    3. Einsteigerfragen
    4. Installation
    5. Installation unter TrueNAS Scale
      anselra last edited by
      Hallo zusammen, kann mir jemand sagen der auf TrueNas den iobrocker als Docker laufen hat wie lange dieser zum Start benötigt und ggf ein log hochladen? Meiner braucht über 2 Stunden
      2024-01-01 14:11:40.443456+00:002024-01-01T14:11:40.443456497Z
      2024-01-01 14:11:40.444240+00:00--------------------------------------------------------------------------------
      2024-01-01 14:11:40.445449+00:00-------------------------     2024-01-01 15:11:40      -------------------------
      2024-01-01 14:11:40.446293+00:00--------------------------------------------------------------------------------
      2024-01-01 14:11:40.446352+00:00-----        -----
      2024-01-01 14:11:40.446406+00:00----- ██╗  ██████╗  ██████╗  ██████╗   ██████╗  ██╗  ██╗ ███████╗ ██████╗  -----
      2024-01-01 14:11:40.446504+00:00----- ██║ ██╔═══██╗ ██╔══██╗ ██╔══██╗ ██╔═══██╗ ██║ ██╔╝ ██╔════╝ ██╔══██╗ -----
      2024-01-01 14:11:40.446543+00:00----- ██║ ██║   ██║ ██████╔╝ ██████╔╝ ██║   ██║ █████╔╝  █████╗   ██████╔╝ -----
      2024-01-01 14:11:40.446580+00:00----- ██║ ██║   ██║ ██╔══██╗ ██╔══██╗ ██║   ██║ ██╔═██╗  ██╔══╝   ██╔══██╗ -----
      2024-01-01 14:11:40.446675+00:00----- ██║ ╚██████╔╝ ██████╔╝ ██║  ██║ ╚██████╔╝ ██║  ██╗ ███████╗ ██║  ██║ -----
      2024-01-01 14:11:40.446702+00:00----- ╚═╝  ╚═════╝  ╚═════╝  ╚═╝  ╚═╝  ╚═════╝  ╚═╝  ╚═╝ ╚══════╝ ╚═╝  ╚═╝ -----
      2024-01-01 14:11:40.446738+00:00-----        -----
      2024-01-01 14:11:40.446771+00:00-----              Welcome to your ioBroker Docker container!              -----
      2024-01-01 14:11:40.446792+00:00-----                    Startupscript is now running!                     -----
      2024-01-01 14:11:40.446824+00:00-----                          Please be patient!                          -----
      2024-01-01 14:11:40.447578+00:00--------------------------------------------------------------------------------
      2024-01-01 14:11:40.447665+00:002024-01-01T14:11:40.447665831Z
      2024-01-01 14:11:40.448473+00:00--------------------------------------------------------------------------------
      2024-01-01 14:11:40.448533+00:00-----                          System Information                          -----
      2024-01-01 14:11:40.450693+00:00-----                    arch:                x86_64                       -----
      2024-01-01 14:11:40.452681+00:00-----                    hostname:            iobroker-ix-chart-7dd88dbb68-bhx7r -----
      2024-01-01 14:11:40.452761+00:00-----        -----
      2024-01-01 14:11:40.452802+00:00-----                          Version Information                         -----
      2024-01-01 14:11:40.453398+00:00-----                    image:               v9.0.1                       -----
      2024-01-01 14:11:40.454041+00:00-----                    build:               2023-12-01T18:43:20+00:00    -----
      2024-01-01 14:11:40.463800+00:00-----                    node:                v18.19.0                     -----
      2024-01-01 14:11:41.136371+00:00-----                    npm:                 10.2.3                       -----
      2024-01-01 14:11:41.136496+00:00-----        -----
      2024-01-01 14:11:41.136635+00:00-----                        Environment Variables                         -----
      2024-01-01 14:11:41.137829+00:00-----                    SETGID:              1000                         -----
      2024-01-01 14:11:41.138651+00:00-----                    SETUID:              1000                         -----
      2024-01-01 14:11:41.139598+00:00--------------------------------------------------------------------------------
      2024-01-01 14:11:41.139750+00:002024-01-01T14:11:41.139750054Z
      2024-01-01 14:11:41.140526+00:00--------------------------------------------------------------------------------
      2024-01-01 14:11:41.140613+00:00-----                   Step 1 of 5: Preparing container                   -----
      2024-01-01 14:11:41.141288+00:00--------------------------------------------------------------------------------
      2024-01-01 14:11:41.141355+00:002024-01-01T14:11:41.141355176Z
      2024-01-01 16:28:56.811560+00:00Updating Linux packages on first run... Done.
