    4. Probleme mit Zigbee Adapter 1.9.5
      Thomas Braun Most Active @Jens G. last edited by
      @jens-g
      In der Zusammenfassung nicht viel.
      iob nodejs-update
      bitte ausführen. Und dann die Langfassung bekannt machen.
      • Jens G.
        Jens G. @Jens G. last edited by
        Skript v.2023-10-10
        *** BASE SYSTEM ***
           Static hostname: smarthomepi
                 Icon name: computer
          Operating System: Raspbian GNU/Linux 11 (bullseye)
                    Kernel: Linux 5.10.103-v7l+
              Architecture: arm
        Model           : Raspberry Pi 4 Model B Rev 1.4
        Docker          : false
        Virtualization  : none
        Kernel          : armv7l
        Userland        : armhf
        Systemuptime and Load:
         16:14:37 up  4:22,  1 user,  load average: 0.27, 0.13, 0.13
        CPU threads: 4
        *** RASPBERRY THROTTLING ***
        Current issues:
        Previously detected issues:
        *** Time and Time Zones ***
                       Local time: Fri 2024-01-05 16:14:37 CET
                   Universal time: Fri 2024-01-05 15:14:37 UTC
                         RTC time: n/a
                      NTP service: active
                  RTC in local TZ: no
        *** User and Groups ***
        pi
        /home/pi
        pi adm dialout cdrom sudo audio video plugdev games users input netdev gpio i2c spi iobroker
        *** X-Server-Setup ***
        X-Server:       false
        Desktop:
        Terminal:       tty
        *** MEMORY ***
        Mem:            3.8G        763M        2.5G        0.0K        606M        3.0G
        Swap:            99M          0B         99M
        Total:          3.9G        763M        2.6G
                 3838 M total memory
                  763 M used memory
                  284 M active memory
                  998 M inactive memory
                 2468 M free memory
                   81 M buffer memory
                  525 M swap cache
                   99 M total swap
                    0 M used swap
                   99 M free swap
        Raspberry only:
        oom events: 0
        *** FAILED SERVICES ***
        0 loaded units listed.
        *** FILESYSTEM ***
        /dev/root      ext4       29G  8.6G   20G  31% /
        devtmpfs       devtmpfs  1.8G     0  1.8G   0% /dev
        tmpfs          tmpfs     1.9G     0  1.9G   0% /dev/shm
        tmpfs          tmpfs     768M  712K  768M   1% /run
        /dev/mmcblk0p1 vfat      253M   49M  204M  20% /boot
        tmpfs          tmpfs     384M     0  384M   0% /run/user/1000
        [Fri Jan  5 11:51:47 2024] Kernel command line: coherent_pool=1M 8250.nr_uarts=0 snd_bcm2835.enable_compat_alsa=0 snd_bcm2835.enable_hdmi=1  smsc95xx.macaddr=E4:5F:01:2B:81:55 vc_mem.mem_base=0x3ec00000 vc_mem.mem_size=0x40000000  console=ttyS0,115200 console=tty1 root=PARTUUID=fb4b5961-02 rootfstype=ext4 elevator=deadline fsck.repair=yes rootwait
        [Fri Jan  5 11:51:48 2024] EXT4-fs (mmcblk0p2): mounted filesystem with ordered data mode. Opts: (null)
        [Fri Jan  5 11:51:48 2024] VFS: Mounted root (ext4 filesystem) readonly on device 179:2.
        [Fri Jan  5 11:51:51 2024] EXT4-fs (mmcblk0p2): re-mounted. Opts: (null)
        TARGET  SOURCE         FSTYPE OPTIONS
        /       /dev/mmcblk0p2 ext4   rw,noatime
        `-/boot /dev/mmcblk0p1 vfat   rw,relatime,fmask=0022,dmask=0022,codepage=437,iocharset=ascii,shortname=mixed,errors=remount-ro
        /var:
        3.2G    /var/
        1.6G    /var/cache/apt
        1.6G    /var/cache
        1.5G    /var/cache/apt/archives
        1.4G    /var/log/journal/47f40db81a924d0ea15f089479b9a154
        Archived and active journals take up 1.3G in the file system.
