    4. Diskussion zum HowTo nodejs-Installation und upgrade
      Thomas Braun Most Active @djsirius last edited by
      @djsirius
      Gib mal von beiden Kisten ein vollständiges
      iob diag
      bekannt.
        djsirius @Thomas Braun last edited by
        @thomas-braun said in Diskussion zum HowTo nodejs-Installation und upgrade:
        iob diag
        Master:
        Skript v.2023-10-10
        *** BASE SYSTEM ***
           Static hostname: debian
                 Icon name: computer-desktop
                   Chassis: desktop
          Operating System: Debian GNU/Linux 11 (bullseye)
                    Kernel: Linux 5.10.0-26-amd64
              Architecture: x86-64
        model name      : Intel(R) Core(TM) i5-2400 CPU @ 3.10GHz
        Docker          : false
        Virtualization  : none
        Kernel          : x86_64
        Userland        : amd64
        Systemuptime and Load:
         10:44:00 up 1 day, 15:16,  1 user,  load average: 0.79, 0.49, 0.31
        CPU threads: 4
        *** Time and Time Zones ***
                       Local time: Fri 2024-01-05 10:44:00 CET
                   Universal time: Fri 2024-01-05 09:44:00 UTC
                         RTC time: Fri 2024-01-05 09:44:01
                      NTP service: active
                  RTC in local TZ: no
        *** User and Groups ***
        iobroker
        /home/iobroker
        iobroker tty dialout cdrom floppy sudo audio dip video plugdev netdev bluetooth lpadmin scanner
        *** X-Server-Setup ***
        X-Server:       false
        Desktop:
        Terminal:       tty
        *** MEMORY ***
        Mem:            7.9G        4.4G        2.7G        5.0M        837M        3.2G
        Swap:           4.0G          0B        4.0G
        Total:           11G        4.4G        6.7G
                 7864 M total memory
                 4364 M used memory
                  341 M active memory
                 4539 M inactive memory
                 2662 M free memory
                  161 M buffer memory
                  676 M swap cache
                 4015 M total swap
                    0 M used swap
                 4015 M free swap
        *** FAILED SERVICES ***
        0 loaded units listed.
        *** FILESYSTEM ***
        Filesystem                         Type      Size  Used Avail Use% Mounted on
        udev                               devtmpfs  3.9G     0  3.9G   0% /dev
        tmpfs                              tmpfs     787M  2.5M  785M   1% /run
        /dev/sda2                          ext4      454G   44G  387G  11% /
        tmpfs                              tmpfs     3.9G     0  3.9G   0% /dev/shm
        tmpfs                              tmpfs     5.0M  4.0K  5.0M   1% /run/lock
        /dev/sda1                          vfat      511M  5.8M  506M   2% /boot/efi
        //192.168.1.1/GLADYS7490/TREKSTOR/ cifs      467G  353G  114G  76% /media/fritzbox
        tmpfs                              tmpfs     787M   40K  787M   1% /run/user/1000
        [Wed Jan  3 19:27:32 2024] EXT4-fs (sda2): mounted filesystem with ordered data mode. Opts: (null)
        [Wed Jan  3 19:27:39 2024] EXT4-fs (sda2): re-mounted. Opts: errors=remount-ro
        TARGET            SOURCE                             FSTYPE OPTIONS
        /                 /dev/sda2                          ext4   rw,relatime,errors=remount-ro
        |-/media/fritzbox //192.168.1.1/GLADYS7490/TREKSTOR/ cifs   rw,relatime,vers=1.0,cache=strict,username=mount,uid=1000,forceuid,gid=1000,forcegid,addr=192.168.1.1,file_mode=0755,dir_mode=0755,soft,nounix,serverino,mapposix,rsize=61440,wsize=65536,bsize=1048576,echo_interval=60,actimeo=1
        `-/boot/efi       /dev/sda1                          vfat   rw,relatime,fmask=0077,dmask=0077,codepage=437,iocharset=ascii,shortname=mixed,utf8,errors=remount-ro
        /var:
        7.3G    /var/
        4.1G    /var/log
        4.0G    /var/log/journal/f063d3dd2a6e40efad76adb6a70d9daf
        2.4G    /var/cache/apt
        Archived and active journals take up 3.6G in the file system.
