    4. Error herdsman start Failed to start Zigbee
    • V
      varg @Thomas Braun last edited by varg
      Skript v.2023-10-10
      *** BASE SYSTEM ***
      Static hostname: iobrokerpi5
      Icon name: computer
      Kernel: Linux 6.1.0-rpi7-rpi-2712
      Architecture: arm64
      Model : Raspberry Pi 5 Model B Rev 1.0
      Docker : false
      Virtualization : none
      Kernel : aarch64
      Userland : arm64
      Systemuptime and Load:
      12:07:23 up 18 min, 2 users, load average: 0.07, 0.14, 0.15
      CPU threads: 4
      *** RASPBERRY THROTTLING ***
      Current issues:
      Previously detected issues:
      *** Time and Time Zones ***
      Local time: Fri 2024-01-05 12:07:23 CET
      Universal time: Fri 2024-01-05 11:07:23 UTC
      RTC time: Fri 2024-01-05 11:07:23
      NTP service: active
      RTC in local TZ: no
      *** User and Groups ***
      pi
      /home/pi
      pi adm dialout cdrom sudo audio video plugdev games users input render netdev gpio i2c spi iobroker
      *** X-Server-Setup ***
      X-Server: false
      Desktop:
      Terminal: tty
      Boot Target: multi-user.target
      *** MEMORY ***
      total used free shared buff/cache available
      Mem: 8.4G 1.4G 6.8G 5.2M 439M 7.1G
      Swap: 104M 0B 104M
      Total: 8.5G 1.4G 6.9G
           8053 M total memory
           1287 M used memory
           1170 M active memory
            236 M inactive memory
           6439 M free memory
             36 M buffer memory
            383 M swap cache
             99 M total swap
              0 M used swap
             99 M free swap
      Raspberry only:
      vc_gencmd_read_response returned -1
      error=1 error_msg="Command not registered"
      *** FAILED SERVICES ***
      0 loaded units listed.
      *** FILESYSTEM ***
      Filesystem Type Size Used Avail Use% Mounted on
      udev devtmpfs 3.8G 0 3.8G 0% /dev
      tmpfs tmpfs 806M 5.0M 801M 1% /run
      /dev/mmcblk0p2 ext4 29G 3.3G 25G 12% /
      tmpfs tmpfs 4.0G 0 4.0G 0% /dev/shm
      tmpfs tmpfs 5.0M 48K 5.0M 1% /run/lock
      /dev/mmcblk0p1 vfat 510M 61M 450M 12% /boot/firmware
      tmpfs tmpfs 806M 0 806M 0% /run/user/1000
      [Fri Jan 5 11:48:26 2024] Kernel command line: coherent_pool=1M 8250.nr_uarts=1 pci=pcie_bus_safe snd_bcm2835.enable_compat_alsa=0 snd_bcm2835.enable_hdmi=1 smsc95xx.macaddr=D8:3A:DD:E2:FA:5E vc_mem.mem_base=0x3fc00000 vc_mem.mem_size=0x40000000 console=ttyAMA10,115200 console=tty1 root=PARTUUID=c9d943cf-02 rootfstype=ext4 fsck.repair=yes rootwait
      [Fri Jan 5 11:48:29 2024] EXT4-fs (mmcblk0p2): mounted filesystem with ordered data mode. Quota mode: none.
      [Fri Jan 5 11:48:30 2024] EXT4-fs (mmcblk0p2): re-mounted. Quota mode: none.
      Show mounted filesystems (real ones only):
      TARGET SOURCE FSTYPE OPTIONS
      / /dev/mmcblk0p2 ext4 rw,noatime
      `-/boot/firmware /dev/mmcblk0p1 vfat rw,relatime,fmask=0022,dmask=0022,codepage=437,iocharset=ascii,shortname=mixed,errors=remount-ro
      /var:
      494M /var/
      176M /var/cache
      170M /var/cache/apt
      160M /var/lib
      132M /var/lib/apt/lists
      Archived and active journals take up 56.9M in the file system.
