    4. [Neuer Adapter] Life360
      eve11 last edited by
      kann es sein, dass das Login wieder nicht funktioniert.
      In der App und auf der Webseite konnte ich mich einloggen.
      life360.0
      2024-01-03 17:17:49.089	warn	No data received from Life360 cloud services!
      life360.0
      2024-01-03 17:17:49.088	error	Error: Error: Connection established but failed to authenticate. Check your credentials!
      life360.0
      2024-01-03 17:17:49.088	error	Failed to connect or to login for 6 times. Aborting ...
      life360.0
      2024-01-03 17:17:49.087	info	Waiting for online operations to finish ...
      life360.0
      2024-01-03 17:17:49.086	error	Connection established but failed to authenticate. Check your credentials!
      life360.0
      2024-01-03 17:17:48.994	info	Waiting for online operations to finish ...
      life360.0
      2024-01-03 17:17:48.992	error	Connection established but failed to authenticate. Check your credentials!
      life360.0
      2024-01-03 17:17:48.889	info	Waiting for online operations to finish ...
      life360.0
      2024-01-03 17:17:48.888	error	Connection established but failed to authenticate. Check your credentials!
      life360.0
      2024-01-03 17:17:48.792	info	Waiting for online operations to finish ...
      life360.0
      2024-01-03 17:17:48.791	error	Connection established but failed to authenticate. Check your credentials!
      life360.0
      2024-01-03 17:17:48.699	info	Waiting for online operations to finish ...
      life360.0
      2024-01-03 17:17:48.697	error	Connection established but failed to authenticate. Check your credentials!
      life360.0
      2024-01-03 17:17:48.598	info	Waiting for online operations to finish ...
      life360.0
      2024-01-03 17:17:48.595	error	Connection established but failed to authenticate. Check your credentials!
      life360.0
      2024-01-03 17:17:48.157	info	Polling enabled every 60 seconds.
      Heiko
      • Riffcommander
        Riffcommander last edited by
        Hier das gleiche Problem.
          eve11 @Riffcommander last edited by
          @riffcommander
          Danke für dein Feedback. Dann liegt es nicht an mir 🙂
            stefu87_CH last edited by
            Scheint wohl ein Problem von Life 360 sein, da auch die App nicht mehr funktioniert. Wurde da ausgeloggt.
              K_o_bold last edited by
              Gleiches Problem bei mir.
              Allerdings funktioniert die App
                michael 1975 last edited by
                hier das selbe problem
                App geht passwort ändern bringt auch nicht die Lösung
                MiGoller 1 Reply Last reply Reply Quote 0
                • MiGoller
                  MiGoller Developer @michael 1975 last edited by
                  Och bitte nicht schon wieder. Kann das Problem nachstellen. Anmeldung geht im Adapter mit zwei unterschiedlichen Konten nicht mehr.
                  MiGoller 1 Reply Last reply Reply Quote -1
                  • MiGoller
                    MiGoller Developer @MiGoller last edited by
                    Aktuell kann ich mich weder per Kommandozeile mit curl, im Postman API-Tool oder mit dem Adapter anmelden.
                    BananaJoe 1 Reply Last reply Reply Quote 1
                    • BananaJoe
                      BananaJoe Most Active @MiGoller last edited by
                      @migoller sagte in [Neuer Adapter] Life360:
                      Ohne was geändert zu haben?
                      • BananaJoe
                        BananaJoe Most Active last edited by
                        @eve11 sagte in [Neuer Adapter] Life360:
                        wo auf der Webseite gibt es denn noch ein Login?
                        • MiGoller
                          MiGoller Developer @BananaJoe last edited by
                          @bananajoe Genau, nichts geändert. Was vor 11 Tagen funktionierte, funktioniert nun nicht mehr.
                          • Knallochse
                            Knallochse last edited by
                            Das hier aus dem Home-Assistant Github Issues Tracker bedeutet wohl nichts gutes.
                            • Knallochse
                              Knallochse last edited by Knallochse
                              Doppelpost ✌️
                              • MiGoller
                                MiGoller Developer @Knallochse last edited by
                                @knallochse , meinst Du diesen Post hier: https://github.com/home-assistant/core/issues/106967#issuecomment-1875665393 ? Die E-Mail, die der Benutzer erhalten hat, lässt nichts Gutes erahnen. Bislang habe ich weder eine solche Mail erhalten, noch habe ich ein OTP für die Anmeldung bekommen.
