    4. Influx DB Daten löschen? Wie? Kein zugriff auf den ioBroker
      Thomas Braun Most Active @holla16 last edited by
      @holla16 sagte in Keine Lan Verbundung zum Raspi / per SSH aber möglich:
      Können wir da nicht was löschen?
      Haben wir schon.
      df -h
        holla16 @Thomas Braun last edited by
        pi@raspberrypi:/opt/iobroker $ df -h
        Filesystem      Size  Used Avail Use% Mounted on
        /dev/root        59G   58G     0 100% /
        devtmpfs        3.7G     0  3.7G   0% /dev
        tmpfs           3.9G     0  3.9G   0% /dev/shm
        tmpfs           1.6G  9.1M  1.6G   1% /run
        tmpfs           5.0M  4.0K  5.0M   1% /run/lock
        /dev/mmcblk0p1  255M   31M  225M  12% /boot
        tmpfs           782M     0  782M   0% /run/user/1000
          @holla16
          cd /opt/iobroker
          du -cks * | sort -rn | head
            @thomas-braun said in Keine Lan Verbundung zum Raspi / per SSH aber möglich:
            pi@raspberrypi:/opt/iobroker $ cd /opt/iobroker
            pi@raspberrypi:/opt/iobroker $ du -cks * | sort -rn | head
            1456376 total
            1014316 node_modules
            371380  iobroker-data
            42608   log
            27060   backups
            1004    package-lock.json
            4       package.json
            4       INSTALLER_INFO.txt
            0       iobroker
            0       iob
              @holla16
              sudo journalctl --vacuum-time=1d
                pi@raspberrypi:/opt/iobroker $ sudo journalctl --vacuum-time=1d
                Journal file /var/log/journal/01a56749d6014a4a88a8e1ae7e3c25b9/system.journal is truncated, ignoring file.
                Vacuuming done, freed 0B of archived journals from /var/log/journal.
                Deleted empty archived journal /var/log/journal/01a56749d6014a4a88a8e1ae7e3c25b9/system@00060e431bf4377d-29094d0e0283d9c4.journal~ (4.0K).
                Deleted empty archived journal /var/log/journal/01a56749d6014a4a88a8e1ae7e3c25b9/system@00060e431bf60270-5ed240af70674cab.journal~ (16.0K).
                Deleted empty archived journal /var/log/journal/01a56749d6014a4a88a8e1ae7e3c25b9/user-1001@00060e412865f478-c67b3d07a3effefe.journal~ (0B).
                Deleted empty archived journal /var/log/journal/01a56749d6014a4a88a8e1ae7e3c25b9/system@00060e4311051e99-63e627a9400cfabf.journal~ (4.0K).
                Deleted empty archived journal /var/log/journal/01a56749d6014a4a88a8e1ae7e3c25b9/system@00060e4128666972-6cc52e4157cb0ff4.journal~ (6.8M).
                Deleted empty archived journal /var/log/journal/01a56749d6014a4a88a8e1ae7e3c25b9/system@00060e431bfd91c1-7ce41f4661306f35.journal~ (16.0K).
                Deleted empty archived journal /var/log/journal/01a56749d6014a4a88a8e1ae7e3c25b9/system@00060e431bf47993-12a2a39f85f1a43d.journal~ (16.0K).
                Vacuuming done, freed 6.9M of archived journals from /var/log/journal/01a56749d6014a4a88a8e1ae7e3c25b9.
                Vacuuming done, freed 0B of archived journals from /run/log/journal/01a56749d6014a4a88a8e1ae7e3c25b9.
                Vacuuming done, freed 0B of archived journals from /run/log/journal.
                  freed 6.9M
                  Das ist natürlich nix.
                  sudo ncdu /
                  wird vermutlich nicht funktionieren.
                  H Homoran 3 Replies Last reply Reply Quote 0
                    sudo ncdu /
                    Es öffnet sich ein neues "Fenster" mit diesen Infos:
                        1.5 GiB [          ] /usr
                        1.4 GiB [          ] /opt
                      440.7 MiB [          ] /home
                       30.5 MiB [          ] /boot
                        9.1 MiB [          ] /run
                        3.9 MiB [          ] /etc
                       32.0 KiB [          ] /root
                       24.0 KiB [          ] /tmp
                    e  16.0 KiB [          ] /lost+found
                    e   4.0 KiB [          ] /srv
                    e   4.0 KiB [          ] /mnt
                    e   4.0 KiB [          ] /media
                        0.0   B [          ] /sys
                    .   0.0   B [          ] /proc
                        0.0   B [          ] /dev
                    @   0.0   B [          ]  sbin
                    @   0.0   B [          ]  lib
                    @   0.0   B [          ]  bin
                      soll ich da wieder raus und wenn ja wie?
                        @holla16
                        Nee, damit suchst du jetzt die dicken Dinger.
                          ok und das mache ich wie?
                            @holla16
                            Mit den Pfeiltasten durch die Verzeichnisse hangeln. Die dicken haben die meisten #-Zeichen...
                            Bei mir also z. B.
