    4. Error Log Controller Iobroker *GELÖST*
    • Nicoloma
      Nicoloma @Thomas Braun last edited by
      danke habe einen neuen Nutzer angelegt und ihn in die Gruppe hinzugefügt
      nicolas@iobroker:/$ sudo usermod -a -G iobroker nicolas
      nicolas@iobroker:/$ groups
      nicolas sudo iobroker
      nicolas@iobroker:/$ iob diag
      nicolas@iobroker:/$
        Thomas Braun Most Active @Nicoloma last edited by
        @nicoloma
        Und der hat kein Heimverzeichnis? Warum stehst du da in / herum?
        Nicoloma 1 Reply Last reply Reply Quote 0
        • Nicoloma
          @thomas-braun ```
          Copy text starting here:
                                  v.2023-10-10
           Static hostname: iobroker
                 Icon name: computer-container
                   Chassis: container
            Virtualization: lxc
          Operating System: Ubuntu 22.04.3 LTS
                    Kernel: Linux 6.2.16-19-pve
              Architecture: x86-64
          Installation:           lxc
          Kernel:                 x86_64
          Userland:               amd64
          Timezone:               CET (CET, +0100)
          User-ID:                1003
          X-Server:               false
          Boot Target:            graphical.target
          Pending OS-Updates:     0
          Pending iob updates:    2
          Nodejs-Installation:    /usr/bin/nodejs         v18.18.2
                                  /usr/bin/node           v18.18.2
                                  /usr/bin/npm            9.8.1
                                  /usr/bin/npx            9.8.1
                                  /usr/bin/corepack       0.19.0
          Recommended versions are nodejs 18.18.2 and npm 9.8.1
          MEMORY:
          Mem:            8.0G        3.5G        4.4G        1.0M        117M        4.5G
          Swap:           2.0G         25M        2.0G
          Total:           10G        3.5G        6.4G
          Active iob-Instances:   31
          Active repo(s): stable
          ioBroker Core:          js-controller           5.0.16
                                  admin                   6.12.0
          Objects type: jsonl
          States  type: jsonl
          + system.adapter.admin.0                  : admin                 : iobroker                                 -  enabled, port: 8081, bind: 192.168.178.103 (SSL), run as: admin
          + system.adapter.web.0                    : web                   : iobroker                                 -  enabled, port: 8082, bind: 0.0.0.0 (SSL), run as: admin
          Objects:                22399
          States:                 18080
          Size of iob-Database:
          15M     /opt/iobroker/iobroker-data/objects.jsonl
          1.1M    /opt/iobroker/iobroker-data/states.jsonl
          === Mark text until here for copying ===
            @nicoloma
            Die lange Fassung.
            • Nicoloma
              @thomas-braun ```
              Skript v.2023-10-10
              *** BASE SYSTEM ***
                       Chassis: container
                Virtualization: lxc
              model name      : Intel(R) Core(TM) i7-6700 CPU @ 3.40GHz
              Docker          : false
              Virtualization  : lxc
              Kernel          : x86_64
              Userland        : amd64
              Systemuptime and Load:
               21:26:26 up  1:34,  2 users,  load average: 1.49, 1.36, 1.13
              CPU threads: 3
              *** Time and Time Zones ***
                             Local time: Fri 2023-11-24 21:26:26 CET
                         Universal time: Fri 2023-11-24 20:26:26 UTC
                               RTC time: n/a
                              Time zone: CET (CET, +0100)
                            NTP service: inactive
                        RTC in local TZ: no
              *** User and Groups ***
              nicolas
              /home/nicolas
              *** X-Server-Setup ***
              X-Server:       false
              Desktop:
              Terminal:       tty
              *** MEMORY ***
              Swap:           2.0G         25M        2.0G
                       8000 M total memory
                       3504 M used memory
                        101 M active memory
                       3356 M inactive memory
                       4377 M free memory
                          0 M buffer memory
                        117 M swap cache
                       2000 M total swap
                         25 M used swap
                       1974 M free swap
              *** FAILED SERVICES ***
                UNIT                                 LOAD   ACTIVE SUB    DESCRIPTION
              * media-FREIGABE.mount                 loaded failed failed /media/FREIGABE
              * run-rpc_pipefs.mount                 loaded failed failed RPC Pipe File System
              * bluetooth.service                    loaded failed failed Bluetooth service
              * motioneye.service                    loaded failed failed motionEye Server
              * systemd-networkd-wait-online.service loaded failed failed Wait for Network to be Configured
              LOAD   = Reflects whether the unit definition was properly loaded.
              ACTIVE = The high-level unit activation state, i.e. generalization of SUB.
              SUB    = The low-level unit activation state, values depend on unit type.
              5 loaded units listed.
              *** FILESYSTEM ***
              Filesystem            Type   Size  Used Avail Use% Mounted on
              ssd/subvol-103-disk-0 zfs     39G   18G   22G  45% /
              none                  tmpfs  492K  4.0K  488K   1% /dev
              tmpfs                 tmpfs  7.8G     0  7.8G   0% /dev/shm
              tmpfs                 tmpfs  3.1G  1.7M  3.1G   1% /run
              tmpfs                 tmpfs  5.0M     0  5.0M   0% /run/lock
              tmpfs                 tmpfs  1.6G  4.0K  1.6G   1% /run/user/1002
              dmesg: read kernel buffer failed: Operation not permitted
              TARGET SOURCE                FSTYPE OPTIONS
              /      ssd/subvol-103-disk-0 zfs    rw,xattr,posixacl
              /var:
              6.5G    /var/
              4.3G    /var/lib
              2.8G    /var/lib/influxdb
              2.7G    /var/lib/influxdb/data
              2.3G    /var/lib/influxdb/data/iobroker/global
              Archived and active journals take up 168.5K in the file system.
              /opt/iobroker/backups:
              6.4G    /opt/iobroker/backups/
              /opt/iobroker/iobroker-data:
              339M    /opt/iobroker/iobroker-data/
              226M    /opt/iobroker/iobroker-data/files
              97M     /opt/iobroker/iobroker-data/backup-objects
              32M     /opt/iobroker/iobroker-data/files/echarts.admin
              26M     /opt/iobroker/iobroker-data/files/javascript.admin
              18M     /opt/iobroker/iobroker-data/files/material/static/js/main.c5478f66.js.map
              16M     /opt/iobroker/iobroker-data/files/devices.admin/static/js/main.24f2bb56.js.map
              13M     /opt/iobroker/iobroker-data/files/iot.admin/static/js/main.1797d034.js.map
              8.2M    /opt/iobroker/iobroker-data/files/echarts/static/js/main.5f66c5d9.js.map
              USB-Devices by-id:
              *** NodeJS-Installation ***
              /usr/bin/npm            9.8.1
              /usr/bin/npx            9.8.1
              nodejs:
                Installed: 18.18.2-1nodesource1
                Candidate: 18.18.2-1nodesource1
                Version table:
               *** 18.18.2-1nodesource1 1001
                      500 https://deb.nodesource.com/node_18.x nodistro/main amd64 Packages
                      100 /var/lib/dpkg/status
                   18.18.1-1nodesource1 1001
                   18.18.0-1nodesource1 1001
                   18.17.1-1nodesource1 1001
                   18.17.0-1nodesource1 1001
                   18.16.1-1nodesource1 1001
                   18.16.0-1nodesource1 1001
                   18.15.0-1nodesource1 1001
                   18.14.2-1nodesource1 1001
                   18.14.1-1nodesource1 1001
                   18.14.0-1nodesource1 1001
                   18.13.0-1nodesource1 1001
                   18.12.0-1nodesource1 1001
                   18.11.0-1nodesource1 1001
                   18.10.0-1nodesource1 1001
                   18.9.1-1nodesource1 1001
                   18.9.0-1nodesource1 1001
                   18.8.0-1nodesource1 1001
                   18.7.0-1nodesource1 1001
                   18.6.0-1nodesource1 1001
                   18.5.0-1nodesource1 1001
                   18.4.0-1nodesource1 1001
                   18.3.0-1nodesource1 1001
                   18.2.0-1nodesource1 1001
                   18.1.0-1nodesource1 1001
                   18.0.0-1nodesource1 1001
                   12.22.9~dfsg-1ubuntu3.2 500
                      500 http://archive.ubuntu.com/ubuntu jammy-updates/universe amd64 Packages
                      500 http://archive.ubuntu.com/ubuntu jammy-security/universe amd64 Packages
                   12.22.9~dfsg-1ubuntu3 500
                      500 http://archive.ubuntu.com/ubuntu jammy/universe amd64 Packages
              No problems detected
              Errors in npm tree:
              *** ioBroker-Installation ***
              ioBroker Status
              Objects type: jsonl
              States  type: jsonl
              Core adapters versions
              js-controller:  5.0.16
              admin:          6.12.0
              javascript:     7.1.6
              Adapters from github:   4
              Adapter State
              + system.adapter.accuweather.0            : accuweather           : iobroker                                 -  enabled
                system.adapter.alexa2.0                 : alexa2                : iobroker                                 -  enabled
                system.adapter.alias-manager.0          : alias-manager         : iobroker                                 - disabled
                system.adapter.backitup.0               : backitup              : iobroker                                 - disabled
                system.adapter.chromecast.0             : chromecast            : iobroker                                 - disabled
                system.adapter.cloud.0                  : cloud                 : iobroker                                 - disabled
              + system.adapter.device-reminder.0        : device-reminder       : iobroker                                 -  enabled
                system.adapter.discovery.0              : discovery             : iobroker                                 - disabled
                system.adapter.echarts.0                : echarts               : iobroker                                 - disabled
                system.adapter.flot.0                   : flot                  : iobroker                                 - disabled
              + system.adapter.hass.0                   : hass                  : iobroker                                 -  enabled, port: 8123
