    4. Sonoff Presence Sensor SNZB-06P problem
      arteck Developer Most Active @FredF last edited by arteck
      @fredf sagte in Sonoff Presence Sensor SNZB-06P problem:
      readResponse
      du bist ja schnell ..
      paar zeilen dadrüber sollte
      meta.state = { state: '' };   // for tuya
      da sein ..lösche mal die zeile... und starte adapter neu...
      kommt dann die error meldung ?? für den SNZB-06P
      • FredF
        FredF Most Active Forum Testing @arteck last edited by
        @arteck Immer noch
        2024-01-03 11:20:37.439	error	arteck: '64529' -> 'readResponse'
        2024-01-03 11:20:37.439	error	Error while processing converters DEVICE_ID: '3410f4fffee39865'
        2024-01-03 11:20:37.276	info	Configuring 0x3410f4fffee39865 SNZB-06P
        2024-01-03 11:20:35.704	error	arteck: '64529' -> 'readResponse'
        2024-01-03 11:20:35.703	error	Error while processing converters DEVICE_ID: '3410f4fffee39865'
        2024-01-03 11:20:35.299	info	debug devices set to []
          @fredf bist sicher dass du den adapter neu gestertet hast ??
          • FredF
            FredF Most Active Forum Testing @arteck last edited by FredF
            @arteck Na klar:
            2024-01-03 11:20:32.794	info	Starting Zigbee npm ...
            2024-01-03 11:20:32.792	info	delete old Backup files. keep only last 10
            2024-01-03 11:20:32.666	info	starting. Version 1.9.6 (non-npm: ioBroker/ioBroker.zigbee) in /opt/iobroker/node_modules/iobroker.zigbee, node: v18.19.0, js-controller: 5.0.17
            2024-01-03 11:20:27.249	info	instance system.adapter.zigbee.0 started with pid 1280
            2024-01-03 11:20:24.971	info	instance system.adapter.zigbee.0 terminated with code 11 (ADAPTER_REQUESTED_TERMINATION)
            2024-01-03 11:20:24.355	info	Terminated (ADAPTER_REQUESTED_TERMINATION): Without reason
            2024-01-03 11:20:24.354	info	terminating
            2024-01-03 11:20:24.113	info	stopInstance system.adapter.zigbee.0 send kill signal
            2024-01-03 11:20:24.010	info	Zigbee: disabling joining new devices.
            2024-01-03 11:20:23.854	info	cleaned everything up...
            2024-01-03 11:20:23.853	info	Got terminate signal TERMINATE_YOURSELF
            2024-01-03 11:20:23.849	info	stopInstance system.adapter.zigbee.0 (force=false, process=true)
            Aber zur Sicherheit nchmal gestartet:
            2024-01-03 11:26:19.969	error	arteck: '64529' -> 'readResponse'
            2024-01-03 11:26:19.969	error	Error while processing converters DEVICE_ID: '3410f4fffee39865'
            2024-01-03 11:26:19.587	info	Configuring 0x3410f4fffee39865 SNZB-06P
            2024-01-03 11:26:18.333	error	arteck: '64529' -> 'readResponse'
            2024-01-03 11:26:18.332	error	Error while processing converters DEVICE_ID: '3410f4fffee39865'
            2024-01-03 11:26:17.644	info	debug devices set to []
              @fredf ok warte gleich kommt ne GIT version
              @fredf installier mal von git
              • FredF
                @arteck Nur beim Adapter Start kommt das, dann nix mehr.
                2024-01-03 12:05:48.223	error	Error while processing converters DEVICE_ID: '3410f4fffee39865' cluster '64529' type 'readResponse'
                2024-01-03 12:05:48.041	info	Configuring 0x3410f4fffee39865 SNZB-06P
                2024-01-03 12:05:46.604	error	Error while processing converters DEVICE_ID: '3410f4fffee39865' cluster '64529' type 'readResponse'
                2024-01-03 12:05:46.120	info	debug devices set to []
                  @fredf sehr gut..