      /opt/iobroker/backups:
      4.0K /opt/iobroker/backups/
      /opt/iobroker/iobroker-data:
      231M /opt/iobroker/iobroker-data/
      142M /opt/iobroker/iobroker-data/files
      67M /opt/iobroker/iobroker-data/files/javascript.admin
      48M /opt/iobroker/iobroker-data/files/javascript.admin/static
      47M /opt/iobroker/iobroker-data/files/javascript.admin/static/js
      72M /opt/iobroker/iobroker-data/objects.jsonl
      33M /opt/iobroker/iobroker-data/files/iot.admin/static/js/main.1797d034.js.map
      12M /opt/iobroker/iobroker-data/states.jsonl
      8.5M /opt/iobroker/iobroker-data/files/iot.admin/static/js/main.1797d034.js
      7.5M /opt/iobroker/iobroker-data/files/javascript.admin/static/js/691.26ff76ce.chunk.js.map
      USB-Devices by-id:
      USB-Sticks - Avoid direct links to /dev/* in your adapter setups, please always prefer the links 'by-id':
      *** NodeJS-Installation ***
      /usr/bin/nodejs v20.10.0
      /usr/bin/node v20.10.0
      /usr/bin/npm 10.2.3
      /usr/bin/npx 10.2.3
      /usr/bin/corepack 0.22.0
      nodejs:
      Installed: 20.10.0-1nodesource1
      Candidate: 20.10.0-1nodesource1
      Version table:
      *** 20.10.0-1nodesource1 600
      500 https://deb.nodesource.com/node_20.x nodistro/main arm64 Packages
      100 /var/lib/dpkg/status
      20.9.0-1nodesource1 600
      20.8.1-1nodesource1 600
      20.8.0-1nodesource1 600
      20.7.0-1nodesource1 600
      20.6.1-1nodesource1 600
      20.6.0-1nodesource1 600
      20.5.1-1nodesource1 600
      20.5.0-1nodesource1 600
      20.4.0-1nodesource1 600
      20.3.1-1nodesource1 600
      20.3.0-1nodesource1 600
      20.2.0-1nodesource1 600
      20.1.0-1nodesource1 600
      20.0.0-1nodesource1 600
      18.19.0+dfsg-6~deb12u1 500
      18.13.0+dfsg1-1 500
      No problems detected
      Errors in npm tree:
      *** ioBroker-Installation ***
      ioBroker Status
      Objects type: jsonl
      States type: jsonl
      Core adapters versions
      js-controller: 5.0.17
      admin: 6.12.0
      javascript: 7.1.6
      Adapters from github: 1
      Adapter State
      • system.adapter.admin.0 : admin : iobrokerpi5 - enabled, port: 8081, bind: 0.0.0.0, run as: admin
      • system.adapter.alexa2.0 : alexa2 : iobrokerpi5 - enabled
        system.adapter.device-reminder.0 : device-reminder : iobrokerpi5 - disabled
      • system.adapter.fb-checkpresence.0 : fb-checkpresence : iobrokerpi5 - enabled
        system.adapter.ical.0 : ical : iobrokerpi5 - enabled
      • system.adapter.info.0 : info : iobrokerpi5 - enabled
      • system.adapter.iot.0 : iot : iobrokerpi5 - enabled
      • system.adapter.javascript.0 : javascript : iobrokerpi5 - enabled
        system.adapter.openweathermap.0 : openweathermap : iobrokerpi5 - enabled
      • system.adapter.ping.0 : ping : iobrokerpi5 - enabled
      • system.adapter.pushover.0 : pushover : iobrokerpi5 - enabled
      • system.adapter.shelly.0 : shelly : iobrokerpi5 - enabled, port: 1882, bind: 0.0.0.0
      • system.adapter.sonoff.0 : sonoff : iobrokerpi5 - enabled, port: 1883, bind: 0.0.0.0
      • system.adapter.tr-064.0 : tr-064 : iobrokerpi5 - enabled
      • system.adapter.trashschedule.0 : trashschedule : iobrokerpi5 - enabled
      • system.adapter.zigbee.0 : zigbee : iobrokerpi5 - enabled, port: /dev/serial/by-id/usb-Texas_Instruments_XDS110__03.00.00.26__Embed_with_CMSIS-DAP_L1100VGY-if00
        system.adapter.zwave2.0 : zwave2 : iobrokerpi5 - disabled
      • instance is alive
      ioBroker-Repositories
      stable : http://iobroker.live/repo/sources-dist.json
      beta : http://iobroker.live/repo/sources-dist-latest.json
      Active repo(s): stable
      Installed ioBroker-Instances
      Used repository: stable
      Adapter "admin" : 6.12.0 , installed 6.12.0
      Adapter "alexa2" : 3.26.3 , installed 3.26.3
      Adapter "device-reminder": 3.0.0 , installed 3.0.0
      Adapter "fb-checkpresence": 1.2.2 , installed 1.2.2
      Adapter "ical" : 1.13.3 , installed 1.13.6
      Adapter "info" : 2.0.0 , installed 2.0.0
      Adapter "iot" : 2.0.11 , installed 2.0.11
      Adapter "javascript" : 7.1.6 , installed 7.1.6
      Controller "js-controller": 5.0.17 , installed 5.0.17
      Adapter "openweathermap": 0.4.5 , installed 0.4.5
      Adapter "ping" : 1.6.2 , installed 1.6.2
      Adapter "pushover" : 3.0.6 , installed 3.0.6
      Adapter "shelly" : 6.6.1 , installed 6.6.1
      Adapter "sonoff" : 3.0.3 , installed 3.0.3
      Adapter "tr-064" : 4.2.18 , installed 4.2.18
      Adapter "trashschedule": 2.3.0 , installed 3.1.3
      Adapter "zigbee" : 1.9.5 , installed 1.9.5
      Adapter "zwave2" : 3.1.0 , installed 3.1.0
      Objects and States
      Objects: 6996
      States: 6069
      Hit:2 http://archive.raspberrypi.com/debian bookworm InRelease
      Hit:5 https://deb.nodesource.com/node_20.x nodistro InRelease
      Reading package lists...
