    4. Diskussion zum HowTo nodejs-Installation und upgrade
      Thomas Braun Most Active @djsirius last edited by
      @djsirius sagte in Diskussion zum HowTo nodejs-Installation und upgrade:
      npm ERR! invalid: iobroker.openligadb@1.3.4 /opt/iobroker/node_modules/iobroker.openligadb
      npm ERR! invalid: iobroker.tibberconnect@0.0.10 /opt/iobroker/node_modules/iobroker.tibberconnect
      Installier die beiden Adapter nochmal. Am besten NICHT über github, sondern eine 'ordentliche' Installation aus einem Repo.
        djsirius @Homoran last edited by
        @homoran said in Diskussion zum HowTo nodejs-Installation und upgrade:
        iobroker.service loaded failed failed ioBroker Server
        da läuft ja nix
        npm ERR! code ELSPROBLEMS
        Probleme mit npm?
        iobroker is not running
        s.o.
        Ich habe den iobroker gestoppt um das Update vom js-controller zu machen. Ist das falsch?
        Skript v.2023-10-10
        *** BASE SYSTEM ***
           Static hostname: debian
                 Icon name: computer-desktop
                   Chassis: desktop
          Operating System: Debian GNU/Linux 11 (bullseye)
                    Kernel: Linux 5.10.0-26-amd64
              Architecture: x86-64
        model name      : Intel(R) Core(TM) i5-2400 CPU @ 3.10GHz
        Docker          : false
        Virtualization  : none
        Kernel          : x86_64
        Userland        : amd64
        Systemuptime and Load:
         15:01:52 up 19:34,  1 user,  load average: 0.37, 0.48, 0.28
        CPU threads: 4
        *** Time and Time Zones ***
                       Local time: Thu 2024-01-04 15:01:52 CET
                   Universal time: Thu 2024-01-04 14:01:52 UTC
                         RTC time: Thu 2024-01-04 14:01:52
                      NTP service: active
                  RTC in local TZ: no
        *** User and Groups ***
        iobroker
        /home/iobroker
        iobroker tty dialout cdrom floppy sudo audio dip video plugdev netdev bluetooth lpadmin scanner
        *** X-Server-Setup ***
        X-Server:       false
        Desktop:
        Terminal:       tty
        *** MEMORY ***
        Mem:            7.9G        2.8G        3.9G        5.0M        1.1G        4.7G
        Swap:           4.0G          0B        4.0G
        Total:           11G        2.8G        7.9G
                 7864 M total memory
                 2838 M used memory
                  684 M active memory
                 2912 M inactive memory
                 3928 M free memory
                  121 M buffer memory
                  976 M swap cache
                 4015 M total swap
                    0 M used swap
                 4015 M free swap
        *** FAILED SERVICES ***
        0 loaded units listed.
        *** FILESYSTEM ***
        Filesystem                         Type      Size  Used Avail Use% Mounted on
        udev                               devtmpfs  3.9G     0  3.9G   0% /dev
        tmpfs                              tmpfs     787M  2.5M  785M   1% /run
        /dev/sda2                          ext4      454G   44G  387G  11% /
        tmpfs                              tmpfs     3.9G     0  3.9G   0% /dev/shm
        tmpfs                              tmpfs     5.0M  4.0K  5.0M   1% /run/lock
        /dev/sda1                          vfat      511M  5.8M  506M   2% /boot/efi
        //192.168.1.1/GLADYS7490/TREKSTOR/ cifs      467G  353G  114G  76% /media/fritzbox
        tmpfs                              tmpfs     787M   40K  787M   1% /run/user/1000
        [Wed Jan  3 19:27:32 2024] EXT4-fs (sda2): mounted filesystem with ordered data mode. Opts: (null)
        [Wed Jan  3 19:27:39 2024] EXT4-fs (sda2): re-mounted. Opts: errors=remount-ro
        TARGET            SOURCE                             FSTYPE OPTIONS
        /                 /dev/sda2                          ext4   rw,relatime,errors=remount-ro
        |-/media/fritzbox //192.168.1.1/GLADYS7490/TREKSTOR/ cifs   rw,relatime,vers=1.0,cache=strict,username=mount,uid=1000,forceuid,gid=1000,forcegid,addr=192.168.1.1,file_mode=0755,dir_mode=0755,soft,nounix,serverino,mapposix,rsize=61440,wsize=65536,bsize=1048576,echo_interval=60,actimeo=1
        `-/boot/efi       /dev/sda1                          vfat   rw,relatime,fmask=0077,dmask=0077,codepage=437,iocharset=ascii,shortname=mixed,utf8,errors=remount-ro
        /var:
        7.3G    /var/
        4.1G    /var/log
        4.0G    /var/log/journal/f063d3dd2a6e40efad76adb6a70d9daf
        2.4G    /var/cache/apt
        Archived and active journals take up 3.6G in the file system.