        /opt/iobroker/backups:
        56M     /opt/iobroker/backups/
        /opt/iobroker/iobroker-data:
        304M    /opt/iobroker/iobroker-data/
        199M    /opt/iobroker/iobroker-data/files
        71M     /opt/iobroker/iobroker-data/backup-objects
        67M     /opt/iobroker/iobroker-data/files/javascript.admin
        48M     /opt/iobroker/iobroker-data/files/javascript.admin/static
        21M     /opt/iobroker/iobroker-data/files/web.admin/static/js/main.aaea95f8.js.map
        17M     /opt/iobroker/iobroker-data/objects.jsonl
        14M     /opt/iobroker/iobroker-data/files/iqontrol.meta/userimages/userwidgets/abfallkalender_2023 (1)-cropped (1).html
        8.9M    /opt/iobroker/iobroker-data/files/scenes.admin/static/js/2.7de3299d.chunk.js.map
        8.3M    /opt/iobroker/iobroker-data/files/web.admin/static/js/main.aaea95f8.js
        USB-Devices by-id:
        *** NodeJS-Installation ***
        /usr/bin/nodejs         v18.17.1
        /usr/bin/node           v18.17.1
        /usr/bin/npm            9.6.7
        /usr/bin/npx            9.6.7
        /usr/bin/corepack       0.18.0
        nodejs:
          Installed: 18.17.1-deb-1nodesource1
          Candidate: 18.17.1-deb-1nodesource1
          Version table:
         *** 18.17.1-deb-1nodesource1 500
                500 https://deb.nodesource.com/node_18.x bullseye/main armhf Packages
                100 /var/lib/dpkg/status
             12.22.12~dfsg-1~deb11u4 500
                500 http://raspbian.raspberrypi.org/raspbian bullseye/main armhf Packages
        No problems detected
        Errors in npm tree:
        *** ioBroker-Installation ***
        ioBroker Status
        Objects type: jsonl
        States  type: jsonl
        Core adapters versions
        js-controller:  5.0.16
        admin:          6.12.0
        javascript:     7.1.6
        Adapters from github:   0
        Adapter State
        + system.adapter.admin.0                  : admin                 : smarthomepi                              -  enabled, port: 8081, bind: 0.0.0.0, run as: admin
        + system.adapter.backitup.0               : backitup              : smarthomepi                              -  enabled
        + system.adapter.daswetter.0              : daswetter             : smarthomepi                              -  enabled
        + system.adapter.discovery.0              : discovery             : smarthomepi                              -  enabled
        + system.adapter.dwd.0                    : dwd                   : smarthomepi                              -  enabled
        + system.adapter.influxdb.0               : influxdb              : smarthomepi                              -  enabled, port: 8086
        + system.adapter.info.0                   : info                  : smarthomepi                              -  enabled
        + system.adapter.iqontrol.0               : iqontrol              : smarthomepi                              -  enabled
        + system.adapter.javascript.0             : javascript            : smarthomepi                              -  enabled
        + system.adapter.maxcul.0                 : maxcul                : smarthomepi                              -  enabled
        + system.adapter.mqtt.0                   : mqtt                  : smarthomepi                              -  enabled, port: 1886, bind: 0.0.0.0
          system.adapter.scenes.0                 : scenes                : smarthomepi                              - disabled
        + system.adapter.sonoff.0                 : sonoff                : smarthomepi                              -  enabled, port: 1883, bind: 192.168.188.159
        + system.adapter.tankerkoenig.0           : tankerkoenig          : smarthomepi                              -  enabled
          system.adapter.terminal.0               : terminal              : smarthomepi                              - disabled, port: 8099, bind: 0.0.0.0, run as: admin
        + system.adapter.web.0                    : web                   : smarthomepi                              -  enabled, port: 8085, bind: 0.0.0.0, run as: admin
        + system.adapter.zigbee.0                 : zigbee                : smarthomepi                              -  enabled, port: /dev/ttyUSB1
        + instance is alive
        ioBroker-Repositories
        stable        : http://repo.iobroker.live/sources-dist.json
        Active repo(s): stable
        Installed ioBroker-Instances
        Used repository: stable
        Adapter    "admin"        : 6.12.0   , installed 6.12.0
        Adapter    "backitup"     : 2.9.8    , installed 2.9.8
        Adapter    "daswetter"    : 3.1.11   , installed 3.1.11
        Adapter    "influxdb"     : 3.2.0    , installed 3.2.0
        Adapter    "iqontrol"     : 2.3.0    , installed 2.3.0
        Adapter    "javascript"   : 7.1.6    , installed 7.1.6
        Controller "js-controller": 5.0.17   , installed 5.0.16 [Updatable]
        Adapter    "maxcul"       : 1.3.1    , installed 1.3.1
        Adapter    "mqtt"         : 5.1.0    , installed 5.1.0
        Adapter    "sonoff"       : 3.0.3    , installed 3.0.3
        Adapter    "terminal"     : 1.0.0    , installed 1.0.0
        Adapter    "web"          : 6.1.10   , installed 6.1.10
        Adapter    "ws"           : 2.5.8    , installed 2.5.8
        Adapter    "zigbee"       : 1.9.5    , installed 1.9.5
        Objects and States
        Objects:        4729
        States:         1683
        Hit:1 http://raspbian.raspberrypi.org/raspbian bullseye InRelease
        Hit:2 http://archive.raspberrypi.org/debian buster InRelease
        Get:3 https://deb.nodesource.com/node_18.x bullseye InRelease [4586 B]
        Fetched 4586 B in 6s (711 B/s)
        Reading package lists...