      Pending Updates: 0
      *** Listening Ports ***
      Proto Recv-Q Send-Q Local Address Foreign Address State User Inode PID/Program name
      tcp 0 0 127.0.0.1:9001 0.0.0.0:* LISTEN 1001 742 774/iobroker.js-con
      tcp 0 0 127.0.0.1:9000 0.0.0.0:* LISTEN 1001 16083 774/iobroker.js-con
      tcp 0 0 0.0.0.0:1883 0.0.0.0:* LISTEN 1001 15086 992/io.sonoff.0
      tcp 0 0 0.0.0.0:1882 0.0.0.0:* LISTEN 1001 883 977/io.shelly.0
      tcp 0 0 0.0.0.0:22 0.0.0.0:* LISTEN 0 14865 783/sshd: /usr/sbin
      tcp6 0 0 :::8081 :::* LISTEN 1001 16543 835/io.admin.0
      tcp6 0 0 :::22 :::* LISTEN 0 14867 783/sshd: /usr/sbin
      udp 0 0 0.0.0.0:5353 0.0.0.0:* 104 14779 668/avahi-daemon: r
      udp 0 0 0.0.0.0:55814 0.0.0.0:* 104 14781 668/avahi-daemon: r
      udp6 0 0 :::58098 :::* 104 14782 668/avahi-daemon: r
      udp6 0 0 :::5353 :::* 104 14780 668/avahi-daemon: r
      udp6 0 0 fe80::9c21:67c8:9e0:546 :::* 0 16562 744/NetworkManager
      2024-01-05 11:51:40.347 - info: zigbee.0 (1797) Try to reconnect. 1 attempts left
      2024-01-05 11:51:40.347 - info: zigbee.0 (1797) Starting Zigbee npm ...
      2024-01-05 11:51:40.354 - info: zigbee.0 (1797) Installed Version: iobroker.zigbee@1.9.5
      2024-01-05 11:51:40.483 - error: zigbee.0 (1797) Starting zigbee-herdsman problem : "Error while opening serialport 'Error: Error: Device or resource busy, cannot open /dev/serial/by-id/usb-Texas_Instruments_XDS110__03.00.00.26__Embed_with_CMSIS-DAP_L1100VGY-if00'"
      2024-01-05 11:51:40.484 - error: zigbee.0 (1797) Failed to start Zigbee
      2024-01-05 11:51:40.484 - error: zigbee.0 (1797) Error herdsman start
      2024-01-05 11:53:47.209 - info: admin.0 (835) ==> Connected system.user.admin from ::ffff:192.168.178.55
      2024-01-05 11:53:47.253 - error: zigbee.0 (1797) getGroups: caught error: TypeError: Cannot read properties of undefined (reading 'getGroups')
      2024-01-05 11:53:47.341 - info: zigbee.0 (1797) List of port: [{"path":"/dev/ttyACM0","manufacturer":"Texas Instruments","serialNumber":"L1100VGY","pnpId":"usb-Texas_Instruments_XDS110__03.00.00.26__Embed_with_CMSIS-DAP_L1100VGY-if00","vendorId":"0451","productId":"bef3"},{"path":"/dev/ttyACM1","manufacturer":"Texas Instruments","serialNumber":"L1100VGY","pnpId":"usb-Texas_Instruments_XDS110__03.00.00.26__Embed_with_CMSIS-DAP_L1100VGY-if03","vendorId":"0451","productId":"bef3"},{"path":"/dev/ttyAMA10"}]
      2024-01-05 11:54:19.105 - info: sonoff.0 (992) Client [H801-09] reconnected. Old secret 1704451755348_1275. New secret 1704452059105_1488
      2024-01-05 11:57:36.056 - info: admin.0 (835) <== Disconnect system.user.admin from ::ffff:192.168.178.55
      2024-01-05 11:59:39.697 - info: admin.0 (835) ==> Connected system.user.admin from ::ffff:192.168.178.55
      2024-01-05 11:59:39.765 - error: zigbee.0 (1797) getGroups: caught error: TypeError: Cannot read properties of undefined (reading 'getGroups')
      2024-01-05 11:59:39.865 - info: zigbee.0 (1797) List of port: [{"path":"/dev/ttyACM0","manufacturer":"Texas Instruments","serialNumber":"L1100VGY","pnpId":"usb-Texas_Instruments_XDS110__03.00.00.26__Embed_with_CMSIS-DAP_L1100VGY-if00","vendorId":"0451","productId":"bef3"},{"path":"/dev/ttyACM1","manufacturer":"Texas Instruments","serialNumber":"L1100VGY","pnpId":"usb-Texas_Instruments_XDS110__03.00.00.26__Embed_with_CMSIS-DAP_L1100VGY-if03","vendorId":"0451","productId":"bef3"},{"path":"/dev/ttyAMA10"}]