        /opt/iobroker/backups:
        115M    /opt/iobroker/backups/
        /opt/iobroker/iobroker-data:
        1.1G    /opt/iobroker/iobroker-data/
        600M    /opt/iobroker/iobroker-data/files
        357M    /opt/iobroker/iobroker-data/backup-objects
        73M     /opt/iobroker/iobroker-data/files/telegram.admin
        67M     /opt/iobroker/iobroker-data/files/javascript.admin
        70M     /opt/iobroker/iobroker-data/states.jsonl
        35M     /opt/iobroker/iobroker-data/files/devices.admin/static/js/main.24f2bb56.js.map
        34M     /opt/iobroker/iobroker-data/objects.jsonl
        33M     /opt/iobroker/iobroker-data/files/iot.admin/static/js/main.1797d034.js.map
        22M     /opt/iobroker/iobroker-data/files/modbus.admin/static/js/main.b5f6766c.js.map
        USB-Devices by-id:
        *** NodeJS-Installation ***
        /usr/bin/nodejs         v18.19.0
        /usr/bin/node           v18.19.0
        /usr/bin/npm            10.2.3
        /usr/bin/npx            10.2.3
        /usr/bin/corepack       0.22.0
        nodejs:
          Installed: 18.19.0-1nodesource1
          Candidate: 18.19.0-1nodesource1
          Version table:
         *** 18.19.0-1nodesource1 500
                500 https://deb.nodesource.com/node_18.x nodistro/main amd64 Packages
                100 /var/lib/dpkg/status
             18.18.2-1nodesource1 500
             18.18.1-1nodesource1 500
             18.18.0-1nodesource1 500
             18.17.1-1nodesource1 500
             18.17.0-1nodesource1 500
             18.16.1-1nodesource1 500
             18.16.0-1nodesource1 500
             18.15.0-1nodesource1 500
             18.14.2-1nodesource1 500
             18.14.1-1nodesource1 500
             18.14.0-1nodesource1 500
             18.13.0-1nodesource1 500
             18.12.0-1nodesource1 500
             18.11.0-1nodesource1 500
             18.10.0-1nodesource1 500
             18.9.1-1nodesource1 500
             18.9.0-1nodesource1 500
             18.8.0-1nodesource1 500
             18.7.0-1nodesource1 500
             18.6.0-1nodesource1 500
             18.5.0-1nodesource1 500
             18.4.0-1nodesource1 500
             18.3.0-1nodesource1 500
             18.2.0-1nodesource1 500
             18.1.0-1nodesource1 500
             18.0.0-1nodesource1 500
             12.22.12~dfsg-1~deb11u4 500
                500 http://ftp.de.debian.org/debian bullseye/main amd64 Packages
                500 http://deb.debian.org/debian bullseye/main amd64 Packages
        No problems detected
        Errors in npm tree:
        npm ERR! extraneous: @types/caseless@0.12.5 /opt/iobroker/node_modules/@types/caseless
        npm ERR! extraneous: @types/request@2.48.12 /opt/iobroker/node_modules/@types/request
        npm ERR! extraneous: @types/tough-cookie@4.0.5 /opt/iobroker/node_modules/@types/tough-cookie
        npm ERR! extraneous: coffeescript@2.7.0 /opt/iobroker/node_modules/coffeescript
        npm ERR! extraneous: jsonata@2.0.3 /opt/iobroker/node_modules/jsonata
        npm ERR! extraneous: node-inspect@2.0.0 /opt/iobroker/node_modules/node-inspect
        npm ERR! extraneous: picocolors@1.0.0 /opt/iobroker/node_modules/picocolors
        npm ERR! extraneous: suncalc2@1.8.1 /opt/iobroker/node_modules/suncalc2
        npm ERR! extraneous: typescript@5.2.2 /opt/iobroker/node_modules/typescript
        npm ERR! extraneous: virtual-tsc@0.6.2 /opt/iobroker/node_modules/virtual-tsc
        npm ERR! extraneous: wake_on_lan@1.0.0 /opt/iobroker/node_modules/wake_on_lan
        npm ERR! extraneous: form-data@2.5.1 /opt/iobroker/node_modules/@types/request/node_modules/form-data
        npm ERR! extraneous: debug@4.3.4 /opt/iobroker/node_modules/virtual-tsc/node_modules/debug
        npm ERR! extraneous: ms@2.1.2 /opt/iobroker/node_modules/virtual-tsc/node_modules/ms
        npm ERR! invalid: xmlbuilder@0.4.2 /opt/iobroker/node_modules/xmlbuilder
        npm ERR! invalid: buffer@5.7.1 /opt/iobroker/node_modules/buffer
        npm ERR! A complete log of this run can be found in: /home/iobroker/.npm/_logs/2024-01-04T14_01_54_476Z-debug-0.log
        *** ioBroker-Installation ***
        ioBroker Status
        Objects type: jsonl
        States  type: jsonl
        Core adapters versions
        js-controller:  4.0.24
        admin:          6.12.0
        javascript:     7.1.6
        npm ERR! A complete log of this run can be found in: /home/iobroker/.npm/_logs/2024-01-04T14_02_02_971Z-debug-0.log
        Adapters from github:   2
        Adapter State
        + system.adapter.admin.0                  : admin                 : debian                                   -  enabled, port: 8081, bind: 0.0.0.0 (SSL), run as: admin
        + system.adapter.alexa2.0                 : alexa2                : debian                                   -  enabled
        + system.adapter.backitup.0               : backitup              : debian                                   -  enabled
          system.adapter.daswetter.0              : daswetter             : debian                                   -  enabled
          system.adapter.devices.0                : devices               : debian                                   -  enabled
        + system.adapter.discovery.0              : discovery             : debian                                   -  enabled
          system.adapter.dwd.0                    : dwd                   : debian                                   -  enabled
        + system.adapter.enigma2.0                : enigma2               : raspberrypi                              -  enabled
          system.adapter.feiertage.0              : feiertage             : debian                                   -  enabled
          system.adapter.flot.0                   : flot                  : debian                                   -  enabled
        + system.adapter.history.0                : history               : debian                                   -  enabled
        + system.adapter.hm-rega.0                : hm-rega               : debian                                   -  enabled
        + system.adapter.hm-rpc.0                 : hm-rpc                : debian                                   -  enabled, port: 0
        + system.adapter.hm-rpc.1                 : hm-rpc                : debian                                   -  enabled, port: 0
          system.adapter.ical.0                   : ical                  : debian                                   -  enabled
          system.adapter.ical.1                   : ical                  : debian                                   -  enabled
          system.adapter.ical.2                   : ical                  : debian                                   -  enabled
          system.adapter.icons-mfd-png.0          : icons-mfd-png         : debian                                   -  enabled
          system.adapter.icons-mfd-svg.0          : icons-mfd-svg         : debian                                   -  enabled
        + system.adapter.info.0                   : info                  : debian                                   -  enabled
        + system.adapter.iot.0                    : iot                   : debian                                   -  enabled
        + system.adapter.javascript.0             : javascript            : debian                                   -  enabled
        + system.adapter.lg-thinq.0               : lg-thinq              : debian                                   -  enabled
        + system.adapter.linux-control.0          : linux-control         : debian                                   -  enabled
        + system.adapter.logparser.0              : logparser             : debian                                   -  enabled
        + system.adapter.meross.0                 : meross                : debian                                   -  enabled
        + system.adapter.mihome-vacuum.0          : mihome-vacuum         : debian                                   -  enabled, port: 54321
