mit backitup kein Influxdb und Grafana backup möglich
Okay, kannst du mir dann sagen was der Unterschied zwischeninfluxdb2-cliundinfluxdb2-clientist?pi@iobroker:~ $ apt policy influx* influxdb2-cli: Installed: (none) Candidate: 2.7.3-1 Version table: 2.7.3-1 500 500 https://repos.influxdata.com/debian stable/main arm64 Packages 2.7.1-2 500 500 https://repos.influxdata.com/debian stable/main arm64 Packages 2.6.1 500 500 https://repos.influxdata.com/debian stable/main arm64 Packages 2.6.0 500 500 https://repos.influxdata.com/debian stable/main arm64 Packages 2.5.0 500 500 https://repos.influxdata.com/debian stable/main arm64 Packages 2.4.0 500 500 https://repos.influxdata.com/debian stable/main arm64 Packages 2.3.0 500 500 https://repos.influxdata.com/debian stable/main arm64 Packages influxdb-client: Installed: (none) Candidate: 1.6.7~rc0-1+b13 Version table: 1.6.7~rc0-1+b13 500 500 http://deb.debian.org/debian bookworm/main arm64 Packages influxdb-dev: Installed: (none) Candidate: (none) Version table: influxdb2-client: Installed: 2.7.1-1 Candidate: 2.7.1-1 Version table: *** 2.7.1-1 500 500 https://repos.influxdata.com/debian stable/main arm64 Packages 100 /var/lib/dpkg/status influxdb: Installed: (none) Candidate: 1.8.10-1 Version table: 1.8.10-1 500 500 https://repos.influxdata.com/debian stable/main arm64 Packages 1.6.7~rc0-1+b13 500 500 http://deb.debian.org/debian bookworm/main arm64 Packages influxctl: Installed: (none) Candidate: 2.4.2 Version table: 2.4.2 500 500 https://repos.influxdata.com/debian stable/main arm64 Packages 2.4.1 500 500 https://repos.influxdata.com/debian stable/main arm64 Packages 2.4.0 500 500 https://repos.influxdata.com/debian stable/main arm64 Packages 2.3.1 500 500 https://repos.influxdata.com/debian stable/main arm64 Packages 2.3.0 500 500 https://repos.influxdata.com/debian stable/main arm64 Packages 2.2.0 500 500 https://repos.influxdata.com/debian stable/main arm64 Packages 2.1.0 500 500 https://repos.influxdata.com/debian stable/main arm64 Packages 2.0.4 500 500 https://repos.influxdata.com/debian stable/main arm64 Packages 2.0.3 500 500 https://repos.influxdata.com/debian stable/main arm64 Packages 2.0.2 500 500 https://repos.influxdata.com/debian stable/main arm64 Packages 2.0.1 500 500 https://repos.influxdata.com/debian stable/main arm64 Packages 2.0.0 500 500 https://repos.influxdata.com/debian stable/main arm64 Packages influxdb2: Installed: 2.7.4-1 Candidate: 2.7.4-1 Version table: *** 2.7.4-1 500 500 https://repos.influxdata.com/debian stable/main arm64 Packages 100 /var/lib/dpkg/status 2.7.3-1 500 500 https://repos.influxdata.com/debian stable/main arm64 Packages 2.7.1-1 500 500 https://repos.influxdata.com/debian stable/main arm64 Packages 2.7.0-1 500 500 https://repos.influxdata.com/debian stable/main arm64 Packages 2.6.1-1 500 500 https://repos.influxdata.com/debian stable/main arm64 Packages 2.6.0-1 500 500 https://repos.influxdata.com/debian stable/main arm64 Packages 2.5.1-1 500 500 https://repos.influxdata.com/debian stable/main arm64 Packages 2.4.0-1 500 500 https://repos.influxdata.com/debian stable/main arm64 Packages 2.3.0-1 500 500 https://repos.influxdata.com/debian stable/main arm64 Packages 2.2.0 500 500 https://repos.influxdata.com/debian stable/main arm64 Packages@simatec sagte in mit backitup kein Influxdb und Grafana backup möglich:
@willi-wunder Lösche den Pfad in den Settings von Backitup und installiere
influxdb-cli
influxdist lediglich zur Sicherung von InfluxDB 1.x geeignet. Für InfluxDB 2.x wirdinfluxdb-clibenötigt.Ich dachte deswegen das noch etwas fehlt
@willi-wunder sagte in mit backitup kein Influxdb und Grafana backup möglich:
influxdb2-client:
Installed: 2.7.1-1influxdb2:
Installed: 2.7.4-1Passt also.
