    4. Error Log Controller Iobroker *GELÖST*
    • Nicoloma
      Nicoloma @Thomas Braun last edited by
      @thomas-braun ```
      Skript v.2023-10-10
      *** BASE SYSTEM ***
       Static hostname: iobroker
             Icon name: computer-container
               Chassis: container
        Virtualization: lxc
      Operating System: Ubuntu 22.04.3 LTS
                Kernel: Linux 6.2.16-19-pve
          Architecture: x86-64
      model name      : Intel(R) Core(TM) i7-6700 CPU @ 3.40GHz
      Docker          : false
      Virtualization  : lxc
      Kernel          : x86_64
      Userland        : amd64
      Systemuptime and Load:
       21:26:26 up  1:34,  2 users,  load average: 1.49, 1.36, 1.13
      CPU threads: 3
      *** Time and Time Zones ***
                     Local time: Fri 2023-11-24 21:26:26 CET
                 Universal time: Fri 2023-11-24 20:26:26 UTC
                       RTC time: n/a
                      Time zone: CET (CET, +0100)
                    NTP service: inactive
                RTC in local TZ: no
      *** User and Groups ***
      nicolas
      /home/nicolas
      nicolas sudo iobroker
      *** X-Server-Setup ***
      X-Server:       false
      Desktop:
      Terminal:       tty
      *** MEMORY ***
      Mem:            8.0G        3.5G        4.4G        1.0M        117M        4.5G
      Swap:           2.0G         25M        2.0G
      Total:           10G        3.5G        6.4G
               8000 M total memory
               3504 M used memory
                101 M active memory
               3356 M inactive memory
               4377 M free memory
                  0 M buffer memory
                117 M swap cache
               2000 M total swap
                 25 M used swap
               1974 M free swap
      *** FAILED SERVICES ***
        UNIT                                 LOAD   ACTIVE SUB    DESCRIPTION
      * media-FREIGABE.mount                 loaded failed failed /media/FREIGABE
      * run-rpc_pipefs.mount                 loaded failed failed RPC Pipe File System
      * bluetooth.service                    loaded failed failed Bluetooth service
      * motioneye.service                    loaded failed failed motionEye Server
      * systemd-networkd-wait-online.service loaded failed failed Wait for Network to be Configured
      LOAD   = Reflects whether the unit definition was properly loaded.
      ACTIVE = The high-level unit activation state, i.e. generalization of SUB.
      SUB    = The low-level unit activation state, values depend on unit type.
      5 loaded units listed.
      *** FILESYSTEM ***
      Filesystem            Type   Size  Used Avail Use% Mounted on
      ssd/subvol-103-disk-0 zfs     39G   18G   22G  45% /
      none                  tmpfs  492K  4.0K  488K   1% /dev
      tmpfs                 tmpfs  7.8G     0  7.8G   0% /dev/shm
      tmpfs                 tmpfs  3.1G  1.7M  3.1G   1% /run
      tmpfs                 tmpfs  5.0M     0  5.0M   0% /run/lock
      tmpfs                 tmpfs  1.6G  4.0K  1.6G   1% /run/user/1002
      dmesg: read kernel buffer failed: Operation not permitted
      TARGET SOURCE                FSTYPE OPTIONS
      /      ssd/subvol-103-disk-0 zfs    rw,xattr,posixacl
      /var:
      6.5G    /var/
      4.3G    /var/lib
      2.8G    /var/lib/influxdb
      2.7G    /var/lib/influxdb/data
      2.3G    /var/lib/influxdb/data/iobroker/global
      Archived and active journals take up 168.5K in the file system.
      /opt/iobroker/backups:
      6.4G    /opt/iobroker/backups/
      /opt/iobroker/iobroker-data:
      339M    /opt/iobroker/iobroker-data/
      226M    /opt/iobroker/iobroker-data/files
      97M     /opt/iobroker/iobroker-data/backup-objects
      32M     /opt/iobroker/iobroker-data/files/echarts.admin
      26M     /opt/iobroker/iobroker-data/files/javascript.admin
      18M     /opt/iobroker/iobroker-data/files/material/static/js/main.c5478f66.js.map
      16M     /opt/iobroker/iobroker-data/files/devices.admin/static/js/main.24f2bb56.js.map
      15M     /opt/iobroker/iobroker-data/objects.jsonl
      13M     /opt/iobroker/iobroker-data/files/iot.admin/static/js/main.1797d034.js.map
      8.2M    /opt/iobroker/iobroker-data/files/echarts/static/js/main.5f66c5d9.js.map
      USB-Devices by-id:
      *** NodeJS-Installation ***
      /usr/bin/nodejs         v18.18.2
      /usr/bin/node           v18.18.2
      /usr/bin/npm            9.8.1
      /usr/bin/npx            9.8.1
      /usr/bin/corepack       0.19.0
      nodejs:
        Installed: 18.18.2-1nodesource1
        Candidate: 18.18.2-1nodesource1
        Version table:
       *** 18.18.2-1nodesource1 1001
              500 https://deb.nodesource.com/node_18.x nodistro/main amd64 Packages
              100 /var/lib/dpkg/status
           18.18.1-1nodesource1 1001
           18.18.0-1nodesource1 1001
           18.17.1-1nodesource1 1001
           18.17.0-1nodesource1 1001
           18.16.1-1nodesource1 1001
           18.16.0-1nodesource1 1001
           18.15.0-1nodesource1 1001
           18.14.2-1nodesource1 1001
           18.14.1-1nodesource1 1001
           18.14.0-1nodesource1 1001
           18.13.0-1nodesource1 1001
           18.12.0-1nodesource1 1001
           18.11.0-1nodesource1 1001
           18.10.0-1nodesource1 1001
           18.9.1-1nodesource1 1001
           18.9.0-1nodesource1 1001
           18.8.0-1nodesource1 1001
           18.7.0-1nodesource1 1001
           18.6.0-1nodesource1 1001
           18.5.0-1nodesource1 1001
           18.4.0-1nodesource1 1001
           18.3.0-1nodesource1 1001
           18.2.0-1nodesource1 1001
           18.1.0-1nodesource1 1001
           18.0.0-1nodesource1 1001
           12.22.9~dfsg-1ubuntu3.2 500
              500 http://archive.ubuntu.com/ubuntu jammy-updates/universe amd64 Packages
              500 http://archive.ubuntu.com/ubuntu jammy-security/universe amd64 Packages
           12.22.9~dfsg-1ubuntu3 500
              500 http://archive.ubuntu.com/ubuntu jammy/universe amd64 Packages
      No problems detected
      Errors in npm tree:
      *** ioBroker-Installation ***
      ioBroker Status
      Objects type: jsonl
      States  type: jsonl
      Core adapters versions
      js-controller:  5.0.16
      admin:          6.12.0
      javascript:     7.1.6
      Adapters from github:   4
      Adapter State
      + system.adapter.accuweather.0            : accuweather           : iobroker                                 -  enabled
      + system.adapter.admin.0                  : admin                 : iobroker                                 -  enabled, port: 8081, bind: 192.168.178.103 (SSL), run as: admin
        system.adapter.alexa2.0                 : alexa2                : iobroker                                 -  enabled
        system.adapter.alias-manager.0          : alias-manager         : iobroker                                 - disabled
        system.adapter.backitup.0               : backitup              : iobroker                                 - disabled
        system.adapter.chromecast.0             : chromecast            : iobroker                                 - disabled
        system.adapter.cloud.0                  : cloud                 : iobroker                                 - disabled
      + system.adapter.device-reminder.0        : device-reminder       : iobroker                                 -  enabled
        system.adapter.discovery.0              : discovery             : iobroker                                 - disabled
        system.adapter.echarts.0                : echarts               : iobroker                                 - disabled
        system.adapter.flot.0                   : flot                  : iobroker                                 - disabled
      + system.adapter.hass.0                   : hass                  : iobroker                                 -  enabled, port: 8123
        system.adapter.history.0                : history               : iobroker                                 - disabled
        system.adapter.ical.0                   : ical                  : iobroker                                 -  enabled
        system.adapter.icons-addictive-flavour-png.0: icons-addictive-flavour-png: iobroker                                 - disabled
        system.adapter.icons-material-png.0     : icons-material-png    : iobroker                                 - disabled
      + system.adapter.influxdb.0               : influxdb              : iobroker                                 -  enabled, port: 8086
      + system.adapter.info.0                   : info                  : iobroker                                 -  enabled
        system.adapter.iot.0                    : iot                   : iobroker                                 - disabled
        system.adapter.javascript.0             : javascript            : iobroker                                 - disabled
      + system.adapter.lgtv.0                   : lgtv                  : iobroker                                 -  enabled
        system.adapter.material.0               : material              : iobroker                                 - disabled