                system.adapter.history.0                : history               : iobroker                                 - disabled
                system.adapter.ical.0                   : ical                  : iobroker                                 -  enabled
                system.adapter.icons-addictive-flavour-png.0: icons-addictive-flavour-png: iobroker                                 - disabled
                system.adapter.icons-material-png.0     : icons-material-png    : iobroker                                 - disabled
              + system.adapter.influxdb.0               : influxdb              : iobroker                                 -  enabled, port: 8086
              + system.adapter.info.0                   : info                  : iobroker                                 -  enabled
                system.adapter.iot.0                    : iot                   : iobroker                                 - disabled
                system.adapter.javascript.0             : javascript            : iobroker                                 - disabled
              + system.adapter.lgtv.0                   : lgtv                  : iobroker                                 -  enabled
                system.adapter.material.0               : material              : iobroker                                 - disabled
                system.adapter.mbus.0                   : mbus                  : iobroker                                 - disabled, port: 1502
              + system.adapter.meross.0                 : meross                : iobroker                                 -  enabled
                system.adapter.modbus.0                 : modbus                : iobroker                                 - disabled
              + system.adapter.modbus.1                 : modbus                : iobroker                                 -  enabled
              + system.adapter.moma.0                   : moma                  : iobroker                                 -  enabled
              + system.adapter.mqtt.0                   : mqtt                  : iobroker                                 -  enabled, port: 1884, bind: 192.168.178.103
                system.adapter.net-tools.0              : net-tools             : iobroker                                 - disabled
              + system.adapter.onvif.0                  : onvif                 : iobroker                                 -  enabled, port: 80, 7575, 8000, 8080, 8081, 8899
                system.adapter.pi-hole.0                : pi-hole               : iobroker                                 - disabled
                system.adapter.ping.0                   : ping                  : iobroker                                 - disabled
              + system.adapter.plenticore.0             : plenticore            : iobroker                                 -  enabled, port: 80
                system.adapter.proxmox.0                : proxmox               : iobroker                                 - disabled, port: 8006
              + system.adapter.pvforecast.0             : pvforecast            : iobroker                                 -  enabled
              + system.adapter.pvforecast.1             : pvforecast            : iobroker                                 -  enabled
                system.adapter.radar2.0                 : radar2                : iobroker                                 - disabled
              + system.adapter.samsung.0                : samsung               : iobroker                                 -  enabled
              + system.adapter.sayit.0                  : sayit                 : iobroker                                 -  enabled
              + system.adapter.shelly.0                 : shelly                : iobroker                                 -  enabled, port: 1887, bind: 192.168.178.103
              + system.adapter.smartcontrol.0           : smartcontrol          : iobroker                                 -  enabled
              + system.adapter.smartmeter.0             : smartmeter            : raspberrypi                              -  enabled
              + system.adapter.smartthings.0            : smartthings           : iobroker                                 -  enabled
                system.adapter.solarviewdatareader.0    : solarviewdatareader   : iobroker                                 - disabled, port: 15000
              + system.adapter.sonoff.0                 : sonoff                : iobroker                                 -  enabled, port: 1880, bind: 192.168.178.50
              + system.adapter.sourceanalytix.1         : sourceanalytix        : iobroker                                 -  enabled
              + system.adapter.statistics.0             : statistics            : iobroker                                 -  enabled
              + system.adapter.tankerkoenig.0           : tankerkoenig          : iobroker                                 -  enabled
              + system.adapter.telegram.2               : telegram              : iobroker                                 -  enabled, port: 8443, bind: 0.0.0.0
                system.adapter.terminal.0               : terminal              : iobroker                                 - disabled, port: 8090, bind: 0.0.0.0, run as: admin
              + system.adapter.text2command.0           : text2command          : iobroker                                 -  enabled
              + system.adapter.tibber.0                 : tibber                : iobroker                                 -  enabled
                system.adapter.tr-064.0                 : tr-064                : iobroker                                 - disabled
                system.adapter.trashschedule.0          : trashschedule         : iobroker                                 -  enabled
              + system.adapter.tuya.0                   : tuya                  : iobroker                                 -  enabled
                system.adapter.upnp.0                   : upnp                  : iobroker                                 - disabled
                system.adapter.vis-bars.0               : vis-bars              : iobroker                                 - disabled
                system.adapter.vis-history.0            : vis-history           : iobroker                                 - disabled
                system.adapter.vis-hqwidgets.0          : vis-hqwidgets         : iobroker                                 - disabled
                system.adapter.vis-inventwo.0           : vis-inventwo          : iobroker                                 - disabled
                system.adapter.vis-plumb.0              : vis-plumb             : iobroker                                 - disabled
                system.adapter.vis-timeandweather.0     : vis-timeandweather    : iobroker                                 - disabled
                system.adapter.vis.0                    : vis                   : iobroker                                 -  enabled
                system.adapter.weatherunderground.0     : weatherunderground    : iobroker                                 - disabled
                system.adapter.zigbee.0                 : zigbee                : iobroker                                 - disabled, port: /dev/ttyACM0
              + instance is alive
              ioBroker-Repositories
              Installed ioBroker-Instances
              Used repository: stable
              Adapter    "accuweather"  : 1.3.1    , installed 1.3.1
              Adapter    "admin"        : 6.12.0   , installed 6.12.0
              Adapter    "alexa2"       : 3.26.1   , installed 3.26.1
              Adapter    "backitup"     : 2.8.7    , installed 2.8.7
              Adapter    "ble"          : 0.13.4   , installed 0.13.4
              Adapter    "chromecast"   : 3.0.3    , installed 3.0.3
              Adapter    "daswetter"    : 3.1.10   , installed 3.1.10
              Adapter    "device-reminder": 3.0.0  , installed 3.0.0
              Adapter    "echarts"      : 1.5.4    , installed 1.5.4
              Adapter    "hass"         : 1.4.0    , installed 1.4.0
              Adapter    "influxdb"     : 3.2.0    , installed 3.2.0
              Adapter    "iot"          : 2.0.11   , installed 2.0.11
              Adapter    "javascript"   : 7.1.4    , installed 7.1.6
              Controller "js-controller": 5.0.16   , installed 5.0.16
              Adapter    "lgtv"         : 2.1.2    , installed 2.1.2
              Adapter    "material"     : 1.3.1    , installed 1.3.1
              Adapter    "mbus"         : 2.5.0    , installed 2.4.0  [Updatable]
              Adapter    "meross"       : 1.15.1   , installed 1.15.1
              Adapter    "modbus"       : 5.0.11   , installed 5.0.11
              Adapter    "moma"         : 1.2.9    , installed 1.2.9
              Adapter    "mqtt"         : 5.1.0    , installed 5.1.0
              Adapter    "onvif"        : 1.1.1    , installed 1.1.1
              Adapter    "pi-hole"      : 1.3.6    , installed 1.3.6
              Adapter    "plenticore"   : 2.2.0    , installed 2.2.0
              Adapter    "proxmox"      : 2.2.1    , installed 2.2.1
              Adapter    "pvforecast"   : 2.9.0    , installed 2.9.0
              Adapter    "radar2"       : 2.0.8    , installed 2.0.8
              Adapter    "samsung"      : 0.5.11   , installed 0.5.11
              Adapter    "sayit"        : 3.0.5    , installed 3.0.5
              Adapter    "shelly"       : 6.6.1    , installed 6.6.1
              Adapter    "smartcontrol" : 2.0.1    , installed 2.0.1
              Adapter    "smartmeter"   : 3.3.4    , installed 3.3.4
              Adapter    "smartthings"  : 0.0.4    , installed 0.0.4
              Adapter    "socketio"     : 6.5.5    , installed 6.5.5
              Adapter    "solarviewdatareader": 1.0.7, installed 1.0.7
              Adapter    "sonoff"       : 3.0.3    , installed 3.0.3
              Adapter    "statistics"   : 2.4.0    , installed 2.3.0  [Updatable]
              Adapter    "telegram"     : 2.0.1    , installed 2.0.1
              Adapter    "terminal"     : 1.0.0    , installed 1.0.0
              Adapter    "text2command" : 3.0.2    , installed 3.0.2
              Adapter    "trashschedule": 2.3.0    , installed 2.3.0
              Adapter    "tuya"         : 3.14.2   , installed 3.14.2
              Adapter    "upnp"         : 1.0.21   , installed 1.0.21
              Adapter    "weatherunderground": 3.6.0, installed 3.6.0
              Adapter    "web"          : 6.1.10   , installed 6.1.10
              Adapter    "ws"           : 2.5.8    , installed 2.5.8
              Adapter    "zigbee"       : 1.8.24   , installed 1.8.24
              Objects and States
              Objects:        22399
              States:         18080
              W: https://packages.grafana.com/oss/deb/dists/stable/InRelease: Key is stored in legacy trusted.gpg keyring (/etc/apt/trusted.gpg), see the DEPRECATION section in apt-key(8) for details.
