    4. Influx DB Daten löschen? Wie? Kein zugriff auf den ioBroker
      holla16 @Homoran last edited by
      in der ncdu bin ich doch. Wenn ich die aufrufe kommt das
      --- / ---------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------   30.2 MiB [  0.1%] /boot        11.5 KiB [  0.0%] /dev
          2.3 MiB [  0.0%] /etc
        421.9 MiB [  0.7%] /home
      e  16.0 KiB [  0.0%] /lost+found
      e   4.0 KiB [  0.0%] /media
      e   4.0 KiB [  0.0%] /mnt
          1.3 GiB [  2.2%] /opt
      . 245.2 KiB [  0.0%] /proc
         21.0 KiB [  0.0%] /root
          8.1 MiB [  0.0%] /run
      e   4.0 KiB [  0.0%] /srv
         45.7 MiB [  0.1%] /sys
         24.0 KiB [  0.0%] /tmp
          1.4 GiB [  2.4%] /usr
         54.7 GiB [ 94.5%] /var
      @   7.0   B [  0.0%]  bin
      @   7.0   B [  0.0%]  lib
      @   8.0   B [  0.0%]  sbin
      Wenn ich dann in den Ordner mit den 54,7gb gehe kommen mehrere Unterordner. Die Inhalte der Unterordner haben eine geringe Datengröße. Der Inhalt des größten Ordners mit den meisten Daten (>50gb) sieht dann so aus:
      ncdu 1.15.1 ~ Use the arrow keys to navigate, press ? for help        --- /var/lib/influxdb/engine/data/ea8b2dc8c77648a5/autogen ----------------------------------------------------------------------------------------------------------------------------------------------------------------------------------                     /..
        114.4 MiB [  0.2%] /1
        371.8 MiB [  0.7%] /10
          1.1 GiB [  2.1%] /101        1.2 GiB [  2.3%] /103
          1.2 GiB [  2.4%] /105
          1.2 GiB [  2.4%] /107
          1.3 GiB [  2.6%] /109
          1.1 GiB [  2.3%] /111
        242.6 MiB [  0.5%] /113
        413.0 MiB [  0.8%] /12
        451.9 MiB [  0.9%] /14
        492.4 MiB [  1.0%] /16
        537.8 MiB [  1.0%] /18
        588.6 MiB [  1.1%] /21
        640.5 MiB [  1.2%] /23
        691.1 MiB [  1.3%] /25
        742.8 MiB [  1.4%] /27
        794.5 MiB [  1.5%] /29
        846.0 MiB [  1.6%] /31
        897.3 MiB [  1.7%] /33
        948.1 MiB [  1.8%] /35
        861.1 MiB [  1.7%] /37
        606.0 MiB [  1.2%] /39
        265.2 MiB [  0.5%] /4
        657.4 MiB [  1.3%] /41
        708.8 MiB [  1.4%] /43
        759.9 MiB [  1.5%] /45
        811.1 MiB [  1.6%] /47
        862.6 MiB [  1.7%] /49
        913.7 MiB [  1.8%] /51
        706.9 MiB [  1.4%] /53
        750.8 MiB [  1.5%] /55
        801.5 MiB [  1.6%] /57
        852.2 MiB [  1.7%] /59
        299.9 MiB [  0.6%] /6
        903.5 MiB [  1.8%] /61
        955.4 MiB [  1.9%] /63
          1.0 GiB [  2.0%] /65
          1.0 GiB [  2.1%] /67
          1.1 GiB [  2.2%] /69
          1.1 GiB [  2.3%] /71
          1.2 GiB [  2.4%] /73
          1.2 GiB [  2.5%] /75
          1.3 GiB [  2.6%] /77
          1.3 GiB [  2.7%] /79
        335.7 MiB [  0.7%] /8
          1.4 GiB [  2.8%] /81
          1.4 GiB [  2.9%] /83
          1.5 GiB [  3.0%] /85
          1.5 GiB [  3.1%] /87
          1.6 GiB [  3.2%] /89
          1.6 GiB [  3.3%] /91
          1.2 GiB [  2.4%] /93
          1.0 GiB [  2.0%] /95
          1.0 GiB [  2.0%] /97
          1.2 GiB [  2.4%] /99
      In einem weiteren Unterbeispielordner ist dann je eine große Datei drin
      ncdu 1.15.1 ~ Use the arrow keys to navigate, press ? for help        --- /var/lib/influxdb/engine/data/ea8b2dc8c77648a5/autogen/103 ------------------------------------------------------------------------------------------------------------------------------------------------------------------------------                     /..
