    4. Diskussion zum HowTo nodejs-Installation und upgrade
      djsirius @Thomas Braun last edited by
      @thomas-braun ok. Das längste war 2 Stunden. Aber ich lasse es mal bis morgen laufen.
        djsirius @djsirius last edited by djsirius
        @djsirius said in Diskussion zum HowTo nodejs-Installation und upgrade:
        @thomas-braun said in Diskussion zum HowTo nodejs-Installation und upgrade:
        iob update && iob upgrade all -y --debug
        das habe ich auch schon versucht.
        iobroker@debian:~$ iob update && iob upgrade all -y --debug
        Used repository: stable
        Adapter    "admin"        : 6.12.0   , installed 6.12.0
        Adapter    "alexa2"       : 3.26.3   , installed 3.26.2 [Updatable]
        Adapter    "backitup"     : 2.9.8    , installed 2.8.7  [Updatable]
        Adapter    "daswetter"    : 3.1.11   , installed 3.1.11
        Adapter    "feiertage"    : 1.1.4    , installed 1.1.4
        Adapter    "hm-rega"      : 4.0.0    , installed 4.0.0
        Adapter    "hm-rpc"       : 1.15.19  , installed 1.15.19
        Adapter    "iot"          : 2.0.11   , installed 2.0.11
        Adapter    "javascript"   : 7.1.6    , installed 7.1.6
        Controller "js-controller": 5.0.17   , installed 4.0.24 [Updatable]
        Adapter    "lg-thinq"     : 0.1.4    , installed 0.1.4
        Adapter    "linux-control": 1.1.5    , installed 1.1.5
        Adapter    "logparser"    : 2.2.0    , installed 2.2.0
        Adapter    "meross"       : 1.16.1   , installed 1.16.1
        Adapter    "mihome-vacuum": 4.1.0    , installed 4.1.0
        Adapter    "mobile"       : 1.0.1    , installed 1.0.1
        Adapter    "modbus"       : 6.0.1    , installed 6.0.1
        Adapter    "openligadb"   : 1.2.4    , installed 1.3.4
        Adapter    "pollenflug"   : 1.0.6    , installed 1.0.6
        Adapter    "shelly"       : 6.6.1    , installed 6.6.1
        Adapter    "sql"          : 2.2.0    , installed 2.2.0
        Adapter    "systeminfo"   : 1.1.0    , installed 1.1.0
        Adapter    "telegram"     : 3.0.1    , installed 3.0.1
        Adapter    "terminal"     : 1.0.0    , installed 1.0.0
        Adapter    "text2command" : 3.0.2    , installed 3.0.2
        Adapter    "tibberlink"   : 2.0.0    , installed 2.0.0
        Adapter    "trashschedule": 2.3.0    , installed 2.3.0
        Adapter    "upnp"         : 1.0.21   , installed 1.0.21
        Adapter    "viessmannapi" : 2.3.0    , installed 2.3.0
        Adapter    "vis-justgage" : 2.1.0    , installed 2.1.0
        Adapter    "vis-weather"  : 2.5.6    , installed 2.5.6
        Adapter    "web"          : 6.1.10   , installed 6.1.10
        Adapter    "ws"           : 2.5.8    , installed 2.5.8
        Update backitup from @2.8.7 to @2.9.8
        host.debian Adapter "system.adapter.backitup.0" is stopped.
        NPM version: 10.2.3
        Installing iobroker.backitup@2.9.8... (System call)
        Danach tut sich nichts mehr!
        Leider hat sich über Nacht nichts mehr getan! Was kann ich jetzt noch machen? Vielleicht Nodejs und NPM neu installieren?
        Weil das Update war ja der Punkt, nachdem kein Update/Installation der Adapter mehr funktioniert hat.
        Vielen Dank!
          Thomas Braun Most Active @djsirius last edited by
          @djsirius sagte in Diskussion zum HowTo nodejs-Installation und upgrade:
          Eigentlich sollte das schon passen.
            @thomas-braun Okay, aber was kann ich jetzt noch machen? Ich kenne mich leider zu wenig damit aus. 😞
            Was für mich komisch ist, dass auf Master und Slave das gleich Problem nach dem Update von Nodejs und NPM besteht.
              @djsirius
              Gib mal von beiden Kisten ein vollständiges
              iob diag
              bekannt.
                iob diag
                Master:
                Skript v.2023-10-10
                *** BASE SYSTEM ***
                   Static hostname: debian
                         Icon name: computer-desktop
                           Chassis: desktop
                  Operating System: Debian GNU/Linux 11 (bullseye)
                            Kernel: Linux 5.10.0-26-amd64
                      Architecture: x86-64
                model name      : Intel(R) Core(TM) i5-2400 CPU @ 3.10GHz
                Docker          : false
                Virtualization  : none
                Kernel          : x86_64
                Userland        : amd64
                Systemuptime and Load:
                 10:44:00 up 1 day, 15:16,  1 user,  load average: 0.79, 0.49, 0.31
                CPU threads: 4
                *** Time and Time Zones ***
                               Local time: Fri 2024-01-05 10:44:00 CET
                           Universal time: Fri 2024-01-05 09:44:00 UTC
                                 RTC time: Fri 2024-01-05 09:44:01
                              NTP service: active
                          RTC in local TZ: no
                *** User and Groups ***
                iobroker
                /home/iobroker
                iobroker tty dialout cdrom floppy sudo audio dip video plugdev netdev bluetooth lpadmin scanner
                *** X-Server-Setup ***
                X-Server:       false
                Desktop:
                Terminal:       tty
                *** MEMORY ***
                Mem:            7.9G        4.4G        2.7G        5.0M        837M        3.2G
                Swap:           4.0G          0B        4.0G
                Total:           11G        4.4G        6.7G
                         7864 M total memory
                         4364 M used memory
                          341 M active memory
                         4539 M inactive memory
                         2662 M free memory
                          161 M buffer memory
                          676 M swap cache
                         4015 M total swap
                            0 M used swap
                         4015 M free swap
                *** FAILED SERVICES ***
                0 loaded units listed.