      2024-01-05 11:59:43.074 - info: admin.0 (835) <== Disconnect system.user.admin from ::ffff:192.168.178.55
      2024-01-05 12:00:00.017 - info: host.iobrokerpi5 instance system.adapter.ical.0 started with pid 1940
      2024-01-05 12:00:00.833 - info: ical.0 (1940) starting. Version 1.13.6 in /opt/iobroker/node_modules/iobroker.ical, node: v20.10.0, js-controller: 5.0.17
      2024-01-05 12:00:01.353 - info: ical.0 (1940) processing URL: Abfallkalender https://calendar.google.com/calendar/ical/74136c8244b022bb0b5d97fdfdee2fe0673eff82bd6842020c2e12bf6c7b489f%40group.calendar.google.com/private-0f8560b829f811ff6c358361c50e5091/basic.ics
      2024-01-05 12:00:01.403 - info: ical.0 (1940) processing URL: Getränkelieferung https://calendar.google.com/calendar/ical/d6sfsku6srbsv5hqp4ane444p8%40group.calendar.google.com/private-573cc39705cb099fd04bbf245c705fea/basic.ics
      2024-01-05 12:00:01.478 - info: trashschedule.0 (1734) Setting "actionNeeded" flag for type.biomüll.actionNeeded to true (???)
      2024-01-05 12:00:06.445 - info: ical.0 (1940) Terminated (NO_ERROR): Without reason
      2024-01-05 12:00:06.967 - info: host.iobrokerpi5 instance system.adapter.ical.0 terminated with code 0 (NO_ERROR)
      2024-01-05 12:03:18.582 - info: admin.0 (835) ==> Connected system.user.admin from ::ffff:192.168.178.55
      2024-01-05 12:03:18.611 - error: zigbee.0 (1797) getGroups: caught error: TypeError: Cannot read properties of undefined (reading 'getGroups')
      2024-01-05 12:03:18.692 - info: zigbee.0 (1797) List of port: [{"path":"/dev/ttyAMA10"}]
      Copy text starting here:
                              v.2023-10-10
             Icon name: computer
          Architecture: arm64
      Installation:           native
      Kernel:                 aarch64
      Userland:               arm64
      Timezone:               Europe/Berlin (CET, +0100)
      User-ID:                1000
      X-Server:               false
      Pending OS-Updates:     0
      Pending iob updates:    0
      Nodejs-Installation:    /usr/bin/nodejs         v20.10.0
                              /usr/bin/npm            10.2.3
                              /usr/bin/npx            10.2.3
      Recommended versions are nodejs  and npm
      MEMORY:
      Mem:            8.4G        1.4G        6.3G        5.4M        760M        7.0G
      Swap:           104M          0B        104M
      Total:          8.5G        1.4G        6.4G
      Active iob-Instances:   14
      ioBroker Core:          js-controller           5.0.17
                              admin                   6.12.0
      Objects type: jsonl
      States  type: jsonl
      + system.adapter.admin.0                  : admin                 : iobrokerpi5                              -  enabled, port: 8081, bind: 0.0.0.0, run as: admin
      Objects:                6996
      States:                 6069
      Size of iob-Database:
      80M     /opt/iobroker/iobroker-data/objects.jsonl
      1.5M    /opt/iobroker/iobroker-data/states.jsonl
      === Mark text until here for copying ===
        Thomas Braun Most Active @varg last edited by
        @varg
        Per
        iob nodejs-update 18
        das Ding auf die empfohlene Version drücken.