        654.0 KiB [  0.1%] /index
          1.2 GiB [ 99.9%]  000000094-000000002.tsm        6.0 KiB [  0.0%]  fields.idx
        Homoran Global Moderator Administrators @holla16 last edited by
        @holla16 sagte in Keine Lan Verbundung zum Raspi / per SSH aber möglich:
        das müsste mit den dicksten Verzeichnissen beginnen
          ne dachte ichz auch. Das dickste Verzeichnis ist weiter unten mit 54,7gb
            Hab es noch mal neu aufgerufen da kommt das
            ncdu 1.15.1 ~ Use the arrow keys to navigate, press ? for help        --- / ---------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------
               54.7 GiB [##########] /var
                1.5 GiB [          ] /usr
                1.4 GiB [          ] /opt
              440.7 MiB [          ] /home
               30.5 MiB [          ] /boot
                9.1 MiB [          ] /run
                3.9 MiB [          ] /etc
               32.0 KiB [          ] /root
               24.0 KiB [          ] /tmp
            e  16.0 KiB [          ] /lost+found
            e   4.0 KiB [          ] /srv
            e   4.0 KiB [          ] /mnt
            e   4.0 KiB [          ] /media
                0.0   B [          ] /sys
            .   0.0   B [          ] /proc
                0.0   B [          ] /dev
            @   0.0   B [          ]  sbin
            @   0.0   B [          ]  lib
            @   0.0   B [          ]  bin
              dann nutzt das nichts
              sollte sortiert sein
                da kommt das
                geht doch!
                mach mal /opt/iobroker auf
                ausser @Thomas-Braun kann dir was aus /var empfehlen
                Thomas Braun H 2 Replies Last reply Reply Quote 0
                  Die journals in /var sind ja schon verkleinert.
                  Hier sollte der influx-Datenberg angepackt werden.
                    sorry aber wie geht /opt/iobroker?
                      @holla16 sagte in Influx DB Daten löschen? Wie? Kein zugriff auf den ioBroker:
                      2 runter 1 rechts
                        OK dann kommt das
                            1.0 GiB [##########] /node_modules
                          362.7 MiB [###       ] /iobroker-data
                           41.6 MiB [          ] /log
                           26.4 MiB [          ] /backups
                            1.0 MiB [          ]  package-lock.json
                            4.0 KiB [          ]  package.json
                            4.0 KiB [          ]  INSTALLER_INFO.txt
                            4.0 KiB [          ]  .npmrc
                        @   0.0   B [          ]  iob
                            0.0   B [          ]  iobroker
                            0.0   B [          ]  diag.sh
                        • Marc Berg
                          Marc Berg Most Active @holla16 last edited by Marc Berg
                          @holla16
                          Wenn du nicht mehr alle InfluxDB-Daten benötigst, könntest du die Vorhaltezeit verkürzen. Hast du InfluxDB 1.x oder 2.x? Wie heißt deine Datenbank/Bucket?
                          EDIT: aber auch hierfür benötigt man ein Minimum an freiem Speicherplatz
                            holla16 @Marc Berg last edited by
                            @marc-berg
                            ich glaube 1.X aber um die Vorhaltezeit zu verkürzen muss ich ja in die Instanz. Da komme ich aktuell nicht rein.