        /opt/iobroker/backups:
        115M    /opt/iobroker/backups/
        /opt/iobroker/iobroker-data:
        1.1G    /opt/iobroker/iobroker-data/
        600M    /opt/iobroker/iobroker-data/files
        356M    /opt/iobroker/iobroker-data/backup-objects
        73M     /opt/iobroker/iobroker-data/files/telegram.admin
        67M     /opt/iobroker/iobroker-data/files/javascript.admin
        81M     /opt/iobroker/iobroker-data/states.jsonl
        35M     /opt/iobroker/iobroker-data/files/devices.admin/static/js/main.24f2bb56.js.map
        33M     /opt/iobroker/iobroker-data/files/iot.admin/static/js/main.1797d034.js.map
        28M     /opt/iobroker/iobroker-data/objects.jsonl
        22M     /opt/iobroker/iobroker-data/files/modbus.admin/static/js/main.b5f6766c.js.map
        USB-Devices by-id:
        *** NodeJS-Installation ***
        /usr/bin/nodejs         v18.19.0
        /usr/bin/node           v18.19.0
        /usr/bin/npm            10.2.3
        /usr/bin/npx            10.2.3
        /usr/bin/corepack       0.22.0
        nodejs:
          Installed: 18.19.0-1nodesource1
          Candidate: 18.19.0-1nodesource1
          Version table:
         *** 18.19.0-1nodesource1 500
                500 https://deb.nodesource.com/node_18.x nodistro/main amd64 Packages
                100 /var/lib/dpkg/status
             18.18.2-1nodesource1 500
             18.18.1-1nodesource1 500
             18.18.0-1nodesource1 500
             18.17.1-1nodesource1 500
             18.17.0-1nodesource1 500
             18.16.1-1nodesource1 500
             18.16.0-1nodesource1 500
             18.15.0-1nodesource1 500
             18.14.2-1nodesource1 500
             18.14.1-1nodesource1 500
             18.14.0-1nodesource1 500
             18.13.0-1nodesource1 500
             18.12.0-1nodesource1 500
             18.11.0-1nodesource1 500
             18.10.0-1nodesource1 500
             18.9.1-1nodesource1 500
             18.9.0-1nodesource1 500
             18.8.0-1nodesource1 500
             18.7.0-1nodesource1 500
             18.6.0-1nodesource1 500
             18.5.0-1nodesource1 500
             18.4.0-1nodesource1 500
             18.3.0-1nodesource1 500
             18.2.0-1nodesource1 500
             18.1.0-1nodesource1 500
             18.0.0-1nodesource1 500
             12.22.12~dfsg-1~deb11u4 500
                500 http://ftp.de.debian.org/debian bullseye/main amd64 Packages
                500 http://deb.debian.org/debian bullseye/main amd64 Packages
        No problems detected
        Errors in npm tree:
        npm ERR! code ELSPROBLEMS
        npm ERR! extraneous: @types/caseless@0.12.5 /opt/iobroker/node_modules/@types/caseless
        npm ERR! extraneous: @types/request@2.48.12 /opt/iobroker/node_modules/@types/request
        npm ERR! extraneous: @types/tough-cookie@4.0.5 /opt/iobroker/node_modules/@types/tough-cookie
        npm ERR! extraneous: coffeescript@2.7.0 /opt/iobroker/node_modules/coffeescript
        npm ERR! invalid: iobroker.openligadb@1.3.4 /opt/iobroker/node_modules/iobroker.openligadb
        npm ERR! invalid: iobroker.tibberconnect@0.0.10 /opt/iobroker/node_modules/iobroker.tibberconnect
        npm ERR! extraneous: jsonata@2.0.3 /opt/iobroker/node_modules/jsonata
        npm ERR! extraneous: node-inspect@2.0.0 /opt/iobroker/node_modules/node-inspect
        npm ERR! extraneous: picocolors@1.0.0 /opt/iobroker/node_modules/picocolors
        npm ERR! extraneous: suncalc2@1.8.1 /opt/iobroker/node_modules/suncalc2
        npm ERR! extraneous: typescript@5.2.2 /opt/iobroker/node_modules/typescript
        npm ERR! extraneous: virtual-tsc@0.6.2 /opt/iobroker/node_modules/virtual-tsc
        npm ERR! extraneous: wake_on_lan@1.0.0 /opt/iobroker/node_modules/wake_on_lan
        npm ERR! extraneous: form-data@2.5.1 /opt/iobroker/node_modules/@types/request/node_modules/form-data
        npm ERR! extraneous: debug@4.3.4 /opt/iobroker/node_modules/virtual-tsc/node_modules/debug
        npm ERR! extraneous: ms@2.1.2 /opt/iobroker/node_modules/virtual-tsc/node_modules/ms
        npm ERR! invalid: xmlbuilder@0.4.2 /opt/iobroker/node_modules/xmlbuilder
        npm ERR! invalid: buffer@5.7.1 /opt/iobroker/node_modules/buffer
        npm ERR! A complete log of this run can be found in: /home/iobroker/.npm/_logs/2024-01-05T09_44_23_394Z-debug-0.log
        *** ioBroker-Installation ***
        ioBroker Status
        Objects type: jsonl
        States  type: jsonl
        Core adapters versions
        js-controller:  4.0.24
        admin:          6.12.0
        javascript:     7.1.6
        npm ERR! A complete log of this run can be found in: /home/iobroker/.npm/_logs/2024-01-05T09_44_34_780Z-debug-0.log
        Adapters from github:   2
        Adapter State
        + system.adapter.admin.0                  : admin                 : debian                                   -  enabled, port: 8081, bind: 0.0.0.0 (SSL), run as: admin
        + system.adapter.alexa2.0                 : alexa2                : debian                                   -  enabled
        + system.adapter.backitup.0               : backitup              : debian                                   -  enabled
          system.adapter.daswetter.0              : daswetter             : debian                                   -  enabled
          system.adapter.devices.0                : devices               : debian                                   -  enabled
        + system.adapter.discovery.0              : discovery             : debian                                   -  enabled
          system.adapter.dwd.0                    : dwd                   : debian                                   -  enabled
        + system.adapter.enigma2.0                : enigma2               : raspberrypi                              -  enabled
          system.adapter.feiertage.0              : feiertage             : debian                                   -  enabled
          system.adapter.flot.0                   : flot                  : debian                                   -  enabled
        + system.adapter.history.0                : history               : debian                                   -  enabled
        + system.adapter.hm-rega.0                : hm-rega               : debian                                   -  enabled
        + system.adapter.hm-rpc.0                 : hm-rpc                : debian                                   -  enabled, port: 0
        + system.adapter.hm-rpc.1                 : hm-rpc                : debian                                   -  enabled, port: 0
          system.adapter.ical.0                   : ical                  : debian                                   -  enabled
          system.adapter.ical.1                   : ical                  : debian                                   -  enabled
          system.adapter.ical.2                   : ical                  : debian                                   -  enabled
          system.adapter.icons-mfd-png.0          : icons-mfd-png         : debian                                   -  enabled
          system.adapter.icons-mfd-svg.0          : icons-mfd-svg         : debian                                   -  enabled
        + system.adapter.info.0                   : info                  : debian                                   -  enabled
        + system.adapter.iot.0                    : iot                   : debian                                   -  enabled
        + system.adapter.javascript.0             : javascript            : debian                                   -  enabled
        + system.adapter.lg-thinq.0               : lg-thinq              : debian                                   -  enabled
        + system.adapter.linux-control.0          : linux-control         : debian                                   -  enabled
        + system.adapter.logparser.0              : logparser             : debian                                   -  enabled
        + system.adapter.meross.0                 : meross                : debian                                   -  enabled
