    4. Sonoff Presence Sensor SNZB-06P problem
      arteck Developer Most Active @FredF last edited by
      @fredf so jetzt nochmal von GIT... und neustart nicht vergessen 🙂
      • FredF
        FredF Most Active Forum Testing @arteck last edited by
        @arteck
        zigbee.0
        2024-01-03 13:05:32.503	error	Error while processing converters DEVICE_ID: '3410f4fffee39865' cluster '64529' type 'readResponse'
        zigbee.0
        2024-01-03 13:05:32.290	info	Configuring 0x3410f4fffee39865 SNZB-06P
        zigbee.0
        2024-01-03 13:05:29.543	error	Error while processing converters DEVICE_ID: '3410f4fffee39865' cluster '64529' type 'readResponse'
        zigbee.0
        2024-01-03 13:05:29.301	info	Configuring 0x3410f4fffee39865 SNZB-06P
        zigbee.0
        2024-01-03 13:05:26.527	error	Error while processing converters DEVICE_ID: '3410f4fffee39865' cluster '64529' type 'readResponse'
        zigbee.0
        2024-01-03 13:05:26.322	info	Configuring 0x3410f4fffee39865 SNZB-06P
        zigbee.0
        2024-01-03 13:05:23.479	error	Error while processing converters DEVICE_ID: '3410f4fffee39865' cluster '64529' type 'readResponse'
        zigbee.0
        2024-01-03 13:05:23.334	info	Configuring 0x3410f4fffee39865 SNZB-06P
        zigbee.0
        2024-01-03 13:05:20.531	error	Error while processing converters DEVICE_ID: '3410f4fffee39865' cluster '64529' type 'readResponse'
        zigbee.0
        2024-01-03 13:05:20.351	info	Configuring 0x3410f4fffee39865 SNZB-06P
        zigbee.0
        2024-01-03 13:03:37.149	warn	DeviceAvailability:Failed to ping 0x385cfbfffe8ce7c8 TRADFRIbulbGU10WS345lm
        zigbee.0
        2024-01-03 13:03:37.065	warn	DeviceAvailability:Failed to ping 0x04cd15fffe0ae3fc TS0505B
        zigbee.0
        2024-01-03 13:03:15.048	error	Error while processing converters DEVICE_ID: '3410f4fffee39865' cluster '64529' type 'readResponse'
        zigbee.0
        2024-01-03 13:03:14.894	info	Configuring 0x3410f4fffee39865 SNZB-06P
        zigbee.0
        2024-01-03 13:03:13.379	error	Error while processing converters DEVICE_ID: '3410f4fffee39865' cluster '64529' type 'readResponse'
        zigbee.0
        2024-01-03 13:03:12.900	info	debug devices set to []
          @fredf
          ich werd bescheuert mit dem Gerät....
          so installier nochmal von GIT.. sollte es immer onch kommen.. dann muss ich Morgen weiter schauen..
          FredF T 3 Replies Last reply Reply Quote 0
          • FredF
            @arteck Bis auf das, gibt es keine Fehlermeldung
            2024-01-03 13:21:18.883	info	Configuring 0x3410f4fffee39865 SNZB-06P
            2024-01-03 13:18:29.357	info	Configuring 0x3410f4fffee39865 SNZB-06P
            2024-01-03 13:15:45.585	info	Configuring 0x3410f4fffee39865 SNZB-06P
            2024-01-03 13:15:42.615	info	Configuring 0x3410f4fffee39865 SNZB-06P
            2024-01-03 13:15:39.680	info	Configuring 0x3410f4fffee39865 SNZB-06P
            2024-01-03 13:15:36.650	info	Configuring 0x3410f4fffee39865 SNZB-06P
            2024-01-03 13:15:33.660	info	Configuring 0x3410f4fffee39865 SNZB-06P
            2024-01-03 13:13:13.261	info	Configuring 0x3410f4fffee39865 SNZB-06P
            2024-01-03 13:13:11.233	info	debug devices set to []
              tobrog @arteck last edited by
              @arteck Sieht bei mir ähnlich aus. Nach der anfänglichen Fehlermeldung kommt auch nur alle paar Minuten diese info Meldung.