        Pending Updates: 0
        *** Listening Ports ***
        tcp        0      0 0.0.0.0:22              0.0.0.0:*               LISTEN      0          10819      773/sshd: /usr/sbin
        tcp        0      0 127.0.0.1:8088          0.0.0.0:*               LISTEN      999        10711      451/influxd
        tcp        0      0 192.168.188.159:1883    0.0.0.0:*               LISTEN      1001       12273      940/io.sonoff.0
        tcp        0      0 0.0.0.0:1886            0.0.0.0:*               LISTEN      1001       10984      959/io.mqtt.0
        tcp        0      0 0.0.0.0:1887            0.0.0.0:*               LISTEN      1001       10985      959/io.mqtt.0
        tcp        0      0 127.0.0.1:9000          0.0.0.0:*               LISTEN      1001       12070      766/iobroker.js-con
        tcp        0      0 127.0.0.1:9001          0.0.0.0:*               LISTEN      1001       12055      766/iobroker.js-con
        tcp6       0      0 :::8081                 :::*                    LISTEN      1001       13828      853/io.admin.0
        tcp6       0      0 :::8085                 :::*                    LISTEN      1001       17691      1573/io.web.0
        tcp6       0      0 :::22                   :::*                    LISTEN      0          10821      773/sshd: /usr/sbin
        tcp6       0      0 :::8086                 :::*                    LISTEN      999        11968      451/influxd
        udp        0      0 0.0.0.0:42406           0.0.0.0:*                           108        11826      402/avahi-daemon: r
        udp        0      0 0.0.0.0:68              0.0.0.0:*                           0          13695      765/dhcpcd
        udp        0      0 0.0.0.0:5353            0.0.0.0:*                           108        11824      402/avahi-daemon: r
        udp6       0      0 :::546                  :::*                                0          10763      765/dhcpcd
        udp6       0      0 :::5353                 :::*                                108        11825      402/avahi-daemon: r
        udp6       0      0 :::53005                :::*                                108        11827      402/avahi-daemon: r
        2024-01-05 16:15:13.432  - debug: daswetter.0 (6914) insert NextDays.Location_1.Day_7.Maximale_Temperatur_value with 2
        2024-01-05 16:15:13.442  - debug: daswetter.0 (6914) insert NextDays.Location_1.Day_7.Wind_valueB with Mäßiger Wind aus Nordosten
        2024-01-05 16:15:13.454  - debug: daswetter.0 (6914) insert NextDays.Location_1.Day_7.Wind_value with Mäßiger Wind aus Nordosten
        2024-01-05 16:15:13.465  - debug: daswetter.0 (6914) insert NextDays.Location_1.Day_7.Wind_idB with 34
        2024-01-05 16:15:13.476  - debug: daswetter.0 (6914) insert NextDays.Location_1.Day_7.Wind_id with 10
        2024-01-05 16:15:13.485  - debug: daswetter.0 (6914) insert NextDays.Location_1.Day_7.windIconURL with /adapter/daswetter/icons/viento-wind/Beaufort-White/34.png
        2024-01-05 16:15:13.495  - debug: daswetter.0 (6914) insert NextDays.Location_1.Day_7.Wetter_Symbol_value2 with Teils bewölkt
        2024-01-05 16:15:13.505  - debug: daswetter.0 (6914) insert NextDays.Location_1.Day_7.Wetter_Symbol_value with Teils bewölkt
        2024-01-05 16:15:13.515  - debug: daswetter.0 (6914) insert NextDays.Location_1.Day_7.Wetter_Symbol_id2 with 2
        2024-01-05 16:15:13.531  - debug: daswetter.0 (6914) insert NextDays.Location_1.Day_7.Wetter_Symbol_id with 2
        2024-01-05 16:15:13.541  - debug: daswetter.0 (6914) insert NextDays.Location_1.Day_7.iconURL with /adapter/daswetter/icons/tiempo-weather/galeria5/SVG/Color/2.svg
        2024-01-05 16:15:13.556  - debug: daswetter.0 (6914) insert NextDays.Location_1.Day_7.Tag_value with Donnerstag
        2024-01-05 16:15:13.565  - debug: daswetter.0 (6914) insert NextDays.Location_1.Day_7.Wetterbedingungen_value with Den ganzen Tag über Sonne
        2024-01-05 16:15:13.575  - debug: daswetter.0 (6914) 7 days forecast done
        2024-01-05 16:15:13.581  - debug: daswetter.0 (6914) exit, all done
        2024-01-05 16:15:13.582  - debug: daswetter.0 (6914) timer killed
        2024-01-05 16:15:13.583  - debug: daswetter.0 (6914) Plugin sentry destroyed
        2024-01-05 16:15:13.584  - info: daswetter.0 (6914) Terminated (ADAPTER_REQUESTED_TERMINATION): All data handled, adapter stopped until next scheduled moment
        2024-01-05 16:15:14.116  - info: daswetter.0 (6914) cleaned everything up...