        + system.adapter.mihome-vacuum.0          : mihome-vacuum         : debian                                   -  enabled, port: 54321
          system.adapter.mobile.0                 : mobile                : debian                                   -  enabled
        + system.adapter.modbus.0                 : modbus                : debian                                   -  enabled
        + system.adapter.openligadb.0             : openligadb            : debian                                   -  enabled
        + system.adapter.ping.0                   : ping                  : debian                                   -  enabled
        + system.adapter.pollenflug.0             : pollenflug            : debian                                   -  enabled
        + system.adapter.rpi2.1                   : rpi2                  : raspberrypi                              -  enabled
        + system.adapter.scenes.0                 : scenes                : debian                                   -  enabled
        + system.adapter.shelly.0                 : shelly                : debian                                   -  enabled, port: 1882, bind: 0.0.0.0
        + system.adapter.simple-api.0             : simple-api            : debian                                   -  enabled, port: 8087, bind: 0.0.0.0, run as: admin
        + system.adapter.socketio.0               : socketio              : debian                                   -  enabled, port: 8084, bind: 0.0.0.0 (SSL), run as: admin
        + system.adapter.sql.0                    : sql                   : debian                                   -  enabled, port: 3306
        + system.adapter.systeminfo.0             : systeminfo            : debian                                   -  enabled
        + system.adapter.tankerkoenig.0           : tankerkoenig          : debian                                   -  enabled
        + system.adapter.telegram.0               : telegram              : debian                                   -  enabled, port: 8443, bind: 0.0.0.0
        + system.adapter.terminal.0               : terminal              : debian                                   -  enabled, port: 8088, bind: 0.0.0.0, run as: admin
        + system.adapter.text2command.0           : text2command          : debian                                   -  enabled
        + system.adapter.tibberlink.0             : tibberlink            : debian                                   -  enabled
        + system.adapter.tr-064.0                 : tr-064                : debian                                   -  enabled
        + system.adapter.trashschedule.0          : trashschedule         : debian                                   -  enabled
        + system.adapter.upnp.0                   : upnp                  : debian                                   -  enabled
        + system.adapter.viessmannapi.0           : viessmannapi          : debian                                   -  enabled
          system.adapter.vis-bars.0               : vis-bars              : debian                                   -  enabled
          system.adapter.vis-canvas-gauges.0      : vis-canvas-gauges     : debian                                   -  enabled
          system.adapter.vis-colorpicker.0        : vis-colorpicker       : debian                                   -  enabled
          system.adapter.vis-fancyswitch.0        : vis-fancyswitch       : debian                                   -  enabled
          system.adapter.vis-history.0            : vis-history           : debian                                   -  enabled
          system.adapter.vis-hqwidgets.0          : vis-hqwidgets         : debian                                   -  enabled
          system.adapter.vis-jqui-mfd.0           : vis-jqui-mfd          : debian                                   -  enabled
          system.adapter.vis-justgage.0           : vis-justgage          : debian                                   -  enabled
          system.adapter.vis-materialdesign.0     : vis-materialdesign    : debian                                   -  enabled
          system.adapter.vis-metro.0              : vis-metro             : debian                                   -  enabled
          system.adapter.vis-plumb.0              : vis-plumb             : debian                                   -  enabled
          system.adapter.vis-timeandweather.0     : vis-timeandweather    : debian                                   -  enabled
          system.adapter.vis-weather.0            : vis-weather           : debian                                   -  enabled
          system.adapter.vis.0                    : vis                   : debian                                   -  enabled
        + system.adapter.web.0                    : web                   : debian                                   -  enabled, port: 8082, bind: 0.0.0.0, run as: admin
        + system.adapter.zigbee.0                 : zigbee                : raspberrypi                              -  enabled, port: /dev/ttyUSB0
        + instance is alive
        ioBroker-Repositories
        Active repo(s): stable
        Installed ioBroker-Instances
        Used repository: stable
        Adapter    "admin"        : 6.12.0   , installed 6.12.0
        Adapter    "alexa2"       : 3.26.3   , installed 3.26.2 [Updatable]
        Adapter    "backitup"     : 2.9.8    , installed 2.8.7  [Updatable]
        Adapter    "daswetter"    : 3.1.11   , installed 3.1.11
        Adapter    "feiertage"    : 1.1.4    , installed 1.1.4
        Adapter    "hm-rega"      : 4.0.0    , installed 4.0.0
        Adapter    "hm-rpc"       : 1.15.19  , installed 1.15.19
        Adapter    "iot"          : 2.0.11   , installed 2.0.11
        Adapter    "javascript"   : 7.1.6    , installed 7.1.6
        Controller "js-controller": 5.0.17   , installed 4.0.24 [Updatable]
        Adapter    "lg-thinq"     : 0.1.4    , installed 0.1.4
        Adapter    "linux-control": 1.1.5    , installed 1.1.5
        Adapter    "logparser"    : 2.2.0    , installed 2.2.0
        Adapter    "meross"       : 1.16.1   , installed 1.16.1
        Adapter    "mihome-vacuum": 4.1.0    , installed 4.1.0
        Adapter    "mobile"       : 1.0.1    , installed 1.0.1
        Adapter    "modbus"       : 6.0.1    , installed 6.0.1
        Adapter    "openligadb"   : 1.2.4    , installed 1.3.4
        Adapter    "pollenflug"   : 1.0.6    , installed 1.0.6
        Adapter    "shelly"       : 6.6.1    , installed 6.6.1
        Adapter    "sql"          : 2.2.0    , installed 2.2.0
        Adapter    "systeminfo"   : 1.1.0    , installed 1.1.0
        Adapter    "telegram"     : 3.0.1    , installed 3.0.1
        Adapter    "terminal"     : 1.0.0    , installed 1.0.0
        Adapter    "text2command" : 3.0.2    , installed 3.0.2
        Adapter    "tibberlink"   : 2.0.0    , installed 2.0.0
        Adapter    "trashschedule": 2.3.0    , installed 2.3.0
        Adapter    "upnp"         : 1.0.21   , installed 1.0.21
        Adapter    "viessmannapi" : 2.3.0    , installed 2.3.0
        Adapter    "vis-justgage" : 2.1.0    , installed 2.1.0
        Adapter    "vis-weather"  : 2.5.6    , installed 2.5.6
        Adapter    "web"          : 6.1.10   , installed 6.1.10
        Adapter    "ws"           : 2.5.8    , installed 2.5.8
        Objects and States
        Objects:        27977
        States:         22607
        Hit:1 http://ftp.de.debian.org/debian bullseye InRelease
        Hit:2 http://ftp.de.debian.org/debian bullseye-updates InRelease
        Hit:3 http://deb.debian.org/debian bullseye InRelease
        Hit:4 http://deb.debian.org/debian bullseye-updates InRelease
        Hit:5 http://deb.debian.org/debian bullseye-backports InRelease
        Hit:6 https://deb.nodesource.com/node_18.x nodistro InRelease
        Hit:7 https://packages.sury.org/php bullseye InRelease
        Hit:8 https://packagecloud.io/ookla/speedtest-cli/debian bullseye InRelease
        Reading package lists...
