    4. Influx DB Daten löschen? Wie? Kein zugriff auf den ioBroker
      Homoran Global Moderator Administrators @holla16 last edited by Homoran
      @holla16 sagte in Keine Lan Verbundung zum Raspi / per SSH aber möglich:
      da müssen daten weg. Nur wie und welche?
      logdateien in /opt/iobroker/logs
      leider zeigst du nicht alles.
      Hab vorhin schon nachgefragt
        holla16 @Homoran last edited by
        das sind alle 57 gb daten: Und daher die Frage ob man die löschen kann? Dann wäre die Hoffnung wieder per IP Adresse auf den ioBroker zugreifen zu können und dann würde ich den Adapter neu konfigurieren.
        --- /var/lib/influxdb/engine/data/ea8b2dc8c77648a5/autogen ----------------------------------------------------------------------------------------------------------------------------------------------------------------------------------                     /..
          114.4 MiB [  0.2%] /1
          371.8 MiB [  0.7%] /10
            1.1 GiB [  2.1%] /101
            1.2 GiB [  2.3%] /103
            1.2 GiB [  2.4%] /105
            1.2 GiB [  2.4%] /107
            1.3 GiB [  2.6%] /109
            1.1 GiB [  2.3%] /111
          242.6 MiB [  0.5%] /113
          413.0 MiB [  0.8%] /12
          451.9 MiB [  0.9%] /14
          492.4 MiB [  1.0%] /16
          537.8 MiB [  1.0%] /18
          588.6 MiB [  1.1%] /21
          640.5 MiB [  1.2%] /23
          691.1 MiB [  1.3%] /25
          742.8 MiB [  1.4%] /27
          794.5 MiB [  1.5%] /29
          846.0 MiB [  1.6%] /31
          897.3 MiB [  1.7%] /33
          948.1 MiB [  1.8%] /35
          861.1 MiB [  1.7%] /37
          606.0 MiB [  1.2%] /39
          265.2 MiB [  0.5%] /4
          657.4 MiB [  1.3%] /41
          708.8 MiB [  1.4%] /43
          759.9 MiB [  1.5%] /45
          811.1 MiB [  1.6%] /47
          862.6 MiB [  1.7%] /49
          913.7 MiB [  1.8%] /51
          706.9 MiB [  1.4%] /53
          750.8 MiB [  1.5%] /55
          801.5 MiB [  1.6%] /57
          852.2 MiB [  1.7%] /59
          299.9 MiB [  0.6%] /6
          903.5 MiB [  1.8%] /61
          955.4 MiB [  1.9%] /63
            1.0 GiB [  2.0%] /65
            1.0 GiB [  2.1%] /67
            1.1 GiB [  2.2%] /69
            1.1 GiB [  2.3%] /71
            1.2 GiB [  2.4%] /73
            1.2 GiB [  2.5%] /75
            1.3 GiB [  2.6%] /77        1.3 GiB [  2.7%] /79
          335.7 MiB [  0.7%] /8
            1.4 GiB [  2.8%] /81
            1.4 GiB [  2.9%] /83
            1.5 GiB [  3.0%] /85
            1.5 GiB [  3.1%] /87
            1.6 GiB [  3.2%] /89
            1.6 GiB [  3.3%] /91
            1.2 GiB [  2.4%] /93
            1.0 GiB [  2.0%] /95
            1.0 GiB [  2.0%] /97
            1.2 GiB [  2.4%] /9
          Homoran Global Moderator Administrators @Homoran last edited by
          @homoran sagte in Keine Lan Verbundung zum Raspi / per SSH aber möglich:
          Es öffnet sich ein neues "Fenster" mit diesen Infos:
          ist das alles?
          du hast laut df -h 58GB voll
          und wie sehen die 58GB in ncdu aus?
          aber unsortiert!
            Thomas Braun Most Active @holla16 last edited by
            @holla16
            Datenbanken bzw. deren Dateninhalte kann man in der Regel irgendwie vernünftig löschen. Steht bestimmt in der Dokumentation dazu drin.
            Wenn sich hier niemand findet, der den aus dem Ärmel schüttelt.
            Jedenfalls würde ich das nicht 'doofstumpf' einfach löschen.
              @thomas-braun möglicherweise gibt es noch mehr dicke Brummer.
              syslog, iob log, backups.....
              aver ncdu scheint ja mitten raus kopiert zu sein.
                Ja, aber die ganz dicken Kinder wohnen offenbar in
                Wenn da Platz ist und man wieder Luft zum atmen hat könnte man sich den Rest auch anschauen.
                  @thomas-braun genau, man muss jetzt nur so viel wegbekommen bis man wieder drauf kommt.
                  Dann da den Rest mit influx angehen.
                    ja genau. Mir würde es reichen, wenn ich was lösche, wieder auf den ioBroker komme und von da aus ein Backup nach google machen, neu aufsetzen mit dem Backup und vorher noch Skripte, etc. sichern. Formatieren und alles neu machen und aus dieser Enkenntnis etwas anders influx und den ioBroker bei den Backups konfigurieren.
                      @holla16
                      iob stop iobroker.influxdb
                      sudo systemctl stop influxd*
                      sollte zumindest den Zufluss an neuen Datensätzen ausschalten.
                      Wie man die bestehenden Datenbanken richtig verkleinert oder löscht kann ich dir aber nicht sagen.