              Hit:1 http://archive.ubuntu.com/ubuntu jammy InRelease
              Hit:2 http://archive.ubuntu.com/ubuntu jammy-updates InRelease
              Hit:3 https://repos.influxdata.com/debian stable InRelease
              Hit:4 https://packages.grafana.com/oss/deb stable InRelease
              Hit:5 http://archive.ubuntu.com/ubuntu jammy-security InRelease
              Hit:6 https://deb.nodesource.com/node_18.x nodistro InRelease
              Reading package lists... Done
              Pending Updates: 0
              *** Listening Ports ***
              tcp        0      0 127.0.0.1:34759         0.0.0.0:*               LISTEN      0          1332094785 228/containerd
              tcp        0      0 127.0.0.1:1883          0.0.0.0:*               LISTEN      112        1332094765 234/mosquitto
              tcp        0      0 0.0.0.0:3001            0.0.0.0:*               LISTEN      0          1332119484 1175/docker-proxy
              tcp        0      0 127.0.0.53:53           0.0.0.0:*               LISTEN      106        1332093500 182/systemd-resolve
              tcp        0      0 127.0.0.1:25            0.0.0.0:*               LISTEN      0          1332115025 540/master
              tcp        0      0 192.168.178.103:8081    0.0.0.0:*               LISTEN      1000       1333518017 7209/io.admin.0
              tcp        0      0 0.0.0.0:10000           0.0.0.0:*               LISTEN      0          1332104159 548/perl
              tcp        0      0 127.0.0.1:45009         0.0.0.0:*               LISTEN      113        1333808462 9856/plugin_start_l
              tcp        0      0 0.0.0.0:9001            0.0.0.0:*               LISTEN      1000       1333517165 7191/iobroker.js-co
              tcp        0      0 0.0.0.0:9000            0.0.0.0:*               LISTEN      1000       1333517169 7191/iobroker.js-co
              tcp        0      0 0.0.0.0:445             0.0.0.0:*               LISTEN      0          1332112977 389/smbd
              tcp        0      0 0.0.0.0:139             0.0.0.0:*               LISTEN      0          1332112978 389/smbd
              tcp        0      0 0.0.0.0:111             0.0.0.0:*               LISTEN      0          1332093146 1/init
              tcp        0      0 192.168.178.103:1885    0.0.0.0:*               LISTEN      1000       1333610677 7354/io.mqtt.0
              tcp        0      0 192.168.178.103:1884    0.0.0.0:*               LISTEN      1000       1333610676 7354/io.mqtt.0
              tcp        0      0 192.168.178.103:1887    0.0.0.0:*               LISTEN      1000       1333610764 7385/io.shelly.0
              tcp        0      0 127.0.0.1:8088          0.0.0.0:*               LISTEN      999        1332112931 291/influxd
              tcp        0      0 127.0.0.1:8080          0.0.0.0:*               LISTEN      115        1332097086 231/motion
              tcp        0      0 127.0.0.1:8081          0.0.0.0:*               LISTEN      115        1332097085 231/motion
              tcp6       0      0 :::3001                 :::*                    LISTEN      0          1332119490 1182/docker-proxy
              tcp6       0      0 :::3000                 :::*                    LISTEN      113        1333803505 9714/grafana
              tcp6       0      0 ::1:25                  :::*                    LISTEN      0          1332115026 540/master
              tcp6       0      0 ::1:1883                :::*                    LISTEN      112        1332094766 234/mosquitto
              tcp6       0      0 :::445                  :::*                    LISTEN      0          1332112975 389/smbd
              tcp6       0      0 :::139                  :::*                    LISTEN      0          1332112976 389/smbd
              tcp6       0      0 :::111                  :::*                    LISTEN      0          1332093148 1/init
              tcp6       0      0 :::22                   :::*                    LISTEN      0          1332094457 1/init
              tcp6       0      0 :::8082                 :::*                    LISTEN      1000       1333754449 8820/io.web.0
              tcp6       0      0 :::8086                 :::*                    LISTEN      999        1332113042 291/influxd
              udp        0      0 0.0.0.0:6666            0.0.0.0:*                           1000       1333661282 7418/io.tuya.0
              udp        0      0 0.0.0.0:6667            0.0.0.0:*                           1000       1333661283 7418/io.tuya.0
              udp        0      0 127.0.0.53:53           0.0.0.0:*                           106        1332093499 182/systemd-resolve
              udp        0      0 0.0.0.0:111             0.0.0.0:*                           0          1332093147 1/init
              udp        0      0 172.17.255.255:137      0.0.0.0:*                           0          1332348842 282/nmbd
              udp        0      0 172.17.0.1:137          0.0.0.0:*                           0          1332348841 282/nmbd
              udp        0      0 192.168.178.255:137     0.0.0.0:*                           0          1332112921 282/nmbd
              udp        0      0 192.168.178.103:137     0.0.0.0:*                           0          1332112920 282/nmbd
              udp        0      0 0.0.0.0:137             0.0.0.0:*                           0          1332112908 282/nmbd
              udp        0      0 172.17.255.255:138      0.0.0.0:*                           0          1332348844 282/nmbd
              udp        0      0 172.17.0.1:138          0.0.0.0:*                           0          1332348843 282/nmbd
              udp        0      0 192.168.178.255:138     0.0.0.0:*                           0          1332112923 282/nmbd
              udp        0      0 192.168.178.103:138     0.0.0.0:*                           0          1332112922 282/nmbd
              udp        0      0 0.0.0.0:138             0.0.0.0:*                           0          1332112909 282/nmbd
              udp        0      0 0.0.0.0:10000           0.0.0.0:*                           0          1332104160 548/perl
              udp6       0      0 :::111                  :::*                                0          1332093149 1/init
              2023-11-24 21:25:58.464  - error: host.iobroker Caught by controller[10]: 13: 0x12f933d v8::internal::Runtime_StringCharCodeAt(int, unsigned long*, v8::internal::Isolate*) [/usr/bin/node]
              2023-11-24 21:25:58.464  - error: host.iobroker Caught by controller[11]: 14: 0x1705b39  [/usr/bin/node]
              2023-11-24 21:25:58.464  - warn: host.iobroker instance system.adapter.trashschedule.0 terminated due to SIGABRT
