    4. Adapter: ioBroker.unifi
      Pino72 @Negalein last edited by Pino72
      @negalein Adapter bleibt grün aber er kommt immer wieder mit dem Fehler und die Anwesenheit wird nicht mehr aktualisiert (is_online Wert!).
      AP an und ausschalten geht aber immer...
      	2023-12-18 12:34:17.861	error	[updateUnifiData-login site undefined] error: timeout of 10000ms exceeded, stack: AxiosError: timeout of 10000ms exceeded at RedirectableRequest.handleRequestTimeout (C:\Program Files\ioBroker\node_modules\axios\lib\adapters\http.js:643:16) at RedirectableRequest.emit (node:events:517:28) at RedirectableRequest.emit (node:domain:489:12) at Timeout.<anonymous> (C:\Program Files\ioBroker\node_modules\follow-redirects\index.js:179:12) at listOnTimeout (node:internal/timers:569:17) at processTimers (node:internal/timers:512:7)
      unifi.0
      	2023-12-18 10:34:17.841	error	[updateUnifiData-login site undefined] error: timeout of 10000ms exceeded, stack: AxiosError: timeout of 10000ms exceeded at RedirectableRequest.handleRequestTimeout (C:\Program Files\ioBroker\node_modules\axios\lib\adapters\http.js:643:16) at RedirectableRequest.emit (node:events:517:28) at RedirectableRequest.emit (node:domain:489:12) at Timeout.<anonymous> (C:\Program Files\ioBroker\node_modules\follow-redirects\index.js:179:12) at listOnTimeout (node:internal/timers:569:17) at processTimers (node:internal/timers:512:7)
      unifi.0
      	2023-12-18 10:00:30.027	info	UniFi adapter is ready
      unifi.0
      	2023-12-18 10:00:29.991	info	starting. Version 0.6.7 in C:/Program Files/ioBroker/node_modules/iobroker.unifi, node: v18.19.0, js-controller: 5.0.17
      unifi.0
      	2023-12-18 10:00:22.042	info	terminating
      unifi.0
      	2023-12-18 10:00:21.525	info	Terminated (ADAPTER_REQUESTED_TERMINATION): Without reason
      unifi.0
      	2023-12-18 10:00:21.523	info	terminating
      unifi.0
      	2023-12-18 10:00:21.522	info	cleaned everything up...
      unifi.0
      	2023-12-18 10:00:21.514	info	Got terminate signal TERMINATE_YOURSELF
      unifi.0
      	2023-12-18 09:34:20.308	error	[updateUnifiData-login site undefined] error: timeout of 10000ms exceeded, stack: AxiosError: timeout of 10000ms exceeded at RedirectableRequest.handleRequestTimeout (C:\Program Files\ioBroker\node_modules\axios\lib\adapters\http.js:643:16) at RedirectableRequest.emit (node:events:517:28) at RedirectableRequest.emit (node:domain:489:12) at Timeout.<anonymous> (C:\Program Files\ioBroker\node_modules\follow-redirects\index.js:179:12) at listOnTimeout (node:internal/timers:569:17) at processTimers (node:internal/timers:512:7)
      Negalein M 2 Replies Last reply Reply Quote 0
      • Negalein
        Negalein Global Moderator @Pino72 last edited by
        @pino72 sagte in Adapter: ioBroker.unifi:
        Adapter bleibt grün
        wie schaut bei dir der ioB CPU-Wert aus, wenn der Adapter läuft?
          @negalein Seit Jahren unverändert so um die 15-20%
            mhuber @Pino72 last edited by mhuber
            @pino72 said in Adapter: ioBroker.unifi:
            hab das gleiche Problem seit ein paar Tagen.....CPU auf unter 10%, keine Konfig Änderung....
            • X
              xawa last edited by
              Gleiches Problem auch bei mir: Datenpunkte aktualisieren sich nach einer gewissen Zeit nicht mehr, nach Restart der Instanz kommt auch die Meldung "timeout of 10000ms exceeded, stack: AxiosError.....", DP werden aber wieder aktualisiert
              CPU und RAM ist normal
                Dragon last edited by
                @jens-maus
                Als erstes mal ein riesen Dankeschön für diesen super Adapter.
                @all
                Habe noch zwei Fragen bezüglich dieses Adapters.
                1. Bei mir wird mein Smartphone immer mal wieder als offline gezeigt im Adapter. Es ist aber ununterbrochen online über die Accesspoints. Eine Anwesenheitserkennung ist so leider nicht möglich. Gibt es eine Lösung für dieses Problem?
