    4. js-controller Update mit npm ERR
      Thomas Braun Most Active @Alex e last edited by
      @alex-e sagte in js-controller Update mit npm ERR:
      3.3.22
      Schrittweise die Versionen hochziehen.
      cd /opt/iobroker
      sudo -H -u iobroker npm install iobroker.js-controller@3.3.22
      iob update
      iob upgrade admin
      iob update
      sudo -H -u iobroker npm install iobroker.js-controller@4.0.0
      iob update
      iob upgrade
      iob stop
      iob upgrade self
      iob start
        Alex e @Thomas Braun last edited by
        ich komme zumindest etwas weiter 🙂 Vielen Dank nochmal!
        cd /opt/iobroker
        iob update
        iob upgrade admin
        iob update
        hat geklappt:
        pi@raspberrypi:~ $ iobroker stop
        pi@raspberrypi:~ $ cd /opt/iobroker
        pi@raspberrypi:/opt/iobroker $ sudo -H -u iobroker npm install iobroker.js-controller@3.3.22
        added 92 packages, removed 32 packages, and changed 52 packages in 2m
        125 packages are looking for funding
          run `npm fund` for details
        pi@raspberrypi:/opt/iobroker $ iob update
        Used repository: stable
        hash changed or no sources cached => force download of new sources
        Cannot get any information of "_repoInfo". Ignored.
        update done
        Adapter    "admin"         : 6.12.0   , installed 4.0.9 [Updateable]
        Adapter    "backitup"      : 2.8.7    , installed 2.8.1 [Updateable]
        Adapter    "daswetter"     : 3.1.10   , installed 3.1.10
        Adapter    "discovery"     : 3.1.0    , installed 3.1.0
        Adapter    "flot"          : 1.12.0   , installed 1.12.0
        Adapter    "fullybrowser"  : 2.2.0    , installed 2.0.1 [Updateable]
        Adapter    "habpanel"      : 0.5.0    , installed 0.4.1 [Updateable]
        Adapter    "history"       : 3.0.1    , installed 1.9.10 [Updateable]
        Adapter    "icons-mfd-png" : 1.1.0    , installed 1.1.0
        Adapter    "info"          : 2.0.0    , installed 2.0.0
        Adapter    "iot"           : 1.14.5   , installed 1.5.3 [Updateable]
        Adapter    "javascript"    : 7.1.4    , installed 7.1.4
        Controller "js-controller" : 5.0.12   , installed 3.3.22 [Updateable]
        Adapter    "knx"           : 2.0.22   , installed 2.0.22
        Adapter    "onkyo"         : 2.1.2    , installed 2.1.2
        Adapter    "openweathermap": 0.3.9    , installed 0.1.0 [Updateable]
        Adapter    "paw"           : 0.3.2    , installed 0.3.2
        Adapter    "simple-api"    : 2.7.2    , installed 2.7.2
        Adapter    "socketio"      : 6.5.5    , installed 6.5.5
        Adapter    "vis"           : 1.4.16   , installed 1.2.4 [Updateable]
        Adapter    "vis-inventwo"  : 3.3.3    , installed 2.5.11 [Updateable]
        Adapter    "vis-metro"     : 1.2.0    , installed 1.2.0
        Adapter    "web"           : 6.1.2    , installed 3.0.7 [Updateable]
        pi@raspberrypi:/opt/iobroker $ iob upgrade admin
        This upgrade of "admin" will at least introduce the following changes:
        -> 6.12.0:
        fixed issue when updating news in backend
        validate json config against the schema
        update socket-client to improve performance
        -> 6.11.0:
        jsonConfig type number now stores values as number instead of string
        objects browser number value input behavior change to allow leading minus
        Added component `interfaces` to the JSON config
        Implemented Backend to GUI communication
        -> 6.10.9:
        Improvement of the public accessibility check
        -> 6.10.8:
        update adapter-react-v5 to fix issues with object browser
        -> 6.10.7:
        Corrected adapter termination if the alias has no target
        -> 6.10.6:
        Added possibility to show the icon on JSON config tabs
        on upgrade all, not yet started commands can now be aborted
        Added security check if the server is available from the internet without protection
        Corrected navigation after the settings closing
        -> 6.10.5:
        JSON config component `port` does no longer mark port as occupied if it is only occupied on another host
        register news as notifications
        if upgrade all is stopped on error, activate close button
        Export/import objects with its values
        BE CAREFUL: THIS IS A MAJOR UPGRADE, WHICH WILL MOST LIKELY INTRODUCE BREAKING CHANGES!
        Would you like to upgrade admin from @4.0.9 to @6.12.0 now? [(y)es, (n)o]: y
        Update admin from @4.0.9 to @6.12.0
        host.raspberrypi Adapter "system.adapter.admin.0" is stopped.
        NPM version: 9.8.1
        npm install iobroker.admin@6.12.0 --loglevel error --prefix "/opt/iobroker" (System call)
        Update "system.adapter.admin.0"
        upload [50] admin.admin /opt/iobroker/node_modules/iobroker.admin/admin/i18n/uk/translations.json i18n/uk/translations.json application/json
        upload [40] admin.admin /opt/iobroker/node_modules/iobroker.admin/admin/custom/static/js/vendors-node_modules_react-dom_index_js.51544235.chunk.js.map custom/static/js/vendors-node_modules_react-dom_index_js.51544235.chunk.js.map application/json
        upload [30] admin.admin /opt/iobroker/node_modules/iobroker.admin/admin/custom/static/js/vendors-node_modules_iobroker_adapter-react-v5_assets_devices_parseNames_js-node_modules_iobr-99c23e.847b8ad9.chunk.js.map custom/static/js/vendors-node_modules_iobroker_adapter-react-v5_assets_devices_parseNames_js-node_modules_iobr-99c23e.847b8ad9.chunk.js.map application/json
        upload [20] admin.admin /opt/iobroker/node_modules/iobroker.admin/admin/custom/static/js/node_modules_iobroker_adapter-react-v5_node_modules_react_index_js.d44f3890.chunk.js.map custom/static/js/node_modules_iobroker_adapter-react-v5_node_modules_react_index_js.d44f3890.chunk.js.map application/json
        upload [19] admin.admin /opt/iobroker/node_modules/iobroker.admin/admin/custom/static/js/node_modules_iobroker_adapter-react-v5_node_modules_react_index_js.d44f3890.chunk.js custom/static/js/node_modules_iobroker_adapter-react-v5_node_modules_react_index_js.d44f3890.chunk.js application/javascript
        upload [18] admin.admin /opt/iobroker/node_modules/iobroker.admin/admin/custom/static/js/node_modules_iobroker_adapter-react-v5_assets_devices_sync_recursive_-node_modules_iobroker_a-de23731.74a7cfbb.chunk.js.map custom/static/js/node_modules_iobroker_adapter-react-v5_assets_devices_sync_recursive_-node_modules_iobroker_a-de23731.74a7cfbb.chunk.js.map application/json
        upload [17] admin.admin /opt/iobroker/node_modules/iobroker.admin/admin/custom/static/js/node_modules_iobroker_adapter-react-v5_assets_devices_sync_recursive_-node_modules_iobroker_a-de23731.74a7cfbb.chunk.js custom/static/js/node_modules_iobroker_adapter-react-v5_assets_devices_sync_recursive_-node_modules_iobroker_a-de23731.74a7cfbb.chunk.js application/javascript
        upload [16] admin.admin /opt/iobroker/node_modules/iobroker.admin/admin/custom/static/js/node_modules_iobroker_adapter-react-v5_assets_devices_sync_recursive_-node_modules_iobroker_a-de23730.df74e930.chunk.js.map custom/static/js/node_modules_iobroker_adapter-react-v5_assets_devices_sync_recursive_-node_modules_iobroker_a-de23730.df74e930.chunk.js.map application/json
        upload [15] admin.admin /opt/iobroker/node_modules/iobroker.admin/admin/custom/static/js/node_modules_iobroker_adapter-react-v5_assets_devices_sync_recursive_-node_modules_iobroker_a-de23730.df74e930.chunk.js custom/static/js/node_modules_iobroker_adapter-react-v5_assets_devices_sync_recursive_-node_modules_iobroker_a-de23730.df74e930.chunk.js application/javascript
        upload [14] admin.admin /opt/iobroker/node_modules/iobroker.admin/admin/custom/static/js/main.681927cc.js.map custom/static/js/main.681927cc.js.map application/json
        upload [13] admin.admin /opt/iobroker/node_modules/iobroker.admin/admin/custom/static/js/main.681927cc.js custom/static/js/main.681927cc.js application/javascript
        upload [12] admin.admin /opt/iobroker/node_modules/iobroker.admin/admin/custom/i18n/zh-cn.json custom/i18n/zh-cn.json application/json
        upload [11] admin.admin /opt/iobroker/node_modules/iobroker.admin/admin/custom/i18n/ru.json custom/i18n/ru.json application/json
        upload [10] admin.admin /opt/iobroker/node_modules/iobroker.admin/admin/custom/i18n/pt.json custom/i18n/pt.json application/json
        upload [9] admin.admin /opt/iobroker/node_modules/iobroker.admin/admin/custom/i18n/pl.json custom/i18n/pl.json application/json
        upload [8] admin.admin /opt/iobroker/node_modules/iobroker.admin/admin/custom/i18n/nl.json custom/i18n/nl.json application/json
        upload [7] admin.admin /opt/iobroker/node_modules/iobroker.admin/admin/custom/i18n/it.json custom/i18n/it.json application/json
        upload [6] admin.admin /opt/iobroker/node_modules/iobroker.admin/admin/custom/i18n/fr.json custom/i18n/fr.json application/json
        upload [5] admin.admin /opt/iobroker/node_modules/iobroker.admin/admin/custom/i18n/es.json custom/i18n/es.json application/json
        upload [4] admin.admin /opt/iobroker/node_modules/iobroker.admin/admin/custom/i18n/en.json custom/i18n/en.json application/json
        upload [3] admin.admin /opt/iobroker/node_modules/iobroker.admin/admin/custom/i18n/de.json custom/i18n/de.json application/json
        upload [2] admin.admin /opt/iobroker/node_modules/iobroker.admin/admin/custom/customComponents.js.map custom/customComponents.js.map application/json
        upload [1] admin.admin /opt/iobroker/node_modules/iobroker.admin/admin/custom/customComponents.js custom/customComponents.js application/javascript
        upload [0] admin.admin /opt/iobroker/node_modules/iobroker.admin/admin/admin.png admin.png image/png
        Adapter "admin" updated
        host.raspberrypi Adapter "system.adapter.admin.0" is started
        hash unchanged, use cached sources
        update done
        Adapter    "admin"         : 6.12.0   , installed 6.12.0
        bei
        ging es dann nicht mehr weiter:
        pi@raspberrypi:/opt/iobroker $ sudo -H -u iobroker npm install iobroker.js-controller@4.0.0
        npm ERR! code ETARGET
        npm ERR! notarget No matching version found for iobroker.js-controller@4.0.0.