        V 3 Replies Last reply Reply Quote 0
        • V
          @thomas-braun said in Error herdsman start Failed to start Zigbee:
          ioBroker nodejs updater 2023-10-13
          You requested to intall latest version from nodejs v18 tree.
          Your current setup is:
          /usr/bin/npm            10.2.3
          /usr/bin/npx            10.2.3
          We found these nodejs versions available for installation:
          nodejs:
            Version table:
               18.13.0+dfsg1-1 500
          Nothing to do - Your installation is using the correct paths.
          You are running nodejs v20.10.0. Do you want to install latest version from nodejs v.18 tree?
          Press <y> to continue or any other key to quit
          Trying to update your installation now. Please be patient.
          Waiting for ioBroker to shut down - Give me a minute...
          *** These repos are active on your system:
          Hit:2 http://deb.debian.org/debian-security bookworm-security InRelease
          Hit:3 http://deb.debian.org/debian bookworm-updates InRelease
          Hit:4 http://archive.raspberrypi.com/debian bookworm InRelease
          Reading package lists... Done
          *** Installing ca-certificates, curl and gnupg, just in case they are missing.
          *** Creating new /etc/apt/sources.list.d/nodesource.list and pinning source
          deb [signed-by=/etc/apt/keyrings/nodesource.gpg] https://deb.nodesource.com/node_18.x nodistro main
          Package: nodejs
          Pin: origin deb.nodesource.com
          Pin-Priority: 1001
          *** These repos are active after the adjustments:
          Get:5 https://deb.nodesource.com/node_18.x nodistro InRelease [12.1 kB]
          Get:6 https://deb.nodesource.com/node_18.x nodistro/main armhf Packages [6656 B]
          Get:7 https://deb.nodesource.com/node_18.x nodistro/main arm64 Packages [6613 B]
          Fetched 25.4 kB in 1s (45.4 kB/s)
          Installing the recommended nodejs version now!
          Exact recommended version unknown, installing a fallback!
          dpkg: warning: downgrading nodejs from 20.10.0-1nodesource1 to 18.0.0-1nodesource1
          (Reading database ... 68077 files and directories currently installed.)
          Preparing to unpack .../nodejs_18.0.0-1nodesource1_arm64.deb ...
          Detected old npm client, removing...
          Unpacking nodejs (18.0.0-1nodesource1) over (20.10.0-1nodesource1) ...
          Setting up nodejs (18.0.0-1nodesource1) ...
          Processing triggers for man-db (2.11.2-2) ...
          Updating fallback to latest nodejs v18 release
          (Reading database ... 68299 files and directories currently installed.)
          Preparing to unpack .../nodejs_18.19.0-1nodesource1_arm64.deb ...
          Unpacking nodejs (18.19.0-1nodesource1) over (18.0.0-1nodesource1) ...
          Setting up nodejs (18.19.0-1nodesource1) ...
          v18.19.0 has been installed! You are using the latest version now!
          Installing the recommended nodejs version!
          We tried our best to update or fix your nodejs. Please run iob diag again to verify.
          *** RESTARTING ioBroker NOW! ***
           Please refresh or restart your browser in a few moments.
          pi@iobrokerpi5:~ $
          moment ich check ob sich was geändert hat und danke schonmal für den Beistand
          Node.js v18.19.0
          pi@iobrokerpi5:~ $ nodejs -v
          v18.19.0
          pi@iobrokerpi5:~ $ node -v
          v18.19.0
          pi@iobrokerpi5:~ $ npm -v
          10.2.3
          pi@iobrokerpi5:~ $
          • V
            zigbee.0
            2024-01-05 12:17:42.424	error	Error herdsman start
            zigbee.0
            2024-01-05 12:17:42.423	error	Failed to start Zigbee
            zigbee.0
            2024-01-05 12:17:42.423	error	Starting zigbee-herdsman problem : "Error while opening serialport 'Error: Error Resource temporarily unavailable Cannot lock port'"
            zigbee.0
            2024-01-05 12:17:42.303	info	Installed Version: iobroker.zigbee@1.9.5
            zigbee.0
            2024-01-05 12:17:42.297	info	Starting Zigbee npm ...
