    4. Influx DB Daten löschen? Wie? Kein zugriff auf den ioBroker
      holla16 @Thomas Braun last edited by
      Ok dann kommt das:
      pi@raspberrypi:~ $ cd /opt/iobroker
      pi@raspberrypi:/opt/iobroker $ sudo -u iobroker npm cache clear --force
      npm ERR! code ENOSPC
      npm ERR! syscall write
      npm ERR! errno -28
      npm ERR! nospc ENOSPC: no space left on device, write
      npm ERR! nospc There appears to be insufficient space on your system to finish.
      npm ERR! nospc Clear up some disk space and try again.
      npm ERR!     /home/iobroker/.npm/_logs/2022-08-07T14_00_43_182Z-debug-0.log
        Thomas Braun Most Active @holla16 last edited by
        @holla16
        ls -lAh /opt/iobroker/backups/
          @Thomas-Braun :
          bin jetzt so weit
          pi@raspberrypi:/opt/iobroker $ ls -lAh / opt/iobroker/backups/
          ls: cannot access 'opt/iobroker/backups/': No such file or directory
          total 60K
          lrwxrwxrwx   1 root root    7 Sep 22  2022 bin -> usr/bin
          drwxr-xr-x   4 root root 4.0K Jan  1  1970 boot
          drwxr-xr-x  16 root root 3.9K Aug  7 15:25 dev
          drwxr-xr-x  86 root root 4.0K Jan  6  2024 etc
          drwxr-xr-x   4 root root 4.0K Dec  6  2022 home
          lrwxrwxrwx   1 root root    7 Sep 22  2022 lib -> usr/lib
          drwx------   2 root root  16K Sep 22  2022 lost+found
          drwxr-xr-x   2 root root 4.0K Sep 22  2022 media
          drwxr-xr-x   2 root root 4.0K Sep 22  2022 mnt
          drwxr-xr-x   3 root root 4.0K Dec  6  2022 opt
          dr-xr-xr-x 190 root root    0 Jan  1  1970 proc
          drwx------   4 root root 4.0K Dec  6  2022 root
          drwxr-xr-x  26 root root  720 Aug  7 15:42 run
          lrwxrwxrwx   1 root root    8 Sep 22  2022 sbin -> usr/sbin
          drwxr-xr-x   2 root root 4.0K Sep 22  2022 srv
          dr-xr-xr-x  12 root root    0 Jan  1  1970 sys
          drwxrwxrwt   7 root root 4.0K Aug  7 15:25 tmp
          drwxr-xr-x  11 root root 4.0K Sep 22  2022 usr
          drwxr-xr-x  11 root root 4.0K Jan  5  2024 var
            @holla16
            Du hast ein Leerzeichen reingeschmuggelt...
              @Thomas-Braun ;
              sorry. Da ist alles drin
              pi@raspberrypi:/opt/iobroker $ ls -1Ah /opt/iobroker/backups/
              iobroker_2023_12_25-02_40_10_backupiobroker.tar.gz
              iobroker_2023_12_26-02_40_10_backupiobroker.tar.gz
              iobroker_2023_12_27-02_40_10_backupiobroker.tar.gz
              iobroker_2023_12_28-02_40_10_backupiobroker.tar.gz
              iobroker_2023_12_29-02_40_10_backupiobroker.tar.gz
              iobroker_2023_12_30-02_40_10_backupiobroker.tar.gz
              iobroker_2023_12_31-02_40_10_backupiobroker.tar.gz
              iobroker_2024_01_01-02_40_10_backupiobroker.tar.gz
              iobroker_2024_01_02-02_40_10_backupiobroker.tar.gz
              iobroker_2024_01_03-02_40_13_backupiobroker.tar.gz
                kann ich da nicht alle bis auf den vom 03.01. löschen?
                  @holla16
                  Bitte kopiere die Kommandos. Das ist ein l, keine 1
                    @holla16 sagte in Keine Lan Verbundung zum Raspi / per SSH aber möglich:
                    rm /opt/iobroker/backups/iobroker_2023_12*
                    df -h
                      Ok Sorry, dann kommt das
                      pi@raspberrypi:/opt/iobroker $ ls -pi@raspberrypi:/opt/iobroker $ ls -1Ah /opt/iobroker/backups/
                      ls: invalid option -- '@'
                      Try 'ls --help' for more information.