        npm ERR! notarget In most cases you or one of your dependencies are requesting
        npm ERR! notarget a package version that doesn't exist.
        npm ERR! A complete log of this run can be found in: /home/iobroker/.npm/_logs/2023-11-04T19_40_51_419Z-debug-0.log
        Starten lässt sich der iobroker noch, jetzt ist der js-controller 3.3.22
        mcm1957 Thomas Braun 2 Replies Last reply Reply Quote 0
        • mcm1957
          mcm1957 @Alex e last edited by mcm1957
          @alex-e
          vom jscontroller 4.x.x ist minimal 4.0.3 und maximal 4.0.24 (letzte 4er stable) verfügbar
          4.0.0 wurde nicht released.
            @alex-e
            Ich weiß die Versionsnummern nicht für 4xx
            iob stop
            cd /opt/iobroker
            sudo -H -u iobroker npm install iobroker.js-controller@4.0.24
            iob update
            iob upgrade
            iob upgrade self
            iob start
            • mcm1957
              mcm1957 @Thomas Braun last edited by mcm1957
              Du weißt mal was nicht ? 🙂
              Hoffe du wirst nicht krank 🙂 🙂 🙂
                Thomas Braun Most Active @mcm1957 last edited by
                @mcm57 sagte in js-controller Update mit npm ERR:
                Ich fühl mich auch schon ganz komisch...
                Aber Versionsnummern 'von ollem Kram' merk ich mir nicht...
                  Vielen Dank nochmal für eure Hilfe, und sorry, dass ich nicht so schnell reagieren kann wie ihr. Ich kann gerade nicht so viel Zeit mit iob verbringen wie ich gerne würde.
                  Ich bin mal bis zum Upgrade auf 4.0.24 vorgegangen. Damit sollte der Tizen Adapter ja noch funktionieren.
                  Bis ich auf 5.x upgrade kann ich ja noch nach einer Alternative suchen. Evtl. schaffe ich es ja, mich da einzuarbeiten.
                  Zur Vollständigkeit: So sah das ganze aus:
                  Durchgeführt habe ich:
                  iob stop
                  cd /opt/iobroker
                  iob update
                  iob upgrade
                  Heraus kam:
                  pi@raspberrypi:~ $ iob stop
                  pi@raspberrypi:/opt/iobroker $ sudo -H -u iobroker npm install iobroker.js-controller@4.0.24
                  added 37 packages, removed 18 packages, and changed 48 packages in 48s
                  127 packages are looking for funding
                  Adapter    "backitup"     : 2.8.7    , installed 2.8.1  [Updatable]
                  Adapter    "fullybrowser" : 2.2.0    , installed 2.0.1  [Updatable]
                  Adapter    "habpanel"     : 0.5.0    , installed 0.4.1  [Updatable]
                  Adapter    "history"      : 3.0.1    , installed 1.9.10 [Updatable]
                  Adapter    "icons-mfd-png": 1.1.0    , installed 1.1.0
                  Adapter    "iot"          : 1.14.5   , installed 1.5.3  [Updatable]
                  Controller "js-controller": 5.0.12   , installed 4.0.24 [Updatable]
                  Adapter    "openweathermap": 0.3.9   , installed 0.1.0  [Updatable]
                  Adapter    "vis"          : 1.4.16   , installed 1.2.4  [Updatable]
                  Adapter    "vis-inventwo" : 3.3.3    , installed 2.5.11 [Updatable]
                  Adapter    "web"          : 6.1.4    , installed 3.0.7  [Updatable]
                  This upgrade of "web" will at least introduce the following changes:
                  -> 6.1.4:
                  upgrade socketio and ws dependencies to fix vis subscribe problem
                  -> 6.1.3:
                  upgraded socketio and ws dependencies to correct the error by unsubscribing on client disconnect
                  -> 6.1.2:
                  -> 6.1.1:
                  added missing node16 requirement
                  -> 6.1.0:
                  Added the subscribing on the specific instance messages
                  -> 6.0.3:
                  Updated packages
                  Implemented the possibility to view folder content
                  -> 6.0.1:
                  Removed letsencrypt handling from web adapter
                  Would you like to upgrade web from @3.0.7 to @6.1.4 now? [(y)es, (n)o]: y
                  Update web from @3.0.7 to @6.1.4
                  host.raspberrypi Adapter "system.adapter.web.0" is stopped.
                  NPM version: 9.8.1
                  Installing iobroker.web@6.1.4... (System call)
                  added 7 packages, removed 4 packages, and changed 4 packages in 11s
                  upload [396] web /opt/iobroker/node_modules/iobroker.web/www/admin/img/admin.png admin/img/admin.png image/png
                  upload [350] web /opt/iobroker/node_modules/iobroker.web/www/lib/css/themes/jquery-ui/blitzer/images/ui-bg_highlight-soft_15_cc0000_1x100.png lib/css/themes/jquery-ui/blitzer/images/ui-bg_highlight-soft_15_cc0000_1x100.png image/png
                  upload [300] web /opt/iobroker/node_modules/iobroker.web/www/lib/css/themes/jquery-ui/custom-light/jquery-ui.theme.min.css lib/css/themes/jquery-ui/custom-light/jquery-ui.theme.min.css text/css
                  upload [250] web /opt/iobroker/node_modules/iobroker.web/www/lib/css/themes/jquery-ui/eggplant/images/ui-bg_highlight-soft_100_eae6ea_1x100.png lib/css/themes/jquery-ui/eggplant/images/ui-bg_highlight-soft_100_eae6ea_1x100.png image/png
                  upload [200] web /opt/iobroker/node_modules/iobroker.web/www/lib/css/themes/jquery-ui/hot-sneaks/images/ui-bg_flat_75_ba9217_40x100.png lib/css/themes/jquery-ui/hot-sneaks/images/ui-bg_flat_75_ba9217_40x100.png image/png
                  upload [150] web /opt/iobroker/node_modules/iobroker.web/www/lib/css/themes/jquery-ui/redmond/images/ui-bg_glass_85_dfeffc_1x400.png lib/css/themes/jquery-ui/redmond/images/ui-bg_glass_85_dfeffc_1x400.png image/png
                  upload [100] web /opt/iobroker/node_modules/iobroker.web/www/lib/css/themes/jquery-ui/sunny/images/ui-bg_diagonals-medium_20_d34d17_40x40.png lib/css/themes/jquery-ui/sunny/images/ui-bg_diagonals-medium_20_d34d17_40x40.png image/png
                  upload [90] web /opt/iobroker/node_modules/iobroker.web/www/lib/css/themes/jquery-ui/sunny/images/ui-icons_bd7b00_256x240.png lib/css/themes/jquery-ui/sunny/images/ui-icons_bd7b00_256x240.png image/png
                  upload [80] web /opt/iobroker/node_modules/iobroker.web/www/lib/css/themes/jquery-ui/ui-darkness/images/ui-bg_flat_50_5c5c5c_40x100.png lib/css/themes/jquery-ui/ui-darkness/images/ui-bg_flat_50_5c5c5c_40x100.png image/png
                  upload [70] web /opt/iobroker/node_modules/iobroker.web/www/lib/css/themes/jquery-ui/ui-darkness/images/ui-icons_a83300_256x240.png lib/css/themes/jquery-ui/ui-darkness/images/ui-icons_a83300_256x240.png image/png
                  upload [60] web /opt/iobroker/node_modules/iobroker.web/www/lib/css/themes/jquery-ui/ui-lightness/images/ui-bg_glass_100_fdf5ce_1x400.png lib/css/themes/jquery-ui/ui-lightness/images/ui-bg_glass_100_fdf5ce_1x400.png image/png
                  upload [50] web /opt/iobroker/node_modules/iobroker.web/www/lib/css/themes/jquery-ui/ui-lightness/jquery-ui.css lib/css/themes/jquery-ui/ui-lightness/jquery-ui.css text/css
                  upload [40] web /opt/iobroker/node_modules/iobroker.web/www/lib/css/themes/jquery-ui/vader/images/ui-bg_inset-soft_15_121212_1x100.png lib/css/themes/jquery-ui/vader/images/ui-bg_inset-soft_15_121212_1x100.png image/png
                  upload [30] web /opt/iobroker/node_modules/iobroker.web/www/lib/css/themes/jquery-ui/vader/theme.css lib/css/themes/jquery-ui/vader/theme.css text/css
                  upload [20] web /opt/iobroker/node_modules/iobroker.web/www/lib/js/jquery-1.11.2.min.js lib/js/jquery-1.11.2.min.js application/javascript
                  upload [19] web /opt/iobroker/node_modules/iobroker.web/www/lib/js/jquery-1.11.2.min.map lib/js/jquery-1.11.2.min.map application/json
                  upload [18] web /opt/iobroker/node_modules/iobroker.web/www/lib/js/jquery-3.2.1.min.js lib/js/jquery-3.2.1.min.js application/javascript
                  upload [17] web /opt/iobroker/node_modules/iobroker.web/www/lib/js/jquery-3.2.1.min.map lib/js/jquery-3.2.1.min.map application/json
                  upload [16] web /opt/iobroker/node_modules/iobroker.web/www/lib/js/jquery-ui-1.10.3.full.min.js lib/js/jquery-ui-1.10.3.full.min.js application/javascript
                  upload [15] web /opt/iobroker/node_modules/iobroker.web/www/lib/js/jquery-ui-1.11.3.full.min.js lib/js/jquery-ui-1.11.3.full.min.js application/javascript
                  upload [14] web /opt/iobroker/node_modules/iobroker.web/www/lib/js/jquery-ui-1.11.4.full.min.js lib/js/jquery-ui-1.11.4.full.min.js application/javascript
                  upload [13] web /opt/iobroker/node_modules/iobroker.web/www/lib/js/jquery-ui.1.11.2.slider.min.js lib/js/jquery-ui.1.11.2.slider.min.js application/javascript
                  upload [12] web /opt/iobroker/node_modules/iobroker.web/www/lib/js/jquery-ui.min.js lib/js/jquery-ui.min.js application/javascript