        Pending Updates: 0
        *** Listening Ports ***
        tcp        0      0 192.168.1.16:8701       0.0.0.0:*               LISTEN      1000       4185347    2227684/io.hm-rpc.1
        tcp        0      0 0.0.0.0:445             0.0.0.0:*               LISTEN      0          16729      808/smbd
        tcp        0      0 0.0.0.0:9000            0.0.0.0:*               LISTEN      1000       4180940    2227358/iobroker.js
        tcp        0      0 0.0.0.0:9001            0.0.0.0:*               LISTEN      1000       4181668    2227358/iobroker.js
        tcp        0      0 0.0.0.0:139             0.0.0.0:*               LISTEN      0          16730      808/smbd
        tcp        0      0 0.0.0.0:111             0.0.0.0:*               LISTEN      0          618        1/init
        tcp        0      0 192.168.1.16:2001       0.0.0.0:*               LISTEN      1000       4181880    2227508/io.hm-rpc.0
        tcp        0      0 0.0.0.0:22              0.0.0.0:*               LISTEN      0          1719       509/sshd: /usr/sbin
        tcp        0      0 127.0.0.1:631           0.0.0.0:*               LISTEN      0          5973237    3206164/cupsd
        tcp        0      0 127.0.0.1:25            0.0.0.0:*               LISTEN      0          17439      800/exim4
        tcp        0      0 0.0.0.0:1882            0.0.0.0:*               LISTEN      1000       4185455    2227740/io.shelly.0
        tcp6       0      0 :::443                  :::*                    LISTEN      0          1851       787/apache2
        tcp6       0      0 :::445                  :::*                    LISTEN      0          16727      808/smbd
        tcp6       0      0 :::8000                 :::*                    LISTEN      1000       4468441    2230360/io.upnp.0
        tcp6       0      0 :::139                  :::*                    LISTEN      0          16728      808/smbd
        tcp6       0      0 :::111                  :::*                    LISTEN      0          622        1/init
        tcp6       0      0 :::80                   :::*                    LISTEN      0          1847       787/apache2
        tcp6       0      0 :::8081                 :::*                    LISTEN      1000       4182414    2227376/io.admin.0
        tcp6       0      0 :::8082                 :::*                    LISTEN      1000       4192699    2230725/io.web.0
        tcp6       0      0 :::8084                 :::*                    LISTEN      1000       4189353    2229167/io.socketio
        tcp6       0      0 :::22                   :::*                    LISTEN      0          1721       509/sshd: /usr/sbin
        tcp6       0      0 ::1:631                 :::*                    LISTEN      0          5973236    3206164/cupsd
        tcp6       0      0 :::8087                 :::*                    LISTEN      1000       4186947    2228911/io.simple-a
        tcp6       0      0 :::8088                 :::*                    LISTEN      1000       4188960    2229778/io.terminal
        tcp6       0      0 ::1:25                  :::*                    LISTEN      0          17440      800/exim4
        udp        0      0 0.0.0.0:631             0.0.0.0:*                           0          5974812    3206193/cups-browse
        udp        0      0 192.168.1.16:5353       0.0.0.0:*                           1000       4183783    2227659/io.tr-064.0
        udp        0      0 0.0.0.0:5353            0.0.0.0:*                           112        1609       419/avahi-daemon: r
        udp        0      0 0.0.0.0:1900            0.0.0.0:*                           1000       4192037    2230360/io.upnp.0
        udp        0      0 0.0.0.0:59503           0.0.0.0:*                           112        1611       419/avahi-daemon: r
        udp        0      0 0.0.0.0:43465           0.0.0.0:*                           1000       4191823    2230360/io.upnp.0
        udp        0      0 0.0.0.0:111             0.0.0.0:*                           0          619        1/init
        udp        0      0 192.168.1.255:137       0.0.0.0:*                           0          18480      538/nmbd
        udp        0      0 192.168.1.16:137        0.0.0.0:*                           0          18479      538/nmbd
        udp        0      0 0.0.0.0:137             0.0.0.0:*                           0          18460      538/nmbd
        udp        0      0 192.168.1.255:138       0.0.0.0:*                           0          18482      538/nmbd
        udp        0      0 192.168.1.16:138        0.0.0.0:*                           0          18481      538/nmbd
        udp        0      0 0.0.0.0:138             0.0.0.0:*                           0          18461      538/nmbd
        udp        0      0 0.0.0.0:53421           0.0.0.0:*                           1000       4182654    2227588/io.mihome-v
        udp6       0      0 fe80::ca9c:dcff:fee:546 :::*                                0          16340      422/NetworkManager
        udp6       0      0 :::5353                 :::*                                112        1610       419/avahi-daemon: r
        udp6       0      0 :::59025                :::*                                112        1612       419/avahi-daemon: r
