    4. Influx DB Daten löschen? Wie? Kein zugriff auf den ioBroker
      Thomas Braun Most Active @holla16 last edited by
      @holla16
      inet 192.168.178.57
      Ist die aktuelle IPv4 auf dem LAN-Interface...
      iob diag
      sagt?
        holla16 last edited by holla16
        entschuldigt bitte meine nicht perfekten Kenntnisse: Wenn ich iob diag eingebe kommt folgendes:
        pi@raspberrypi:~ $ select all inet 192.168.178.57
        -bash: syntax error near unexpected token `inet'
        pi@raspberrypi:~ $ iob diag
        iobroker [command]
        Commands:
          iobroker setup                                               Setup ioBroker
          iobroker start [all|<adapter>.<instance>]                    Starts the js-controller or a specified adapter instance
          iobroker stop [<adapter>.<instance>]                         stops the js-controller or a specified adapter instance
          iobroker restart [<adapter>.<instance>]                      Restarts js-controller or a specified adapter instance  [aliases: r]
          iobroker debug <adapter>[.<instance>]                        Starts a Node.js debugging session for the adapter instance
          iobroker info                                                Shows the host info
          iobroker logs [<adapter>]                                    Monitor log
          iobroker add <adapter> [desiredNumber]                       Add instance of adapter  [aliases: a]
          iobroker install <adapter>                                   Installs a specified adapter  [aliases: i]
          iobroker rebuild [<module>]                                  Rebuild all native modules or path
          iobroker url <url> [<name>]                                  Install adapter from specified url, e.g. GitHub
          iobroker del <adapter>                                       Remove adapter and all instances from this host  [aliases: delete]
          iobroker del <adapter>.<instance>                            Remove adapter instance  [aliases: delete]
          iobroker update [<repositoryUrl>]                            Update repository and list adapters
          iobroker upgrade                                             Upgrade management
          iobroker upload [all|<adapter>]                              Upload management  [aliases: u]
          iobroker object                                              Object management  [aliases: o]
          iobroker state                                               State management  [aliases: s]
          iobroker message <adapter>[.instance] <command> [<message>]  Send message to adapter instance/s
          iobroker list <type> [<filter>]                              List all entries, like objects
          iobroker chmod <mode> <file>                                 Change file rights
          iobroker chown <user> <group> <file>                         Change file ownership
          iobroker touch <file>                                        Touch file
          iobroker rm <file>                                           Remove file
          iobroker file                                                File management
          iobroker user                                                User commands
          iobroker group                                               group management
          iobroker host <hostname>                                     Set host to given hostname
          iobroker set <adapter>.<instance>                            Change settings of adapter config
          iobroker license <license.file or license.text>              Update license by given file
          iobroker cert                                                Certificate management
          iobroker clean <yes>                                         Clears all objects and states
          iobroker backup                                              Create backup
          iobroker restore <backup name or path>                       Restore a specified backup
          iobroker validate <backup name or path>                      Validate a specified backup
          iobroker status [all|<adapter>.<instance>]                   Status of ioBroker or adapter instance  [aliases: isrun]
          iobroker repo [<name>]                                       Show repo information
          iobroker uuid                                                Show uuid of the installation  [aliases: id]
          iobroker unsetup                                             Reset license, installation secret and language
          iobroker fix                                                 Execute the installation fixer script, this updates your ioBroker installation
          iobroker multihost                                           Multihost management
          iobroker compact                                             compact group management
        pi@raspberrypi:~ $
          iobroker version [<adapter>]                                 Show version of js-controller or specified adapter  [aliases: v]
        Options:
          --help  Show help  [boolean]
        pi@raspberrypi:~ $
        wcag22 da_Woody Thomas Braun 3 Replies Last reply Reply Quote 0
        • wcag22
          wcag22 @holla16 last edited by wcag22
          @holla16
          Ist denn diag installiert?
          curl -sLf -o diag.sh https://iobroker.net/diag.sh && bash diag.sh
            @Pi-ter : soll ich das eingeben? curl -sLf -o diag.sh https://iobroker.net/diag.sh && bash diag.sh
            Wenn ich das eingebe dann passiert nichts...
            • da_Woody
              da_Woody @holla16 last edited by da_Woody
              @holla16 auch für dich. Log immer in Tags schreiben. So ist das unleserlich.