          system.adapter.mobile.0                 : mobile                : debian                                   -  enabled
        + system.adapter.modbus.0                 : modbus                : debian                                   -  enabled
        + system.adapter.openligadb.0             : openligadb            : debian                                   -  enabled
        + system.adapter.ping.0                   : ping                  : debian                                   -  enabled
        + system.adapter.pollenflug.0             : pollenflug            : debian                                   -  enabled
        + system.adapter.rpi2.1                   : rpi2                  : raspberrypi                              -  enabled
        + system.adapter.scenes.0                 : scenes                : debian                                   -  enabled
        + system.adapter.shelly.0                 : shelly                : debian                                   -  enabled, port: 1882, bind: 0.0.0.0
        + system.adapter.simple-api.0             : simple-api            : debian                                   -  enabled, port: 8087, bind: 0.0.0.0, run as: admin
        + system.adapter.socketio.0               : socketio              : debian                                   -  enabled, port: 8084, bind: 0.0.0.0 (SSL), run as: admin
        + system.adapter.sql.0                    : sql                   : debian                                   -  enabled, port: 3306
        + system.adapter.systeminfo.0             : systeminfo            : debian                                   -  enabled
        + system.adapter.tankerkoenig.0           : tankerkoenig          : debian                                   -  enabled
        + system.adapter.telegram.0               : telegram              : debian                                   -  enabled, port: 8443, bind: 0.0.0.0
        + system.adapter.terminal.0               : terminal              : debian                                   -  enabled, port: 8088, bind: 0.0.0.0, run as: admin
        + system.adapter.text2command.0           : text2command          : debian                                   -  enabled
        + system.adapter.tibberlink.0             : tibberlink            : debian                                   -  enabled
        + system.adapter.tr-064.0                 : tr-064                : debian                                   -  enabled
        + system.adapter.trashschedule.0          : trashschedule         : debian                                   -  enabled
        + system.adapter.upnp.0                   : upnp                  : debian                                   -  enabled
        + system.adapter.viessmannapi.0           : viessmannapi          : debian                                   -  enabled
          system.adapter.vis-bars.0               : vis-bars              : debian                                   -  enabled
          system.adapter.vis-canvas-gauges.0      : vis-canvas-gauges     : debian                                   -  enabled
          system.adapter.vis-colorpicker.0        : vis-colorpicker       : debian                                   -  enabled
          system.adapter.vis-fancyswitch.0        : vis-fancyswitch       : debian                                   -  enabled
          system.adapter.vis-history.0            : vis-history           : debian                                   -  enabled
          system.adapter.vis-hqwidgets.0          : vis-hqwidgets         : debian                                   -  enabled
          system.adapter.vis-jqui-mfd.0           : vis-jqui-mfd          : debian                                   -  enabled
          system.adapter.vis-justgage.0           : vis-justgage          : debian                                   -  enabled
          system.adapter.vis-materialdesign.0     : vis-materialdesign    : debian                                   -  enabled
          system.adapter.vis-metro.0              : vis-metro             : debian                                   -  enabled
          system.adapter.vis-plumb.0              : vis-plumb             : debian                                   -  enabled
          system.adapter.vis-timeandweather.0     : vis-timeandweather    : debian                                   -  enabled
          system.adapter.vis-weather.0            : vis-weather           : debian                                   -  enabled
          system.adapter.vis.0                    : vis                   : debian                                   -  enabled
        + system.adapter.web.0                    : web                   : debian                                   -  enabled, port: 8082, bind: 0.0.0.0, run as: admin
          system.adapter.zigbee.0                 : zigbee                : raspberrypi                              - disabled, port: /dev/ttyUSB0
        + instance is alive
        ioBroker-Repositories
        Active repo(s): stable
        Installed ioBroker-Instances
        Used repository: stable
        Adapter    "admin"        : 6.12.0   , installed 6.12.0
        Adapter    "alexa2"       : 3.26.3   , installed 3.26.2 [Updatable]
        Adapter    "backitup"     : 2.9.8    , installed 2.8.7  [Updatable]
        Adapter    "daswetter"    : 3.1.11   , installed 3.1.11
        Adapter    "feiertage"    : 1.1.4    , installed 1.1.4
        Adapter    "hm-rega"      : 4.0.0    , installed 4.0.0
        Adapter    "hm-rpc"       : 1.15.19  , installed 1.15.19
        Adapter    "iot"          : 2.0.11   , installed 2.0.11
        Adapter    "javascript"   : 7.1.6    , installed 7.1.6
        Controller "js-controller": 5.0.17   , installed 4.0.24 [Updatable]
        Adapter    "lg-thinq"     : 0.1.4    , installed 0.1.4
        Adapter    "linux-control": 1.1.5    , installed 1.1.5
        Adapter    "logparser"    : 2.2.0    , installed 2.2.0
        Adapter    "meross"       : 1.16.1   , installed 1.16.1
        Adapter    "mihome-vacuum": 4.1.0    , installed 4.1.0
        Adapter    "mobile"       : 1.0.1    , installed 1.0.1
        Adapter    "modbus"       : 6.0.1    , installed 6.0.1
        Adapter    "openligadb"   : 1.2.4    , installed 1.3.4
        Adapter    "pollenflug"   : 1.0.6    , installed 1.0.6
        Adapter    "shelly"       : 6.6.1    , installed 6.6.1
        Adapter    "sql"          : 2.2.0    , installed 2.2.0
        Adapter    "systeminfo"   : 1.1.0    , installed 1.1.0
        Adapter    "telegram"     : 3.0.1    , installed 3.0.1
        Adapter    "terminal"     : 1.0.0    , installed 1.0.0
        Adapter    "text2command" : 3.0.2    , installed 3.0.2
        Adapter    "tibberlink"   : 2.0.0    , installed 2.0.0
        Adapter    "trashschedule": 2.3.0    , installed 2.3.0
        Adapter    "upnp"         : 1.0.21   , installed 1.0.21
        Adapter    "viessmannapi" : 2.3.0    , installed 2.3.0
        Adapter    "vis-justgage" : 2.1.0    , installed 2.1.0
        Adapter    "vis-weather"  : 2.5.6    , installed 2.5.6
        Adapter    "web"          : 6.1.10   , installed 6.1.10
        Adapter    "ws"           : 2.5.8    , installed 2.5.8
        Objects and States
        Objects:        27978
        States:         22662
        Hit:1 http://ftp.de.debian.org/debian bullseye InRelease
        Hit:2 http://ftp.de.debian.org/debian bullseye-updates InRelease
        Hit:3 http://deb.debian.org/debian bullseye InRelease
        Hit:4 http://deb.debian.org/debian bullseye-updates InRelease
        Hit:5 http://deb.debian.org/debian bullseye-backports InRelease
        Hit:6 https://deb.nodesource.com/node_18.x nodistro InRelease
        Hit:7 https://packages.sury.org/php bullseye InRelease
        Hit:8 https://packagecloud.io/ookla/speedtest-cli/debian bullseye InRelease
        Reading package lists...
