    4. Diskussion zum HowTo nodejs-Installation und upgrade
      djsirius @Thomas Braun last edited by djsirius
      Skript v.2023-10-10
      *** BASE SYSTEM ***
         Static hostname: raspberrypi
               Icon name: computer
        Operating System: Debian GNU/Linux 11 (bullseye)
                  Kernel: Linux 6.1.21-v8+
            Architecture: arm64
      Model           : Raspberry Pi 3 Model B Rev 1.2
      Docker          : false
      Virtualization  : none
      Kernel          : aarch64
      Userland        : arm64
      Systemuptime and Load:
       09:27:08 up 14:00,  1 user,  load average: 2.07, 2.00, 1.17
      CPU threads: 4
      *** RASPBERRY THROTTLING ***
      Current issues:
      Previously detected issues:
      *** Time and Time Zones ***
                     Local time: Thu 2024-01-04 09:27:08 CET
                 Universal time: Thu 2024-01-04 08:27:08 UTC
                       RTC time: n/a
                    NTP service: active
                RTC in local TZ: no
      *** User and Groups ***
      pi
      /home/pi
      pi adm dialout cdrom sudo audio video plugdev games users input render netdev gpio i2c spi iobroker
      *** X-Server-Setup ***
      X-Server:       false
      Desktop:
      Terminal:       tty
      Boot Target:    multi-user.target
      *** MEMORY ***
      Mem:            909M        589M         64M        0.0K        255M        260M
      Swap:            99M         99M        0.0K
      Total:          1.0G        689M         64M
                909 M total memory
                590 M used memory
                416 M active memory
                344 M inactive memory
                 63 M free memory
                  9 M buffer memory
                246 M swap cache
                 99 M total swap
                 99 M used swap
                  0 M free swap
      Raspberry only:
      oom events: 0
      *** FAILED SERVICES ***
      0 loaded units listed.
      *** FILESYSTEM ***
      /dev/root      ext4       59G   32G   25G  57% /
      devtmpfs       devtmpfs  325M     0  325M   0% /dev
      tmpfs          tmpfs     455M     0  455M   0% /dev/shm
      tmpfs          tmpfs     182M 1020K  181M   1% /run
      /dev/mmcblk0p1 vfat      255M   31M  225M  13% /boot
      tmpfs          tmpfs      91M     0   91M   0% /run/user/1000
      tmpfs          tmpfs      91M     0   91M   0% /run/user/0
      [Wed Jan  3 19:27:05 2024] Kernel command line: coherent_pool=1M 8250.nr_uarts=0 snd_bcm2835.enable_headphones=0 snd_bcm2835.enable_headphones=1 snd_bcm2835.enable_hdmi=1 snd_bcm2835.enable_hdmi=0 video=Composite-1:720x480@60i vc_mem.mem_base=0x3ec00000 vc_mem.mem_size=0x40000000  console=ttyS0,115200 console=tty1 root=PARTUUID=d3cf0315-02 rootfstype=ext4 fsck.repair=yes rootwait
      [Wed Jan  3 19:27:08 2024] EXT4-fs (mmcblk0p2): INFO: recovery required on readonly filesystem
      [Wed Jan  3 19:27:08 2024] EXT4-fs (mmcblk0p2): write access will be enabled during recovery
      [Wed Jan  3 19:27:08 2024] EXT4-fs (mmcblk0p2): orphan cleanup on readonly fs
      [Wed Jan  3 19:27:08 2024] EXT4-fs (mmcblk0p2): 4 orphan inodes deleted
      [Wed Jan  3 19:27:08 2024] EXT4-fs (mmcblk0p2): recovery complete
      [Wed Jan  3 19:27:08 2024] EXT4-fs (mmcblk0p2): mounted filesystem with ordered data mode. Quota mode: none.
      [Wed Jan  3 19:27:08 2024] VFS: Mounted root (ext4 filesystem) readonly on device 179:2.
      [Wed Jan  3 19:27:12 2024] EXT4-fs (mmcblk0p2): re-mounted. Quota mode: none.
      TARGET  SOURCE         FSTYPE OPTIONS
      /       /dev/mmcblk0p2 ext4   rw,noatime
      `-/boot /dev/mmcblk0p1 vfat   rw,relatime,fmask=0022,dmask=0022,codepage=437,iocharset=ascii,shortname=mixed,errors=remount-ro
      /var:
      27G     /var/
      22G     /var/lib/mysql/iobroker
      22G     /var/lib/mysql
      22G     /var/lib
      4.5G    /var/log
      Archived and active journals take up 4.0G in the file system.
      /opt/iobroker/backups:
      4.0K    /opt/iobroker/backups/
      /opt/iobroker/iobroker-data:
      18M     /opt/iobroker/iobroker-data/
      14M     /opt/iobroker/iobroker-data/files
      13M     /opt/iobroker/iobroker-data/files/admin.admin/custom/static/js
      6.3M    /opt/iobroker/iobroker-data/files/admin.admin/custom/static/js/vendors-node_modules_iobroker_adapter-react-v5_assets_devices_parseNames_js-node_modules_iobr-99c23e.847b8ad9.chunk.js.map
      3.0M    /opt/iobroker/iobroker-data/objects.jsonl
      2.8M    /opt/iobroker/iobroker-data/files/admin.admin/custom/static/js/vendors-node_modules_iobroker_adapter-react-v5_assets_devices_parseNames_js-node_modules_iobr-99c23e.847b8ad9.chunk.js
      1.6M    /opt/iobroker/iobroker-data/files/admin.admin/custom/static/js/vendors-node_modules_mui_material_Accordion_index_js-node_modules_mui_material_AccordionDetai-57e02d.0886b730.chunk.js.map
      652K    /opt/iobroker/iobroker-data/files/admin.admin/custom/static/js/vendors-node_modules_mui_material_index_js.40e01f69.chunk.js.map
      USB-Devices by-id:
      /dev/serial/by-id/usb-1a86_USB_Serial-if00-port0
      *** NodeJS-Installation ***
      /usr/bin/nodejs         v18.19.0
      /usr/bin/node           v18.19.0
      /usr/bin/npm            10.2.3
      /usr/bin/npx            10.2.3
      /usr/bin/corepack       0.22.0
      nodejs:
        Installed: 18.19.0-1nodesource1
        Candidate: 18.19.0-1nodesource1
        Version table:
       *** 18.19.0-1nodesource1 500
              100 /var/lib/dpkg/status
           18.18.2-1nodesource1 500
           18.18.1-1nodesource1 500
           18.18.0-1nodesource1 500
           18.17.1-1nodesource1 500
           18.17.0-1nodesource1 500
           18.16.1-1nodesource1 500
           18.16.0-1nodesource1 500
           18.15.0-1nodesource1 500
           18.14.2-1nodesource1 500
           18.14.1-1nodesource1 500
           18.14.0-1nodesource1 500
           18.13.0-1nodesource1 500
           18.12.0-1nodesource1 500
           18.11.0-1nodesource1 500
           18.10.0-1nodesource1 500
           18.9.1-1nodesource1 500
           18.9.0-1nodesource1 500
           18.8.0-1nodesource1 500
           18.7.0-1nodesource1 500
           18.6.0-1nodesource1 500
           18.5.0-1nodesource1 500
           18.4.0-1nodesource1 500
           18.3.0-1nodesource1 500
           18.2.0-1nodesource1 500
           18.1.0-1nodesource1 500
           18.0.0-1nodesource1 500
           12.22.12~dfsg-1~deb11u4 500
              500 http://deb.debian.org/debian bullseye/main arm64 Packages
              500 http://security.debian.org/debian-security bullseye-security/main arm64 Packages
      No problems detected
      Errors in npm tree:
      *** ioBroker-Installation ***
      ioBroker Status
      At least one iobroker host is running.