              2023-11-24 21:26:15.274  - warn: hass.0 (7464) State "hass.0.entities.device_tracker.s21_von_espe_2.connected_to" has no existing object, this might lead to an error in future versions
              2023-11-24 21:26:15.274  - warn: hass.0 (7464) State "hass.0.entities.device_tracker.s21_von_espe_2.connection_type" has no existing object, this might lead to an error in future versions
              2023-11-24 21:26:15.274  - warn: hass.0 (7464) State "hass.0.entities.device_tracker.s21_von_espe_2.ssid" has no existing object, this might lead to an error in future versions
              2023-11-24 21:26:29.330  - error: host.iobroker Caught by controller[0]: <--- Last few GCs --->
              2023-11-24 21:26:29.330  - error: host.iobroker Caught by controller[0]: [33518:0x5e306c0]      720 ms: Mark-sweep (reduce) 19.1 (20.8) -> 18.4 (21.3) MB, 4.4 / 0.0 ms  (+ 0.4 ms in 30 steps since start of marking, biggest step 0.0 ms, walltime since start of marking 31 ms) (average mu = 0.901, current mu = 0.877) allocation f[33518:0x5e306c0]      739 ms: Mark-sweep (reduce) 19.9 (21.3) -> 18.5 (21.5) MB, 4.3 / 0.0 ms  (+ 0.3 ms in 15 steps since start of marking, biggest step 0.0 ms, walltime since start of marking 18 ms) (average mu = 0.862, current mu = 0.757) allocation f
              2023-11-24 21:26:29.330  - error: host.iobroker Caught by controller[0]: <--- JS stacktrace --->
              2023-11-24 21:26:29.330  - error: host.iobroker Caught by controller[1]: FATAL ERROR: Reached heap limit Allocation failed - JavaScript heap out of memory
              2023-11-24 21:26:29.330  - error: host.iobroker Caught by controller[2]:  1: 0xb85bc0 node::Abort() [/usr/bin/node]
              2023-11-24 21:26:29.330  - error: host.iobroker Caught by controller[3]:  2: 0xa94834  [/usr/bin/node]
              2023-11-24 21:26:29.330  - error: host.iobroker Caught by controller[4]:  3: 0xd66d10 v8::Utils::ReportOOMFailure(v8::internal::Isolate*, char const*, bool) [/usr/bin/node]
              2023-11-24 21:26:29.330  - error: host.iobroker Caught by controller[5]:  4: 0xd670b7 v8::internal::V8::FatalProcessOutOfMemory(v8::internal::Isolate*, char const*, bool) [/usr/bin/node]
              2023-11-24 21:26:29.330  - error: host.iobroker Caught by controller[6]:  5: 0xf447c5  [/usr/bin/node]
              2023-11-24 21:26:29.331  - error: host.iobroker Caught by controller[7]:  6: 0xf56cad v8::internal::Heap::CollectGarbage(v8::internal::AllocationSpace, v8::internal::GarbageCollectionReason, v8::GCCallbackFlags) [/usr/bin/node]
              2023-11-24 21:26:29.331  - error: host.iobroker Caught by controller[8]:  7: 0xf313ae v8::internal::HeapAllocator::AllocateRawWithLightRetrySlowPath(int, v8::internal::AllocationType, v8::internal::AllocationOrigin, v8::internal::AllocationAlignment) [/usr/bin/node]
              2023-11-24 21:26:29.331  - error: host.iobroker Caught by controller[9]:  8: 0xf32777 v8::internal::HeapAllocator::AllocateRawWithRetryOrFailSlowPath(int, v8::internal::AllocationType, v8::internal::AllocationOrigin, v8::internal::AllocationAlignment) [/usr/bin/node]
              2023-11-24 21:26:29.331  - error: host.iobroker Caught by controller[10]:  9: 0xf1394a v8::internal::Factory::NewFillerObject(int, v8::internal::AllocationAlignment, v8::internal::AllocationType, v8::internal::AllocationOrigin) [/usr/bin/node]
              2023-11-24 21:26:29.331  - error: host.iobroker Caught by controller[11]: 10: 0x12d8caf v8::internal::Runtime_AllocateInYoungGeneration(int, unsigned long*, v8::internal::Isolate*) [/usr/bin/node]
              2023-11-24 21:26:29.331  - error: host.iobroker Caught by controller[12]: 11: 0x1705b39  [/usr/bin/node]
              2023-11-24 21:26:29.331  - warn: host.iobroker instance system.adapter.trashschedule.0 terminated due to SIGABRT
              2023-11-24 21:26:48.283  - warn: hass.0 (7464) State "hass.0.entities.device_tracker.s21_von_espe_2.connected_to" has no existing object, this might lead to an error in future versions
              2023-11-24 21:26:48.283  - warn: hass.0 (7464) State "hass.0.entities.device_tracker.s21_von_espe_2.connection_type" has no existing object, this might lead to an error in future versions
              2023-11-24 21:26:48.283  - warn: hass.0 (7464) State "hass.0.entities.device_tracker.s21_von_espe_2.ssid" has no existing object, this might lead to an error in future versions
              • Nicoloma
                Nicoloma @Nicoloma last edited by
                @Thomas-Braun Hallo, hast du eine Idee?
                  @nicoloma
                  Nein
                  • Nicoloma
                    Hallo Jungs und Mädels,
                    ich habe immer noch das gleiche Problem.
                    Kann bitte mir einer versuchen nochmal zu helfen. Mein Web adapter bzw VIS funktioniert nicht. Er zeigt keine fehlermeldung im Log an aber ich kann es nicht aufrufen.
                    Ich wäre euch sehr verbunden
                    Skript v.2023-10-25
                    *** BASE SYSTEM ***
                             Chassis: container
                      Virtualization: lxc
                              Kernel: Linux 6.5.11-7-pve
                    Docker          : false
                    Kernel          : x86_64
                    Userland        : amd64
                     11:43:02 up 21:41,  1 user,  load average: 2.66, 3.07, 2.94
                    CPU threads: 4
                                   Local time: Wed 2024-01-03 11:43:02 CET
                               Universal time: Wed 2024-01-03 10:43:02 UTC
                                     RTC time: n/a
                              RTC in local TZ: no
                    nicolo
                    /home/nicolo
                    nicolo sudo iobroker
                    X-Server:       false
                    Desktop:
                    Terminal:       tty
                    *** MEMORY ***
                    Mem:            8.0G        4.5G        3.1G        0.0K        336M        3.5G
                    Swap:           100M         99M        0.0K
                    Total:          8.1G        4.6G        3.1G
                             8000 M total memory
                             4543 M used memory
                             1839 M active memory
                             2869 M inactive memory
                             3119 M free memory
                                0 M buffer memory
                              337 M swap cache
                              100 M total swap
                               99 M used swap
                                0 M free swap
                    3 loaded units listed.
