    4. [Neuer Adapter] Life360
      Sandy last edited by
      Scheint wieder zu funktionieren. Habe keine Fehlermeldungen mehr. Habe nichts geändert.
      S Riffcommander 2 Replies Last reply Reply Quote 0
        stefu87_CH @Sandy last edited by
        @sandy Bei mir läuft er nicht
        2024-01-04 14:54:26.175 - error: life360.0 (2707463) Connection established but failed to authenticate. Check your credentials!
        2024-01-04 14:54:26.177 - info: life360.0 (2707463) Waiting for online operations to finish ...
        2024-01-04 14:54:26.262 - error: life360.0 (2707463) Connection established but failed to authenticate. Check your credentials!
        2024-01-04 14:54:26.263 - info: life360.0 (2707463) Waiting for online operations to finish ...
        2024-01-04 14:54:26.340 - error: life360.0 (2707463) Connection established but failed to authenticate. Check your credentials!
        2024-01-04 14:54:26.341 - info: life360.0 (2707463) Waiting for online operations to finish ...
        2024-01-04 14:54:26.420 - error: life360.0 (2707463) Connection established but failed to authenticate. Check your credentials!
        2024-01-04 14:54:26.421 - info: life360.0 (2707463) Waiting for online operations to finish ...
        2024-01-04 14:54:26.501 - error: life360.0 (2707463) Connection established but failed to authenticate. Check your credentials!
        2024-01-04 14:54:26.502 - info: life360.0 (2707463) Waiting for online operations to finish ...
        2024-01-04 14:54:26.588 - error: life360.0 (2707463) Connection established but failed to authenticate. Check your credentials!
        2024-01-04 14:54:26.589 - info: life360.0 (2707463) Waiting for online operations to finish ...
        2024-01-04 14:54:26.589 - error: life360.0 (2707463) Failed to connect or to login for 6 times. Aborting ...
        2024-01-04 14:54:26.589 - error: life360.0 (2707463) Error: Error: Connection established but failed to authenticate. Check your credentials!
        • Riffcommander
          Riffcommander @Sandy last edited by
          @sandy Bei mir läuft er auch nicht.
            bei mir ist er grün
            aber im Protokoll habe ich diese Warnungen
            PS: jetzt habe ich auch wieder errors. Die ganze Zeit nicht ... komisch
              K_o_bold last edited by
              Wie könnte es hier nun weitergehen?
              Ist Life360 damit am Ende und man muss sich nach einer Alternative umschauen, oder gibt es noch Hoffnung dass es mal wieder dauerhaft läuft…
              MiGoller 1 Reply Last reply Reply Quote 0
              • MiGoller
                MiGoller Developer @K_o_bold last edited by
                Ab und an schaffe ich es wieder, mich anzumelden mit meinem Test-Tool, aber die nächste Abfrage der Life360 Kreise beendet das ganze dann sofort wieder.
                Bislang habe ich keinen Ansatzpunkt, wie ich das lösen könnte. Parallel beobachte ich auch die Home-Assistent Community... auch da wird eher über das "Aus" der Integration gesprochen, als das es Hoffnung auf baldige Lösung geben würde.
                Um es ganz deutlich zu sagen: Aktuell habe ich keinen Ansatz, dass ich den Adapter wieder ans Rennen bekomme. So leid es mir tut.
                Knallochse 1 Reply Last reply Reply Quote 1
                • Knallochse
                  Knallochse @MiGoller last edited by Knallochse
                  @migoller Der Github HA Beitrag Link Text von „pantherale0“ hatte mir bisschen Hoffnung verschafft. Ist das kein Lösungsansatz für uns?
                  • MiGoller
                    MiGoller Developer @Knallochse last edited by
                    @knallochse welchen dieser Posts meinst Du: https://github.com/home-assistant/core/issues/106967#issuecomment-1875699137 oder den hier https://github.com/home-assistant/core/issues/106967#issuecomment-1876123190?
                    Ich tippe auf den zweiten Post. Der Ansatz besteht darin, einen eigenen Request-Handler auf niedriger Ebene (für Python) nachzubauen, der sich für eine Web-Application-Firewall (hier Cloudflare) wie die Java-Bibliothek https://square.github.io/okhttp/ unter Android verhält. Ist eine interessante Theorie, die aber auch noch nicht bestätigt ist.