            zigbee.0
            2024-01-05 12:17:42.297	info	Try to reconnect. 1 attempts left
            zigbee.0
            2024-01-05 12:17:32.294	error	Error herdsman start
            zigbee.0
            2024-01-05 12:17:32.293	error	Failed to start Zigbee
            zigbee.0
            2024-01-05 12:17:32.293	error	Starting zigbee-herdsman problem : "Failed to connect to the adapter (Error: SRSP - SYS - ping after 6000ms)"
            pi@iobrokerpi5:~ $ ls -ls /dev/serial/by-id/
            total 0
            0 lrwxrwxrwx 1 root root 13 Jan  5 12:15 usb-Texas_Instruments_XDS110__03.00.00.26__Embed_with_CMSIS-DAP_L1100VGY-if00 -> ../../ttyACM0
            0 lrwxrwxrwx 1 root root 13 Jan  5 12:15 usb-Texas_Instruments_XDS110__03.00.00.26__Embed_with_CMSIS-DAP_L1100VGY-if03 -> ../../ttyACM1
            zigbee.0
            2024-01-05 12:19:29.585	error	Error herdsman start
            zigbee.0
            2024-01-05 12:19:29.584	error	Failed to start Zigbee
            zigbee.0
            2024-01-05 12:19:29.584	error	Starting zigbee-herdsman problem : "Error while opening serialport 'Error: Error Resource temporarily unavailable Cannot lock port'"
            zigbee.0
            2024-01-05 12:19:29.459	info	Installed Version: iobroker.zigbee@1.9.5
            zigbee.0
            2024-01-05 12:19:29.451	info	Starting Zigbee npm ...
            zigbee.0
            2024-01-05 12:19:29.450	info	Try to reconnect. 1 attempts left
            zigbee.0
            2024-01-05 12:19:19.447	error	Error herdsman start
            zigbee.0
            2024-01-05 12:19:19.447	error	Failed to start Zigbee
            zigbee.0
            2024-01-05 12:19:19.447	error	Starting zigbee-herdsman problem : "startup failed - configuration-adapter mismatch - see logs above for more information"
            zigbee.0
            2024-01-05 12:19:19.376	error	Re-commissioning your network will require re-pairing of all devices!
            zigbee.0
            2024-01-05 12:19:19.375	error	If you wish to re-commission your network, please remove coordinator backup at /opt/iobroker/iobroker-data/zigbee_0/nvbackup.json.
            zigbee.0
            2024-01-05 12:19:19.375	error	Please update configuration to prevent further issues.
            zigbee.0
            2024-01-05 12:19:19.375	error	- Channel List: configured=11, adapter=11
            zigbee.0
            2024-01-05 12:19:19.374	error	- Network Key: configured=ffffffffffffffffaaaaaaaaaaaaaaaa, adapter=ffffffffffffffffbbbbbbbbbbbbbbbb
            zigbee.0
            2024-01-05 12:19:19.374	error	- Extended PAN ID: configured=ffffffffaaaaaaaa, adapter=ddddddddaaaaaaaa
            zigbee.0
            2024-01-05 12:19:19.374	error	- PAN ID: configured=6754, adapter=6754
            zigbee.0
            2024-01-05 12:19:19.373	error	Configuration is not consistent with adapter state/backup!
            Zeit
            debug
            Nachricht
            zigbee.0
            2024-01-05 12:22:15.518	error	Error herdsman start
            zigbee.0
            2024-01-05 12:22:15.518	error	Failed to start Zigbee
            zigbee.0
            2024-01-05 12:22:15.517	error	Starting zigbee-herdsman problem : "network commissioning timed out - most likely network with the same panId or extendedPanId already exists nearby"
            admin.0
            2024-01-05 12:22:13.107	info	<== Disconnect system.user.admin from ::ffff:192.168.178.55
            admin.0
            zigbee.0
            2024-01-05 12:22:04.147	info	List of port: [{"path":"/dev/ttyACM0","manufacturer":"Texas Instruments","serialNumber":"L1100VGY","pnpId":"usb-Texas_Instruments_XDS110__03.00.00.26__Embed_with_CMSIS-DAP_L1100VGY-if00","vendorId":"0451","productId":"bef3"},{"path":"/dev/ttyACM1","manufacturer":"Texas Instruments","serialNumber":"L1100VGY","pnpId":"usb-Texas_Instruments_XDS110__03.00.00.26__Embed_with_CMSIS-DAP_L1100VGY-if03","vendorId":"0451","productId":"bef3"},{"path":"/dev/ttyAMA10"}]
            zigbee.0
