    4. Sonoff Presence Sensor SNZB-06P problem
      tobrog @arteck last edited by
      @arteck Bei mir auch. Wiederholt sich alle paar Minuten:
      zigbee.0
      2024-01-03 09:50:51.375	error	Error while processing converters DEVICE_ID: '3410f4fffee99489'
      zigbee.0
      2024-01-03 09:50:51.137	info	Configuring 0x3410f4fffee99489 SNZB-06P
      zigbee.0
      2024-01-03 09:50:48.600	error	Error while processing converters DEVICE_ID: '3410f4fffee99489'
      zigbee.0
      2024-01-03 09:50:48.111	info	Configuring 0x3410f4fffee99489 SNZB-06P
      zigbee.0
      2024-01-03 09:50:45.433	error	Error while processing converters DEVICE_ID: '3410f4fffee99489'
      zigbee.0
      2024-01-03 09:50:45.113	info	Configuring 0x3410f4fffee99489 SNZB-06P
      zigbee.0
      2024-01-03 09:50:42.256	error	Error while processing converters DEVICE_ID: '3410f4fffee99489'
      zigbee.0
      2024-01-03 09:50:42.089	info	Configuring 0x3410f4fffee99489 SNZB-06P
      zigbee.0
      2024-01-03 09:50:39.235	error	Error while processing converters DEVICE_ID: '3410f4fffee99489'
      zigbee.0
      2024-01-03 09:50:39.072	info	Configuring 0x3410f4fffee99489 SNZB-06P
      zigbee.0
      2024-01-03 09:48:02.275	error	Error while processing converters DEVICE_ID: '3410f4fffee99489'
      zigbee.0
      2024-01-03 09:48:01.723	info	Configuring 0x3410f4fffee99489 SNZB-06P
      zigbee.0
      2024-01-03 09:40:31.648	error	Error while processing converters DEVICE_ID: '3410f4fffee99489'
      zigbee.0
      2024-01-03 09:40:31.377	info	Configuring 0x3410f4fffee99489 SNZB-06P
      zigbee.0
      2024-01-03 09:40:29.204	error	Error while processing converters DEVICE_ID: '3410f4fffee99489'
      zigbee.0
      2024-01-03 09:40:28.360	info	Configuring 0x3410f4fffee99489 SNZB-06P
      zigbee.0
      2024-01-03 09:40:25.563	error	Error while processing converters DEVICE_ID: '3410f4fffee99489'
      zigbee.0
      2024-01-03 09:40:25.345	info	Configuring 0x3410f4fffee99489 SNZB-06P
      zigbee.0
      2024-01-03 09:40:22.483	error	Error while processing converters DEVICE_ID: '3410f4fffee99489'
      zigbee.0
      2024-01-03 09:40:22.328	info	Configuring 0x3410f4fffee99489 SNZB-06P
      zigbee.0
      2024-01-03 09:40:19.521	error	Error while processing converters DEVICE_ID: '3410f4fffee99489'
      zigbee.0
      2024-01-03 09:40:19.331	info	Configuring 0x3410f4fffee99489 SNZB-06P
      zigbee.0
      2024-01-03 09:37:42.089	error	Error while processing converters DEVICE_ID: '3410f4fffee99489'
      zigbee.0
      2024-01-03 09:37:41.892	info	Configuring 0x3410f4fffee99489 SNZB-06P
      zigbee.0
      2024-01-03 09:30:12.372	error	Error while processing converters DEVICE_ID: '3410f4fffee99489'
      zigbee.0
      2024-01-03 09:30:11.620	info	Configuring 0x3410f4fffee99489 SNZB-06P
      zigbee.0
      2024-01-03 09:30:08.826	error	Error while processing converters DEVICE_ID: '3410f4fffee99489'
      zigbee.0
      2024-01-03 09:30:08.603	info	Configuring 0x3410f4fffee99489 SNZB-06P
      zigbee.0
      2024-01-03 09:30:05.897	error	Error while processing converters DEVICE_ID: '3410f4fffee99489'
      zigbee.0
      2024-01-03 09:30:05.588	info	Configuring 0x3410f4fffee99489 SNZB-06P
      zigbee.0
      2024-01-03 09:30:03.318	error	Error while processing converters DEVICE_ID: '3410f4fffee99489'
      zigbee.0
      2024-01-03 09:30:02.579	info	Configuring 0x3410f4fffee99489 SNZB-06P
      zigbee.0