      2024-01-01 16:29:01.001809+00:002024-01-01T16:29:01.001809776Z
      2024-01-01 16:29:01.001883+00:002024-01-01T16:29:01.001883447Z
      2024-01-01 16:29:01.001932+00:002024-01-01T16:29:01.001932149Z
      2024-01-01 16:29:03.388081+00:00Registering maintenance script as command... Done.
      2024-01-01 16:29:03.388387+00:002024-01-01T16:29:03.388387202Z
      2024-01-01 16:29:03.396216+00:00--------------------------------------------------------------------------------
      2024-01-01 16:29:03.396365+00:00-----             Step 2 of 5: Detecting ioBroker installation             -----
      2024-01-01 16:29:03.397242+00:00--------------------------------------------------------------------------------
      2024-01-01 16:29:03.397331+00:002024-01-01T16:29:03.397331442Z
      2024-01-01 16:29:04.305935+00:00Existing installation of ioBroker detected in "/opt/iobroker".
      2024-01-01 16:29:04.306168+00:002024-01-01T16:29:04.306168560Z
      2024-01-01 16:29:04.307361+00:00--------------------------------------------------------------------------------
      2024-01-01 16:29:04.307490+00:00-----             Step 3 of 5: Checking ioBroker installation              -----
      2024-01-01 16:29:04.308267+00:00--------------------------------------------------------------------------------
      2024-01-01 16:29:04.308361+00:002024-01-01T16:29:04.308361521Z
      2024-01-01 16:29:36.074091+00:00(Re)setting permissions (This might take a while! Please be patient!)... Done.
      2024-01-01 16:29:36.074282+00:002024-01-01T16:29:36.074282965Z
      2024-01-01 16:29:50.384220+00:00Checking Database connection... Done.
      2024-01-01 16:29:50.384339+00:002024-01-01T16:29:50.384339127Z
      2024-01-01 16:30:19.426032+00:00Hostname in ioBroker matches the hostname of this container.
      2024-01-01 16:30:19.426268+00:00No action required.
      2024-01-01 16:30:19.426310+00:002024-01-01T16:30:19.426310073Z
      2024-01-01 16:30:19.427164+00:00--------------------------------------------------------------------------------
      2024-01-01 16:30:19.427265+00:00-----                Step 4 of 5: Applying special settings                -----
      2024-01-01 16:30:19.428215+00:00--------------------------------------------------------------------------------
      2024-01-01 16:30:19.428335+00:002024-01-01T16:30:19.428335452Z
      2024-01-01 16:30:19.428384+00:00Some adapters have special requirements/ settings which can be activated by the use of environment variables.
      2024-01-01 16:30:19.428409+00:00For more information see ioBroker Docker Image Docs (https://docs.buanet.de/iobroker-docker-image/docs/).
      2024-01-01 16:30:19.428461+00:002024-01-01T16:30:19.428461968Z
      2024-01-01 16:30:19.432101+00:002024-01-01T16:30:19.432101312Z
      2024-01-01 16:30:19.434664+00:00--------------------------------------------------------------------------------
      2024-01-01 16:30:19.434725+00:00-----                    Step 5 of 5: ioBroker startup                     -----
      2024-01-01 16:30:19.435444+00:00--------------------------------------------------------------------------------
      2024-01-01 16:30:19.435515+00:002024-01-01T16:30:19.435515785Z
      2024-01-01 16:30:19.435543+00:00Starting ioBroker...