                            • Marc Berg
                              @marc-berg
                              das geht auch auf der Kommandozeile. Wenn du 1.x hast, starte
                              influx
                              Wenn du da drin bist
                              USE <DATEBANKNAME>
                              SHOW RETENTION POLICIES
                              Und dann sehen wir weiter.
                                holla16 @Marc Berg last edited by holla16
                                @marc-berg
                                wenn ich influx eingebe kommt das
                                pi@raspberrypi:~ $ influx
                                NAME:
                                   influx - Influx Client
                                USAGE:
                                   influx [command]
                                HINT: If you are looking for the InfluxQL shell from 1.x, run "influx v1 shell"
                                COMMANDS:
                                   version              Print the influx CLI version
                                   write                Write points to InfluxDB
                                   bucket               Bucket management commands
                                   completion           Generates completion scripts
                                   query                Execute a Flux query
                                   config               Config management commands
                                   org, organization    Organization management commands
                                   delete               Delete points from InfluxDB
                                   user                 User management commands
                                   task                 Task management commands
                                   telegrafs            List Telegraf configuration(s). Subcommands manage Telegraf configurations.
                                   dashboards           List Dashboard(s).
                                   export               Export existing resources as a template
                                   secret               Secret management commands
                                   v1                   InfluxDB v1 management commands
                                   auth, authorization  Authorization management commands
                                   apply                Apply a template to manage resources
                                   stacks               List stack(s) and associated templates. Subcommands manage stacks.
                                   template             Summarize the provided template
                                   bucket-schema        Bucket schema management commands
                                   scripts              Scripts management commands
                                   ping                 Check the InfluxDB /health endpoint
                                   setup                Setup instance with initial user, org, bucket
                                   backup               Backup database
                                   restore              Restores a backup directory to InfluxDB
                                   remote               Remote connection management commands
                                   replication          Replication stream management commands
                                   server-config        Display server config
                                   help, h              Shows a list of commands or help for one command
                                was muss ich als Name eingeben?
                                • Marc Berg
                                  Dann ist es keine 1.x, sondern 2.x
                                  Kommst Du auf die Weboberfläche der DB?
                                  http://<IP des RASPI>:8086
                                    @marc-berg
                                    ne auf die Weboberfläche geht mit der Ip und dem Port nicht.
                                    • Marc Berg
                                      Hast du die DB noch gestoppt?
                                      @thomas-braun sagte in Influx DB Daten löschen? Wie? Kein zugriff auf den ioBroker:
                                      sudo systemctl stop influxd*
                                      dann wieder starten.
                                      sudo systemctl start influxd*
                                        @marc-berg
                                        ist ausgeführt:
                                        pi@raspberrypi:~ $ sudo systemctl start influxd*
                                        Warning: systemctl start called with a glob pattern.
                                        Hint: unit globs expand to loaded units, so start will usually have no effect.
                                              Passing --all will also load units which are pulled in by other units.
                                              See systemctl(1) for more details.
                                        Job for influxdb.service failed because the control process exited with error code.
                                        See "systemctl status influxdb.service" and "journalctl -xe" for details.
                                        pi@raspberrypi:~ $
                                        auf die Weboberfläche komme ich aber noch nicht
                                        Marc Berg 2 Replies Last reply Reply Quote 0
                                        • Marc Berg
                                          Ich denke, die DB kann wegen deines Speicherproblems nicht gestartet werden. Puh ...
                                          • Marc Berg
                                            @holla16
                                            Ich glaube, jetzt hilft nur noch der Holzhammer. Wenn die Daten nicht zu wichtig sind, dann einfach einen Shard löschen:
                                            sudo rm -r /var/lib/influxdb/engine/data/ea8b2dc8c77648a5/autogen/1
                                            Den Raspi neu starten und schauen, ob die DB wieder hoch kommt. Dann auf die Oberfläche und die Vorhaltezeit verkürzen.
                                            12291