                *** FILESYSTEM ***
                Filesystem                         Type      Size  Used Avail Use% Mounted on
                udev                               devtmpfs  3.9G     0  3.9G   0% /dev
                tmpfs                              tmpfs     787M  2.5M  785M   1% /run
                /dev/sda2                          ext4      454G   44G  387G  11% /
                tmpfs                              tmpfs     3.9G     0  3.9G   0% /dev/shm
                tmpfs                              tmpfs     5.0M  4.0K  5.0M   1% /run/lock
                /dev/sda1                          vfat      511M  5.8M  506M   2% /boot/efi
                //192.168.1.1/GLADYS7490/TREKSTOR/ cifs      467G  353G  114G  76% /media/fritzbox
                tmpfs                              tmpfs     787M   40K  787M   1% /run/user/1000
                [Wed Jan  3 19:27:32 2024] EXT4-fs (sda2): mounted filesystem with ordered data mode. Opts: (null)
                [Wed Jan  3 19:27:39 2024] EXT4-fs (sda2): re-mounted. Opts: errors=remount-ro
                TARGET            SOURCE                             FSTYPE OPTIONS
                /                 /dev/sda2                          ext4   rw,relatime,errors=remount-ro
                |-/media/fritzbox //192.168.1.1/GLADYS7490/TREKSTOR/ cifs   rw,relatime,vers=1.0,cache=strict,username=mount,uid=1000,forceuid,gid=1000,forcegid,addr=192.168.1.1,file_mode=0755,dir_mode=0755,soft,nounix,serverino,mapposix,rsize=61440,wsize=65536,bsize=1048576,echo_interval=60,actimeo=1
                `-/boot/efi       /dev/sda1                          vfat   rw,relatime,fmask=0077,dmask=0077,codepage=437,iocharset=ascii,shortname=mixed,utf8,errors=remount-ro
                /var:
                7.3G    /var/
                4.1G    /var/log
                4.0G    /var/log/journal/f063d3dd2a6e40efad76adb6a70d9daf
                2.4G    /var/cache/apt
                Archived and active journals take up 3.6G in the file system.
                /opt/iobroker/backups:
                115M    /opt/iobroker/backups/
                /opt/iobroker/iobroker-data:
                1.1G    /opt/iobroker/iobroker-data/
                600M    /opt/iobroker/iobroker-data/files
                356M    /opt/iobroker/iobroker-data/backup-objects
                73M     /opt/iobroker/iobroker-data/files/telegram.admin
                67M     /opt/iobroker/iobroker-data/files/javascript.admin
                81M     /opt/iobroker/iobroker-data/states.jsonl
                35M     /opt/iobroker/iobroker-data/files/devices.admin/static/js/main.24f2bb56.js.map
                33M     /opt/iobroker/iobroker-data/files/iot.admin/static/js/main.1797d034.js.map
                28M     /opt/iobroker/iobroker-data/objects.jsonl
                22M     /opt/iobroker/iobroker-data/files/modbus.admin/static/js/main.b5f6766c.js.map
                USB-Devices by-id:
                *** NodeJS-Installation ***
                /usr/bin/nodejs         v18.19.0
                /usr/bin/node           v18.19.0
                /usr/bin/npm            10.2.3
                /usr/bin/npx            10.2.3
                /usr/bin/corepack       0.22.0
                nodejs:
                  Installed: 18.19.0-1nodesource1
                  Candidate: 18.19.0-1nodesource1
                  Version table:
                 *** 18.19.0-1nodesource1 500
                        500 https://deb.nodesource.com/node_18.x nodistro/main amd64 Packages
                        100 /var/lib/dpkg/status
                     18.18.2-1nodesource1 500
                     18.18.1-1nodesource1 500
                     18.18.0-1nodesource1 500
                     18.17.1-1nodesource1 500
                     18.17.0-1nodesource1 500
                     18.16.1-1nodesource1 500
                     18.16.0-1nodesource1 500
                     18.15.0-1nodesource1 500
                     18.14.2-1nodesource1 500
                     18.14.1-1nodesource1 500
                     18.14.0-1nodesource1 500
                     18.13.0-1nodesource1 500
                     18.12.0-1nodesource1 500
                     18.11.0-1nodesource1 500
                     18.10.0-1nodesource1 500
                     18.9.1-1nodesource1 500
                     18.9.0-1nodesource1 500
                     18.8.0-1nodesource1 500
                     18.7.0-1nodesource1 500
                     18.6.0-1nodesource1 500
                     18.5.0-1nodesource1 500
                     18.4.0-1nodesource1 500
                     18.3.0-1nodesource1 500
                     18.2.0-1nodesource1 500
                     18.1.0-1nodesource1 500
                     18.0.0-1nodesource1 500
                     12.22.12~dfsg-1~deb11u4 500
                        500 http://ftp.de.debian.org/debian bullseye/main amd64 Packages
                        500 http://deb.debian.org/debian bullseye/main amd64 Packages
                No problems detected
                Errors in npm tree:
                npm ERR! code ELSPROBLEMS
                npm ERR! extraneous: @types/caseless@0.12.5 /opt/iobroker/node_modules/@types/caseless
                npm ERR! extraneous: @types/request@2.48.12 /opt/iobroker/node_modules/@types/request
                npm ERR! extraneous: @types/tough-cookie@4.0.5 /opt/iobroker/node_modules/@types/tough-cookie
                npm ERR! extraneous: coffeescript@2.7.0 /opt/iobroker/node_modules/coffeescript
                npm ERR! invalid: iobroker.openligadb@1.3.4 /opt/iobroker/node_modules/iobroker.openligadb
                npm ERR! invalid: iobroker.tibberconnect@0.0.10 /opt/iobroker/node_modules/iobroker.tibberconnect
                npm ERR! extraneous: jsonata@2.0.3 /opt/iobroker/node_modules/jsonata
                npm ERR! extraneous: node-inspect@2.0.0 /opt/iobroker/node_modules/node-inspect
                npm ERR! extraneous: picocolors@1.0.0 /opt/iobroker/node_modules/picocolors
                npm ERR! extraneous: suncalc2@1.8.1 /opt/iobroker/node_modules/suncalc2
                npm ERR! extraneous: typescript@5.2.2 /opt/iobroker/node_modules/typescript
                npm ERR! extraneous: virtual-tsc@0.6.2 /opt/iobroker/node_modules/virtual-tsc
                npm ERR! extraneous: wake_on_lan@1.0.0 /opt/iobroker/node_modules/wake_on_lan
                npm ERR! extraneous: form-data@2.5.1 /opt/iobroker/node_modules/@types/request/node_modules/form-data
                npm ERR! extraneous: debug@4.3.4 /opt/iobroker/node_modules/virtual-tsc/node_modules/debug
                npm ERR! extraneous: ms@2.1.2 /opt/iobroker/node_modules/virtual-tsc/node_modules/ms
                npm ERR! invalid: xmlbuilder@0.4.2 /opt/iobroker/node_modules/xmlbuilder
                npm ERR! invalid: buffer@5.7.1 /opt/iobroker/node_modules/buffer
                npm ERR! A complete log of this run can be found in: /home/iobroker/.npm/_logs/2024-01-05T09_44_23_394Z-debug-0.log
                *** ioBroker-Installation ***
                ioBroker Status
                Objects type: jsonl
                States  type: jsonl
                Core adapters versions
                js-controller:  4.0.24
                admin:          6.12.0