        system.adapter.mbus.0                   : mbus                  : iobroker                                 - disabled, port: 1502
      + system.adapter.meross.0                 : meross                : iobroker                                 -  enabled
        system.adapter.modbus.0                 : modbus                : iobroker                                 - disabled
      + system.adapter.modbus.1                 : modbus                : iobroker                                 -  enabled
      + system.adapter.moma.0                   : moma                  : iobroker                                 -  enabled
      + system.adapter.mqtt.0                   : mqtt                  : iobroker                                 -  enabled, port: 1884, bind: 192.168.178.103
        system.adapter.net-tools.0              : net-tools             : iobroker                                 - disabled
      + system.adapter.onvif.0                  : onvif                 : iobroker                                 -  enabled, port: 80, 7575, 8000, 8080, 8081, 8899
        system.adapter.pi-hole.0                : pi-hole               : iobroker                                 - disabled
        system.adapter.ping.0                   : ping                  : iobroker                                 - disabled
      + system.adapter.plenticore.0             : plenticore            : iobroker                                 -  enabled, port: 80
        system.adapter.proxmox.0                : proxmox               : iobroker                                 - disabled, port: 8006
      + system.adapter.pvforecast.0             : pvforecast            : iobroker                                 -  enabled
      + system.adapter.pvforecast.1             : pvforecast            : iobroker                                 -  enabled
        system.adapter.radar2.0                 : radar2                : iobroker                                 - disabled
      + system.adapter.samsung.0                : samsung               : iobroker                                 -  enabled
      + system.adapter.sayit.0                  : sayit                 : iobroker                                 -  enabled
      + system.adapter.shelly.0                 : shelly                : iobroker                                 -  enabled, port: 1887, bind: 192.168.178.103
      + system.adapter.smartcontrol.0           : smartcontrol          : iobroker                                 -  enabled
      + system.adapter.smartmeter.0             : smartmeter            : raspberrypi                              -  enabled
      + system.adapter.smartthings.0            : smartthings           : iobroker                                 -  enabled
        system.adapter.solarviewdatareader.0    : solarviewdatareader   : iobroker                                 - disabled, port: 15000
      + system.adapter.sonoff.0                 : sonoff                : iobroker                                 -  enabled, port: 1880, bind: 192.168.178.50
      + system.adapter.sourceanalytix.1         : sourceanalytix        : iobroker                                 -  enabled
      + system.adapter.statistics.0             : statistics            : iobroker                                 -  enabled
      + system.adapter.tankerkoenig.0           : tankerkoenig          : iobroker                                 -  enabled
      + system.adapter.telegram.2               : telegram              : iobroker                                 -  enabled, port: 8443, bind: 0.0.0.0
        system.adapter.terminal.0               : terminal              : iobroker                                 - disabled, port: 8090, bind: 0.0.0.0, run as: admin
      + system.adapter.text2command.0           : text2command          : iobroker                                 -  enabled
      + system.adapter.tibber.0                 : tibber                : iobroker                                 -  enabled
        system.adapter.tr-064.0                 : tr-064                : iobroker                                 - disabled
        system.adapter.trashschedule.0          : trashschedule         : iobroker                                 -  enabled
      + system.adapter.tuya.0                   : tuya                  : iobroker                                 -  enabled
        system.adapter.upnp.0                   : upnp                  : iobroker                                 - disabled
        system.adapter.vis-bars.0               : vis-bars              : iobroker                                 - disabled
        system.adapter.vis-history.0            : vis-history           : iobroker                                 - disabled
        system.adapter.vis-hqwidgets.0          : vis-hqwidgets         : iobroker                                 - disabled
        system.adapter.vis-inventwo.0           : vis-inventwo          : iobroker                                 - disabled
        system.adapter.vis-plumb.0              : vis-plumb             : iobroker                                 - disabled
        system.adapter.vis-timeandweather.0     : vis-timeandweather    : iobroker                                 - disabled
        system.adapter.vis.0                    : vis                   : iobroker                                 -  enabled
        system.adapter.weatherunderground.0     : weatherunderground    : iobroker                                 - disabled
      + system.adapter.web.0                    : web                   : iobroker                                 -  enabled, port: 8082, bind: 0.0.0.0 (SSL), run as: admin
        system.adapter.zigbee.0                 : zigbee                : iobroker                                 - disabled, port: /dev/ttyACM0
      + instance is alive
      ioBroker-Repositories
      Active repo(s): stable
      Installed ioBroker-Instances
      Used repository: stable
      Adapter    "accuweather"  : 1.3.1    , installed 1.3.1
      Adapter    "admin"        : 6.12.0   , installed 6.12.0
      Adapter    "alexa2"       : 3.26.1   , installed 3.26.1
      Adapter    "backitup"     : 2.8.7    , installed 2.8.7
      Adapter    "ble"          : 0.13.4   , installed 0.13.4
      Adapter    "chromecast"   : 3.0.3    , installed 3.0.3
      Adapter    "daswetter"    : 3.1.10   , installed 3.1.10
      Adapter    "device-reminder": 3.0.0  , installed 3.0.0
      Adapter    "echarts"      : 1.5.4    , installed 1.5.4
      Adapter    "hass"         : 1.4.0    , installed 1.4.0
      Adapter    "influxdb"     : 3.2.0    , installed 3.2.0
      Adapter    "iot"          : 2.0.11   , installed 2.0.11
      Adapter    "javascript"   : 7.1.4    , installed 7.1.6
      Controller "js-controller": 5.0.16   , installed 5.0.16
      Adapter    "lgtv"         : 2.1.2    , installed 2.1.2
      Adapter    "material"     : 1.3.1    , installed 1.3.1
      Adapter    "mbus"         : 2.5.0    , installed 2.4.0  [Updatable]
      Adapter    "meross"       : 1.15.1   , installed 1.15.1
      Adapter    "modbus"       : 5.0.11   , installed 5.0.11
      Adapter    "moma"         : 1.2.9    , installed 1.2.9
      Adapter    "mqtt"         : 5.1.0    , installed 5.1.0
      Adapter    "onvif"        : 1.1.1    , installed 1.1.1
      Adapter    "pi-hole"      : 1.3.6    , installed 1.3.6
      Adapter    "plenticore"   : 2.2.0    , installed 2.2.0
      Adapter    "proxmox"      : 2.2.1    , installed 2.2.1
      Adapter    "pvforecast"   : 2.9.0    , installed 2.9.0
      Adapter    "radar2"       : 2.0.8    , installed 2.0.8
      Adapter    "samsung"      : 0.5.11   , installed 0.5.11
      Adapter    "sayit"        : 3.0.5    , installed 3.0.5
      Adapter    "shelly"       : 6.6.1    , installed 6.6.1
      Adapter    "smartcontrol" : 2.0.1    , installed 2.0.1
      Adapter    "smartmeter"   : 3.3.4    , installed 3.3.4
      Adapter    "smartthings"  : 0.0.4    , installed 0.0.4
      Adapter    "socketio"     : 6.5.5    , installed 6.5.5
      Adapter    "solarviewdatareader": 1.0.7, installed 1.0.7
      Adapter    "sonoff"       : 3.0.3    , installed 3.0.3
      Adapter    "statistics"   : 2.4.0    , installed 2.3.0  [Updatable]
      Adapter    "telegram"     : 2.0.1    , installed 2.0.1
      Adapter    "terminal"     : 1.0.0    , installed 1.0.0
      Adapter    "text2command" : 3.0.2    , installed 3.0.2
      Adapter    "trashschedule": 2.3.0    , installed 2.3.0
      Adapter    "tuya"         : 3.14.2   , installed 3.14.2
      Adapter    "upnp"         : 1.0.21   , installed 1.0.21
      Adapter    "weatherunderground": 3.6.0, installed 3.6.0
      Adapter    "web"          : 6.1.10   , installed 6.1.10
      Adapter    "ws"           : 2.5.8    , installed 2.5.8
      Adapter    "zigbee"       : 1.8.24   , installed 1.8.24
      Objects and States
      Objects:        22399
      States:         18080
      W: https://packages.grafana.com/oss/deb/dists/stable/InRelease: Key is stored in legacy trusted.gpg keyring (/etc/apt/trusted.gpg), see the DEPRECATION section in apt-key(8) for details.