                            ncdu 1.19 ~ Use the arrow keys to navigate, press ? for help
                                5.8 GiB [#################] /opt
                                2.6 GiB [#######          ] /usr
                                1.1 GiB [###              ] /var
                              906.9 MiB [##               ] /home
                              161.6 MiB [                 ] /boot
                               22.7 MiB [                 ] /tmp
                                5.5 MiB [                 ] /etc
                            Näheres dann per ?-Taste im Programm.
                              Homoran Global Moderator Administrators @holla16 last edited by
                              ist das alles?
                              du hast laut df -h 58GB voll
                                hab den Fehler gefunden. Es sind influxdb Daten:
                                --- /var/lib/influxdb/engine/data/ea8b2dc8c77648a5/autogen ----------------------------------------------------------------------------------------------------------------------------------------------------------------------------------                         /..
                                    1.6 GiB [##########] /91
                                    1.6 GiB [######### ] /89
                                    1.5 GiB [######### ] /87
                                    1.5 GiB [######### ] /85
                                    1.4 GiB [########  ] /83
                                    1.4 GiB [########  ] /81
                                    1.3 GiB [########  ] /79
                                    1.3 GiB [########  ] /109        1.3 GiB [#######   ] /77
                                    1.2 GiB [#######   ] /75
                                    1.2 GiB [#######   ] /107
                                    1.2 GiB [#######   ] /105
                                    1.2 GiB [#######   ] /93
                                    1.2 GiB [#######   ] /99
                                    1.2 GiB [#######   ] /73
                                    1.2 GiB [#######   ] /103
                                    1.1 GiB [######    ] /111
                                    1.1 GiB [######    ] /71
                                    1.1 GiB [######    ] /69
                                    1.1 GiB [######    ] /101
                                    1.0 GiB [######    ] /67
                                    1.0 GiB [######    ] /95
                                    1.0 GiB [######    ] /97
                                    1.0 GiB [######    ] /65
                                  955.4 MiB [#####     ] /63
                                  948.1 MiB [#####     ] /35
                                  913.8 MiB [#####     ] /51
                                  903.5 MiB [#####     ] /61
                                  897.4 MiB [#####     ] /33
                                  862.6 MiB [#####     ] /49
                                  861.2 MiB [#####     ] /37
                                  852.2 MiB [#####     ] /59
                                  846.1 MiB [#####     ] /31
                                  811.1 MiB [####      ] /47
                                  801.6 MiB [####      ] /57
                                  794.6 MiB [####      ] /29
                                  759.9 MiB [####      ] /45
                                  750.9 MiB [####      ] /55
                                  742.8 MiB [####      ] /27
                                  708.8 MiB [####      ] /43
                                  707.0 MiB [####      ] /53
                                  691.2 MiB [####      ] /25
                                  657.5 MiB [###       ] /41
                                  640.6 MiB [###       ] /23
                                  606.0 MiB [###       ] /39
                                  588.6 MiB [###       ] /21
                                  537.8 MiB [###       ] /18
                                  492.5 MiB [##        ] /16
                                  451.9 MiB [##        ] /14
                                  413.1 MiB [##        ] /12
                                  371.9 MiB [##        ] /10
                                  335.7 MiB [##        ] /8
                                  300.0 MiB [#         ] /6
                                  265.2 MiB [#         ] /4
                                  242.7 MiB [#         ] /113
                                  114.5 MiB [          ] /1
                                  kann auf die influx bd. daten gern verzichten. Die liefen eh nur mit ohne, dass ich bisher damit was gemacht habe. Kann man die Löschen und wenn ja wie?
                                    Thomas Braun Most Active @holla16 last edited by Thomas Braun
                                    @holla16
                                    Bei influxdb kenne ich micht nicht aus.
                                    Löschen mit
                                    sudo apt purge influxdb*
                                    Edit: Wrong command... 🙂
                                      Homoran Global Moderator Administrators @Thomas Braun last edited by Homoran
                                      @thomas-braun sagte in Keine Lan Verbundung zum Raspi / per SSH aber möglich:
                                      @holla16
                                      Löschen mit
                                      sudo apt prune influxdb*
                                      löscht aber die Daten nicht
                                      kenne mich mit dem Influx Adapter nicht aus, aber ggf. kann man da auch die Aufbewahrungszeit reduzieren, dann werden alte Daten gelöscht
                                      Thomas Braun H 2 Replies Last reply Reply Quote 0
                                        @homoran sagte in Keine Lan Verbundung zum Raspi / per SSH aber möglich:
                                        Hast recht.
                                          holla16 @Homoran last edited by
                                          das kann ich ja gerne versuchen, ich komme in den iobroker aber nicht rein. Kein Zugriff per ip Adresse. nur über das Terminal. Heißt den Adapter kann ich aktuell wegen dem vollen speicher nicht konfigurieren. Heißt da müssen daten weg. Nur wie und welche?
                                            Homoran Global Moderator Administrators @holla16 last edited by Homoran
                                            logdateien in /opt/iobroker/logs
                                            leider zeigst du nicht alles.
                                            Hab vorhin schon nachgefragt
                                            12311