                    Wir wissen, dass Android und iOS Geräte funktionieren; ob das allerdings wegen des "Fingerprints" der o.a. Bibliothek ist, oder ob der Cloudflare-Schutz auf einem "Verhalten" der App beruht, ist nicht bekannt. Der Autor der HA-Integration hat auch schon festgehalten, dass er die massiven Änderungen auch nicht mehr kompensieren kann (vgl. https://github.com/home-assistant/core/issues/106967#issuecomment-1875690924).
                    Ich behalte das weiter im Blick und schaue, ob sich an einer Stelle eine Lösung abzeichnen könnte. Versprechen kann ich nichts. Meiner Wahrnehmung nach stehen auch andere Entwickler, die unabhängig Integrationen entwickelt haben, vor demselben Problem. Auch die voneinander unabhängigen Problemanalysen haben noch keinen Durchbruch gebracht.
                    smarthomefamilyverrips created this issue in home-assistant/core
                    closed Life360 fails authentification again #106967
                    Knallochse 1 Reply Last reply Reply Quote 3
                    • maloross
                      maloross last edited by
                      @migoller sagte in [Neuer Adapter] Life360:
                      Du hast ja bisher saubere Arbeit geleistet, der Adapter hat ja auch eine lange Zeit sehr gut funktioniert - dafür noch mal ein fettes Danke.
                      Ich gehe auch davon aus, dass alle evtl. vorhandenen "Löcher" noch gestopft werden und die Beschränkungen weiter intensiviert/verschärft werden.
                      Für Anwesenheitserkennung gibt es Alternativen, alles andere ist für mich eher ein "nice to have".
                      • Knallochse
                        @migoller Danke für deine ausführliche Erklärung.
                        Ich möchte mich ebenfalls für deine bisherige Arbeit bedanken.
                        Du hast immer schnell auf die Änderung von Life360 reagiert.
                        Natürlich wäre es wünschenswert, dass der Adapter wieder funktioniert.
                        Für mich hat er alle Daten für eine Zuverlässige Anwesenheitserkennung geliefert (und eine Menge mehr).
                        Vielen Dank 🙏
                          Pischleuder last edited by Pischleuder
                          Hallo Zusammen,
                          den Einsatz von @migoller finde ich auch großartig - Danke dafür.
                          Die E-Mail von life360 habe ich auch bekommen und da mir das Ganze langsam etwas suspekt erscheint, bin ich nun auf owntrack gewechselt, das funktioniert wunderbar.
                            juggi1962 @Pischleuder last edited by
                            @pischleuder sagte in [Neuer Adapter] Life360:
                            Hallo Zusammen,
                            Kannst du mir, uns sagen wie man das einrichtet. Eine kleine Anleitung wäre super für Handy und iobroker. Adapter und APP sind installiert. Danke im Voraus, Gruß Jürgen
                            BananaJoe P 2 Replies Last reply Reply Quote 0
                            • BananaJoe
                              BananaJoe Most Active @juggi1962 last edited by
                              @juggi1962 sagte in [Neuer Adapter] Life360:
                              Das gehört hier nicht her, ggf. ein eigenes Thema dafür aufmachen, aber:
                              • Anleitung des Adapters: https://github.com/iobroker-community-adapters/ioBroker.owntracks
                              • In den Adaptereinstellungen wird ebenfalls auf diese Anleitung verwiesen
                              • Oder das Thema zum Adapter hier im Forum: https://forum.iobroker.net/topic/26501/test-adapter-owntracks-v1-0-x-github?_=1704539129860
                              MiGoller 1 Reply Last reply Reply Quote 1
                              • MiGoller
                                MiGoller Developer @BananaJoe last edited by
                                Die Home-Assistant-Community scheint mehr "Glück" gehabt zu haben und hat eine Antwort auf eine Anfrage zur Nutzung der Life360 API erhalten. Ihr könnt die Einlassung von Life360 zu Home-Automation-Integrationen direkt unter https://github.com/home-assistant/core/issues/106967#issuecomment-1879504648 und https://github.com/home-assistant/core/issues/106967#issuecomment-1879669135 nachlesen:
                                Thank you for contacting Life360 about your feedback and request to reconsider the Home Assistant functionality of the app. I will coordinate this with the appropriate team.
