    4. Influx DB Daten löschen? Wie? Kein zugriff auf den ioBroker
      holla16 @Thomas Braun last edited by
      @thomas-braun said in Keine Lan Verbundung zum Raspi / per SSH aber möglich:
      sudo journalctl --vacuum-time=1d
      pi@raspberrypi:/opt/iobroker $ sudo journalctl --vacuum-time=1d
      Journal file /var/log/journal/01a56749d6014a4a88a8e1ae7e3c25b9/system.journal is truncated, ignoring file.
      Vacuuming done, freed 0B of archived journals from /var/log/journal.
      Deleted empty archived journal /var/log/journal/01a56749d6014a4a88a8e1ae7e3c25b9/system@00060e431bf4377d-29094d0e0283d9c4.journal~ (4.0K).
      Deleted empty archived journal /var/log/journal/01a56749d6014a4a88a8e1ae7e3c25b9/system@00060e431bf60270-5ed240af70674cab.journal~ (16.0K).
      Deleted empty archived journal /var/log/journal/01a56749d6014a4a88a8e1ae7e3c25b9/user-1001@00060e412865f478-c67b3d07a3effefe.journal~ (0B).
      Deleted empty archived journal /var/log/journal/01a56749d6014a4a88a8e1ae7e3c25b9/system@00060e4311051e99-63e627a9400cfabf.journal~ (4.0K).
      Deleted empty archived journal /var/log/journal/01a56749d6014a4a88a8e1ae7e3c25b9/system@00060e4128666972-6cc52e4157cb0ff4.journal~ (6.8M).
      Deleted empty archived journal /var/log/journal/01a56749d6014a4a88a8e1ae7e3c25b9/system@00060e431bfd91c1-7ce41f4661306f35.journal~ (16.0K).
      Deleted empty archived journal /var/log/journal/01a56749d6014a4a88a8e1ae7e3c25b9/system@00060e431bf47993-12a2a39f85f1a43d.journal~ (16.0K).
      Vacuuming done, freed 6.9M of archived journals from /var/log/journal/01a56749d6014a4a88a8e1ae7e3c25b9.
      Vacuuming done, freed 0B of archived journals from /run/log/journal/01a56749d6014a4a88a8e1ae7e3c25b9.
      Vacuuming done, freed 0B of archived journals from /run/log/journal.
        Thomas Braun Most Active @holla16 last edited by
        @holla16 sagte in Keine Lan Verbundung zum Raspi / per SSH aber möglich:
        freed 6.9M
        Das ist natürlich nix.
        sudo ncdu /
        wird vermutlich nicht funktionieren.
        H Homoran 3 Replies Last reply Reply Quote 0
          sudo ncdu /
          Es öffnet sich ein neues "Fenster" mit diesen Infos:
              1.5 GiB [          ] /usr
              1.4 GiB [          ] /opt
            440.7 MiB [          ] /home
             30.5 MiB [          ] /boot
              9.1 MiB [          ] /run
              3.9 MiB [          ] /etc
             32.0 KiB [          ] /root
             24.0 KiB [          ] /tmp
          e  16.0 KiB [          ] /lost+found
          e   4.0 KiB [          ] /srv
          e   4.0 KiB [          ] /mnt
          e   4.0 KiB [          ] /media
              0.0   B [          ] /sys
          .   0.0   B [          ] /proc
              0.0   B [          ] /dev
          @   0.0   B [          ]  sbin
          @   0.0   B [          ]  lib
          @   0.0   B [          ]  bin
            soll ich da wieder raus und wenn ja wie?
              @holla16
              Nee, damit suchst du jetzt die dicken Dinger.
                ok und das mache ich wie?
                  @holla16
                  Mit den Pfeiltasten durch die Verzeichnisse hangeln. Die dicken haben die meisten #-Zeichen...
                  Bei mir also z. B.
                  ncdu 1.19 ~ Use the arrow keys to navigate, press ? for help
                      5.8 GiB [#################] /opt
                      2.6 GiB [#######          ] /usr
                      1.1 GiB [###              ] /var
                    906.9 MiB [##               ] /home
                    161.6 MiB [                 ] /boot
                     22.7 MiB [                 ] /tmp
                      5.5 MiB [                 ] /etc
                  Näheres dann per ?-Taste im Programm.
