Error Log Controller Iobroker *GELÖST*
JavaScript heap out of memory
gesehen..bestimmt nicht..
da läuft in deinen Javscripten was schief
@arteck doch, ich habe den den Adapter sogar schon komplett deaktiviert, die Meldung bleibt gleich.
host.iobroker 2024-01-03 12:15:34.137 warn instance system.adapter.trashschedule.0 terminated due to SIGABRT host.iobroker 2024-01-03 12:15:34.137 error Caught by controller[11]: 10: 0x170deb9 [/usr/bin/node] host.iobroker 2024-01-03 12:15:34.137 error Caught by controller[10]: 9: 0x12e0bcf v8::internal::Runtime_StackGuardWithGap(int, unsigned long*, v8::internal::Isolate*) [/usr/bin/node] host.iobroker 2024-01-03 12:15:34.137 error Caught by controller[9]: 8: 0xee014f v8::internal::StackGuard::HandleInterrupts() [/usr/bin/node] host.iobroker 2024-01-03 12:15:34.137 error Caught by controller[8]: 7: 0xf61ff5 v8::internal::Heap::HandleGCRequest() [/usr/bin/node] host.iobroker 2024-01-03 12:15:34.137 error Caught by controller[7]: 6: 0xf5f08d v8::internal::Heap::CollectGarbage(v8::internal::AllocationSpace, v8::internal::GarbageCollectionReason, v8::GCCallbackFlags) [/usr/bin/node] host.iobroker 2024-01-03 12:15:34.137 error Caught by controller[6]: 5: 0xf4cba5 [/usr/bin/node] host.iobroker 2024-01-03 12:15:34.137 error Caught by controller[5]: 4: 0xd6f697 v8::internal::V8::FatalProcessOutOfMemory(v8::internal::Isolate*, char const*, bool) [/usr/bin/node] host.iobroker 2024-01-03 12:15:34.137 error Caught by controller[4]: 3: 0xd6f2f0 v8::Utils::ReportOOMFailure(v8::internal::Isolate*, char const*, bool) [/usr/bin/node] host.iobroker 2024-01-03 12:15:34.137 error Caught by controller[3]: 2: 0xa9a7f8 [/usr/bin/node] host.iobroker 2024-01-03 12:15:34.137 error Caught by controller[2]: 1: 0xb95b60 node::Abort() [/usr/bin/node] host.iobroker 2024-01-03 12:15:34.137 error Caught by controller[1]: FATAL ERROR: Reached heap limit Allocation failed - JavaScript heap out of memory host.iobroker 2024-01-03 12:15:34.137 error Caught by controller[1]: <--- JS stacktrace ---> host.iobroker 2024-01-03 12:15:34.137 error Caught by controller[0]: nc[269268:0x6440870] 24816 ms: Mark-sweep (reduce) 18.9 (21.3) -> 18.7 (21.3) MB, 6.7 / 0.0 ms (+ 0.1 ms in 2 steps since start of marking, biggest step 0.1 ms, walltime since start of marking 52 ms) (average mu = 0.937, current mu = 0.874) finalize inc[269268:0x6440870] 24903 ms: Mark-sweep (reduce) 19.0 (21.3) -> 18.8 (21.6) MB, 5.9 / 0.0 ms (+ 0.1 ms in 2 steps since start of marking, biggest step 0.0 ms, walltime since start of marking 86 ms) (average mu = 0.934, current mu = 0.931) finalize inc host.iobroker 2024-01-03 12:15:34.137 error Caught by controller[0]: <--- Last few GCs ---> javascript.0 2024-01-03 12:15:03.964 info terminating javascript.0 2024-01-03 12:15:03.469 info Terminated (ADAPTER_REQUESTED_TERMINATION): Without reason javascript.0 2024-01-03 12:15:03.468 info terminating javascript.0 2024-01-03 12:15:03.467 info Stop script script.js.common.Heizung.PV-Heizstab_aktiv javascript.0 2024-01-03 12:15:03.467 info Stop script script.js.common.Heizung.Fußboden javascript.0 2024-01-03 12:15:03.467 info Stop script script.js.common.PV.aquarium_per_pv javascript.0 2024-01-03 12:15:03.467 info Stop script script.js.common.telegramm1 javascript.0 2024-01-03 12:15:03.467 info Stop script script.js.common.nullsteller javascript.0 2024-01-03 12:15:03.467 info Stop script script.js.common.PV.überschuss1_b javascript.0 2024-01-03 12:15:03.466 info Stop script script.js.common.Ordner_1.Spreiz_OG javascript.0 2024-01-03 12:15:03.466 info Stop script script.js.common.Ordner_1.Spreiz_Fb javascript.0 2024-01-03 12:15:03.466 info Stop script script.js.common.Gas.gaszahler javascript.0 2024-01-03 12:15:03.466 info Stop script script.js.common.Gas.gasslbst javascript.0 2024-01-03 12:15:03.466 info Stop script script.js.common.Gas.gaskhwverbrauch javascript.0 2024-01-03 12:15:03.466 info Stop script script.js.common.Gas.Gas_kwheuro javascript.0 2024-01-03 12:15:03.466 info Stop script script.js.common.Alexa.Müllrausbringen javascript.0 2024-01-03 12:15:03.465 info Stop script script.js.Skript_1ss javascript.0 2024-01-03 12:15:03.463 info Got terminate signal TERMINATE_YOURSELF
LÖSUNG: DOWNGRADE VON Node.js18 auf NODE 16...