      Hit:1 http://archive.ubuntu.com/ubuntu jammy InRelease
      Hit:2 http://archive.ubuntu.com/ubuntu jammy-updates InRelease
      Hit:3 https://repos.influxdata.com/debian stable InRelease
      Hit:4 https://packages.grafana.com/oss/deb stable InRelease
      Hit:5 http://archive.ubuntu.com/ubuntu jammy-security InRelease
      Hit:6 https://deb.nodesource.com/node_18.x nodistro InRelease
      Reading package lists... Done
      Pending Updates: 0
      *** Listening Ports ***
      tcp        0      0 127.0.0.1:34759         0.0.0.0:*               LISTEN      0          1332094785 228/containerd
      tcp        0      0 127.0.0.1:1883          0.0.0.0:*               LISTEN      112        1332094765 234/mosquitto
      tcp        0      0 0.0.0.0:3001            0.0.0.0:*               LISTEN      0          1332119484 1175/docker-proxy
      tcp        0      0 127.0.0.53:53           0.0.0.0:*               LISTEN      106        1332093500 182/systemd-resolve
      tcp        0      0 127.0.0.1:25            0.0.0.0:*               LISTEN      0          1332115025 540/master
      tcp        0      0 192.168.178.103:8081    0.0.0.0:*               LISTEN      1000       1333518017 7209/io.admin.0
      tcp        0      0 0.0.0.0:10000           0.0.0.0:*               LISTEN      0          1332104159 548/perl
      tcp        0      0 127.0.0.1:45009         0.0.0.0:*               LISTEN      113        1333808462 9856/plugin_start_l
      tcp        0      0 0.0.0.0:9001            0.0.0.0:*               LISTEN      1000       1333517165 7191/iobroker.js-co
      tcp        0      0 0.0.0.0:9000            0.0.0.0:*               LISTEN      1000       1333517169 7191/iobroker.js-co
      tcp        0      0 0.0.0.0:445             0.0.0.0:*               LISTEN      0          1332112977 389/smbd
      tcp        0      0 0.0.0.0:139             0.0.0.0:*               LISTEN      0          1332112978 389/smbd
      tcp        0      0 0.0.0.0:111             0.0.0.0:*               LISTEN      0          1332093146 1/init
      tcp        0      0 192.168.178.103:1885    0.0.0.0:*               LISTEN      1000       1333610677 7354/io.mqtt.0
      tcp        0      0 192.168.178.103:1884    0.0.0.0:*               LISTEN      1000       1333610676 7354/io.mqtt.0
      tcp        0      0 192.168.178.103:1887    0.0.0.0:*               LISTEN      1000       1333610764 7385/io.shelly.0
      tcp        0      0 127.0.0.1:8088          0.0.0.0:*               LISTEN      999        1332112931 291/influxd
      tcp        0      0 127.0.0.1:8080          0.0.0.0:*               LISTEN      115        1332097086 231/motion
      tcp        0      0 127.0.0.1:8081          0.0.0.0:*               LISTEN      115        1332097085 231/motion
      tcp6       0      0 :::3001                 :::*                    LISTEN      0          1332119490 1182/docker-proxy
      tcp6       0      0 :::3000                 :::*                    LISTEN      113        1333803505 9714/grafana
      tcp6       0      0 ::1:25                  :::*                    LISTEN      0          1332115026 540/master
      tcp6       0      0 ::1:1883                :::*                    LISTEN      112        1332094766 234/mosquitto
      tcp6       0      0 :::445                  :::*                    LISTEN      0          1332112975 389/smbd
      tcp6       0      0 :::139                  :::*                    LISTEN      0          1332112976 389/smbd
      tcp6       0      0 :::111                  :::*                    LISTEN      0          1332093148 1/init
      tcp6       0      0 :::22                   :::*                    LISTEN      0          1332094457 1/init
      tcp6       0      0 :::8082                 :::*                    LISTEN      1000       1333754449 8820/io.web.0
      tcp6       0      0 :::8086                 :::*                    LISTEN      999        1332113042 291/influxd
      udp        0      0 0.0.0.0:6666            0.0.0.0:*                           1000       1333661282 7418/io.tuya.0
      udp        0      0 0.0.0.0:6667            0.0.0.0:*                           1000       1333661283 7418/io.tuya.0
      udp        0      0 127.0.0.53:53           0.0.0.0:*                           106        1332093499 182/systemd-resolve
      udp        0      0 0.0.0.0:111             0.0.0.0:*                           0          1332093147 1/init
      udp        0      0 172.17.255.255:137      0.0.0.0:*                           0          1332348842 282/nmbd
      udp        0      0 172.17.0.1:137          0.0.0.0:*                           0          1332348841 282/nmbd
      udp        0      0 192.168.178.255:137     0.0.0.0:*                           0          1332112921 282/nmbd
      udp        0      0 192.168.178.103:137     0.0.0.0:*                           0          1332112920 282/nmbd
      udp        0      0 0.0.0.0:137             0.0.0.0:*                           0          1332112908 282/nmbd
      udp        0      0 172.17.255.255:138      0.0.0.0:*                           0          1332348844 282/nmbd
      udp        0      0 172.17.0.1:138          0.0.0.0:*                           0          1332348843 282/nmbd
      udp        0      0 192.168.178.255:138     0.0.0.0:*                           0          1332112923 282/nmbd
      udp        0      0 192.168.178.103:138     0.0.0.0:*                           0          1332112922 282/nmbd
      udp        0      0 0.0.0.0:138             0.0.0.0:*                           0          1332112909 282/nmbd
      udp        0      0 0.0.0.0:10000           0.0.0.0:*                           0          1332104160 548/perl
      udp6       0      0 :::111                  :::*                                0          1332093149 1/init
      2023-11-24 21:25:58.464  - error: host.iobroker Caught by controller[10]: 13: 0x12f933d v8::internal::Runtime_StringCharCodeAt(int, unsigned long*, v8::internal::Isolate*) [/usr/bin/node]
      2023-11-24 21:25:58.464  - error: host.iobroker Caught by controller[11]: 14: 0x1705b39  [/usr/bin/node]
      2023-11-24 21:25:58.464  - warn: host.iobroker instance system.adapter.trashschedule.0 terminated due to SIGABRT
      2023-11-24 21:26:15.274  - warn: hass.0 (7464) State "hass.0.entities.device_tracker.s21_von_espe_2.connected_to" has no existing object, this might lead to an error in future versions
      2023-11-24 21:26:15.274  - warn: hass.0 (7464) State "hass.0.entities.device_tracker.s21_von_espe_2.connection_type" has no existing object, this might lead to an error in future versions
      2023-11-24 21:26:15.274  - warn: hass.0 (7464) State "hass.0.entities.device_tracker.s21_von_espe_2.ssid" has no existing object, this might lead to an error in future versions
      2023-11-24 21:26:29.330  - error: host.iobroker Caught by controller[0]: <--- Last few GCs --->
      2023-11-24 21:26:29.330  - error: host.iobroker Caught by controller[0]: [33518:0x5e306c0]      720 ms: Mark-sweep (reduce) 19.1 (20.8) -> 18.4 (21.3) MB, 4.4 / 0.0 ms  (+ 0.4 ms in 30 steps since start of marking, biggest step 0.0 ms, walltime since start of marking 31 ms) (average mu = 0.901, current mu = 0.877) allocation f[33518:0x5e306c0]      739 ms: Mark-sweep (reduce) 19.9 (21.3) -> 18.5 (21.5) MB, 4.3 / 0.0 ms  (+ 0.3 ms in 15 steps since start of marking, biggest step 0.0 ms, walltime since start of marking 18 ms) (average mu = 0.862, current mu = 0.757) allocation f
      2023-11-24 21:26:29.330  - error: host.iobroker Caught by controller[0]: <--- JS stacktrace --->
      2023-11-24 21:26:29.330  - error: host.iobroker Caught by controller[1]: FATAL ERROR: Reached heap limit Allocation failed - JavaScript heap out of memory
      2023-11-24 21:26:29.330  - error: host.iobroker Caught by controller[2]:  1: 0xb85bc0 node::Abort() [/usr/bin/node]
      2023-11-24 21:26:29.330  - error: host.iobroker Caught by controller[3]:  2: 0xa94834  [/usr/bin/node]
      2023-11-24 21:26:29.330  - error: host.iobroker Caught by controller[4]:  3: 0xd66d10 v8::Utils::ReportOOMFailure(v8::internal::Isolate*, char const*, bool) [/usr/bin/node]
      2023-11-24 21:26:29.330  - error: host.iobroker Caught by controller[5]:  4: 0xd670b7 v8::internal::V8::FatalProcessOutOfMemory(v8::internal::Isolate*, char const*, bool) [/usr/bin/node]
      2023-11-24 21:26:29.330  - error: host.iobroker Caught by controller[6]:  5: 0xf447c5  [/usr/bin/node]
      2023-11-24 21:26:29.331  - error: host.iobroker Caught by controller[7]:  6: 0xf56cad v8::internal::Heap::CollectGarbage(v8::internal::AllocationSpace, v8::internal::GarbageCollectionReason, v8::GCCallbackFlags) [/usr/bin/node]
      2023-11-24 21:26:29.331  - error: host.iobroker Caught by controller[8]:  7: 0xf313ae v8::internal::HeapAllocator::AllocateRawWithLightRetrySlowPath(int, v8::internal::AllocationType, v8::internal::AllocationOrigin, v8::internal::AllocationAlignment) [/usr/bin/node]