                  upload [11] web /opt/iobroker/node_modules/iobroker.web/www/lib/js/jquery.fancytree-all.min.js lib/js/jquery.fancytree-all.min.js application/javascript
                  upload [10] web /opt/iobroker/node_modules/iobroker.web/www/lib/js/jquery.fancytree-all.min.js.map lib/js/jquery.fancytree-all.min.js.map application/json
                  upload [9] web /opt/iobroker/node_modules/iobroker.web/www/lib/js/jquery.jqGrid-4.5.4.min.js lib/js/jquery.jqGrid-4.5.4.min.js application/javascript
                  upload [8] web /opt/iobroker/node_modules/iobroker.web/www/lib/js/loStorage.js lib/js/loStorage.js application/javascript
                  upload [7] web /opt/iobroker/node_modules/iobroker.web/www/lib/js/materialize.js lib/js/materialize.js application/javascript
                  upload [6] web /opt/iobroker/node_modules/iobroker.web/www/lib/js/materialize.js.map lib/js/materialize.js.map application/json
                  upload [5] web /opt/iobroker/node_modules/iobroker.web/www/lib/js/selectID.js lib/js/selectID.js application/javascript
                  upload [4] web /opt/iobroker/node_modules/iobroker.web/www/lib/js/showdown.min.js lib/js/showdown.min.js application/javascript
                  upload [3] web /opt/iobroker/node_modules/iobroker.web/www/lib/js/socket.io.js lib/js/socket.io.js application/javascript
                  upload [2] web /opt/iobroker/node_modules/iobroker.web/www/lib/js/translate.js lib/js/translate.js application/javascript
                  upload [1] web /opt/iobroker/node_modules/iobroker.web/www/login/favicon.ico login/favicon.ico image/vnd.microsoft.icon
                  upload [0] web /opt/iobroker/node_modules/iobroker.web/www/login/index.html login/index.html text/html
                  Update "system.adapter.web.0"
                  upload [129] web.admin /opt/iobroker/node_modules/iobroker.web/admin/asset-manifest.json asset-manifest.json application/json
                  upload [100] web.admin /opt/iobroker/node_modules/iobroker.web/admin/static/media/Computer.9558f6ee3941dba4e3c5.svg static/media/Computer.9558f6ee3941dba4e3c5.svg image/svg+xml
                  upload [90] web.admin /opt/iobroker/node_modules/iobroker.web/admin/static/media/Dressing Room.5e6f8f64b0e8f91c473e.svg static/media/Dressing Room.5e6f8f64b0e8f91c473e.svg image/svg+xml
                  upload [80] web.admin /opt/iobroker/node_modules/iobroker.web/admin/static/media/Garage.f7fc0a9b326d582afee6.svg static/media/Garage.f7fc0a9b326d582afee6.svg image/svg+xml
                  upload [70] web.admin /opt/iobroker/node_modules/iobroker.web/admin/static/media/Hanging Lamps.0bd452fc843edd645c30.svg static/media/Hanging Lamps.0bd452fc843edd645c30.svg image/svg+xml
                  upload [60] web.admin /opt/iobroker/node_modules/iobroker.web/admin/static/media/Led Strip.5cf2de461e29ffbaa5f0.svg static/media/Led Strip.5cf2de461e29ffbaa5f0.svg image/svg+xml
                  upload [50] web.admin /opt/iobroker/node_modules/iobroker.web/admin/static/media/Nursery.9cecc0544bdb5c28500c.svg static/media/Nursery.9cecc0544bdb5c28500c.svg image/svg+xml
                  upload [40] web.admin /opt/iobroker/node_modules/iobroker.web/admin/static/media/Rear Wall.38843c33f1ea1f575500.svg static/media/Rear Wall.38843c33f1ea1f575500.svg image/svg+xml
                  upload [30] web.admin /opt/iobroker/node_modules/iobroker.web/admin/static/media/Sockets.8320e1a99be9de004629.svg static/media/Sockets.8320e1a99be9de004629.svg image/svg+xml
                  upload [20] web.admin /opt/iobroker/node_modules/iobroker.web/admin/static/media/Terrace.d71d07d9290674f2ca20.svg static/media/Terrace.d71d07d9290674f2ca20.svg image/svg+xml
                  upload [19] web.admin /opt/iobroker/node_modules/iobroker.web/admin/static/media/Toilet.83604dd2daafb67067dd.svg static/media/Toilet.83604dd2daafb67067dd.svg image/svg+xml
                  upload [18] web.admin /opt/iobroker/node_modules/iobroker.web/admin/static/media/Tv.4e9745a548e57bfac0c7.svg static/media/Tv.4e9745a548e57bfac0c7.svg image/svg+xml
                  upload [17] web.admin /opt/iobroker/node_modules/iobroker.web/admin/static/media/Upstairs.441813e54e0daca0882d.svg static/media/Upstairs.441813e54e0daca0882d.svg image/svg+xml
                  upload [16] web.admin /opt/iobroker/node_modules/iobroker.web/admin/static/media/Vacuum Cleaner.9c8d50e436e6cea06dfa.svg static/media/Vacuum Cleaner.9c8d50e436e6cea06dfa.svg image/svg+xml
                  upload [15] web.admin /opt/iobroker/node_modules/iobroker.web/admin/static/media/Ventilation.c31761d86d67e245ac92.svg static/media/Ventilation.c31761d86d67e245ac92.svg image/svg+xml
                  upload [14] web.admin /opt/iobroker/node_modules/iobroker.web/admin/static/media/Wardrobe.e8019970a2b51412cfdc.svg static/media/Wardrobe.e8019970a2b51412cfdc.svg image/svg+xml
                  upload [13] web.admin /opt/iobroker/node_modules/iobroker.web/admin/static/media/Washing Machines.577f3acdb3cef002b523.svg static/media/Washing Machines.577f3acdb3cef002b523.svg image/svg+xml
                  upload [12] web.admin /opt/iobroker/node_modules/iobroker.web/admin/static/media/Washroom.bfb54196f381f36de9d6.svg static/media/Washroom.bfb54196f381f36de9d6.svg image/svg+xml
                  upload [11] web.admin /opt/iobroker/node_modules/iobroker.web/admin/static/media/Water Consumption.68891649591cc2434c5b.svg static/media/Water Consumption.68891649591cc2434c5b.svg image/svg+xml
                  upload [10] web.admin /opt/iobroker/node_modules/iobroker.web/admin/static/media/Water Heater.7e4bb4d99a5213f24d08.svg static/media/Water Heater.7e4bb4d99a5213f24d08.svg image/svg+xml
                  upload [9] web.admin /opt/iobroker/node_modules/iobroker.web/admin/static/media/Water.f50411984c5c24fa574d.svg static/media/Water.f50411984c5c24fa574d.svg image/svg+xml
                  upload [8] web.admin /opt/iobroker/node_modules/iobroker.web/admin/static/media/Wc.83604dd2daafb67067dd.svg static/media/Wc.83604dd2daafb67067dd.svg image/svg+xml
                  upload [7] web.admin /opt/iobroker/node_modules/iobroker.web/admin/static/media/Weather.e91dae647698d48365e3.svg static/media/Weather.e91dae647698d48365e3.svg image/svg+xml
                  upload [6] web.admin /opt/iobroker/node_modules/iobroker.web/admin/static/media/Window.421664f57c35e5109aa2.svg static/media/Window.421664f57c35e5109aa2.svg image/svg+xml
                  upload [5] web.admin /opt/iobroker/node_modules/iobroker.web/admin/static/media/Windscreen.6058448bf63f72dd5036.svg static/media/Windscreen.6058448bf63f72dd5036.svg image/svg+xml
                  upload [4] web.admin /opt/iobroker/node_modules/iobroker.web/admin/static/media/Workshop.7856e59fe4f164c90609.svg static/media/Workshop.7856e59fe4f164c90609.svg image/svg+xml
                  upload [3] web.admin /opt/iobroker/node_modules/iobroker.web/admin/static/media/Workspace.97d73e419d966bfb6428.svg static/media/Workspace.97d73e419d966bfb6428.svg image/svg+xml
                  upload [2] web.admin /opt/iobroker/node_modules/iobroker.web/admin/static/media/names.3a7dae0bd6b8b03b280f.txt static/media/names.3a7dae0bd6b8b03b280f.txt text/plain
                  upload [1] web.admin /opt/iobroker/node_modules/iobroker.web/admin/static/media/names.e7efb5283d98000c74ac.txt static/media/names.e7efb5283d98000c74ac.txt text/plain
                  upload [0] web.admin /opt/iobroker/node_modules/iobroker.web/admin/web.png web.png image/png
                  host.raspberrypi Adapter "system.adapter.web.0" is started
                  This upgrade of "vis-inventwo" will at least introduce the following changes:
                  -> 3.3.3:
                  Fixed issue with border color and view in popup
                  -> 3.3.2:
                  Bugfix
                  -> 3.3.1:
                  Bugfix
                  -> 3.3.0:
                  New widget: configurable colorpicker for HEX, RGB, HSL, HSV and CIE/XY
                  -> 3.2.8:
                  JSON-Table: Added text align für headrow, Radiobutton-List: Added Multi-Row/-Column schema (for more details go to the changelog on Github)
                  -> 3.2.7:
                  Fixed issue that popup not closing on datapoint value
                  -> 3.2.6:
                  JSON-Table: Color background per line depending on a value [#280], JSON-Table: Default sort of a column [#286], Universal- & Multi-Widget ViewInPopUp: View scrolling [#344], Universal- & Multi-Widget HTTP: Link can be opened in same or new tab [#363], FIXED: JSON-Table now also works if there is only a single object in the data point instead of an array with objects [#319], FIXED: JSON-Table: 10-digit timestamp didn't work [#376]
                  Would you like to upgrade vis-inventwo from @2.5.11 to @3.3.3 now? [(y)es, (n)o]: y
                  Update vis-inventwo from @2.5.11 to @3.3.3
                  NPM version: 9.8.1
                  Installing iobroker.vis-inventwo@3.3.3... (System call)
                  changed 1 package in 10s
                  Adapter "system.adapter.vis.0" restarted.
