    4. Diskussion zum HowTo nodejs-Installation und upgrade
      Willi-Wunder @Thomas Braun last edited by
      TOP, vielen Dank. Jetzt sollte es passen.
      ioBroker nodejs fixer 2023-10-13
      You requested to intall latest version from nodejs v18 tree.
      Your current setup is:
      /usr/bin/nodejs         v18.19.0
      /usr/bin/node           v18.19.0
      /usr/bin/npm            10.2.3
      /usr/bin/npx            10.2.3
      /usr/bin/corepack       0.22.0
      We found these nodejs versions available for installation:
      nodejs:
        Installed: 18.19.0-1nodesource1
        Candidate: 18.19.0-1nodesource1
        Version table:
           18.19.0+dfsg-6~deb12u1 500
       *** 18.19.0-1nodesource1 1001
              100 /var/lib/dpkg/status
           18.18.2-1nodesource1 1001
           18.18.1-1nodesource1 1001
           18.18.0-1nodesource1 1001
           18.17.1-1nodesource1 1001
           18.17.0-1nodesource1 1001
           18.16.1-1nodesource1 1001
           18.16.0-1nodesource1 1001
           18.15.0-1nodesource1 1001
           18.14.2-1nodesource1 1001
           18.14.1-1nodesource1 1001
           18.14.0-1nodesource1 1001
           18.13.0+dfsg1-1 500
           18.13.0-1nodesource1 1001
           18.12.0-1nodesource1 1001
           18.11.0-1nodesource1 1001
           18.10.0-1nodesource1 1001
           18.9.1-1nodesource1 1001
           18.9.0-1nodesource1 1001
           18.8.0-1nodesource1 1001
           18.7.0-1nodesource1 1001
           18.6.0-1nodesource1 1001
           18.5.0-1nodesource1 1001
           18.4.0-1nodesource1 1001
           18.3.0-1nodesource1 1001
           18.2.0-1nodesource1 1001
           18.1.0-1nodesource1 1001
           18.0.0-1nodesource1 1001
      Nothing to do - Your installation is using the correct paths.
      You are running nodejs v18.19.0. Do you want to install latest version from nodejs v.18 tree?
      Press <y> to continue or any other key to quit
      Trying to update your installation now. Please be patient.
      find: '/run/user/1000/doc': Permission denied
      find: '/run/user/1000/gvfs': Permission denied
      Waiting for ioBroker to shut down - Give me a minute...
      *** These repos are active on your system:
      Hit:2 http://deb.debian.org/debian-security bookworm-security InRelease
      Hit:3 http://archive.raspberrypi.com/debian bookworm InRelease
      Hit:5 https://apt.grafana.com stable InRelease
      Hit:6 https://repos.influxdata.com/debian stable InRelease
      Reading package lists... Done
      *** Installing ca-certificates, curl and gnupg, just in case they are missing.
      *** Creating new /etc/apt/sources.list.d/nodesource.list and pinning source
      deb [signed-by=/etc/apt/keyrings/nodesource.gpg] https://deb.nodesource.com/node_18.x nodistro main
      Package: nodejs
      Pin: origin deb.nodesource.com
      Pin-Priority: 1001
      *** These repos are active after the adjustments:
      Hit:3 https://repos.influxdata.com/debian stable InRelease
      Hit:4 http://archive.raspberrypi.com/debian bookworm InRelease
      Hit:5 http://deb.debian.org/debian bookworm-updates InRelease
      Hit:6 https://apt.grafana.com stable InRelease
      Get:7 https://deb.nodesource.com/node_18.x nodistro InRelease [12.1 kB]
      Get:8 https://deb.nodesource.com/node_18.x nodistro/main arm64 Packages [6613 B]
      Get:9 https://deb.nodesource.com/node_18.x nodistro/main armhf Packages [6656 B]
      Fetched 25.4 kB in 2s (13.0 kB/s)
      Installing the recommended nodejs version now!
      Installing the recommended nodejs version!
      We tried our best to fix your nodejs. Please run iob diag again to verify.
      *** RESTARTING ioBroker NOW! ***
       Please refresh or restart your browser in a few moments.
      Beim ausführen des Befehls kam noch am Anfang......
      pi@iobroker:~ $ iob nodejs-update 18
      /usr/bin/bash: warning: setlocale: LC_ALL: cannot change locale (de_DE)
      ioBroker node-update v2023-10-13 is starting. Please be patient!