      2023-11-24 21:26:29.331  - error: host.iobroker Caught by controller[9]:  8: 0xf32777 v8::internal::HeapAllocator::AllocateRawWithRetryOrFailSlowPath(int, v8::internal::AllocationType, v8::internal::AllocationOrigin, v8::internal::AllocationAlignment) [/usr/bin/node]
      2023-11-24 21:26:29.331  - error: host.iobroker Caught by controller[10]:  9: 0xf1394a v8::internal::Factory::NewFillerObject(int, v8::internal::AllocationAlignment, v8::internal::AllocationType, v8::internal::AllocationOrigin) [/usr/bin/node]
      2023-11-24 21:26:29.331  - error: host.iobroker Caught by controller[11]: 10: 0x12d8caf v8::internal::Runtime_AllocateInYoungGeneration(int, unsigned long*, v8::internal::Isolate*) [/usr/bin/node]
      2023-11-24 21:26:29.331  - error: host.iobroker Caught by controller[12]: 11: 0x1705b39  [/usr/bin/node]
      2023-11-24 21:26:29.331  - warn: host.iobroker instance system.adapter.trashschedule.0 terminated due to SIGABRT
      2023-11-24 21:26:48.283  - warn: hass.0 (7464) State "hass.0.entities.device_tracker.s21_von_espe_2.connected_to" has no existing object, this might lead to an error in future versions
      2023-11-24 21:26:48.283  - warn: hass.0 (7464) State "hass.0.entities.device_tracker.s21_von_espe_2.connection_type" has no existing object, this might lead to an error in future versions
      2023-11-24 21:26:48.283  - warn: hass.0 (7464) State "hass.0.entities.device_tracker.s21_von_espe_2.ssid" has no existing object, this might lead to an error in future versions
      Nicoloma 1 Reply Last reply Reply Quote 0
      • Nicoloma
        Nicoloma @Nicoloma last edited by
        @Thomas-Braun Hallo, hast du eine Idee?
          Thomas Braun Most Active @Nicoloma last edited by
          @nicoloma
          Nein
          • Nicoloma
            Hallo Jungs und Mädels,
            ich habe immer noch das gleiche Problem.
            Kann bitte mir einer versuchen nochmal zu helfen. Mein Web adapter bzw VIS funktioniert nicht. Er zeigt keine fehlermeldung im Log an aber ich kann es nicht aufrufen.
            Ich wäre euch sehr verbunden
            Skript v.2023-10-25
            *** BASE SYSTEM ***
                     Chassis: container
              Virtualization: lxc
                      Kernel: Linux 6.5.11-7-pve
            Docker          : false
            Kernel          : x86_64
            Userland        : amd64
             11:43:02 up 21:41,  1 user,  load average: 2.66, 3.07, 2.94
            CPU threads: 4
                           Local time: Wed 2024-01-03 11:43:02 CET
                       Universal time: Wed 2024-01-03 10:43:02 UTC
                             RTC time: n/a
                      RTC in local TZ: no
            nicolo
            /home/nicolo
            nicolo sudo iobroker
            X-Server:       false
            Desktop:
            Terminal:       tty
            *** MEMORY ***
            Mem:            8.0G        4.5G        3.1G        0.0K        336M        3.5G
            Swap:           100M         99M        0.0K
            Total:          8.1G        4.6G        3.1G
                     8000 M total memory
                     4543 M used memory
                     1839 M active memory
                     2869 M inactive memory
                     3119 M free memory
                        0 M buffer memory
                      337 M swap cache
                      100 M total swap
                       99 M used swap
                        0 M free swap
            3 loaded units listed.
            *** FILESYSTEM ***
            /dev/mapper/Save-vm--103--disk--1 ext4       39G   15G   23G  40% /
            efivarfs                          efivarfs  128K   72K   52K  59% /sys/firmware/efi/efivars
            tmpfs                             tmpfs     3.1G  1.6M  3.1G   1% /run
            Check not possible in LXC or Docker
            Show mounted filesystems:
            /                                             /dev/mapper/Save-vm--103--disk--1 ext4        rw,relatime,stripe=16
            |-/run                                        tmpfs                             tmpfs       rw,nosuid,nodev,size=3246552k,nr_inodes=819200,mode=755,uid=100000,gid=100000,inode64
            | |-/run/lock                                 tmpfs                             tmpfs       rw,nosuid,nodev,noexec,relatime,size=5120k,uid=100000,gid=100000,inode64
            | |-/run/credentials/systemd-sysusers.service ramfs                             ramfs       ro,nosuid,nodev,noexec,relatime,mode=700
            | `-/run/user/1002                            tmpfs                             tmpfs       rw,nosuid,nodev,relatime,size=1623276k,nr_inodes=405819,mode=700,uid=101002,gid=101002,inode64
            |-/dev                                        none                              tmpfs       rw,relatime,size=492k,mode=755,uid=100000,gid=100000,inode64
            | |-/dev/shm                                  tmpfs                             tmpfs       rw,nosuid,nodev,uid=100000,gid=100000,inode64
            | |-/dev/mqueue                               mqueue                            mqueue      rw,relatime
            | |-/dev/ttyACM0                              udev[/ttyACM0]                    devtmpfs    rw,nosuid,relatime,size=8082704k,nr_inodes=2020676,mode=755,inode64
            | |-/dev/.lxc/proc                            proc                              proc        rw,relatime
            | |-/dev/.lxc/sys                             sys                               sysfs       rw,relatime
            | |-/dev/full                                 udev[/full]                       devtmpfs    rw,nosuid,relatime,size=8082704k,nr_inodes=2020676,mode=755,inode64
            | |-/dev/null                                 udev[/null]                       devtmpfs    rw,nosuid,relatime,size=8082704k,nr_inodes=2020676,mode=755,inode64
            | |-/dev/random                               udev[/random]                     devtmpfs    rw,nosuid,relatime,size=8082704k,nr_inodes=2020676,mode=755,inode64
            | |-/dev/tty                                  udev[/tty]                        devtmpfs    rw,nosuid,relatime,size=8082704k,nr_inodes=2020676,mode=755,inode64
            | |-/dev/urandom                              udev[/urandom]                    devtmpfs    rw,nosuid,relatime,size=8082704k,nr_inodes=2020676,mode=755,inode64
            | |-/dev/zero                                 udev[/zero]                       devtmpfs    rw,nosuid,relatime,size=8082704k,nr_inodes=2020676,mode=755,inode64
            | |-/dev/pts                                  devpts                            devpts      rw,nosuid,noexec,relatime,gid=100005,mode=620,ptmxmode=666,max=1026
            | |-/dev/ptmx                                 devpts[/ptmx]                     devpts      rw,nosuid,noexec,relatime,gid=100005,mode=620,ptmxmode=666,max=1026
            | |-/dev/console                              devpts[/0]                        devpts      rw,nosuid,noexec,relatime,gid=100005,mode=620,ptmxmode=666,max=1026
            | |-/dev/tty1                                 devpts[/1]                        devpts      rw,nosuid,noexec,relatime,gid=100005,mode=620,ptmxmode=666,max=1026
            | `-/dev/tty2                                 devpts[/2]                        devpts      rw,nosuid,noexec,relatime,gid=100005,mode=620,ptmxmode=666,max=1026
            |-/proc                                       proc                              proc        rw,nosuid,nodev,noexec,relatime
            | |-/proc/sys                                 proc[/sys]                        proc        ro,relatime
            | | |-/proc/sys/net                           proc[/sys/net]                    proc        rw,nosuid,nodev,noexec,relatime
            | | |-/proc/sys/fs/binfmt_misc                binfmt_misc                       binfmt_misc rw,nosuid,nodev,noexec,relatime
            | | `-/proc/sys/kernel/random/boot_id         none[/.lxc-boot-id]               tmpfs       ro,nosuid,nodev,noexec,relatime,size=492k,mode=755,uid=100000,gid=100000,inode64
            | |-/proc/sysrq-trigger                       proc[/sysrq-trigger]              proc        ro,relatime
            | |-/proc/cpuinfo                             lxcfs[/proc/cpuinfo]              fuse.lxcfs  rw,nosuid,nodev,relatime,user_id=0,group_id=0,allow_other
            | |-/proc/diskstats                           lxcfs[/proc/diskstats]            fuse.lxcfs  rw,nosuid,nodev,relatime,user_id=0,group_id=0,allow_other
            | |-/proc/loadavg                             lxcfs[/proc/loadavg]              fuse.lxcfs  rw,nosuid,nodev,relatime,user_id=0,group_id=0,allow_other
