    4. Influx DB Daten löschen? Wie? Kein zugriff auf den ioBroker
      holla16 @Thomas Braun last edited by
      pi@raspberrypi:/opt/iobroker $ pi@raspberrypi:/opt/iobroker $rm /opt/iobroker/backups/iobroker_2023_12*
      -bash: pi@raspberrypi:/opt/iobroker: No such file or directory
      pi@raspberrypi:/opt/iobroker $ df -h
      Filesystem      Size  Used Avail Use% Mounted on
      /dev/root        59G   59G     0 100% /
      devtmpfs        3.7G     0  3.7G   0% /dev
      tmpfs           3.9G     0  3.9G   0% /dev/shm
      tmpfs           1.6G  9.1M  1.6G   1% /run
      tmpfs           5.0M  4.0K  5.0M   1% /run/lock
      /dev/mmcblk0p1  255M   31M  225M  12% /boot
      tmpfs           782M     0  782M   0% /run/user/1000
        Thomas Braun Most Active @holla16 last edited by
        @holla16
        NICHT
        in die Konsole knallen.
          holla16 @Thomas Braun last edited by holla16
          @thomas-braun said in Keine Lan Verbundung zum Raspi / per SSH aber möglich:
          Ok dann kommt das
          pi@raspberrypi:/opt/iobroker $ rm /opt/iobroker/backups/iobroker_2023_12*
          rm: cannot remove '/opt/iobroker/backups/iobroker_2023_12*': No such file or directory
          /dev/root        59G   58G     0 100% /
            @holla16
            ls -lAh /opt/iobroker/backups/
              pi@raspberrypi:/opt/iobroker $ ls -lAh /opt/iobroker/backups/
              total 27M
              -rw-rwxr--+ 1 iobroker iobroker  15M Jan  1  2024 iobroker_2024_01_01-02_40_10_backupiobroker.tar.gz
              -rw-rwxr--+ 1 iobroker iobroker 4.2M Jan  2  2024 iobroker_2024_01_02-02_40_10_backupiobroker.tar.gz
              -rw-rwxr--+ 1 iobroker iobroker 8.2M Jan  3  2024 iobroker_2024_01_03-02_40_13_backupiobroker.tar.gz
                @holla16
                iob stop
                iob fix
                iob start
                iob diag
                  pi@raspberrypi:/opt/iobroker $ iob stop
                  pi@raspberrypi:/opt/iobroker $ iob fix
                  pi@raspberrypi:/opt/iobroker $ iob start
                  pi@raspberrypi:/opt/iobroker $ iob diag
                    @holla16
                    curl -L -o diag.sh https://iobroker.net/diag.sh && bash diag.sh
                      pi@raspberrypi:/opt/iobroker $ curl -L -o diag.sh https://iobroker.net/diag.sh && bash diag.sh
                        % Total    % Received % Xferd  Average Speed   Time    Time     Time  Current
                                                       Dload  Upload   Total   Spent    Left  Speed
                        0     0    0     0    0     0      0      0 --:--:-- --:--:-- --:--:--     0
                      curl: (60) SSL certificate problem: certificate is not yet valid
                      More details here: https://curl.se/docs/sslcerts.html
                      curl failed to verify the legitimacy of the server and therefore could not
                      establish a secure connection to it. To learn more about this situation and
                      how to fix it, please visit the web page mentioned above.
                        @holla16
                        curl -kL -o diag.sh https://iobroker.net/diag.sh && bash diag.sh
                          pi@raspberrypi:/opt/iobroker $ curl -kL -o diag.sh https://iobroker.net/diag.sh && bash diag.sh
                          100   185  100   185    0     0   1258      0 --:--:-- --:--:-- --:--:--  1267
                           87 18519   87 16127    0     0  60627      0 --:--:-- --:--:-- --:--:-- 60627
                          curl: (23) Failure writing output to destination
                            @holla16
                            Wohl immer noch kein Platz auf der Kiste.
                            sudo du -a / | sort -n -r | head -n 20
                              da kommt das
                              pi@raspberrypi:/opt/iobroker $ sudo du -a / | sort -n -r | head -n 20
                              sort: write failed: /tmp/sortm0nSnH: No space left on device
                              ne da ist alles zu 100% voll. Wir haben eben gesehen, dass dort einige Backups drin waren. Können wir da nicht was löschen?
                                @holla16 sagte in Keine Lan Verbundung zum Raspi / per SSH aber möglich:
                                Haben wir schon.
                                df -h
                                    @holla16
                                    cd /opt/iobroker
                                    du -cks * | sort -rn | head
                                      pi@raspberrypi:/opt/iobroker $ cd /opt/iobroker
                                      pi@raspberrypi:/opt/iobroker $ du -cks * | sort -rn | head
                                      1456376 total
                                      1014316 node_modules
                                      371380  iobroker-data
                                      42608   log
                                      27060   backups
                                      1004    package-lock.json
                                      4       package.json
                                      4       INSTALLER_INFO.txt
                                      0       iobroker
                                      0       iob
                                        @holla16
                                        sudo journalctl --vacuum-time=1d
                                          pi@raspberrypi:/opt/iobroker $ sudo journalctl --vacuum-time=1d
                                          Journal file /var/log/journal/01a56749d6014a4a88a8e1ae7e3c25b9/system.journal is truncated, ignoring file.
                                          Vacuuming done, freed 0B of archived journals from /var/log/journal.
                                          Deleted empty archived journal /var/log/journal/01a56749d6014a4a88a8e1ae7e3c25b9/system@00060e431bf4377d-29094d0e0283d9c4.journal~ (4.0K).
                                          Deleted empty archived journal /var/log/journal/01a56749d6014a4a88a8e1ae7e3c25b9/system@00060e431bf60270-5ed240af70674cab.journal~ (16.0K).
                                          Deleted empty archived journal /var/log/journal/01a56749d6014a4a88a8e1ae7e3c25b9/user-1001@00060e412865f478-c67b3d07a3effefe.journal~ (0B).
                                          Deleted empty archived journal /var/log/journal/01a56749d6014a4a88a8e1ae7e3c25b9/system@00060e4311051e99-63e627a9400cfabf.journal~ (4.0K).
                                          Deleted empty archived journal /var/log/journal/01a56749d6014a4a88a8e1ae7e3c25b9/system@00060e4128666972-6cc52e4157cb0ff4.journal~ (6.8M).
                                          Deleted empty archived journal /var/log/journal/01a56749d6014a4a88a8e1ae7e3c25b9/system@00060e431bfd91c1-7ce41f4661306f35.journal~ (16.0K).
                                          Deleted empty archived journal /var/log/journal/01a56749d6014a4a88a8e1ae7e3c25b9/system@00060e431bf47993-12a2a39f85f1a43d.journal~ (16.0K).
                                          Vacuuming done, freed 6.9M of archived journals from /var/log/journal/01a56749d6014a4a88a8e1ae7e3c25b9.
                                          Vacuuming done, freed 0B of archived journals from /run/log/journal/01a56749d6014a4a88a8e1ae7e3c25b9.
                                          Vacuuming done, freed 0B of archived journals from /run/log/journal.
                                            freed 6.9M
                                            Das ist natürlich nix.
                                            sudo ncdu /
                                            wird vermutlich nicht funktionieren.
                                            H Homoran 3 Replies Last reply Reply Quote 0
                                            12311