      2024-01-03 09:29:59.768	error	Error while processing converters DEVICE_ID: '3410f4fffee99489'
      zigbee.0
      2024-01-03 09:29:59.566	info	Configuring 0x3410f4fffee99489 SNZB-06P
      zigbee.0
      2024-01-03 09:27:22.335	error	Error while processing converters DEVICE_ID: '3410f4fffee99489'
      zigbee.0
      2024-01-03 09:27:22.113	info	Configuring 0x3410f4fffee99489 SNZB-06P
        na dann weiter gehts
        bitte die
        /opt/iobroker/node_modules/iobroker.zigbee/main.js
        editieren und diese Zeile suchen (ca. Zeile 559 )
        this.log.error(`Error while processing converters DEVICE_ID: '${devId}' `);
        direkt danach das einfügen..(copy paste nutzen nicht abtippen)
        this.log.error(`arteck: '${cluster}' -> '${type}'`);
        es sollte dann erst die Fehlermeldung kommen und dann noch eine mit
        arteck:
        diese brauch ich
        • FredF
          FredF Most Active Forum Testing @arteck last edited by
          @arteck Adapter vorher stoppen?
            arteck Developer Most Active @FredF last edited by arteck
            @fredf ne musst du nicht.. danach aber nue starten
            oder stoppen editieren und starten
            • FredF
              @arteck
              2024-01-03 11:15:18.918	error	arteck: '64529' -> 'readResponse'
              2024-01-03 11:15:18.918	error	Error while processing converters DEVICE_ID: '3410f4fffee39865'
              2024-01-03 11:15:18.913	error	arteck: '64529' -> 'readResponse'
              2024-01-03 11:15:18.913	error	Error while processing converters DEVICE_ID: '3410f4fffee39865'
              2024-01-03 11:15:16.712	info	Configuring 0x3410f4fffee39865 SNZB-06P
              2024-01-03 11:15:15.279	error	arteck: '64529' -> 'readResponse'
              2024-01-03 11:15:15.279	error	Error while processing converters DEVICE_ID: '3410f4fffee39865'
              2024-01-03 11:15:15.275	error	arteck: '64529' -> 'readResponse'
              2024-01-03 11:15:15.275	error	Error while processing converters DEVICE_ID: '3410f4fffee39865'
              2024-01-03 11:15:14.867	info	debug devices set to []
                @fredf sagte in Sonoff Presence Sensor SNZB-06P problem:
                readResponse
                du bist ja schnell ..
                paar zeilen dadrüber sollte
                meta.state = { state: '' };   // for tuya
                da sein ..lösche mal die zeile... und starte adapter neu...
                kommt dann die error meldung ?? für den SNZB-06P
                • FredF
                  @arteck Immer noch
                  2024-01-03 11:20:37.439	error	arteck: '64529' -> 'readResponse'
                  2024-01-03 11:20:37.439	error	Error while processing converters DEVICE_ID: '3410f4fffee39865'
                  2024-01-03 11:20:37.276	info	Configuring 0x3410f4fffee39865 SNZB-06P
                  2024-01-03 11:20:35.704	error	arteck: '64529' -> 'readResponse'
                  2024-01-03 11:20:35.703	error	Error while processing converters DEVICE_ID: '3410f4fffee39865'
                  2024-01-03 11:20:35.299	info	debug devices set to []
                    @fredf bist sicher dass du den adapter neu gestertet hast ??
                    • FredF
                      FredF Most Active Forum Testing @arteck last edited by FredF
                      @arteck Na klar:
                      2024-01-03 11:20:32.794	info	Starting Zigbee npm ...