            | |-/proc/meminfo                             lxcfs[/proc/meminfo]              fuse.lxcfs  rw,nosuid,nodev,relatime,user_id=0,group_id=0,allow_other
            | |-/proc/slabinfo                            lxcfs[/proc/slabinfo]             fuse.lxcfs  rw,nosuid,nodev,relatime,user_id=0,group_id=0,allow_other
            | |-/proc/stat                                lxcfs[/proc/stat]                 fuse.lxcfs  rw,nosuid,nodev,relatime,user_id=0,group_id=0,allow_other
            | |-/proc/swaps                               lxcfs[/proc/swaps]                fuse.lxcfs  rw,nosuid,nodev,relatime,user_id=0,group_id=0,allow_other
            | `-/proc/uptime                              lxcfs[/proc/uptime]               fuse.lxcfs  rw,nosuid,nodev,relatime,user_id=0,group_id=0,allow_other
            `-/sys                                        sysfs                             sysfs       ro,nosuid,nodev,noexec,relatime
              |-/sys/fs/fuse/connections                  fusectl                           fusectl     rw,nosuid,nodev,noexec,relatime
              |-/sys/devices/virtual/net                  sysfs[/devices/virtual/net]       sysfs       rw,nosuid,nodev,noexec,relatime
              |-/sys/kernel/debug                         debugfs                           debugfs     rw,nosuid,nodev,noexec,relatime
              |-/sys/kernel/security                      securityfs                        securityfs  rw,nosuid,nodev,noexec,relatime
              |-/sys/fs/pstore                            pstore                            pstore      rw,nosuid,nodev,noexec,relatime
              |-/sys/firmware/efi/efivars                 efivarfs                          efivarfs    rw,nosuid,nodev,noexec,relatime
              |-/sys/fs/cgroup                            none                              cgroup2     rw,nosuid,nodev,noexec,relatime
              `-/sys/devices/system/cpu                   lxcfs[/sys/devices/system/cpu]    fuse.lxcfs  rw,nosuid,nodev,relatime,user_id=0,group_id=0,allow_other
            /var:
            6.9G    /var/
            4.5G    /var/lib
            3.8G    /var/lib/influxdb/data
            3.3G    /var/lib/influxdb/data/iobroker
            Archived and active journals take up 24.0M in the file system.
            83M     /opt/iobroker/backups/
            747M    /opt/iobroker/iobroker-data/
            588M    /opt/iobroker/iobroker-data/files
            126M    /opt/iobroker/iobroker-data/files/vis-2
            105M    /opt/iobroker/iobroker-data/backup-objects
            90M     /opt/iobroker/iobroker-data/files/echarts.admin
            48M     /opt/iobroker/iobroker-data/objects.jsonl
            35M     /opt/iobroker/iobroker-data/files/devices.admin/static/js/main.24f2bb56.js.map
            33M     /opt/iobroker/iobroker-data/files/iot.admin/static/js/main.1797d034.js.map
            24M     /opt/iobroker/iobroker-data/files/echarts/static/js/main.5f66c5d9.js.map
            24M     /opt/iobroker/iobroker-data/files/echarts.admin/static/js/main.9f2a6569.js.map
            USB-Devices by-id:
            /dev/serial/by-id/usb-ITEAD_SONOFF_Zigbee_3.0_USB_Dongle_Plus_V2_20220810141742-if00
            /usr/bin/nodejs         v18.19.0
            /usr/bin/node           v18.19.0
            /usr/bin/npm            10.2.3
            /usr/bin/npx            10.2.3
            /usr/bin/corepack       0.22.0
            nodejs:
              Installed: 18.19.0-1nodesource1
              Candidate: 18.19.0-1nodesource1
              Version table:
             *** 18.19.0-1nodesource1 1001
            Errors in npm tree:
            ioBroker Status
            Objects type: jsonl
            States  type: jsonl
            js-controller:  5.0.17
            admin:          6.12.0
            javascript:     7.1.6
            Adapters from github:   5
            Adapter State
            + system.adapter.admin.0                  : admin                 : iobroker                                 -  enabled, port: 8081, bind: 192.168.178.103, run as: admin
            + system.adapter.alexa2.0                 : alexa2                : iobroker                                 -  enabled
            + system.adapter.backitup.0               : backitup              : iobroker                                 -  enabled
              system.adapter.energiefluss.0           : energiefluss          : iobroker                                 - disabled
              system.adapter.hass.0                   : hass                  : iobroker                                 - disabled, port: 8123
            + system.adapter.iot.0                    : iot                   : iobroker                                 -  enabled
              system.adapter.lgtv.0                   : lgtv                  : iobroker                                 - disabled
              system.adapter.onvif.0                  : onvif                 : iobroker                                 - disabled, port: 80, 7575, 8000, 8080, 8081, 8899
            + system.adapter.proxmox.0                : proxmox               : iobroker                                 -  enabled, port: 8006
            + system.adapter.sonoff.0                 : sonoff                : iobroker                                 -  enabled, port: 1880, bind: 192.168.178.103
            + system.adapter.tr-064.0                 : tr-064                : iobroker                                 -  enabled
            + system.adapter.vis-2.0                  : vis-2                 : iobroker                                 -  enabled
            + system.adapter.web.0                    : web                   : iobroker                                 -  enabled, port: 8082, bind: 0.0.0.0, run as: admin
            + instance is alive
            Adapter    "accuweather"  : 1.3.2    , installed 1.3.2
            Adapter    "acme"         : 0.1.2    , installed 0.1.2
            Adapter    "alexa2"       : 3.26.3   , installed 3.26.3
            Adapter    "backitup"     : 2.9.8    , installed 2.9.8
            Adapter    "daswetter"    : 3.1.11   , installed 3.1.11
            Adapter    "javascript"   : 7.1.6    , installed 7.1.6
            Controller "js-controller": 5.0.17   , installed 5.0.17
            Adapter    "mbus"         : 2.6.1    , installed 2.6.1
            Adapter    "meross"       : 1.16.1   , installed 1.16.1
            Adapter    "modbus"       : 6.0.1    , installed 6.0.1
            Adapter    "proxmox"      : 2.2.2    , installed 2.2.2
            Adapter    "radar2"       : 2.1.0    , installed 2.1.0
            Adapter    "smartmeter"   : 3.4.0    , installed 3.4.0
            Adapter    "statistics"   : 2.4.0    , installed 2.4.0
            Adapter    "telegram"     : 3.0.1    , installed 3.0.1
            Adapter    "tuya"         : 3.15.0   , installed 3.15.0
            Adapter    "welcome"      : 0.1.0    , installed 0.1.0
            Adapter    "zigbee"       : 1.9.5    , installed 1.9.5
            Objects and States
            Objects:        23550
            States:         19971
            Hit:1 https://repos.influxdata.com/debian stable InRelease
            Hit:2 https://packages.grafana.com/oss/deb stable InRelease
            Hit:3 https://deb.nodesource.com/node_18.x nodistro InRelease
            Hit:4 http://archive.ubuntu.com/ubuntu jammy InRelease
            Hit:5 http://archive.ubuntu.com/ubuntu jammy-updates InRelease
            Hit:6 http://archive.ubuntu.com/ubuntu jammy-security InRelease
            Pending Updates: 0
            Netid                  State                   Recv-Q                   Send-Q                                       Local Address:Port                                      Peer Address:Port                  Process
            udp                    UNCONN                  0                        0                                                  0.0.0.0:6666                                           0.0.0.0:*                      users:(("io.tuya.0",pid=894,fd=41))
            udp                    UNCONN                  0                        0                                                  0.0.0.0:6667                                           0.0.0.0:*                      users:(("io.tuya.0",pid=894,fd=42))
            udp                    UNCONN                  0                        0                                            127.0.0.53%lo:53                                             0.0.0.0:*                      users:(("systemd-resolve",pid=157,fd=13))
            udp                    UNCONN                  0                        0                                                  0.0.0.0:111                                            0.0.0.0:*                      users:(("rpcbind",pid=156,fd=5),("systemd",pid=1,fd=28))
            udp                    UNCONN                  0                        0                                          192.168.178.255:137                                            0.0.0.0:*                      users:(("nmbd",pid=281,fd=16))