                @holla16
                iob stop
                iob fix
                iob start
                Und dann
                iob diag
                • da_Woody
                  @holla16 sagte in Keine Lan Verbundung zum Raspi / per SSH aber möglich:
                  ich gebe in der Eingabeaufforderung
                  Auch möglich, aber geht einfacher mit PuTTY, oder besser mobaxterm.
                    @da_Woody wie schreibe ich in Tags?
                    • DJMarc75
                      DJMarc75 @holla16 last edited by
                        @Thomas-Braun dann kommt das
                        pi@raspberrypi:~ $ iob stop
                        pi@raspberrypi:~ $ iob fix
                        library: loaded
                        Library version=2024-01-04
                            Welcome to the ioBroker installation fixer!
                            Script version: 2024-01-04
                            You might need to enter your password a couple of times.
                            Installing prerequisites (1/5)
                        Get:1 http://deb.debian.org/debian bullseye InRelease [116 kB]
                        Err:1 http://deb.debian.org/debian bullseye InRelease
                          Error writing to file - write (28: No space left on device) [IP: 2a04:4e42:65::644 80]
                        Get:2 http://archive.raspberrypi.org/debian bullseye InRelease [23.6 kB]
                        Err:2 http://archive.raspberrypi.org/debian bullseye InRelease
                          Error writing to file - write (28: No space left on device) [IP: 2a00:1098:82:47::2:1 80]
                        Get:3 http://security.debian.org/debian-security bullseye-security InRelease [48.4 kB]
                        Err:3 http://security.debian.org/debian-security bullseye-security InRelease
                        Get:4 http://deb.debian.org/debian bullseye-updates InRelease [44.1 kB]
                        Err:4 http://deb.debian.org/debian bullseye-updates InRelease
                        Get:5 https://repos.influxdata.com/debian bullseye InRelease [7,049 B]
                        Err:5 https://repos.influxdata.com/debian bullseye InRelease
                          Error writing to file - write (28: No space left on device) [IP: 2600:9000:2315:4400:11:fe8d:7d40:93a1 443]
                        Get:6 https://deb.nodesource.com/node_16.x bullseye InRelease [4,586 B]
                        Err:6 https://deb.nodesource.com/node_16.x bullseye InRelease
                          Error writing to file - write (28: No space left on device) [IP: 2606:4700:10::ac43:acd 443]
                        Reading package lists... Error!
                        W: Failed to fetch http://deb.debian.org/debian/dists/bullseye/InRelease  Error writing to file - write (28: No space left on device) [IP: 2a04:4e42:65::644 80]
                        W: Failed to fetch http://security.debian.org/debian-security/dists/bullseye-security/InRelease  Error writing to file - write (28: No space left on device) [IP: 2a04:4e42:65::644 80]
                        W: Failed to fetch http://deb.debian.org/debian/dists/bullseye-updates/InRelease  Error writing to file - write (28: No space left on device) [IP: 2a04:4e42:65::644 80]
                        W: Failed to fetch https://repos.influxdata.com/debian/dists/bullseye/InRelease  Error writing to file - write (28: No space left on device) [IP: 2600:9000:2315:4400:11:fe8d:7d40:93a1 443]
                        W: Failed to fetch https://deb.nodesource.com/node_16.x/dists/bullseye/InRelease  Error writing to file - write (28: No space left on device) [IP: 2606:4700:10::ac43:acd 443]
                        W: Failed to fetch http://archive.raspberrypi.org/debian/dists/bullseye/InRelease  Error writing to file - write (28: No space left on device) [IP: 2a00:1098:82:47::2:1 80]
                        W: Some index files failed to download. They have been ignored, or old ones used instead.
                        E: Write error - write (28: No space left on device)
                        E: IO Error saving source cache
                        E: The package lists or status file could not be parsed or opened.
                            Checking ioBroker user and directory permissions (2/5)
                        usermod: /etc/passwd.1010: No space left on device
                        usermod: cannot lock /etc/passwd; try again later.
                        main: line 702: echo: write error: No space left on device
                        Created /etc/sudoers.d/iobroker
                        usermod: /etc/shadow.1222: No space left on device
                        usermod: cannot lock /etc/shadow; try again later.
                        usermod: /etc/shadow.1225: No space left on device
                        usermod: /etc/shadow.1228: No space left on device
                        usermod: /etc/shadow.1231: No space left on device
                        usermod: /etc/shadow.1234: No space left on device
                        usermod: /etc/passwd.1238: No space left on device
                        usermod: /etc/passwd.1241: No space left on device
                        Fixing directory permissions...