                javascript:     7.1.6
                npm ERR! A complete log of this run can be found in: /home/iobroker/.npm/_logs/2024-01-05T09_44_34_780Z-debug-0.log
                Adapters from github:   2
                Adapter State
                + system.adapter.admin.0                  : admin                 : debian                                   -  enabled, port: 8081, bind: 0.0.0.0 (SSL), run as: admin
                + system.adapter.alexa2.0                 : alexa2                : debian                                   -  enabled
                + system.adapter.backitup.0               : backitup              : debian                                   -  enabled
                  system.adapter.daswetter.0              : daswetter             : debian                                   -  enabled
                  system.adapter.devices.0                : devices               : debian                                   -  enabled
                + system.adapter.discovery.0              : discovery             : debian                                   -  enabled
                  system.adapter.dwd.0                    : dwd                   : debian                                   -  enabled
                + system.adapter.enigma2.0                : enigma2               : raspberrypi                              -  enabled
                  system.adapter.feiertage.0              : feiertage             : debian                                   -  enabled
                  system.adapter.flot.0                   : flot                  : debian                                   -  enabled
                + system.adapter.history.0                : history               : debian                                   -  enabled
                + system.adapter.hm-rega.0                : hm-rega               : debian                                   -  enabled
                + system.adapter.hm-rpc.0                 : hm-rpc                : debian                                   -  enabled, port: 0
                + system.adapter.hm-rpc.1                 : hm-rpc                : debian                                   -  enabled, port: 0
                  system.adapter.ical.0                   : ical                  : debian                                   -  enabled
                  system.adapter.ical.1                   : ical                  : debian                                   -  enabled
                  system.adapter.ical.2                   : ical                  : debian                                   -  enabled
                  system.adapter.icons-mfd-png.0          : icons-mfd-png         : debian                                   -  enabled
                  system.adapter.icons-mfd-svg.0          : icons-mfd-svg         : debian                                   -  enabled
                + system.adapter.info.0                   : info                  : debian                                   -  enabled
                + system.adapter.iot.0                    : iot                   : debian                                   -  enabled
                + system.adapter.javascript.0             : javascript            : debian                                   -  enabled
                + system.adapter.lg-thinq.0               : lg-thinq              : debian                                   -  enabled
                + system.adapter.linux-control.0          : linux-control         : debian                                   -  enabled
                + system.adapter.logparser.0              : logparser             : debian                                   -  enabled
                + system.adapter.meross.0                 : meross                : debian                                   -  enabled
                + system.adapter.mihome-vacuum.0          : mihome-vacuum         : debian                                   -  enabled, port: 54321
                  system.adapter.mobile.0                 : mobile                : debian                                   -  enabled
                + system.adapter.modbus.0                 : modbus                : debian                                   -  enabled
                + system.adapter.openligadb.0             : openligadb            : debian                                   -  enabled
                + system.adapter.ping.0                   : ping                  : debian                                   -  enabled
                + system.adapter.pollenflug.0             : pollenflug            : debian                                   -  enabled
                + system.adapter.rpi2.1                   : rpi2                  : raspberrypi                              -  enabled
                + system.adapter.scenes.0                 : scenes                : debian                                   -  enabled
                + system.adapter.shelly.0                 : shelly                : debian                                   -  enabled, port: 1882, bind: 0.0.0.0
                + system.adapter.simple-api.0             : simple-api            : debian                                   -  enabled, port: 8087, bind: 0.0.0.0, run as: admin
                + system.adapter.socketio.0               : socketio              : debian                                   -  enabled, port: 8084, bind: 0.0.0.0 (SSL), run as: admin
                + system.adapter.sql.0                    : sql                   : debian                                   -  enabled, port: 3306
                + system.adapter.systeminfo.0             : systeminfo            : debian                                   -  enabled
                + system.adapter.tankerkoenig.0           : tankerkoenig          : debian                                   -  enabled
                + system.adapter.telegram.0               : telegram              : debian                                   -  enabled, port: 8443, bind: 0.0.0.0
                + system.adapter.terminal.0               : terminal              : debian                                   -  enabled, port: 8088, bind: 0.0.0.0, run as: admin
                + system.adapter.text2command.0           : text2command          : debian                                   -  enabled
                + system.adapter.tibberlink.0             : tibberlink            : debian                                   -  enabled
                + system.adapter.tr-064.0                 : tr-064                : debian                                   -  enabled
                + system.adapter.trashschedule.0          : trashschedule         : debian                                   -  enabled
                + system.adapter.upnp.0                   : upnp                  : debian                                   -  enabled
                + system.adapter.viessmannapi.0           : viessmannapi          : debian                                   -  enabled
                  system.adapter.vis-bars.0               : vis-bars              : debian                                   -  enabled