            udp                    UNCONN                  0                        0                                          192.168.178.103:137                                            0.0.0.0:*                      users:(("nmbd",pid=281,fd=15))
            udp                    UNCONN                  0                        0                                                  0.0.0.0:137                                            0.0.0.0:*                      users:(("nmbd",pid=281,fd=13))
            udp                    UNCONN                  0                        0                                          192.168.178.255:138                                            0.0.0.0:*                      users:(("nmbd",pid=281,fd=18))
            udp                    UNCONN                  0                        0                                          192.168.178.103:138                                            0.0.0.0:*                      users:(("nmbd",pid=281,fd=17))
            udp                    UNCONN                  0                        0                                                  0.0.0.0:138                                            0.0.0.0:*                      users:(("nmbd",pid=281,fd=14))
            udp                    UNCONN                  0                        0                                                  0.0.0.0:10000                                          0.0.0.0:*                      users:(("miniserv.pl",pid=541,fd=6))
            udp                    UNCONN                  0                        0                                                     [::]:111                                               [::]:*                      users:(("rpcbind",pid=156,fd=7),("systemd",pid=1,fd=30))
            tcp                    LISTEN                  0                        511                                        192.168.178.103:8081                                           0.0.0.0:*                      users:(("io.admin.0",pid=257225,fd=29))
            tcp                    LISTEN                  0                        100                                              127.0.0.1:25                                             0.0.0.0:*                      users:(("master",pid=459,fd=13))
            tcp                    LISTEN                  0                        100                                              127.0.0.1:1883                                           0.0.0.0:*                      users:(("mosquitto",pid=192,fd=5))
            tcp                    LISTEN                  0                        4096                                               0.0.0.0:10000                                          0.0.0.0:*                      users:(("miniserv.pl",pid=541,fd=5))
            tcp                    LISTEN                  0                        511                                              127.0.0.1:43317                                          0.0.0.0:*                      users:(("plugin_start_li",pid=744,fd=19))
            tcp                    LISTEN                  0                        50                                                 0.0.0.0:445                                            0.0.0.0:*                      users:(("smbd",pid=477,fd=46))
            tcp                    LISTEN                  0                        4096                                         127.0.0.53%lo:53                                             0.0.0.0:*                      users:(("systemd-resolve",pid=157,fd=14))
            tcp                    LISTEN                  0                        4096                                               0.0.0.0:111                                            0.0.0.0:*                      users:(("rpcbind",pid=156,fd=4),("systemd",pid=1,fd=27))
            tcp                    LISTEN                  0                        50                                                 0.0.0.0:139                                            0.0.0.0:*                      users:(("smbd",pid=477,fd=47))
            tcp                    LISTEN                  0                        511                                                0.0.0.0:9001                                           0.0.0.0:*                      users:(("iobroker.js-con",pid=602,fd=21))
            tcp                    LISTEN                  0                        511                                                0.0.0.0:9000                                           0.0.0.0:*                      users:(("iobroker.js-con",pid=602,fd=27))
            tcp                    LISTEN                  0                        511                                        192.168.178.103:1887                                           0.0.0.0:*                      users:(("io.shelly.0",pid=846,fd=32))
            tcp                    LISTEN                  0                        511                                        192.168.178.103:1884                                           0.0.0.0:*                      users:(("io.mqtt.0",pid=791,fd=29))
            tcp                    LISTEN                  0                        511                                        192.168.178.103:1885                                           0.0.0.0:*                      users:(("io.mqtt.0",pid=791,fd=30))
            tcp                    LISTEN                  0                        511                                        192.168.178.103:1880                                           0.0.0.0:*                      users:(("io.sonoff.0",pid=864,fd=34))
            tcp                    LISTEN                  0                        4096                                             127.0.0.1:8088                                           0.0.0.0:*                      users:(("influxd",pid=330,fd=3))
            tcp                    LISTEN                  0                        4096                                             127.0.0.1:8080                                           0.0.0.0:*                      users:(("motion",pid=190,fd=7))
            tcp                    LISTEN                  0                        4096                                             127.0.0.1:8081                                           0.0.0.0:*                      users:(("motion",pid=190,fd=5))
            tcp                    LISTEN                  0                        4096                                                     *:3000                                                 *:*                      users:(("grafana",pid=601,fd=9))
            tcp                    LISTEN                  0                        50                                                    [::]:445                                               [::]:*                      users:(("smbd",pid=477,fd=44))
            tcp                    LISTEN                  0                        4096                                                     *:22                                                   *:*                      users:(("systemd",pid=1,fd=43))
            tcp                    LISTEN                  0                        4096                                                  [::]:111                                               [::]:*                      users:(("rpcbind",pid=156,fd=6),("systemd",pid=1,fd=29))
            tcp                    LISTEN                  0                        50                                                    [::]:139                                               [::]:*                      users:(("smbd",pid=477,fd=45))
            tcp                    LISTEN                  0                        511                                                      *:8082                                                 *:*                      users:(("io.web.0",pid=8598,fd=28))
            tcp                    LISTEN                  0                        4096                                                     *:8086                                                 *:*                      users:(("influxd",pid=330,fd=179))
            tcp                    LISTEN                  0                        100                                                  [::1]:1883                                              [::]:*                      users:(("mosquitto",pid=192,fd=6))
            tcp                    LISTEN                  0                        100                                                  [::1]:25                                                [::]:*                      users:(("master",pid=459,fd=14))