        2024-01-05 16:15:14.149  - info: host.smarthomepi instance system.adapter.daswetter.0 terminated with code 11 (ADAPTER_REQUESTED_TERMINATION)
        2024-01-05 16:15:14.377  - info: dwd.0 (6895) Terminated (ADAPTER_REQUESTED_TERMINATION): Without reason
        2024-01-05 16:15:14.980  - info: host.smarthomepi instance system.adapter.dwd.0 terminated with code 11 (ADAPTER_REQUESTED_TERMINATION)
        2024-01-05 16:15:17.406  - info: admin.0 (853) <== Disconnect system.user.admin from ::ffff:192.168.188.21
        2024-01-05 16:15:25.678  - info: admin.0 (853) ==> Connected system.user.admin from ::ffff:192.168.188.21
        2024-01-05 16:15:25.886  - info: zigbee.0 (3432) List of port: [{"path":"/dev/ttyUSB0","manufacturer":"SHK","serialNumber":"868","vendorId":"0403","productId":"6001"},{"path":"/dev/ttyUSB1","manufacturer":"ITead","serialNumber":"78c227e46ed8ed11ad85736162c613ac","vendorId":"10c4","productId":"ea60"},{"path":"/dev/ttyAMA0"}]
          @jens-g
          Zunächst solltest du doch
          iob nodejs-update
          ausführen...
          Jens G. 1 Reply Last reply Reply Quote 0
          • Jens G.
            Jens G. @Thomas Braun last edited by
            Sorry habe ich übersehern wird gerade gemacht auf Version 18.19
              Thomas Braun Most Active @Jens G. last edited by Thomas Braun
              @jens-g
              apt policy udev
              sagt? Da wirst du dir die defekte Version eingehandelt haben.
              Ich würde ohne hin von dem auslaufenden Bullseye-Release auf Debian 12 'Bookworm' (64Bit - Lite) wechseln. Das Thema wird ohnehin früher oder später auf dich zukommen. Kannste auch jetzt den Absprung machen.
              • Jens G.
                Skript v.2023-10-10
                *** BASE SYSTEM ***
                         Icon name: computer
                      Architecture: arm
                Docker          : false
                Kernel          : armv7l
                Userland        : armhf
                 16:26:27 up  4:34,  1 user,  load average: 1.92, 0.88, 0.47
                CPU threads: 4
                Current issues:
                               Local time: Fri 2024-01-05 16:26:27 CET
                           Universal time: Fri 2024-01-05 15:26:27 UTC
                                 RTC time: n/a
                              NTP service: active
                          RTC in local TZ: no
                pi
                /home/pi
                X-Server:       false
                Desktop:
                Terminal:       tty
                *** MEMORY ***
                Mem:            3.8G        794M        2.1G        0.0K        985M        2.9G
                Swap:            99M          0B         99M
                Total:          3.9G        794M        2.2G
                         3838 M total memory
                          794 M used memory
                          495 M active memory
                         1151 M inactive memory
                         2058 M free memory
                          238 M buffer memory
                          746 M swap cache
                           99 M total swap
                            0 M used swap
                           99 M free swap
                Raspberry only:
                oom events: 0
                *** FILESYSTEM ***
                /var:
                3.3G    /var/
                1.6G    /var/cache/apt
                1.6G    /var/cache
                USB-Devices by-id:
                /usr/bin/nodejs         v18.19.0
                /usr/bin/node           v18.19.0
                /usr/bin/npm            10.2.3
                /usr/bin/npx            10.2.3
                /usr/bin/corepack       0.22.0
                nodejs:
                  Installed: 18.19.0-1nodesource1
                  Candidate: 18.19.0-1nodesource1
                  Version table:
                 *** 18.19.0-1nodesource1 1001
                        500 https://deb.nodesource.com/node_18.x nodistro/main armhf Packages
                     18.18.2-1nodesource1 1001
                     18.18.1-1nodesource1 1001
                     18.18.0-1nodesource1 1001
                     18.17.1-1nodesource1 1001
                     18.17.0-1nodesource1 1001
                     18.16.1-1nodesource1 1001
                     18.16.0-1nodesource1 1001
                     18.15.0-1nodesource1 1001
                     18.14.2-1nodesource1 1001
                     18.14.1-1nodesource1 1001
                     18.14.0-1nodesource1 1001
                     18.13.0-1nodesource1 1001
                     18.12.0-1nodesource1 1001
                     18.11.0-1nodesource1 1001
                     18.10.0-1nodesource1 1001
                     18.9.1-1nodesource1 1001
                     18.9.0-1nodesource1 1001
                     18.8.0-1nodesource1 1001
                     18.7.0-1nodesource1 1001
                     18.6.0-1nodesource1 1001
                     18.5.0-1nodesource1 1001
                     18.4.0-1nodesource1 1001
                     18.3.0-1nodesource1 1001
                     18.2.0-1nodesource1 1001
                     18.1.0-1nodesource1 1001
                     18.0.0-1nodesource1 1001
                Errors in npm tree:
                ioBroker Status
                Objects type: jsonl