                      2024-01-03 11:20:32.792	info	delete old Backup files. keep only last 10
                      2024-01-03 11:20:32.666	info	starting. Version 1.9.6 (non-npm: ioBroker/ioBroker.zigbee) in /opt/iobroker/node_modules/iobroker.zigbee, node: v18.19.0, js-controller: 5.0.17
                      2024-01-03 11:20:27.249	info	instance system.adapter.zigbee.0 started with pid 1280
                      2024-01-03 11:20:24.971	info	instance system.adapter.zigbee.0 terminated with code 11 (ADAPTER_REQUESTED_TERMINATION)
                      2024-01-03 11:20:24.355	info	Terminated (ADAPTER_REQUESTED_TERMINATION): Without reason
                      2024-01-03 11:20:24.354	info	terminating
                      2024-01-03 11:20:24.113	info	stopInstance system.adapter.zigbee.0 send kill signal
                      2024-01-03 11:20:24.010	info	Zigbee: disabling joining new devices.
                      2024-01-03 11:20:23.854	info	cleaned everything up...
                      2024-01-03 11:20:23.853	info	Got terminate signal TERMINATE_YOURSELF
                      2024-01-03 11:20:23.849	info	stopInstance system.adapter.zigbee.0 (force=false, process=true)
                      Aber zur Sicherheit nchmal gestartet:
                      2024-01-03 11:26:19.969	error	arteck: '64529' -> 'readResponse'
                      2024-01-03 11:26:19.969	error	Error while processing converters DEVICE_ID: '3410f4fffee39865'
                      2024-01-03 11:26:19.587	info	Configuring 0x3410f4fffee39865 SNZB-06P
                      2024-01-03 11:26:18.333	error	arteck: '64529' -> 'readResponse'
                      2024-01-03 11:26:18.332	error	Error while processing converters DEVICE_ID: '3410f4fffee39865'
                      2024-01-03 11:26:17.644	info	debug devices set to []
                        @fredf ok warte gleich kommt ne GIT version
                        @fredf installier mal von git
                        • FredF
                          @arteck Nur beim Adapter Start kommt das, dann nix mehr.
                          2024-01-03 12:05:48.223	error	Error while processing converters DEVICE_ID: '3410f4fffee39865' cluster '64529' type 'readResponse'
                          2024-01-03 12:05:48.041	info	Configuring 0x3410f4fffee39865 SNZB-06P
                          2024-01-03 12:05:46.604	error	Error while processing converters DEVICE_ID: '3410f4fffee39865' cluster '64529' type 'readResponse'
                          2024-01-03 12:05:46.120	info	debug devices set to []
                            @fredf sehr gut..
                            arteck 1 Reply Last reply Reply Quote 1
                              arteck Developer Most Active @arteck last edited by arteck
                              @arteck schaumal bitte noch
                              editiere
                              /opt/iobroker/node_modules/iobroker.zigbee/lib/zbDeviceConfigure.js
                              ganz unten zeile 144
                              // do nothing ignore it
                              ersetze diese durch
                              return true;
                              adapter neu starten
                              • FredF
                                @arteck zu früh gefreut, die Fehlermeldungen kommen weiter
                                2024-01-03 12:24:39.133	error	Error while processing converters DEVICE_ID: '3410f4fffee39865' cluster '64529' type 'readResponse'
                                2024-01-03 12:24:39.005	info	Configuring 0x3410f4fffee39865 SNZB-06P
                                2024-01-03 12:24:36.189	error	Error while processing converters DEVICE_ID: '3410f4fffee39865' cluster '64529' type 'readResponse'
                                2024-01-03 12:24:36.026	info	Configuring 0x3410f4fffee39865 SNZB-06P
                                2024-01-03 12:24:33.198	error	Error while processing converters DEVICE_ID: '3410f4fffee39865' cluster '64529' type 'readResponse'
                                2024-01-03 12:24:33.053	info	Configuring 0x3410f4fffee39865 SNZB-06P