                  arteck 1 Reply Last reply Reply Quote 1
                    arteck Developer Most Active @arteck last edited by arteck
                    @arteck schaumal bitte noch
                    editiere
                    /opt/iobroker/node_modules/iobroker.zigbee/lib/zbDeviceConfigure.js
                    ganz unten zeile 144
                    // do nothing ignore it
                    ersetze diese durch
                    return true;
                    adapter neu starten
                    • FredF
                      @arteck zu früh gefreut, die Fehlermeldungen kommen weiter
                      2024-01-03 12:24:39.133	error	Error while processing converters DEVICE_ID: '3410f4fffee39865' cluster '64529' type 'readResponse'
                      2024-01-03 12:24:39.005	info	Configuring 0x3410f4fffee39865 SNZB-06P
                      2024-01-03 12:24:36.189	error	Error while processing converters DEVICE_ID: '3410f4fffee39865' cluster '64529' type 'readResponse'
                      2024-01-03 12:24:36.026	info	Configuring 0x3410f4fffee39865 SNZB-06P
                      2024-01-03 12:24:33.198	error	Error while processing converters DEVICE_ID: '3410f4fffee39865' cluster '64529' type 'readResponse'
                      2024-01-03 12:24:33.053	info	Configuring 0x3410f4fffee39865 SNZB-06P
                      2024-01-03 12:24:30.203	error	Error while processing converters DEVICE_ID: '3410f4fffee39865' cluster '64529' type 'readResponse'
                      2024-01-03 12:24:30.059	info	Configuring 0x3410f4fffee39865 SNZB-06P
                      2024-01-03 12:24:27.237	error	Error while processing converters DEVICE_ID: '3410f4fffee39865' cluster '64529' type 'readResponse'
                      2024-01-03 12:24:27.086	info	Configuring 0x3410f4fffee39865 SNZB-06P
                      2024-01-03 12:14:30.861	info	Device '0xec1bbdfffea30275' announced itself
                      2024-01-03 12:14:25.910	error	Error while processing converters DEVICE_ID: '3410f4fffee39865' cluster '64529' type 'readResponse'
                      2024-01-03 12:14:25.690	info	Configuring 0x3410f4fffee39865 SNZB-06P
                      2024-01-03 12:14:22.929	error	Error while processing converters DEVICE_ID: '3410f4fffee39865' cluster '64529' type 'readResponse'
                      2024-01-03 12:14:22.716	info	Configuring 0x3410f4fffee39865 SNZB-06P
                      2024-01-03 12:14:19.951	error	Error while processing converters DEVICE_ID: '3410f4fffee39865' cluster '64529' type 'readResponse'
                      2024-01-03 12:14:19.730	info	Configuring 0x3410f4fffee39865 SNZB-06P
                      2024-01-03 12:14:16.960	error	Error while processing converters DEVICE_ID: '3410f4fffee39865' cluster '64529' type 'readResponse'
                      2024-01-03 12:14:16.789	info	Configuring 0x3410f4fffee39865 SNZB-06P
                      2024-01-03 12:14:14.125	error	Error while processing converters DEVICE_ID: '3410f4fffee39865' cluster '64529' type 'readResponse'
                      2024-01-03 12:14:13.812	info	Configuring 0x3410f4fffee39865 SNZB-06P
                        @fredf installier nochmal von GIT
                        • FredF
                          @arteck Beim Start des Adapters immer noch:
                          2024-01-03 12:34:52.689	error	Error while processing converters DEVICE_ID: '3410f4fffee39865' cluster '64529' type 'readResponse'
                          2024-01-03 12:34:52.388	info	Configuring 0x3410f4fffee39865 SNZB-06P
                          2024-01-03 12:34:49.691	error	Error while processing converters DEVICE_ID: '3410f4fffee39865' cluster '64529' type 'readResponse'
                          2024-01-03 12:34:49.405	info	Configuring 0x3410f4fffee39865 SNZB-06P
                          2024-01-03 12:34:46.724	error	Error while processing converters DEVICE_ID: '3410f4fffee39865' cluster '64529' type 'readResponse'
                          2024-01-03 12:34:46.424	info	Configuring 0x3410f4fffee39865 SNZB-06P
                          2024-01-03 12:34:43.751	error	Error while processing converters DEVICE_ID: '3410f4fffee39865' cluster '64529' type 'readResponse'
                          2024-01-03 12:34:43.445	info	Configuring 0x3410f4fffee39865 SNZB-06P
                          2024-01-03 12:34:40.782	error	Error while processing converters DEVICE_ID: '3410f4fffee39865' cluster '64529' type 'readResponse'
                          2024-01-03 12:34:40.471	info	Configuring 0x3410f4fffee39865 SNZB-06P
                          Ansonsten scheint jetzt ruhe zu sein (seit 10 Minuten)
                          Edit gerade geschrieben und schon kommen die Fehlermeldung wieder
                            @fredf nochmal von GIT
                            da sollte jetzt wieder ein error arteck : kommen
                            den brauch ich
                            • FredF
                              @arteck Es kommt keine solche Meldung...