Funktioniert ja jetzt auch alles, nochmals vielen Dank.Will es aber jetzt auch verstehen. Die
influxdb2-cliist dann für was genau bestimmt? -
Die influxdb2-cli ist dann für was genau bestimmt?
Die genauen Unterschiede kenne ich auch nicht. Die Kernfunktionen werden aber von beiden Paketen wohl abgedeckt, weswegen die auch nicht parallel installiert sein können.
Beide Pakete installieren das Kommandozeilen-Interface (CLI) für InfluxDB2 "influx", nichts weiter.
Das Paket "...-client" bringt dabei immer eine etwas aktuellere Version mit.
Da sich am Daten(Speicher-)format des InfluxDB2 schon ewig nichts mehr geändert hat, ist es für Backup-Zwecke eigentlich völlig irrelevant, welches Paket benutzt wird.
Wenn man auf Nummer sicher gehen will, nimmt man die "-cli", die ist meist "gut abgehangen". -
Vielen Dank für eure Infos, will ja auch etwas dazu lernen. Jetzt kommen die nächsten Schritte mit influxDB und Grafana......Vermutlich noch ein steiniger Weg, lach.
Re: mit backitup kein Influxdb und Grafana backup möglich
Guten Morgen, leider muss ich mich auch mit einem Problem an euch wenden.
Ich habe einen LXC Container unter Proxmox auf dem meine IOBroker und meine Influx (2) Instanz liegt.
Durch eure bisherige Hilfestellung konnte ich ein Backup meiner Daten durchführen. Importiere ich die Daten auf meiner neuen IO Broker Instanz werden aber keine Buckets angelegt.
Hier ein paar Ergbnisse der CLI:
influx auth list -t Jwn-2_-7uR4NIwCjEFvoxMCYzmSt2qLbfHR3yxpaqFKL9V_XAcWzuil5Tb1OpLiSlvOJ79yonzaWF1IIUPptkA== --json [ { "id": "0aa176f53b5ec000", "description": "admin's Token", "token": "oL0zQjQCzKLf0QThs2q-xjtIqpBVVsg7KwcA3lHuiwGL4KmtIaZzGt1AAUVOxA9kvmfkLVLRc8csjEqsv9s7PA==", "status": "active", "userName": "admin", "userID": "0aa176f5165ec000", "permissions": [ "read:/authorizations", "write:/authorizations", "read:/buckets", "write:/buckets", "read:/dashboards", "write:/dashboards", "read:/orgs", "write:/orgs", "read:/sources", "write:/sources", "read:/tasks", "write:/tasks", "read:/telegrafs", "write:/telegrafs", "read:/users", "write:/users", "read:/variables", "write:/variables", "read:/scrapers", "write:/scrapers", "read:/secrets", "write:/secrets", "read:/labels", "write:/labels", "read:/views", "write:/views", "read:/documents", "write:/documents", "read:/notificationRules", "write:/notificationRules", "read:/notificationEndpoints", "write:/notificationEndpoints", "read:/checks", "write:/checks", "read:/dbrp", "write:/dbrp", "read:/notebooks", "write:/notebooks", "read:/annotations", "write:/annotations", "read:/remotes", "write:/remotes", "read:/replications", "write:/replications" ] }, { "id": "0aa178ecd3cac000", "description": "admin", "token": "Jwn-2_-7uR4NIwCjEFvoxMCYzmSt2qLbfHR3yxpaqFKL9V_XAcWzuil5Tb1OpLiSlvOJ79yonzaWF1IIUPptkA==", "status": "active", "userName": "admin", "userID": "0aa176f5165ec000", "permissions": [ "read:orgs/88eaca12149fac9e/authorizations", "write:orgs/88eaca12149fac9e/authorizations", "read:orgs/88eaca12149fac9e/buckets", "write:orgs/88eaca12149fac9e/buckets", "read:orgs/88eaca12149fac9e/dashboards", "write:orgs/88eaca12149fac9e/dashboards", "read:/orgs/88eaca12149fac9e", "write:/orgs/88eaca12149fac9e", "read:orgs/88eaca12149fac9e/sources", "write:orgs/88eaca12149fac9e/sources", "read:orgs/88eaca12149fac9e/tasks", "write:orgs/88eaca12149fac9e/tasks", "read:orgs/88eaca12149fac9e/telegrafs", "write:orgs/88eaca12149fac9e/telegrafs", "read:/users/0aa176f5165ec000", "write:/users/0aa176f5165ec000", "read:orgs/88eaca12149fac9e/variables", "write:orgs/88eaca12149fac9e/variables", "read:orgs/88eaca12149fac9e/scrapers", "write:orgs/88eaca12149fac9e/scrapers", "read:orgs/88eaca12149fac9e/secrets", "write:orgs/88eaca12149fac9e/secrets", "read:orgs/88eaca12149fac9e/labels", "write:orgs/88eaca12149fac9e/labels", "read:orgs/88eaca12149fac9e/views", "write:orgs/88eaca12149fac9e/views", "read:orgs/88eaca12149fac9e/documents", "write:orgs/88eaca12149fac9e/documents", "read:orgs/88eaca12149fac9e/notificationRules", "write:orgs/88eaca12149fac9e/notificationRules", "read:orgs/88eaca12149fac9e/notificationEndpoints", "write:orgs/88eaca12149fac9e/notificationEndpoints", "read:orgs/88eaca12149fac9e/checks", "write:orgs/88eaca12149fac9e/checks", "read:orgs/88eaca12149fac9e/dbrp", "write:orgs/88eaca12149fac9e/dbrp", "read:orgs/88eaca12149fac9e/notebooks", "write:orgs/88eaca12149fac9e/notebooks", "read:orgs/88eaca12149fac9e/annotations", "write:orgs/88eaca12149fac9e/annotations", "read:orgs/88eaca12149fac9e/remotes", "write:orgs/88eaca12149fac9e/remotes", "read:orgs/88eaca12149fac9e/replications", "write:orgs/88eaca12149fac9e/replications" ] },Mit Jwn habe ich immer gearbeitet, aber:
root@Influx:~# influx backup --bucket iobroker --host http://172.16.0.102:8086 -t Jwn-2_-7uR4NIwCjEFvoxMCYzmSt2qLbfHR3yxpaqFKL9V_XAcWzuil5Tb1OpLiSlvOJ79yonzaWF1IIUPptkA== "/tmp/influx-test" 2024/01/03 10:13:15 INFO: Downloading metadata snapshot Error: failed to backup metadata: failed to download metadata snapshot: 401 Unauthorized: read:authorizations is unauthorizedMit oL0 funktioniert ein Export:
root@Influx:~# influx backup --bucket iobroker --host http://172.16.0.102:8086 -t oL0zQjQCzKLf0QThs2q-xjtIqpBVVsg7KwcA3lHuiwGL4KmtIaZzGt1AAUVOxA9kvmfkLVLRc8csjEqsv9s7PA== "/tmp/influx-test" 2024/01/03 10:39:21 INFO: Downloading metadata snapshot 2024/01/03 10:39:21 INFO: Backing up TSM for shard 4110 2024/01/03 10:39:21 WARN: Shard 4110 removed during backup ....Log von BackitUp
Started iobroker ... [DEBUG] [mount] - done [DEBUG] [iobroker] - host.Influx 4335 states saved [DEBUG] [iobroker] - host.Influx 4958 objects saved [DEBUG] [iobroker] - Backup created: /opt/iobroker/backups/iobroker_2024_01_03-11_12_14_backupiobroker.tar.gz [DEBUG] [iobroker] - This backup can only be restored with js-controller version up from 4.1 [DEBUG] [iobroker] - done [DEBUG] [influxDB] - InfluxDB-Backup for is started ... [DEBUG] [influxDB] - Start InfluxDB Backup ... [DEBUG] [influxDB] - InfluxDB Backup tmp directory created [DEBUG] [influxDB] - Backup created: /opt/iobroker/backups/influxDB_2024_01_03-11_12_17_backupiobroker.tar.gz [DEBUG] [influxDB] - Try deleting the InfluxDB tmp directory: "/opt/iobroker/backups/influxDB_2024_01_03-11_12_17_backupiobroker" [DEBUG] [influxDB] - InfluxDB tmp directory "/opt/iobroker/backups/influxDB_2024_01_03-11_12_17_backupiobroker" successfully deleted [DEBUG] [influxDB] - InfluxDB-Backup for is finish [DEBUG] [influxDB] - InfluxDB-Backup for is started ... [DEBUG] [influxDB] - Start InfluxDB Backup ... [DEBUG] [influxDB] - InfluxDB Backup tmp directory created [DEBUG] [influxDB] - Backup created: /opt/iobroker/backups/influxDB_2024_01_03-11_12_19_backupiobroker.tar.gz [DEBUG] [influxDB] - Try deleting the InfluxDB tmp directory: "/opt/iobroker/backups/influxDB_2024_01_03-11_12_19_backupiobroker" [DEBUG] [influxDB] - InfluxDB tmp directory "/opt/iobroker/backups/influxDB_2024_01_03-11_12_19_backupiobroker" successfully deleted [DEBUG] [influxDB] - InfluxDB-Backup for is finish [DEBUG] [influxDB] - InfluxDB-Backup for is started ... [DEBUG] [influxDB] - Start InfluxDB Backup ... [DEBUG] [influxDB] - InfluxDB Backup tmp directory created [DEBUG] [influxDB] - Backup created: /opt/iobroker/backups/influxDB_2024_01_03-11_12_19_backupiobroker.tar.gz [DEBUG] [influxDB] - Try deleting the InfluxDB tmp directory: "/opt/iobroker/backups/influxDB_2024_01_03-11_12_19_backupiobroker" [DEBUG] [influxDB] - InfluxDB tmp directory "/opt/iobroker/backups/influxDB_2024_01_03-11_12_19_backupiobroker" successfully deleted [DEBUG] [influxDB] - InfluxDB-Backup for is finish [DEBUG] [influxDB] - InfluxDB-Backup for is started ... [DEBUG] [influxDB] - Start InfluxDB Backup ... [DEBUG] [influxDB] - InfluxDB Backup tmp directory created [DEBUG] [influxDB] - Backup created: /opt/iobroker/backups/influxDB_2024_01_03-11_12_20_backupiobroker.tar.gz [DEBUG] [influxDB] - Try deleting the InfluxDB tmp directory: "/opt/iobroker/backups/influxDB_2024_01_03-11_12_20_backupiobroker" [DEBUG] [influxDB] - InfluxDB tmp directory "/opt/iobroker/backups/influxDB_2024_01_03-11_12_20_backupiobroker" successfully deleted [DEBUG] [influxDB] - InfluxDB-Backup for is finish [DEBUG] [influxDB] - InfluxDB-Backup for is started ... [DEBUG] [influxDB] - Start InfluxDB Backup ... [DEBUG] [influxDB] - InfluxDB Backup tmp directory created [DEBUG] [influxDB] - Backup created: /opt/iobroker/backups/influxDB_2024_01_03-11_12_21_backupiobroker.tar.gz [DEBUG] [influxDB] - Try deleting the InfluxDB tmp directory: "/opt/iobroker/backups/influxDB_2024_01_03-11_12_21_backupiobroker" [DEBUG] [influxDB] - InfluxDB tmp directory "/opt/iobroker/backups/influxDB_2024_01_03-11_12_21_backupiobroker" successfully deleted [DEBUG] [influxDB] - InfluxDB-Backup for is finish [DEBUG] [influxDB] - InfluxDB-Backup for is started ... [DEBUG] [influxDB] - Start InfluxDB Backup ... [DEBUG] [influxDB] - InfluxDB Backup tmp directory created [DEBUG] [influxDB] - Backup created: /opt/iobroker/backups/influxDB_2024_01_03-11_12_26_backupiobroker.tar.gz [DEBUG] [influxDB] - Try deleting the InfluxDB tmp directory: "/opt/iobroker/backups/influxDB_2024_01_03-11_12_26_backupiobroker" [DEBUG] [influxDB] - InfluxDB tmp directory "/opt/iobroker/backups/influxDB_2024_01_03-11_12_26_backupiobroker" successfully deleted [DEBUG] [influxDB] - InfluxDB-Backup for is finish [DEBUG] [influxDB] - InfluxDB-Backup for is started ... [DEBUG] [influxDB] - Start InfluxDB Backup ... [DEBUG] [influxDB] - InfluxDB Backup tmp directory created [DEBUG] [influxDB] - Backup created: /opt/iobroker/backups/influxDB_2024_01_03-11_12_27_backupiobroker.tar.gz [DEBUG] [influxDB] - Try deleting the InfluxDB tmp directory: "/opt/iobroker/backups/influxDB_2024_01_03-11_12_27_backupiobroker" [DEBUG] [influxDB] - InfluxDB tmp directory "/opt/iobroker/backups/influxDB_2024_01_03-11_12_27_backupiobroker" successfully deleted [DEBUG] [influxDB] - InfluxDB-Backup for is finish [DEBUG] [influxDB] - InfluxDB-Backup for is started ... [DEBUG] [influxDB] - Start InfluxDB Backup ... [DEBUG] [influxDB] - InfluxDB Backup tmp directory created [DEBUG] [influxDB] - Backup created: /opt/iobroker/backups/influxDB_2024_01_03-11_12_28_backupiobroker.tar.gz [DEBUG] [influxDB] - Try deleting the InfluxDB tmp directory: "/opt/iobroker/backups/influxDB_2024_01_03-11_12_28_backupiobroker" [DEBUG] [influxDB] - InfluxDB tmp directory "/opt/iobroker/backups/influxDB_2024_01_03-11_12_28_backupiobroker" successfully deleted [DEBUG] [influxDB] - InfluxDB-Backup for is finish [DEBUG] [influxDB] - done [DEBUG] [cifs] - used copy path: /mnt/ [DEBUG] [cifs] - Copy iobroker_2024_01_03-11_12_14_backupiobroker.tar.gz... [DEBUG] [cifs] - Copy influxDB_2024_01_03-11_12_17_backupiobroker.tar.gz... [DEBUG] [cifs] - Copy influxDB_2024_01_03-11_12_19_backupiobroker.tar.gz... [DEBUG] [cifs] - Copy influxDB_2024_01_03-11_12_20_backupiobroker.tar.gz... [DEBUG] [cifs] - Copy influxDB_2024_01_03-11_12_21_backupiobroker.tar.gz... [DEBUG] [cifs] - Copy influxDB_2024_01_03-11_12_26_backupiobroker.tar.gz... [DEBUG] [cifs] - Copy influxDB_2024_01_03-11_12_27_backupiobroker.tar.gz... [DEBUG] [cifs] - Copy influxDB_2024_01_03-11_12_28_backupiobroker.tar.gz... [DEBUG] [cifs] - done [DEBUG] [clean] - No older backup files are deleted, because this backup was started manually [DEBUG] [clean] - done [DEBUG] [historyHTML] - new history html values created [DEBUG] [historyHTML] - done [DEBUG] [historyJSON] - new history json values created [DEBUG] [historyJSON] - done [DEBUG] [umount] - done [EXIT] 0Lade ich nun die Influx Backups über die Backitup Oberfläche hoch, werden die Buckets nicht importiert
@taddy81 was meinst du genau mit hochladen? Laut Log werden deine Backups mit der Auswahl des richtigen Operator Token korrekt erstellt.
Beim „hochladen“ weiß ich nicht, was du da genau meinst
@taddy81 sagte in mit backitup kein Influxdb und Grafana backup möglich:
Ich gehe davon aus, dass du die Daten auf der neuen Instanz wiederherstellen willst, richtig?
Wenn du dort die InfluxDB neu installiert hast, benötigt du auch den Operator-Token der neuen DB. Das dürfte ein anderer sein, wenn du nicht den alten explizit beim Setup der DB angegeben hast.