      Objects type: jsonl
      States  type: jsonl
      Core adapters versions
      js-controller:  4.0.24
      admin:          6.12.0
      javascript:     "javascript" not found
      Adapters from github:   0
      Adapter State
      + system.adapter.admin.0                  : admin                 : debian                                   -  enabled, port: 8081, bind: 0.0.0.0 (SSL), run as: admin
      + system.adapter.alexa2.0                 : alexa2                : debian                                   -  enabled
      + system.adapter.backitup.0               : backitup              : debian                                   -  enabled
        system.adapter.daswetter.0              : daswetter             : debian                                   -  enabled
        system.adapter.devices.0                : devices               : debian                                   -  enabled
      + system.adapter.discovery.0              : discovery             : debian                                   -  enabled
        system.adapter.dwd.0                    : dwd                   : debian                                   -  enabled
      + system.adapter.enigma2.0                : enigma2               : raspberrypi                              -  enabled
        system.adapter.feiertage.0              : feiertage             : debian                                   -  enabled
        system.adapter.flot.0                   : flot                  : debian                                   -  enabled
      + system.adapter.history.0                : history               : debian                                   -  enabled
      + system.adapter.hm-rega.0                : hm-rega               : debian                                   -  enabled
      + system.adapter.hm-rpc.0                 : hm-rpc                : debian                                   -  enabled, port: 0
      + system.adapter.hm-rpc.1                 : hm-rpc                : debian                                   -  enabled, port: 0
        system.adapter.ical.0                   : ical                  : debian                                   -  enabled
        system.adapter.ical.1                   : ical                  : debian                                   -  enabled
        system.adapter.ical.2                   : ical                  : debian                                   -  enabled
        system.adapter.icons-mfd-png.0          : icons-mfd-png         : debian                                   -  enabled
        system.adapter.icons-mfd-svg.0          : icons-mfd-svg         : debian                                   -  enabled
      + system.adapter.info.0                   : info                  : debian                                   -  enabled
      + system.adapter.iot.0                    : iot                   : debian                                   -  enabled
      + system.adapter.javascript.0             : javascript            : debian                                   -  enabled
      + system.adapter.lg-thinq.0               : lg-thinq              : debian                                   -  enabled
      + system.adapter.linux-control.0          : linux-control         : debian                                   -  enabled
      + system.adapter.logparser.0              : logparser             : debian                                   -  enabled
      + system.adapter.meross.0                 : meross                : debian                                   -  enabled
      + system.adapter.mihome-vacuum.0          : mihome-vacuum         : debian                                   -  enabled, port: 54321
        system.adapter.mobile.0                 : mobile                : debian                                   -  enabled
      + system.adapter.modbus.0                 : modbus                : debian                                   -  enabled
      + system.adapter.openligadb.0             : openligadb            : debian                                   -  enabled
      + system.adapter.ping.0                   : ping                  : debian                                   -  enabled
      + system.adapter.pollenflug.0             : pollenflug            : debian                                   -  enabled
      + system.adapter.rpi2.1                   : rpi2                  : raspberrypi                              -  enabled
      + system.adapter.scenes.0                 : scenes                : debian                                   -  enabled
      + system.adapter.shelly.0                 : shelly                : debian                                   -  enabled, port: 1882, bind: 0.0.0.0
      + system.adapter.simple-api.0             : simple-api            : debian                                   -  enabled, port: 8087, bind: 0.0.0.0, run as: admin
      + system.adapter.socketio.0               : socketio              : debian                                   -  enabled, port: 8084, bind: 0.0.0.0 (SSL), run as: admin
      + system.adapter.sql.0                    : sql                   : debian                                   -  enabled, port: 3306
      + system.adapter.systeminfo.0             : systeminfo            : debian                                   -  enabled
      + system.adapter.tankerkoenig.0           : tankerkoenig          : debian                                   -  enabled
      + system.adapter.telegram.0               : telegram              : debian                                   -  enabled, port: 8443, bind: 0.0.0.0
      + system.adapter.terminal.0               : terminal              : debian                                   -  enabled, port: 8088, bind: 0.0.0.0, run as: admin
      + system.adapter.text2command.0           : text2command          : debian                                   -  enabled
      + system.adapter.tibberlink.0             : tibberlink            : debian                                   -  enabled
      + system.adapter.tr-064.0                 : tr-064                : debian                                   -  enabled
      + system.adapter.trashschedule.0          : trashschedule         : debian                                   -  enabled
      + system.adapter.upnp.0                   : upnp                  : debian                                   -  enabled
      + system.adapter.viessmannapi.0           : viessmannapi          : debian                                   -  enabled
        system.adapter.vis-bars.0               : vis-bars              : debian                                   -  enabled
        system.adapter.vis-canvas-gauges.0      : vis-canvas-gauges     : debian                                   -  enabled
        system.adapter.vis-colorpicker.0        : vis-colorpicker       : debian                                   -  enabled
        system.adapter.vis-fancyswitch.0        : vis-fancyswitch       : debian                                   -  enabled
        system.adapter.vis-history.0            : vis-history           : debian                                   -  enabled
        system.adapter.vis-hqwidgets.0          : vis-hqwidgets         : debian                                   -  enabled
        system.adapter.vis-jqui-mfd.0           : vis-jqui-mfd          : debian                                   -  enabled
        system.adapter.vis-justgage.0           : vis-justgage          : debian                                   -  enabled
        system.adapter.vis-materialdesign.0     : vis-materialdesign    : debian                                   -  enabled
        system.adapter.vis-metro.0              : vis-metro             : debian                                   -  enabled
        system.adapter.vis-plumb.0              : vis-plumb             : debian                                   -  enabled
        system.adapter.vis-timeandweather.0     : vis-timeandweather    : debian                                   -  enabled
        system.adapter.vis-weather.0            : vis-weather           : debian                                   -  enabled
        system.adapter.vis.0                    : vis                   : debian                                   -  enabled
      + system.adapter.web.0                    : web                   : debian                                   -  enabled, port: 8082, bind: 0.0.0.0, run as: admin
      + system.adapter.zigbee.0                 : zigbee                : raspberrypi                              -  enabled, port: /dev/ttyUSB0
      + instance is alive
      ioBroker-Repositories
      Active repo(s): stable
      Installed ioBroker-Instances
      Used repository: stable
      Adapter    "admin"        : 6.12.0   , installed 6.12.0
      Adapter    "enigma2"      : 2.0.5    , installed 2.0.5
      Controller "js-controller": 5.0.17   , installed 4.0.24 [Updatable]
      Adapter    "unifi"        : 0.6.7    , installed 0.6.7
      Adapter    "zigbee"       : 1.9.5    , installed 1.8.23 [Updatable]
      Objects and States
      Objects:        27972
      States:         22604
      Hit:1 http://deb.debian.org/debian bullseye InRelease
      Hit:2 http://deb.debian.org/debian bullseye-updates InRelease
      Hit:3 http://security.debian.org/debian-security bullseye-security InRelease
      Hit:4 http://archive.raspberrypi.org/debian bullseye InRelease
      Hit:5 https://deb.nodesource.com/node_18.x nodistro InRelease
      Reading package lists...