                        usermod: /etc/passwd.1302: No space left on device
                            Check and cleanup npm temporary directories (3/5)
                        Done.
                            Database maintenance (4/5)
                        Checking for uncompressed JSONL databases... This might take a while!
                        npm ERR! code ENOSPC
                        npm ERR! syscall write
                        npm ERR! errno -28
                        npm ERR! nospc ENOSPC: no space left on device, write
                        npm ERR! nospc There appears to be insufficient space on your system to finish.
                        npm ERR! nospc Clear up some disk space and try again.
                        npm ERR!     /home/iobroker/.npm/_logs/2024-01-06T10_14_32_048Z-debug-0.log
                        main: line 14: [: -lt: unary operator expected
                        npm ERR! errno -28
                        npm ERR!     /home/iobroker/.npm/_logs/2024-01-06T10_14_33_034Z-debug-0.log
                            Checking autostart (5/5)
                        Enabling autostart...
                        Failed to enable unit: Unit file /lib/systemd/system/iobroker.service is masked.
                        Autostart enabled!
                            Your installation was fixed successfully
                            Run iobroker start to start ioBroker again!
                          @DJMarc75 : Vielen Dank
                            @holla16
                            Der Datenträger ist voll.
                              @Thomas-Braun ok, heißt ich kann was machen? Es kann sein, dass die Backups dort gespeichert wurde. Was mich nur wundert. Ich nehme den Raspi fälschlicher Weise so vom Stromnetz, will ich wieder an machen und nichts geht mehr.
                              Einfach SD Karte raus backups löschen und loslegen?
                              da_Woody Thomas Braun 2 Replies Last reply Reply Quote 0
                              • da_Woody
                                SD raus, wird dein raspi nicht mehr starten...
                                Wie groß ist die SD? abstecken, wieder anstecken macht bei meinen raspis fürs 3d drucken kein problem. bei ioB kanns knallen.
                                  @holla16
                                  Wenn du so grobschlächtig mit dem Ding umgehst wundert mich eigentlich nix mehr.
                                  Mit
                                  sudo apt clean
                                  da etwas Luft verschaffen.
                                  Dann nochmal wie oben.
                                    Thomas Braun Most Active @da_Woody last edited by
                                    @da_woody sagte in Keine Lan Verbundung zum Raspi / per SSH aber möglich:
                                    Ist auch da Mist. Nie machen, Dateisysteme IMMER sauber aushängen.
                                      holla16 @Thomas Braun last edited by
                                      @thomas-braun Ja was ich da jetzt für einen Mist habe, werde ich das zukünftig anders machen.
                                        ich könnt abdrehen... Hab die SD Karte im Windows PC angeschaut, nicht gemacht. Dann wieder in den Raspi und dann die Befehle ausgeführt. Aber keine Reaktion:
                                        pi@raspberrypi:~ $ sudo apt clean
                                        pi@raspberrypi:~ $ iob start
                                        pi@raspberrypi:~ $
                                        Wenn ich df eingebe
                                        pi@raspberrypi:~ $ df
                                        Filesystem     1K-blocks     Used Available Use% Mounted on
                                        /dev/root       61092524 60901000         0 100% /
                                        devtmpfs         3834160        0   3834160   0% /dev
                                        tmpfs            3999920        0   3999920   0% /dev/shm
                                        tmpfs            1599972     9284   1590688   1% /run
                                        tmpfs               5120        4      5116   1% /run/lock
                                        /dev/mmcblk0p1    261108    31264    229844  12% /boot
                                        tmpfs             799984        0    799984   0% /run/user/1000
                                        pi@raspberrypi:~ $
                                        sieht man das die Partition zu 100% voll ist. Kann ich das letzte Backup nicht irgendwie sichern und den ioBroker neu aufsetzen und das Backup einspielen?
                                        • da_Woody
                                          da_Woody @Thomas Braun last edited by
                                          @thomas-braun ist mir grundsätzlich klar, aber hatte seit 3 Jahren kein Problem. Vllt immer Glück gehabt. Da wird ja auch nicht dauernd auf die Karte zugegriffen.
                                          Drucker und raspi hängen an einem Shelly Plug. Ein Klick, Strom weg.
                                            Könnte auch zu 'Ein Klick, System weg' führen. Ist aber hier für den TE uninteressant, wie du deine Kisten malträtierst.
                                            12290