            2024-01-03 11:43:25.443  - error: host.iobroker Caught by controller[15]: 14: 0xd8c7f9 v8::ScriptCompiler::CompileFunctionInternal(v8::Local<v8::Context>, v8::ScriptCompiler::Source*, unsigned long, v8::Local<v8::String>*, unsigned long, v8::Local<v8::Object>*, v8::ScriptCompiler::CompileOptions, v8::ScriptCompiler::NoCacheReason, v8::Local<v8::ScriptOrModule>*) [/usr/bin/node]
            2024-01-03 11:43:25.443  - error: host.iobroker Caught by controller[16]: 15: 0xd8cbc7 v8::ScriptCompiler::CompileFunction(v8::Local<v8::Context>, v8::ScriptCompiler::Source*, unsigned long, v8::Local<v8::String>*, unsigned long, v8::Local<v8::Object>*, v8::ScriptCompiler::CompileOptions, v8::ScriptCompiler::NoCacheReason) [/usr/bin/node]
            2024-01-03 11:43:25.443  - error: host.iobroker Caught by controller[17]: 16: 0xb875f8 node::contextify::ContextifyContext::CompileFunction(v8::FunctionCallbackInfo<v8::Value> const&) [/usr/bin/node]
            2024-01-03 11:43:25.443  - error: host.iobroker Caught by controller[18]: 17: 0xdcd3e0  [/usr/bin/node]
            2024-01-03 11:43:25.443  - error: host.iobroker Caught by controller[19]: 18: 0xdce91f v8::internal::Builtin_HandleApiCall(int, unsigned long*, v8::internal::Isolate*) [/usr/bin/node]
            2024-01-03 11:43:25.443  - error: host.iobroker Caught by controller[20]: 19: 0x170dfb9  [/usr/bin/node]
            2024-01-03 11:43:25.443  - warn: host.iobroker instance system.adapter.trashschedule.0 terminated due to SIGABRT
            2024-01-03 11:43:38.840  - error: host.iobroker cannot call visUtils: Not exists
            2024-01-03 11:43:38.842  - error: host.iobroker cannot call visUtils: Not exists
            2024-01-03 11:43:56.508  - error: host.iobroker Caught by controller[0]: <--- Last few GCs --->
            2024-01-03 11:43:56.508  - error: host.iobroker Caught by controller[0]: n [262346:0x64c0870]      883 ms: Mark-sweep (reduce) 18.9 (21.0) -> 18.3 (21.3) MB, 2.9 / 0.0 ms  (+ 1.0 ms in 10 steps since start of marking, biggest step 0.2 ms, walltime since start of marking 16 ms) (average mu = 0.669, current mu = 0.768) finalize in[262346:0x64c0870]      902 ms: Mark-sweep (reduce) 19.1 (21.6) -> 18.6 (21.6) MB, 6.2 / 0.0 ms  (+ 0.2 ms in 4 steps since start of marking, biggest step 0.1 ms, walltime since start of marking 17 ms) (average mu = 0.669, current mu = 0.669) finalize inc
            2024-01-03 11:43:56.508  - error: host.iobroker Caught by controller[0]: <--- JS stacktrace --->
            2024-01-03 11:43:56.508  - error: host.iobroker Caught by controller[0]: FATAL ERROR: Reached heap limit Allocation failed - JavaScript heap out of memory
            2024-01-03 11:43:56.508  - error: host.iobroker Caught by controller[1]:  1: 0xb95b60 node::Abort() [/usr/bin/node]
            2024-01-03 11:43:56.509  - error: host.iobroker Caught by controller[2]:  2: 0xa9a7f8  [/usr/bin/node]
            2024-01-03 11:43:56.509  - error: host.iobroker Caught by controller[3]:  3: 0xd6f2f0 v8::Utils::ReportOOMFailure(v8::internal::Isolate*, char const*, bool) [/usr/bin/node]
            2024-01-03 11:43:56.509  - error: host.iobroker Caught by controller[4]:  4: 0xd6f697 v8::internal::V8::FatalProcessOutOfMemory(v8::internal::Isolate*, char const*, bool) [/usr/bin/node]
            2024-01-03 11:43:56.509  - error: host.iobroker Caught by controller[5]:  5: 0xf4cba5  [/usr/bin/node]
            2024-01-03 11:43:56.509  - error: host.iobroker Caught by controller[6]:  6: 0xf5f08d v8::internal::Heap::CollectGarbage(v8::internal::AllocationSpace, v8::internal::GarbageCollectionReason, v8::GCCallbackFlags) [/usr/bin/node]
            2024-01-03 11:43:56.509  - error: host.iobroker Caught by controller[7]:  7: 0xf61ff5 v8::internal::Heap::HandleGCRequest() [/usr/bin/node]
            2024-01-03 11:43:56.509  - error: host.iobroker Caught by controller[8]:  8: 0xee014f v8::internal::StackGuard::HandleInterrupts() [/usr/bin/node]
            2024-01-03 11:43:56.509  - error: host.iobroker Caught by controller[9]:  9: 0x12e0a65 v8::internal::Runtime_StackGuard(int, unsigned long*, v8::internal::Isolate*) [/usr/bin/node]
            2024-01-03 11:43:56.509  - error: host.iobroker Caught by controller[10]: 10: 0x170deb9  [/usr/bin/node]
            2024-01-03 11:43:56.509  - warn: host.iobroker instance system.adapter.trashschedule.0 terminated due to SIGABRT
            2024-01-03 11:43:57.345  - info: iot.0 (8971) Connection changed: disconnect
            iob diag has finished.
            Copy text starting here:
                                    v.2023-10-25
                     Chassis: container
              Virtualization: lxc
            Installation:           lxc
            Kernel:                 x86_64
            Userland:               amd64
            Timezone:               CET (CET, +0100)
            User-ID:                1002
            X-Server:               false
            Boot Target:            graphical.target
            Pending OS-Updates:     0
            Pending iob updates:    0
            Nodejs-Installation:    /usr/bin/nodejs         v18.19.0
                                    /usr/bin/npm            10.2.3
                                    /usr/bin/npx            10.2.3
            Recommended versions are nodejs 18.19.0 and npm 10.2.3
            MEMORY:
            Mem:            8.0G        4.5G        2.8G        0.0K        707M        3.5G
            Swap:           100M         99M        0.0K
            Total:          8.1G        4.6G        2.8G
            Active iob-Instances:   33
            ioBroker Core:          js-controller           5.0.17
                                    admin                   6.12.0
            Objects type: jsonl
            States  type: jsonl
            Objects:                23550
            States:                 19971
            Size of iob-Database:
            56M     /opt/iobroker/iobroker-data/objects.jsonl
            10M     /opt/iobroker/iobroker-data/states.jsonl
            === Mark text until here for copying ===
              arteck Developer Most Active @Nicoloma last edited by
              @nicoloma
              gesehen..bestimmt nicht..
              da läuft in deinen Javscripten was schief
              Nicoloma 2 Replies Last reply Reply Quote 0
              • Nicoloma
                Nicoloma @arteck last edited by
                @arteck doch, ich habe den den Adapter sogar schon komplett deaktiviert, die Meldung bleibt gleich.
                • Nicoloma
                  Nicoloma @arteck last edited by Nicoloma
                  @arteck
                  host.iobroker
                  2024-01-03 12:15:34.137	warn	instance system.adapter.trashschedule.0 terminated due to SIGABRT
                  host.iobroker
                  2024-01-03 12:15:34.137	error	Caught by controller[11]: 10: 0x170deb9 [/usr/bin/node]
                  host.iobroker
                  2024-01-03 12:15:34.137	error	Caught by controller[10]: 9: 0x12e0bcf v8::internal::Runtime_StackGuardWithGap(int, unsigned long*, v8::internal::Isolate*) [/usr/bin/node]
                  host.iobroker
                  2024-01-03 12:15:34.137	error	Caught by controller[9]: 8: 0xee014f v8::internal::StackGuard::HandleInterrupts() [/usr/bin/node]
                  host.iobroker
                  2024-01-03 12:15:34.137	error	Caught by controller[8]: 7: 0xf61ff5 v8::internal::Heap::HandleGCRequest() [/usr/bin/node]
                  host.iobroker
                  2024-01-03 12:15:34.137	error	Caught by controller[7]: 6: 0xf5f08d v8::internal::Heap::CollectGarbage(v8::internal::AllocationSpace, v8::internal::GarbageCollectionReason, v8::GCCallbackFlags) [/usr/bin/node]
                  host.iobroker
                  2024-01-03 12:15:34.137	error	Caught by controller[6]: 5: 0xf4cba5 [/usr/bin/node]
                  host.iobroker
                  2024-01-03 12:15:34.137	error	Caught by controller[5]: 4: 0xd6f697 v8::internal::V8::FatalProcessOutOfMemory(v8::internal::Isolate*, char const*, bool) [/usr/bin/node]
                  host.iobroker
                  2024-01-03 12:15:34.137	error	Caught by controller[4]: 3: 0xd6f2f0 v8::Utils::ReportOOMFailure(v8::internal::Isolate*, char const*, bool) [/usr/bin/node]
                  host.iobroker
                  2024-01-03 12:15:34.137	error	Caught by controller[3]: 2: 0xa9a7f8 [/usr/bin/node]
                  host.iobroker
                  2024-01-03 12:15:34.137	error	Caught by controller[2]: 1: 0xb95b60 node::Abort() [/usr/bin/node]
                  host.iobroker
                  2024-01-03 12:15:34.137	error	Caught by controller[1]: FATAL ERROR: Reached heap limit Allocation failed - JavaScript heap out of memory
                  host.iobroker
                  2024-01-03 12:15:34.137	error	Caught by controller[1]: <--- JS stacktrace --->
                  host.iobroker