              zigbee.0
              2024-01-03 15:31:30.015	info	Configuring 0x3410f4fffee99489 SNZB-06P
              zigbee.0
              2024-01-03 15:28:52.569	info	Configuring 0x3410f4fffee99489 SNZB-06P
              zigbee.0
              2024-01-03 15:21:22.341	info	Configuring 0x3410f4fffee99489 SNZB-06P
              zigbee.0
              2024-01-03 15:21:19.341	info	Configuring 0x3410f4fffee99489 SNZB-06P
              zigbee.0
              2024-01-03 15:21:16.321	info	Configuring 0x3410f4fffee99489 SNZB-06P
              zigbee.0
              2024-01-03 15:21:13.306	info	Configuring 0x3410f4fffee99489 SNZB-06P
              zigbee.0
              2024-01-03 15:21:10.297	info	Configuring 0x3410f4fffee99489 SNZB-06P
              zigbee.0
              2024-01-03 15:14:13.742	error	DeviceConfigure:Failed to DeviceConfigure.configure 0x3410f4fffee99489 SNZB-06P (Error: Read 0x3410f4fffee99489/1 64529([8193], {"sendWhen":"immediate","timeout":10000,"disableResponse":false,"disableRecovery":false,"disableDefaultResponse":true,"direction":0,"srcEndpoint":null,"reservedBits":0,"manufacturerCode":null,"transactionSequenceNumber":null,"writeUndiv":false}) failed (no response received (18)) at DeconzAdapter.sendZclFrameToEndpoint (/opt/iobroker/node_modules/zigbee-herdsman/src/adapter/deconz/adapter/deconzAdapter.ts:666:23) at Request.send (/opt/iobroker/node_modules/zigbee-herdsman/src/controller/helpers/request.ts:81:20) at Endpoint.read (/opt/iobroker/node_modules/zigbee-herdsman/src/controller/model/endpoint.ts:460:28) at setupAttributes (/opt/iobroker/node_modules/zigbee-herdsman-converters/src/lib/modernExtend.ts:62:9) at configure (/opt/iobroker/node_modules/zigbee-herdsman-converters/src/lib/modernExtend.ts:72:9) at Object.configure (/opt/iobroker/node_modules/zigbee-herdsman-converters/src/index.ts:139:25) at DeviceConfigure.doConfigure (/opt/iobroker/node_modules/iobroker.zigbee/lib/zbDeviceConfigure.js:136:17) at DeviceConfigure.configure (/opt/iobroker/node_modules/iobroker.zigbee/lib/zbDeviceConfigure.js:114:21))
              zigbee.0
              2024-01-03 15:14:02.862	info	Configuring 0x3410f4fffee99489 SNZB-06P
              zigbee.0
              2024-01-03 15:14:00.650	info	debug devices set to []
              zigbee.0
              2024-01-03 15:14:00.169	info	Zigbee started
              • FredF
                @arteck
                Bonus: Der Sensor funktionierte nicht mehr... musste ihn neu anlernen
                  so weiter gehts. 🙂
                  von GIT bitte
                  • FredF
                    FredF Most Active Forum Testing @arteck last edited by FredF
                    @arteck
                    2024-01-04 09:50:52.709	info	Configuring 0x3410f4fffee39865 SNZB-06P
                    2024-01-04 09:50:49.761	info	Configuring 0x3410f4fffee39865 SNZB-06P
                    2024-01-04 09:50:46.738	info	Configuring 0x3410f4fffee39865 SNZB-06P
                    2024-01-04 09:50:43.764	info	Configuring 0x3410f4fffee39865 SNZB-06P
                    2024-01-04 09:50:40.772	info	Configuring 0x3410f4fffee39865 SNZB-06P
                    Edit: kommt alle 10 Minuten
                    arteck 2 Replies Last reply Reply Quote 0
                      arteck Developer Most Active @FredF last edited by arteck
                      kein Plan.. . da ich das Gerät nicht habe, ich weiss nicht was bei dem falsch läuft..
                      hat das Teil vielleicht jemand doppelt gekauft und kann mir ein Verkaufen ?
                        @fredf installier nochmal von GIT... bitte
                        die Meldung sollte jetzt nur einmal kommen
                        FredF 1 Reply Last reply Reply Quote 1
                        • FredF
                          @arteck sagte in Sonoff Presence Sensor SNZB-06P problem:
                          Jep, die kam tatsächlich nun nur einmal beim neustart
                          2024-01-04 17:54:38.407	info	-> Configuring 0x3410f4fffee39865 SNZB-06P
                          und seitdem nicht mehr 👍
                            @fredf dann schau ob der sensor daten liefert
                            • FredF
                              @arteck Tut er
                              Besten dank für deine unermüdlich Arbeit, Top.
                                dann mach ich ne neue version
                                  @arteck Bei mir läuft die letzte GIT version auch problemlos ohne weitere Meldungen im log.
                                  Vielen Dank!
                                    Förster last edited by
                                    Bei mir funktioniert es jetzt auch. Vielen Dank für deinen Einsatz!
                                    Jan Lange 1 Reply Last reply Reply Quote 0
                                    • Jan Lange
                                      Jan Lange @Förster last edited by
                                      @arteck
                                      Ich versuche mich gerade auch an dem Sonoff. Leider ist bei mir auch der Wert für occupancy null. Das GIT Update einschließlich der Korrekturen sollte doch in der gepublished Version mittlerweile vorhanden sein oder?
                                        arteck Developer Most Active @Jan Lange last edited by
                                        @jan-lange https://forum.iobroker.net/topic/70141/sonoff-presence-sensor-snzb-06p-problem/11?_=1717223824585
                                        gelesen Probiert ??? kein Plan was mit dem Device nicht stimmt.. habs nicht hier...
                                        • U
                                          UncleB last edited by
                                          Funktioniert das Gerät nun bei euch ordentlich?
                                          Der Wert für occupancy steht auf Null..
                                          Alle Vorschläge hier habe ich durch
                                            tobrog @UncleB last edited by
                                            @uncleb Ich hab zwei davon im Einsatz und die funktionieren problemlos.
                                            80
                                            11805