      Pending Updates: 0
      *** Listening Ports ***
      tcp        0      0 0.0.0.0:22              0.0.0.0:*               LISTEN      0          11952      526/sshd: /usr/sbin
      tcp6       0      0 :::22                   :::*                    LISTEN      0          11954      526/sshd: /usr/sbin
      tcp6       0      0 :::3306                 :::*                    LISTEN      110        14596      568/mariadbd
      udp        0      0 0.0.0.0:5353            0.0.0.0:*                           108        12753      394/avahi-daemon: r
      udp        0      0 0.0.0.0:58923           0.0.0.0:*                           108        12755      394/avahi-daemon: r
      udp        0      0 0.0.0.0:68              0.0.0.0:*                           0          12822      697/dhcpcd
      udp6       0      0 :::5353                 :::*                                108        12754      394/avahi-daemon: r
      udp6       0      0 :::59929                :::*                                108        12756      394/avahi-daemon: r
      udp6       0      0 :::546                  :::*                                0          12083      697/dhcpcd
      2024-01-04 08:46:50.276  - info: zigbee.0 (129073)   --> transmitPower : normal
      2024-01-04 08:46:50.308  - info: zigbee.0 (129073) Currently 18 devices are joined:
      2024-01-04 08:46:50.630  - info: zigbee.0 (129073) 0x00158d00069b00d3 (addr 12111): WSDCGQ11LM - Xiaomi Aqara temperature, humidity and pressure sensor (EndDevice)
      2024-01-04 08:46:50.642  - info: zigbee.0 (129073) 0x00158d00053f42d6 (addr 25476): MCCGQ11LM - Xiaomi Aqara door & window contact sensor (EndDevice)
      2024-01-04 08:46:50.652  - info: zigbee.0 (129073) 0x00124b001f7a8b1c (addr 48495): GL-C-007-2ID - Gledopto Zigbee LED Controller RGBW (2 ID) (Router)
      2024-01-04 08:46:50.658  - info: zigbee.0 (129073) 0x00158d00045ced13 (addr 57845): MCCGQ11LM - Xiaomi Aqara door & window contact sensor (EndDevice)
      2024-01-04 08:46:50.663  - info: zigbee.0 (129073) 0x7cb03eaa0a07df5f (addr 3784): AC03641 - OSRAM LIGHTIFY LED Classic A60 clear (Router)
      2024-01-04 08:46:50.667  - info: zigbee.0 (129073) 0x00158d00053f72a6 (addr 38940): MCCGQ11LM - Xiaomi Aqara door & window contact sensor (EndDevice)
      2024-01-04 08:46:50.671  - info: zigbee.0 (129073) 0x00158d0006a034d9 (addr 9912): WSDCGQ11LM - Xiaomi Aqara temperature, humidity and pressure sensor (EndDevice)
      2024-01-04 08:46:50.675  - info: zigbee.0 (129073) 0x7cb03eaa0a07df70 (addr 52141): AC03641 - OSRAM LIGHTIFY LED Classic A60 clear (Router)
      2024-01-04 08:46:50.681  - info: zigbee.0 (129073) 0xb4e3f9fffe8119c5 (addr 52016): E1603/E1702/E1708 - IKEA TRADFRI control outlet (Router)
      2024-01-04 08:46:50.685  - info: zigbee.0 (129073) 0xb4e3f9fffe810ccf (addr 7537): E1603/E1702/E1708 - IKEA TRADFRI control outlet (Router)
      2024-01-04 08:46:50.690  - info: zigbee.0 (129073) 0x00158d00068b6d42 (addr 4761): WSDCGQ11LM - Xiaomi Aqara temperature, humidity and pressure sensor (EndDevice)
      2024-01-04 08:46:50.693  - info: zigbee.0 (129073) 0x00158d00069c5148 (addr 61445): MCCGQ11LM - Xiaomi Aqara door & window contact sensor (EndDevice)
      2024-01-04 08:46:50.697  - info: zigbee.0 (129073) 0x00158d00069d3207 (addr 54025): MCCGQ11LM - Xiaomi Aqara door & window contact sensor (EndDevice)
      2024-01-04 08:46:50.701  - info: zigbee.0 (129073) 0x00158d00047dd980 (addr 56066): MCCGQ11LM - Xiaomi Aqara door & window contact sensor (EndDevice)
      2024-01-04 08:46:50.706  - info: zigbee.0 (129073) 0x00158d00069ae75b (addr 18976): MCCGQ11LM - Xiaomi Aqara door & window contact sensor (EndDevice)
      2024-01-04 08:46:50.712  - info: zigbee.0 (129073) 0x00158d00069c52b6 (addr 10299): MCCGQ11LM - Xiaomi Aqara door & window contact sensor (EndDevice)
      2024-01-04 08:46:50.716  - info: zigbee.0 (129073) 0x00158d00053fad60 (addr 54656): MCCGQ11LM - Xiaomi Aqara door & window contact sensor (EndDevice)
      2024-01-04 08:46:50.720  - info: zigbee.0 (129073) 0x00158d000659e158 (addr 22041): WSDCGQ11LM - Xiaomi Aqara temperature, humidity and pressure sensor (EndDevice)
      2024-01-04 08:46:50.723  - info: zigbee.0 (129073) Zigbee started
      2024-01-04 08:46:50.937  - info: zigbee.0 (129073) debug devices set to []
      2024-01-04 08:47:10.049  - warn: zigbee.0 (129073) DeviceAvailability:Failed to ping 0x7cb03eaa0a07df70 Classic A60 W clear - LIGHTIFY
      2024-01-04 09:18:02.612  - warn: zigbee.0 (129073) DeviceAvailability:Stopping to ping 0x7cb03eaa0a07df70 Classic A60 W clear - LIGHTIFY after 4 ping attempts
      2024-01-04 09:28:52.925  - warn: zigbee.0 (129073) Device '0x7cb03eaa0a07df70' announced itself
      iob diag has finished.