                  system.adapter.vis-canvas-gauges.0      : vis-canvas-gauges     : debian                                   -  enabled
                  system.adapter.vis-colorpicker.0        : vis-colorpicker       : debian                                   -  enabled
                  system.adapter.vis-fancyswitch.0        : vis-fancyswitch       : debian                                   -  enabled
                  system.adapter.vis-history.0            : vis-history           : debian                                   -  enabled
                  system.adapter.vis-hqwidgets.0          : vis-hqwidgets         : debian                                   -  enabled
                  system.adapter.vis-jqui-mfd.0           : vis-jqui-mfd          : debian                                   -  enabled
                  system.adapter.vis-justgage.0           : vis-justgage          : debian                                   -  enabled
                  system.adapter.vis-materialdesign.0     : vis-materialdesign    : debian                                   -  enabled
                  system.adapter.vis-metro.0              : vis-metro             : debian                                   -  enabled
                  system.adapter.vis-plumb.0              : vis-plumb             : debian                                   -  enabled
                  system.adapter.vis-timeandweather.0     : vis-timeandweather    : debian                                   -  enabled
                  system.adapter.vis-weather.0            : vis-weather           : debian                                   -  enabled
                  system.adapter.vis.0                    : vis                   : debian                                   -  enabled
                + system.adapter.web.0                    : web                   : debian                                   -  enabled, port: 8082, bind: 0.0.0.0, run as: admin
                + system.adapter.zigbee.0                 : zigbee                : raspberrypi                              -  enabled, port: /dev/ttyUSB0
                + instance is alive
                ioBroker-Repositories
                Active repo(s): stable
                Installed ioBroker-Instances
                Objects and States
                Objects:        27977
                States:         22607
                Hit:1 http://ftp.de.debian.org/debian bullseye InRelease
                Hit:2 http://ftp.de.debian.org/debian bullseye-updates InRelease
                Hit:3 http://deb.debian.org/debian bullseye InRelease
                Hit:4 http://deb.debian.org/debian bullseye-updates InRelease
                Hit:5 http://deb.debian.org/debian bullseye-backports InRelease
                Hit:6 https://deb.nodesource.com/node_18.x nodistro InRelease
                Hit:7 https://packages.sury.org/php bullseye InRelease
                Hit:8 https://packagecloud.io/ookla/speedtest-cli/debian bullseye InRelease
                Reading package lists...
                Pending Updates: 0
                *** Listening Ports ***
                tcp        0      0 192.168.1.16:8701       0.0.0.0:*               LISTEN      1000       4185347    2227684/io.hm-rpc.1
                tcp        0      0 0.0.0.0:445             0.0.0.0:*               LISTEN      0          16729      808/smbd
                tcp        0      0 0.0.0.0:9000            0.0.0.0:*               LISTEN      1000       4180940    2227358/iobroker.js
                tcp        0      0 0.0.0.0:9001            0.0.0.0:*               LISTEN      1000       4181668    2227358/iobroker.js
                tcp        0      0 0.0.0.0:139             0.0.0.0:*               LISTEN      0          16730      808/smbd
                tcp        0      0 0.0.0.0:111             0.0.0.0:*               LISTEN      0          618        1/init
                tcp        0      0 192.168.1.16:2001       0.0.0.0:*               LISTEN      1000       4181880    2227508/io.hm-rpc.0
                tcp        0      0 0.0.0.0:22              0.0.0.0:*               LISTEN      0          1719       509/sshd: /usr/sbin
                tcp        0      0 127.0.0.1:631           0.0.0.0:*               LISTEN      0          5973237    3206164/cupsd
                tcp        0      0 127.0.0.1:25            0.0.0.0:*               LISTEN      0          17439      800/exim4
                tcp        0      0 0.0.0.0:1882            0.0.0.0:*               LISTEN      1000       4185455    2227740/io.shelly.0
                tcp6       0      0 :::443                  :::*                    LISTEN      0          1851       787/apache2
                tcp6       0      0 :::445                  :::*                    LISTEN      0          16727      808/smbd
                tcp6       0      0 :::8000                 :::*                    LISTEN      1000       4468441    2230360/io.upnp.0
                tcp6       0      0 :::139                  :::*                    LISTEN      0          16728      808/smbd
                tcp6       0      0 :::111                  :::*                    LISTEN      0          622        1/init
                tcp6       0      0 :::80                   :::*                    LISTEN      0          1847       787/apache2
                tcp6       0      0 :::8081                 :::*                    LISTEN      1000       4182414    2227376/io.admin.0
                tcp6       0      0 :::8082                 :::*                    LISTEN      1000       4192699    2230725/io.web.0
                tcp6       0      0 :::8084                 :::*                    LISTEN      1000       4189353    2229167/io.socketio
                tcp6       0      0 :::22                   :::*                    LISTEN      0          1721       509/sshd: /usr/sbin
                tcp6       0      0 ::1:631                 :::*                    LISTEN      0          5973236    3206164/cupsd
                tcp6       0      0 :::8087                 :::*                    LISTEN      1000       4186947    2228911/io.simple-a
                tcp6       0      0 :::8088                 :::*                    LISTEN      1000       4188960    2229778/io.terminal
                tcp6       0      0 ::1:25                  :::*                    LISTEN      0          17440      800/exim4
                udp        0      0 0.0.0.0:631             0.0.0.0:*                           0          5974812    3206193/cups-browse
                udp        0      0 192.168.1.16:5353       0.0.0.0:*                           1000       4183783    2227659/io.tr-064.0
                udp        0      0 0.0.0.0:5353            0.0.0.0:*                           112        1609       419/avahi-daemon: r
                udp        0      0 0.0.0.0:1900            0.0.0.0:*                           1000       4192037    2230360/io.upnp.0
                udp        0      0 0.0.0.0:59503           0.0.0.0:*                           112        1611       419/avahi-daemon: r
                udp        0      0 0.0.0.0:43465           0.0.0.0:*                           1000       4191823    2230360/io.upnp.0
                udp        0      0 0.0.0.0:111             0.0.0.0:*                           0          619        1/init