                                2024-01-03 12:24:30.203	error	Error while processing converters DEVICE_ID: '3410f4fffee39865' cluster '64529' type 'readResponse'
                                2024-01-03 12:24:30.059	info	Configuring 0x3410f4fffee39865 SNZB-06P
                                2024-01-03 12:24:27.237	error	Error while processing converters DEVICE_ID: '3410f4fffee39865' cluster '64529' type 'readResponse'
                                2024-01-03 12:24:27.086	info	Configuring 0x3410f4fffee39865 SNZB-06P
                                2024-01-03 12:14:30.861	info	Device '0xec1bbdfffea30275' announced itself
                                2024-01-03 12:14:25.910	error	Error while processing converters DEVICE_ID: '3410f4fffee39865' cluster '64529' type 'readResponse'
                                2024-01-03 12:14:25.690	info	Configuring 0x3410f4fffee39865 SNZB-06P
                                2024-01-03 12:14:22.929	error	Error while processing converters DEVICE_ID: '3410f4fffee39865' cluster '64529' type 'readResponse'
                                2024-01-03 12:14:22.716	info	Configuring 0x3410f4fffee39865 SNZB-06P
                                2024-01-03 12:14:19.951	error	Error while processing converters DEVICE_ID: '3410f4fffee39865' cluster '64529' type 'readResponse'
                                2024-01-03 12:14:19.730	info	Configuring 0x3410f4fffee39865 SNZB-06P
                                2024-01-03 12:14:16.960	error	Error while processing converters DEVICE_ID: '3410f4fffee39865' cluster '64529' type 'readResponse'
                                2024-01-03 12:14:16.789	info	Configuring 0x3410f4fffee39865 SNZB-06P
                                2024-01-03 12:14:14.125	error	Error while processing converters DEVICE_ID: '3410f4fffee39865' cluster '64529' type 'readResponse'
                                2024-01-03 12:14:13.812	info	Configuring 0x3410f4fffee39865 SNZB-06P
                                  @fredf installier nochmal von GIT
                                  • FredF
                                    @arteck Beim Start des Adapters immer noch:
                                    2024-01-03 12:34:52.689	error	Error while processing converters DEVICE_ID: '3410f4fffee39865' cluster '64529' type 'readResponse'
                                    2024-01-03 12:34:52.388	info	Configuring 0x3410f4fffee39865 SNZB-06P
                                    2024-01-03 12:34:49.691	error	Error while processing converters DEVICE_ID: '3410f4fffee39865' cluster '64529' type 'readResponse'
                                    2024-01-03 12:34:49.405	info	Configuring 0x3410f4fffee39865 SNZB-06P
                                    2024-01-03 12:34:46.724	error	Error while processing converters DEVICE_ID: '3410f4fffee39865' cluster '64529' type 'readResponse'
                                    2024-01-03 12:34:46.424	info	Configuring 0x3410f4fffee39865 SNZB-06P
                                    2024-01-03 12:34:43.751	error	Error while processing converters DEVICE_ID: '3410f4fffee39865' cluster '64529' type 'readResponse'
                                    2024-01-03 12:34:43.445	info	Configuring 0x3410f4fffee39865 SNZB-06P
                                    2024-01-03 12:34:40.782	error	Error while processing converters DEVICE_ID: '3410f4fffee39865' cluster '64529' type 'readResponse'
                                    2024-01-03 12:34:40.471	info	Configuring 0x3410f4fffee39865 SNZB-06P
                                    Ansonsten scheint jetzt ruhe zu sein (seit 10 Minuten)
                                    Edit gerade geschrieben und schon kommen die Fehlermeldung wieder
                                      @fredf nochmal von GIT
                                      da sollte jetzt wieder ein error arteck : kommen
                                      den brauch ich
                                      • FredF
                                        @arteck Es kommt keine solche Meldung...