Danke für deine Antwort.
Irgendwie habe ich nun alles zerschossen, ich habe die Backup Dateien über die GUI hochgeladen und diese dann über "Sicherung abrufen" hochgeladen.
Nachdem ich dies gemacht habe, war in der Influx Datenbank kein Bucket hinzugefügt.Anschließend habe ich noch ein paar Influx Backups hochgeladen um diese nochmals Wiederherzustellen, aber nun läuft bei "Sicherung abrufen" nur ein blauer Balken oben durch, aber es erscheinen keine Backups mehr
Wo finde ich denn unter SSH die Uploads auf der 2. Instanz?
Ein find / -name ".tar.gz" ergibt kein Ergebnis -
@taddy81 schau mal…
https://github.com/simatec/ioBroker.backitup/wiki/Diverse-Anleitungen-für-ioBroker.backitup#influxdb2-restoreDamit sollte es funktionieren. Wichtig ist der richtige Operator Token deiner neuen Influx Installation
Komme leider nicht weiter...
Ich habe nun eine InfluxDB importieren wollen und bin auch nach deiner Anleitung vorgegangen.
Ich habe die Organisation in Influx gleich benannt, war das nun richtig? Den Admin Token der NEUEN Influx Installation habe ich dann in die 3 Influx Instanzen geschrieben, nach einem Wiederherstellen erhalte ich folgende Fehlermeldung
Started restore ... [DEBUG] [influxDB] - Created tmp directory [DEBUG] [influxDB] - Start infuxDB Restore ... [ERROR] [influxDB] - Error: failed to check existence of organization "homelab": 401 Unauthorized: unauthorized access [DEBUG] [influxDB] - Try deleting the InfluxDB tmp directory [DEBUG] [influxDB] - InfluxDB tmp directory was successfully deleted [DEBUG] [influxDB] - infuxDB Restore completed successfully [EXIT] influxDB restore doneoot@Influx2:~# influx auth list -t r6cDtTGWFJR5UJe-jtnDkwdkHtYUPfrU25OU4Lb1rRxTEaA-vqdNZETg1MxoL3w0wTLnaNiLT4lPSzveAhkDEA== --json [ { "id": "0c5feb1b8e1fb000", "description": "admin's Token", "token": "r6cDtTGWFJR5UJe-jtnDkwdkHtYUPfrU25OU4Lb1rRxTEaA-vqdNZETg1MxoL3w0wTLnaNiLT4lPSzveAhkDEA==", "status": "active", "userName": "admin", "userID": "0c5feb1b389fb000", "permissions": [ "read:/authorizations", "write:/authorizations", "read:/buckets", "write:/buckets", "read:/dashboards", "write:/dashboards", "read:/orgs", "write:/orgs", "read:/sources", "write:/sources", "read:/tasks", "write:/tasks", "read:/telegrafs", "write:/telegrafs", "read:/users", "write:/users", "read:/variables", "write:/variables", "read:/scrapers", "write:/scrapers", "read:/secrets", "write:/secrets", "read:/labels", "write:/labels", "read:/views", "write:/views", "read:/documents", "write:/documents", "read:/notificationRules", "write:/notificationRules", "read:/notificationEndpoints", "write:/notificationEndpoints", "read:/checks", "write:/checks", "read:/dbrp", "write:/dbrp", "read:/notebooks", "write:/notebooks", "read:/annotations", "write:/annotations", "read:/remotes", "write:/remotes", "read:/replications", "write:/replications" ] } ]Und eine Frage für später, die Daten dieser 3 Influxinstanzen werden täglich in jeweils ein Langzeitbucket mit niedriger Auflösung geschrieben, ich nehme an, dass ich nur InfluxDatenbanken wiederherstellen kann, die auch in IOBroker eine Instanz haben?
Auch Backitup benötigt den Admin Token
Ich habe bei mir in einer eigenen Instanz influx Version1.7.10 installiert. Wie komme ich denn an den Operator Token damit das Backitup funktioniert.
@toki1973 InfluxDB 1.x benötigt keinen Token
https://github.com/simatec/ioBroker.backitup/wiki/ioBroker.backitup-Wiki-Deutsch#influxdb-backup