                States  type: jsonl
                admin:          6.12.0
                javascript:     7.1.6
                Adapter State
                + instance is alive
                Objects and States
                Objects:        4729
                States:         1691
                Hit:1 http://archive.raspberrypi.org/debian buster InRelease
                Hit:2 http://raspbian.raspberrypi.org/raspbian bullseye InRelease
                Hit:3 https://deb.nodesource.com/node_18.x nodistro InRelease
                Pending Updates: 0
                tcp        0      0 192.168.188.159:1883    0.0.0.0:*               LISTEN      1001       47485      8303/io.sonoff.0
                tcp        0      0 0.0.0.0:1886            0.0.0.0:*               LISTEN      1001       50214      8330/io.mqtt.0
                tcp        0      0 0.0.0.0:1887            0.0.0.0:*               LISTEN      1001       50215      8330/io.mqtt.0
                tcp        0      0 127.0.0.1:9000          0.0.0.0:*               LISTEN      1001       46977      8225/iobroker.js-co
                tcp        0      0 127.0.0.1:9001          0.0.0.0:*               LISTEN      1001       46970      8225/iobroker.js-co
                tcp6       0      0 :::8081                 :::*                    LISTEN      1001       46039      8246/io.admin.0
                tcp6       0      0 :::8085                 :::*                    LISTEN      1001       50942      9090/io.web.0
                2024-01-05 16:26:25.626  - info: host.smarthomepi instance system.adapter.maxcul.0 started with pid 8665
                2024-01-05 16:26:28.481  - info: dwd.0 (8427) Terminated (ADAPTER_REQUESTED_TERMINATION): Without reason
                2024-01-05 16:26:28.821  - info: maxcul.0 (8665) starting. Version 1.3.1 in /opt/iobroker/node_modules/iobroker.maxcul, node: v18.19.0, js-controller: 5.0.16
                2024-01-05 16:26:29.179  - info: host.smarthomepi instance system.adapter.dwd.0 terminated with code 11 (ADAPTER_REQUESTED_TERMINATION)
                2024-01-05 16:26:29.351  - info: maxcul.0 (8665) using serial device /dev/ttyUSB0@38400
                2024-01-05 16:26:29.392  - info: maxcul.0 (8665) serialPort /dev/ttyUSB0 is open!
                2024-01-05 16:26:29.709  - info: host.smarthomepi instance system.adapter.tankerkoenig.0 started with pid 9004
                2024-01-05 16:26:31.417  - info: maxcul.0 (8665) CUL FW Version: V 1.67 nanoCUL868
                2024-01-05 16:26:32.632  - info: tankerkoenig.0 (9004) starting. Version 3.3.7 in /opt/iobroker/node_modules/iobroker.tankerkoenig, node: v18.19.0, js-controller: 5.0.16
                2024-01-05 16:26:32.695  - info: tankerkoenig.0 (9004) Adapter is already in daemon mode
                2024-01-05 16:26:32.697  - warn: tankerkoenig.0 (9004) Sync time was too short (5). New sync time is 10 min
                2024-01-05 16:26:32.698  - info: tankerkoenig.0 (9004) Sync time set to 10 minutes or 600000 ms
                2024-01-05 16:26:33.708  - info: host.smarthomepi instance system.adapter.web.0 started with pid 9090
                2024-01-05 16:26:34.180  - warn: zigbee.0 (8318) DeviceAvailability:Failed to ping 0xa4c1384e05b39d11 TS011F
                2024-01-05 16:26:38.379  - info: web.0 (9090) starting. Version 6.1.10 in /opt/iobroker/node_modules/iobroker.web, node: v18.19.0, js-controller: 5.0.16
                2024-01-05 16:26:38.832  - info: web.0 (9090) socket.io server listening on port 8085
                2024-01-05 16:26:38.846  - info: web.0 (9090) http server listening on port 8085
                2024-01-05 16:26:39.942  - info: tankerkoenig.0 (9004) Start first request
                2024-01-05 16:26:44.375  - info: web.0 (9090) ==> Connected system.user.admin from ::ffff:192.168.188.162
                2024-01-05 16:27:38.077  - info: admin.0 (8246) <== Disconnect system.user.admin from ::ffff:192.168.188.21
                2024-01-05 16:27:38.085  - info: admin.0 (8246) <== Disconnect system.user.admin from ::ffff:192.168.188.21 admin
                2024-01-05 16:27:38.713  - info: admin.0 (8246) ==> Connected system.user.admin from ::ffff:192.168.188.21
                2024-01-05 16:27:41.881  - info: admin.0 (8246) ==> Connected system.user.admin from ::ffff:192.168.188.21
                2024-01-05 16:27:42.203  - info: zigbee.0 (8318) List of port: [{"path":"/dev/ttyUSB0","manufacturer":"SHK","serialNumber":"868","vendorId":"0403","productId":"6001"},{"path":"/dev/ttyUSB1","manufacturer":"ITead","serialNumber":"78c227e46ed8ed11ad85736162c613ac","vendorId":"10c4","productId":"ea60"},{"path":"/dev/ttyAMA0"}]
                2024-01-05 16:27:46.416  - info: admin.0 (8246) <== Disconnect system.user.admin from ::ffff:192.168.188.21
                So hier einmal die Langfassung nach nodejs Update.
                pi@smarthomepi:~ $ apt policy udev
                udev:
                  Installiert:           247.3-7+rpi1+deb11u2
                  Installationskandidat: 247.3-7+rpi1+deb11u2
                  Versionstabelle:
                 *** 247.3-7+rpi1+deb11u2 500
                  @jens-g sagte in Probleme mit Zigbee Adapter 1.9.5:
                  Das ist das defekte Paket.
                  Für dein 32Bit-OS gibt es da aber soweit ich weiß auch keinen Patch mehr.