                              host.Tower
                              2024-01-03 12:50:06.301	info	iobroker exit 0
                              host.Tower
                              2024-01-03 12:50:05.205	info	iobroker upload [0] zigbee.admin /opt/iobroker/node_modules/iobroker.zigbee/admin/zigbee.svg zigbee.svg image/svg+xml
                              host.Tower
                              2024-01-03 12:50:05.198	info	iobroker upload [1] zigbee.admin /opt/iobroker/node_modules/iobroker.zigbee/admin/zigbee.png zigbee.png image/png
                              host.Tower
                              2024-01-03 12:50:05.191	info	iobroker upload [2] zigbee.admin /opt/iobroker/node_modules/iobroker.zigbee/admin/words.js words.js application/javascript
                              host.Tower
                              2024-01-03 12:50:05.179	info	iobroker upload [3] zigbee.admin /opt/iobroker/node_modules/iobroker.zigbee/admin/vis-network.min.js vis-network.min.js application/javascript
                              host.Tower
                              2024-01-03 12:50:05.171	info	iobroker upload [4] zigbee.admin /opt/iobroker/node_modules/iobroker.zigbee/admin/vis-network.min.css vis-network.min.css text/css
                              host.Tower
                              2024-01-03 12:50:05.164	info	iobroker upload [5] zigbee.admin /opt/iobroker/node_modules/iobroker.zigbee/admin/tab_m.html tab_m.html text/html
                              host.Tower
                              2024-01-03 12:50:05.157	info	iobroker upload [6] zigbee.admin /opt/iobroker/node_modules/iobroker.zigbee/admin/shuffle.min.js shuffle.min.js application/javascript
                              host.Tower
                              2024-01-03 12:50:05.151	info	iobroker upload [7] zigbee.admin /opt/iobroker/node_modules/iobroker.zigbee/admin/moment.min.js moment.min.js application/javascript
                              host.Tower
                              2024-01-03 12:50:05.139	info	iobroker upload [8] zigbee.admin /opt/iobroker/node_modules/iobroker.zigbee/admin/index_m.html index_m.html text/html
                              host.Tower
                              2024-01-03 12:50:05.133	info	iobroker upload [9] zigbee.admin /opt/iobroker/node_modules/iobroker.zigbee/admin/index.html index.html text/html
                              host.Tower
                              2024-01-03 12:50:05.126	info	iobroker upload [10] zigbee.admin /opt/iobroker/node_modules/iobroker.zigbee/admin/img/zemismart_sw2.png img/zemismart_sw2.png image/png
                              host.Tower
                              2024-01-03 12:50:05.118	info	iobroker upload [11] zigbee.admin /opt/iobroker/node_modules/iobroker.zigbee/admin/img/zbt_smart_switch.png img/zbt_smart_switch.png image/png
                              host.Tower
                              2024-01-03 12:50:05.110	info	iobroker upload [12] zigbee.admin /opt/iobroker/node_modules/iobroker.zigbee/admin/img/zbt_led_panel.png img/zbt_led_panel.png image/png
                              host.Tower
                              2024-01-03 12:50:05.096	info	iobroker upload [13] zigbee.admin /opt/iobroker/node_modules/iobroker.zigbee/admin/img/zbt_e27_rgbw.png img/zbt_e27_rgbw.png image/png
                              host.Tower
                              2024-01-03 12:50:05.077	info	iobroker upload [14] zigbee.admin /opt/iobroker/node_modules/iobroker.zigbee/admin/img/zbt_e27.png img/zbt_e27.png image/png
                              host.Tower
                              2024-01-03 12:50:05.070	info	iobroker upload [15] zigbee.admin /opt/iobroker/node_modules/iobroker.zigbee/admin/img/xiaomi_wireless_switch.png img/xiaomi_wireless_switch.png image/png
                              host.Tower
                              2024-01-03 12:50:05.062	info	iobroker upload [16] zigbee.admin /opt/iobroker/node_modules/iobroker.zigbee/admin/img/xiaomi_plug_eu.png img/xiaomi_plug_eu.png image/png
                              host.Tower