      Log sagt nichts, da ich das Update irgendwann abbreche, weil es nicht weiter geht.
      host.raspberrypi
      2024-01-04 09:34:57.508	info	iobroker Installing iobroker.zigbee@1.9.5... (System call)
      host.raspberrypi
      2024-01-04 09:34:57.504	info	iobroker NPM version: 10.2.3
      host.raspberrypi
      2024-01-04 09:34:56.787	info	instance system.adapter.zigbee.0 terminated with code 11 (ADAPTER_REQUESTED_TERMINATION)
      host.raspberrypi
      2024-01-04 09:34:56.225	info	stopInstance system.adapter.zigbee.0 killing pid 129073
      host.raspberrypi
      2024-01-04 09:34:55.220	info	stopInstance system.adapter.zigbee.0 send kill signal
      host.raspberrypi
      2024-01-04 09:34:55.108	info	stopInstance system.adapter.zigbee.0 (force=false, process=true)
      host.raspberrypi
      2024-01-04 09:34:55.103	info	"system.adapter.zigbee.0" disabled
      host.raspberrypi
      2024-01-04 09:34:55.087	info	iobroker host.raspberrypi Adapter "system.adapter.zigbee.0" is stopped.
      host.raspberrypi
      2024-01-04 09:34:55.025	info	iobroker Update zigbee from @1.8.23 to @1.9.5
      host.raspberrypi
      2024-01-04 09:34:50.295	info	iobroker upgrade zigbee@1.9.5 --debug
      Thomas Braun DJMarc75 3 Replies Last reply Reply Quote 0
        Thomas Braun Most Active @djsirius last edited by
        @djsirius sagte in Diskussion zum HowTo nodejs-Installation und upgrade:
        Dann lass es einfach mal laufen...
        • DJMarc75
          DJMarc75 @djsirius last edited by
          @djsirius
          So am Rande: auf einem RPI3 mit 1 GB RAM sind 30+ aktive Instanzen mehr als sportlich.
          Dir geht definitiv der Speicher aus.
            Dein Dateisystem hat 'nen Treffer.
            Update den js-controller.
              djsirius @DJMarc75 last edited by
              @djmarc75 auf dem System laufen nur 3 Instanzen, es handelt sich hierbei um ein Slave.
                @thomas-braun Ich habe das Update um 09:34 gestartet und es hängt noch immer. 😞
                  Nein, das läuft noch immer. Finger weg, laufen lassen.
                    Es hat sich nichts mehr getan. Hab jetzt versucht auf meinem Master den js-controller zu updaten.
                    Leider bleibt er auch hängen.
                    /opt/iobroker$ iob upgrade self
                    Update js-controller from @4.0.24 to @5.0.17
                    Stopped Objects DB
                    Stopped States DB
                    NPM version: 10.2.3
                    Installing iobroker.js-controller@5.0.17... (System call)
                      Homoran Global Moderator Administrators @djsirius last edited by
                      @djsirius dann mach es mal mit --debug
                        djsirius @Homoran last edited by
                        @homoran keine Veränderung
                        iobroker@debian:~$ cd /opt/iobroker
                        iobroker@debian:/opt/iobroker$ iobroker stop
                        iobroker@debian:/opt/iobroker$ iob upgrade self --debug
                        Stopped Objects DB
                        Stopped States DB
                        NPM version: 10.2.3
                          keine Veränderung
                          was bedeutet
                          denn in Zahlen?
                          wie sieht es denn
                          auf meinem Master
                          mit iob diag aus?
                          was ist das für ein Rechner?
                          hast du mal eine zweite Terminalsession aufgemacht und z.B. mit top nachgesehen was da gerade rödelt?
                            @homoran said in Diskussion zum HowTo nodejs-Installation und upgrade:
                            iob diag
                            ich habe das update für den js-controller über eine Terminalverbindung gemacht. Da Update bleibt einfach stehen. Ich bekomme weiter nichts angezeigt. Nach Installing iobroker.js-controller@5.0.17... (System call)
                            geht es nicht weiter. Bis ich das Update abbreche.
                            Skript v.2023-10-10
                            *** BASE SYSTEM ***
                               Static hostname: debian
                                     Icon name: computer-desktop
                                       Chassis: desktop
                                        Kernel: Linux 5.10.0-26-amd64
                                  Architecture: x86-64
                            model name      : Intel(R) Core(TM) i5-2400 CPU @ 3.10GHz
                            Docker          : false
                            Kernel          : x86_64
                            Userland        : amd64
                             13:50:42 up 18:23,  1 user,  load average: 0.00, 0.00, 0.01
                            CPU threads: 4
                                           Local time: Thu 2024-01-04 13:50:42 CET
                                       Universal time: Thu 2024-01-04 12:50:42 UTC
                                             RTC time: Thu 2024-01-04 12:50:42
                                          NTP service: active
                                      RTC in local TZ: no
                            iobroker
                            /home/iobroker
                            iobroker tty dialout cdrom floppy sudo audio dip video plugdev netdev bluetooth lpadmin scanner
                            X-Server:       false
                            Desktop:
                            Terminal:       tty
                            *** MEMORY ***
                            Mem:            7.9G        201M        6.9G        5.0M        740M        7.4G
                            Swap:           4.0G          0B        4.0G
                            Total:           11G        201M         10G
                                     7864 M total memory
                                      201 M used memory
                                      377 M active memory
                                      392 M inactive memory
                                     6923 M free memory
                                       85 M buffer memory
                                      655 M swap cache
                                     4015 M total swap
                                        0 M used swap
                                     4015 M free swap
                              UNIT             LOAD   ACTIVE SUB    DESCRIPTION
                            * iobroker.service loaded failed failed ioBroker Server
                            LOAD   = Reflects whether the unit definition was properly loaded.