                      pi@raspberrypi:/opt/iobroker $ iobroker_2023_12_25-02_40_10_backupiobroker.tar.gz
                      iobroker_2023_12_31-02_-bash: iobroker_2023_12_25-02_40_10_backupiobroker.tar.gz: command not found
                      pi@raspberrypi:/opt/iobroker $ iobroker_2023_12_26-02_40_10_backupiobroker.tar.gz
                      iobroker-bash: iobroker_2023_12_26-02_40_10_backupiobroker.tar.gz: command not found
                      _2024_01_02-02_40_10_backupiobrokepi@raspberrypi:/opt/iobroker $ iobroker_2023_12_27-02_40_10_backupiobroker.tar.gz
                      pi@raspberrypi:/opt/iobro-bash: iobroker_2023_12_27-02_40_10_backupiobroker.tar.gz: command not found
                      ker $pi@raspberrypi:/opt/iobroker $ iobroker_2023_12_28-02_40_10_backupiobroker.tar.gz
                      -bash: iobroker_2023_12_28-02_40_10_backupiobroker.tar.gz: command not found
                      pi@raspberrypi:/opt/iobroker $ iobroker_2023_12_29-02_40_10_backupiobroker.tar.gz
                      -bash: iobroker_2023_12_29-02_40_10_backupiobroker.tar.gz: command not found
                      pi@raspberrypi:/opt/iobroker $ iobroker_2023_12_30-02_40_10_backupiobroker.tar.gz
                      -bash: iobroker_2023_12_30-02_40_10_backupiobroker.tar.gz: command not found
                      pi@raspberrypi:/opt/iobroker $ iobroker_2023_12_31-02_40_10_backupiobroker.tar.gz
                      -bash: iobroker_2023_12_31-02_40_10_backupiobroker.tar.gz: command not found
                      pi@raspberrypi:/opt/iobroker $ iobroker_2024_01_01-02_40_10_backupiobroker.tar.gz
                      -bash: iobroker_2024_01_01-02_40_10_backupiobroker.tar.gz: command not found
                      pi@raspberrypi:/opt/iobroker $ iobroker_2024_01_02-02_40_10_backupiobroker.tar.gz
                      -bash: iobroker_2024_01_02-02_40_10_backupiobroker.tar.gz: command not found
                      pi@raspberrypi:/opt/iobroker $ iobroker_2024_01_03-02_40_13_backupiobroker.tar.gz
                      -bash: iobroker_2024_01_03-02_40_13_backupiobroker.tar.gz: command not found
                        @holla16
                        Das ist auch nicht das was ich geschrieben habe. Das ist 'irgendwas' in die Konsole gekippt und die kann dann mit dem wirren Zeug nix anfangen.
                          pi@raspberrypi:/opt/iobroker $ pi@raspberrypi:/opt/iobroker $rm /opt/iobroker/backups/iobroker_2023_12*
                          -bash: pi@raspberrypi:/opt/iobroker: No such file or directory
                          pi@raspberrypi:/opt/iobroker $ df -h
                          Filesystem      Size  Used Avail Use% Mounted on
                          /dev/root        59G   59G     0 100% /
                          devtmpfs        3.7G     0  3.7G   0% /dev
                          tmpfs           3.9G     0  3.9G   0% /dev/shm
                          tmpfs           1.6G  9.1M  1.6G   1% /run
                          tmpfs           5.0M  4.0K  5.0M   1% /run/lock
                          /dev/mmcblk0p1  255M   31M  225M  12% /boot
                          tmpfs           782M     0  782M   0% /run/user/1000
                            @holla16
                            NICHT
                            in die Konsole knallen.
                              holla16 @Thomas Braun last edited by holla16
                              @thomas-braun said in Keine Lan Verbundung zum Raspi / per SSH aber möglich:
                              Ok dann kommt das
                              pi@raspberrypi:/opt/iobroker $ rm /opt/iobroker/backups/iobroker_2023_12*
                              rm: cannot remove '/opt/iobroker/backups/iobroker_2023_12*': No such file or directory
                              /dev/root        59G   58G     0 100% /
                                @holla16
                                  pi@raspberrypi:/opt/iobroker $ ls -lAh /opt/iobroker/backups/
                                  total 27M
                                  -rw-rwxr--+ 1 iobroker iobroker  15M Jan  1  2024 iobroker_2024_01_01-02_40_10_backupiobroker.tar.gz
                                  -rw-rwxr--+ 1 iobroker iobroker 4.2M Jan  2  2024 iobroker_2024_01_02-02_40_10_backupiobroker.tar.gz
                                  -rw-rwxr--+ 1 iobroker iobroker 8.2M Jan  3  2024 iobroker_2024_01_03-02_40_13_backupiobroker.tar.gz
                                    @holla16
                                    iob stop
                                    iob fix
                                    iob start
                                    iob diag
                                      pi@raspberrypi:/opt/iobroker $ iob stop
                                      pi@raspberrypi:/opt/iobroker $ iob fix
                                      pi@raspberrypi:/opt/iobroker $ iob start
                                      pi@raspberrypi:/opt/iobroker $ iob diag
                                        @holla16
                                        curl -L -o diag.sh https://iobroker.net/diag.sh && bash diag.sh
                                          pi@raspberrypi:/opt/iobroker $ curl -L -o diag.sh https://iobroker.net/diag.sh && bash diag.sh
                                            % Total    % Received % Xferd  Average Speed   Time    Time     Time  Current
        Dload  Upload   Total   Spent    Left  Speed
                                            0     0    0     0    0     0      0      0 --:--:-- --:--:-- --:--:--     0
                                          curl: (60) SSL certificate problem: certificate is not yet valid
                                          More details here: https://curl.se/docs/sslcerts.html
                                          curl failed to verify the legitimacy of the server and therefore could not
                                          establish a secure connection to it. To learn more about this situation and
                                          how to fix it, please visit the web page mentioned above.
                                            @holla16
                                            curl -kL -o diag.sh https://iobroker.net/diag.sh && bash diag.sh
                                            12292