                              2024-01-03 12:50:05.054	info	iobroker upload [17] zigbee.admin /opt/iobroker/node_modules/iobroker.zigbee/admin/img/wemo.png img/wemo.png image/png
                              host.Tower
                              2024-01-03 12:50:05.047	info	iobroker upload [18] zigbee.admin /opt/iobroker/node_modules/iobroker.zigbee/admin/img/unknown.png img/unknown.png image/png
                              host.Tower
                              2024-01-03 12:50:05.040	info	iobroker upload [19] zigbee.admin /opt/iobroker/node_modules/iobroker.zigbee/admin/img/unavailable.png img/unavailable.png image/png
                              host.Tower
                              2024-01-03 12:50:05.033	info	iobroker upload [20] zigbee.admin /opt/iobroker/node_modules/iobroker.zigbee/admin/img/tuya_tyzs1l.png img/tuya_tyzs1l.png image/png
                              host.Tower
                              2024-01-03 12:50:04.954	info	iobroker upload [30] zigbee.admin /opt/iobroker/node_modules/iobroker.zigbee/admin/img/ts0203.png img/ts0203.png image/png
                              host.Tower
                              2024-01-03 12:50:04.885	info	iobroker upload [40] zigbee.admin /opt/iobroker/node_modules/iobroker.zigbee/admin/img/smartthings_motion.png img/smartthings_motion.png image/png
                              host.Tower
                              2024-01-03 12:50:04.818	info	iobroker upload [50] zigbee.admin /opt/iobroker/node_modules/iobroker.zigbee/admin/img/sensor_philipshue.png img/sensor_philipshue.png image/png
                              host.Tower
                              2024-01-03 12:50:04.749	info	iobroker upload [60] zigbee.admin /opt/iobroker/node_modules/iobroker.zigbee/admin/img/plug.png img/plug.png image/png
                              host.Tower
                              2024-01-03 12:50:04.638	info	iobroker upload [70] zigbee.admin /opt/iobroker/node_modules/iobroker.zigbee/admin/img/philips_hue_ltc021.png img/philips_hue_ltc021.png image/png
                              host.Tower
                              2024-01-03 12:50:04.559	info	iobroker upload [80] zigbee.admin /opt/iobroker/node_modules/iobroker.zigbee/admin/img/philips_hue_e27_ambiance.png img/philips_hue_e27_ambiance.png image/png
                              host.Tower
                              2024-01-03 12:50:04.498	info	iobroker upload [90] zigbee.admin /opt/iobroker/node_modules/iobroker.zigbee/admin/img/philips_hue_ambiance.png img/philips_hue_ambiance.png image/png
                              host.Tower
                              2024-01-03 12:50:04.432	info	iobroker upload [100] zigbee.admin /opt/iobroker/node_modules/iobroker.zigbee/admin/img/philips_amaze.png img/philips_amaze.png image/png
                              host.Tower
                              2024-01-03 12:50:04.079	info	iobroker upload [150] zigbee.admin /opt/iobroker/node_modules/iobroker.zigbee/admin/img/lh_32Zb.png img/lh_32Zb.png image/png
                              host.Tower
                              2024-01-03 12:50:03.727	info	iobroker upload [200] zigbee.admin /opt/iobroker/node_modules/iobroker.zigbee/admin/img/hive.png img/hive.png image/png
                              host.Tower
                              2024-01-03 12:50:03.415	info	iobroker upload [250] zigbee.admin /opt/iobroker/node_modules/iobroker.zigbee/admin/img/bitron_motion.png img/bitron_motion.png image/png
                              host.Tower
                              2024-01-03 12:50:03.040	info	iobroker upload [300] zigbee.admin /opt/iobroker/node_modules/iobroker.zigbee/admin/img/DGNWG05LM.png img/DGNWG05LM.png image/png
                              host.Tower
                              2024-01-03 12:50:02.874	info	iobroker upload [323] zigbee.admin /opt/iobroker/node_modules/iobroker.zigbee/admin/adapter-settings.js adapter-settings.js application/javascript
                              host.Tower
                              2024-01-03 12:50:00.143	info	iobroker 313 packages are looking for funding run `npm fund` for details
                              host.Tower