                2. Ich hatte bei meiner Fritzbox die Möglichkeit einen Online Status abzufragen. Sie hat also gesagt wenn die InetVerbindung gestört war. Ist dies über einen Datenpunkt im Adapter auch möglich (Habe jetzt ein USG, welches hervorragend funktioniert)? Momentan habe ich das ganze über den Ping Adapter auf 8.8.8.8 laufen, wenn es aber über diesen Adapter möglich wär wär das natürlich toll.
                  crunchip Forum Testing Most Active @Dragon last edited by
                  @dragon https://forum.iobroker.net/post/635725
                  Offset
                    Dragon @crunchip last edited by
                    @crunchip vielen dank.... War zwar erstmal etwas Sucherei, aber dann habe ich gefunden, dass es eine Adaptereinstellung ist, die du meinst. Werde es mal versuchen. Danke schon mal.
                    Bei der zweiten Frag noch jemand, der mir dabei helfen kann?
                      @dragon müsst ich nachschauen, aus dem stehgreif kann ich das jetzt nicht beantworten, ich meine aber es gibt einen Datenpunkt
                        @crunchip gibt es iwo eine Erklärung was welcher Datenpunkte ist oder macht?
                          @dragon https://github.com/iobroker-community-adapters/ioBroker.unifi
                          • Negalein
                            bin ich der einzige mit dem CPU-Problem?
                            Oder tritt dies noch bei wem auf?
                            crunchip ? 2 Replies Last reply Reply Quote 0
                              crunchip Forum Testing Most Active @Negalein last edited by
                              @negalein liegt wahrscheinlich an der jeweiligen Hardware, bzw je nachdem was du im Adapter alles angehakt hast
                                A Former User @Negalein last edited by
                                @negalein
                                welche CPU meinst du denn, von der UDM Pro oder dem iobroker?
                                Bei der UDM Pro wurde das Problem mit dem Update auf 3.2.9 (Early Access) behoben.
                                Auf dem iobroker laeuft der Adapter ohne Probleme, nutze hier aber auch die Daten der 27 Switche und Access Points, bei den Netzwerkdevices werden nur 5 ausgelesen durch den Filter.
                                Alles andere lasse ich von einem anderen Docker mit dem unifipoller in die Influx blasen.. damit ist der iobroker entlastet und ich hab 70000 objekte weniger.. was den io deutlich beschleunigt..
                                • Negalein
                                  Negalein Global Moderator @crunchip last edited by Negalein
                                  @crunchip sagte in Adapter: ioBroker.unifi:
                                  Hardware sicher nicht, da es vor 0.6.7 einwandfrei funktionierte.
                                  Aktiviert ist auch nur Clients, Devices, WLAN, Networks, Alarms.
                                  @ilovegym sagte in Adapter: ioBroker.unifi:
                                  ioB
                                  wie filterst du da?
                                    @negalein sagte in Adapter: ioBroker.unifi:
                                    Und in der Zeit auch kein Firmware Update gefahren?
                                    Controller/Gerät schon mal neu gestartet?
                                    • Negalein
                                      Ja, von den Devices
                                      Ja, wurde auch schon versucht
                                        @negalein
                                        meine Config:
                                        DPI, Alarms und Vouchers hab ich disabled, ausser bei den Clients keine Filter aktiv.
                                        • Hant0r
                                          Hant0r last edited by
                                          Moin zusammen,
                                          damit der Adapter richtig läuft, starte ich ihn jeden Morgen um 3 Uhr einmal durch. Die meiste Zeit habe ich auch keine Probleme.
                                          Nun entdecke ich aber mind. einmal am Tag folgende Fehlermeldung im Log:
                                          unifi.0
                                          2024-01-05 08:08:36.023	error	[updateUnifiData-login site undefined] error: timeout of 10000ms exceeded, stack: AxiosError: timeout of 10000ms exceeded at RedirectableRequest.handleRequestTimeout (/opt/iobroker/node_modules/node-unifi/node_modules/axios/lib/adapters/http.js:643:16) at RedirectableRequest.emit (node:events:514:28) at RedirectableRequest.emit (node:domain:489:12) at Timeout.<anonymous> (/opt/iobroker/node_modules/follow-redirects/index.js:209:12) at listOnTimeout (node:internal/timers:569:17) at processTimers (node:internal/timers:512:7)
                                          Jemand eine Idee, woran das liegen könnte und was ich tun muss?
                                          Hatte nun auch schon zweimal den Fall, dass ich den Adapter nochmals neustarten musste, weil die Handys nichts richitg erkannt wurden (ob online oder nicht). Nach Neustart war wieder alles richtig
                                            crunchip Forum Testing Most Active @Hant0r last edited by
                                            @hant0r dazu gibt es bereits ein issue auf git
                                            Hant0r 1 Reply Last reply Reply Quote 1
                                            unifi
                                            171
                                            1010
                                            385590
