    • Segway
      Segway @Michael Roling last edited by Segway
      @michael-roling sagte in Test Adapter telegram-menu v.0.9.x:
      @segway evtl. Über die console updaten
      Schon 1000x mal im Log gelesen aber weiss nicht den Befehl um die aktuelle git version zu laden.
      iob update telegram-menu ?
      • Segway
        @michael-roling
        Auch darüber siehts komisch aus 😞
        iob upgrade telegram-menu@1.6.1
        Would you like to upgrade telegram-menu from @1.5.1 to @1.6.1 now? [(y)es, (n)o]: y
        Update telegram-menu from @1.5.1 to @1.6.1
        NPM version: 10.2.3
        Installing iobroker.telegram-menu@1.6.1... (System call)
        removed 104 packages, and changed 1 package in 8s
        295 packages are looking for funding
          run `npm fund` for details
        Update "system.adapter.telegram-menu.0"
        upload [17] telegram-menu.admin /opt/iobroker/node_modules/iobroker.telegram-menu/admin/build/index.js build/index.js application/javascript
        upload [16] telegram-menu.admin /opt/iobroker/node_modules/iobroker.telegram-menu/admin/build/index.js.map build/index.js.map application/json
         Objects database error: read ECONNRESET
         Objects database error: connect ECONNREFUSED 0.0.0.0:9001
        upload [15] telegram-menu.admin /opt/iobroker/node_modules/iobroker.telegram-menu/admin/i18n/de/translations.json i18n/de/translations.json application/json
        upload [14] telegram-menu.admin /opt/iobroker/node_modules/iobroker.telegram-menu/admin/i18n/en/translations.json i18n/en/translations.json application/json
        upload [13] telegram-menu.admin /opt/iobroker/node_modules/iobroker.telegram-menu/admin/i18n/es/translations.json i18n/es/translations.json application/json
        upload [12] telegram-menu.admin /opt/iobroker/node_modules/iobroker.telegram-menu/admin/i18n/fr/translations.json i18n/fr/translations.json application/json
        upload [11] telegram-menu.admin /opt/iobroker/node_modules/iobroker.telegram-menu/admin/i18n/it/translations.json i18n/it/translations.json application/json
        upload [10] telegram-menu.admin /opt/iobroker/node_modules/iobroker.telegram-menu/admin/i18n/nl/translations.json i18n/nl/translations.json application/json
        upload [9] telegram-menu.admin /opt/iobroker/node_modules/iobroker.telegram-menu/admin/i18n/pl/translations.json i18n/pl/translations.json application/json
        upload [8] telegram-menu.admin /opt/iobroker/node_modules/iobroker.telegram-menu/admin/i18n/pt/translations.json i18n/pt/translations.json application/json
        upload [7] telegram-menu.admin /opt/iobroker/node_modules/iobroker.telegram-menu/admin/i18n/ru/translations.json i18n/ru/translations.json application/json
        upload [6] telegram-menu.admin /opt/iobroker/node_modules/iobroker.telegram-menu/admin/i18n/uk/translations.json i18n/uk/translations.json application/json
        upload [5] telegram-menu.admin /opt/iobroker/node_modules/iobroker.telegram-menu/admin/i18n/zh-cn/translations.json i18n/zh-cn/translations.json application/json
        upload [4] telegram-menu.admin /opt/iobroker/node_modules/iobroker.telegram-menu/admin/img/info-big.png img/info-big.png image/png
        upload [3] telegram-menu.admin /opt/iobroker/node_modules/iobroker.telegram-menu/admin/index_m.html index_m.html text/html
        upload [2] telegram-menu.admin /opt/iobroker/node_modules/iobroker.telegram-menu/admin/src/style.css src/style.css text/css
        upload [1] telegram-menu.admin /opt/iobroker/node_modules/iobroker.telegram-menu/admin/telegram-menu.png telegram-menu.png image/png
        upload [0] telegram-menu.admin /opt/iobroker/node_modules/iobroker.telegram-menu/admin/words.js words.js application/javascript
        Speicher ist auch wieder voll gelaufen und stop/start ausgeführt 😞
        • Michael Roling
          Michael Roling Developer @Segway last edited by
          @segway du nutzt doch anscheinend proxmox. Kannst du dem Container nicht etwas mehr ram zuteilen
          • Segway
            @michael-roling
            Sollten 5Gb nicht ausreichen ?