        udp6       0      0 :::111                  :::*                                0          625        1/init
        2024-01-05 10:40:01.281  - info: dwd.0 (340585) starting. Version 2.8.5 in /opt/iobroker/node_modules/iobroker.dwd, node: v18.19.0, js-controller: 4.0.24
        2024-01-05 10:40:02.367  - info: dwd.0 (340585) Terminated (ADAPTER_REQUESTED_TERMINATION): Without reason
        2024-01-05 10:40:02.890  - info: host.debian instance system.adapter.dwd.0 terminated with code 11 (ADAPTER_REQUESTED_TERMINATION)
        2024-01-05 10:40:38.193  - error: lg-thinq.0 (2230962) Failed to get home
        2024-01-05 10:40:38.194  - error: lg-thinq.0 (2230962) AxiosError: Request failed with status code 400
        2024-01-05 10:40:38.194  - error: lg-thinq.0 (2230962) {"resultCode":"0102","result":""}
        2024-01-05 10:40:38.194  - info: lg-thinq.0 (2230962) Try to refresh Token
        2024-01-05 10:41:38.203  - error: lg-thinq.0 (2230962) Failed to get home
        2024-01-05 10:41:38.203  - error: lg-thinq.0 (2230962) AxiosError: Request failed with status code 400
        2024-01-05 10:41:38.203  - error: lg-thinq.0 (2230962) {"resultCode":"0102","result":""}
        2024-01-05 10:41:38.203  - info: lg-thinq.0 (2230962) Try to refresh Token
        2024-01-05 10:42:38.190  - error: lg-thinq.0 (2230962) Failed to get home
        2024-01-05 10:42:38.191  - error: lg-thinq.0 (2230962) AxiosError: Request failed with status code 400
        2024-01-05 10:42:38.191  - error: lg-thinq.0 (2230962) {"resultCode":"0102","result":""}
        2024-01-05 10:42:38.191  - info: lg-thinq.0 (2230962) Try to refresh Token
        2024-01-05 10:43:38.187  - error: lg-thinq.0 (2230962) Failed to get home
        2024-01-05 10:43:38.187  - error: lg-thinq.0 (2230962) AxiosError: Request failed with status code 400
        2024-01-05 10:43:38.188  - error: lg-thinq.0 (2230962) {"resultCode":"0102","result":""}
        2024-01-05 10:43:38.188  - info: lg-thinq.0 (2230962) Try to refresh Token
        2024-01-05 10:44:38.236  - error: lg-thinq.0 (2230962) Failed to get home
        2024-01-05 10:44:38.237  - error: lg-thinq.0 (2230962) AxiosError: Request failed with status code 400
        2024-01-05 10:44:38.237  - error: lg-thinq.0 (2230962) {"resultCode":"0102","result":""}
        2024-01-05 10:44:38.237  - info: lg-thinq.0 (2230962) Try to refresh Token
        2024-01-05 10:44:52.527  - info: admin.0 (2227376) failed connection to socket.io from ::ffff:192.168.1.201: Passport was not initialized
        2024-01-05 10:45:00.026  - info: host.debian instance system.adapter.dwd.0 started with pid 352969
        Slave:
        Skript v.2023-10-10
        *** BASE SYSTEM ***
           Static hostname: raspberrypi
                 Icon name: computer
                    Kernel: Linux 6.1.21-v8+
              Architecture: arm64
        Model           : Raspberry Pi 3 Model B Rev 1.2
        Docker          : false
        Kernel          : aarch64
        Userland        : arm64
         10:39:38 up 23:36,  1 user,  load average: 2.82, 1.21, 0.63
        CPU threads: 4
        *** RASPBERRY THROTTLING ***
        Current issues:
        Previously detected issues:
                       Local time: Fri 2024-01-05 10:39:38 CET
                   Universal time: Fri 2024-01-05 09:39:38 UTC
                         RTC time: n/a
                      NTP service: active
                  RTC in local TZ: no
        pi
        /home/pi
        pi adm dialout cdrom sudo audio video plugdev games users input render netdev gpio i2c spi iobroker
        X-Server:       false
        Desktop:
        Terminal:       tty
        Boot Target:    multi-user.target
        *** MEMORY ***
        Mem:            909M        527M         89M        0.0K        293M        319M
        Swap:            99M         38M         61M
        Total:          1.0G        565M        151M
                  909 M total memory
                  527 M used memory
                  438 M active memory
                  284 M inactive memory
                   89 M free memory
                    1 M buffer memory
                  291 M swap cache
                   99 M total swap
                   38 M used swap
                   61 M free swap
        Raspberry only:
        oom events: 0
        *** FILESYSTEM ***
        /dev/root      ext4       59G   32G   25G  57% /
        devtmpfs       devtmpfs  325M     0  325M   0% /dev
        tmpfs          tmpfs     455M     0  455M   0% /dev/shm
        tmpfs          tmpfs     182M  996K  181M   1% /run
        /dev/mmcblk0p1 vfat      255M   31M  225M  13% /boot
        tmpfs          tmpfs      91M     0   91M   0% /run/user/1000
        [Thu Jan  4 11:03:22 2024] Kernel command line: coherent_pool=1M 8250.nr_uarts=0 snd_bcm2835.enable_headphones=0 snd_bcm2835.enable_headphones=1 snd_bcm2835.enable_hdmi=1 snd_bcm2835.enable_hdmi=0 video=Composite-1:720x480@60i vc_mem.mem_base=0x3ec00000 vc_mem.mem_size=0x40000000  console=ttyS0,115200 console=tty1 root=PARTUUID=d3cf0315-02 rootfstype=ext4 fsck.repair=yes rootwait
        [Thu Jan  4 11:03:25 2024] EXT4-fs (mmcblk0p2): mounted filesystem with ordered data mode. Quota mode: none.