                  Adapter "system.adapter.web.0" restarted.
                  Update "system.adapter.vis-inventwo.0"
                  upload [21] vis-inventwo.admin /opt/iobroker/node_modules/iobroker.vis-inventwo/admin/BackgroundUrl.png BackgroundUrl.png image/png
                  upload [20] vis-inventwo.admin /opt/iobroker/node_modules/iobroker.vis-inventwo/admin/Blockly.png Blockly.png image/png
                  upload [19] vis-inventwo.admin /opt/iobroker/node_modules/iobroker.vis-inventwo/admin/Button_CSS.png Button_CSS.png image/png
                  upload [18] vis-inventwo.admin /opt/iobroker/node_modules/iobroker.vis-inventwo/admin/CSS-text.png CSS-text.png image/png
                  upload [17] vis-inventwo.admin /opt/iobroker/node_modules/iobroker.vis-inventwo/admin/Config.png Config.png image/png
                  upload [16] vis-inventwo.admin /opt/iobroker/node_modules/iobroker.vis-inventwo/admin/Data.png Data.png image/png
                  upload [15] vis-inventwo.admin /opt/iobroker/node_modules/iobroker.vis-inventwo/admin/Muster.png Muster.png image/png
                  upload [14] vis-inventwo.admin /opt/iobroker/node_modules/iobroker.vis-inventwo/admin/Preview.png Preview.png image/png
                  upload [13] vis-inventwo.admin /opt/iobroker/node_modules/iobroker.vis-inventwo/admin/Preview2.png Preview2.png image/png
                  upload [12] vis-inventwo.admin /opt/iobroker/node_modules/iobroker.vis-inventwo/admin/Preview3.png Preview3.png image/png
                  upload [11] vis-inventwo.admin /opt/iobroker/node_modules/iobroker.vis-inventwo/admin/Preview4.png Preview4.png image/png
                  upload [10] vis-inventwo.admin /opt/iobroker/node_modules/iobroker.vis-inventwo/admin/Set.png Set.png image/png
                  upload [9] vis-inventwo.admin /opt/iobroker/node_modules/iobroker.vis-inventwo/admin/Set_new.png Set_new.png image/png
                  upload [8] vis-inventwo.admin /opt/iobroker/node_modules/iobroker.vis-inventwo/admin/admin.d.ts admin.d.ts video/mp2t
                  upload [7] vis-inventwo.admin /opt/iobroker/node_modules/iobroker.vis-inventwo/admin/i1_150.png i1_150.png image/png
                  upload [6] vis-inventwo.admin /opt/iobroker/node_modules/iobroker.vis-inventwo/admin/i_300.png i_300.png image/png
                  upload [5] vis-inventwo.admin /opt/iobroker/node_modules/iobroker.vis-inventwo/admin/i_DEV_150.png i_DEV_150.png image/png
                  upload [4] vis-inventwo.admin /opt/iobroker/node_modules/iobroker.vis-inventwo/admin/icons.png icons.png image/png
                  upload [3] vis-inventwo.admin /opt/iobroker/node_modules/iobroker.vis-inventwo/admin/index_m.html index_m.html text/htmlupload [2] vis-inventwo.admin /opt/iobroker/node_modules/iobroker.vis-inventwo/admin/inventwo.png inventwo.png image/pngupload [1] vis-inventwo.admin /opt/iobroker/node_modules/iobroker.vis-inventwo/admin/spende.png spende.png image/png
                  upload [0] vis-inventwo.admin /opt/iobroker/node_modules/iobroker.vis-inventwo/admin/style.css style.css text/css
                  This upgrade of "vis" will at least introduce the following changes:
                  -> 1.4.16:
                  Corrected connection with "only port" URLs
                  -> 1.4.15:
                  Better check of the offline license
                  -> 1.4.14:
                  Corrected GUI bug
                  -> 1.4.13:
                  The group attributes will be replaced recursively
                  -> 1.4.12:
                  Fixed bug with the export of specific widgets
                  -> 1.4.11:
                  Removed ES6 commands to be supported by older browsers
                  Fixed problem with update of grouped widgets
                  Added web manifest to be able to handle vis as the web app
                  -> 1.4.8:
                  Added support for js-controller 4.x
                  Would you like to upgrade vis from @1.2.4 to @1.4.16 now? [(y)es, (n)o]: y
                  Update vis from @1.2.4 to @1.4.16
                  NPM version: 9.8.1
                  Installing iobroker.vis@1.4.16... (System call)
                  added 2 packages, and changed 1 package in 21s
                  upload [439] vis /opt/iobroker/node_modules/iobroker.vis/www/cache.manifest cache.manifest text/cache-manifest
                  upload [400] vis /opt/iobroker/node_modules/iobroker.vis/www/icon/navigation.png icon/navigation.png image/png
                  upload [350] vis /opt/iobroker/node_modules/iobroker.vis/www/img/vis.png img/vis.png image/png
                  upload [300] vis /opt/iobroker/node_modules/iobroker.vis/www/js/fm/icon/mine/24/misc.png js/fm/icon/mine/24/misc.png image/png
                  upload [250] vis /opt/iobroker/node_modules/iobroker.vis/www/lib/img/shape_align_left.png lib/img/shape_align_left.png image/png
                  upload [200] vis /opt/iobroker/node_modules/iobroker.vis/www/widgets/basic/img/Prev_HTMLnavigation.png widgets/basic/img/Prev_HTMLnavigation.png image/png
                  upload [150] vis /opt/iobroker/node_modules/iobroker.vis/www/widgets/jqplot/img/Prev_MeterGauge.png widgets/jqplot/img/Prev_MeterGauge.png image/png
                  upload [100] vis /opt/iobroker/node_modules/iobroker.vis/www/widgets/metro/img/light_light_dim_80.png widgets/metro/img/light_light_dim_80.png image/png
                  upload [90] vis /opt/iobroker/node_modules/iobroker.vis/www/widgets/swipe/img/Prev_Carousel.png widgets/swipe/img/Prev_Carousel.png image/png
                  upload [80] vis /opt/iobroker/node_modules/iobroker.vis/www/widgets/tabs/styles/images/leftArrow.png widgets/tabs/styles/images/leftArrow.png image/png
                  upload [70] vis /opt/iobroker/node_modules/iobroker.vis/www/widgets/todo/special.html widgets/todo/special.html text/html
                  upload [60] vis /opt/iobroker/node_modules/iobroker.vis/www/widgets/vis-inventwo/img/0_Nav.png widgets/vis-inventwo/img/0_Nav.png image/png
                  upload [50] vis /opt/iobroker/node_modules/iobroker.vis/www/widgets/vis-inventwo/img/Check.gif widgets/vis-inventwo/img/Check.gif image/gif
                  upload [40] vis /opt/iobroker/node_modules/iobroker.vis/www/widgets/vis-inventwo/img/Slider2.gif widgets/vis-inventwo/img/Slider2.gif image/gif
                  upload [30] vis /opt/iobroker/node_modules/iobroker.vis/www/widgets/vis-inventwo/img/ToggleSwitch/switch-1-vert-off-black.png widgets/vis-inventwo/img/ToggleSwitch/switch-1-vert-off-black.png image/png
                  upload [20] vis /opt/iobroker/node_modules/iobroker.vis/www/widgets/vis-inventwo/img/clock_analog/01.png widgets/vis-inventwo/img/clock_analog/01.png image/png
                  upload [19] vis /opt/iobroker/node_modules/iobroker.vis/www/widgets/vis-inventwo/img/clock_analog/02/min.png widgets/vis-inventwo/img/clock_analog/02/min.png image/png
                  upload [18] vis /opt/iobroker/node_modules/iobroker.vis/www/widgets/vis-inventwo/img/clock_analog/02/sek.png widgets/vis-inventwo/img/clock_analog/02/sek.png image/png
                  upload [17] vis /opt/iobroker/node_modules/iobroker.vis/www/widgets/vis-inventwo/img/clock_analog/02/std.png widgets/vis-inventwo/img/clock_analog/02/std.png image/png
                  upload [16] vis /opt/iobroker/node_modules/iobroker.vis/www/widgets/vis-inventwo/img/clock_analog/02.png widgets/vis-inventwo/img/clock_analog/02.png image/png
                  upload [15] vis /opt/iobroker/node_modules/iobroker.vis/www/widgets/vis-inventwo/img/clock_analog/03/min.png widgets/vis-inventwo/img/clock_analog/03/min.png image/png