                  2024-01-03 12:15:34.137	error	Caught by controller[0]: nc[269268:0x6440870] 24816 ms: Mark-sweep (reduce) 18.9 (21.3) -> 18.7 (21.3) MB, 6.7 / 0.0 ms (+ 0.1 ms in 2 steps since start of marking, biggest step 0.1 ms, walltime since start of marking 52 ms) (average mu = 0.937, current mu = 0.874) finalize inc[269268:0x6440870] 24903 ms: Mark-sweep (reduce) 19.0 (21.3) -> 18.8 (21.6) MB, 5.9 / 0.0 ms (+ 0.1 ms in 2 steps since start of marking, biggest step 0.0 ms, walltime since start of marking 86 ms) (average mu = 0.934, current mu = 0.931) finalize inc
                  host.iobroker
                  2024-01-03 12:15:34.137	error	Caught by controller[0]: <--- Last few GCs --->
                  javascript.0
                  2024-01-03 12:15:03.964	info	terminating
                  javascript.0
                  2024-01-03 12:15:03.469	info	Terminated (ADAPTER_REQUESTED_TERMINATION): Without reason
                  javascript.0
                  2024-01-03 12:15:03.468	info	terminating
                  javascript.0
                  2024-01-03 12:15:03.467	info	Stop script script.js.common.Heizung.PV-Heizstab_aktiv
                  javascript.0
                  2024-01-03 12:15:03.467	info	Stop script script.js.common.Heizung.Fußboden
                  javascript.0
                  2024-01-03 12:15:03.467	info	Stop script script.js.common.PV.aquarium_per_pv
                  javascript.0
                  2024-01-03 12:15:03.467	info	Stop script script.js.common.telegramm1
                  javascript.0
                  2024-01-03 12:15:03.467	info	Stop script script.js.common.nullsteller
                  javascript.0
                  2024-01-03 12:15:03.467	info	Stop script script.js.common.PV.überschuss1_b
                  javascript.0
                  2024-01-03 12:15:03.466	info	Stop script script.js.common.Ordner_1.Spreiz_OG
                  javascript.0
                  2024-01-03 12:15:03.466	info	Stop script script.js.common.Ordner_1.Spreiz_Fb
                  javascript.0
                  2024-01-03 12:15:03.466	info	Stop script script.js.common.Gas.gaszahler
                  javascript.0
                  2024-01-03 12:15:03.466	info	Stop script script.js.common.Gas.gasslbst
                  javascript.0
                  2024-01-03 12:15:03.466	info	Stop script script.js.common.Gas.gaskhwverbrauch
                  javascript.0
                  2024-01-03 12:15:03.466	info	Stop script script.js.common.Gas.Gas_kwheuro
                  javascript.0
                  2024-01-03 12:15:03.466	info	Stop script script.js.common.Alexa.Müllrausbringen
                  javascript.0
                  2024-01-03 12:15:03.465	info	Stop script script.js.Skript_1ss
                  javascript.0
                  2024-01-03 12:15:03.463	info	Got terminate signal TERMINATE_YOURSELF
                  • Nicoloma
                    LÖSUNG: DOWNGRADE VON Node.js18 auf NODE 16...
                      @nicoloma
                      Das ist keine Lösung, nodejs@16 ist im Upstream abgekündigt.
                      • Nicoloma
                        @thomas-braun Ja, aber ich kann es nicht lösen und keiner von euch weiß weiter.
                        • Nicoloma
                          War doch keine lösung habe wieder auf 18 upgedatet!
                            @nicoloma setzt die kiste mal neu auf...
                            wechsel auf debian.. probeweise..warum auch immer
                              Thomas Braun Most Active @arteck last edited by
                              @arteck sagte in Error Log Controller Iobroker:
                              Den exakt gleichen Gedanken hatte ich auch! 🙂
                              • Nicoloma
                                Kann man mit den Fehlermeldungen den nichts anfangen?
                                host.iobroker
                                2024-01-04 10:36:18.491	warn	instance system.adapter.trashschedule.0 terminated due to SIGABRT
                                host.iobroker
                                2024-01-04 10:36:18.491	error	Caught by controller[10]: 10: 0x170deb9 [/usr/bin/node]
                                host.iobroker
                                2024-01-04 10:36:18.491	error	Caught by controller[9]: 9: 0x12e0a65 v8::internal::Runtime_StackGuard(int, unsigned long*, v8::internal::Isolate*) [/usr/bin/node]
                                host.iobroker
                                2024-01-04 10:36:18.491	error	Caught by controller[8]: 8: 0xee014f v8::internal::StackGuard::HandleInterrupts() [/usr/bin/node]
                                host.iobroker
                                2024-01-04 10:36:18.491	error	Caught by controller[7]: 7: 0xf61ff5 v8::internal::Heap::HandleGCRequest() [/usr/bin/node]
                                host.iobroker
                                2024-01-04 10:36:18.491	error	Caught by controller[6]: 6: 0xf5f08d v8::internal::Heap::CollectGarbage(v8::internal::AllocationSpace, v8::internal::GarbageCollectionReason, v8::GCCallbackFlags) [/usr/bin/node]
                                host.iobroker
                                2024-01-04 10:36:18.491	error	Caught by controller[5]: 5: 0xf4cba5 [/usr/bin/node]
                                host.iobroker
                                2024-01-04 10:36:18.491	error	Caught by controller[4]: 4: 0xd6f697 v8::internal::V8::FatalProcessOutOfMemory(v8::internal::Isolate*, char const*, bool) [/usr/bin/node]
                                host.iobroker
                                2024-01-04 10:36:18.491	error	Caught by controller[3]: 3: 0xd6f2f0 v8::Utils::ReportOOMFailure(v8::internal::Isolate*, char const*, bool) [/usr/bin/node]
                                host.iobroker
                                2024-01-04 10:36:18.491	error	Caught by controller[2]: 2: 0xa9a7f8 [/usr/bin/node]
                                host.iobroker
                                2024-01-04 10:36:18.491	error	Caught by controller[1]: 1: 0xb95b60 node::Abort() [/usr/bin/node]
                                host.iobroker
                                2024-01-04 10:36:18.491	error	Caught by controller[0]: FATAL ERROR: Reached heap limit Allocation failed - JavaScript heap out of memory
                                host.iobroker
                                2024-01-04 10:36:18.491	error	Caught by controller[0]: <--- JS stacktrace --->
                                host.iobroker
                                2024-01-04 10:36:18.490	error	Caught by controller[0]: nc[269575:0x689a870] 693 ms: Mark-sweep (reduce) 18.9 (21.3) -> 18.3 (21.3) MB, 2.9 / 0.0 ms (+ 0.4 ms in 9 steps since start of marking, biggest step 0.1 ms, walltime since start of marking 10 ms) (average mu = 0.772, current mu = 0.708) allocation f[269575:0x689a870] 714 ms: Mark-sweep (reduce) 19.7 (21.6) -> 19.1 (22.1) MB, 5.9 / 0.0 ms (+ 0.7 ms in 12 steps since start of marking, biggest step 0.1 ms, walltime since start of marking 19 ms) (average mu = 0.717, current mu = 0.681) finalize in
                                host.iobroker
                                2024-01-04 10:36:18.490	error	Caught by controller[0]: <--- Last few GCs --->
                                Boah das system neu aufzusetzten ist, da stecken für mich LAIE, ewig viel Arbeit....
                                influx.. die ganzen config.... 😕
                                  @nicoloma sagte in Error Log Controller Iobroker:
                                  Ich nicht. Ich sehe da nur, das 'irgendwas' den Speicher im Heap auffrisst.
                                  Kannst ja mal durch deine Skripte gehen.
                                  • Nicoloma
                                    Ich bin dir für jeden Vorschlag dankbar! Aber wenn ich den Javascript-Adapter stoppe sollen doch alle Skripte auch nicht mehr laufen?
                                    Oder laufen Sie vielleicht im Hintergrund weiter?
                                    • Nicoloma
                                      Ich habe schon den Node Option auf
                                      Node: -max_old_space_size=8192 erhöt.
                                      dan habe ich
                                      npm install -g increase-memory-limit
                                      durchgeführt..
                                      Hat auch nichts gebraucht
                                      @Thomas-Braun kennst du eine gute Anleitung für einen evetuellen Umzug?
                                      • Nicoloma
                                        OCH LEUTE * Ich bin stink sauer*
                                        Ich glaube ich habe es jetzt.
                                        Aus unerklärlichen Gründen, hatte der Trashsheduleadapater eine limitierung von 20MB!
                                        JUHU!!!!!
                                        Trotzdem allen vielen dank. Jetzt muss ich nur noch schauen, warum VIS bei mir nicht funktioniert!
                                        1246
