[gelöst] Scenes Adapter geht immer auf rot
host.ioBroker-Master 2024-01-03 11:18:45.714 warn Do not restart adapter system.adapter.scenes.0 because restart loop detected host.ioBroker-Master 2024-01-03 11:18:45.713 info Restart adapter system.adapter.scenes.0 because enabled host.ioBroker-Master 2024-01-03 11:18:45.713 error instance system.adapter.scenes.0 terminated with code 6 (UNCAUGHT_EXCEPTION) host.ioBroker-Master 2024-01-03 11:18:45.713 error Caught by controller[1]: at processImmediate (node:internal/timers:478:21) host.ioBroker-Master 2024-01-03 11:18:45.713 error Caught by controller[1]: at Immediate.<anonymous> (/opt/iobroker/node_modules/@iobroker/js-controller-adapter/src/lib/adapter/adapter.ts:8524:38) host.ioBroker-Master 2024-01-03 11:18:45.713 error Caught by controller[1]: at Object.maybeCallbackWithError (/opt/iobroker/node_modules/@iobroker/js-controller-common/src/lib/common/maybeCallback.ts:136:17) host.ioBroker-Master 2024-01-03 11:18:45.712 error Caught by controller[1]: Error: Alias alias.0.Beleuchtung.Erdgeschoss.Grosses Fenster links oben has no target host.ioBroker-Master 2024-01-03 11:18:45.712 error Caught by controller[0]: This error originated either by throwing inside of an async function without a catch block, or by rejecting a promise which was not handled with .catch(). The promise rejected with the reason: scenes.0 2024-01-03 11:18:45.251 info terminating scenes.0 2024-01-03 11:18:44.748 warn Terminated (UNCAUGHT_EXCEPTION): Without reason scenes.0 2024-01-03 11:18:44.747 debug Plugin sentry destroyed scenes.0 2024-01-03 11:18:44.746 info terminating scenes.0 2024-01-03 11:18:44.714 error Alias alias.0.Beleuchtung.Erdgeschoss.Grosses Fenster links oben has no target scenes.0 2024-01-03 11:18:44.713 error Error: Alias alias.0.Beleuchtung.Erdgeschoss.Grosses Fenster links oben has no target at Object.maybeCallbackWithError (/opt/iobroker/node_modules/@iobroker/js-controller-common/src/lib/common/maybeCallback.ts:136:17) at Immediate.<anonymous> (/opt/iobroker/node_modules/@iobroker/js-controller-adapter/src/lib/adapter/adapter.ts:8524:38) at processImmediate (node:internal/timers:478:21) scenes.0 2024-01-03 11:18:44.388 error unhandled promise rejection: Alias alias.0.Beleuchtung.Erdgeschoss.Grosses Fenster links oben has no target scenes.0 2024-01-03 11:18:44.388 error Unhandled promise rejection. This error originated either by throwing inside of an async function without a catch block, or by rejecting a promise which was not handled with .catch(). scenes.0 2024-01-03 11:18:44.386 warn Alias alias.0.Beleuchtung.Erdgeschoss.Grosses Fenster links oben has no target 5 scenes.0 2024-01-03 11:18:44.383 warn Alias alias.0.Beleuchtung.Erdgeschoss.Grosses Fenster links oben has no target 8 scenes.0 2024-01-03 11:18:41.378 debug activateScene: execute for "scene.0.Schmucklampen" (false) scenes.0 2024-01-03 11:18:27.610 warn Alias alias.0.Beleuchtung.Erdgeschoss.Wandleuchte Kopierer LED unten has no target 8 scenes.0 2024-01-03 11:18:27.610 warn Alias alias.0.Beleuchtung.Erdgeschoss.Wandleuchte Kopierer LED oben has no target 8 scenes.0 2024-01-03 11:18:27.609 warn Alias alias.0.Beleuchtung.Erdgeschoss.Grosses Fenster rechts unten has no target 8 scenes.0 2024-01-03 11:18:27.608 warn Alias alias.0.Beleuchtung.Erdgeschoss.Grosses Fenster rechts oben has no target 8 scenes.0 2024-01-03 11:18:27.608 warn Alias alias.0.Beleuchtung.Erdgeschoss.Grosses Fenster links unten has no target 8 scenes.0 