                  upload [14] vis /opt/iobroker/node_modules/iobroker.vis/www/widgets/vis-inventwo/img/clock_analog/03/sek.png widgets/vis-inventwo/img/clock_analog/03/sek.png image/png
                  upload [13] vis /opt/iobroker/node_modules/iobroker.vis/www/widgets/vis-inventwo/img/clock_analog/03/std.png widgets/vis-inventwo/img/clock_analog/03/std.png image/png
                  upload [12] vis /opt/iobroker/node_modules/iobroker.vis/www/widgets/vis-inventwo/img/clock_analog/03.png widgets/vis-inventwo/img/clock_analog/03.png image/png
                  upload [11] vis /opt/iobroker/node_modules/iobroker.vis/www/widgets/vis-inventwo/img/clock_analog/04/min.png widgets/vis-inventwo/img/clock_analog/04/min.png image/png
                  upload [10] vis /opt/iobroker/node_modules/iobroker.vis/www/widgets/vis-inventwo/img/clock_analog/04/sek.png widgets/vis-inventwo/img/clock_analog/04/sek.png image/png
                  upload [9] vis /opt/iobroker/node_modules/iobroker.vis/www/widgets/vis-inventwo/img/clock_analog/04/std.png widgets/vis-inventwo/img/clock_analog/04/std.png image/png
                  upload [8] vis /opt/iobroker/node_modules/iobroker.vis/www/widgets/vis-inventwo/img/clock_analog/04.png widgets/vis-inventwo/img/clock_analog/04.png image/png
                  upload [7] vis /opt/iobroker/node_modules/iobroker.vis/www/widgets/vis-inventwo/img/clock_analog/05/min.png widgets/vis-inventwo/img/clock_analog/05/min.png image/png
                  upload [6] vis /opt/iobroker/node_modules/iobroker.vis/www/widgets/vis-inventwo/img/clock_analog/05/sek.png widgets/vis-inventwo/img/clock_analog/05/sek.png image/png
                  upload [5] vis /opt/iobroker/node_modules/iobroker.vis/www/widgets/vis-inventwo/img/clock_analog/05/std.png widgets/vis-inventwo/img/clock_analog/05/std.png image/png
                  upload [4] vis /opt/iobroker/node_modules/iobroker.vis/www/widgets/vis-inventwo/img/clock_analog/05.png widgets/vis-inventwo/img/clock_analog/05.png image/png
                  upload [3] vis /opt/iobroker/node_modules/iobroker.vis/www/widgets/vis-inventwo/img/clock_analog/frame.png widgets/vis-inventwo/img/clock_analog/frame.png image/png
                  upload [2] vis /opt/iobroker/node_modules/iobroker.vis/www/widgets/vis-inventwo/js/iro.min.js widgets/vis-inventwo/js/iro.min.js application/javascript
                  upload [1] vis /opt/iobroker/node_modules/iobroker.vis/www/widgets/vis-inventwo/js/vis-inventwo.js widgets/vis-inventwo/js/vis-inventwo.js application/javascript
                  upload [0] vis /opt/iobroker/node_modules/iobroker.vis/www/widgets/vis-inventwo.html widgets/vis-inventwo.html text/htmlUpdate "system.adapter.vis.0"
                  upload [3] vis.admin /opt/iobroker/node_modules/iobroker.vis/admin/index.html index.html text/html
                  upload [2] vis.admin /opt/iobroker/node_modules/iobroker.vis/admin/index_m.html index_m.html text/html
                  upload [1] vis.admin /opt/iobroker/node_modules/iobroker.vis/admin/vis.png vis.png image/png
                  upload [0] vis.admin /opt/iobroker/node_modules/iobroker.vis/admin/words.js words.js application/javascript
                  This upgrade of "openweathermap" will at least introduce the following changes:
                  -> 0.3.9:
                  updated build process
                  -> 0.3.8:
                  update packages
                  -> 0.3.6:
                  Installation from GitHub does not possible anymore
                  -> 0.3.4:
                  Updated packages
                  -> 0.3.3:
                  Updated widget for vis 2.0
                  -> 0.3.0:
                  Added new widget for vis2.0
                  -> 0.2.5:
                  Make sure all forecast data are processed correctly
                  Would you like to upgrade openweathermap from @0.1.0 to @0.3.9 now? [(y)es, (n)o]: y
                  Update openweathermap from @0.1.0 to @0.3.9
                  NPM version: 9.8.1
                  Installing iobroker.openweathermap@0.3.9... (System call)
                  added 2 packages, and changed 1 package in 9s
                  Update "system.adapter.openweathermap.0"
                  upload [14] openweathermap.admin /opt/iobroker/node_modules/iobroker.openweathermap/admin/i18n/de/translations.json i18n/de/translations.json application/json
                  upload [13] openweathermap.admin /opt/iobroker/node_modules/iobroker.openweathermap/admin/i18n/en/translations.json i18n/en/translations.json application/json
                  upload [12] openweathermap.admin /opt/iobroker/node_modules/iobroker.openweathermap/admin/i18n/es/translations.json i18n/es/translations.json application/json
                  upload [11] openweathermap.admin /opt/iobroker/node_modules/iobroker.openweathermap/admin/i18n/fr/translations.json i18n/fr/translations.json application/json
                  upload [10] openweathermap.admin /opt/iobroker/node_modules/iobroker.openweathermap/admin/i18n/it/translations.json i18n/it/translations.json application/json
                  upload [9] openweathermap.admin /opt/iobroker/node_modules/iobroker.openweathermap/admin/i18n/nl/translations.json i18n/nl/translations.json application/json
                  upload [8] openweathermap.admin /opt/iobroker/node_modules/iobroker.openweathermap/admin/i18n/pl/translations.json i18n/pl/translations.json application/json
                  upload [7] openweathermap.admin /opt/iobroker/node_modules/iobroker.openweathermap/admin/i18n/pt/translations.json i18n/pt/translations.json application/json
                  upload [6] openweathermap.admin /opt/iobroker/node_modules/iobroker.openweathermap/admin/i18n/ru/translations.json i18n/ru/translations.json application/json
                  upload [5] openweathermap.admin /opt/iobroker/node_modules/iobroker.openweathermap/admin/i18n/zh-cn/translations.json i18n/zh-cn/translations.json application/json
                  upload [4] openweathermap.admin /opt/iobroker/node_modules/iobroker.openweathermap/admin/index.html index.html text/htmlupload [3] openweathermap.admin /opt/iobroker/node_modules/iobroker.openweathermap/admin/index_m.html index_m.html text/html
                  upload [2] openweathermap.admin /opt/iobroker/node_modules/iobroker.openweathermap/admin/jsonConfig.json jsonConfig.json application/json
                  upload [1] openweathermap.admin /opt/iobroker/node_modules/iobroker.openweathermap/admin/openweathermap.png openweathermap.png image/png
                  upload [0] openweathermap.admin /opt/iobroker/node_modules/iobroker.openweathermap/admin/words.js words.js application/javascript
                  This upgrade of "iot" will at least introduce the following changes:
                  -> 1.14.5:
                  Corrected names of enums in GUI
                  -> 1.14.3:
                  Fixed processing for lights with CT and RGB in Alisa
                  -> 1.14.2:
                  Updated GUI packages
                  -> 1.14.1:
                  Downgraded axios version to 0.27.2
                  -> 1.14.0:
                  Added netatmo support
                  -> 1.13.0:
                  Add support vor Custom Skill v2
                  -> 1.12.5:
                  Small changes on configuration GUI
                  Would you like to upgrade iot from @1.5.3 to @1.14.5 now? [(y)es, (n)o]: y
                  Update iot from @1.5.3 to @1.14.5
                  host.raspberrypi Adapter "system.adapter.iot.0" is stopped.