                    Homoran Global Moderator Administrators @holla16 last edited by
                    ist das alles?
                    du hast laut df -h 58GB voll
                      hab den Fehler gefunden. Es sind influxdb Daten:
                      --- /var/lib/influxdb/engine/data/ea8b2dc8c77648a5/autogen ----------------------------------------------------------------------------------------------------------------------------------------------------------------------------------                         /..
                          1.6 GiB [##########] /91
                          1.6 GiB [######### ] /89
                          1.5 GiB [######### ] /87
                          1.5 GiB [######### ] /85
                          1.4 GiB [########  ] /83
                          1.4 GiB [########  ] /81
                          1.3 GiB [########  ] /79
                          1.3 GiB [########  ] /109        1.3 GiB [#######   ] /77
                          1.2 GiB [#######   ] /75
                          1.2 GiB [#######   ] /107
                          1.2 GiB [#######   ] /105
                          1.2 GiB [#######   ] /93
                          1.2 GiB [#######   ] /99
                          1.2 GiB [#######   ] /73
                          1.2 GiB [#######   ] /103
                          1.1 GiB [######    ] /111
                          1.1 GiB [######    ] /71
                          1.1 GiB [######    ] /69
                          1.1 GiB [######    ] /101
                          1.0 GiB [######    ] /67
                          1.0 GiB [######    ] /95
                          1.0 GiB [######    ] /97
                          1.0 GiB [######    ] /65
                        955.4 MiB [#####     ] /63
                        948.1 MiB [#####     ] /35
                        913.8 MiB [#####     ] /51
                        903.5 MiB [#####     ] /61
                        897.4 MiB [#####     ] /33
                        862.6 MiB [#####     ] /49
                        861.2 MiB [#####     ] /37
                        852.2 MiB [#####     ] /59
                        846.1 MiB [#####     ] /31
                        811.1 MiB [####      ] /47
                        801.6 MiB [####      ] /57
                        794.6 MiB [####      ] /29
                        759.9 MiB [####      ] /45
                        750.9 MiB [####      ] /55
                        742.8 MiB [####      ] /27
                        708.8 MiB [####      ] /43
                        707.0 MiB [####      ] /53
                        691.2 MiB [####      ] /25
                        657.5 MiB [###       ] /41
                        640.6 MiB [###       ] /23
                        606.0 MiB [###       ] /39
                        588.6 MiB [###       ] /21
                        537.8 MiB [###       ] /18
                        492.5 MiB [##        ] /16
                        451.9 MiB [##        ] /14
                        413.1 MiB [##        ] /12
                        371.9 MiB [##        ] /10
                        335.7 MiB [##        ] /8
                        300.0 MiB [#         ] /6
                        265.2 MiB [#         ] /4
                        242.7 MiB [#         ] /113
                        114.5 MiB [          ] /1
                        kann auf die influx bd. daten gern verzichten. Die liefen eh nur mit ohne, dass ich bisher damit was gemacht habe. Kann man die Löschen und wenn ja wie?
                          Thomas Braun Most Active @holla16 last edited by Thomas Braun
                          @holla16
                          Bei influxdb kenne ich micht nicht aus.
                          Löschen mit
                          sudo apt purge influxdb*
                          Edit: Wrong command... 🙂
                            Homoran Global Moderator Administrators @Thomas Braun last edited by Homoran
                            @thomas-braun sagte in Keine Lan Verbundung zum Raspi / per SSH aber möglich:
                            @holla16
                            Löschen mit
                            sudo apt prune influxdb*
                            löscht aber die Daten nicht
                            kenne mich mit dem Influx Adapter nicht aus, aber ggf. kann man da auch die Aufbewahrungszeit reduzieren, dann werden alte Daten gelöscht
                            Thomas Braun H 2 Replies Last reply Reply Quote 0
                              @homoran sagte in Keine Lan Verbundung zum Raspi / per SSH aber möglich:
                              Hast recht.
                                holla16 @Homoran last edited by
                                das kann ich ja gerne versuchen, ich komme in den iobroker aber nicht rein. Kein Zugriff per ip Adresse. nur über das Terminal. Heißt den Adapter kann ich aktuell wegen dem vollen speicher nicht konfigurieren. Heißt da müssen daten weg. Nur wie und welche?