      Gruß Ralf
      • OliverIO
        OliverIO @anselra last edited by
        @anselra
        Da stimmt was nicht. Zwischen den Zeilen mit dem großen Zeitsprung passiert gemäß dem Skript eigentlich nichts.
        https://github.com/buanet/ioBroker.docker/blob/0cbfd67f5a97cfee8615c9434e34b54721340c72/debian11/scripts/iobroker_startup.sh#L128
        https://github.com/buanet/ioBroker.docker/blob/0cbfd67f5a97cfee8615c9434e34b54721340c72/debian11/scripts/iobroker_startup.sh#L138
        https://github.com/buanet/ioBroker.docker/blob/0cbfd67f5a97cfee8615c9434e34b54721340c72/debian11/scripts/setup_packages.sh#L61
          anselra @OliverIO last edited by
          @oliverio
          kannst du mir einen tip geben wie ich das gefixt bekomme?
          Danke vorab
          Gruß Ralf
          • OliverIO
            @anselra
            Container neu aufsetzen, erst mal clean ohne Backup in irgendeinem Verzeichnis
            Deine Konfigurationsfragen in truenas hier mal posten
            • David G.
              David G. last edited by
              Worauf hast du denn truenas am laufen?
              Evtl wäre es ja ein Weg auf dem Rechner proxmox zu installieren und dann beide Systeme dort zu virtualisieren.
              So mache ich es.
              Hätte auch Vorteile alles ordentlich sichern zu können.
                @oliverio
                die Konfiguration ist so aufgesetzt, hoffe das hast du gemeint?!
                Ich habe keine bessere Darstellungsoption gefunden.
                Was ich gerade gemacht habe ist ein Update auf TrueNAS-SCALE-23.10.1 und die Startzeit ging deutlich nach unten
                2024-01-03 12:02:15.527333+01:002024-01-03T12:02:15.527333454+01:00
                2024-01-03 12:02:15.528312+01:00--------------------------------------------------------------------------------
                2024-01-03 12:02:15.529971+01:00-------------------------     2024-01-03 12:02:15      -------------------------
                2024-01-03 12:02:15.530902+01:00--------------------------------------------------------------------------------
                2024-01-03 12:02:15.530937+01:00-----        -----
                2024-01-03 12:02:15.531041+01:00----- ██╗  ██████╗  ██████╗  ██████╗   ██████╗  ██╗  ██╗ ███████╗ ██████╗  -----
                2024-01-03 12:02:15.531082+01:00----- ██║ ██╔═══██╗ ██╔══██╗ ██╔══██╗ ██╔═══██╗ ██║ ██╔╝ ██╔════╝ ██╔══██╗ -----
                2024-01-03 12:02:15.531142+01:00----- ██║ ██║   ██║ ██████╔╝ ██████╔╝ ██║   ██║ █████╔╝  █████╗   ██████╔╝ -----
                2024-01-03 12:02:15.531215+01:00----- ██║ ██║   ██║ ██╔══██╗ ██╔══██╗ ██║   ██║ ██╔═██╗  ██╔══╝   ██╔══██╗ -----
                2024-01-03 12:02:15.531251+01:00----- ██║ ╚██████╔╝ ██████╔╝ ██║  ██║ ╚██████╔╝ ██║  ██╗ ███████╗ ██║  ██║ -----
                2024-01-03 12:02:15.531295+01:00----- ╚═╝  ╚═════╝  ╚═════╝  ╚═╝  ╚═╝  ╚═════╝  ╚═╝  ╚═╝ ╚══════╝ ╚═╝  ╚═╝ -----
                2024-01-03 12:02:15.531327+01:00-----        -----
                2024-01-03 12:02:15.531366+01:00-----              Welcome to your ioBroker Docker container!              -----
                2024-01-03 12:02:15.531394+01:00-----                    Startupscript is now running!                     -----
                2024-01-03 12:02:15.531423+01:00-----                          Please be patient!                          -----
                2024-01-03 12:02:15.532361+01:00--------------------------------------------------------------------------------
                2024-01-03 12:02:15.532412+01:002024-01-03T12:02:15.532412934+01:00
                2024-01-03 12:02:15.533231+01:00--------------------------------------------------------------------------------
                2024-01-03 12:02:15.533266+01:00-----                          System Information                          -----
                2024-01-03 12:02:15.536921+01:00-----                    arch:                x86_64                       -----
                2024-01-03 12:02:15.540194+01:00-----                    hostname:            iobroker-ix-chart-7dd88dbb68-knbc7 -----
                2024-01-03 12:02:15.540335+01:00-----        -----