                    *** FILESYSTEM ***
                    /dev/mapper/Save-vm--103--disk--1 ext4       39G   15G   23G  40% /
                    efivarfs                          efivarfs  128K   72K   52K  59% /sys/firmware/efi/efivars
                    tmpfs                             tmpfs     3.1G  1.6M  3.1G   1% /run
                    Check not possible in LXC or Docker
                    Show mounted filesystems:
                    /                                             /dev/mapper/Save-vm--103--disk--1 ext4        rw,relatime,stripe=16
                    |-/run                                        tmpfs                             tmpfs       rw,nosuid,nodev,size=3246552k,nr_inodes=819200,mode=755,uid=100000,gid=100000,inode64
                    | |-/run/lock                                 tmpfs                             tmpfs       rw,nosuid,nodev,noexec,relatime,size=5120k,uid=100000,gid=100000,inode64
                    | |-/run/credentials/systemd-sysusers.service ramfs                             ramfs       ro,nosuid,nodev,noexec,relatime,mode=700
                    | `-/run/user/1002                            tmpfs                             tmpfs       rw,nosuid,nodev,relatime,size=1623276k,nr_inodes=405819,mode=700,uid=101002,gid=101002,inode64
                    |-/dev                                        none                              tmpfs       rw,relatime,size=492k,mode=755,uid=100000,gid=100000,inode64
                    | |-/dev/shm                                  tmpfs                             tmpfs       rw,nosuid,nodev,uid=100000,gid=100000,inode64
                    | |-/dev/mqueue                               mqueue                            mqueue      rw,relatime
                    | |-/dev/ttyACM0                              udev[/ttyACM0]                    devtmpfs    rw,nosuid,relatime,size=8082704k,nr_inodes=2020676,mode=755,inode64
                    | |-/dev/.lxc/proc                            proc                              proc        rw,relatime
                    | |-/dev/.lxc/sys                             sys                               sysfs       rw,relatime
                    | |-/dev/full                                 udev[/full]                       devtmpfs    rw,nosuid,relatime,size=8082704k,nr_inodes=2020676,mode=755,inode64
                    | |-/dev/null                                 udev[/null]                       devtmpfs    rw,nosuid,relatime,size=8082704k,nr_inodes=2020676,mode=755,inode64
                    | |-/dev/random                               udev[/random]                     devtmpfs    rw,nosuid,relatime,size=8082704k,nr_inodes=2020676,mode=755,inode64
                    | |-/dev/tty                                  udev[/tty]                        devtmpfs    rw,nosuid,relatime,size=8082704k,nr_inodes=2020676,mode=755,inode64
                    | |-/dev/urandom                              udev[/urandom]                    devtmpfs    rw,nosuid,relatime,size=8082704k,nr_inodes=2020676,mode=755,inode64
                    | |-/dev/zero                                 udev[/zero]                       devtmpfs    rw,nosuid,relatime,size=8082704k,nr_inodes=2020676,mode=755,inode64
                    | |-/dev/pts                                  devpts                            devpts      rw,nosuid,noexec,relatime,gid=100005,mode=620,ptmxmode=666,max=1026
                    | |-/dev/ptmx                                 devpts[/ptmx]                     devpts      rw,nosuid,noexec,relatime,gid=100005,mode=620,ptmxmode=666,max=1026
                    | |-/dev/console                              devpts[/0]                        devpts      rw,nosuid,noexec,relatime,gid=100005,mode=620,ptmxmode=666,max=1026
                    | |-/dev/tty1                                 devpts[/1]                        devpts      rw,nosuid,noexec,relatime,gid=100005,mode=620,ptmxmode=666,max=1026
                    | `-/dev/tty2                                 devpts[/2]                        devpts      rw,nosuid,noexec,relatime,gid=100005,mode=620,ptmxmode=666,max=1026
                    |-/proc                                       proc                              proc        rw,nosuid,nodev,noexec,relatime
                    | |-/proc/sys                                 proc[/sys]                        proc        ro,relatime
                    | | |-/proc/sys/net                           proc[/sys/net]                    proc        rw,nosuid,nodev,noexec,relatime
                    | | |-/proc/sys/fs/binfmt_misc                binfmt_misc                       binfmt_misc rw,nosuid,nodev,noexec,relatime
                    | | `-/proc/sys/kernel/random/boot_id         none[/.lxc-boot-id]               tmpfs       ro,nosuid,nodev,noexec,relatime,size=492k,mode=755,uid=100000,gid=100000,inode64
                    | |-/proc/sysrq-trigger                       proc[/sysrq-trigger]              proc        ro,relatime
                    | |-/proc/cpuinfo                             lxcfs[/proc/cpuinfo]              fuse.lxcfs  rw,nosuid,nodev,relatime,user_id=0,group_id=0,allow_other
                    | |-/proc/diskstats                           lxcfs[/proc/diskstats]            fuse.lxcfs  rw,nosuid,nodev,relatime,user_id=0,group_id=0,allow_other
                    | |-/proc/loadavg                             lxcfs[/proc/loadavg]              fuse.lxcfs  rw,nosuid,nodev,relatime,user_id=0,group_id=0,allow_other
                    | |-/proc/meminfo                             lxcfs[/proc/meminfo]              fuse.lxcfs  rw,nosuid,nodev,relatime,user_id=0,group_id=0,allow_other
                    | |-/proc/slabinfo                            lxcfs[/proc/slabinfo]             fuse.lxcfs  rw,nosuid,nodev,relatime,user_id=0,group_id=0,allow_other
                    | |-/proc/stat                                lxcfs[/proc/stat]                 fuse.lxcfs  rw,nosuid,nodev,relatime,user_id=0,group_id=0,allow_other
                    | |-/proc/swaps                               lxcfs[/proc/swaps]                fuse.lxcfs  rw,nosuid,nodev,relatime,user_id=0,group_id=0,allow_other
                    | `-/proc/uptime                              lxcfs[/proc/uptime]               fuse.lxcfs  rw,nosuid,nodev,relatime,user_id=0,group_id=0,allow_other
                    `-/sys                                        sysfs                             sysfs       ro,nosuid,nodev,noexec,relatime
                      |-/sys/fs/fuse/connections                  fusectl                           fusectl     rw,nosuid,nodev,noexec,relatime
                      |-/sys/devices/virtual/net                  sysfs[/devices/virtual/net]       sysfs       rw,nosuid,nodev,noexec,relatime
                      |-/sys/kernel/debug                         debugfs                           debugfs     rw,nosuid,nodev,noexec,relatime
                      |-/sys/kernel/security                      securityfs                        securityfs  rw,nosuid,nodev,noexec,relatime
                      |-/sys/fs/pstore                            pstore                            pstore      rw,nosuid,nodev,noexec,relatime
                      |-/sys/firmware/efi/efivars                 efivarfs                          efivarfs    rw,nosuid,nodev,noexec,relatime
                      |-/sys/fs/cgroup                            none                              cgroup2     rw,nosuid,nodev,noexec,relatime
                      `-/sys/devices/system/cpu                   lxcfs[/sys/devices/system/cpu]    fuse.lxcfs  rw,nosuid,nodev,relatime,user_id=0,group_id=0,allow_other
                    /var:
                    6.9G    /var/
                    4.5G    /var/lib
                    3.8G    /var/lib/influxdb/data
                    3.3G    /var/lib/influxdb/data/iobroker
                    Archived and active journals take up 24.0M in the file system.
                    83M     /opt/iobroker/backups/
                    747M    /opt/iobroker/iobroker-data/
                    588M    /opt/iobroker/iobroker-data/files
                    126M    /opt/iobroker/iobroker-data/files/vis-2
                    105M    /opt/iobroker/iobroker-data/backup-objects
                    90M     /opt/iobroker/iobroker-data/files/echarts.admin
                    48M     /opt/iobroker/iobroker-data/objects.jsonl
                    35M     /opt/iobroker/iobroker-data/files/devices.admin/static/js/main.24f2bb56.js.map
                    33M     /opt/iobroker/iobroker-data/files/iot.admin/static/js/main.1797d034.js.map
                    24M     /opt/iobroker/iobroker-data/files/echarts/static/js/main.5f66c5d9.js.map
                    24M     /opt/iobroker/iobroker-data/files/echarts.admin/static/js/main.9f2a6569.js.map
                    USB-Devices by-id:
                    /dev/serial/by-id/usb-ITEAD_SONOFF_Zigbee_3.0_USB_Dongle_Plus_V2_20220810141742-if00
                    /usr/bin/nodejs         v18.19.0
                    /usr/bin/node           v18.19.0
                    /usr/bin/npm            10.2.3
                    /usr/bin/npx            10.2.3
                    /usr/bin/corepack       0.22.0
                    nodejs:
                      Installed: 18.19.0-1nodesource1
                      Candidate: 18.19.0-1nodesource1
                      Version table:
                     *** 18.19.0-1nodesource1 1001
                    Errors in npm tree:
                    ioBroker Status
                    Objects type: jsonl
                    States  type: jsonl
                    js-controller:  5.0.17
                    admin:          6.12.0
                    javascript:     7.1.6
                    Adapters from github:   5
                    Adapter State
                    + system.adapter.admin.0                  : admin                 : iobroker                                 -  enabled, port: 8081, bind: 192.168.178.103, run as: admin
                    + system.adapter.alexa2.0                 : alexa2                : iobroker                                 -  enabled
                    + system.adapter.backitup.0               : backitup              : iobroker                                 -  enabled
                      system.adapter.energiefluss.0           : energiefluss          : iobroker                                 - disabled
