Brother Drucker
@homoran sagte in Brother Drucker:
Es wird wärmer:
Hier nochmal für BLACK:<?xml version="1.0" encoding="iso-8859-1"?><!DOCTYPE html PUBLIC "-//W3C//DTD XHTML 1.0 Strict//EN" "http://www.w3.org/TR/xhtml1/DTD/xhtml1-strict.dtd"><html lang="en-gb" xmlns="http://www.w3.org/1999/xhtml" xml:lang="en-gb"><head><meta http-equiv="Content-Script-Type" content="text/javascript" /><meta http-equiv="content-style-type" content="text/css" /><meta http-equiv="Content-Type" content="text/html; charset=iso-8859-1" /><meta http-equiv="X-UA-Compatible" content="IE=edge"><script type="text/javascript" src="/common/js/ews.js"></script><link rel="stylesheet" type="text/css" href="../common/css/mobile_common.css" /> <link rel="stylesheet" type="text/css" href="../common/css/mobile_ews.css" /> <script type="text/javascript" src="../common/js/cookie.js"></script> <script type="text/javascript" src="../common/js/language.js"></script> <script type="text/javascript" src="../common/js/lcddisplay.js"></script> <title>Brother MFC-J6940DW</title><meta name="viewport" content="width=device-width, initial-scale=1.0, maximum-scale=1, user-scalable=no" /></head><body><div id="headerFrame"><div id="menuButton" layout="pc" onclick="toggleMenu();"><img src="/common/images/menu_icon.gif" alt="Menu"></div><div id="modelName" layout="pc">MFC-J6940DW</div><div id="corporateLogo" layout="pc"><img src="/common/images/logo.gif" alt="Brother" /></div></div></div><div id="Menu" layout="pc"><div id="navigationContainer"><div id="navMenu"><div id="LayoutButton"><img id="PCButton" layout="pc" src="/common/images/chevron_left.gif" onclick="changeLayout('user_layout','mobile');"></img><img id="MobileButton" layout="pc" src="/common/images/pin.gif" onclick="changeLayout('user_layout','pc');"></img></div><hr><div id="httpmessage">You must redirect to a secure HTTPS page in order to log in.<br /><br />If a security certification warning appears, follow the connection instructions to accept the certificate.</div><div class="links"><a href="https://update.brother.co.jp/device/redirect.aspx?redirecttype=6&country=w&lang=en&device=MFC-J6940DW&alias=aqfr" target="_blank">More Information</a></div><div id="ChangeToHTTPSButton"><input type="button" onclick="redirech_to_https()" value="Open Secure Login" /></div><hr><div id="menu_tree_root"><div class="menuLv1"><a href="#" onclick="expandMenu('home_sub');">Home</a><div id="home_sub" class="open"><div class="menuLv2 selected"><a href="../home/status.html">Status</a></div><div class="menuLv2"><a href="/home/reflesh.html" class="subMenu">Auto Refresh Interval</a></div></div></div><hr></div></div></div></div><div id="Page" layout="pc"><div id="rightFrameContainer"><div id="rightFrame"><div id="mainContent"><div id="pageTitle"><h2>Status</h2></div><div id="pageContents"><form method="post" action="/home/status.html"><div><input type="hidden" id="pageid" name="pageid" value="1" /></div><div class="contentsGroup"><dl class="items"><dt>Device Status</dt><dd><div id="moni_data"><span class="moni moniOk">Energiesparen</span></div></dd><dt class="subhead"><span>Automatic Refresh</span></dt><dd><div><label class="radioSimple"><input type="radio" name="Refresh" value="0" onclick="refreshLCD(0);" checked="checked" /> Off</label><label class="radioSimple"><input type="radio" name="Refresh" value="1" onclick="refreshLCD(60000);" /> On</label></div></dd><dt>Estimated Ink Level</dt><dd><div id="ink_level"><table id="inkLevel" summary="ink level"><tr><th></th><th></th><th></th><th></th></tr><tr><td><img src="../common/images/magenta.gif" alt="Magenta" class="tonerremain" height="45" /></td><td><img src="../common/images/cyan.gif" alt="Cyan" class="tonerremain" height="45" /></td><td><img src="../common/images/yellow.gif" alt="Yellow" class="tonerremain" height="41" /></td><td><img src="../common/images/black.gif" alt="Black" class="tonerremain" height="53" /></td></tr><tr><th>M</th><th>C</th><th>Y</th><th>BK</th></tr></table></div></dd><dt>Remaining Page Yield </dt><dd></dd><dt class="subhead"><span>Approximate Page Yield (ISO-based)</span></dt><dd><div id="possible_print_num"><table id="possiblePrintNum" summary="possible print number"><tr id="format_iso" style="display:;"><th><span>300</span></th><th><span>300</span></th><th><span>300</span></th><th><span>350</span></th></tr><tr><th>M</th><th>C</th><th>Y</th><th>BK</th></tr></table><p class="noteMessage">*The remaining page yields are approximated and may vary depending on the type of pages printed.