        Pending Updates: 0
        *** Listening Ports ***
        tcp        0      0 192.168.1.16:8701       0.0.0.0:*               LISTEN      1000       3906617    2073310/io.hm-rpc.1
        tcp        0      0 0.0.0.0:445             0.0.0.0:*               LISTEN      0          16729      808/smbd
        tcp        0      0 0.0.0.0:9000            0.0.0.0:*               LISTEN      1000       3901948    2072931/iobroker.js
        tcp        0      0 0.0.0.0:9001            0.0.0.0:*               LISTEN      1000       3901937    2072931/iobroker.js
        tcp        0      0 0.0.0.0:139             0.0.0.0:*               LISTEN      0          16730      808/smbd
        tcp        0      0 0.0.0.0:111             0.0.0.0:*               LISTEN      0          618        1/init
        tcp        0      0 192.168.1.16:2001       0.0.0.0:*               LISTEN      1000       3903816    2073084/io.hm-rpc.0
        tcp        0      0 0.0.0.0:22              0.0.0.0:*               LISTEN      0          1719       509/sshd: /usr/sbin
        tcp        0      0 127.0.0.1:631           0.0.0.0:*               LISTEN      0          1073875    562579/cupsd
        tcp        0      0 127.0.0.1:25            0.0.0.0:*               LISTEN      0          17439      800/exim4
        tcp        0      0 0.0.0.0:1882            0.0.0.0:*               LISTEN      1000       3904358    2073336/io.shelly.0
        tcp6       0      0 :::443                  :::*                    LISTEN      0          1851       787/apache2
        tcp6       0      0 :::445                  :::*                    LISTEN      0          16727      808/smbd
        tcp6       0      0 :::139                  :::*                    LISTEN      0          16728      808/smbd
        tcp6       0      0 :::111                  :::*                    LISTEN      0          622        1/init
        tcp6       0      0 :::80                   :::*                    LISTEN      0          1847       787/apache2
        tcp6       0      0 :::8081                 :::*                    LISTEN      1000       3903614    2072950/io.admin.0
        tcp6       0      0 :::8082                 :::*                    LISTEN      1000       3914125    2076273/io.web.0
        tcp6       0      0 :::8084                 :::*                    LISTEN      1000       3910869    2074746/io.socketio
        tcp6       0      0 :::22                   :::*                    LISTEN      0          1721       509/sshd: /usr/sbin
        tcp6       0      0 :::8087                 :::*                    LISTEN      1000       3910040    2074489/io.simple-a
        tcp6       0      0 ::1:631                 :::*                    LISTEN      0          1073874    562579/cupsd
        tcp6       0      0 :::8088                 :::*                    LISTEN      1000       3911944    2075331/io.terminal
        tcp6       0      0 ::1:25                  :::*                    LISTEN      0          17440      800/exim4
        udp        0      0 0.0.0.0:631             0.0.0.0:*                           0          1076452    562586/cups-browsed
        udp        0      0 192.168.1.16:5353       0.0.0.0:*                           1000       3906800    2073282/io.tr-064.0
        udp        0      0 0.0.0.0:5353            0.0.0.0:*                           112        1609       419/avahi-daemon: r
        udp        0      0 0.0.0.0:1900            0.0.0.0:*                           1000       3915805    2075908/io.upnp.0
        udp        0      0 0.0.0.0:59503           0.0.0.0:*                           112        1611       419/avahi-daemon: r
        udp        0      0 0.0.0.0:57375           0.0.0.0:*                           1000       3912188    2075908/io.upnp.0
        udp        0      0 0.0.0.0:111             0.0.0.0:*                           0          619        1/init
        udp        0      0 192.168.1.255:137       0.0.0.0:*                           0          18480      538/nmbd
        udp        0      0 192.168.1.16:137        0.0.0.0:*                           0          18479      538/nmbd
        udp        0      0 0.0.0.0:137             0.0.0.0:*                           0          18460      538/nmbd
        udp        0      0 192.168.1.255:138       0.0.0.0:*                           0          18482      538/nmbd
        udp        0      0 192.168.1.16:138        0.0.0.0:*                           0          18481      538/nmbd
        udp        0      0 0.0.0.0:138             0.0.0.0:*                           0          18461      538/nmbd
        udp        0      0 0.0.0.0:53421           0.0.0.0:*                           1000       3905755    2073211/io.mihome-v
        udp6       0      0 fe80::ca9c:dcff:fee:546 :::*                                0          16340      422/NetworkManager
        udp6       0      0 :::5353                 :::*                                112        1610       419/avahi-daemon: r
        udp6       0      0 :::59025                :::*                                112        1612       419/avahi-daemon: r
        udp6       0      0 :::111                  :::*                                0          625        1/init