                            ACTIVE = The high-level unit activation state, i.e. generalization of SUB.
                            SUB    = The low-level unit activation state, values depend on unit type.
                            1 loaded units listed.
                            *** FILESYSTEM ***
                            Filesystem                         Type      Size  Used Avail Use% Mounted on
                            udev                               devtmpfs  3.9G     0  3.9G   0% /dev
                            tmpfs                              tmpfs     787M  2.5M  785M   1% /run
                            /dev/sda2                          ext4      454G   44G  387G  11% /
                            tmpfs                              tmpfs     3.9G     0  3.9G   0% /dev/shm
                            tmpfs                              tmpfs     5.0M  4.0K  5.0M   1% /run/lock
                            /dev/sda1                          vfat      511M  5.8M  506M   2% /boot/efi
                            //192.168.1.1/GLADYS7490/TREKSTOR/ cifs      467G  353G  114G  76% /media/fritzbox
                            tmpfs                              tmpfs     787M   40K  787M   1% /run/user/1000
                            [Wed Jan  3 19:27:32 2024] EXT4-fs (sda2): mounted filesystem with ordered data mode. Opts: (null)
                            [Wed Jan  3 19:27:39 2024] EXT4-fs (sda2): re-mounted. Opts: errors=remount-ro
                            /                 /dev/sda2                          ext4   rw,relatime,errors=remount-ro
                            |-/media/fritzbox //192.168.1.1/GLADYS7490/TREKSTOR/ cifs   rw,relatime,vers=1.0,cache=strict,username=mount,uid=1000,forceuid,gid=1000,forcegid,addr=192.168.1.1,file_mode=0755,dir_mode=0755,soft,nounix,serverino,mapposix,rsize=61440,wsize=65536,bsize=1048576,echo_interval=60,actimeo=1
                            `-/boot/efi       /dev/sda1                          vfat   rw,relatime,fmask=0077,dmask=0077,codepage=437,iocharset=ascii,shortname=mixed,utf8,errors=remount-ro
                            /var:
                            7.3G    /var/
                            4.1G    /var/log
                            4.0G    /var/log/journal/f063d3dd2a6e40efad76adb6a70d9daf
                            2.4G    /var/cache/apt
                            Archived and active journals take up 3.6G in the file system.
                            115M    /opt/iobroker/backups/
                            1.1G    /opt/iobroker/iobroker-data/
                            600M    /opt/iobroker/iobroker-data/files
                            357M    /opt/iobroker/iobroker-data/backup-objects
                            73M     /opt/iobroker/iobroker-data/files/telegram.admin
                            67M     /opt/iobroker/iobroker-data/files/javascript.admin
                            60M     /opt/iobroker/iobroker-data/states.jsonl
                            35M     /opt/iobroker/iobroker-data/files/devices.admin/static/js/main.24f2bb56.js.map
                            33M     /opt/iobroker/iobroker-data/files/iot.admin/static/js/main.1797d034.js.map
                            31M     /opt/iobroker/iobroker-data/objects.jsonl
                            22M     /opt/iobroker/iobroker-data/files/modbus.admin/static/js/main.b5f6766c.js.map
                            USB-Devices by-id:
                            /usr/bin/npm            10.2.3
                            /usr/bin/npx            10.2.3
                            nodejs:
                              Version table:
                                    500 https://deb.nodesource.com/node_18.x nodistro/main amd64 Packages
                                    500 http://ftp.de.debian.org/debian bullseye/main amd64 Packages
                                    500 http://deb.debian.org/debian bullseye/main amd64 Packages
                            Errors in npm tree:
                            npm ERR! code ELSPROBLEMS
                            npm ERR! extraneous: @types/caseless@0.12.5 /opt/iobroker/node_modules/@types/caseless
                            npm ERR! extraneous: @types/request@2.48.12 /opt/iobroker/node_modules/@types/request
                            npm ERR! extraneous: @types/tough-cookie@4.0.5 /opt/iobroker/node_modules/@types/tough-cookie
                            npm ERR! extraneous: coffeescript@2.7.0 /opt/iobroker/node_modules/coffeescript
                            npm ERR! invalid: iobroker.openligadb@1.3.4 /opt/iobroker/node_modules/iobroker.openligadb
                            npm ERR! invalid: iobroker.tibberconnect@0.0.10 /opt/iobroker/node_modules/iobroker.tibberconnect
                            npm ERR! extraneous: jsonata@2.0.3 /opt/iobroker/node_modules/jsonata
                            npm ERR! extraneous: node-inspect@2.0.0 /opt/iobroker/node_modules/node-inspect
                            npm ERR! extraneous: picocolors@1.0.0 /opt/iobroker/node_modules/picocolors
                            npm ERR! extraneous: suncalc2@1.8.1 /opt/iobroker/node_modules/suncalc2
                            npm ERR! extraneous: typescript@5.2.2 /opt/iobroker/node_modules/typescript
                            npm ERR! extraneous: virtual-tsc@0.6.2 /opt/iobroker/node_modules/virtual-tsc
                            npm ERR! extraneous: wake_on_lan@1.0.0 /opt/iobroker/node_modules/wake_on_lan
                            npm ERR! extraneous: form-data@2.5.1 /opt/iobroker/node_modules/@types/request/node_modules/form-data
                            npm ERR! extraneous: debug@4.3.4 /opt/iobroker/node_modules/virtual-tsc/node_modules/debug
                            npm ERR! extraneous: ms@2.1.2 /opt/iobroker/node_modules/virtual-tsc/node_modules/ms
                            npm ERR! invalid: xmlbuilder@0.4.2 /opt/iobroker/node_modules/xmlbuilder
                            npm ERR! invalid: buffer@5.7.1 /opt/iobroker/node_modules/buffer
                            npm ERR! A complete log of this run can be found in: /home/iobroker/.npm/_logs/2024-01-04T12_51_00_273Z-debug-0.log
                            ioBroker Status
                            iobroker is not running on this host.