            Selbst mit 6,5Gb ist dergleichen Effekt 😞
            • Michael Roling
              @segway das ist nicht so schön. Dann musst du evtl die 0.8.5 installieren und warten bis bei dem js-Controller dieses Issue gefixt wurde
              Rene55 Segway 2 Replies Last reply Reply Quote 0
              • Rene55
                Rene55 @Michael Roling last edited by
                @michael-roling Ich habe im Bereich der Navigation keinen Scrollbalken. Liegt das am Adapter oder am Admin?
                • Michael Roling
                  Michael Roling Developer @Rene55 last edited by
                  @rene55 kann am Adapter liegen. Müsste ich mal nachschauen die Tage. Erstellst du bitte ein Issue
                  • Rene55
                    @michael-roling Wenn du das so möchtest.
                    • Michael Roling
                      @rene55 ja sonst verliere ich das aus den Augen
                      • Rene55
                        @michael-roling Kann ja auch nur an mir liegen. Haben das die anderen Mitstreiter evtl. auch? Dann mach ich ein Issue.
                        Michael Roling liv-in-sky B 3 Replies Last reply Reply Quote 0
                        • Michael Roling
                          @rene55 mach einfach und ich schaue nach
                            liv-in-sky @Rene55 last edited by
                            @rene55
                            ja , habe ich auch - der ramverbrauch steigt um ca 1,5 GB - da ich aber 6 gb frei habe ist das kein thema bei mir
                              BobBruni @Rene55 last edited by
                              @rene55 said in Test Adapter telegram-menu v.0.9.x:
                              Ich kann auch nicht mehr Scrollen, wenn ich einen Datenpunkt auswählen möchte (setstate sowie getstate).
                                abuzze last edited by
                                Guten Abend.Ich habe eine Frage zum Adapter. Wie kann ich eine Chat ID einer Gruppe hinzufügen ? Mache ich das über diesen Adapter oder im Telegram Adapter ? Würde gerne die Tastatur im Gruppenchat laden. Danke
                                W Michael Roling 2 Replies Last reply Reply Quote 0
                                  Willi-Wunder @abuzze last edited by
                                  @abuzze
                                  Das wirst du im Telegram Adapter selbst tun müssen. Hier wird das Menü erstellt.
                                    Willi-Wunder @Willi-Wunder last edited by
                                    Hallo Michael,
                                    was haben die drei roten Kreuze bei "Par" zu sagen? Kann diese bei Aufruf auch nicht an- oder abwählen.
                                      Willi-Wunder @Segway last edited by
                                      @segway
                                      Habe einen Rasp 4 mit 4GB. Mit den ganzen Adapter die Laufen sind aktuell 50-60% verbraucht. Update klappt aber dennoch, braucht halt 2-4 Minuten.
                                      System
                                      Debian 12 "bookworm"
                                      Node.js 18.19.0
                                      NPM 10.2.3
                                      Vielleicht bringen dir die Infos etwas.
                                      • Michael Roling
                                        Michael Roling Developer @Willi-Wunder last edited by
                                        @willi-wunder das ist nicht so gewollt. Aber sollte keine Auswirkungen haben. Sagt nur das der parse Mode aus ist. Ich meine eigentlich sollten alle ein Kreuz haben. Aktiviere evtl. Mal den parsemode speichern und dann wieder entfernen. Ich meine das ich da schon etwas dran geändert habe. Dürfte dann bei neu erstellten Zeilen nicht mehr auftauchen. Bzw gleichmäßig logisch.
                                        • Michael Roling
                                          Michael Roling Developer @abuzze last edited by
                                          @abuzze im Gruppenchat kann es meiner Meinung nach nicht funktionieren , denn das Menu beruht auf der Kommunikation mit einem bot. Ich weiß aber nicht ob man einen bot der Gruppe hinzufügen kann.
                                          • Rene55
                                            Rene55 @Michael Roling last edited by Rene55
                                            @michael-roling Nachtrag zu gestern 'Scrollbalken': @Willi-Wunder hat den Scrollbalken drin.
                                            Version ist 1.6.1
                                            EDIT: hier ist das Erstell-Fenster zu sehen. Ich meinte eine Ebene früher in der Übersicht.
                                            1801
                                            790995