                      system.adapter.hass.0                   : hass                  : iobroker                                 - disabled, port: 8123
                    + system.adapter.iot.0                    : iot                   : iobroker                                 -  enabled
                      system.adapter.lgtv.0                   : lgtv                  : iobroker                                 - disabled
                      system.adapter.onvif.0                  : onvif                 : iobroker                                 - disabled, port: 80, 7575, 8000, 8080, 8081, 8899
                    + system.adapter.proxmox.0                : proxmox               : iobroker                                 -  enabled, port: 8006
                    + system.adapter.sonoff.0                 : sonoff                : iobroker                                 -  enabled, port: 1880, bind: 192.168.178.103
                    + system.adapter.tr-064.0                 : tr-064                : iobroker                                 -  enabled
                    + system.adapter.vis-2.0                  : vis-2                 : iobroker                                 -  enabled
                    + system.adapter.web.0                    : web                   : iobroker                                 -  enabled, port: 8082, bind: 0.0.0.0, run as: admin
                    + instance is alive
                    Adapter    "accuweather"  : 1.3.2    , installed 1.3.2
                    Adapter    "acme"         : 0.1.2    , installed 0.1.2
                    Adapter    "alexa2"       : 3.26.3   , installed 3.26.3
                    Adapter    "backitup"     : 2.9.8    , installed 2.9.8
                    Adapter    "daswetter"    : 3.1.11   , installed 3.1.11
                    Adapter    "javascript"   : 7.1.6    , installed 7.1.6
                    Controller "js-controller": 5.0.17   , installed 5.0.17
                    Adapter    "mbus"         : 2.6.1    , installed 2.6.1
                    Adapter    "meross"       : 1.16.1   , installed 1.16.1
                    Adapter    "modbus"       : 6.0.1    , installed 6.0.1
                    Adapter    "proxmox"      : 2.2.2    , installed 2.2.2
                    Adapter    "radar2"       : 2.1.0    , installed 2.1.0
                    Adapter    "smartmeter"   : 3.4.0    , installed 3.4.0
                    Adapter    "statistics"   : 2.4.0    , installed 2.4.0
                    Adapter    "telegram"     : 3.0.1    , installed 3.0.1
                    Adapter    "tuya"         : 3.15.0   , installed 3.15.0
                    Adapter    "welcome"      : 0.1.0    , installed 0.1.0
                    Adapter    "zigbee"       : 1.9.5    , installed 1.9.5
                    Objects and States
                    Objects:        23550
                    States:         19971
                    Hit:1 https://repos.influxdata.com/debian stable InRelease
                    Hit:2 https://packages.grafana.com/oss/deb stable InRelease
                    Hit:3 https://deb.nodesource.com/node_18.x nodistro InRelease
                    Hit:4 http://archive.ubuntu.com/ubuntu jammy InRelease
                    Hit:5 http://archive.ubuntu.com/ubuntu jammy-updates InRelease
                    Hit:6 http://archive.ubuntu.com/ubuntu jammy-security InRelease
                    Pending Updates: 0
                    Netid                  State                   Recv-Q                   Send-Q                                       Local Address:Port                                      Peer Address:Port                  Process
                    udp                    UNCONN                  0                        0                                                  0.0.0.0:6666                                           0.0.0.0:*                      users:(("io.tuya.0",pid=894,fd=41))
                    udp                    UNCONN                  0                        0                                                  0.0.0.0:6667                                           0.0.0.0:*                      users:(("io.tuya.0",pid=894,fd=42))
                    udp                    UNCONN                  0                        0                                            127.0.0.53%lo:53                                             0.0.0.0:*                      users:(("systemd-resolve",pid=157,fd=13))
                    udp                    UNCONN                  0                        0                                                  0.0.0.0:111                                            0.0.0.0:*                      users:(("rpcbind",pid=156,fd=5),("systemd",pid=1,fd=28))
                    udp                    UNCONN                  0                        0                                          192.168.178.255:137                                            0.0.0.0:*                      users:(("nmbd",pid=281,fd=16))
                    udp                    UNCONN                  0                        0                                          192.168.178.103:137                                            0.0.0.0:*                      users:(("nmbd",pid=281,fd=15))
                    udp                    UNCONN                  0                        0                                                  0.0.0.0:137                                            0.0.0.0:*                      users:(("nmbd",pid=281,fd=13))
                    udp                    UNCONN                  0                        0                                          192.168.178.255:138                                            0.0.0.0:*                      users:(("nmbd",pid=281,fd=18))
                    udp                    UNCONN                  0                        0                                          192.168.178.103:138                                            0.0.0.0:*                      users:(("nmbd",pid=281,fd=17))
                    udp                    UNCONN                  0                        0                                                  0.0.0.0:138                                            0.0.0.0:*                      users:(("nmbd",pid=281,fd=14))
                    udp                    UNCONN                  0                        0                                                  0.0.0.0:10000                                          0.0.0.0:*                      users:(("miniserv.pl",pid=541,fd=6))
                    udp                    UNCONN                  0                        0                                                     [::]:111                                               [::]:*                      users:(("rpcbind",pid=156,fd=7),("systemd",pid=1,fd=30))
                    tcp                    LISTEN                  0                        511                                        192.168.178.103:8081                                           0.0.0.0:*                      users:(("io.admin.0",pid=257225,fd=29))
                    tcp                    LISTEN                  0                        100                                              127.0.0.1:25                                             0.0.0.0:*                      users:(("master",pid=459,fd=13))
                    tcp                    LISTEN                  0                        100                                              127.0.0.1:1883                                           0.0.0.0:*                      users:(("mosquitto",pid=192,fd=5))
                    tcp                    LISTEN                  0                        4096                                               0.0.0.0:10000                                          0.0.0.0:*                      users:(("miniserv.pl",pid=541,fd=5))
                    tcp                    LISTEN                  0                        511                                              127.0.0.1:43317                                          0.0.0.0:*                      users:(("plugin_start_li",pid=744,fd=19))
                    tcp                    LISTEN                  0                        50                                                 0.0.0.0:445                                            0.0.0.0:*                      users:(("smbd",pid=477,fd=46))
                    tcp                    LISTEN                  0                        4096                                         127.0.0.53%lo:53                                             0.0.0.0:*                      users:(("systemd-resolve",pid=157,fd=14))
                    tcp                    LISTEN                  0                        4096                                               0.0.0.0:111                                            0.0.0.0:*                      users:(("rpcbind",pid=156,fd=4),("systemd",pid=1,fd=27))
                    tcp                    LISTEN                  0                        50                                                 0.0.0.0:139                                            0.0.0.0:*                      users:(("smbd",pid=477,fd=47))
                    tcp                    LISTEN                  0                        511                                                0.0.0.0:9001                                           0.0.0.0:*                      users:(("iobroker.js-con",pid=602,fd=21))
                    tcp                    LISTEN                  0                        511                                                0.0.0.0:9000                                           0.0.0.0:*                      users:(("iobroker.js-con",pid=602,fd=27))
                    tcp                    LISTEN                  0                        511                                        192.168.178.103:1887                                           0.0.0.0:*                      users:(("io.shelly.0",pid=846,fd=32))
                    tcp                    LISTEN                  0                        511                                        192.168.178.103:1884                                           0.0.0.0:*                      users:(("io.mqtt.0",pid=791,fd=29))