                            Objects type: jsonl
                            States  type: jsonl
                            admin:          6.12.0
                            javascript:     7.1.6
                            npm ERR! A complete log of this run can be found in: /home/iobroker/.npm/_logs/2024-01-04T12_51_19_738Z-debug-0.log
                            Adapters from github:   2
                            Adapter State
                              system.adapter.zigbee.0                 : zigbee                : raspberrypi                              - disabled, port: /dev/ttyUSB0
                            + instance is alive
                            Adapter    "alexa2"       : 3.26.3   , installed 3.26.2 [Updatable]
                            Adapter    "backitup"     : 2.9.8    , installed 2.8.7  [Updatable]
                            Adapter    "daswetter"    : 3.1.11   , installed 3.1.11
                            Adapter    "feiertage"    : 1.1.4    , installed 1.1.4
                            Adapter    "hm-rega"      : 4.0.0    , installed 4.0.0
                            Adapter    "hm-rpc"       : 1.15.19  , installed 1.15.19
                            Adapter    "iot"          : 2.0.11   , installed 2.0.11
                            Adapter    "javascript"   : 7.1.6    , installed 7.1.6
                            Adapter    "lg-thinq"     : 0.1.4    , installed 0.1.4
                            Adapter    "linux-control": 1.1.5    , installed 1.1.5
                            Adapter    "logparser"    : 2.2.0    , installed 2.2.0
                            Adapter    "meross"       : 1.16.1   , installed 1.16.1
                            Adapter    "mihome-vacuum": 4.1.0    , installed 4.1.0
                            Adapter    "mobile"       : 1.0.1    , installed 1.0.1
                            Adapter    "modbus"       : 6.0.1    , installed 6.0.1
                            Adapter    "openligadb"   : 1.2.4    , installed 1.3.4
                            Adapter    "pollenflug"   : 1.0.6    , installed 1.0.6
                            Adapter    "shelly"       : 6.6.1    , installed 6.6.1
                            Adapter    "sql"          : 2.2.0    , installed 2.2.0
                            Adapter    "systeminfo"   : 1.1.0    , installed 1.1.0
                            Adapter    "telegram"     : 3.0.1    , installed 3.0.1
                            Adapter    "terminal"     : 1.0.0    , installed 1.0.0
                            Adapter    "text2command" : 3.0.2    , installed 3.0.2
                            Adapter    "tibberlink"   : 2.0.0    , installed 2.0.0
                            Adapter    "trashschedule": 2.3.0    , installed 2.3.0
                            Adapter    "upnp"         : 1.0.21   , installed 1.0.21
                            Adapter    "viessmannapi" : 2.3.0    , installed 2.3.0
                            Adapter    "vis-justgage" : 2.1.0    , installed 2.1.0
                            Adapter    "vis-weather"  : 2.5.6    , installed 2.5.6
                            Adapter    "web"          : 6.1.10   , installed 6.1.10
                            Adapter    "ws"           : 2.5.8    , installed 2.5.8
                            Objects and States
                            Objects:        27978
                            States:         22605
                            Hit:1 http://ftp.de.debian.org/debian bullseye InRelease
                            Hit:2 http://ftp.de.debian.org/debian bullseye-updates InRelease
                            Hit:3 http://deb.debian.org/debian bullseye InRelease
                            Hit:4 http://deb.debian.org/debian bullseye-updates InRelease
                            Hit:5 http://deb.debian.org/debian bullseye-backports InRelease
                            Hit:6 https://deb.nodesource.com/node_18.x nodistro InRelease
                            Hit:7 https://packages.sury.org/php bullseye InRelease
                            Hit:8 https://packagecloud.io/ookla/speedtest-cli/debian bullseye InRelease
                            Pending Updates: 0
                            tcp        0      0 0.0.0.0:445             0.0.0.0:*               LISTEN      0          16729      808/smbd
                            tcp        0      0 0.0.0.0:139             0.0.0.0:*               LISTEN      0          16730      808/smbd
                            tcp        0      0 0.0.0.0:111             0.0.0.0:*               LISTEN      0          618        1/init
                            tcp        0      0 0.0.0.0:22              0.0.0.0:*               LISTEN      0          1719       509/sshd: /usr/sbin
                            tcp        0      0 127.0.0.1:631           0.0.0.0:*               LISTEN      0          1073875    562579/cupsd
                            tcp        0      0 127.0.0.1:25            0.0.0.0:*               LISTEN      0          17439      800/exim4
                            tcp6       0      0 :::443                  :::*                    LISTEN      0          1851       787/apache2
                            tcp6       0      0 :::445                  :::*                    LISTEN      0          16727      808/smbd
                            tcp6       0      0 :::139                  :::*                    LISTEN      0          16728      808/smbd
                            tcp6       0      0 :::111                  :::*                    LISTEN      0          622        1/init
                            tcp6       0      0 :::80                   :::*                    LISTEN      0          1847       787/apache2
                            tcp6       0      0 :::22                   :::*                    LISTEN      0          1721       509/sshd: /usr/sbin
                            tcp6       0      0 ::1:631                 :::*                    LISTEN      0          1073874    562579/cupsd
                            tcp6       0      0 ::1:25                  :::*                    LISTEN      0          17440      800/exim4
                            udp        0      0 0.0.0.0:631             0.0.0.0:*                           0          1076452    562586/cups-browsed
                            udp        0      0 0.0.0.0:5353            0.0.0.0:*                           112        1609       419/avahi-daemon: r
                            udp        0      0 0.0.0.0:59503           0.0.0.0:*                           112        1611       419/avahi-daemon: r
                            udp        0      0 0.0.0.0:111             0.0.0.0:*                           0          619        1/init
                            udp        0      0 192.168.1.255:137       0.0.0.0:*                           0          18480      538/nmbd
                            udp        0      0 192.168.1.16:137        0.0.0.0:*                           0          18479      538/nmbd
                            udp        0      0 0.0.0.0:137             0.0.0.0:*                           0          18460      538/nmbd
                            udp        0      0 192.168.1.255:138       0.0.0.0:*                           0          18482      538/nmbd
                            udp        0      0 192.168.1.16:138        0.0.0.0:*                           0          18481      538/nmbd
                            udp        0      0 0.0.0.0:138             0.0.0.0:*                           0          18461      538/nmbd
                            udp6       0      0 fe80::ca9c:dcff:fee:546 :::*                                0          16340      422/NetworkManager
                            udp6       0      0 :::5353                 :::*                                112        1610       419/avahi-daemon: r
                            udp6       0      0 :::59025                :::*                                112        1612       419/avahi-daemon: r
                            udp6       0      0 :::111                  :::*                                0          625        1/init