      Hat das noch etwas zu sagen?
        Thomas Braun Most Active @Willi-Wunder last edited by
        @willi-wunder sagte in Diskussion zum HowTo nodejs-Installation und upgrade:
        Nein, ist für dich nicht wichtig.
          Dann danke für deine erneute Hilfe 👍
            JoSbg last edited by
            Hallo
            Wollt gerade das Update von v16 auf v18 machen. Leider scheitere ich schon beim ersten Schritt "Altlasten entfernen".
            sudo rm `sudo find / -name nodesource.gpg`
            Es werden da eine Menge Ordner aufgelistet, aber bei allen kommt "Permission denied"
            iobroker@CT101:~$ sudo rm `sudo find / -name nodesource.gpg`
            find: '/proc/tty/driver': Permission denied
            find: '/sys/kernel/debug': Permission denied
            find: '/sys/fs/fuse/connections/41': Permission denied
            find: '/sys/fs/fuse/connections/38': Permission denied
            iobroker läuft bei mir auf Proxmox mit Debian.
            • Glasfaser
              Glasfaser @JoSbg last edited by
              @josbg sagte in Diskussion zum HowTo nodejs-Installation und upgrade:
              Was machst du da !?
              schau ein paar .... Beiträge über deine !
              iob stop
              iob fix
              iob nodejs-update
              sudo reboot
                JoSbg @Glasfaser last edited by
                @glasfaser
                Danke hat so natürlich funktioniert.
                Manchmal sieht man den Wald vor lauter Bäumen nicht.
                  Stefan_NK last edited by
                  Hallo Zusammen,
                  ich habe einen Raspi4 für Testzwecke komplett neu aufgesetzt und den iobroker installiert.
                  curl -sLf https://iobroker.net/install.sh | bash -
                  Ich habe jetzt in der Übersicht folgende Versionen:
                  Node.js: v18.19.0
                  NPM: 9.2.0(10.2.3)
                  Wie kann ich denn die NPM-Version auf 19.x updaten? Ich habe dazu leider nichts gefunden, was mir weitergeholfen hätte.
                  LG Stefan
                    Thomas Braun Most Active @Stefan_NK last edited by Thomas Braun
                    @stefan_nk
                    npm wird gar nicht separat installiert.
                    Mach es danach:
                    https://forum.iobroker.net/topic/71478/plötzliche-probleme-durch-nodejs-dfsg-version-npm-fehlt
                    Hinterher per
                    iob nodejs-update
                    schauen ob das dann senkrecht installiert wurde.
                      Stefan_NK @Thomas Braun last edited by
                      @thomas-braun sagte in Diskussion zum HowTo nodejs-Installation und upgrade:
                      iob nodejs-update
                      Hat funktioniert. Vielen Dank Thomas
                        knatterman last edited by
                        ich habe versucht, Nodejs von 14 auf 18 upzugraden, habe gemäß der Anleitung die beiden Repos eingetragen und erhielt dann beim Update aber immer den Hinweis, dass ein Schlüssel fehlen ...
                        iobroker@iobroker:~$ sudo apt update
                        OK:1 http://deb.debian.org/debian buster InRelease
                        OK:2 http://deb.debian.org/debian buster-updates InRelease
                        OK:3 http://security.debian.org/debian-security buster/updates InRelease
                        OK:4 https://deb.nodesource.com/node_14.x buster InRelease
                        Holen:5 https://deb.nodesource.com/node_16.x nodistro InRelease [12,1 kB]
                        Holen:6 https://deb.nodesource.com/node_18.x nodistro InRelease [12,1 kB]
                        Fehl:5 https://deb.nodesource.com/node_16.x nodistro InRelease
                          Die folgenden Signaturen konnten nicht überprüft werden, weil ihr öffentlicher Schlüssel nicht verfügbar ist: NO_PUBKEY 2F59B5F99B1BE0B4
                        Fehl:6 https://deb.nodesource.com/node_18.x nodistro InRelease
                        W: GPG-Fehler: https://deb.nodesource.com/node_16.x nodistro InRelease: Die folgenden Signaturen konnten nicht überprüft werden, weil ihr öffentlicher Schlüssel nicht verfügbar ist: NO_PUBKEY 2F59B5F99B1BE0B4
                        E: Das Depot »https://deb.nodesource.com/node_16.x nodistro InRelease« ist nicht signiert.