                      Vielleicht änderst du den Titel dahingehend ab, dann sieht es vielleicht jemand der es weiß.
                        dann zeig doch endlich die korrekte Ausgabe von ncdu
                          wie komme ich denn dahin?
                            @thomas-braun sagte in Keine Lan Verbundung zum Raspi / per SSH aber möglich:
                            sudo ncdu /
                            • DJMarc75
                              DJMarc75 last edited by
                              vll kann @Marc-Berg da etwas zu sagen ?!
                                Thomas Braun Most Active @DJMarc75 last edited by
                                @djmarc75
                                Ich hatte eben nach dem Nick von ihm gesucht. Ich wusste da war jemand mit Datenbank-Fachwissen...
                                  in der ncdu bin ich doch. Wenn ich die aufrufe kommt das
                                  --- / ---------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------   30.2 MiB [  0.1%] /boot        11.5 KiB [  0.0%] /dev
                                      2.3 MiB [  0.0%] /etc
                                    421.9 MiB [  0.7%] /home
                                  e  16.0 KiB [  0.0%] /lost+found
                                  e   4.0 KiB [  0.0%] /media
                                  e   4.0 KiB [  0.0%] /mnt
                                      1.3 GiB [  2.2%] /opt
                                  . 245.2 KiB [  0.0%] /proc
                                     21.0 KiB [  0.0%] /root
                                      8.1 MiB [  0.0%] /run
                                  e   4.0 KiB [  0.0%] /srv
                                     45.7 MiB [  0.1%] /sys
                                     24.0 KiB [  0.0%] /tmp
                                      1.4 GiB [  2.4%] /usr
                                     54.7 GiB [ 94.5%] /var
                                  @   7.0   B [  0.0%]  bin
                                  @   7.0   B [  0.0%]  lib
                                  @   8.0   B [  0.0%]  sbin
                                  Wenn ich dann in den Ordner mit den 54,7gb gehe kommen mehrere Unterordner. Die Inhalte der Unterordner haben eine geringe Datengröße. Der Inhalt des größten Ordners mit den meisten Daten (>50gb) sieht dann so aus:
                                  ncdu 1.15.1 ~ Use the arrow keys to navigate, press ? for help        --- /var/lib/influxdb/engine/data/ea8b2dc8c77648a5/autogen ----------------------------------------------------------------------------------------------------------------------------------------------------------------------------------                     /..
                                      1.1 GiB [  2.1%] /101        1.2 GiB [  2.3%] /103
                                      1.0 GiB [  2.0%] /65
                                      1.0 GiB [  2.1%] /67
                                      1.1 GiB [  2.2%] /69
                                      1.1 GiB [  2.3%] /71
                                      1.2 GiB [  2.4%] /73
                                      1.2 GiB [  2.5%] /75
                                      1.3 GiB [  2.6%] /77
                                      1.3 GiB [  2.7%] /79
                                      1.4 GiB [  2.8%] /81
                                      1.4 GiB [  2.9%] /83
                                      1.5 GiB [  3.0%] /85
                                      1.5 GiB [  3.1%] /87
                                      1.6 GiB [  3.2%] /89
                                      1.6 GiB [  3.3%] /91
                                      1.2 GiB [  2.4%] /93
                                      1.0 GiB [  2.0%] /95
                                      1.0 GiB [  2.0%] /97
                                      1.2 GiB [  2.4%] /99
                                  In einem weiteren Unterbeispielordner ist dann je eine große Datei drin
                                  ncdu 1.15.1 ~ Use the arrow keys to navigate, press ? for help        --- /var/lib/influxdb/engine/data/ea8b2dc8c77648a5/autogen/103 ------------------------------------------------------------------------------------------------------------------------------------------------------------------------------                     /..
                                    654.0 KiB [  0.1%] /index
                                      1.2 GiB [ 99.9%]  000000094-000000002.tsm        6.0 KiB [  0.0%]  fields.idx
                                    das müsste mit den dicksten Verzeichnissen beginnen
                                      ne dachte ichz auch. Das dickste Verzeichnis ist weiter unten mit 54,7gb
                                        Hab es noch mal neu aufgerufen da kommt das
                                        ncdu 1.15.1 ~ Use the arrow keys to navigate, press ? for help        --- / ---------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------
                                           54.7 GiB [##########] /var
                                            1.5 GiB [          ] /usr
                                            1.4 GiB [          ] /opt
                                          440.7 MiB [          ] /home
                                           30.5 MiB [          ] /boot
                                            9.1 MiB [          ] /run
                                            3.9 MiB [          ] /etc
                                           32.0 KiB [          ] /root
                                           24.0 KiB [          ] /tmp
                                        e  16.0 KiB [          ] /lost+found
                                        e   4.0 KiB [          ] /srv
                                        e   4.0 KiB [          ] /mnt
                                        e   4.0 KiB [          ] /media
                                            0.0   B [          ] /sys
                                        .   0.0   B [          ] /proc
                                            0.0   B [          ] /dev
                                        @   0.0   B [          ]  sbin
                                        @   0.0   B [          ]  lib
                                        @   0.0   B [          ]  bin
                                          dann nutzt das nichts
                                          sollte sortiert sein
                                            da kommt das
                                            geht doch!
                                            mach mal /opt/iobroker auf
                                            ausser @Thomas-Braun kann dir was aus /var empfehlen
                                            Thomas Braun H 2 Replies Last reply Reply Quote 0
                                            12295