        [Thu Jan  4 11:03:25 2024] VFS: Mounted root (ext4 filesystem) readonly on device 179:2.
        [Thu Jan  4 11:03:29 2024] EXT4-fs (mmcblk0p2): re-mounted. Quota mode: none.
        /       /dev/mmcblk0p2 ext4   rw,noatime
        `-/boot /dev/mmcblk0p1 vfat   rw,relatime,fmask=0022,dmask=0022,codepage=437,iocharset=ascii,shortname=mixed,errors=remount-ro
        /var:
        27G     /var/
        22G     /var/lib/mysql/iobroker
        22G     /var/lib/mysql
        22G     /var/lib
        4.5G    /var/log
        Archived and active journals take up 4.0G in the file system.
        4.0K    /opt/iobroker/backups/
        18M     /opt/iobroker/iobroker-data/
        14M     /opt/iobroker/iobroker-data/files
        13M     /opt/iobroker/iobroker-data/files/admin.admin/custom/static/js
        6.3M    /opt/iobroker/iobroker-data/files/admin.admin/custom/static/js/vendors-node_modules_iobroker_adapter-react-v5_assets_devices_parseNames_js-node_modules_iobr-99c23e.847b8ad9.chunk.js.map
        3.0M    /opt/iobroker/iobroker-data/objects.jsonl
        2.8M    /opt/iobroker/iobroker-data/files/admin.admin/custom/static/js/vendors-node_modules_iobroker_adapter-react-v5_assets_devices_parseNames_js-node_modules_iobr-99c23e.847b8ad9.chunk.js
        1.6M    /opt/iobroker/iobroker-data/files/admin.admin/custom/static/js/vendors-node_modules_mui_material_Accordion_index_js-node_modules_mui_material_AccordionDetai-57e02d.0886b730.chunk.js.map
        652K    /opt/iobroker/iobroker-data/files/admin.admin/custom/static/js/vendors-node_modules_mui_material_index_js.40e01f69.chunk.js.map
        USB-Devices by-id:
        /dev/serial/by-id/usb-1a86_USB_Serial-if00-port0
        /usr/bin/npm            10.2.3
        /usr/bin/npx            10.2.3
        nodejs:
          Version table:
                500 http://deb.debian.org/debian bullseye/main arm64 Packages
                500 http://security.debian.org/debian-security bullseye-security/main arm64 Packages
        Errors in npm tree:
        ioBroker Status
        At least one iobroker host is running.
        Objects type: jsonl
        States  type: jsonl
        admin:          6.12.0
        javascript:     "javascript" not found
        Adapters from github:   0
        Adapter State
        + instance is alive
        Adapter    "enigma2"      : 2.0.5    , installed 2.0.5
        Adapter    "unifi"        : 0.6.7    , installed 0.6.7
        Adapter    "zigbee"       : 1.9.5    , installed 1.8.23 [Updatable]
        Objects and States
        Objects:        27977
        States:         22607
        Hit:1 http://security.debian.org/debian-security bullseye-security InRelease
        Hit:2 http://deb.debian.org/debian bullseye InRelease
        Hit:3 http://deb.debian.org/debian bullseye-updates InRelease
        Hit:4 http://archive.raspberrypi.org/debian bullseye InRelease
        Hit:5 https://deb.nodesource.com/node_18.x nodistro InRelease
        Pending Updates: 0
        tcp        0      0 0.0.0.0:22              0.0.0.0:*               LISTEN      0          12641      525/sshd: /usr/sbin
        tcp6       0      0 :::3306                 :::*                    LISTEN      110        12676      569/mariadbd
        tcp6       0      0 :::22                   :::*                    LISTEN      0          12643      525/sshd: /usr/sbin
        udp        0      0 0.0.0.0:68              0.0.0.0:*                           0          13987      780/dhcpcd
        udp        0      0 0.0.0.0:5353            0.0.0.0:*                           108        13921      394/avahi-daemon: r
        udp        0      0 0.0.0.0:58656           0.0.0.0:*                           108        13923      394/avahi-daemon: r
        udp6       0      0 :::41470                :::*                                108        13924      394/avahi-daemon: r
        udp6       0      0 :::546                  :::*                                0          13999      780/dhcpcd
        udp6       0      0 :::5353                 :::*                                108        13922      394/avahi-daemon: r
        2024-01-05 01:00:45.882  - warn: zigbee.0 (29251) Device '0x00158d00069b00d3' announced itself
        2024-01-05 01:20:14.792  - info: host.raspberrypi Delete log file iobroker.2023-12-28.log.gz
        2024-01-05 07:17:30.301  - error: zigbee.0 (29251) No converter available for 'AC03641' with key 'available'
          @djsirius sagte in Diskussion zum HowTo nodejs-Installation und upgrade:
          Nebenbei gesehen:
          Der CIFS der Fritzboxen spricht vers=3.1.1 und muss mit der Option 'noserverino' gemountet werden.
          Setz den User in die Gruppe 'adm' rein.
          Installier die beiden Adapter auf dem Master nochmal, zur Not 'über die Katze':
          Trag beim zigbee-Adapter statt
          port: /dev/ttyUSB0
          besser
          ein. (Wenn das denn der zigbee-USB-Stick ist.
            npm ERR! invalid: iobroker.openligadb@1.3.4 /opt/iobroker/node_modules/iobroker.openligadb npm ERR! invalid: iobroker.tibberconnect@0.0.10 /opt/iobroker/node_modules/iobroker.tibberconnect
            Das ist ja das Problem, ich kann keine Adapter installieren und auch keine Adapter updaten und keine Adapter löschen. 😞
            Die anderen beiden Sachen schaue ich mir sofort an. Vielen Dank für Deine Mühe!!!