                            2024-01-04 13:18:36.279  - info: host.debian instance system.adapter.linux-control.0 terminated with code 156 (START_IMMEDIATELY_AFTER_STOP)
                            2024-01-04 13:18:36.298  - info: host.debian instance system.adapter.pollenflug.0 terminated with code 156 (START_IMMEDIATELY_AFTER_STOP)
                            2024-01-04 13:18:36.341  - info: host.debian instance system.adapter.simple-api.0 terminated with code 156 (START_IMMEDIATELY_AFTER_STOP)
                            2024-01-04 13:18:36.341  - info: host.debian instance system.adapter.socketio.0 terminated with code 156 (START_IMMEDIATELY_AFTER_STOP)
                            2024-01-04 13:18:36.360  - info: host.debian instance system.adapter.terminal.0 terminated with code 156 (START_IMMEDIATELY_AFTER_STOP)
                            2024-01-04 13:18:36.377  - info: host.debian instance system.adapter.trashschedule.0 terminated with code 156 (START_IMMEDIATELY_AFTER_STOP)
                            2024-01-04 13:18:36.406  - info: host.debian instance system.adapter.viessmannapi.0 terminated with code 156 (START_IMMEDIATELY_AFTER_STOP)
                            2024-01-04 13:18:36.423  - info: host.debian instance system.adapter.logparser.0 terminated with code 156 (START_IMMEDIATELY_AFTER_STOP)
                            2024-01-04 13:18:36.460  - info: host.debian instance system.adapter.hm-rpc.1 terminated with code 156 (START_IMMEDIATELY_AFTER_STOP)
                            2024-01-04 13:18:36.460  - info: host.debian instance system.adapter.discovery.0 terminated with code 156 (START_IMMEDIATELY_AFTER_STOP)
                            2024-01-04 13:18:36.494  - info: host.debian instance system.adapter.iot.0 terminated with code 156 (START_IMMEDIATELY_AFTER_STOP)
                            2024-01-04 13:18:36.821  - info: host.debian instance system.adapter.javascript.0 terminated with code 156 (START_IMMEDIATELY_AFTER_STOP)
                            2024-01-04 13:18:36.839  - warn: host.debian instance system.adapter.telegram.0 terminated due to SIGTERM
                            2024-01-04 13:18:36.839  - info: host.debian instance system.adapter.telegram.0 terminated with code null ()
                            2024-01-04 13:18:36.861  - warn: host.debian instance system.adapter.ping.0 terminated due to SIGTERM
                            2024-01-04 13:18:36.861  - info: host.debian instance system.adapter.ping.0 terminated with code null ()
                            2024-01-04 13:18:36.885  - warn: host.debian instance system.adapter.text2command.0 terminated due to SIGTERM
                            2024-01-04 13:18:36.885  - info: host.debian instance system.adapter.text2command.0 terminated with code null ()
                            2024-01-04 13:18:36.902  - info: host.debian instance system.adapter.web.0 terminated with code 156 (START_IMMEDIATELY_AFTER_STOP)
                            2024-01-04 13:18:36.946  - info: host.debian instance system.adapter.sql.0 terminated with code 156 (START_IMMEDIATELY_AFTER_STOP)
                            2024-01-04 13:18:36.946  - info: host.debian instance system.adapter.history.0 terminated with code 156 (START_IMMEDIATELY_AFTER_STOP)
                            2024-01-04 13:18:37.290  - info: meross.0 (1962438) Terminated (START_IMMEDIATELY_AFTER_STOP): Without reason
                            2024-01-04 13:18:37.909  - info: host.debian instance system.adapter.meross.0 terminated with code 156 (START_IMMEDIATELY_AFTER_STOP)
                            2024-01-04 13:18:37.909  - info: host.debian All instances are stopped.
                            2024-01-04 13:18:38.089  - info: host.debian terminated
                            Homoran Thomas Braun 3 Replies Last reply Reply Quote 0
                              Homoran Global Moderator Administrators @djsirius last edited by Homoran
                              soweit ist das bekannt!
                              Die fehlenden Antworten auf die Fragen
                              • Wie lange hast du gewartet?
                              • hast du mit einer zweiten Session nachgesehen was da klemmt?
                              • wie sieht iob diag auf dem Master aus
                              bitte nachreichen
                                da läuft ja nix
                                Probleme mit npm?
                                s.o.
                                  Installier die beiden Adapter nochmal. Am besten NICHT über github, sondern eine 'ordentliche' Installation aus einem Repo.
                                    da läuft ja nix
                                    Probleme mit npm?
                                    s.o.
                                    Ich habe den iobroker gestoppt um das Update vom js-controller zu machen. Ist das falsch?
                                    Skript v.2023-10-10
                                    *** BASE SYSTEM ***
                                               Chassis: desktop
                                    Docker          : false
                                    Kernel          : x86_64
                                    Userland        : amd64
                                     15:01:52 up 19:34,  1 user,  load average: 0.37, 0.48, 0.28
                                    CPU threads: 4
                                                   Local time: Thu 2024-01-04 15:01:52 CET
                                               Universal time: Thu 2024-01-04 14:01:52 UTC
                                                     RTC time: Thu 2024-01-04 14:01:52
                                                  NTP service: active
                                              RTC in local TZ: no
                                    iobroker
                                    /home/iobroker
                                    X-Server:       false
                                    Desktop:
                                    Terminal:       tty
                                    *** MEMORY ***
                                    Mem:            7.9G        2.8G        3.9G        5.0M        1.1G        4.7G
                                    Swap:           4.0G          0B        4.0G
                                    Total:           11G        2.8G        7.9G
                                             7864 M total memory
                                             2838 M used memory
                                              684 M active memory
                                             2912 M inactive memory
                                             3928 M free memory
                                              121 M buffer memory
                                              976 M swap cache
                                             4015 M total swap
                                                0 M used swap
                                             4015 M free swap
                                    *** FILESYSTEM ***
                                    /var:
                                    7.3G    /var/
                                    4.1G    /var/log
                                    2.4G    /var/cache/apt
                                    70M     /opt/iobroker/iobroker-data/states.jsonl
                                    34M     /opt/iobroker/iobroker-data/objects.jsonl
                                    USB-Devices by-id:
                                    /usr/bin/npm            10.2.3
                                    /usr/bin/npx            10.2.3
                                    nodejs:
                                      Version table:
                                    Errors in npm tree:
                                    npm ERR! A complete log of this run can be found in: /home/iobroker/.npm/_logs/2024-01-04T14_01_54_476Z-debug-0.log
                                    ioBroker Status
                                    Objects type: jsonl