            2024-01-05 12:22:04.051	error	getGroups: caught error: TypeError: Cannot read properties of undefined (reading 'getGroups')
            admin.0
            2024-01-05 12:22:03.973	info	==> Connected system.user.admin from ::ffff:192.168.178.55
            admin.0
            2024-01-05 12:22:02.099	info	<== Disconnect system.user.admin from ::ffff:192.168.178.55
            zigbee.0
            2024-01-05 12:21:58.972	info	List of port: [{"path":"/dev/ttyACM0","manufacturer":"Texas Instruments","serialNumber":"L1100VGY","pnpId":"usb-Texas_Instruments_XDS110__03.00.00.26__Embed_with_CMSIS-DAP_L1100VGY-if00","vendorId":"0451","productId":"bef3"},{"path":"/dev/ttyACM1","manufacturer":"Texas Instruments","serialNumber":"L1100VGY","pnpId":"usb-Texas_Instruments_XDS110__03.00.00.26__Embed_with_CMSIS-DAP_L1100VGY-if03","vendorId":"0451","productId":"bef3"},{"path":"/dev/ttyAMA10"}]
            zigbee.0
            2024-01-05 12:21:58.878	error	getGroups: caught error: TypeError: Cannot read properties of undefined (reading 'getGroups')
            ich installier den adapter mal neu
            • V
              will leider nicht
              zigbee.0
              2024-01-05 12:32:22.961	error	Error herdsman start
              zigbee.0
              2024-01-05 12:32:22.961	error	Failed to start Zigbee
              zigbee.0
              2024-01-05 12:32:22.961	error	Starting zigbee-herdsman problem : "Error while opening serialport 'Error: Error Resource temporarily unavailable Cannot lock port'"
              zigbee.0
              2024-01-05 12:32:22.824	info	Installed Version: iobroker.zigbee@1.9.5
              zigbee.0
              2024-01-05 12:32:22.816	info	Starting Zigbee npm ...
              zigbee.0
              2024-01-05 12:32:22.815	info	Try to reconnect. 1 attempts left
              admin.0
              2024-01-05 12:32:18.198	info	<== Disconnect system.user.admin from ::ffff:192.168.178.55
              admin.0
              zigbee.0
              2024-01-05 12:32:12.812	error	Error herdsman start
              zigbee.0
              2024-01-05 12:32:12.812	error	Failed to start Zigbee
              zigbee.0
              2024-01-05 12:32:12.812	error	Starting zigbee-herdsman problem : "Failed to connect to the adapter (Error: SRSP - SYS - ping after 6000ms)"
              zigbee.0
              2024-01-05 12:32:05.356	info	List of port: [{"path":"/dev/ttyACM0","manufacturer":"Texas Instruments","serialNumber":"L1100VGY","pnpId":"usb-Texas_Instruments_XDS110__03.00.00.26__Embed_with_CMSIS-DAP_L1100VGY-if00","vendorId":"0451","productId":"bef3"},{"path":"/dev/ttyACM1","manufacturer":"Texas Instruments","serialNumber":"L1100VGY","pnpId":"usb-Texas_Instruments_XDS110__03.00.00.26__Embed_with_CMSIS-DAP_L1100VGY-if03","vendorId":"0451","productId":"bef3"},{"path":"/dev/ttyAMA10"}]
              zigbee.0
              2024-01-05 12:32:05.235	error	getGroups: caught error: TypeError: Cannot read properties of undefined (reading 'getGroups')
              • V
                varg @varg last edited by varg
                Ich vermute es hat was mit der neuen TI Platine zu tun.
                Wenn ich den alten Stick von Arteck anschliesse funzt es auch nach Neustart.
                @arteck hast Du eine Idee wie ich das Board richtig einbinde. Geflasht wurde es wie oben beschrieben
                Ich kann nur so viel sagen dass ich mit dem TI Board nach jedem neustart ein port problem bekomme
                  @varg
                  Ich kenne das Ding nicht, wie wird das denn angebunden? Über einen Seriellen Port?
                  V Meister Mopper 2 Replies Last reply Reply Quote 0
                  • V
                    ich sag einfach mal ja hab aber wenig ahnung.
                    vor 2 Jahren konnte ich die platine noch in nem anderen system ohne probleme einbinden.
                    die neuere revision eben nicht
                    youtube
                    • Meister Mopper
                      Meister Mopper @Thomas Braun last edited by
                      Ich denke, hier ist der Wurm drin, oder?