        2024-01-04 14:57:07.416  - info: lg-thinq.0 (2076539) MQTT connected to: t20/op/4859c133c7b998076e20059473cf71b1ebd27dfe4321c9740a3ce75973cbbf5a/inbox
        2024-01-04 14:57:08.267  - info: host.debian instance system.adapter.tibberlink.0 started with pid 2076872
        2024-01-04 14:57:09.704  - info: tibberlink.0 (2076872) starting. Version 2.0.0 in /opt/iobroker/node_modules/iobroker.tibberlink, node: v18.19.0, js-controller: 4.0.24
        2024-01-04 14:57:28.874  - info: meross.0 (2073191) Can not get Data for Device 1912244352887225188148e1e9147e10: Error: Device has no data connection available
        2024-01-04 14:57:28.875  - warn: meross.0 (2073191) Can not get Data for Device 1912244352887225188148e1e9147e10: undefined
        2024-01-04 14:58:35.018  - info: meross.0 (2073191) Can not get Data for Device 1912244352887225188148e1e9147e10: Error: Device has no data connection available
        2024-01-04 14:58:35.019  - warn: meross.0 (2073191) Can not get Data for Device 1912244352887225188148e1e9147e10: undefined
        2024-01-04 14:59:41.163  - info: meross.0 (2073191) Can not get Data for Device 1912244352887225188148e1e9147e10: Error: Device has no data connection available
        2024-01-04 14:59:41.163  - warn: meross.0 (2073191) Can not get Data for Device 1912244352887225188148e1e9147e10: undefined
        2024-01-04 15:00:00.028  - info: host.debian instance system.adapter.dwd.0 started with pid 2083021
        2024-01-04 15:00:00.155  - info: javascript.0 (2072992) script.js.Speedtest: Speedtest mit Server 44081 gestartet! Der Test dauert zwischen 10 - 20 Sekunden!
        2024-01-04 15:00:01.308  - info: dwd.0 (2083021) starting. Version 2.8.5 in /opt/iobroker/node_modules/iobroker.dwd, node: v18.19.0, js-controller: 4.0.24
        2024-01-04 15:00:03.904  - info: dwd.0 (2083021) Terminated (ADAPTER_REQUESTED_TERMINATION): Without reason
        2024-01-04 15:00:04.035  - info: host.debian instance system.adapter.daswetter.0 started with pid 2083350
        2024-01-04 15:00:04.455  - info: host.debian instance system.adapter.dwd.0 terminated with code 11 (ADAPTER_REQUESTED_TERMINATION)
        2024-01-04 15:00:05.306  - info: daswetter.0 (2083350) starting. Version 3.1.11 in /opt/iobroker/node_modules/iobroker.daswetter, node: v18.19.0, js-controller: 4.0.24
        2024-01-04 15:00:13.817  - info: daswetter.0 (2083350) still wrong data structure from server received! repaired...
        2024-01-04 15:00:15.732  - info: daswetter.0 (2083350) Terminated (ADAPTER_REQUESTED_TERMINATION): All data handled, adapter stopped until next scheduled moment
        2024-01-04 15:00:16.243  - info: daswetter.0 (2083350) cleaned everything up...
        2024-01-04 15:00:16.258  - info: host.debian instance system.adapter.daswetter.0 terminated with code 11 (ADAPTER_REQUESTED_TERMINATION)
        2024-01-04 15:00:26.694  - info: javascript.0 (2072992) script.js.Speedtest: Speedtest durchgeführt. Ergebnisse: Download: 10.47 MB/s | Upload: 4.43 MB/s | Ping: 14.979ms
        2024-01-04 15:00:47.306  - info: meross.0 (2073191) Can not get Data for Device 1912244352887225188148e1e9147e10: Error: Device has no data connection available
        2024-01-04 15:00:47.307  - warn: meross.0 (2073191) Can not get Data for Device 1912244352887225188148e1e9147e10: undefined
        2024-01-04 15:01:53.450  - info: meross.0 (2073191) Can not get Data for Device 1912244352887225188148e1e9147e10: Error: Device has no data connection available
        2024-01-04 15:01:53.450  - warn: meross.0 (2073191) Can not get Data for Device 1912244352887225188148e1e9147e10: undefined
        iob diag has finished.
          djsirius @Thomas Braun last edited by
          @thomas-braun said in Diskussion zum HowTo nodejs-Installation und upgrade:
          Kann das denn das Problem sein? Es ist doch vor dem Update von Nodejs und NPM ja auch gelaufen.
            Das sorgt jedenfalls für die angemeckerten npm errors.
              Weil z.B. Openligadb läuft Version aus dem repo nicht ohne Fehler.
                @djsirius
                Dann installier es nochmal aus github. Es muss aber halt nochmal frisch draufgebügelt werden.
                  @thomas-braun ich kann ja leider keine Adapter installieren, bzw. updaten, weil ja jede Installation bzw. Update stehen bleibt. Das ist ja mein Problem, seitdem ich Nodejs und NPM geupdatet habe. 😞
                    @djsirius
                    iob update && iob upgrade all -y --debug
                    auf dem Host 'debian' sagt?
                      das habe ich auch schon versucht.
                      iobroker@debian:~$ iob update && iob upgrade all -y --debug
                      Update backitup from @2.8.7 to @2.9.8
                      host.debian Adapter "system.adapter.backitup.0" is stopped.
                      NPM version: 10.2.3
                      Installing iobroker.backitup@2.9.8... (System call)
                      Danach tut sich nichts mehr!
                      Thomas Braun D 2 Replies Last reply Reply Quote 0
                        Warten. Ggf. laaaaaaaaaaaaaaaaaaaaaaaaange warten.
                          @thomas-braun ok. Das längste war 2 Stunden. Aber ich lasse es mal bis morgen laufen.