                  NPM version: 9.8.1
                  Installing iobroker.iot@1.14.5... (System call)
                  added 49 packages, removed 56 packages, and changed 70 packages in 2m
                  132 packages are looking for funding
                  Update "system.adapter.iot.0"
                  upload [132] iot.admin /opt/iobroker/node_modules/iobroker.iot/admin/actions.js actions.js application/javascript
                  upload [100] iot.admin /opt/iobroker/node_modules/iobroker.iot/admin/static/media/Cold Water.937aad5fa21b0c20a856.svg static/media/Cold Water.937aad5fa21b0c20a856.svg image/svg+xml
                  upload [90] iot.admin /opt/iobroker/node_modules/iobroker.iot/admin/static/media/Doorstep.10630b759b4867a10776.svg static/media/Doorstep.10630b759b4867a10776.svg image/svg+xml
                  upload [80] iot.admin /opt/iobroker/node_modules/iobroker.iot/admin/static/media/Garage Doors.0c2a1cfca7ad1ea59625.svg static/media/Garage Doors.0c2a1cfca7ad1ea59625.svg image/svg+xml
                  upload [70] iot.admin /opt/iobroker/node_modules/iobroker.iot/admin/static/media/Handle.3de1d1320fc3ce2f9712.svg static/media/Handle.3de1d1320fc3ce2f9712.svg image/svg+xml
                  upload [60] iot.admin /opt/iobroker/node_modules/iobroker.iot/admin/static/media/Laundry Room.58da550dff0173676e02.svg static/media/Laundry Room.58da550dff0173676e02.svg image/svg+xml
                  upload [50] iot.admin /opt/iobroker/node_modules/iobroker.iot/admin/static/media/Music.67bc6063cb601642fd74.svg static/media/Music.67bc6063cb601642fd74.svg image/svg+xml
                  upload [40] iot.admin /opt/iobroker/node_modules/iobroker.iot/admin/static/media/Pump.a6035507cddbe7db5f6a.svg static/media/Pump.a6035507cddbe7db5f6a.svg image/svg+xml
                  upload [30] iot.admin /opt/iobroker/node_modules/iobroker.iot/admin/static/media/SmokeDetector.8222f77cb07030a409ee.svg static/media/SmokeDetector.8222f77cb07030a409ee.svg image/svg+xml
                  upload [20] iot.admin /opt/iobroker/node_modules/iobroker.iot/admin/static/media/Temperature Sensors.75d805988a6b77b231d8.svg static/media/Temperature Sensors.75d805988a6b77b231d8.svg image/svg+xml
                  upload [19] iot.admin /opt/iobroker/node_modules/iobroker.iot/admin/static/media/Terrace.d71d07d9290674f2ca20.svg static/media/Terrace.d71d07d9290674f2ca20.svg image/svg+xml
                  upload [18] iot.admin /opt/iobroker/node_modules/iobroker.iot/admin/static/media/Toilet.83604dd2daafb67067dd.svg static/media/Toilet.83604dd2daafb67067dd.svg image/svg+xml
                  upload [17] iot.admin /opt/iobroker/node_modules/iobroker.iot/admin/static/media/Tv.4e9745a548e57bfac0c7.svg static/media/Tv.4e9745a548e57bfac0c7.svg image/svg+xml
                  upload [16] iot.admin /opt/iobroker/node_modules/iobroker.iot/admin/static/media/Upstairs.441813e54e0daca0882d.svg static/media/Upstairs.441813e54e0daca0882d.svg image/svg+xml
                  upload [15] iot.admin /opt/iobroker/node_modules/iobroker.iot/admin/static/media/Vacuum Cleaner.9c8d50e436e6cea06dfa.svg static/media/Vacuum Cleaner.9c8d50e436e6cea06dfa.svg image/svg+xml
                  upload [14] iot.admin /opt/iobroker/node_modules/iobroker.iot/admin/static/media/Ventilation.c31761d86d67e245ac92.svg static/media/Ventilation.c31761d86d67e245ac92.svg image/svg+xml
                  upload [13] iot.admin /opt/iobroker/node_modules/iobroker.iot/admin/static/media/Wardrobe.e8019970a2b51412cfdc.svg static/media/Wardrobe.e8019970a2b51412cfdc.svg image/svg+xml
                  upload [12] iot.admin /opt/iobroker/node_modules/iobroker.iot/admin/static/media/Washing Machines.577f3acdb3cef002b523.svg static/media/Washing Machines.577f3acdb3cef002b523.svg image/svg+xml
                  upload [11] iot.admin /opt/iobroker/node_modules/iobroker.iot/admin/static/media/Washroom.bfb54196f381f36de9d6.svg static/media/Washroom.bfb54196f381f36de9d6.svg image/svg+xml
                  upload [10] iot.admin /opt/iobroker/node_modules/iobroker.iot/admin/static/media/Water Consumption.68891649591cc2434c5b.svg static/media/Water Consumption.68891649591cc2434c5b.svg image/svg+xml
                  upload [9] iot.admin /opt/iobroker/node_modules/iobroker.iot/admin/static/media/Water Heater.7e4bb4d99a5213f24d08.svg static/media/Water Heater.7e4bb4d99a5213f24d08.svg image/svg+xml
                  upload [8] iot.admin /opt/iobroker/node_modules/iobroker.iot/admin/static/media/Water.f50411984c5c24fa574d.svg static/media/Water.f50411984c5c24fa574d.svg image/svg+xml
                  upload [7] iot.admin /opt/iobroker/node_modules/iobroker.iot/admin/static/media/Wc.83604dd2daafb67067dd.svg static/media/Wc.83604dd2daafb67067dd.svg image/svg+xml
                  upload [6] iot.admin /opt/iobroker/node_modules/iobroker.iot/admin/static/media/Weather.e91dae647698d48365e3.svg static/media/Weather.e91dae647698d48365e3.svg image/svg+xml
                  upload [5] iot.admin /opt/iobroker/node_modules/iobroker.iot/admin/static/media/Window.421664f57c35e5109aa2.svg static/media/Window.421664f57c35e5109aa2.svg image/svg+xml
                  upload [4] iot.admin /opt/iobroker/node_modules/iobroker.iot/admin/static/media/Windscreen.6058448bf63f72dd5036.svg static/media/Windscreen.6058448bf63f72dd5036.svg image/svg+xml
                  upload [3] iot.admin /opt/iobroker/node_modules/iobroker.iot/admin/static/media/Workshop.7856e59fe4f164c90609.svg static/media/Workshop.7856e59fe4f164c90609.svg image/svg+xml
                  upload [2] iot.admin /opt/iobroker/node_modules/iobroker.iot/admin/static/media/Workspace.97d73e419d966bfb6428.svg static/media/Workspace.97d73e419d966bfb6428.svg image/svg+xml
                  upload [1] iot.admin /opt/iobroker/node_modules/iobroker.iot/admin/static/media/names.3a7dae0bd6b8b03b280f.txt static/media/names.3a7dae0bd6b8b03b280f.txt text/plain
                  upload [0] iot.admin /opt/iobroker/node_modules/iobroker.iot/admin/static/media/names.e7efb5283d98000c74ac.txt static/media/names.e7efb5283d98000c74ac.txt text/plain
                  host.raspberrypi Adapter "system.adapter.iot.0" is started
                  This upgrade of "history" will at least introduce the following changes:
                  -> 3.0.1:
                  activated the round option when averaging
                  -> 3.0.0:
                  fix history2db.js with controller v5
                  Minimal node.sj version is 16
                  Added support for `count` aggregate type on getHistory
                  -> 2.2.6:
                  Fix getHistory when aggregations were used in some cases
                  -> 2.2.5:
                  -> 2.2.4:
                  Update for future js-controller versions
                  -> 2.2.3:
                  Fix error in history2db converter script
                  -> 2.2.1:
                  Fix crash cases reported by Sentry
                  Would you like to upgrade history from @1.9.10 to @3.0.1 now? [(y)es, (n)o]: y
                  Update history from @1.9.10 to @3.0.1
                  NPM version: 9.8.1
                  Installing iobroker.history@3.0.1... (System call)
                  removed 1 package, and changed 2 packages in 11s
                  Update "system.adapter.history.0"
                  upload [13] history.admin /opt/iobroker/node_modules/iobroker.history/admin/history.png history.png image/png
                  upload [12] history.admin /opt/iobroker/node_modules/iobroker.history/admin/i18n/de/translations.json i18n/de/translations.json application/json
                  upload [11] history.admin /opt/iobroker/node_modules/iobroker.history/admin/i18n/en/translations.json i18n/en/translations.json application/json
                  upload [10] history.admin /opt/iobroker/node_modules/iobroker.history/admin/i18n/es/translations.json i18n/es/translations.json application/json
                  upload [9] history.admin /opt/iobroker/node_modules/iobroker.history/admin/i18n/fr/translations.json i18n/fr/translations.json application/json
                  upload [8] history.admin /opt/iobroker/node_modules/iobroker.history/admin/i18n/it/translations.json i18n/it/translations.json application/json
                  upload [7] history.admin /opt/iobroker/node_modules/iobroker.history/admin/i18n/nl/translations.json i18n/nl/translations.json application/json
                  upload [6] history.admin /opt/iobroker/node_modules/iobroker.history/admin/i18n/pl/translations.json i18n/pl/translations.json application/json
                  upload [5] history.admin /opt/iobroker/node_modules/iobroker.history/admin/i18n/pt/translations.json i18n/pt/translations.json application/json
                  upload [4] history.admin /opt/iobroker/node_modules/iobroker.history/admin/i18n/ru/translations.json i18n/ru/translations.json application/json
                  upload [3] history.admin /opt/iobroker/node_modules/iobroker.history/admin/i18n/zh-cn/translations.json i18n/zh-cn/translations.json application/json
                  upload [2] history.admin /opt/iobroker/node_modules/iobroker.history/admin/jsonConfig.json jsonConfig.json application/json
                  upload [1] history.admin /opt/iobroker/node_modules/iobroker.history/admin/jsonCustom.json jsonCustom.json application/json
                  upload [0] history.admin /opt/iobroker/node_modules/iobroker.history/admin/words.js words.js application/javascript
                  This upgrade of "habpanel" will introduce the following changes:
                  -> 0.5.0:
                  added on support for new websockets