                              2024-01-03 12:50:00.142	info	iobroker changed 1 package in 17s
                              host.Tower
                              host.Tower
                              2024-01-03 12:49:42.351	info	iobroker Installing ioBroker/ioBroker.zigbee... (System call)
                              host.Tower
                              2024-01-03 12:49:42.351	info	iobroker NPM version: 10.2.3
                              host.Tower
                              2024-01-03 12:49:41.984	info	iobroker install ioBroker/ioBroker.zigbee
                              host.Tower
                              2024-01-03 12:49:38.412	info	iobroker url ioBroker/ioBroker.zigbee --host Tower --debug
                              Edit: Ah... Nach Neustart des Adpaters
                              arteck : 'Error: Expected one of: 0, 1, got: 'undefined''
                                @fredf so jetzt nochmal von GIT... und neustart nicht vergessen 🙂
                                • FredF
                                  @arteck
                                  zigbee.0
                                  2024-01-03 13:05:32.503	error	Error while processing converters DEVICE_ID: '3410f4fffee39865' cluster '64529' type 'readResponse'
                                  zigbee.0
                                  2024-01-03 13:05:32.290	info	Configuring 0x3410f4fffee39865 SNZB-06P
                                  zigbee.0
                                  2024-01-03 13:05:29.543	error	Error while processing converters DEVICE_ID: '3410f4fffee39865' cluster '64529' type 'readResponse'
                                  zigbee.0
                                  2024-01-03 13:05:29.301	info	Configuring 0x3410f4fffee39865 SNZB-06P
                                  zigbee.0
                                  2024-01-03 13:05:26.527	error	Error while processing converters DEVICE_ID: '3410f4fffee39865' cluster '64529' type 'readResponse'
                                  zigbee.0
                                  2024-01-03 13:05:26.322	info	Configuring 0x3410f4fffee39865 SNZB-06P
                                  zigbee.0
                                  2024-01-03 13:05:23.479	error	Error while processing converters DEVICE_ID: '3410f4fffee39865' cluster '64529' type 'readResponse'
                                  zigbee.0
                                  2024-01-03 13:05:23.334	info	Configuring 0x3410f4fffee39865 SNZB-06P
                                  zigbee.0
                                  2024-01-03 13:05:20.531	error	Error while processing converters DEVICE_ID: '3410f4fffee39865' cluster '64529' type 'readResponse'
                                  zigbee.0
                                  2024-01-03 13:05:20.351	info	Configuring 0x3410f4fffee39865 SNZB-06P
                                  zigbee.0
                                  2024-01-03 13:03:37.149	warn	DeviceAvailability:Failed to ping 0x385cfbfffe8ce7c8 TRADFRIbulbGU10WS345lm
                                  zigbee.0
                                  2024-01-03 13:03:37.065	warn	DeviceAvailability:Failed to ping 0x04cd15fffe0ae3fc TS0505B
                                  zigbee.0
                                  2024-01-03 13:03:15.048	error	Error while processing converters DEVICE_ID: '3410f4fffee39865' cluster '64529' type 'readResponse'
                                  zigbee.0
                                  2024-01-03 13:03:14.894	info	Configuring 0x3410f4fffee39865 SNZB-06P
                                  zigbee.0
                                  2024-01-03 13:03:13.379	error	Error while processing converters DEVICE_ID: '3410f4fffee39865' cluster '64529' type 'readResponse'
                                  zigbee.0
                                  2024-01-03 13:03:12.900	info	debug devices set to []
                                    @fredf
                                    ich werd bescheuert mit dem Gerät....
                                    so installier nochmal von GIT.. sollte es immer onch kommen.. dann muss ich Morgen weiter schauen..