                                We understand the importance of using the Home Assistant program with Life360. However, please be aware that we no longer support home automation programs such as Home Assistant, Google Home, Alexa, IFTTT, and others, and Life360 is no longer compatible with these programs. Currently, we do not have any plans to reintroduce compatibility with these programs yet, we are constantly working to build products our members will love.
                                We appreciate your feedback and thank you so much for bringing this to our attention. I've recorded your feedback so that it can be reviewed and included in the planning of our development team for features to build next.
                                Ich danke Euch für Euer Feedback und Eure Unterstützung in den letzten Jahren. Es tut mir sehr leid, dass ich derzeit keine Lösung mehr liefern kann. Life360 werde ich im Auge behalten, ob sich da vielleicht doch noch etwas tut. Nur wenn Life360 weiterhin auf dem Kurs der Isolation bleibt, dann wird Life360 auch weiterhin alles tun, damit Integrationen praktisch nicht funktionieren werden.
                                maloross 1 Reply Last reply Reply Quote 0
                                  Pischleuder @juggi1962 last edited by
                                  @juggi1962
                                  es ist genau so, wie @BananaJoe es gesagt hat. Auf die github Seite des Adapters gehen und die Schritte befolgen. Die Einrichtung ist einfach, bei Fragen einfach neues Thema eröffen.
                                  • maloross
                                    maloross @MiGoller last edited by
                                    Wenn Platzhirsche wie Amazon, Google & Co ausgeschlossen werden, sehe ich keine Chance, dass eine Öffnung für kleinere Anwendungen überhaupt in Betracht gezogen wird.
                                    Hab schon überlegt, meinen Mann mit einem Tractive Tracker auszustatten 😉
                                      K_o_bold @maloross last edited by K_o_bold
                                      Auch von mir vielen Dank für die tolle Arbeit von @MiGoller der letzten Jahre...
                                      Du warst immer sehr zuverlässig und sehr Reaktionsschnell... großen DANK!
                                      Ich für meinen Teil, habe mittlerweile eine sehr gute Alternative für IPhone Nutzer entdeckt.
                                      Ganz ohne Drittanbieter, nur mit IOS eigenen Bordmitteln und IoT Adapter des iobroker.
                                      Dazu einfach in der App Kurzbefehle eine Automation anlegen und auf den Ort triggern.
                                      Als Aktion kann ein https Befehl an den Service des IoT Adapters abgesetzt werden.
                                      Damit hat man einen Datenpunkt im iobroker und kann darauf seine Skripte ansetzen.
                                      Bei Interesse erstelle ich ein neues Thema mit der Anleitung dazu...
                                      MiGoller E 2 Replies Last reply Reply Quote 2
                                      • MiGoller
                                        @k_o_bold Hmm, könnte ich mir gleich auch einmal ansehen. Du rufst einfach einen Web-Hook, also einen https-Endpunkt des IoT Adapters auf?
                                          K_o_bold @MiGoller last edited by K_o_bold
                                          @migoller ,
                                          jup....
                                          Die Automation lautet bei mir so....
                                          Wenn ich einen bestimmten Ort erreiche (Radius kann eingestellt werden), dann rufe Inhalt von URL ab... Die URL habe ich aus dem IoT Adapter und endsprechend abgeändert, nach meinen Bedürfnissen ( gelbe Markierung ändern )
                                            eve11 last edited by
                                            Ich bin jetzt erst mal auf Traccar umgestiegen. Der eigene Server war in einem LXC Container auf Proxmox in 10 Minuten installiert. Soweit funktioniert alles tadellos. Nur der Traccar Adapter wäre noch ausbaufähig. Ein ähnlicher Funktionsumfang dito Life360 wäre wünschenswert.
                                            Heiko
                                            adapter geoposition life360 präsenzmelder
                                            85
                                            708
                                            165152
