    4. Zigbee: Resource temporarily unavailable Cannot lock port
      roughestboy @crunchip last edited by roughestboy
      @crunchip
      Ja, die alte nvbackup.json is ja auch noch da. Wenn ich die wieder einsetze, sehen die Fehlermeldungen anders aus, Instanz bleibt aber auf gelb:
      zigbee.0
      2023-02-26 18:00:06.605	error	Error herdsman start
      zigbee.0
      2023-02-26 18:00:06.604	error	Failed to start Zigbee
      zigbee.0
      2023-02-26 18:00:06.598	error	Starting zigbee-herdsman problem : "Error while opening serialport 'Error: Error Resource temporarily unavailable Cannot lock port'"
      zigbee.0
      2023-02-26 18:00:06.199	info	Installed Version: iobroker.zigbee@1.8.10
      zigbee.0
      2023-02-26 18:00:06.131	info	Starting Zigbee npm ...
      zigbee.0
      2023-02-26 18:00:06.128	info	Try to reconnect. 1 attempts left
      zigbee.0
      2023-02-26 17:59:56.121	error	Error herdsman start
      zigbee.0
      2023-02-26 17:59:56.120	error	Failed to start Zigbee
      zigbee.0
      2023-02-26 17:59:56.117	error	Starting zigbee-herdsman problem : "Cannot read properties of undefined (reading 'payload')"
      zigbee.0
      2023-02-26 17:59:46.937	info	Installed Version: iobroker.zigbee@1.8.10
      zigbee.0
      2023-02-26 17:59:46.246	info	Starting Zigbee npm ...
      zigbee.0
      2023-02-26 17:59:46.242	info	delete old Backup files. keep only last 10
      zigbee.0
      2023-02-26 17:59:46.102	info	starting. Version 1.8.10 in /opt/iobroker/node_modules/iobroker.zigbee, node: v16.19.1, js-controller: 4.0.24
        roughestboy @Thomas Braun last edited by
                             v.2023-01-02
        Operatingsystem:        Debian GNU/Linux 11 (bullseye)
        Installation:           Native
        Timezone:               Europe/Berlin
        User-ID:                1000
        X-Server:               false
        Boot Target:            multi-user.target
        Pending OS-Updates:     54
        Nodejs-Installation:    /usr/bin/nodejs         v16.19.1
                                /usr/bin/node           v16.19.1
                                /usr/bin/npm            8.19.3
                                /usr/bin/npx            8.19.3
        ioBroker Core:          js-controller           4.0.24
                                admin                   6.3.6
        Objects type: jsonl
        States  type: redis
        Status admin:
        + system.adapter.admin.0                  : admin                 : pi4iobroker                              -  enabled, port: 8081, bind: 0.0.0.0, run as: admin
        Pending iob updates:    0
        Active repo(s): beta
        Objects:                4090
        States:                 2820
        Size of iob-Database:
        25M     /opt/iobroker/iobroker-data/objects.jsonl
        552K    /opt/iobroker/iobroker-data/states.jsonl
          Thomas Braun Most Active @roughestboy last edited by
          @roughestboy
          Updaten...
            crunchip Forum Testing Most Active @roughestboy last edited by
            @roughestboy und wenn du den Stick mal kurz absteckst?
              @crunchip ändert nichts.
                Habe jetzt Pending OS-Updates auf Null. Zwischendurch Kabel zum Stick getauscht, den Stick gegen einen identischen gewechselt, und ein Backitup vom 2.2. eingespielt, da war das Problem noch nicht. Auch noch eine neue, 2te Instanz angelegt. Es bleibt immer bei einem 'zigbee-herdsman Problem,' "Cannot read properties of undefined (reading 'payload')" und "Error while opening serialport 'Error: Error Resource temporarily unavailable Cannot lock port'". Letztes log:
                zigbee.0
                	2023-03-04 11:48:47.327	error	Error herdsman start
                zigbee.0
                	2023-03-04 11:48:47.325	error	Failed to start Zigbee
                zigbee.0
                	2023-03-04 11:48:47.324	error	Starting zigbee-herdsman problem : "Error while opening serialport 'Error: Error Resource temporarily unavailable Cannot lock port'"
                zigbee.0
                	2023-03-04 11:48:47.127	info	Installed Version: iobroker.zigbee@1.8.10
                zigbee.0
                	2023-03-04 11:48:47.103	info	Starting Zigbee npm ...