                  Ich würde den Weg einer Neuinstallation von Bookworm 64Bit Lite gehen.
                  Meister Mopper Jens G. 2 Replies Last reply Reply Quote 1
                  • Meister Mopper
                    Meister Mopper @Thomas Braun last edited by
                    @thomas-braun sagte in Probleme mit Zigbee Adapter 1.9.5:
                    @jens-g
                    Ja, diesen Weg bin ich kürzlich auch erfolgreich gegangen.
                    • Jens G.
                      Ok bedeutet konkret Micro SD Karte raus und neu beschreiben mit Bookworm Lite oder gibts noch eine Möglichkeit über ssh auf Bookworm 64 bit zu upgraden. Backup ist vorhanden, sowohl von Zigbee als auch Iobroker allgemein
                        Nein. Neuinstallation.
                        • Jens G.
                          Jens G. @Thomas Braun last edited by Jens G.
                          In Ordnung, ist ja zum Glück morgen WE dann werde ich es mal probieren, danach sollte der Stick besser laufen, so ein Mist, das ich die defekte Version erwischt habe 😠 . Also einfach per Skript Iobroker installieren, dann BackitUP Adapter drauf und wiederherstellen. Danach Zigbee und schauen ob es klappt, dann gibts morgen den Zwischenstand.
                          Danke für eure Tipps, muss ich wohl doch mal auf Bookworm gehen.
                          PS: Muss ich dann Zigbee neu anlernen oder reicht Backup drauf bzw. wiederherstellen?
                          • Jens G.
                            Jens G. @Meister Mopper last edited by
                            @meister-mopper
                            Danke für deine Antwort irgendwelche Tipps noch oder einfach wie gehabt per Skript
                            • Meister Mopper
                              Meister Mopper @Jens G. last edited by
                              Ganz rudimentär ohne Schnickschnack. Selbst der Vis-Bug ist mittlerweile behoben.
                              • Jens G.
                                Jens G. @Meister Mopper last edited by Jens G.
                                @meister-mopper
                                Das sind ja gute Aussichten für den Samstag. Dann hoffe ich mal das es bei mir ebenso glatt läuft
                                • Jens G.
                                  So nun ist es geschafft und die Ausgabe von /dev/serial/by-id lautet:
                                  lrwxrwxrwx 1 root root 13 Jan  6 11:20 usb-ITead_Sonoff_Zigbee_3.0_USB_Dongle_Plus_78c227e46ed8ed11ad85736162c613ac-if00-port0 -> ../../ttyUSB0
                                  lrwxrwxrwx 1 root root 13 Jan  6 11:20 usb-SHK_NANO_CUL_868-if00-port0 -> ../../ttyUSB1
                                  habe den Zigbee teil schon direkt so eingetragen: /dev/serial/by-id/usb-ITead_Sonoff_Zigbee_3.0_USB_Dongle_Plus_78c227e46ed8ed11ad85736162c613ac-if00-port0
                                  Aber trotzdem noch kein Signal überall nur getrennt zigbee adapter nach upgrade.png siehe Bild
                                    @jens-g
                                    Log sagt?
                                    • Jens G.
                                      Im Log vom Iobroker steht immer Failed to ping für die Steckdose, obwohl diese eingeschaltet ist, das weiß ich denn dort hängt mein Homeserver dran. Bei den anderen Geräten liegts wahrscheinlich am Batterie Betrieb und nicht so oft senden
                                        @jens-g
                                        Wie wäre es, wenn du keine Nacherzählung machen würdest sondern einfach das Log postest? Oder auch
                                        iob diag
                                        • Jens G.
                                          Skript v.2023-10-10
                                          *** BASE SYSTEM ***
                                                 Icon name: computer
                                                    Kernel: Linux 6.1.0-rpi7-rpi-v8
                                              Architecture: arm64
                                          Docker          : false
                                          Kernel          : aarch64
                                          Userland        : arm64
                                           12:24:44 up  1:03,  2 users,  load average: 0.32, 0.25, 0.29
                                          CPU threads: 4
                                          Current issues:
                                                         Local time: Sat 2024-01-06 12:24:44 CET
                                                     Universal time: Sat 2024-01-06 11:24:44 UTC
                                                           RTC time: n/a
                                                        NTP service: active
                                                    RTC in local TZ: no
                                          pi
                                          /home/pi
                                          pi adm dialout cdrom sudo audio video plugdev games users input render netdev gpio i2c spi iobroker
                                          X-Server:       false
                                          Desktop:
                                          Terminal:       tty
                                          Boot Target:    multi-user.target
                                          *** MEMORY ***
                                          Mem:            4.0G        1.2G        372M        1.2M        2.4G        2.7G
                                          Swap:           104M          0B        104M
                                          Total:          4.1G        1.2G        477M
                                                   3793 M total memory
                                                   1189 M used memory
                                                   1172 M active memory
                                                   2005 M inactive memory
                                                    354 M free memory
                                                     92 M buffer memory
                                                   2241 M swap cache
                                                     99 M total swap
                                                      0 M used swap
                                                     99 M free swap
                                          Raspberry only:
                                          oom events: 0
                                          *** FILESYSTEM ***
                                          udev           devtmpfs  1.6G     0  1.6G   0% /dev
                                          tmpfs          tmpfs     380M  1.2M  379M   1% /run
                                          /dev/mmcblk0p2 ext4       29G  3.5G   24G  13% /
                                          /dev/mmcblk0p1 vfat      510M   61M  450M  12% /boot/firmware
                                          tmpfs          tmpfs     380M     0  380M   0% /run/user/1000
                                          [Sat Jan  6 11:20:50 2024] Kernel command line: coherent_pool=1M 8250.nr_uarts=0 snd_bcm2835.enable_headphones=0 snd_bcm2835.enable_headphones=1 snd_bcm2835.enable_hdmi=1 snd_bcm2835.enable_hdmi=0  smsc95xx.macaddr=E4:5F:01:2B:81:55 vc_mem.mem_base=0x3ec00000 vc_mem.mem_size=0x40000000  console=ttyS0,115200 console=tty1 root=PARTUUID=3381e9f9-02 rootfstype=ext4 fsck.repair=yes rootwait
                                          [Sat Jan  6 11:20:52 2024] EXT4-fs (mmcblk0p2): mounted filesystem with ordered data mode. Quota mode: none.