              Per git url muss das gehen.
                @thomas-braun Leider nicht!
                  Leider nicht!
                  Meldungen?
                    djsirius @Thomas Braun last edited by djsirius
                    @thomas-braun Es gibt keine Meldung, weil er beim Installieren immer stehen bleibt.
                      ich tippe immer noch auf ipv6 Thematik bei npm
                        In einer Konsole den Installationsbefehl per git url (genaue Syntax habe ich gerade nicht parat, kannste aber aus dem entsprechenden Admin-Fenster entnehmen) eingeben.
                          Sorry, aber damit kenne ich mich überhaupt nicht aus.
                          Ich habe jetzt
                          iobroker url https://github.com/oweitman/ioBroker.openligadb --host debian --debug
                          Über git bekomme ich es nicht hin, weil ich den Befehl nicht kenne.
                          Ist und bleibt aber das selbe Problem.
                          Was gibt es denn da genau für ein Problem mit ipv6?
                          Vielen Dank!
                            djsirius @djsirius last edited by
                            Moin,
                            ich habe jetzt aus lauter Verzweiflung Nodejs nochmal neu installiert. Auf meinem Master ist alles OK.
                            Auf meinem Slave bekomme ich immer eine Meldung, wenn ich den iob fix drüber laufen lasse.
                                Database maintenance (4/5)
                            Checking for uncompressed JSONL databases... This might take a while!
                            npm ERR! code ETIMEDOUT
                            npm ERR! syscall connect
                            npm ERR! errno ETIMEDOUT
                            npm ERR! network request to https://registry.npmjs.org/@iobroker%2fjsonltool failed, reason: connect ETIMEDOUT 2606:4700::6810:1a22:443
                            npm ERR! network This is a problem related to network connectivity.
                            npm ERR! network In most cases you are behind a proxy or have bad network settings.
                            npm ERR! network
                            npm ERR! network If you are behind a proxy, please make sure that the
                            npm ERR! network 'proxy' config is set properly.  See: 'npm help config'
                            npm ERR! A complete log of this run can be found in: /home/iobroker/.npm/_logs/2024-01-08T08_12_15_007Z-debug-0.log
                            iob diag:
                            Skript v.2023-10-10
                            *** BASE SYSTEM ***
                                     Icon name: computer
                                  Architecture: arm64
                            Docker          : false
                            Kernel          : aarch64
                            Userland        : arm64
                             09:20:56 up 3 days, 22:17,  1 user,  load average: 0.25, 0.45, 0.80
                            CPU threads: 4
                            Current issues:
                                           Local time: Mon 2024-01-08 09:20:56 CET
                                       Universal time: Mon 2024-01-08 08:20:56 UTC
                                             RTC time: n/a
                                          NTP service: active
                                      RTC in local TZ: no
                            pi
                            /home/pi
                            X-Server:       false
                            Desktop:
                            Terminal:       tty
                            *** MEMORY ***
                            Mem:            909M        212M        138M        0.0K        558M        632M
                            Swap:            99M         78M         21M
                            Total:          1.0G        290M        160M
                                      909 M total memory
                                      212 M used memory
                                      238 M active memory
                                      396 M inactive memory
                                      138 M free memory
                                       39 M buffer memory
                                      518 M swap cache
                                       99 M total swap
                                       78 M used swap
                                       21 M free swap
                            Raspberry only:
                            oom events: 0
                              UNIT             LOAD   ACTIVE SUB    DESCRIPTION
                            * iobroker.service loaded failed failed ioBroker Server
                            LOAD   = Reflects whether the unit definition was properly loaded.
                            ACTIVE = The high-level unit activation state, i.e. generalization of SUB.
                            SUB    = The low-level unit activation state, values depend on unit type.
                            1 loaded units listed.
                            *** FILESYSTEM ***
                            /dev/root      ext4       59G   32G   25G  56% /
                            tmpfs          tmpfs     182M 1008K  181M   1% /run
                            tmpfs          tmpfs      91M     0   91M   0% /run/user/0
                            /var:
                            27G     /var/
                            22G     /var/lib/mysql
                            22G     /var/lib
                            4.2G    /var/log
                            Archived and active journals take up 3.9G in the file system.
                            USB-Devices by-id:
                            /usr/bin/npm            10.2.3
                            /usr/bin/npx            10.2.3
                            nodejs:
                              Version table:
                             *** 18.19.0-1nodesource1 1001
                                 18.18.2-1nodesource1 1001
                                 18.18.1-1nodesource1 1001
                                 18.18.0-1nodesource1 1001
                                 18.17.1-1nodesource1 1001
                                 18.17.0-1nodesource1 1001
                                 18.16.1-1nodesource1 1001
                                 18.16.0-1nodesource1 1001
                                 18.15.0-1nodesource1 1001
                                 18.14.2-1nodesource1 1001
                                 18.14.1-1nodesource1 1001
                                 18.14.0-1nodesource1 1001
                                 18.13.0-1nodesource1 1001
                                 18.12.0-1nodesource1 1001
                                 18.11.0-1nodesource1 1001
                                 18.10.0-1nodesource1 1001
                                 18.9.1-1nodesource1 1001
                                 18.9.0-1nodesource1 1001
                                 18.8.0-1nodesource1 1001
                                 18.7.0-1nodesource1 1001
                                 18.6.0-1nodesource1 1001
                                 18.5.0-1nodesource1 1001
                                 18.4.0-1nodesource1 1001
                                 18.3.0-1nodesource1 1001
                                 18.2.0-1nodesource1 1001
                                 18.1.0-1nodesource1 1001
                                 18.0.0-1nodesource1 1001
                            Errors in npm tree:
                            ioBroker Status
                            iobroker is not running on this host.