                           18.13.0+dfsg1-1 500
                        Thomas Braun Most Active @Meister Mopper last edited by
                        @meister-mopper
                        Das ist bereits geändert worden:
                          @varg
                          Mach zur Sicherheit noch:
                          echo -e "Package: nodejs\nPin: origin deb.nodesource.com\nPin-Priority: 1001" | sudo tee /etc/apt/preferences.d/nodejs.pref
                          sudo apt update
                          iob stop
                          sudo apt install nodejs=18.19.0-1nodesource1
                          iob start
                          • V
                            Ich hab das System nochmal komplett neu mit nodejs18 aufgesetzt und den alten Stick in Betrieb genommen.
                            Vielleicht hat noch jemand die neuere ti Platine mit der config und kann was dazu sagen.
                            Ich teste das Teil die Tage mal an einem PI4 mit buster und schau ob's damit läuft
                            Würde mich dann nochmal melden. Danke Euch
                              BigChris last edited by BigChris
                              Bist du weitergekommen?
                              Gleiches Problem bei mir, nach Update vom Zigbee Adapter und nodejs funtioniert der Zigbee Adapter nicht mehr.
                              Bei mir mit dem raspbee als Aufsteckplatine.
                              			v.2023-10-10
                               Static hostname: pi-iobroker
                                     Icon name: computer
                              Operating System: Raspbian GNU/Linux 12 (bookworm)
                                        Kernel: Linux 6.1.0-rpi4-rpi-v8
                                  Architecture: arm64
                              Kernel: 		aarch64
                              Userland: 		armhf
                              User-ID: 		1000
                              X-Server: 		false
                              Nodejs-Installation: 	/usr/bin/nodejs 	v18.19.0
                              			/usr/bin/node 		v18.19.0
                              			/usr/bin/npm 		10.2.3
                              			/usr/bin/npx 		10.2.3
                              MEMORY:
                              Mem:            8.2G        749M        7.1G        1.2M        477M        7.4G
                              Swap:           104M          0B        104M
                              Total:          8.3G        749M        7.2G
                              Active iob-Instances: 	9
                              			admin 			6.12.0
                              ioBroker Status: 	iobroker is running on this host.
                              Objects type: jsonl
                              States  type: jsonl
                              + system.adapter.admin.0                  : admin                 : pi-iobroker                              -  enabled, port: 8081, bind: 0.0.0.0, run as: admin
                              Objects: 		1713
                              States: 		1506
                              19M	/opt/iobroker/iobroker-data/objects.jsonl
                              2.7M	/opt/iobroker/iobroker-data/states.jsonl
                              Was mich wundert ist das hier:
                              USB-Devices by-id:
                              Irgendwie wird die Platine nicht mehr erkannt. Das passiert bei zwei Systemen bei mir, jeweils Rasperry Pi 3 und raspbee.
                                Thomas Braun Most Active @BigChris last edited by
                                @bigchris sagte in Error herdsman start Failed to start Zigbee:
                                An der Stelle dürfte die noch nie erkannt worden sein. Da tauchen nur USB-Geräte auf. Du hast doch da ein IP-basiertes Ding laufen, oder?
                                • MartinP
                                  MartinP @Thomas Braun last edited by
                                  @thomas-braun Im ersten Logging finde ich "/dev/ttyACM0" das deutet doch auf USB hin, oder?
                                  Braille-Reader Service?
                                    Thomas Braun Most Active @MartinP last edited by
                                    Gerade über 'raspbee' gestolpert...
                                    @BigChris : Hast du in
                                    sudo raspi-config
                                    auch die Serielle Schnittstelle freigeschaltet?
                                    MartinP B 2 Replies Last reply Reply Quote 0
                                    • MartinP
                                      @thomas-braun Für solche Sachen bin ich auch Spezialist - solche "Unterbau-Vorbereitungen", die man vor Urzeiten mal gemacht hat vergesse ich auch regelmäßig bei Umzügen ...
                                        Thomas Braun Most Active @MartinP last edited by Thomas Braun
                                        @martinp
                                        Es gibt Leute, die führen Buch über Änderungen / Ergänzungen am System.
                                        MartinP 1 Reply Last reply Reply Quote 1
                                          BigChris @Thomas Braun last edited by
                                          @thomas-braun sagte in Error herdsman start Failed to start Zigbee:
                                          sudo raspi-config
                                          Ja habe ich auch noch mal gemacht.
                                          Ich habe im Verdacht, dass das apt update / upgrade ein defekt eingespielt hat beim wechsel zu bookworm.
                                          Die Geräte an dem GPIO werden offensichtlich nicht mehr im System erkannt.
                                            @bigchris
                                            Gib uns mal die Langfassung von
                                            iob diag
                                            3072
