensaverEntityText: 'Strom',
                                      ScreensaverEntityUnitText: 'kWh',
                                      ScreensaverEntityIconColor: White
                                  // bottomScreensaverEntity 5 (for Alternative and Advanced Screensaver)
                                      ScreensaverEntity: 'accuweather.0.Current.RelativeHumidity',
                                      ScreensaverEntityIconOn: 'water-percent',
                                      ScreensaverEntityText: 'Feuchte',
                                      ScreensaverEntityIconColor: {'val_min': 0, 'val_max': 100, 'val_best': 65}
                                  // bottomScreensaverEntity 6 (for Advanced Screensaver)
                                   ScreensaverEntity: NSPanel_Path + 'Relay.1',
                                   ScreensaverEntityIconOn: 'coach-lamp-variant',
                                   ScreensaverEntityText: 'Street',
                                   ScreensaverEntityOnColor: Yellow,
                                   ScreensaverEntityOffColor: White,
                                   ScreensaverEntityOnText: 'Is ON',
                                   ScreensaverEntityOffText: 'Not ON'
                          indicatorScreensaverEntity:
                              // Status Icon
                          mrIcon1ScreensaverEntity:
                                  ScreensaverEntityIconOn: 'lightbulb',
                                  ScreensaverEntityValue: null,
                                  ScreensaverEntityValueDecimalPlace : 0,
                                  ScreensaverEntityValueUnit: null,
                                  ScreensaverEntityOnColor: On,
                                  ScreensaverEntityOffColor: HMIOff
                          mrIcon2ScreensaverEntity:
                                  ScreensaverEntity: NSPanel_Path + 'Relay.2',
                      // ------ Ende der Screensaver Einstellungen --------------------
                        TT-Tom @jayjojayson last edited by TT-Tom
                        @jayjojayson
                        Ein gesundes neues Jahr.
                        Das sieht danach aus, das da in der JavaScript Instanz das npm Modul fehlt. Vergleich bitte mal mit der Anweisung im Wiki.
                        • jayjojayson
                          @tt-tom Ich habe jetzt noch /opt/iobroker/SkripteJS nachgetragen. Die restlichen Punkte waren schon gesetzt.
                          Jetzt bekomme ich noch viel mehr Fehler angezeigt und der Screensaver wird gar nicht mehr angezeigt. Die erstellten Seiten aber schon.
                          Thomas Braun T 2 Replies Last reply Reply Quote 0
                            Thomas Braun Most Active @jayjojayson last edited by
                            @jayjojayson Spiegel würde ich immer nach /home/iobroker/skripte oder sowas. Jedenfalls nicht in /opt/
                            jayjojayson 1 Reply Last reply Reply Quote 0
                            • jayjojayson
                              jayjojayson @Thomas Braun last edited by
                              @thomas-braun sagte in SONOFF NSPanel mit Lovelace UI:
                              Muss man denn überhaupt spiegeln?
                                @jayjojayson
                                Nein.
                                  ticaki last edited by ticaki
                                  Zu fehlenden NPM-modulen mir hat er auch vorgestern dayjs angemeckert - nach 1 Stunde vergeblichen Fehler beheben, hab ich den Rechner neu gestartet und tadaging wieder.
                                  @Kuckuckmann
                                  Das oben genannte Skript - da drücke ich noch noch vor der Readme und den ganze Konfigurationschecks 😄
                                  Aber das hier ist einfacher:
                                  Mein NSPanel werden wenn ich fertig bin, alle durch BWM aktiviert, daher möchte ich eine Möglichkeit mir wichtiges als Text anzeigen zu lassen und nicht in jedem Skript eine Logik zu haben die das ganze verwaltet.
                                  Verwaltung von Nachrichten für Nspanel Screensaver.
                                  Da schreibt man Nachrichten in die erstellten States und die Verwaltung kümmert sich darum die gegebenenfalls zu rotieren und nach einer vorgegebenen Zeit zu entfernen oder erst nach einer weiteren Nachricht.
                                  Anleitung: https://github.com/ticaki/iobroker-skript-sammlung/blob/main/ScreensaverMessage.md
                                  Skript: https://github.com/ticaki/iobroker-skript-sammlung/blob/main/ScreensaverMessage.ts
                                  @TT-Tom @Armilar
                                  Gibts einen Möglichkeit vom Nspanel über das Menü, den Screensaver zu aktivieren? Oder einen Datenpunkt in dem Datenbaum der das aktiviert?
                                  Wenn ihr mal lust habt könnte ihr da vielleicht buzzer möglich machen?
                                  https://github.com/joBr99/nspanel-lovelace-ui/blob/b1b679701ebeb785abe853fc32fac480c1df2603/docs/notifications.md#notification-on-screensaver
                                    @jayjojayson
                                    bitte trage die Module in die obere Zeile. "zusätzliche Module" Siehe die das Wiki nochmal an.
                                    jayjojayson 1 Reply Last reply Reply Quote 1
                                    • jayjojayson
                                      jayjojayson @TT-Tom last edited by jayjojayson
                                      @tt-tom oh man, manchmal kann es so einfach sein. Ich Trottel habe da so oft drauf geschaut und nicht gesehen, dass die Module in der falschen Zeile stehen. Jetzt klappt es, vielen Dank.
                                      Bekomme jetzt nur noch diese Fehler einmalig bei Start angezeigt. Der will noch das ich irgendwas update.
                                        ticaki @jayjojayson last edited by ticaki
                                        @jayjojayson
                                        Die roten Meldungen kannst du ignorieren, die Gelben hingegen nicht. 🙂
                                        • jayjojayson
                                          jayjojayson @ticaki last edited by
                                          @ticaki echt, hätte genau anders herum gedacht. Die Meldungen kommen aber auch nur bei Start des Scripts. Danach nicht mehr.
                                            @jayjojayson
                                            Alle Meldungen von npm werden als Fehler dargestellt, das ist aber eine Warnung das Module die zwingend erforderlich sind nicht mehr gewartet werden.
                                            so sieht das auf der Console aus:
                                            npm WARN deprecated har-validator@5.1.5: this library is no longer supported
                                            npm WARN deprecated uuid@3.4.0: Please upgrade  to version 7 or higher.  Older versions may use Math.random() in certain circumstances, which is known to be problematic.  See https://v8.dev/blog/math-random for details.
                                            npm WARN deprecated request@2.88.2: request has been deprecated, see https://github.com/request/request/issues/3142
                                            Solange du kein request in deinen Skripten benutzt kann dir das wurscht sein 🙂
                                            em, hab aber nicht nachgesehen ob dieses Skript request benutzt. Nope benutz axios alle gut.
                                            mikeal created this issue in request/request
                                            open Request’s Past, Present and Future #3142
                                            lovelace ui nspanel sonoff
                                            271
                                            7725
                                            6655599