Das ist keine Lösung, nodejs@16 ist im Upstream abgekündigt.
@thomas-braun Ja, aber ich kann es nicht lösen und keiner von euch weiß weiter.
War doch keine lösung habe wieder auf 18 upgedatet!
@nicoloma setzt die kiste mal neu auf...
wechsel auf debian.. probeweise..warum auch immer
@arteck sagte in Error Log Controller Iobroker:
wechsel auf debian.. probeweise..warum auch immerDen exakt gleichen Gedanken hatte ich auch!
Kann man mit den Fehlermeldungen den nichts anfangen?host.iobroker 2024-01-04 10:36:18.491 warn instance system.adapter.trashschedule.0 terminated due to SIGABRT host.iobroker 2024-01-04 10:36:18.491 error Caught by controller[10]: 10: 0x170deb9 [/usr/bin/node] host.iobroker 2024-01-04 10:36:18.491 error Caught by controller[9]: 9: 0x12e0a65 v8::internal::Runtime_StackGuard(int, unsigned long*, v8::internal::Isolate*) [/usr/bin/node] host.iobroker 2024-01-04 10:36:18.491 error Caught by controller[8]: 8: 0xee014f v8::internal::StackGuard::HandleInterrupts() [/usr/bin/node] host.iobroker 2024-01-04 10:36:18.491 error Caught by controller[7]: 7: 0xf61ff5 v8::internal::Heap::HandleGCRequest() [/usr/bin/node] host.iobroker 2024-01-04 10:36:18.491 error Caught by controller[6]: 6: 0xf5f08d v8::internal::Heap::CollectGarbage(v8::internal::AllocationSpace, v8::internal::GarbageCollectionReason, v8::GCCallbackFlags) [/usr/bin/node] host.iobroker 2024-01-04 10:36:18.491 error Caught by controller[5]: 5: 0xf4cba5 [/usr/bin/node] host.iobroker 2024-01-04 10:36:18.491 error Caught by controller[4]: 4: 0xd6f697 v8::internal::V8::FatalProcessOutOfMemory(v8::internal::Isolate*, char const*, bool) [/usr/bin/node] host.iobroker 2024-01-04 10:36:18.491 error Caught by controller[3]: 3: 0xd6f2f0 v8::Utils::ReportOOMFailure(v8::internal::Isolate*, char const*, bool) [/usr/bin/node] host.iobroker 2024-01-04 10:36:18.491 error Caught by controller[2]: 2: 0xa9a7f8 [/usr/bin/node] host.iobroker 2024-01-04 10:36:18.491 error Caught by controller[1]: 1: 0xb95b60 node::Abort() [/usr/bin/node] host.iobroker 2024-01-04 10:36:18.491 error Caught by controller[0]: FATAL ERROR: Reached heap limit Allocation failed - JavaScript heap out of memory host.iobroker 2024-01-04 10:36:18.491 error Caught by controller[0]: <--- JS stacktrace ---> host.iobroker 2024-01-04 10:36:18.490 error Caught by controller[0]: nc[269575:0x689a870] 693 ms: Mark-sweep (reduce) 18.9 (21.3) -> 18.3 (21.3) MB, 2.9 / 0.0 ms (+ 0.4 ms in 9 steps since start of marking, biggest step 0.1 ms, walltime since start of marking 10 ms) (average mu = 0.772, current mu = 0.708) allocation f[269575:0x689a870] 714 ms: Mark-sweep (reduce) 19.7 (21.6) -> 19.1 (22.1) MB, 5.9 / 0.0 ms (+ 0.7 ms in 12 steps since start of marking, biggest step 0.1 ms, walltime since start of marking 19 ms) (average mu = 0.717, current mu = 0.681) finalize in host.iobroker 2024-01-04 10:36:18.490 error Caught by controller[0]: <--- Last few GCs --->
Boah das system neu aufzusetzten ist, da stecken für mich LAIE, ewig viel Arbeit....
influx.. die ganzen config....
@nicoloma sagte in Error Log Controller Iobroker:
Ich nicht. Ich sehe da nur, das 'irgendwas' den Speicher im Heap auffrisst.
Kannst ja mal durch deine Skripte gehen. -
Ich bin dir für jeden Vorschlag dankbar! Aber wenn ich den Javascript-Adapter stoppe sollen doch alle Skripte auch nicht mehr laufen?
Oder laufen Sie vielleicht im Hintergrund weiter? -
Ich habe schon den Node Option auf
Node: -max_old_space_size=8192 erhöt.
dan habe ich
npm install -g increase-memory-limit
durchgeführt..
Hat auch nichts gebraucht
@Thomas-Braun kennst du eine gute Anleitung für einen evetuellen Umzug?
OCH LEUTE * Ich bin stink sauer*
Ich glaube ich habe es jetzt.Aus unerklärlichen Gründen, hatte der Trashsheduleadapater eine limitierung von 20MB!
JUHU!!!!!
Trotzdem allen vielen dank. Jetzt muss ich nur noch schauen, warum VIS bei mir nicht funktioniert!