                                    States  type: jsonl
                                    admin:          6.12.0
                                    javascript:     7.1.6
                                    npm ERR! A complete log of this run can be found in: /home/iobroker/.npm/_logs/2024-01-04T14_02_02_971Z-debug-0.log
                                    Adapter State
                                    + instance is alive
                                    Objects and States
                                    Objects:        27978
                                    States:         22662
                                    Pending Updates: 0
                                    tcp        0      0 192.168.1.16:8701       0.0.0.0:*               LISTEN      1000       3906617    2073310/io.hm-rpc.1
                                    tcp        0      0 0.0.0.0:9000            0.0.0.0:*               LISTEN      1000       3901948    2072931/iobroker.js
                                    tcp        0      0 0.0.0.0:9001            0.0.0.0:*               LISTEN      1000       3901937    2072931/iobroker.js
                                    tcp        0      0 192.168.1.16:2001       0.0.0.0:*               LISTEN      1000       3903816    2073084/io.hm-rpc.0
                                    tcp        0      0 0.0.0.0:1882            0.0.0.0:*               LISTEN      1000       3904358    2073336/io.shelly.0
                                    tcp6       0      0 :::8081                 :::*                    LISTEN      1000       3903614    2072950/io.admin.0
                                    tcp6       0      0 :::8082                 :::*                    LISTEN      1000       3914125    2076273/io.web.0
                                    tcp6       0      0 :::8084                 :::*                    LISTEN      1000       3910869    2074746/io.socketio
                                    tcp6       0      0 :::8087                 :::*                    LISTEN      1000       3910040    2074489/io.simple-a
                                    tcp6       0      0 :::8088                 :::*                    LISTEN      1000       3911944    2075331/io.terminal
                                    udp        0      0 192.168.1.16:5353       0.0.0.0:*                           1000       3906800    2073282/io.tr-064.0
                                    udp        0      0 0.0.0.0:1900            0.0.0.0:*                           1000       3915805    2075908/io.upnp.0
                                    udp        0      0 0.0.0.0:57375           0.0.0.0:*                           1000       3912188    2075908/io.upnp.0
                                    udp        0      0 0.0.0.0:53421           0.0.0.0:*                           1000       3905755    2073211/io.mihome-v
                                    2024-01-04 14:57:07.416  - info: lg-thinq.0 (2076539) MQTT connected to: t20/op/4859c133c7b998076e20059473cf71b1ebd27dfe4321c9740a3ce75973cbbf5a/inbox
                                    2024-01-04 14:57:08.267  - info: host.debian instance system.adapter.tibberlink.0 started with pid 2076872
                                    2024-01-04 14:57:09.704  - info: tibberlink.0 (2076872) starting. Version 2.0.0 in /opt/iobroker/node_modules/iobroker.tibberlink, node: v18.19.0, js-controller: 4.0.24
                                    2024-01-04 14:57:28.874  - info: meross.0 (2073191) Can not get Data for Device 1912244352887225188148e1e9147e10: Error: Device has no data connection available
                                    2024-01-04 14:57:28.875  - warn: meross.0 (2073191) Can not get Data for Device 1912244352887225188148e1e9147e10: undefined
                                    2024-01-04 14:58:35.018  - info: meross.0 (2073191) Can not get Data for Device 1912244352887225188148e1e9147e10: Error: Device has no data connection available
                                    2024-01-04 14:58:35.019  - warn: meross.0 (2073191) Can not get Data for Device 1912244352887225188148e1e9147e10: undefined
                                    2024-01-04 14:59:41.163  - info: meross.0 (2073191) Can not get Data for Device 1912244352887225188148e1e9147e10: Error: Device has no data connection available
                                    2024-01-04 14:59:41.163  - warn: meross.0 (2073191) Can not get Data for Device 1912244352887225188148e1e9147e10: undefined
                                    2024-01-04 15:00:00.028  - info: host.debian instance system.adapter.dwd.0 started with pid 2083021
                                    2024-01-04 15:00:00.155  - info: javascript.0 (2072992) script.js.Speedtest: Speedtest mit Server 44081 gestartet! Der Test dauert zwischen 10 - 20 Sekunden!
                                    2024-01-04 15:00:01.308  - info: dwd.0 (2083021) starting. Version 2.8.5 in /opt/iobroker/node_modules/iobroker.dwd, node: v18.19.0, js-controller: 4.0.24
                                    2024-01-04 15:00:03.904  - info: dwd.0 (2083021) Terminated (ADAPTER_REQUESTED_TERMINATION): Without reason
                                    2024-01-04 15:00:04.035  - info: host.debian instance system.adapter.daswetter.0 started with pid 2083350
                                    2024-01-04 15:00:04.455  - info: host.debian instance system.adapter.dwd.0 terminated with code 11 (ADAPTER_REQUESTED_TERMINATION)
                                    2024-01-04 15:00:05.306  - info: daswetter.0 (2083350) starting. Version 3.1.11 in /opt/iobroker/node_modules/iobroker.daswetter, node: v18.19.0, js-controller: 4.0.24
                                    2024-01-04 15:00:13.817  - info: daswetter.0 (2083350) still wrong data structure from server received! repaired...
                                    2024-01-04 15:00:15.732  - info: daswetter.0 (2083350) Terminated (ADAPTER_REQUESTED_TERMINATION): All data handled, adapter stopped until next scheduled moment
                                    2024-01-04 15:00:16.243  - info: daswetter.0 (2083350) cleaned everything up...
                                    2024-01-04 15:00:16.258  - info: host.debian instance system.adapter.daswetter.0 terminated with code 11 (ADAPTER_REQUESTED_TERMINATION)
                                    2024-01-04 15:00:26.694  - info: javascript.0 (2072992) script.js.Speedtest: Speedtest durchgeführt. Ergebnisse: Download: 10.47 MB/s | Upload: 4.43 MB/s | Ping: 14.979ms
                                    2024-01-04 15:00:47.306  - info: meross.0 (2073191) Can not get Data for Device 1912244352887225188148e1e9147e10: Error: Device has no data connection available
                                    2024-01-04 15:00:47.307  - warn: meross.0 (2073191) Can not get Data for Device 1912244352887225188148e1e9147e10: undefined
                                    2024-01-04 15:01:53.450  - info: meross.0 (2073191) Can not get Data for Device 1912244352887225188148e1e9147e10: Error: Device has no data connection available
                                    2024-01-04 15:01:53.450  - warn: meross.0 (2073191) Can not get Data for Device 1912244352887225188148e1e9147e10: undefined
                                      @thomas-braun said in Diskussion zum HowTo nodejs-Installation und upgrade:
                                      Kann das denn das Problem sein? Es ist doch vor dem Update von Nodejs und NPM ja auch gelaufen.
                                        Das sorgt jedenfalls für die angemeckerten npm errors.
                                          Weil z.B. Openligadb läuft Version aus dem repo nicht ohne Fehler.
                                            @djsirius
                                            Dann installier es nochmal aus github. Es muss aber halt nochmal frisch draufgebügelt werden.
                                            81.1k
                                            nodejs
                                            91
                                            844
                                            228722