</p></div></dd></dl></div><div class="contentsGroup"><dl class="items"><dt>Web Language</dt><dd><select id="Language" name="Language" onchange="changeLanguage('Language', 'WebLang');"><option value="0" selected="selected">Auto</option><option value="2">English</option><option value="3">French</option><option value="4">German</option><option value="5">Dutch</option><option value="6">Spanish</option><option value="7">Italian</option><option value="10">Russian</option><option value="9">Chinese</option><option value="11">Portuguese</option><option value="18">Norwegian</option></select></dd></dl></div><div class="contentsGroup"><dl class="items"><dt>Device Location</dt><dd><ul class="itemList"><li class="contact">Contact<span class="spacer">:</span></li><li class="location">Location<span class="spacer">:</span></li></ul></dd></dl></div></form></div></div></div></div><script type="text/javascript"> <!-- judge_refresh(60000); //--> </script> </div></div><div id="footerFrame">Copyright(C) 2000-2021 Brother Industries, Ltd. All Rights Reserved.</div><script type="text/javascript" src="/common/js/mobilemenucontrl.js"></script><script>window.onpageshow = function(event) {if (event.persisted) { window.location.reload(); }};</script></body></html> -
@axel-koeneke sagte in Brother Drucker:
Es wird wärmer:
und was willst du damit es heiss wird?
Evtl kennst du die benötigten Parameter für den Parser.
Mit deinen Angaben kommt jetzt ja schon mal etwas. Leider noch nicht die richtigen Zahlen. -
doch!
zumindest das, was nach deinem Seiteninhalt als Füllstand ausgegeben wird.Warum Schwarz bei dir mit 100% angezeigt wird ist mir ein Rätsel.
doch!
Könntest du das begründen?
Sind die Werte %-Angaben für Füllstand?
Ich dachte man bekommt damit die Anzahl der zu bedruckenden Seiten, wie im Screenshot oben... -
das ist eine grobe Schätzung bei Verbrauch nach ISO.
Steht auch so da.EDIT:
Reihenfolge musst du selber rausfinden, wahrscheinlich wie oben
ay:[^\d]+(\d+)
ay:[^\d]+\d+[^\d]+(\d+)
ay:[^\d]+\d+[^\d]+\d+[^\d]+(\d+)
ay:[^\d]+\d+[^\d]+\d+[^\d]+\d+[^\d]+(\d+) -
Super, vielen Dank
@axel-koeneke kannst du mir mal auf die Sprünge helfen, welche Daten du im Parser hast, damit die die Füllstände bekommst? Ich verzweifle so langsam.
diesen Drucker habe ich, vielleicht hat diesen auch jemand, aber ich glaube, die Unterschiede werden nicht sehr groß sein. Brother MFC-L3750CDW
Falls jemand den gleichen Drucker hat wie ich, geht alles mit der Holzhammermethode.
Toner Cyan.{19}>([\d]+)
Toner Magenta.{19}([\d]+)
Toner Yellow.{19}([\d]+)
Toner Black.{20}([\d]+)So bekomme ich alle Werte für die Farben. Allerding ist der Parser Adapter die absolute Katastrophe. Der macht beim einstellen was er will. Außerdem ist auch Lustig, die Webseite vom Drucker ist deutsch, im Parser ist es auf einmal Englisch, dass muss man erstmal sehen. Also die Werte oben funktionieren.
@rissn Habe den Brother MFC-9332CDW und es nun wie folgt hinbekommen:
\(BK\)\*\*<\/dt><dd>\(([0-9.]*)%\) \(C\)\*\*<\/dt><dd>\(([0-9.]*)%\) \(M\)\*\*<\/dt><dd>\(([0-9.]*)%\) \(Y\)\*\*<\/dt><dd>\(([0-9.]*)%\)für weitere Farben das BK in C oder M oder Y tauschen.
Probiert hatte ich es vorher auf
https://regex101.com/Der Trick beim Bearbeiten im Parser ist es, nach dem Hinzufügen einer Zeile per + nur den Namen zu schreiben, dann zu speichern und anschließend erneut zu bearbeiten. Falls speichern nicht verfügbar ist einfach schließen unten rechts. Dabei sollte der Parser die ganze Zeit auf pausiert stehen!! Parser erst nach Abschluss von allem starten und freuen.
LG