                zigbee.0
                	2023-03-04 11:48:47.102	info	Try to reconnect. 1 attempts left
                zigbee.0
                	2023-03-04 11:48:37.083	error	Error herdsman start
                zigbee.0
                	2023-03-04 11:48:37.083	error	Failed to start Zigbee
                zigbee.0
                	2023-03-04 11:48:37.081	error	Starting zigbee-herdsman problem : "Cannot read properties of undefined (reading 'payload')"
                zigbee.0
                	2023-03-04 11:48:28.346	info	Installed Version: iobroker.zigbee@1.8.10
                zigbee.0
                	2023-03-04 11:48:27.652	info	Starting Zigbee npm ...
                zigbee.0
                	2023-03-04 11:48:27.483	info	starting. Version 1.8.10 in /opt/iobroker/node_modules/iobroker.zigbee, node: v16.19.1, js-controller: 4.0.24
                  Frage: gibts in iobroker irgendetwas oder einen anderen Adapter, der sich den Zigbee Stick schnappt, in etwa sowas wie hier:
                  502 - Bad Gateway =>TypeError: Cannot read property 'payload' of undefined
                    So, um das hier noch abzuschließen. Habe mich wegen eines anderen 'Großprojekts' lange nicht kümmern können und erstmal ohne Zigbee leben müssen.
                    Nun ist raus, es war ein 'schlechtes' udev-Paket. Siehe auch
                    zigbee-conbee2-funktioniert-nach-update-nicht-mehr-udev
                    Für mich war es dann die Möglichkeit 2.
                      micw42 last edited by micw42
                      ich habe heute den js-controller aktualisiert und danach node.js und den zigbee-Adapter. Sonst habe ich nichts verändert!
                      Leider bekomme ich nun auch die Meldung und der Adapter startet nicht mehr:
                      zigbee.0
                      2024-01-03 23:02:48.184	error	Error herdsman start
                      zigbee.0
                      2024-01-03 23:02:48.183	error	Failed to start Zigbee
                      zigbee.0
                      2024-01-03 23:02:48.182	error	Starting zigbee-herdsman problem : "Error while opening serialport 'Error: Error Resource temporarily unavailable Cannot lock port'"
                      zigbee.0
                      2024-01-03 23:02:47.835	info	Installed Version: iobroker.zigbee@1.9.5
                      zigbee.0
                      2024-01-03 23:02:47.802	info	Starting Zigbee npm ...
                      zigbee.0
                      2024-01-03 23:02:47.801	info	Try to reconnect. 1 attempts left
                      zigbee.0
                      2024-01-03 23:02:37.795	error	Error herdsman start
                      zigbee.0
                      2024-01-03 23:02:37.794	error	Failed to start Zigbee
                      zigbee.0
                      2024-01-03 23:02:37.793	error	Starting zigbee-herdsman problem : undefined
                      zigbee.0
                      2024-01-03 23:02:26.289	info	Installed Version: iobroker.zigbee@1.9.5
                      zigbee.0
                      2024-01-03 23:02:25.619	info	Starting Zigbee npm ...
                      zigbee.0
                      2024-01-03 23:02:25.616	info	delete old Backup files. keep only last 10
                      zigbee.0
                      2024-01-03 23:02:25.317	info	starting. Version 1.9.5 in /opt/iobroker/node_modules/iobroker.zigbee, node: v18.19.0, js-controller: 5.0.17
                        Thomas Braun Most Active @micw42 last edited by
                        @micw42
                        iob diag
                        in der Langfassung anschauen.
                          micw42 @Thomas Braun last edited by micw42
                          Ich muss wohl noch dazu sagen, dass ich einen RaspBee II Stick habe.
                            @micw42 sagte in Zigbee: Resource temporarily unavailable Cannot lock port:
                            Was davon ist denn interessant?
                            Alles. Im gesamten gibt es ein Bild.
                              Habe es in dem vorigen Beitrag reingepackt.
                                @micw42
                                Besser CodeTags statt Spoiler verwenden.
                                  Thomas Braun Most Active @micw42 last edited by Thomas Braun
                                  @micw42
                                  Ich brauche aber gar nicht weiterlesen.
                                  Buster ist tot, installier da NEU das aktuelle Release 'Bookworm'. In der 64Bit Lite-Version.
                                    Ich weiß, aber daran kann es doch nicht liegen?
                                    Das hat vor zwei Stunden unter buster alles funktioniert ...
                                      @micw42 Irrelevant. Buster ist tot. Zeit von dem Gaul abzusteigen.
                                      2919