                            Objects type: jsonl
                            States  type: jsonl
                            admin:          6.12.0
                            Adapter State
                            + instance is alive
                            Adapter    "zigbee"       : 1.9.7    , installed 1.8.23 [Updatable]
                            Objects and States
                            Objects:        28092
                            States:         22715
                            Pending Updates: 0
                            2024-01-08 09:11:19.565  - info: zigbee.0 (765235) debug devices set to []
                            2024-01-08 09:11:27.300  - info: host.raspberrypi received SIGTERM
                            2024-01-08 09:11:27.306  - info: zigbee.0 (765235) cleaned everything up...
                            2024-01-08 09:11:27.324  - info: rpi2.1 (765173) Terminated (START_IMMEDIATELY_AFTER_STOP): Without reason
                            2024-01-08 09:11:27.312  - info: host.raspberrypi stopInstance system.adapter.rpi2.1 (force=false, process=true)
                            2024-01-08 09:11:27.314  - info: host.raspberrypi stopInstance system.adapter.zigbee.0 (force=false, process=true)
                            2024-01-08 09:11:27.316  - info: host.raspberrypi stopInstance system.adapter.enigma2.0 (force=false, process=true)
                            2024-01-08 09:11:27.337  - info: rpi2.1 (765173) Got terminate signal TERMINATE_YOURSELF
                            2024-01-08 09:11:27.336  - info: enigma2.0 (765291) Got terminate signal TERMINATE_YOURSELF
                            2024-01-08 09:11:27.379  - info: host.raspberrypi stopInstance system.adapter.rpi2.1 send kill signal
                            2024-01-08 09:11:27.384  - info: host.raspberrypi stopInstance system.adapter.zigbee.0 send kill signal
                            2024-01-08 09:11:27.386  - info: host.raspberrypi stopInstance system.adapter.enigma2.0 send kill signal
                            2024-01-08 09:11:27.619  - info: zigbee.0 (765235) Zigbee: disabling joining new devices.
                            2024-01-08 09:11:27.670  - info: zigbee.0 (765235) Got terminate signal TERMINATE_YOURSELF
                            2024-01-08 09:11:27.834  - info: enigma2.0 (765291) Terminated (START_IMMEDIATELY_AFTER_STOP): Without reason
                            2024-01-08 09:11:27.879  - info: zigbee.0 (765235) Terminated (START_IMMEDIATELY_AFTER_STOP): Without reason
                            2024-01-08 09:11:28.310  - info: host.raspberrypi instance system.adapter.rpi2.1 terminated with code 156 (START_IMMEDIATELY_AFTER_STOP)
                            2024-01-08 09:11:28.387  - info: host.raspberrypi stopInstance system.adapter.zigbee.0 killing pid 765235
                            2024-01-08 09:11:28.389  - info: host.raspberrypi stopInstance system.adapter.enigma2.0 killing pid 765291
                            2024-01-08 09:11:28.834  - info: host.raspberrypi instance system.adapter.enigma2.0 terminated with code 156 (START_IMMEDIATELY_AFTER_STOP)
                            2024-01-08 09:11:28.836  - info: host.raspberrypi All instances are stopped.
                            2024-01-08 09:11:29.178  - warn: host.raspberrypi instance system.adapter.zigbee.0 terminated due to SIGTERM
                            2024-01-08 09:11:29.180  - info: host.raspberrypi instance system.adapter.zigbee.0 terminated with code null ()
                            2024-01-08 09:11:29.181  - info: host.raspberrypi All instances are stopped.
                            2024-01-08 09:11:29.271  - info: host.raspberrypi terminated
                            Vielen Dank!
                              Thomas Braun Most Active @djsirius last edited by Thomas Braun
                              npm ERR! network request to https://registry.npmjs.org/@iobroker%2Fjsonltool failed, reason: connect ETIMEDOUT 2606:4700::6810:1a22:443
                              Schau mal nach, ob dein Router / Internet-Provider zur Gänze auf IPv6 umgestellt ist.
                              Z. B. in der FritzBox muss zum einen IPv6 grundsätzlich angehakt sein, aber auch das Routing nach draußen muss auf IPv6 gestellt werden.
                                macht das Sinn, weil das Master System diesen Fehler nicht hat. Die laufen ja beide über den selben Router.
                                Ist IPv6 ist aber auch angehakt.
                                  Ich habe jetzt ein Downgrade von Nodejs gemacht, weil ich nicht weiter komme.
                                  Wenn noch jemand eine Idee hat, bitte her damit. Ich bin ratlos! 😞
                                  Thomas Braun Marc Berg 2 Replies Last reply Reply Quote 0
                                    @djsirius
                                    Ist zu 99,9% etwas in deinem Netzwerk.
                                    • Marc Berg
                                      Marc Berg Most Active @djsirius last edited by Marc Berg
                                      mach mal auf master und slave jeweils:
                                      ping registry.npmjs.org
                                      ping -4 registry.npmjs.org
                                      ping -6 registry.npmjs.org
                                      Thomas Braun D 3 Replies Last reply Reply Quote 0
                                        Thomas Braun Most Active @Marc Berg last edited by
                                        @marc-berg
                                        Haste gerade die traceroute commandos für IPv6 und IPv4 parat?
                                          djsirius @Marc Berg last edited by
                                          @marc-berg said in Diskussion zum HowTo nodejs-Installation und upgrade:
                                          ping registry.npmjs.org <- geht auf beiden nicht
                                          ping -4 registry.npmjs.org <- geht auf beiden
                                          ping -6 registry.npmjs.org <- geht auf beiden nicht
                                          • Marc Berg
                                            Marc Berg Most Active @Thomas Braun last edited by
                                            @thomas-braun sagte in Diskussion zum HowTo nodejs-Installation und upgrade:
                                            traceroute6  heise.de
                                            traceroute  heise.de
                                            81.1k
                                            nodejs
                                            91
                                            844
                                            228564