                                smarthomefamilyverrips created this issue in home-assistant/core
                                closed Life360 fails authentification again #106967
                                MiGoller D 2 Replies Last reply Reply Quote 0
                                • MiGoller
                                  Musste zwischenzeitlich mein Kennwort ändern, damit ich mich überhaupt wieder in der mobilen App anmelden kann. Sehe jetzt so viel Traffic von dem Gerät... und Life360 sammelt schön Informationen über das Gerät, die Software- und Firmware-Stände, etc. soweit ich bislang erkennen kann.
                                  Statt die wenigen sensiblen Daten der Nutzer besser zu schützen, habe ich den Eindruck, dass noch mehr gesammelt werden, obwohl Life360 in 2021 und jetzt noch einmal in 2023 in den U.S.A. meint, sensible Daten nicht mehr zu verkaufen (vgl. https://themarkup.org/privacy/2023/06/01/life360-sued-for-selling-location-data)...
                                  • Knallochse
                                    Mal vorausgesetzt, dass der Life360 Adapter nicht mehr zum laufen gebracht wird, vielleicht könnte @foxriver76 die IoBroker App um die Funktion einer Homezone zu erweitern. In der App kann mann ja schon einstellen, dass die Standortdaten gesendet werden sollen.
                                    Diese Daten liegen dann unter vis.0.Gerät.currentLocation. Leider werden die Standortdaten aktuell nur bei aktiver App übermittelt und nicht im Hintergrund.
                                      Daniel81 @MiGoller last edited by
                                      @migoller Diese Mail habe ich auch vor ein paar Tagen von life360 erhalten...
                                        eve11 @Knallochse last edited by
                                        @knallochse
                                        Das mit der IoBroker App wäre sicherlich die beste Lösung.
                                        Muss ja nicht kostenlos sein. Diese Funktionalität stellt schon einen großen Mehrwert dar. Eine gute Anwesenheitsteuerung ist mit das wichtigste in einer Heimautomatisierung. Natürlich auch den Standort von den Familienmitgliedern wäre gut.
                                          Sandy last edited by
                                          Scheint wieder zu funktionieren. Habe keine Fehlermeldungen mehr. Habe nichts geändert.
                                          S Riffcommander 2 Replies Last reply Reply Quote 0
                                            stefu87_CH @Sandy last edited by
                                            @sandy Bei mir läuft er nicht
                                            2024-01-04 14:54:26.175 - error: life360.0 (2707463) Connection established but failed to authenticate. Check your credentials!
                                            2024-01-04 14:54:26.177 - info: life360.0 (2707463) Waiting for online operations to finish ...
                                            2024-01-04 14:54:26.262 - error: life360.0 (2707463) Connection established but failed to authenticate. Check your credentials!
                                            2024-01-04 14:54:26.263 - info: life360.0 (2707463) Waiting for online operations to finish ...
                                            2024-01-04 14:54:26.340 - error: life360.0 (2707463) Connection established but failed to authenticate. Check your credentials!
                                            2024-01-04 14:54:26.341 - info: life360.0 (2707463) Waiting for online operations to finish ...
                                            2024-01-04 14:54:26.420 - error: life360.0 (2707463) Connection established but failed to authenticate. Check your credentials!
                                            2024-01-04 14:54:26.421 - info: life360.0 (2707463) Waiting for online operations to finish ...
                                            2024-01-04 14:54:26.501 - error: life360.0 (2707463) Connection established but failed to authenticate. Check your credentials!
                                            2024-01-04 14:54:26.502 - info: life360.0 (2707463) Waiting for online operations to finish ...
                                            2024-01-04 14:54:26.588 - error: life360.0 (2707463) Connection established but failed to authenticate. Check your credentials!
                                            2024-01-04 14:54:26.589 - info: life360.0 (2707463) Waiting for online operations to finish ...
                                            2024-01-04 14:54:26.589 - error: life360.0 (2707463) Failed to connect or to login for 6 times. Aborting ...
                                            2024-01-04 14:54:26.589 - error: life360.0 (2707463) Error: Error: Connection established but failed to authenticate. Check your credentials!
                                            adapter geoposition life360 präsenzmelder
                                            85
                                            708
                                            165757