                                        host.Tower
                                        2024-01-03 12:50:06.301	info	iobroker exit 0
                                        host.Tower
                                        2024-01-03 12:50:05.205	info	iobroker upload [0] zigbee.admin /opt/iobroker/node_modules/iobroker.zigbee/admin/zigbee.svg zigbee.svg image/svg+xml
                                        host.Tower
                                        2024-01-03 12:50:05.198	info	iobroker upload [1] zigbee.admin /opt/iobroker/node_modules/iobroker.zigbee/admin/zigbee.png zigbee.png image/png
                                        host.Tower
                                        2024-01-03 12:50:05.191	info	iobroker upload [2] zigbee.admin /opt/iobroker/node_modules/iobroker.zigbee/admin/words.js words.js application/javascript
                                        host.Tower
                                        2024-01-03 12:50:05.179	info	iobroker upload [3] zigbee.admin /opt/iobroker/node_modules/iobroker.zigbee/admin/vis-network.min.js vis-network.min.js application/javascript
                                        host.Tower
                                        2024-01-03 12:50:05.171	info	iobroker upload [4] zigbee.admin /opt/iobroker/node_modules/iobroker.zigbee/admin/vis-network.min.css vis-network.min.css text/css
                                        host.Tower
                                        2024-01-03 12:50:05.164	info	iobroker upload [5] zigbee.admin /opt/iobroker/node_modules/iobroker.zigbee/admin/tab_m.html tab_m.html text/html
                                        host.Tower
                                        2024-01-03 12:50:05.157	info	iobroker upload [6] zigbee.admin /opt/iobroker/node_modules/iobroker.zigbee/admin/shuffle.min.js shuffle.min.js application/javascript
                                        host.Tower
                                        2024-01-03 12:50:05.151	info	iobroker upload [7] zigbee.admin /opt/iobroker/node_modules/iobroker.zigbee/admin/moment.min.js moment.min.js application/javascript
                                        host.Tower
                                        2024-01-03 12:50:05.139	info	iobroker upload [8] zigbee.admin /opt/iobroker/node_modules/iobroker.zigbee/admin/index_m.html index_m.html text/html
                                        host.Tower
                                        2024-01-03 12:50:05.133	info	iobroker upload [9] zigbee.admin /opt/iobroker/node_modules/iobroker.zigbee/admin/index.html index.html text/html
                                        host.Tower
                                        2024-01-03 12:50:05.126	info	iobroker upload [10] zigbee.admin /opt/iobroker/node_modules/iobroker.zigbee/admin/img/zemismart_sw2.png img/zemismart_sw2.png image/png
                                        host.Tower
                                        2024-01-03 12:50:05.118	info	iobroker upload [11] zigbee.admin /opt/iobroker/node_modules/iobroker.zigbee/admin/img/zbt_smart_switch.png img/zbt_smart_switch.png image/png
                                        host.Tower
                                        2024-01-03 12:50:05.110	info	iobroker upload [12] zigbee.admin /opt/iobroker/node_modules/iobroker.zigbee/admin/img/zbt_led_panel.png img/zbt_led_panel.png image/png
                                        host.Tower
                                        2024-01-03 12:50:05.096	info	iobroker upload [13] zigbee.admin /opt/iobroker/node_modules/iobroker.zigbee/admin/img/zbt_e27_rgbw.png img/zbt_e27_rgbw.png image/png
                                        host.Tower
                                        2024-01-03 12:50:05.077	info	iobroker upload [14] zigbee.admin /opt/iobroker/node_modules/iobroker.zigbee/admin/img/zbt_e27.png img/zbt_e27.png image/png
                                        host.Tower
                                        2024-01-03 12:50:05.070	info	iobroker upload [15] zigbee.admin /opt/iobroker/node_modules/iobroker.zigbee/admin/img/xiaomi_wireless_switch.png img/xiaomi_wireless_switch.png image/png
                                        host.Tower
                                        2024-01-03 12:50:05.062	info	iobroker upload [16] zigbee.admin /opt/iobroker/node_modules/iobroker.zigbee/admin/img/xiaomi_plug_eu.png img/xiaomi_plug_eu.png image/png
                                        host.Tower