                    tcp                    LISTEN                  0                        511                                        192.168.178.103:1885                                           0.0.0.0:*                      users:(("io.mqtt.0",pid=791,fd=30))
                    tcp                    LISTEN                  0                        511                                        192.168.178.103:1880                                           0.0.0.0:*                      users:(("io.sonoff.0",pid=864,fd=34))
                    tcp                    LISTEN                  0                        4096                                             127.0.0.1:8088                                           0.0.0.0:*                      users:(("influxd",pid=330,fd=3))
                    tcp                    LISTEN                  0                        4096                                             127.0.0.1:8080                                           0.0.0.0:*                      users:(("motion",pid=190,fd=7))
                    tcp                    LISTEN                  0                        4096                                             127.0.0.1:8081                                           0.0.0.0:*                      users:(("motion",pid=190,fd=5))
                    tcp                    LISTEN                  0                        4096                                                     *:3000                                                 *:*                      users:(("grafana",pid=601,fd=9))
                    tcp                    LISTEN                  0                        50                                                    [::]:445                                               [::]:*                      users:(("smbd",pid=477,fd=44))
                    tcp                    LISTEN                  0                        4096                                                     *:22                                                   *:*                      users:(("systemd",pid=1,fd=43))
                    tcp                    LISTEN                  0                        4096                                                  [::]:111                                               [::]:*                      users:(("rpcbind",pid=156,fd=6),("systemd",pid=1,fd=29))
                    tcp                    LISTEN                  0                        50                                                    [::]:139                                               [::]:*                      users:(("smbd",pid=477,fd=45))
                    tcp                    LISTEN                  0                        511                                                      *:8082                                                 *:*                      users:(("io.web.0",pid=8598,fd=28))
                    tcp                    LISTEN                  0                        4096                                                     *:8086                                                 *:*                      users:(("influxd",pid=330,fd=179))
                    tcp                    LISTEN                  0                        100                                                  [::1]:1883                                              [::]:*                      users:(("mosquitto",pid=192,fd=6))
                    tcp                    LISTEN                  0                        100                                                  [::1]:25                                                [::]:*                      users:(("master",pid=459,fd=14))
                    2024-01-03 11:43:25.443  - error: host.iobroker Caught by controller[15]: 14: 0xd8c7f9 v8::ScriptCompiler::CompileFunctionInternal(v8::Local<v8::Context>, v8::ScriptCompiler::Source*, unsigned long, v8::Local<v8::String>*, unsigned long, v8::Local<v8::Object>*, v8::ScriptCompiler::CompileOptions, v8::ScriptCompiler::NoCacheReason, v8::Local<v8::ScriptOrModule>*) [/usr/bin/node]
                    2024-01-03 11:43:25.443  - error: host.iobroker Caught by controller[16]: 15: 0xd8cbc7 v8::ScriptCompiler::CompileFunction(v8::Local<v8::Context>, v8::ScriptCompiler::Source*, unsigned long, v8::Local<v8::String>*, unsigned long, v8::Local<v8::Object>*, v8::ScriptCompiler::CompileOptions, v8::ScriptCompiler::NoCacheReason) [/usr/bin/node]
                    2024-01-03 11:43:25.443  - error: host.iobroker Caught by controller[17]: 16: 0xb875f8 node::contextify::ContextifyContext::CompileFunction(v8::FunctionCallbackInfo<v8::Value> const&) [/usr/bin/node]
                    2024-01-03 11:43:25.443  - error: host.iobroker Caught by controller[18]: 17: 0xdcd3e0  [/usr/bin/node]
                    2024-01-03 11:43:25.443  - error: host.iobroker Caught by controller[19]: 18: 0xdce91f v8::internal::Builtin_HandleApiCall(int, unsigned long*, v8::internal::Isolate*) [/usr/bin/node]
                    2024-01-03 11:43:25.443  - error: host.iobroker Caught by controller[20]: 19: 0x170dfb9  [/usr/bin/node]
                    2024-01-03 11:43:25.443  - warn: host.iobroker instance system.adapter.trashschedule.0 terminated due to SIGABRT
                    2024-01-03 11:43:38.840  - error: host.iobroker cannot call visUtils: Not exists
                    2024-01-03 11:43:38.842  - error: host.iobroker cannot call visUtils: Not exists
                    2024-01-03 11:43:56.508  - error: host.iobroker Caught by controller[0]: <--- Last few GCs --->
                    2024-01-03 11:43:56.508  - error: host.iobroker Caught by controller[0]: n [262346:0x64c0870]      883 ms: Mark-sweep (reduce) 18.9 (21.0) -> 18.3 (21.3) MB, 2.9 / 0.0 ms  (+ 1.0 ms in 10 steps since start of marking, biggest step 0.2 ms, walltime since start of marking 16 ms) (average mu = 0.669, current mu = 0.768) finalize in[262346:0x64c0870]      902 ms: Mark-sweep (reduce) 19.1 (21.6) -> 18.6 (21.6) MB, 6.2 / 0.0 ms  (+ 0.2 ms in 4 steps since start of marking, biggest step 0.1 ms, walltime since start of marking 17 ms) (average mu = 0.669, current mu = 0.669) finalize inc
                    2024-01-03 11:43:56.508  - error: host.iobroker Caught by controller[0]: <--- JS stacktrace --->
                    2024-01-03 11:43:56.508  - error: host.iobroker Caught by controller[0]: FATAL ERROR: Reached heap limit Allocation failed - JavaScript heap out of memory
                    2024-01-03 11:43:56.508  - error: host.iobroker Caught by controller[1]:  1: 0xb95b60 node::Abort() [/usr/bin/node]
                    2024-01-03 11:43:56.509  - error: host.iobroker Caught by controller[2]:  2: 0xa9a7f8  [/usr/bin/node]
                    2024-01-03 11:43:56.509  - error: host.iobroker Caught by controller[3]:  3: 0xd6f2f0 v8::Utils::ReportOOMFailure(v8::internal::Isolate*, char const*, bool) [/usr/bin/node]
                    2024-01-03 11:43:56.509  - error: host.iobroker Caught by controller[4]:  4: 0xd6f697 v8::internal::V8::FatalProcessOutOfMemory(v8::internal::Isolate*, char const*, bool) [/usr/bin/node]
                    2024-01-03 11:43:56.509  - error: host.iobroker Caught by controller[5]:  5: 0xf4cba5  [/usr/bin/node]
                    2024-01-03 11:43:56.509  - error: host.iobroker Caught by controller[6]:  6: 0xf5f08d v8::internal::Heap::CollectGarbage(v8::internal::AllocationSpace, v8::internal::GarbageCollectionReason, v8::GCCallbackFlags) [/usr/bin/node]
                    2024-01-03 11:43:56.509  - error: host.iobroker Caught by controller[7]:  7: 0xf61ff5 v8::internal::Heap::HandleGCRequest() [/usr/bin/node]
                    2024-01-03 11:43:56.509  - error: host.iobroker Caught by controller[8]:  8: 0xee014f v8::internal::StackGuard::HandleInterrupts() [/usr/bin/node]
                    2024-01-03 11:43:56.509  - error: host.iobroker Caught by controller[9]:  9: 0x12e0a65 v8::internal::Runtime_StackGuard(int, unsigned long*, v8::internal::Isolate*) [/usr/bin/node]
                    2024-01-03 11:43:56.509  - error: host.iobroker Caught by controller[10]: 10: 0x170deb9  [/usr/bin/node]
                    2024-01-03 11:43:56.509  - warn: host.iobroker instance system.adapter.trashschedule.0 terminated due to SIGABRT
                    2024-01-03 11:43:57.345  - info: iot.0 (8971) Connection changed: disconnect
                    iob diag has finished.
                                            v.2023-10-25
                             Chassis: container
                      Virtualization: lxc
                    Installation:           lxc
                    Kernel:                 x86_64
                    Userland:               amd64
                    User-ID:                1002
                    X-Server:               false
                    Pending iob updates:    0
                    Nodejs-Installation:    /usr/bin/nodejs         v18.19.0
                                            /usr/bin/npm            10.2.3
                                            /usr/bin/npx            10.2.3
                    Recommended versions are nodejs 18.19.0 and npm 10.2.3
                    MEMORY:
                    Mem:            8.0G        4.5G        2.8G        0.0K        707M        3.5G
                    Swap:           100M         99M        0.0K
                    Total:          8.1G        4.6G        2.8G
                    Active iob-Instances:   33
                    ioBroker Core:          js-controller           5.0.17
                                            admin                   6.12.0
                    Objects type: jsonl
                    States  type: jsonl
                    Objects:                23550
                    States:                 19971
                    56M     /opt/iobroker/iobroker-data/objects.jsonl
                    10M     /opt/iobroker/iobroker-data/states.jsonl
                      arteck Developer Most Active @Nicoloma last edited by
                      @nicoloma
                      gesehen..bestimmt nicht..
                      da läuft in deinen Javscripten was schief
                      Nicoloma 2 Replies Last reply Reply Quote 0
                      • Nicoloma
                        Nicoloma @arteck last edited by
                        @arteck doch, ich habe den den Adapter sogar schon komplett deaktiviert, die Meldung bleibt gleich.