                udp        0      0 192.168.1.255:137       0.0.0.0:*                           0          18480      538/nmbd
                udp        0      0 192.168.1.16:137        0.0.0.0:*                           0          18479      538/nmbd
                udp        0      0 0.0.0.0:137             0.0.0.0:*                           0          18460      538/nmbd
                udp        0      0 192.168.1.255:138       0.0.0.0:*                           0          18482      538/nmbd
                udp        0      0 192.168.1.16:138        0.0.0.0:*                           0          18481      538/nmbd
                udp        0      0 0.0.0.0:138             0.0.0.0:*                           0          18461      538/nmbd
                udp        0      0 0.0.0.0:53421           0.0.0.0:*                           1000       4182654    2227588/io.mihome-v
                udp6       0      0 fe80::ca9c:dcff:fee:546 :::*                                0          16340      422/NetworkManager
                udp6       0      0 :::5353                 :::*                                112        1610       419/avahi-daemon: r
                udp6       0      0 :::59025                :::*                                112        1612       419/avahi-daemon: r
                udp6       0      0 :::111                  :::*                                0          625        1/init
                2024-01-05 10:40:01.281  - info: dwd.0 (340585) starting. Version 2.8.5 in /opt/iobroker/node_modules/iobroker.dwd, node: v18.19.0, js-controller: 4.0.24
                2024-01-05 10:40:02.367  - info: dwd.0 (340585) Terminated (ADAPTER_REQUESTED_TERMINATION): Without reason
                2024-01-05 10:40:02.890  - info: host.debian instance system.adapter.dwd.0 terminated with code 11 (ADAPTER_REQUESTED_TERMINATION)
                2024-01-05 10:40:38.193  - error: lg-thinq.0 (2230962) Failed to get home
                2024-01-05 10:40:38.194  - error: lg-thinq.0 (2230962) AxiosError: Request failed with status code 400
                2024-01-05 10:40:38.194  - error: lg-thinq.0 (2230962) {"resultCode":"0102","result":""}
                2024-01-05 10:40:38.194  - info: lg-thinq.0 (2230962) Try to refresh Token
                2024-01-05 10:41:38.203  - error: lg-thinq.0 (2230962) Failed to get home
                2024-01-05 10:41:38.203  - error: lg-thinq.0 (2230962) AxiosError: Request failed with status code 400
                2024-01-05 10:41:38.203  - error: lg-thinq.0 (2230962) {"resultCode":"0102","result":""}
                2024-01-05 10:41:38.203  - info: lg-thinq.0 (2230962) Try to refresh Token
                2024-01-05 10:42:38.190  - error: lg-thinq.0 (2230962) Failed to get home
                2024-01-05 10:42:38.191  - error: lg-thinq.0 (2230962) AxiosError: Request failed with status code 400
                2024-01-05 10:42:38.191  - error: lg-thinq.0 (2230962) {"resultCode":"0102","result":""}
                2024-01-05 10:42:38.191  - info: lg-thinq.0 (2230962) Try to refresh Token
                2024-01-05 10:43:38.187  - error: lg-thinq.0 (2230962) Failed to get home
                2024-01-05 10:43:38.187  - error: lg-thinq.0 (2230962) AxiosError: Request failed with status code 400
                2024-01-05 10:43:38.188  - error: lg-thinq.0 (2230962) {"resultCode":"0102","result":""}
                2024-01-05 10:43:38.188  - info: lg-thinq.0 (2230962) Try to refresh Token
                2024-01-05 10:44:38.236  - error: lg-thinq.0 (2230962) Failed to get home
                2024-01-05 10:44:38.237  - error: lg-thinq.0 (2230962) AxiosError: Request failed with status code 400
                2024-01-05 10:44:38.237  - error: lg-thinq.0 (2230962) {"resultCode":"0102","result":""}
                2024-01-05 10:44:38.237  - info: lg-thinq.0 (2230962) Try to refresh Token
                2024-01-05 10:44:52.527  - info: admin.0 (2227376) failed connection to socket.io from ::ffff:192.168.1.201: Passport was not initialized
                2024-01-05 10:45:00.026  - info: host.debian instance system.adapter.dwd.0 started with pid 352969
                Slave:
                Skript v.2023-10-10
                *** BASE SYSTEM ***
                   Static hostname: raspberrypi
                         Icon name: computer
                            Kernel: Linux 6.1.21-v8+
                      Architecture: arm64
                Model           : Raspberry Pi 3 Model B Rev 1.2
                Docker          : false
                Kernel          : aarch64
                Userland        : arm64
                 10:39:38 up 23:36,  1 user,  load average: 2.82, 1.21, 0.63
                CPU threads: 4
                *** RASPBERRY THROTTLING ***
                Current issues:
                Previously detected issues:
                               Local time: Fri 2024-01-05 10:39:38 CET
                           Universal time: Fri 2024-01-05 09:39:38 UTC
                                 RTC time: n/a
                              NTP service: active
                          RTC in local TZ: no
                pi
                /home/pi
                pi adm dialout cdrom sudo audio video plugdev games users input render netdev gpio i2c spi iobroker
                X-Server:       false
                Desktop:
                Terminal:       tty
                Boot Target:    multi-user.target
                *** MEMORY ***
                Mem:            909M        527M         89M        0.0K        293M        319M
                Swap:            99M         38M         61M
                Total:          1.0G        565M        151M
                          909 M total memory
                          527 M used memory
                          438 M active memory
                          284 M inactive memory
                           89 M free memory
                            1 M buffer memory
                          291 M swap cache
                           99 M total swap
                           38 M used swap
                           61 M free swap
                Raspberry only:
                oom events: 0
                *** FILESYSTEM ***
                /dev/root      ext4       59G   32G   25G  57% /
                devtmpfs       devtmpfs  325M     0  325M   0% /dev
                tmpfs          tmpfs     455M     0  455M   0% /dev/shm
                tmpfs          tmpfs     182M  996K  181M   1% /run
                /dev/mmcblk0p1 vfat      255M   31M  225M  13% /boot
                tmpfs          tmpfs      91M     0   91M   0% /run/user/1000
                [Thu Jan  4 11:03:22 2024] Kernel command line: coherent_pool=1M 8250.nr_uarts=0 snd_bcm2835.enable_headphones=0 snd_bcm2835.enable_headphones=1 snd_bcm2835.enable_hdmi=1 snd_bcm2835.enable_hdmi=0 video=Composite-1:720x480@60i vc_mem.mem_base=0x3ec00000 vc_mem.mem_size=0x40000000  console=ttyS0,115200 console=tty1 root=PARTUUID=d3cf0315-02 rootfstype=ext4 fsck.repair=yes rootwait
                [Thu Jan  4 11:03:25 2024] EXT4-fs (mmcblk0p2): mounted filesystem with ordered data mode. Quota mode: none.