                                        2024-01-03 12:50:05.054	info	iobroker upload [17] zigbee.admin /opt/iobroker/node_modules/iobroker.zigbee/admin/img/wemo.png img/wemo.png image/png
                                        host.Tower
                                        2024-01-03 12:50:05.047	info	iobroker upload [18] zigbee.admin /opt/iobroker/node_modules/iobroker.zigbee/admin/img/unknown.png img/unknown.png image/png
                                        host.Tower
                                        2024-01-03 12:50:05.040	info	iobroker upload [19] zigbee.admin /opt/iobroker/node_modules/iobroker.zigbee/admin/img/unavailable.png img/unavailable.png image/png
                                        host.Tower
                                        2024-01-03 12:50:05.033	info	iobroker upload [20] zigbee.admin /opt/iobroker/node_modules/iobroker.zigbee/admin/img/tuya_tyzs1l.png img/tuya_tyzs1l.png image/png
                                        host.Tower
                                        2024-01-03 12:50:04.954	info	iobroker upload [30] zigbee.admin /opt/iobroker/node_modules/iobroker.zigbee/admin/img/ts0203.png img/ts0203.png image/png
                                        host.Tower
                                        2024-01-03 12:50:04.885	info	iobroker upload [40] zigbee.admin /opt/iobroker/node_modules/iobroker.zigbee/admin/img/smartthings_motion.png img/smartthings_motion.png image/png
                                        host.Tower
                                        2024-01-03 12:50:04.818	info	iobroker upload [50] zigbee.admin /opt/iobroker/node_modules/iobroker.zigbee/admin/img/sensor_philipshue.png img/sensor_philipshue.png image/png
                                        host.Tower
                                        2024-01-03 12:50:04.749	info	iobroker upload [60] zigbee.admin /opt/iobroker/node_modules/iobroker.zigbee/admin/img/plug.png img/plug.png image/png
                                        host.Tower
                                        2024-01-03 12:50:04.638	info	iobroker upload [70] zigbee.admin /opt/iobroker/node_modules/iobroker.zigbee/admin/img/philips_hue_ltc021.png img/philips_hue_ltc021.png image/png
                                        host.Tower
                                        2024-01-03 12:50:04.559	info	iobroker upload [80] zigbee.admin /opt/iobroker/node_modules/iobroker.zigbee/admin/img/philips_hue_e27_ambiance.png img/philips_hue_e27_ambiance.png image/png
                                        host.Tower
                                        2024-01-03 12:50:04.498	info	iobroker upload [90] zigbee.admin /opt/iobroker/node_modules/iobroker.zigbee/admin/img/philips_hue_ambiance.png img/philips_hue_ambiance.png image/png
                                        host.Tower
                                        2024-01-03 12:50:04.432	info	iobroker upload [100] zigbee.admin /opt/iobroker/node_modules/iobroker.zigbee/admin/img/philips_amaze.png img/philips_amaze.png image/png
                                        host.Tower
                                        2024-01-03 12:50:04.079	info	iobroker upload [150] zigbee.admin /opt/iobroker/node_modules/iobroker.zigbee/admin/img/lh_32Zb.png img/lh_32Zb.png image/png
                                        host.Tower
                                        2024-01-03 12:50:03.727	info	iobroker upload [200] zigbee.admin /opt/iobroker/node_modules/iobroker.zigbee/admin/img/hive.png img/hive.png image/png
                                        host.Tower
                                        2024-01-03 12:50:03.415	info	iobroker upload [250] zigbee.admin /opt/iobroker/node_modules/iobroker.zigbee/admin/img/bitron_motion.png img/bitron_motion.png image/png
                                        host.Tower
                                        2024-01-03 12:50:03.040	info	iobroker upload [300] zigbee.admin /opt/iobroker/node_modules/iobroker.zigbee/admin/img/DGNWG05LM.png img/DGNWG05LM.png image/png
                                        host.Tower
                                        2024-01-03 12:50:02.874	info	iobroker upload [323] zigbee.admin /opt/iobroker/node_modules/iobroker.zigbee/admin/adapter-settings.js adapter-settings.js application/javascript
                                        host.Tower
                                        2024-01-03 12:50:00.143	info	iobroker 313 packages are looking for funding run `npm fund` for details