                            djsirius @djsirius last edited by djsirius
                            @djsirius said in Diskussion zum HowTo nodejs-Installation und upgrade:
                            NPM version: 10.2.3
                            Leider hat sich über Nacht nichts mehr getan! Was kann ich jetzt noch machen? Vielleicht Nodejs und NPM neu installieren?
                            Weil das Update war ja der Punkt, nachdem kein Update/Installation der Adapter mehr funktioniert hat.
                            Vielen Dank!
                              Eigentlich sollte das schon passen.
                                @thomas-braun Okay, aber was kann ich jetzt noch machen? Ich kenne mich leider zu wenig damit aus. 😞
                                Was für mich komisch ist, dass auf Master und Slave das gleich Problem nach dem Update von Nodejs und NPM besteht.
                                  @djsirius
                                  Gib mal von beiden Kisten ein vollständiges
                                  iob diag
                                  bekannt.
                                    iob diag
                                    Master:
                                    Skript v.2023-10-10
                                    *** BASE SYSTEM ***
                                               Chassis: desktop
                                    Docker          : false
                                    Kernel          : x86_64
                                    Userland        : amd64
                                     10:44:00 up 1 day, 15:16,  1 user,  load average: 0.79, 0.49, 0.31
                                    CPU threads: 4
                                                   Local time: Fri 2024-01-05 10:44:00 CET
                                               Universal time: Fri 2024-01-05 09:44:00 UTC
                                                     RTC time: Fri 2024-01-05 09:44:01
                                                  NTP service: active
                                              RTC in local TZ: no
                                    iobroker
                                    /home/iobroker
                                    X-Server:       false
                                    Desktop:
                                    Terminal:       tty
                                    *** MEMORY ***
                                    Mem:            7.9G        4.4G        2.7G        5.0M        837M        3.2G
                                    Swap:           4.0G          0B        4.0G
                                    Total:           11G        4.4G        6.7G
                                             7864 M total memory
                                             4364 M used memory
                                              341 M active memory
                                             4539 M inactive memory
                                             2662 M free memory
                                              161 M buffer memory
                                              676 M swap cache
                                             4015 M total swap
                                                0 M used swap
                                             4015 M free swap
                                    *** FILESYSTEM ***
                                    /var:
                                    7.3G    /var/
                                    4.1G    /var/log
                                    2.4G    /var/cache/apt
                                    356M    /opt/iobroker/iobroker-data/backup-objects
                                    81M     /opt/iobroker/iobroker-data/states.jsonl
                                    28M     /opt/iobroker/iobroker-data/objects.jsonl
                                    USB-Devices by-id:
                                    /usr/bin/npm            10.2.3
                                    /usr/bin/npx            10.2.3
                                    nodejs:
                                      Version table:
                                    Errors in npm tree:
                                    npm ERR! A complete log of this run can be found in: /home/iobroker/.npm/_logs/2024-01-05T09_44_23_394Z-debug-0.log
                                    ioBroker Status
                                    Objects type: jsonl
                                    States  type: jsonl
                                    admin:          6.12.0
                                    javascript:     7.1.6
                                    npm ERR! A complete log of this run can be found in: /home/iobroker/.npm/_logs/2024-01-05T09_44_34_780Z-debug-0.log
                                    Adapter State
                                    + system.adapter.zigbee.0                 : zigbee                : raspberrypi                              -  enabled, port: /dev/ttyUSB0
                                    + instance is alive
                                    Objects and States
                                    Objects:        27977
                                    States:         22607
                                    Pending Updates: 0
                                    tcp        0      0 192.168.1.16:8701       0.0.0.0:*               LISTEN      1000       4185347    2227684/io.hm-rpc.1
                                    tcp        0      0 0.0.0.0:9000            0.0.0.0:*               LISTEN      1000       4180940    2227358/iobroker.js
                                    tcp        0      0 0.0.0.0:9001            0.0.0.0:*               LISTEN      1000       4181668    2227358/iobroker.js
                                    tcp        0      0 192.168.1.16:2001       0.0.0.0:*               LISTEN      1000       4181880    2227508/io.hm-rpc.0
                                    tcp        0      0 127.0.0.1:631           0.0.0.0:*               LISTEN      0          5973237    3206164/cupsd
                                    tcp        0      0 0.0.0.0:1882            0.0.0.0:*               LISTEN      1000       4185455    2227740/io.shelly.0
                                    tcp6       0      0 :::8000                 :::*                    LISTEN      1000       4468441    2230360/io.upnp.0
                                    tcp6       0      0 :::8081                 :::*                    LISTEN      1000       4182414    2227376/io.admin.0
                                    tcp6       0      0 :::8082                 :::*                    LISTEN      1000       4192699    2230725/io.web.0
                                    tcp6       0      0 :::8084                 :::*                    LISTEN      1000       4189353    2229167/io.socketio
                                    tcp6       0      0 ::1:631                 :::*                    LISTEN      0          5973236    3206164/cupsd
                                    tcp6       0      0 :::8087                 :::*                    LISTEN      1000       4186947    2228911/io.simple-a
                                    tcp6       0      0 :::8088                 :::*                    LISTEN      1000       4188960    2229778/io.terminal
                                    udp        0      0 0.0.0.0:631             0.0.0.0:*                           0          5974812    3206193/cups-browse
                                    udp        0      0 192.168.1.16:5353       0.0.0.0:*                           1000       4183783    2227659/io.tr-064.0
                                    udp        0      0 0.0.0.0:1900            0.0.0.0:*                           1000       4192037    2230360/io.upnp.0