                [Thu Jan  4 11:03:25 2024] VFS: Mounted root (ext4 filesystem) readonly on device 179:2.
                [Thu Jan  4 11:03:29 2024] EXT4-fs (mmcblk0p2): re-mounted. Quota mode: none.
                /       /dev/mmcblk0p2 ext4   rw,noatime
                `-/boot /dev/mmcblk0p1 vfat   rw,relatime,fmask=0022,dmask=0022,codepage=437,iocharset=ascii,shortname=mixed,errors=remount-ro
                /var:
                27G     /var/
                22G     /var/lib/mysql/iobroker
                22G     /var/lib/mysql
                22G     /var/lib
                4.5G    /var/log
                Archived and active journals take up 4.0G in the file system.
                4.0K    /opt/iobroker/backups/
                18M     /opt/iobroker/iobroker-data/
                14M     /opt/iobroker/iobroker-data/files
                13M     /opt/iobroker/iobroker-data/files/admin.admin/custom/static/js
                6.3M    /opt/iobroker/iobroker-data/files/admin.admin/custom/static/js/vendors-node_modules_iobroker_adapter-react-v5_assets_devices_parseNames_js-node_modules_iobr-99c23e.847b8ad9.chunk.js.map
                3.0M    /opt/iobroker/iobroker-data/objects.jsonl
                2.8M    /opt/iobroker/iobroker-data/files/admin.admin/custom/static/js/vendors-node_modules_iobroker_adapter-react-v5_assets_devices_parseNames_js-node_modules_iobr-99c23e.847b8ad9.chunk.js
                1.6M    /opt/iobroker/iobroker-data/files/admin.admin/custom/static/js/vendors-node_modules_mui_material_Accordion_index_js-node_modules_mui_material_AccordionDetai-57e02d.0886b730.chunk.js.map
                652K    /opt/iobroker/iobroker-data/files/admin.admin/custom/static/js/vendors-node_modules_mui_material_index_js.40e01f69.chunk.js.map
                USB-Devices by-id:
                /dev/serial/by-id/usb-1a86_USB_Serial-if00-port0
                /usr/bin/npm            10.2.3
                /usr/bin/npx            10.2.3
                nodejs:
                  Version table:
                        500 http://deb.debian.org/debian bullseye/main arm64 Packages
                        500 http://security.debian.org/debian-security bullseye-security/main arm64 Packages
                Errors in npm tree:
                ioBroker Status
                At least one iobroker host is running.
                Objects type: jsonl
                States  type: jsonl
                admin:          6.12.0
                javascript:     "javascript" not found
                Adapters from github:   0
                Adapter State
                + instance is alive
                Adapter    "enigma2"      : 2.0.5    , installed 2.0.5
                Adapter    "unifi"        : 0.6.7    , installed 0.6.7
                Adapter    "zigbee"       : 1.9.5    , installed 1.8.23 [Updatable]
                Objects and States
                Objects:        27977
                States:         22607
                Hit:1 http://security.debian.org/debian-security bullseye-security InRelease
                Hit:2 http://deb.debian.org/debian bullseye InRelease
                Hit:3 http://deb.debian.org/debian bullseye-updates InRelease
                Hit:4 http://archive.raspberrypi.org/debian bullseye InRelease
                Hit:5 https://deb.nodesource.com/node_18.x nodistro InRelease
                Pending Updates: 0
                tcp        0      0 0.0.0.0:22              0.0.0.0:*               LISTEN      0          12641      525/sshd: /usr/sbin
                tcp6       0      0 :::3306                 :::*                    LISTEN      110        12676      569/mariadbd
                tcp6       0      0 :::22                   :::*                    LISTEN      0          12643      525/sshd: /usr/sbin
                udp        0      0 0.0.0.0:68              0.0.0.0:*                           0          13987      780/dhcpcd
                udp        0      0 0.0.0.0:5353            0.0.0.0:*                           108        13921      394/avahi-daemon: r
                udp        0      0 0.0.0.0:58656           0.0.0.0:*                           108        13923      394/avahi-daemon: r
                udp6       0      0 :::41470                :::*                                108        13924      394/avahi-daemon: r
                udp6       0      0 :::546                  :::*                                0          13999      780/dhcpcd
                udp6       0      0 :::5353                 :::*                                108        13922      394/avahi-daemon: r
                2024-01-05 01:00:45.882  - warn: zigbee.0 (29251) Device '0x00158d00069b00d3' announced itself
                2024-01-05 01:20:14.792  - info: host.raspberrypi Delete log file iobroker.2023-12-28.log.gz
                2024-01-05 07:17:30.301  - error: zigbee.0 (29251) No converter available for 'AC03641' with key 'available'
                  Nebenbei gesehen:
                  Der CIFS der Fritzboxen spricht vers=3.1.1 und muss mit der Option 'noserverino' gemountet werden.