                                          [Sat Jan  6 11:20:54 2024] EXT4-fs (mmcblk0p2): re-mounted. Quota mode: none.
                                          `-/boot/firmware /dev/mmcblk0p1 vfat   rw,relatime,fmask=0022,dmask=0022,codepage=437,iocharset=ascii,shortname=mixed,errors=remount-ro
                                          /var:
                                          503M    /var/
                                          202M    /var/cache
                                          197M    /var/cache/apt
                                          160M    /var/lib
                                          132M    /var/lib/apt/lists
                                          Archived and active journals take up 40.0M in the file system.
                                          4.0K    /opt/iobroker/backups/
                                          217M    /opt/iobroker/iobroker-data/
                                          198M    /opt/iobroker/iobroker-data/files
                                          47M     /opt/iobroker/iobroker-data/files/javascript.admin/static/js
                                          USB-Devices by-id:
                                          /dev/serial/by-id/usb-SHK_NANO_CUL_868-if00-port0
                                          /usr/bin/npm            10.2.3
                                          /usr/bin/npx            10.2.3
                                          nodejs:
                                            Version table:
                                               18.19.0+dfsg-6~deb12u1 500
                                               18.13.0+dfsg1-1 500
                                          Errors in npm tree:
                                          ioBroker Status
                                          Objects type: jsonl
                                          States  type: jsonl
                                          js-controller:  5.0.17
                                          admin:          6.12.0
                                          javascript:     7.1.6
                                          Adapter State
                                          + system.adapter.zigbee.0                 : zigbee                : smarthomepi                              -  enabled, port: /dev/serial/by-id/usb-ITead_Sonoff_Zigbee_3.0_USB_Dongle_Plus_78c227e46ed8ed11ad85736162c613ac-if00-port0
                                          + instance is alive
                                          Controller "js-controller": 5.0.17   , installed 5.0.17
                                          Objects and States
                                          Objects:        4797
                                          States:         1744
                                          Hit:2 http://deb.debian.org/debian-security bookworm-security InRelease
                                          Hit:3 http://deb.debian.org/debian bookworm-updates InRelease
                                          Hit:4 http://archive.raspberrypi.com/debian bookworm InRelease
                                          Hit:5 https://deb.nodesource.com/node_18.x nodistro InRelease
                                          Pending Updates: 0
                                          tcp        0      0 0.0.0.0:22              0.0.0.0:*               LISTEN      0          13059      773/sshd: /usr/sbin
                                          tcp        0      0 192.168.188.159:1883    0.0.0.0:*               LISTEN      1001       51787      10516/io.sonoff.0
                                          tcp        0      0 0.0.0.0:1887            0.0.0.0:*               LISTEN      1001       51828      10547/io.mqtt.0
                                          tcp        0      0 0.0.0.0:1886            0.0.0.0:*               LISTEN      1001       51827      10547/io.mqtt.0
                                          tcp        0      0 127.0.0.1:9001          0.0.0.0:*               LISTEN      1001       51508      10210/iobroker.js-c
                                          tcp        0      0 127.0.0.1:9000          0.0.0.0:*               LISTEN      1001       51515      10210/iobroker.js-c
                                          tcp6       0      0 :::22                   :::*                    LISTEN      0          13061      773/sshd: /usr/sbin
                                          tcp6       0      0 :::8085                 :::*                    LISTEN      1001       54602      11727/io.web.0
                                          tcp6       0      0 :::8081                 :::*                    LISTEN      1001       49898      10239/io.admin.0
                                          udp        0      0 0.0.0.0:5353            0.0.0.0:*                           104        15395      511/avahi-daemon: r
                                          udp        0      0 0.0.0.0:51346           0.0.0.0:*                           104        15397      511/avahi-daemon: r
                                          udp6       0      0 fe80::8152:7386:387:546 :::*                                0          13144      652/NetworkManager
                                          udp6       0      0 :::44029                :::*                                104        15398      511/avahi-daemon: r
                                          udp6       0      0 :::5353                 :::*                                104        15396      511/avahi-daemon: r
                                          2024-01-06 12:20:26.629  - info: host.smarthomepi "system.adapter.zigbee.0" enabled
                                          2024-01-06 12:20:26.865  - info: host.smarthomepi instance system.adapter.zigbee.0 started with pid 11984
                                          2024-01-06 12:20:31.349  - info: zigbee.0 (11984) starting. Version 1.9.5 in /opt/iobroker/node_modules/iobroker.zigbee, node: v18.19.0, js-controller: 5.0.17
                                          2024-01-06 12:20:31.453  - info: zigbee.0 (11984) delete old Backup files. keep only last 10
                                          2024-01-06 12:20:31.456  - info: zigbee.0 (11984) Starting Zigbee  npm ...