                                  Homoran Global Moderator Administrators @holla16 last edited by Homoran
                                  logdateien in /opt/iobroker/logs
                                  leider zeigst du nicht alles.
                                  Hab vorhin schon nachgefragt
                                    das sind alle 57 gb daten: Und daher die Frage ob man die löschen kann? Dann wäre die Hoffnung wieder per IP Adresse auf den ioBroker zugreifen zu können und dann würde ich den Adapter neu konfigurieren.
                                      114.4 MiB [  0.2%] /1
                                      371.8 MiB [  0.7%] /10
                                        1.1 GiB [  2.1%] /101
                                        1.2 GiB [  2.3%] /103
                                        1.2 GiB [  2.4%] /105
                                        1.2 GiB [  2.4%] /107
                                        1.3 GiB [  2.6%] /109
                                        1.1 GiB [  2.3%] /111
                                      242.6 MiB [  0.5%] /113
                                      413.0 MiB [  0.8%] /12
                                      451.9 MiB [  0.9%] /14
                                      492.4 MiB [  1.0%] /16
                                      537.8 MiB [  1.0%] /18
                                      588.6 MiB [  1.1%] /21
                                      640.5 MiB [  1.2%] /23
                                      691.1 MiB [  1.3%] /25
                                      742.8 MiB [  1.4%] /27
                                      794.5 MiB [  1.5%] /29
                                      846.0 MiB [  1.6%] /31
                                      897.3 MiB [  1.7%] /33
                                      948.1 MiB [  1.8%] /35
                                      861.1 MiB [  1.7%] /37
                                      606.0 MiB [  1.2%] /39
                                      265.2 MiB [  0.5%] /4
                                      657.4 MiB [  1.3%] /41
                                      708.8 MiB [  1.4%] /43
                                      759.9 MiB [  1.5%] /45
                                      811.1 MiB [  1.6%] /47
                                      862.6 MiB [  1.7%] /49
                                      913.7 MiB [  1.8%] /51
                                      706.9 MiB [  1.4%] /53
                                      750.8 MiB [  1.5%] /55
                                      801.5 MiB [  1.6%] /57
                                      852.2 MiB [  1.7%] /59
                                      299.9 MiB [  0.6%] /6
                                      903.5 MiB [  1.8%] /61
                                      955.4 MiB [  1.9%] /63
                                        1.0 GiB [  2.0%] /65
                                        1.0 GiB [  2.1%] /67
                                        1.1 GiB [  2.2%] /69
                                        1.1 GiB [  2.3%] /71
                                        1.2 GiB [  2.4%] /73
                                        1.2 GiB [  2.5%] /75
                                        1.3 GiB [  2.6%] /77        1.3 GiB [  2.7%] /79
                                      335.7 MiB [  0.7%] /8
                                        1.4 GiB [  2.8%] /81
                                        1.4 GiB [  2.9%] /83
                                        1.5 GiB [  3.0%] /85
                                        1.5 GiB [  3.1%] /87
                                        1.6 GiB [  3.2%] /89
                                        1.6 GiB [  3.3%] /91
                                        1.2 GiB [  2.4%] /93
                                        1.0 GiB [  2.0%] /95
                                        1.0 GiB [  2.0%] /97
                                        1.2 GiB [  2.4%] /9
                                      Homoran Global Moderator Administrators @Homoran last edited by
                                      ist das alles?
                                      und wie sehen die 58GB in ncdu aus?
                                      aber unsortiert!
                                        @holla16
                                        Datenbanken bzw. deren Dateninhalte kann man in der Regel irgendwie vernünftig löschen. Steht bestimmt in der Dokumentation dazu drin.
                                        Wenn sich hier niemand findet, der den aus dem Ärmel schüttelt.
                                        Jedenfalls würde ich das nicht 'doofstumpf' einfach löschen.
                                          @thomas-braun möglicherweise gibt es noch mehr dicke Brummer.
                                          syslog, iob log, backups.....
                                          aver ncdu scheint ja mitten raus kopiert zu sein.
                                            Ja, aber die ganz dicken Kinder wohnen offenbar in
                                            Wenn da Platz ist und man wieder Luft zum atmen hat könnte man sich den Rest auch anschauen.
                                            12291