                  Setz den User in die Gruppe 'adm' rein.
                  Installier die beiden Adapter auf dem Master nochmal, zur Not 'über die Katze':
                  Trag beim zigbee-Adapter statt
                  port: /dev/ttyUSB0
                  besser
                  ein. (Wenn das denn der zigbee-USB-Stick ist.
                    npm ERR! invalid: iobroker.openligadb@1.3.4 /opt/iobroker/node_modules/iobroker.openligadb npm ERR! invalid: iobroker.tibberconnect@0.0.10 /opt/iobroker/node_modules/iobroker.tibberconnect
                    Das ist ja das Problem, ich kann keine Adapter installieren und auch keine Adapter updaten und keine Adapter löschen. 😞
                    Die anderen beiden Sachen schaue ich mir sofort an. Vielen Dank für Deine Mühe!!!
                      Per git url muss das gehen.
                        @thomas-braun Leider nicht!
                          Leider nicht!
                          Meldungen?
                            djsirius @Thomas Braun last edited by djsirius
                            @thomas-braun Es gibt keine Meldung, weil er beim Installieren immer stehen bleibt.
                              ich tippe immer noch auf ipv6 Thematik bei npm
                                In einer Konsole den Installationsbefehl per git url (genaue Syntax habe ich gerade nicht parat, kannste aber aus dem entsprechenden Admin-Fenster entnehmen) eingeben.
                                  Sorry, aber damit kenne ich mich überhaupt nicht aus.
                                  Ich habe jetzt
                                  iobroker url https://github.com/oweitman/ioBroker.openligadb --host debian --debug
                                  Über git bekomme ich es nicht hin, weil ich den Befehl nicht kenne.
                                  Ist und bleibt aber das selbe Problem.
                                  Was gibt es denn da genau für ein Problem mit ipv6?
                                  Vielen Dank!
                                    Moin,
                                    ich habe jetzt aus lauter Verzweiflung Nodejs nochmal neu installiert. Auf meinem Master ist alles OK.
                                    Auf meinem Slave bekomme ich immer eine Meldung, wenn ich den iob fix drüber laufen lasse.
                                        Database maintenance (4/5)
                                    Checking for uncompressed JSONL databases... This might take a while!
                                    npm ERR! code ETIMEDOUT
                                    npm ERR! syscall connect
                                    npm ERR! errno ETIMEDOUT
                                    npm ERR! network request to https://registry.npmjs.org/@iobroker%2fjsonltool failed, reason: connect ETIMEDOUT 2606:4700::6810:1a22:443
                                    npm ERR! network This is a problem related to network connectivity.
                                    npm ERR! network In most cases you are behind a proxy or have bad network settings.
                                    npm ERR! network
                                    npm ERR! network If you are behind a proxy, please make sure that the
                                    npm ERR! network 'proxy' config is set properly.  See: 'npm help config'
                                    npm ERR! A complete log of this run can be found in: /home/iobroker/.npm/_logs/2024-01-08T08_12_15_007Z-debug-0.log
                                    iob diag:
                                    Skript v.2023-10-10
                                    *** BASE SYSTEM ***
                                             Icon name: computer
                                          Architecture: arm64
                                    Docker          : false
                                    Kernel          : aarch64
                                    Userland        : arm64
                                     09:20:56 up 3 days, 22:17,  1 user,  load average: 0.25, 0.45, 0.80
                                    CPU threads: 4
                                    Current issues:
                                                   Local time: Mon 2024-01-08 09:20:56 CET
                                               Universal time: Mon 2024-01-08 08:20:56 UTC
                                                     RTC time: n/a
                                                  NTP service: active
                                              RTC in local TZ: no
                                    pi
                                    /home/pi
                                    X-Server:       false
                                    Desktop:
                                    Terminal:       tty
                                    *** MEMORY ***
                                    Mem:            909M        212M        138M        0.0K        558M        632M
                                    Swap:            99M         78M         21M
                                    Total:          1.0G        290M        160M
                                              909 M total memory
                                              212 M used memory
                                              238 M active memory
                                              396 M inactive memory
                                              138 M free memory
                                               39 M buffer memory
                                              518 M swap cache
                                               99 M total swap
                                               78 M used swap
                                               21 M free swap
                                    Raspberry only:
                                    oom events: 0
                                      UNIT             LOAD   ACTIVE SUB    DESCRIPTION
                                    * iobroker.service loaded failed failed ioBroker Server
                                    LOAD   = Reflects whether the unit definition was properly loaded.
                                    ACTIVE = The high-level unit activation state, i.e. generalization of SUB.
                                    SUB    = The low-level unit activation state, values depend on unit type.
                                    1 loaded units listed.
                                    *** FILESYSTEM ***
                                    /dev/root      ext4       59G   32G   25G  56% /
                                    tmpfs          tmpfs     182M 1008K  181M   1% /run
                                    tmpfs          tmpfs      91M     0   91M   0% /run/user/0
                                    /var:
                                    27G     /var/
                                    22G     /var/lib/mysql
                                    22G     /var/lib
                                    4.2G    /var/log
                                    Archived and active journals take up 3.9G in the file system.