                  -> 0.4.3:
                  The compatibility to socket.io 3.0.13 provided
                  Would you like to upgrade habpanel from @0.4.1 to @0.5.0 now? [(y)es, (n)o]: y
                  Update habpanel from @0.4.1 to @0.5.0
                  NPM version: 9.8.1
                  Installing iobroker.habpanel@0.5.0... (System call)
                  added 2 packages, and changed 2 packages in 23s
                  upload [1750] habpanel /opt/iobroker/node_modules/iobroker.habpanel/www/app/app.js app/app.js application/javascript
                  upload [1700] habpanel /opt/iobroker/node_modules/iobroker.habpanel/www/app/widgets/knob/knob.tpl.html app/widgets/knob/knob.tpl.html text/html
                  upload [1650] habpanel /opt/iobroker/node_modules/iobroker.habpanel/www/assets/i18n/admin/it.json assets/i18n/admin/it.json application/json
                  upload [1600] habpanel /opt/iobroker/node_modules/iobroker.habpanel/www/assets/i18n/main/en.po assets/i18n/main/en.po null
                  upload [1550] habpanel /opt/iobroker/node_modules/iobroker.habpanel/www/assets/i18n/widgets/ar.json assets/i18n/widgets/ar.json application/json
                  upload [1500] habpanel /opt/iobroker/node_modules/iobroker.habpanel/www/assets/i18n/widgets/sv.po assets/i18n/widgets/sv.po null
                  upload [1450] habpanel /opt/iobroker/node_modules/iobroker.habpanel/www/assets/icons/eclipse-smarthome-classic/battery-90.png assets/icons/eclipse-smarthome-classic/battery-90.png image/png
                  upload [1400] habpanel /opt/iobroker/node_modules/iobroker.habpanel/www/assets/icons/eclipse-smarthome-classic/boy_4.png assets/icons/eclipse-smarthome-classic/boy_4.png image/png
                  upload [1350] habpanel /opt/iobroker/node_modules/iobroker.habpanel/www/assets/icons/eclipse-smarthome-classic/cistern-30.png assets/icons/eclipse-smarthome-classic/cistern-30.png image/png
                  upload [1300] habpanel /opt/iobroker/node_modules/iobroker.habpanel/www/assets/icons/eclipse-smarthome-classic/dimmablelight-40.png assets/icons/eclipse-smarthome-classic/dimmablelight-40.png image/png
                  upload [1250] habpanel /opt/iobroker/node_modules/iobroker.habpanel/www/assets/icons/eclipse-smarthome-classic/fire-on.svg assets/icons/eclipse-smarthome-classic/fire-on.svg image/svg+xml
                  upload [1200] habpanel /opt/iobroker/node_modules/iobroker.habpanel/www/assets/icons/eclipse-smarthome-classic/garagedoor.svg assets/icons/eclipse-smarthome-classic/garagedoor.svg image/svg+xml
                  upload [1150] habpanel /opt/iobroker/node_modules/iobroker.habpanel/www/assets/icons/eclipse-smarthome-classic/humidity-100.svg assets/icons/eclipse-smarthome-classic/humidity-100.svg image/svg+xml
                  upload [1100] habpanel /opt/iobroker/node_modules/iobroker.habpanel/www/assets/icons/eclipse-smarthome-classic/man_3.svg assets/icons/eclipse-smarthome-classic/man_3.svg image/svg+xml
                  upload [1050] habpanel /opt/iobroker/node_modules/iobroker.habpanel/www/assets/icons/eclipse-smarthome-classic/parents_2_2.svg assets/icons/eclipse-smarthome-classic/parents_2_2.svg image/svg+xml
                  upload [1000] habpanel /opt/iobroker/node_modules/iobroker.habpanel/www/assets/icons/eclipse-smarthome-classic/parents_6_3.svg assets/icons/eclipse-smarthome-classic/parents_6_3.svg image/svg+xml
                  upload [950] habpanel /opt/iobroker/node_modules/iobroker.habpanel/www/assets/icons/eclipse-smarthome-classic/qualityofservice.svg assets/icons/eclipse-smarthome-classic/qualityofservice.svg image/svg+xml
                  upload [900] habpanel /opt/iobroker/node_modules/iobroker.habpanel/www/assets/icons/eclipse-smarthome-classic/sewerage-20.svg assets/icons/eclipse-smarthome-classic/sewerage-20.svg image/svg+xml
                  upload [850] habpanel /opt/iobroker/node_modules/iobroker.habpanel/www/assets/icons/eclipse-smarthome-classic/slider-30.svg assets/icons/eclipse-smarthome-classic/slider-30.svg image/svg+xml
                  upload [800] habpanel /opt/iobroker/node_modules/iobroker.habpanel/www/assets/icons/eclipse-smarthome-classic/switch-off.svg assets/icons/eclipse-smarthome-classic/switch-off.svg image/svg+xml
                  upload [750] habpanel /opt/iobroker/node_modules/iobroker.habpanel/www/assets/icons/eclipse-smarthome-classic/wind.svg assets/icons/eclipse-smarthome-classic/wind.svg image/svg+xml
                  upload [700] habpanel /opt/iobroker/node_modules/iobroker.habpanel/www/assets/icons/freepik-gadgets/cs-mixer.svg assets/icons/freepik-gadgets/cs-mixer.svg image/svg+xml
                  upload [650] habpanel /opt/iobroker/node_modules/iobroker.habpanel/www/assets/icons/freepik-gadgets/synthesizer.svg assets/icons/freepik-gadgets/synthesizer.svg image/svg+xml
                  upload [600] habpanel /opt/iobroker/node_modules/iobroker.habpanel/www/assets/icons/freepik-household/bookshelf.svg assets/icons/freepik-household/bookshelf.svg image/svg+xml
                  upload [550] habpanel /opt/iobroker/node_modules/iobroker.habpanel/www/assets/icons/freepik-household/door.svg assets/icons/freepik-household/door.svg image/svg+xml
                  upload [500] habpanel /opt/iobroker/node_modules/iobroker.habpanel/www/assets/icons/freepik-household/mixer-2.svg assets/icons/freepik-household/mixer-2.svg image/svg+xml
                  upload [450] habpanel /opt/iobroker/node_modules/iobroker.habpanel/www/assets/icons/freepik-household/sofa-17.svg assets/icons/freepik-household/sofa-17.svg image/svg+xml
                  upload [400] habpanel /opt/iobroker/node_modules/iobroker.habpanel/www/assets/icons/freepik-household/window-6.svg assets/icons/freepik-household/window-6.svg image/svg+xml
                  upload [350] habpanel /opt/iobroker/node_modules/iobroker.habpanel/www/assets/icons/freepik-housethings/bedroom-stairs-tool.svg assets/icons/freepik-housethings/bedroom-stairs-tool.svg image/svg+xml
                  upload [300] habpanel /opt/iobroker/node_modules/iobroker.habpanel/www/assets/icons/freepik-housethings/door-design.svg assets/icons/freepik-housethings/door-design.svg image/svg+xml
                  upload [250] habpanel /opt/iobroker/node_modules/iobroker.habpanel/www/assets/icons/freepik-housethings/house-building.svg assets/icons/freepik-housethings/house-building.svg image/svg+xml
                  upload [200] habpanel /opt/iobroker/node_modules/iobroker.habpanel/www/assets/icons/freepik-housethings/livingroom-lamp.svg assets/icons/freepik-housethings/livingroom-lamp.svg image/svg+xml
                  upload [150] habpanel /opt/iobroker/node_modules/iobroker.habpanel/www/assets/icons/freepik-housethings/shower-bathroom-tool.svg assets/icons/freepik-housethings/shower-bathroom-tool.svg image/svg+xml
                  upload [100] habpanel /opt/iobroker/node_modules/iobroker.habpanel/www/assets/icons/freepik-housethings/yard-fountain.svg assets/icons/freepik-housethings/yard-fountain.svg image/svg+xml
                  upload [90] habpanel /opt/iobroker/node_modules/iobroker.habpanel/www/assets/icons/smarthome-set/air-conditioning-indoor.svg assets/icons/smarthome-set/air-conditioning-indoor.svg image/svg+xml
                  upload [80] habpanel /opt/iobroker/node_modules/iobroker.habpanel/www/assets/icons/smarthome-set/eye.svg assets/icons/smarthome-set/eye.svg image/svg+xml
                  upload [70] habpanel /opt/iobroker/node_modules/iobroker.habpanel/www/assets/icons/smarthome-set/plug.svg assets/icons/smarthome-set/plug.svg image/svg+xml
                  upload [60] habpanel /opt/iobroker/node_modules/iobroker.habpanel/www/assets/icons/smarthome-set/socket-i.svg assets/icons/smarthome-set/socket-i.svg image/svg+xml
                  upload [50] habpanel /opt/iobroker/node_modules/iobroker.habpanel/www/assets/icons/smarthome-set.list.json assets/icons/smarthome-set.list.json application/json
                  upload [40] habpanel /opt/iobroker/node_modules/iobroker.habpanel/www/assets/styles/themes/default.css assets/styles/themes/default.css text/css
                  upload [30] habpanel /opt/iobroker/node_modules/iobroker.habpanel/www/assets/styles/themes/translucent/translucent.min.css assets/styles/themes/translucent/translucent.min.css text/css
                  upload [20] habpanel /opt/iobroker/node_modules/iobroker.habpanel/www/fonts/roboto/Roboto-Regular.ttf fonts/roboto/Roboto-Regular.ttf font/ttf
                  upload [19] habpanel /opt/iobroker/node_modules/iobroker.habpanel/www/fonts/roboto/Roboto-Regular.woff fonts/roboto/Roboto-Regular.woff font/woff
                  upload [18] habpanel /opt/iobroker/node_modules/iobroker.habpanel/www/fonts/roboto/Roboto-Regular.woff2 fonts/roboto/Roboto-Regular.woff2 font/woff2
                  upload [17] habpanel /opt/iobroker/node_modules/iobroker.habpanel/www/index.html index.html text/html
                  upload [16] habpanel /opt/iobroker/node_modules/iobroker.habpanel/www/manifest.json manifest.json application/json
                  upload [15] habpanel /opt/iobroker/node_modules/iobroker.habpanel/www/service-worker.js service-worker.js application/javascript
                  upload [14] habpanel /opt/iobroker/node_modules/iobroker.habpanel/www/tile.png tile.png image/png
                  upload [13] habpanel /opt/iobroker/node_modules/iobroker.habpanel/www/vendor/cm/addon/edit/closebrackets.js vendor/cm/addon/edit/closebrackets.js application/javascript