                                          2024-01-06 12:20:31.790  - info: zigbee.0 (11984) Installed Version: iobroker.zigbee@1.9.5
                                          2024-01-06 12:20:32.727  - info: zigbee.0 (11984) Coordinator firmware version: {"type":"zStack3x0","meta":{"transportrev":2,"product":1,"majorrel":2,"minorrel":7,"maintrel":1,"revision":20210708}}
                                          2024-01-06 12:20:32.737  - info: zigbee.0 (11984) Unable to disable LED, unsupported function.
                                          2024-01-06 12:20:32.762  - info: zigbee.0 (11984)   --> transmitPower : high+
                                          2024-01-06 12:20:32.783  - info: zigbee.0 (11984) Currently 5 devices are joined:
                                          2024-01-06 12:20:32.837  - info: zigbee.0 (11984) 0x00158d0002f7bc51 (addr 30345): WXKG01LM - Xiaomi MiJia wireless switch (EndDevice)
                                          2024-01-06 12:20:32.842  - info: zigbee.0 (11984) 0x00158d0002732ad3 (addr 49658): RTCGQ11LM - Xiaomi Aqara human body movement and illuminance sensor (EndDevice)
                                          2024-01-06 12:20:32.843  - info: zigbee.0 (11984) 0x00158d00051e85e8 (addr 46898): WSDCGQ11LM - Xiaomi Aqara temperature, humidity and pressure sensor (EndDevice)
                                          2024-01-06 12:20:32.846  - info: zigbee.0 (11984) 0x7cb03eaa0a00c5df (addr 39975): AC03642 - OSRAM SMART+ CLASSIC A 60 TW (Router)
                                          2024-01-06 12:20:32.848  - info: zigbee.0 (11984) 0xa4c1384e05b39d11 (addr 45128): TS011F_plug_1 - TuYa Smart plug (with power monitoring) (Router)
                                          2024-01-06 12:20:32.849  - info: zigbee.0 (11984) Zigbee started
                                          2024-01-06 12:20:32.910  - info: zigbee.0 (11984) debug devices set to []
                                          2024-01-06 12:20:55.844  - warn: zigbee.0 (11984) DeviceAvailability:Failed to ping 0x7cb03eaa0a00c5df CLA60 TW OSRAM
                                          2024-01-06 12:21:04.726  - info: admin.0 (10239) ==> Connected system.user.admin from ::ffff:192.168.188.21
                                          2024-01-06 12:21:05.097  - info: zigbee.0 (11984) List of port: [{"path":"/dev/ttyUSB1","manufacturer":"SHK","serialNumber":"868","pnpId":"usb-SHK_NANO_CUL_868-if00-port0","vendorId":"0403","productId":"6001"},{"path":"/dev/ttyUSB0","manufacturer":"ITead","serialNumber":"78c227e46ed8ed11ad85736162c613ac","pnpId":"usb-ITead_Sonoff_Zigbee_3.0_USB_Dongle_Plus_78c227e46ed8ed11ad85736162c613ac-if00-port0","vendorId":"10c4","productId":"ea60"}]
                                          2024-01-06 12:21:06.742  - warn: zigbee.0 (11984) DeviceAvailability:Failed to ping 0xa4c1384e05b39d11 TS011F
                                          2024-01-06 12:25:00.041  - info: host.smarthomepi instance system.adapter.dwd.0 started with pid 12220
                                          2024-01-06 12:25:02.430  - info: dwd.0 (12220) starting. Version 2.8.5 in /opt/iobroker/node_modules/iobroker.dwd, node: v18.19.0, js-controller: 5.0.17
                                          2024-01-06 12:25:13.275  - info: dwd.0 (12220) Terminated (ADAPTER_REQUESTED_TERMINATION): Without reason
                                          2024-01-06 12:25:13.807  - info: host.smarthomepi instance system.adapter.dwd.0 terminated with code 11 (ADAPTER_REQUESTED_TERMINATION)
                                          So hier ist die Langfassung
                                            @jens-g
                                            System ist richtig aufgesetzt.
                                            Die OSRAM-Klamotten sind bekannt dafür zickig zu sein.
                                            Bring vielleicht die Firmware des Sticks auf Stand, die ist wohl schon älter.
                                            3754