2024-01-03 11:18:27.607 warn Alias alias.0.Beleuchtung.Erdgeschoss.Grosses Fenster links oben has no target 8 scenes.0 2024-01-03 11:18:27.602 warn Alias alias.0.Beleuchtung.Erdgeschoss.Wandleuchte Kopierer LED unten has no target 8 scenes.0 2024-01-03 11:18:27.602 warn Alias alias.0.Beleuchtung.Erdgeschoss.Wandleuchte Kopierer LED oben has no target 8 scenes.0 2024-01-03 11:18:27.601 warn Alias alias.0.Beleuchtung.Erdgeschoss.Grosses Fenster rechts unten has no target 8 scenes.0 2024-01-03 11:18:27.601 warn Alias alias.0.Beleuchtung.Erdgeschoss.Grosses Fenster rechts oben has no target 8 scenes.0 2024-01-03 11:18:27.600 warn Alias alias.0.Beleuchtung.Erdgeschoss.Grosses Fenster links unten has no target 8 scenes.0 2024-01-03 11:18:27.600 warn Alias alias.0.Beleuchtung.Erdgeschoss.Grosses Fenster links oben has no target 8 scenes.0 2024-01-03 11:18:27.599 warn Alias alias.0.Beleuchtung.Erdgeschoss.Wandleuchte Kopierer LED unten has no target 8 scenes.0 2024-01-03 11:18:27.598 warn Alias alias.0.Beleuchtung.Erdgeschoss.Wandleuchte Kopierer LED oben has no target 8 scenes.0 2024-01-03 11:18:27.598 warn Alias alias.0.Beleuchtung.Erdgeschoss.Grosses Fenster rechts unten has no target 8 scenes.0 2024-01-03 11:18:27.597 warn Alias alias.0.Beleuchtung.Erdgeschoss.Grosses Fenster rechts oben has no target 8 scenes.0 2024-01-03 11:18:27.597 warn Alias alias.0.Beleuchtung.Erdgeschoss.Grosses Fenster links unten has no target 8 scenes.0 2024-01-03 11:18:27.596 warn Alias alias.0.Beleuchtung.Erdgeschoss.Grosses Fenster links oben has no target 8 scenes.0 2024-01-03 11:18:27.544 debug initScenes: subscribe on all scenes.0 2024-01-03 11:18:27.372 info starting. Version 2.3.9 in /opt/iobroker/node_modules/iobroker.scenes, node: v18.19.0, js-controller: 5.0.17 scenes.0 2024-01-03 11:18:26.609 debug Plugin sentry Initialize Plugin (enabled=true) host.ioBroker-Master 2024-01-03 11:18:24.094 info instance system.adapter.scenes.0 started with pid 15539
Es mag ja unglaubwürdig klingen, aber bis zum 31.12.2023 hat es problemlos funktioniert.
@beowolf sagte in Scenes Adapter geht immer auf rot:
der referenzierte DP im alias existiert noch?
Alle DP existieren und sind auch bei iqontrol eingetragen und auch schaltbar.Alle DP haben auch kein Leerzeichen.
Alle DP existieren
dann zeig sie mal bitte!
die Alias Definition und den darin referenzierten Datenpunkt -
@homoran sagte in Scenes Adapter geht immer auf rot:
die Alias Definition und den darin referenzierten DatenpunktZeigt das nicht das Bild?
nein!
sonst würde ich nicht fragen -
Meinst du dieses? -
Meinst du dieses?
auch!
aber vom angemeckerten Alias ...-links-obenund dann den darin eingstellten Datenpunkt
der soll laut log nicht mehr existieren -
das meinst du?
das meinst du?
auch! aber das entscheidende feht.
existiert der dort eingegebene Ikea Datenpunkt.
Laut log fehlt der
Hier haben die DPs alle einen Bindestrich in der Bezeichnung.
Lt. Log von scenes Adapter allerdings nicht
Das mit dem Bindestrich war es.
Wie immer sitzt der Fehler VOR dem Bildschirm. Ich habe am 31.12.2023 aus Langweile die DP bearbeitet.
Deshalb ging es auch bis zu dem Datum.
Alle DP die ich geändert habe neu unter Scenes eingetragen.
Was soll ich sagen - kaum macht man es richtig - funktioniert es.
Danke für die Hilfe
@beowolf sagte in [gelöst] Scenes Adapter geht immer auf rot:
Danke für die Hilfe
Ach was!??
genau so etwas stand ja auch im log
Ja, ja. Das mit dem Sehen - Lesen - Verstehen ist nicht immer einfach.