                2024-01-03 12:02:15.540417+01:00-----                          Version Information                         -----
                2024-01-03 12:02:15.541120+01:00-----                    image:               v9.0.1                       -----
                2024-01-03 12:02:15.542002+01:00-----                    build:               2023-12-24T23:44:38+00:00    -----
                2024-01-03 12:02:15.615136+01:00-----                    node:                v18.19.0                     -----
                2024-01-03 12:02:16.455563+01:00-----                    npm:                 10.2.3                       -----
                2024-01-03 12:02:16.455646+01:00-----        -----
                2024-01-03 12:02:16.455668+01:00-----                        Environment Variables                         -----
                2024-01-03 12:02:16.456926+01:00-----                    SETGID:              1000                         -----
                2024-01-03 12:02:16.457689+01:00-----                    SETUID:              1000                         -----
                2024-01-03 12:02:16.458573+01:00--------------------------------------------------------------------------------
                2024-01-03 12:02:16.458688+01:002024-01-03T12:02:16.458688525+01:00
                2024-01-03 12:02:16.459491+01:00--------------------------------------------------------------------------------
                2024-01-03 12:02:16.459558+01:00-----                   Step 1 of 5: Preparing container                   -----
                2024-01-03 12:02:16.460359+01:00--------------------------------------------------------------------------------
                2024-01-03 12:02:16.460416+01:002024-01-03T12:02:16.460416103+01:00
                2024-01-03 12:25:59.556504+01:00Updating Linux packages on first run... Done.
                2024-01-03 12:26:03.690595+01:002024-01-03T12:26:03.690595643+01:00
                2024-01-03 12:26:03.690703+01:002024-01-03T12:26:03.690703258+01:00
                2024-01-03 12:26:03.690724+01:002024-01-03T12:26:03.690724355+01:00
                2024-01-03 12:26:05.414778+01:00Registering maintenance script as command... Done.
                2024-01-03 12:26:05.414895+01:002024-01-03T12:26:05.414895718+01:00
                Gruß Ralf
                  anselra @David G. last edited by
                  @david-g
                  Mein TrueNas läuft auf einem Asrock C3758D4I-4L mit 32GB UDIMM
                  Ich bin damit eigentlich sehr zufrieden, Proxmox hatte damals Probleme mit dem Board.
                  Gruß Ralf
                  • OliverIO
                    @anselra
                    2 Dinge sind mir aufgefallen
                    1. unter Speicher steht bei mount path
                    opt/iobroker
                    müsste das nicht /opt/iobroker heißen?
                    1. das kann was trueNAS spezifisches sein in dem man einen macvlan oder iplan container erstellt unter Networking die angaben zu Host Interface
                      unter Docker definiert man das separat, einmal ein macvlan netzwerk
                      und dann in der containerdefinition die zuordnung des netzwerks
                      da du aber probleme beim start hast, kann das eigentlich erst mal keine auswirkungen haben, aber du kannst mal im container das netzwerk controllieren ob das so entspricht wie du dir das vorstellst mit ifconfig
                      @oliverio
                      danke für deinen Input, Änderung des mount path hat keine Auswirkungen.
                      Ich kann aktuell mit den ca. 20 Minuten Startzeit recht gut leben und werde mich am WE mal dran setzen den Container neu aufzusetzen da sich um mein aktuelles Produktivstem handelt. Ich habe keinen weg gefunden einen weiteren Docker aufzubauen der nicht auf das selbe Image zugreift, diese verhalten sich gleich beim starten. Ich werde berichten
                      Gruß Ralf
                      • OliverIO
                        @anselra
                        Es gibt noch eine environment Variable von Buanet mit dem man den debug Modus des Containers einschalten kann
                        1.0k
                        3899