                                    udp        0      0 0.0.0.0:43465           0.0.0.0:*                           1000       4191823    2230360/io.upnp.0
                                    udp        0      0 0.0.0.0:53421           0.0.0.0:*                           1000       4182654    2227588/io.mihome-v
                                    2024-01-05 10:40:01.281  - info: dwd.0 (340585) starting. Version 2.8.5 in /opt/iobroker/node_modules/iobroker.dwd, node: v18.19.0, js-controller: 4.0.24
                                    2024-01-05 10:40:02.367  - info: dwd.0 (340585) Terminated (ADAPTER_REQUESTED_TERMINATION): Without reason
                                    2024-01-05 10:40:02.890  - info: host.debian instance system.adapter.dwd.0 terminated with code 11 (ADAPTER_REQUESTED_TERMINATION)
                                    2024-01-05 10:40:38.193  - error: lg-thinq.0 (2230962) Failed to get home
                                    2024-01-05 10:40:38.194  - error: lg-thinq.0 (2230962) AxiosError: Request failed with status code 400
                                    2024-01-05 10:40:38.194  - error: lg-thinq.0 (2230962) {"resultCode":"0102","result":""}
                                    2024-01-05 10:40:38.194  - info: lg-thinq.0 (2230962) Try to refresh Token
                                    2024-01-05 10:41:38.203  - error: lg-thinq.0 (2230962) Failed to get home
                                    2024-01-05 10:41:38.203  - error: lg-thinq.0 (2230962) AxiosError: Request failed with status code 400
                                    2024-01-05 10:41:38.203  - error: lg-thinq.0 (2230962) {"resultCode":"0102","result":""}
                                    2024-01-05 10:41:38.203  - info: lg-thinq.0 (2230962) Try to refresh Token
                                    2024-01-05 10:42:38.190  - error: lg-thinq.0 (2230962) Failed to get home
                                    2024-01-05 10:42:38.191  - error: lg-thinq.0 (2230962) AxiosError: Request failed with status code 400
                                    2024-01-05 10:42:38.191  - error: lg-thinq.0 (2230962) {"resultCode":"0102","result":""}
                                    2024-01-05 10:42:38.191  - info: lg-thinq.0 (2230962) Try to refresh Token
                                    2024-01-05 10:43:38.187  - error: lg-thinq.0 (2230962) Failed to get home
                                    2024-01-05 10:43:38.187  - error: lg-thinq.0 (2230962) AxiosError: Request failed with status code 400
                                    2024-01-05 10:43:38.188  - error: lg-thinq.0 (2230962) {"resultCode":"0102","result":""}
                                    2024-01-05 10:43:38.188  - info: lg-thinq.0 (2230962) Try to refresh Token
                                    2024-01-05 10:44:38.236  - error: lg-thinq.0 (2230962) Failed to get home
                                    2024-01-05 10:44:38.237  - error: lg-thinq.0 (2230962) AxiosError: Request failed with status code 400
                                    2024-01-05 10:44:38.237  - error: lg-thinq.0 (2230962) {"resultCode":"0102","result":""}
                                    2024-01-05 10:44:38.237  - info: lg-thinq.0 (2230962) Try to refresh Token
                                    2024-01-05 10:44:52.527  - info: admin.0 (2227376) failed connection to socket.io from ::ffff:192.168.1.201: Passport was not initialized
                                    2024-01-05 10:45:00.026  - info: host.debian instance system.adapter.dwd.0 started with pid 352969
                                    Slave:
                                    Skript v.2023-10-10
                                    *** BASE SYSTEM ***
                                       Static hostname: raspberrypi
                                             Icon name: computer
                                                Kernel: Linux 6.1.21-v8+
                                          Architecture: arm64
                                    Model           : Raspberry Pi 3 Model B Rev 1.2
                                    Docker          : false
                                    Kernel          : aarch64
                                    Userland        : arm64
                                     10:39:38 up 23:36,  1 user,  load average: 2.82, 1.21, 0.63
                                    CPU threads: 4
                                    *** RASPBERRY THROTTLING ***
                                    Current issues:
                                    Previously detected issues:
                                                   Local time: Fri 2024-01-05 10:39:38 CET
                                               Universal time: Fri 2024-01-05 09:39:38 UTC
                                                     RTC time: n/a
                                                  NTP service: active
                                              RTC in local TZ: no
                                    pi
                                    /home/pi
                                    pi adm dialout cdrom sudo audio video plugdev games users input render netdev gpio i2c spi iobroker
                                    X-Server:       false
                                    Desktop:
                                    Terminal:       tty
                                    Boot Target:    multi-user.target
                                    *** MEMORY ***
                                    Mem:            909M        527M         89M        0.0K        293M        319M
                                    Swap:            99M         38M         61M
                                    Total:          1.0G        565M        151M
                                              909 M total memory
                                              527 M used memory
                                              438 M active memory
                                              284 M inactive memory
                                               89 M free memory
                                                1 M buffer memory
                                              291 M swap cache
                                               99 M total swap
                                               38 M used swap
                                               61 M free swap
                                    Raspberry only:
                                    oom events: 0
                                    *** FILESYSTEM ***
                                    /dev/root      ext4       59G   32G   25G  57% /
                                    devtmpfs       devtmpfs  325M     0  325M   0% /dev
                                    tmpfs          tmpfs     455M     0  455M   0% /dev/shm
                                    tmpfs          tmpfs     182M  996K  181M   1% /run
                                    /dev/mmcblk0p1 vfat      255M   31M  225M  13% /boot
                                    tmpfs          tmpfs      91M     0   91M   0% /run/user/1000
                                    [Thu Jan  4 11:03:22 2024] Kernel command line: coherent_pool=1M 8250.nr_uarts=0 snd_bcm2835.enable_headphones=0 snd_bcm2835.enable_headphones=1 snd_bcm2835.enable_hdmi=1 snd_bcm2835.enable_hdmi=0 video=Composite-1:720x480@60i vc_mem.mem_base=0x3ec00000 vc_mem.mem_size=0x40000000  console=ttyS0,115200 console=tty1 root=PARTUUID=d3cf0315-02 rootfstype=ext4 fsck.repair=yes rootwait
                                    [Thu Jan  4 11:03:25 2024] EXT4-fs (mmcblk0p2): mounted filesystem with ordered data mode. Quota mode: none.
                                    [Thu Jan  4 11:03:25 2024] VFS: Mounted root (ext4 filesystem) readonly on device 179:2.