                                    FredF T 3 Replies Last reply Reply Quote 0
                                    • FredF
                                      @arteck Bis auf das, gibt es keine Fehlermeldung
                                      2024-01-03 13:21:18.883	info	Configuring 0x3410f4fffee39865 SNZB-06P
                                      2024-01-03 13:18:29.357	info	Configuring 0x3410f4fffee39865 SNZB-06P
                                      2024-01-03 13:15:45.585	info	Configuring 0x3410f4fffee39865 SNZB-06P
                                      2024-01-03 13:15:42.615	info	Configuring 0x3410f4fffee39865 SNZB-06P
                                      2024-01-03 13:15:39.680	info	Configuring 0x3410f4fffee39865 SNZB-06P
                                      2024-01-03 13:15:36.650	info	Configuring 0x3410f4fffee39865 SNZB-06P
                                      2024-01-03 13:15:33.660	info	Configuring 0x3410f4fffee39865 SNZB-06P
                                      2024-01-03 13:13:13.261	info	Configuring 0x3410f4fffee39865 SNZB-06P
                                      2024-01-03 13:13:11.233	info	debug devices set to []
                                        tobrog @arteck last edited by
                                        @arteck Sieht bei mir ähnlich aus. Nach der anfänglichen Fehlermeldung kommt auch nur alle paar Minuten diese info Meldung.
                                        zigbee.0
                                        2024-01-03 15:31:30.015	info	Configuring 0x3410f4fffee99489 SNZB-06P
                                        zigbee.0
                                        2024-01-03 15:28:52.569	info	Configuring 0x3410f4fffee99489 SNZB-06P
                                        zigbee.0
                                        2024-01-03 15:21:22.341	info	Configuring 0x3410f4fffee99489 SNZB-06P
                                        zigbee.0
                                        2024-01-03 15:21:19.341	info	Configuring 0x3410f4fffee99489 SNZB-06P
                                        zigbee.0
                                        2024-01-03 15:21:16.321	info	Configuring 0x3410f4fffee99489 SNZB-06P
                                        zigbee.0
                                        2024-01-03 15:21:13.306	info	Configuring 0x3410f4fffee99489 SNZB-06P
                                        zigbee.0
                                        2024-01-03 15:21:10.297	info	Configuring 0x3410f4fffee99489 SNZB-06P
                                        zigbee.0
                                        2024-01-03 15:14:13.742	error	DeviceConfigure:Failed to DeviceConfigure.configure 0x3410f4fffee99489 SNZB-06P (Error: Read 0x3410f4fffee99489/1 64529([8193], {"sendWhen":"immediate","timeout":10000,"disableResponse":false,"disableRecovery":false,"disableDefaultResponse":true,"direction":0,"srcEndpoint":null,"reservedBits":0,"manufacturerCode":null,"transactionSequenceNumber":null,"writeUndiv":false}) failed (no response received (18)) at DeconzAdapter.sendZclFrameToEndpoint (/opt/iobroker/node_modules/zigbee-herdsman/src/adapter/deconz/adapter/deconzAdapter.ts:666:23) at Request.send (/opt/iobroker/node_modules/zigbee-herdsman/src/controller/helpers/request.ts:81:20) at Endpoint.read (/opt/iobroker/node_modules/zigbee-herdsman/src/controller/model/endpoint.ts:460:28) at setupAttributes (/opt/iobroker/node_modules/zigbee-herdsman-converters/src/lib/modernExtend.ts:62:9) at configure (/opt/iobroker/node_modules/zigbee-herdsman-converters/src/lib/modernExtend.ts:72:9) at Object.configure (/opt/iobroker/node_modules/zigbee-herdsman-converters/src/index.ts:139:25) at DeviceConfigure.doConfigure (/opt/iobroker/node_modules/iobroker.zigbee/lib/zbDeviceConfigure.js:136:17) at DeviceConfigure.configure (/opt/iobroker/node_modules/iobroker.zigbee/lib/zbDeviceConfigure.js:114:21))
                                        zigbee.0
                                        2024-01-03 15:14:02.862	info	Configuring 0x3410f4fffee99489 SNZB-06P
                                        zigbee.0
                                        2024-01-03 15:14:00.650	info	debug devices set to []
                                        zigbee.0
                                        2024-01-03 15:14:00.169	info	Zigbee started
                                        • FredF
                                          @arteck
                                          Bonus: Der Sensor funktionierte nicht mehr... musste ihn neu anlernen
                                            so weiter gehts. 🙂
                                            von GIT bitte
                                            80
                                            11804