                  upload [12] habpanel /opt/iobroker/node_modules/iobroker.habpanel/www/vendor/cm/addon/edit/closetag.js vendor/cm/addon/edit/closetag.js application/javascript
                  upload [11] habpanel /opt/iobroker/node_modules/iobroker.habpanel/www/vendor/cm/addon/edit/matchbrackets.js vendor/cm/addon/edit/matchbrackets.js application/javascript
                  upload [10] habpanel /opt/iobroker/node_modules/iobroker.habpanel/www/vendor/cm/addon/edit/matchtags.js vendor/cm/addon/edit/matchtags.js application/javascript
                  upload [9] habpanel /opt/iobroker/node_modules/iobroker.habpanel/www/vendor/cm/addon/edit/xml.js vendor/cm/addon/edit/xml.js application/javascript
                  upload [8] habpanel /opt/iobroker/node_modules/iobroker.habpanel/www/vendor/cm/addon/fold/xml-fold.js vendor/cm/addon/fold/xml-fold.js application/javascript
                  upload [7] habpanel /opt/iobroker/node_modules/iobroker.habpanel/www/vendor/cm/addon/mode/overlay.js vendor/cm/addon/mode/overlay.js application/javascript
                  upload [6] habpanel /opt/iobroker/node_modules/iobroker.habpanel/www/vendor/cm/lib/codemirror.css vendor/cm/lib/codemirror.css text/css
                  upload [5] habpanel /opt/iobroker/node_modules/iobroker.habpanel/www/vendor/cm/lib/codemirror.js vendor/cm/lib/codemirror.js application/javascript
                  upload [4] habpanel /opt/iobroker/node_modules/iobroker.habpanel/www/vendor/cm/mode/javascript/javascript.js vendor/cm/mode/javascript/javascript.js application/javascript
                  upload [3] habpanel /opt/iobroker/node_modules/iobroker.habpanel/www/vendor/cm/mode/xml/xml.js vendor/cm/mode/xml/xml.js application/javascript
                  upload [2] habpanel /opt/iobroker/node_modules/iobroker.habpanel/www/vendor/cm/theme/rubyblue.css vendor/cm/theme/rubyblue.css text/css
                  upload [1] habpanel /opt/iobroker/node_modules/iobroker.habpanel/www/vendor/styles.min.css vendor/styles.min.css text/css
                  upload [0] habpanel /opt/iobroker/node_modules/iobroker.habpanel/www/vendor/vendor.js vendor/vendor.js application/javascript
                  Update "system.adapter.habpanel.0"
                  upload [0] habpanel.admin /opt/iobroker/node_modules/iobroker.habpanel/admin/habpanel.png habpanel.png image/png
                  This upgrade of "fullybrowser" will at least introduce the following changes:
                  -> 2.2.0:
                  intrvall corr
                  -> 2.1.6:
                  add name of devie to admin
                  -> 2.1.2:
                  encodeuri for psw
                  -> 2.1.1:
                  js-controller 4.x
                  Would you like to upgrade fullybrowser from @2.0.1 to @2.2.0 now? [(y)es, (n)o]: y
                  Update fullybrowser from @2.0.1 to @2.2.0
                  NPM version: 9.8.1
                  Installing iobroker.fullybrowser@2.2.0... (System call)
                  removed 2 packages, and changed 3 packages in 9s
                  Update "system.adapter.fullybrowser.0"
                  upload [2] fullybrowser.admin /opt/iobroker/node_modules/iobroker.fullybrowser/admin/fully.png fully.png image/png
                  upload [1] fullybrowser.admin /opt/iobroker/node_modules/iobroker.fullybrowser/admin/index_m.html index_m.html text/html
                  upload [0] fullybrowser.admin /opt/iobroker/node_modules/iobroker.fullybrowser/admin/words.js words.js application/javascript
                  This upgrade of "backitup" will introduce the following changes:
                  -> 2.8.7:
                  fix restore in docker v9
                  -> 2.8.6:
                  Fix node-red restore
                  dependencies updated
                  -> 2.8.5:
                  Fix mount errors
                  -> 2.8.4:
                  Fix mysql Backup
                  Fix pgsql Backup
                  Fix InfluxDB Backup
                  -> 2.8.3:
                  Wake on LAN Advanced Settings added
                  -> 2.8.2:
                  Fix redis backup
                  Would you like to upgrade backitup from @2.8.1 to @2.8.7 now? [(y)es, (n)o]: y
                  Update backitup from @2.8.1 to @2.8.7
                  host.raspberrypi Adapter "system.adapter.backitup.0" is stopped.
                  NPM version: 9.8.1
                  Installing iobroker.backitup@2.8.7... (System call)
                  Update "system.adapter.backitup.0"
                  upload [21] backitup.admin /opt/iobroker/node_modules/iobroker.backitup/admin/adapter-settings.js adapter-settings.js application/javascript
                  upload [20] backitup.admin /opt/iobroker/node_modules/iobroker.backitup/admin/backitup.png backitup.png image/png
                  upload [19] backitup.admin /opt/iobroker/node_modules/iobroker.backitup/admin/backitup.svg backitup.svg image/svg+xml
                  upload [18] backitup.admin /opt/iobroker/node_modules/iobroker.backitup/admin/i18n/de/translations.json i18n/de/translations.json application/json
                  upload [17] backitup.admin /opt/iobroker/node_modules/iobroker.backitup/admin/i18n/en/translations.json i18n/en/translations.json application/json
                  upload [16] backitup.admin /opt/iobroker/node_modules/iobroker.backitup/admin/i18n/es/translations.json i18n/es/translations.json application/json
                  upload [15] backitup.admin /opt/iobroker/node_modules/iobroker.backitup/admin/i18n/fr/translations.json i18n/fr/translations.json application/json
                  upload [14] backitup.admin /opt/iobroker/node_modules/iobroker.backitup/admin/i18n/it/translations.json i18n/it/translations.json application/json
                  upload [13] backitup.admin /opt/iobroker/node_modules/iobroker.backitup/admin/i18n/nl/translations.json i18n/nl/translations.json application/json
                  upload [12] backitup.admin /opt/iobroker/node_modules/iobroker.backitup/admin/i18n/pl/translations.json i18n/pl/translations.json application/json
                  upload [11] backitup.admin /opt/iobroker/node_modules/iobroker.backitup/admin/i18n/pt/translations.json i18n/pt/translations.json application/json
                  upload [10] backitup.admin /opt/iobroker/node_modules/iobroker.backitup/admin/i18n/ru/translations.json i18n/ru/translations.json application/json
                  upload [9] backitup.admin /opt/iobroker/node_modules/iobroker.backitup/admin/i18n/uk/translations.json i18n/uk/translations.json application/json
                  upload [8] backitup.admin /opt/iobroker/node_modules/iobroker.backitup/admin/i18n/zh-cn/translations.json i18n/zh-cn/translations.json application/json
                  upload [7] backitup.admin /opt/iobroker/node_modules/iobroker.backitup/admin/index.html index.html text/html
                  upload [6] backitup.admin /opt/iobroker/node_modules/iobroker.backitup/admin/index_m.html index_m.html text/html
                  upload [5] backitup.admin /opt/iobroker/node_modules/iobroker.backitup/admin/index_m.js index_m.js application/javascript
                  upload [4] backitup.admin /opt/iobroker/node_modules/iobroker.backitup/admin/style.css style.css text/css
                  upload [3] backitup.admin /opt/iobroker/node_modules/iobroker.backitup/admin/tab_m.css tab_m.css text/css
                  upload [2] backitup.admin /opt/iobroker/node_modules/iobroker.backitup/admin/tab_m.html tab_m.html text/html
                  upload [1] backitup.admin /opt/iobroker/node_modules/iobroker.backitup/admin/tab_m.js tab_m.js application/javascript
                  upload [0] backitup.admin /opt/iobroker/node_modules/iobroker.backitup/admin/words.js words.js application/javascript
                  host.raspberrypi Adapter "system.adapter.backitup.0" is started
                  pi@raspberrypi:/opt/iobroker $ iob start
                    Thomas Braun Most Active @Alex e last edited by
                    @alex-e sagte in js-controller Update mit npm ERR:
                    Der funktioniert als git-Version wohl wieder mit js-controller5.
                    • mcm1957
                      @alex-e said in js-controller Update mit npm ERR:
                      https://github.com/iobroker-community-adapters/ioBroker.samsung_tizen#100-alpha1-2023-09-24
                      Mit ioBroker.smsung_tizen von aus der community sollte js-controller 5 kein Problem haben - oder umgekehrt. Zumindest hab ich nix negatives erfahren.
                      Release in Repos fehlt noch - steht aber auf der (ellenlangen) Liste 🙂
                        Alex e @mcm1957 last edited by
                        @mcm57 @Thomas-Braun
                        Vielen Dank auch noch für den Tipp mit dem Tizen Adapter.
                        Ich habe mein System jetzt (um zu testen ob das Backup funktioniert) aus dem Backup neu aufgsetzt und dann den Tizen Adapter aus Github neu installiert.
                        Bisher funktioniert alles wunderbar.
                        • mcm1957
                          @mcm57 @Thomas-Braun .
                          Warum installierst du von Github?
                          Installationen von Github sollten NUR auf Aufforderung des DEV und iA. zur Fehleranalyse oder dem Test eines Hot-Fixes erfolgen. Für die normale Benutzung - insbesondere auf produktiven Systemen - wird von einer GITHUB Installation dringend abgeraten.
                          Der Adapter ist längst normal im Repo verfügbar:
                          1.0.0 (2023-09-30)
                          (mcm1957) An official release has been created
                          1567