                                    [Thu Jan  4 11:03:29 2024] EXT4-fs (mmcblk0p2): re-mounted. Quota mode: none.
                                    /       /dev/mmcblk0p2 ext4   rw,noatime
                                    `-/boot /dev/mmcblk0p1 vfat   rw,relatime,fmask=0022,dmask=0022,codepage=437,iocharset=ascii,shortname=mixed,errors=remount-ro
                                    /var:
                                    27G     /var/
                                    22G     /var/lib/mysql/iobroker
                                    22G     /var/lib/mysql
                                    22G     /var/lib
                                    4.5G    /var/log
                                    Archived and active journals take up 4.0G in the file system.
                                    4.0K    /opt/iobroker/backups/
                                    18M     /opt/iobroker/iobroker-data/
                                    14M     /opt/iobroker/iobroker-data/files
                                    13M     /opt/iobroker/iobroker-data/files/admin.admin/custom/static/js
                                    6.3M    /opt/iobroker/iobroker-data/files/admin.admin/custom/static/js/vendors-node_modules_iobroker_adapter-react-v5_assets_devices_parseNames_js-node_modules_iobr-99c23e.847b8ad9.chunk.js.map
                                    3.0M    /opt/iobroker/iobroker-data/objects.jsonl
                                    2.8M    /opt/iobroker/iobroker-data/files/admin.admin/custom/static/js/vendors-node_modules_iobroker_adapter-react-v5_assets_devices_parseNames_js-node_modules_iobr-99c23e.847b8ad9.chunk.js
                                    1.6M    /opt/iobroker/iobroker-data/files/admin.admin/custom/static/js/vendors-node_modules_mui_material_Accordion_index_js-node_modules_mui_material_AccordionDetai-57e02d.0886b730.chunk.js.map
                                    652K    /opt/iobroker/iobroker-data/files/admin.admin/custom/static/js/vendors-node_modules_mui_material_index_js.40e01f69.chunk.js.map
                                    USB-Devices by-id:
                                    /dev/serial/by-id/usb-1a86_USB_Serial-if00-port0
                                    /usr/bin/npm            10.2.3
                                    /usr/bin/npx            10.2.3
                                    nodejs:
                                      Version table:
                                            500 http://deb.debian.org/debian bullseye/main arm64 Packages
                                            500 http://security.debian.org/debian-security bullseye-security/main arm64 Packages
                                    Errors in npm tree:
                                    ioBroker Status
                                    At least one iobroker host is running.
                                    Objects type: jsonl
                                    States  type: jsonl
                                    admin:          6.12.0
                                    javascript:     "javascript" not found
                                    Adapters from github:   0
                                    Adapter State
                                    + instance is alive
                                    Adapter    "enigma2"      : 2.0.5    , installed 2.0.5
                                    Adapter    "unifi"        : 0.6.7    , installed 0.6.7
                                    Adapter    "zigbee"       : 1.9.5    , installed 1.8.23 [Updatable]
                                    Objects and States
                                    Objects:        27977
                                    States:         22607
                                    Hit:1 http://security.debian.org/debian-security bullseye-security InRelease
                                    Hit:2 http://deb.debian.org/debian bullseye InRelease
                                    Hit:3 http://deb.debian.org/debian bullseye-updates InRelease
                                    Hit:4 http://archive.raspberrypi.org/debian bullseye InRelease
                                    Hit:5 https://deb.nodesource.com/node_18.x nodistro InRelease
                                    Pending Updates: 0
                                    tcp        0      0 0.0.0.0:22              0.0.0.0:*               LISTEN      0          12641      525/sshd: /usr/sbin
                                    tcp6       0      0 :::3306                 :::*                    LISTEN      110        12676      569/mariadbd
                                    tcp6       0      0 :::22                   :::*                    LISTEN      0          12643      525/sshd: /usr/sbin
                                    udp        0      0 0.0.0.0:68              0.0.0.0:*                           0          13987      780/dhcpcd
                                    udp        0      0 0.0.0.0:5353            0.0.0.0:*                           108        13921      394/avahi-daemon: r
                                    udp        0      0 0.0.0.0:58656           0.0.0.0:*                           108        13923      394/avahi-daemon: r
                                    udp6       0      0 :::41470                :::*                                108        13924      394/avahi-daemon: r
                                    udp6       0      0 :::546                  :::*                                0          13999      780/dhcpcd
                                    udp6       0      0 :::5353                 :::*                                108        13922      394/avahi-daemon: r
                                    2024-01-05 01:00:45.882  - warn: zigbee.0 (29251) Device '0x00158d00069b00d3' announced itself
                                    2024-01-05 01:20:14.792  - info: host.raspberrypi Delete log file iobroker.2023-12-28.log.gz
                                    2024-01-05 07:17:30.301  - error: zigbee.0 (29251) No converter available for 'AC03641' with key 'available'
                                      Nebenbei gesehen:
                                      Der CIFS der Fritzboxen spricht vers=3.1.1 und muss mit der Option 'noserverino' gemountet werden.
                                      Setz den User in die Gruppe 'adm' rein.
                                      Installier die beiden Adapter auf dem Master nochmal, zur Not 'über die Katze':
                                      Trag beim zigbee-Adapter statt
                                      port: /dev/ttyUSB0
                                      besser
                                      ein. (Wenn das denn der zigbee-USB-Stick ist.
                                        npm ERR! invalid: iobroker.openligadb@1.3.4 /opt/iobroker/node_modules/iobroker.openligadb npm ERR! invalid: iobroker.tibberconnect@0.0.10 /opt/iobroker/node_modules/iobroker.tibberconnect
                                        Das ist ja das Problem, ich kann keine Adapter installieren und auch keine Adapter updaten und keine Adapter löschen. 😞
                                        Die anderen beiden Sachen schaue ich mir sofort an. Vielen Dank für Deine Mühe!!!
                                          Per git url muss das gehen.
                                            @thomas-braun Leider nicht!
                                            81.1k
                                            nodejs
                                            91
                                            844
                                            228644