                                        host.Tower
                                        2024-01-03 12:50:00.142	info	iobroker changed 1 package in 17s
                                        host.Tower
                                        host.Tower
                                        2024-01-03 12:49:42.351	info	iobroker Installing ioBroker/ioBroker.zigbee... (System call)
                                        host.Tower
                                        2024-01-03 12:49:42.351	info	iobroker NPM version: 10.2.3
                                        host.Tower
                                        2024-01-03 12:49:41.984	info	iobroker install ioBroker/ioBroker.zigbee
                                        host.Tower
                                        2024-01-03 12:49:38.412	info	iobroker url ioBroker/ioBroker.zigbee --host Tower --debug
                                        Edit: Ah... Nach Neustart des Adpaters
                                        arteck : 'Error: Expected one of: 0, 1, got: 'undefined''
                                          @fredf so jetzt nochmal von GIT... und neustart nicht vergessen 🙂
                                          • FredF
                                            @arteck
                                            zigbee.0
                                            2024-01-03 13:05:32.503	error	Error while processing converters DEVICE_ID: '3410f4fffee39865' cluster '64529' type 'readResponse'
                                            zigbee.0
                                            2024-01-03 13:05:32.290	info	Configuring 0x3410f4fffee39865 SNZB-06P
                                            zigbee.0
                                            2024-01-03 13:05:29.543	error	Error while processing converters DEVICE_ID: '3410f4fffee39865' cluster '64529' type 'readResponse'
                                            zigbee.0
                                            2024-01-03 13:05:29.301	info	Configuring 0x3410f4fffee39865 SNZB-06P
                                            zigbee.0
                                            2024-01-03 13:05:26.527	error	Error while processing converters DEVICE_ID: '3410f4fffee39865' cluster '64529' type 'readResponse'
                                            zigbee.0
                                            2024-01-03 13:05:26.322	info	Configuring 0x3410f4fffee39865 SNZB-06P
                                            zigbee.0
                                            2024-01-03 13:05:23.479	error	Error while processing converters DEVICE_ID: '3410f4fffee39865' cluster '64529' type 'readResponse'
                                            zigbee.0
                                            2024-01-03 13:05:23.334	info	Configuring 0x3410f4fffee39865 SNZB-06P
                                            zigbee.0
                                            2024-01-03 13:05:20.531	error	Error while processing converters DEVICE_ID: '3410f4fffee39865' cluster '64529' type 'readResponse'
                                            zigbee.0
                                            2024-01-03 13:05:20.351	info	Configuring 0x3410f4fffee39865 SNZB-06P
                                            zigbee.0
                                            2024-01-03 13:03:37.149	warn	DeviceAvailability:Failed to ping 0x385cfbfffe8ce7c8 TRADFRIbulbGU10WS345lm
                                            zigbee.0
                                            2024-01-03 13:03:37.065	warn	DeviceAvailability:Failed to ping 0x04cd15fffe0ae3fc TS0505B
                                            zigbee.0
                                            2024-01-03 13:03:15.048	error	Error while processing converters DEVICE_ID: '3410f4fffee39865' cluster '64529' type 'readResponse'
                                            zigbee.0
                                            2024-01-03 13:03:14.894	info	Configuring 0x3410f4fffee39865 SNZB-06P
                                            zigbee.0
                                            2024-01-03 13:03:13.379	error	Error while processing converters DEVICE_ID: '3410f4fffee39865' cluster '64529' type 'readResponse'
                                            zigbee.0
                                            2024-01-03 13:03:12.900	info	debug devices set to []
                                            80
                                            11804