                        N: Eine Aktualisierung von solch einem Depot kann nicht auf eine sichere Art durchgeführt werden, daher ist es standardmäßig deaktiviert.
                        N: Weitere Details zur Erzeugung von Paketdepots sowie zu deren Benutzerkonfiguration finden Sie in der Handbuchseite apt-secure(8).
                        W: GPG-Fehler: https://deb.nodesource.com/node_18.x nodistro InRelease: Die folgenden Signaturen konnten nicht überprüft werden, weil ihr öffentlicher Schlüssel nicht verfügbar ist: NO_PUBKEY 2F59B5F99B1BE0B4
                        E: Das Depot »https://deb.nodesource.com/node_18.x nodistro InRelease« ist nicht signiert.
                        Die Hinweise hier im Thread haben nicht wirklich geholfen. Habe dann auf https://den.nodesource.com einen Hinweis auf die (wohl) aktuellste Key Datei gefunden und sie wie folgt hinzugefügt.
                        iobroker@iobroker:~$ curl -fsSL https://deb.nodesource.com/gpgkey/nodesource-repo.gpg.key | sudo apt-key add -
                        Ein
                        liefert nun
                        OK:2 http://security.debian.org/debian-security buster/updates InRelease
                        OK:3 http://deb.debian.org/debian buster-updates InRelease
                        Holen:7 https://deb.nodesource.com/node_16.x nodistro/main amd64 Packages [7.462 B]
                        Holen:8 https://deb.nodesource.com/node_18.x nodistro/main amd64 Packages [6.634 B]
                        Es wurden 14,1 kB in 2 s geholt (8.844 B/s).
                        Aktualisierung für 1 Paket verfügbar. Führen Sie »apt list --upgradable« aus, um es anzuzeigen.
                        Vielleicht hilft es irgendwem irgendwann ...
                        Frank
                        • Glasfaser
                          Glasfaser last edited by Glasfaser
                          @knatterman sagte in Diskussion zum HowTo nodejs-Installation und upgrade:
                          Auch nicht !?
                          iob nodejs-update
                          Da hast du aber schon lange nichts mehr gemacht ....
                            Thomas Braun Most Active @knatterman last edited by Thomas Braun
                            Nein, es hilft nicht, denn die Schlüsselverwaltung wird nicht mehr via apt-key gemacht.
                            iob nodejs-update
                            macht das alles für dich.
                            Und den Buster musst du auch beerdigen, installier da Bookworm / Debian 12.
                              knatterman @Glasfaser last edited by
                              @glasfaser
                              Hi
                              Auch nicht !?
                              iob nodejs-update
                              nein, die Option nodejs-update wurde nicht 'erkannt' ...
                              Tja, never change a running system 😄
                              Frank
                              Thomas Braun Glasfaser Homoran 4 Replies Last reply Reply Quote 0
                                @knatterman
                                So lange nur nix changen, bis gar nix mehr geht...
                                Wer gibt eigentlich immer diesen schwachsinnigen Rat?
                                  knatterman @Thomas Braun last edited by knatterman
                                  Hast ja recht, ich denke halt nur zu selten daran, Mal wieder upzudaten.
                                  Habe gerade aber nochmal geschaut, die Option nodejs-update gibt's auf meinem System (immer) noch nicht. Muss ich hier noch was manuell tun?
                                  Frank
                                  Glasfaser 2 Replies Last reply Reply Quote 0
                                  • Glasfaser
                                    Glasfaser @knatterman last edited by
                                    Dann war dein System ... Steinalt
                                    bzw. ist es immer noch!
                                    das würde man per
                                    iob fix
                                    sich den Befehl dazu holen !
                                      Homoran Global Moderator Administrators @knatterman last edited by
                                      siehst ja was dann passiert
                                        iob stop
                                        iob fix
                                        danach ist auch nodejs-update bekannt.
                                        Aber lieber wird da ja irgendein veralteter Kram festgetackert...
                                        Näwah tschäintsch.... Ich weiß...
                                        • Glasfaser
                                          dann vermute ich auch das du noch Buster hast ...
                                            Homoran Global Moderator Administrators @Glasfaser last edited by Homoran
                                            @glasfaser sagte in Diskussion zum HowTo nodejs-Installation und upgrade:
                                            oder jessie
                                            oder gab es 2017 noch was älteres?
                                            1.4k
                                            nodejs
                                            91
                                            844
                                            228829