                                    USB-Devices by-id:
                                    /usr/bin/npm            10.2.3
                                    /usr/bin/npx            10.2.3
                                    nodejs:
                                      Version table:
                                     *** 18.19.0-1nodesource1 1001
                                         18.18.2-1nodesource1 1001
                                         18.18.1-1nodesource1 1001
                                         18.18.0-1nodesource1 1001
                                         18.17.1-1nodesource1 1001
                                         18.17.0-1nodesource1 1001
                                         18.16.1-1nodesource1 1001
                                         18.16.0-1nodesource1 1001
                                         18.15.0-1nodesource1 1001
                                         18.14.2-1nodesource1 1001
                                         18.14.1-1nodesource1 1001
                                         18.14.0-1nodesource1 1001
                                         18.13.0-1nodesource1 1001
                                         18.12.0-1nodesource1 1001
                                         18.11.0-1nodesource1 1001
                                         18.10.0-1nodesource1 1001
                                         18.9.1-1nodesource1 1001
                                         18.9.0-1nodesource1 1001
                                         18.8.0-1nodesource1 1001
                                         18.7.0-1nodesource1 1001
                                         18.6.0-1nodesource1 1001
                                         18.5.0-1nodesource1 1001
                                         18.4.0-1nodesource1 1001
                                         18.3.0-1nodesource1 1001
                                         18.2.0-1nodesource1 1001
                                         18.1.0-1nodesource1 1001
                                         18.0.0-1nodesource1 1001
                                    Errors in npm tree:
                                    ioBroker Status
                                    iobroker is not running on this host.
                                    Objects type: jsonl
                                    States  type: jsonl
                                    admin:          6.12.0
                                    Adapter State
                                    + instance is alive
                                    Adapter    "zigbee"       : 1.9.7    , installed 1.8.23 [Updatable]
                                    Objects and States
                                    Objects:        28092
                                    States:         22715
                                    Pending Updates: 0
                                    2024-01-08 09:11:19.565  - info: zigbee.0 (765235) debug devices set to []
                                    2024-01-08 09:11:27.300  - info: host.raspberrypi received SIGTERM
                                    2024-01-08 09:11:27.306  - info: zigbee.0 (765235) cleaned everything up...
                                    2024-01-08 09:11:27.324  - info: rpi2.1 (765173) Terminated (START_IMMEDIATELY_AFTER_STOP): Without reason
                                    2024-01-08 09:11:27.312  - info: host.raspberrypi stopInstance system.adapter.rpi2.1 (force=false, process=true)
                                    2024-01-08 09:11:27.314  - info: host.raspberrypi stopInstance system.adapter.zigbee.0 (force=false, process=true)
                                    2024-01-08 09:11:27.316  - info: host.raspberrypi stopInstance system.adapter.enigma2.0 (force=false, process=true)
                                    2024-01-08 09:11:27.337  - info: rpi2.1 (765173) Got terminate signal TERMINATE_YOURSELF
                                    2024-01-08 09:11:27.336  - info: enigma2.0 (765291) Got terminate signal TERMINATE_YOURSELF
                                    2024-01-08 09:11:27.379  - info: host.raspberrypi stopInstance system.adapter.rpi2.1 send kill signal
                                    2024-01-08 09:11:27.384  - info: host.raspberrypi stopInstance system.adapter.zigbee.0 send kill signal
                                    2024-01-08 09:11:27.386  - info: host.raspberrypi stopInstance system.adapter.enigma2.0 send kill signal
                                    2024-01-08 09:11:27.619  - info: zigbee.0 (765235) Zigbee: disabling joining new devices.
                                    2024-01-08 09:11:27.670  - info: zigbee.0 (765235) Got terminate signal TERMINATE_YOURSELF
                                    2024-01-08 09:11:27.834  - info: enigma2.0 (765291) Terminated (START_IMMEDIATELY_AFTER_STOP): Without reason
                                    2024-01-08 09:11:27.879  - info: zigbee.0 (765235) Terminated (START_IMMEDIATELY_AFTER_STOP): Without reason
                                    2024-01-08 09:11:28.310  - info: host.raspberrypi instance system.adapter.rpi2.1 terminated with code 156 (START_IMMEDIATELY_AFTER_STOP)
                                    2024-01-08 09:11:28.387  - info: host.raspberrypi stopInstance system.adapter.zigbee.0 killing pid 765235
                                    2024-01-08 09:11:28.389  - info: host.raspberrypi stopInstance system.adapter.enigma2.0 killing pid 765291
                                    2024-01-08 09:11:28.834  - info: host.raspberrypi instance system.adapter.enigma2.0 terminated with code 156 (START_IMMEDIATELY_AFTER_STOP)
                                    2024-01-08 09:11:28.836  - info: host.raspberrypi All instances are stopped.
                                    2024-01-08 09:11:29.178  - warn: host.raspberrypi instance system.adapter.zigbee.0 terminated due to SIGTERM
                                    2024-01-08 09:11:29.180  - info: host.raspberrypi instance system.adapter.zigbee.0 terminated with code null ()
                                    2024-01-08 09:11:29.181  - info: host.raspberrypi All instances are stopped.
                                    2024-01-08 09:11:29.271  - info: host.raspberrypi terminated
                                    Vielen Dank!
                                      Thomas Braun Most Active @djsirius last edited by Thomas Braun
                                      npm ERR! network request to https://registry.npmjs.org/@iobroker%2Fjsonltool failed, reason: connect ETIMEDOUT 2606:4700::6810:1a22:443
                                      Schau mal nach, ob dein Router / Internet-Provider zur Gänze auf IPv6 umgestellt ist.
                                      Z. B. in der FritzBox muss zum einen IPv6 grundsätzlich angehakt sein, aber auch das Routing nach draußen muss auf IPv6 gestellt werden.
                                        macht das Sinn, weil das Master System diesen Fehler nicht hat. Die laufen ja beide über den selben Router.
                                        Ist IPv6 ist aber auch angehakt.
                                          Ich habe jetzt ein Downgrade von Nodejs gemacht, weil ich nicht weiter komme.
                                          Wenn noch jemand eine Idee hat, bitte her damit. Ich bin ratlos! 😞
                                          Thomas Braun Marc Berg 2 Replies Last reply Reply Quote 0
                                            @djsirius
                                            Ist zu 99,9% etwas in deinem Netzwerk.
                                            1.0k
                                            81.1k
                                            nodejs
                                            91
                                            844
                                            228608