                        • Nicoloma
                          Nicoloma @arteck last edited by Nicoloma
                          @arteck
                          host.iobroker
                          2024-01-03 12:15:34.137	warn	instance system.adapter.trashschedule.0 terminated due to SIGABRT
                          host.iobroker
                          2024-01-03 12:15:34.137	error	Caught by controller[11]: 10: 0x170deb9 [/usr/bin/node]
                          host.iobroker
                          2024-01-03 12:15:34.137	error	Caught by controller[10]: 9: 0x12e0bcf v8::internal::Runtime_StackGuardWithGap(int, unsigned long*, v8::internal::Isolate*) [/usr/bin/node]
                          host.iobroker
                          2024-01-03 12:15:34.137	error	Caught by controller[9]: 8: 0xee014f v8::internal::StackGuard::HandleInterrupts() [/usr/bin/node]
                          host.iobroker
                          2024-01-03 12:15:34.137	error	Caught by controller[8]: 7: 0xf61ff5 v8::internal::Heap::HandleGCRequest() [/usr/bin/node]
                          host.iobroker
                          2024-01-03 12:15:34.137	error	Caught by controller[7]: 6: 0xf5f08d v8::internal::Heap::CollectGarbage(v8::internal::AllocationSpace, v8::internal::GarbageCollectionReason, v8::GCCallbackFlags) [/usr/bin/node]
                          host.iobroker
                          2024-01-03 12:15:34.137	error	Caught by controller[6]: 5: 0xf4cba5 [/usr/bin/node]
                          host.iobroker
                          2024-01-03 12:15:34.137	error	Caught by controller[5]: 4: 0xd6f697 v8::internal::V8::FatalProcessOutOfMemory(v8::internal::Isolate*, char const*, bool) [/usr/bin/node]
                          host.iobroker
                          2024-01-03 12:15:34.137	error	Caught by controller[4]: 3: 0xd6f2f0 v8::Utils::ReportOOMFailure(v8::internal::Isolate*, char const*, bool) [/usr/bin/node]
                          host.iobroker
                          2024-01-03 12:15:34.137	error	Caught by controller[3]: 2: 0xa9a7f8 [/usr/bin/node]
                          host.iobroker
                          2024-01-03 12:15:34.137	error	Caught by controller[2]: 1: 0xb95b60 node::Abort() [/usr/bin/node]
                          host.iobroker
                          2024-01-03 12:15:34.137	error	Caught by controller[1]: FATAL ERROR: Reached heap limit Allocation failed - JavaScript heap out of memory
                          host.iobroker
                          2024-01-03 12:15:34.137	error	Caught by controller[1]: <--- JS stacktrace --->
                          host.iobroker
                          2024-01-03 12:15:34.137	error	Caught by controller[0]: nc[269268:0x6440870] 24816 ms: Mark-sweep (reduce) 18.9 (21.3) -> 18.7 (21.3) MB, 6.7 / 0.0 ms (+ 0.1 ms in 2 steps since start of marking, biggest step 0.1 ms, walltime since start of marking 52 ms) (average mu = 0.937, current mu = 0.874) finalize inc[269268:0x6440870] 24903 ms: Mark-sweep (reduce) 19.0 (21.3) -> 18.8 (21.6) MB, 5.9 / 0.0 ms (+ 0.1 ms in 2 steps since start of marking, biggest step 0.0 ms, walltime since start of marking 86 ms) (average mu = 0.934, current mu = 0.931) finalize inc
                          host.iobroker
                          2024-01-03 12:15:34.137	error	Caught by controller[0]: <--- Last few GCs --->
                          javascript.0
                          2024-01-03 12:15:03.964	info	terminating
                          javascript.0
                          2024-01-03 12:15:03.469	info	Terminated (ADAPTER_REQUESTED_TERMINATION): Without reason
                          javascript.0
                          2024-01-03 12:15:03.468	info	terminating
                          javascript.0
                          2024-01-03 12:15:03.467	info	Stop script script.js.common.Heizung.PV-Heizstab_aktiv
                          javascript.0
                          2024-01-03 12:15:03.467	info	Stop script script.js.common.Heizung.Fußboden
                          javascript.0
                          2024-01-03 12:15:03.467	info	Stop script script.js.common.PV.aquarium_per_pv
                          javascript.0
                          2024-01-03 12:15:03.467	info	Stop script script.js.common.telegramm1
                          javascript.0
                          2024-01-03 12:15:03.467	info	Stop script script.js.common.nullsteller
                          javascript.0
                          2024-01-03 12:15:03.467	info	Stop script script.js.common.PV.überschuss1_b
                          javascript.0
                          2024-01-03 12:15:03.466	info	Stop script script.js.common.Ordner_1.Spreiz_OG
                          javascript.0
                          2024-01-03 12:15:03.466	info	Stop script script.js.common.Ordner_1.Spreiz_Fb
                          javascript.0
                          2024-01-03 12:15:03.466	info	Stop script script.js.common.Gas.gaszahler
                          javascript.0
                          2024-01-03 12:15:03.466	info	Stop script script.js.common.Gas.gasslbst
                          javascript.0
                          2024-01-03 12:15:03.466	info	Stop script script.js.common.Gas.gaskhwverbrauch
                          javascript.0
                          2024-01-03 12:15:03.466	info	Stop script script.js.common.Gas.Gas_kwheuro
                          javascript.0
                          2024-01-03 12:15:03.466	info	Stop script script.js.common.Alexa.Müllrausbringen
                          javascript.0
                          2024-01-03 12:15:03.465	info	Stop script script.js.Skript_1ss
                          javascript.0
                          2024-01-03 12:15:03.463	info	Got terminate signal TERMINATE_YOURSELF
                          • Nicoloma
                            LÖSUNG: DOWNGRADE VON Node.js18 auf NODE 16...
                              @nicoloma
                              Das ist keine Lösung, nodejs@16 ist im Upstream abgekündigt.
                              • Nicoloma
                                @thomas-braun Ja, aber ich kann es nicht lösen und keiner von euch weiß weiter.
                                • Nicoloma
                                  War doch keine lösung habe wieder auf 18 upgedatet!
                                    @nicoloma setzt die kiste mal neu auf...
                                    wechsel auf debian.. probeweise..warum auch immer
                                      Thomas Braun Most Active @arteck last edited by
                                      @arteck sagte in Error Log Controller Iobroker:
                                      Den exakt gleichen Gedanken hatte ich auch! 🙂
                                      • Nicoloma
                                        Kann man mit den Fehlermeldungen den nichts anfangen?
                                        host.iobroker
                                        2024-01-04 10:36:18.491	warn	instance system.adapter.trashschedule.0 terminated due to SIGABRT
                                        host.iobroker
                                        2024-01-04 10:36:18.491	error	Caught by controller[10]: 10: 0x170deb9 [/usr/bin/node]
                                        host.iobroker
                                        2024-01-04 10:36:18.491	error	Caught by controller[9]: 9: 0x12e0a65 v8::internal::Runtime_StackGuard(int, unsigned long*, v8::internal::Isolate*) [/usr/bin/node]
                                        host.iobroker
                                        2024-01-04 10:36:18.491	error	Caught by controller[8]: 8: 0xee014f v8::internal::StackGuard::HandleInterrupts() [/usr/bin/node]
                                        host.iobroker
                                        2024-01-04 10:36:18.491	error	Caught by controller[7]: 7: 0xf61ff5 v8::internal::Heap::HandleGCRequest() [/usr/bin/node]
                                        host.iobroker
                                        2024-01-04 10:36:18.491	error	Caught by controller[6]: 6: 0xf5f08d v8::internal::Heap::CollectGarbage(v8::internal::AllocationSpace, v8::internal::GarbageCollectionReason, v8::GCCallbackFlags) [/usr/bin/node]
                                        host.iobroker
                                        2024-01-04 10:36:18.491	error	Caught by controller[5]: 5: 0xf4cba5 [/usr/bin/node]
                                        host.iobroker
                                        2024-01-04 10:36:18.491	error	Caught by controller[4]: 4: 0xd6f697 v8::internal::V8::FatalProcessOutOfMemory(v8::internal::Isolate*, char const*, bool) [/usr/bin/node]
                                        host.iobroker
                                        2024-01-04 10:36:18.491	error	Caught by controller[3]: 3: 0xd6f2f0 v8::Utils::ReportOOMFailure(v8::internal::Isolate*, char const*, bool) [/usr/bin/node]
                                        host.iobroker
                                        2024-01-04 10:36:18.491	error	Caught by controller[2]: 2: 0xa9a7f8 [/usr/bin/node]
                                        host.iobroker
                                        2024-01-04 10:36:18.491	error	Caught by controller[1]: 1: 0xb95b60 node::Abort() [/usr/bin/node]
                                        host.iobroker
                                        2024-01-04 10:36:18.491	error	Caught by controller[0]: FATAL ERROR: Reached heap limit Allocation failed - JavaScript heap out of memory
                                        host.iobroker
                                        2024-01-04 10:36:18.491	error	Caught by controller[0]: <--- JS stacktrace --->
                                        host.iobroker
                                        2024-01-04 10:36:18.490	error	Caught by controller[0]: nc[269575:0x689a870] 693 ms: Mark-sweep (reduce) 18.9 (21.3) -> 18.3 (21.3) MB, 2.9 / 0.0 ms (+ 0.4 ms in 9 steps since start of marking, biggest step 0.1 ms, walltime since start of marking 10 ms) (average mu = 0.772, current mu = 0.708) allocation f[269575:0x689a870] 714 ms: Mark-sweep (reduce) 19.7 (21.6) -> 19.1 (22.1) MB, 5.9 / 0.0 ms (+ 0.7 ms in 12 steps since start of marking, biggest step 0.1 ms, walltime since start of marking 19 ms) (average mu = 0.717, current mu = 0.681) finalize in
                                        host.iobroker
                                        2024-01-04 10:36:18.490	error	Caught by controller[0]: <--- Last few GCs --->
                                        Boah das system neu aufzusetzten ist, da stecken für mich LAIE, ewig viel Arbeit....
                                        influx.. die ganzen config.... 😕
                                          @nicoloma sagte in Error Log Controller Iobroker:
                                          Ich nicht. Ich sehe da nur, das 'irgendwas' den Speicher im Heap auffrisst.
                                          Kannst ja mal durch deine Skripte gehen.
                                          • Nicoloma
                                            Ich bin dir für jeden Vorschlag dankbar! Aber wenn ich den Javascript-Adapter stoppe sollen doch alle Skripte auch nicht mehr laufen?
                                            Oder laufen Sie vielleicht im Hintergrund weiter?
                                            1246
